02-NTP configuration commands | 134.19 KB |
ntp-service authentication enable
ntp-service authentication-keyid·
ntp-service in-interface disable·
ntp-service max-dynamic-sessions
ntp-service reliable authentication-keyid·
display ntp-service sessions
Use display ntp-service sessions to display information about all NTP sessions.
display ntp-service sessions [ verbose ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
verbose: Displays detailed information about all NTP sessions. If you do not specify this keyword, only brief information about the NTP sessions is displayed.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display brief information about all NTP sessions.
<Sysname> display ntp-service sessions
source reference stra reach poll now offset delay disper
[12345]127.127.1.0 127.127.1.0 3 1 64 33 0.0 0.0 0.0
note: 1 source(master),2 source(peer),3 selected,4 candidate,5 configured
Total associations : 1
source |
IP address of the clock source. |
reference |
Reference clock ID of the clock source: · If the reference clock is the local clock, the value of this field is related to the value of the stra field: ¡ If the value of the stra field is 0 or 1, this field is LOCL. ¡ If the stra field has another value, this field is the IP address of the local clock. · If the reference clock is the clock of another device on the network, the value of this field is the IP address of that device. |
stra |
Stratum level of the clock source, which determines the clock precision. The value is in the range of 1 to 16. The clock precision decreases from stratum 1 to stratum 16. A stratum 1 clock has the highest precision, and a stratum 16 clock is not synchronized. |
reach |
Reachability count of the clock source. 0 indicates that the clock source is unreachable. |
poll |
Poll interval in seconds, namely, the maximum interval between successive NTP messages. |
now |
Length of time from when the last NTP message was received or when the local clock was last updated to the current time. Time is in seconds by default. If the time length is greater than 2048 seconds, it is displayed in minutes. If greater than 300 minutes, in hours. If greater than 96 hours, in days. |
offset |
Offset of the system clock relative to the reference clock, in milliseconds. |
delay |
Roundtrip delay from the local device to the clock source, in milliseconds. |
disper |
Maximum error of the system clock relative to the reference source. |
[12345] |
· 1—Clock source selected by the system (the current reference source). · 2—Stratum level of the clock source is less than or equal to 15. · 3—This clock source has survived the clock selection algorithm. · 4—This clock source is a candidate clock source. · 5—This clock source was created by a configuration command. |
Total associations |
Total number of associations. |
# Display detailed information about all NTP sessions.
<Sysname> display ntp-service sessions verbose
clock source: 127.127.1.0
clock stratum: 3
clock status: configured, master, sane, valid
reference clock ID: 127.127.1.0
local mode: client, local poll: 6
peer mode: server, peer poll: 6
offset: 0.0000 ms,delay: 0.00 ms, disper: 0.02 ms
root delay: 0.00 ms, root disper: 10.00 ms
reach: 1, sync dist: 0.010, sync state: 2
precision: 2^18, version: 3, peer interface: InLoopBack0
reftime: 10:56:22.442 UTC Aug 7 2012(CE2686D6.71484513)
orgtime: 10:56:22.442 UTC Aug 7 2012(CE2686D6.71484513)
rcvtime: 10:56:22.442 UTC Aug 7 2012(CE2686D6.7149E881)
xmttime: 10:56:22.442 UTC Aug 7 2012(CE2686D6.71464DC2)
filter delay : 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
filter offset: 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
filter disper: 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
reference clock status: working abnormally
timecode:
clock source |
clock stratum |
clock status |
Status of the clock source corresponding to this session: · configured—The session was created by a configuration command. · dynamic—This session is dynamically established. · master—The clock source is the primary reference source of the current system. · selected—The clock source has survived the clock selection algorithm. · candidate—The clock source is the candidate reference source. · sane—The clock source has passed the sane authentication. · insane—The clock source has failed the sane authentication. · valid—The clock source is valid, which means the clock source meet the following requirements: it has passed the authentication and is being synchronized; its stratum level is valid; its root delay and root dispersion values are within their ranges. · invalid—The clock source is invalid. · unsynced—The clock source has not been synchronized or the value of the stratum level is invalid. |
reference clock ID |
Reference clock ID of the clock source: · If the reference clock is the local clock, the value of this field is related to the stratum level of the clock source: ¡ If the stratum level of the clock source is 0 or 1, this field is LOCL. ¡ If the stratum level of the clock source has another value, this field is the IP address of the local clock. · If the reference clock is the clock of another device on the network, the value of this field is the IP address of that device. |
local mode |
Operation mode of the local device: · unspec—The mode is unspecified. · active—Active mode. · passive—Passive mode. · client—Client mode. · server—Server mode. · bdcast—Broadcast server mode. · control—Control query mode. · private—Private message mode. |
local poll |
Poll interval of the local device, in seconds. The value displayed is a power of 2. For example, if the displayed value is 6, the poll interval of the local device is 26, or 64 seconds. |
peer mode |
Operation mode of the peer device: · unspec—The mode is unspecified. · active—Active mode. · passive—Passive mode. · client—Client mode. · server—Server mode. · bdcast—Broadcast server mode. · control—Control query mode. · private—Private message mode. |
peer poll |
Poll interval of the peer device, in seconds. The value displayed is a power of 2. For example, if the displayed value is 6, the poll interval of the local device is 26, or 64 seconds. |
offset |
delay |
disper |
Maximum error of the system clock relative to the reference clock. |
root delay |
Roundtrip delay from the local device to the primary reference source, in milliseconds. |
root disper |
Maximum error of the system clock relative to the primary reference clock, in milliseconds. |
reach |
sync dist |
Synchronization distance relative to the upper-level clock, in seconds, calculated from dispersion and roundtrip delay values. |
sync state |
State of the state machine. Displayed value is an integer that is in the range of 0 to 5. |
precision |
Precision of the system clock. |
version |
NTP version. Displayed value is an integer that is in the range of 1 to 4. |
peer interface |
Source interface. If the source interface is not specified, this field is wildcard. |
reftime |
Reference timestamp in the NTP message. |
orgtime |
Originate timestamp in the NTP message. |
rcvtime |
Receive timestamp in the NTP message. |
xmttime |
Transmit timestamp in the NTP message. |
filter delay |
Delay information. |
filter offset |
Offset information. |
filter disper |
Dispersion information. |
reference clock status |
Status of the reference clock: · working properly. · working improperly. |
timecode |
Time code. |
When a device is operating in NTP broadcast/multicast server mode, the display ntp-service sessions command does not display the NTP session information corresponding to the broadcast/multicast server, but the sessions are counted in the total number of associations.
display ntp-service status
Use display ntp-service status to display the NTP service status.
display ntp-service status [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the NTP service status.
<Sysname> display ntp-service status
Clock status: unsynchronized
Clock stratum: 16
Reference clock ID: none
Nominal frequency: 100.0000 Hz
Actual frequency: 100.0000 Hz
Clock precision: 2^17
Clock offset: 0.0000 ms
Root delay: 0.00 ms
Root dispersion: 0.00 ms
Peer dispersion: 0.00 ms
Reference time: 00:00:00.000 UTC Jan 1 1900(00000000.00000000)
Clock status |
Status of the system clock: · Synchronized—The system clock has been synchronized. · Unsynchronized—The system clock has not been synchronized. |
Clock stratum |
Stratum level of the system clock. |
Reference clock ID |
When the system clock is synchronized to a remote time server, this field indicates the address of the remote time server. When the system clock is synchronized to a local reference source, this field indicates the address of the local clock source: · If the local clock has a stratum level of 1, the value of this field is LOCL. · If the stratum of the local clock has another value, the value of this field is the IP address of the local clock. |
Nominal frequency |
Nominal frequency of the local system hardware clock, in Hz. |
Actual frequency |
Actual frequency of the local system hardware clock, in Hz. |
Clock precision |
Clock offset |
Offset of the system clock relative to the reference source, in milliseconds. |
Root delay |
Root dispersion |
Maximum error of the system clock relative to the primary reference source, in milliseconds. |
Peer dispersion |
Maximum error of the system clock relative to the reference source, in milliseconds. |
Reference time |
Reference timestamp. |
display ntp-service trace
Use display ntp-service trace to display brief information about each NTP server from the local device back to the primary reference source.
display ntp-service trace [ | { begin | exclude | include } regular-expression ]
1: Monitor level
The display ntp-service trace command takes effect only when the local device and all the devices on the NTP server chain can reach one another. Otherwise, this command is unable to display all the NTP servers on the NTP chain due to timeout.
# Display brief information about each NTP server from the local device back to the primary reference source.
<Sysname> display ntp-service trace
server 127.0.0.1,stratum 2, offset -0.013500, synch distance 0.03154
server 133.1.1.1,stratum 1, offset -0.506500, synch distance 0.03429
refid LOCL
The output shows an NTP server chain for server 127.0.0.1: Server 127.0.0.1 is synchronized to server 133.1.1.1, and server 133.1.1.1 is synchronized to the local clock source.
server |
IP address of the NTP server. |
stratum |
Stratum level of the corresponding system clock. |
offset |
Clock offset relative to the upper-level clock, in seconds. |
synch distance |
refid |
Identifier of the primary reference source. When the stratum level of the primary reference clock is 0, it is displayed as LOCL. Otherwise, it is displayed as the IP address of the primary reference clock. |
ntp-service access
Use ntp-service access to configure the access-control right for the peer devices to access the NTP services of the local device.
Use undo ntp-service access to remove the configured NTP service access-control right to the local device.
ntp-service access { peer | query | server | synchronization } acl-number
undo ntp-service access { peer | query | server | synchronization }
The access-control right for the peer devices to access the NTP services of the local device is set to peer.
3: Manage level
peer: Permits full access. This level of right permits the peer devices to perform synchronization and control query to the local device and also permits the local device to synchronize its clock to that of a peer device. Control query refers to query of NTP status, such as alarm information, authentication status, and clock source information.
query: Permits control query. This level of right permits the peer devices to perform control query to the NTP service on the local device but does not permit a peer device to synchronize its clock to that of the local device.
server: Permits server access and query. This level of right permits the peer devices to perform synchronization and control query to the local device but does not permit the local device to synchronize its clock to that of a peer device.
synchronization: Permits server access only. This level of right permits a peer device to synchronize its clock to that of the local device but does not permit the peer devices to perform control query.
acl-number: Basic ACL number, in the range of 2000 to 2999.
From the highest to lowest, the NTP service access-control rights are peer, server, synchronization, and query. If a device receives an NTP request, it performs an access-control right match and uses the first matched right. If no matched right is found, the device drops the NTP request.
The ntp-service access command provides only a minimum degree of security protection. A more secure method is identity authentication. The related command is ntp-service authentication enable.
Before you specify an ACL number in the ntp-service access command, make sure you have created and configured this ACL.
# Configure the peer devices on subnet 10.10.0.0/16 to have the full access right to the local device.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.10.0.0 0.0.255.255
[Sysname-acl-basic-2001] quit
[Sysname] ntp-service access peer 2001
Use ntp-service authentication enable to enable NTP authentication.
Use undo ntp-service authentication enable to disable NTP authentication.
NTP authentication is disabled.
3: Manage level
# Enable NTP authentication.
[Sysname] ntp-service authentication enable
· ntp-service authentication-keyid
· ntp-service reliable authentication-keyid
Use ntp-service authentication-keyid to set the NTP authentication key.
Use undo ntp-service authentication-keyid to remove the configured NTP authentication key.
ntp-service authentication-keyid keyid authentication-mode md5 [ cipher | simple ] value
undo ntp-service authentication-keyid keyid
No NTP authentication key is set.
3: Manage level
keyid: Specifies an authentication key ID, in the range of 1 to 4294967295.
cipher: Sets a ciphertext key.
simple: Sets a plaintext key. This key is saved in cipher text for secrecy.
value: Specifies the MD5 authentication key string. This argument is case sensitive. If simple is specified, it is a string of 1 to 32 characters. If cipher is specified, it is a string of 1 to 73 characters. If neither cipher nor simple is specified, you set a plaintext key string.
In a security-demanding network, enable NTP authentication for a system running NTP. NTP authentication enhances network security by using the client-server key authentication, which prohibits a client from synchronizing to a device that has failed the authentication.
After you specify an NTP authentication key, configure the key as a trusted key by using the ntp-service reliable authentication-keyid command.
The system supports only the MD5 algorithm for key authentication.
A maximum of 1024 keys can be set for each device.
If an NTP authentication key is specified as a trusted key, the key automatically changes to untrusted after you delete the key. In this case, you do not need to execute the undo ntp-service reliable authentication-keyid command.
# Set an MD5 authentication key, with the key ID of 10 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 10 authentication-mode md5 BetterKey
ntp-service broadcast-client
Use ntp-service broadcast-client to configure the device to operate in NTP broadcast client mode and use the current interface to receive NTP broadcast packets.
Use undo ntp-service broadcast-client to remove the configuration.
The device does not operate in any NTP operation mode.
VLAN interface view
3: Manage level
# Configure the device to operate in broadcast client mode and receive NTP broadcast messages on VLAN-interface 1.
[Sysname-Vlan-interface1] ntp-service broadcast-client
ntp-service broadcast-server
Use ntp-service broadcast-server to configure the device to operate in NTP broadcast server mode and use the current interface to send NTP broadcast packets.
Use undo ntp-service broadcast-server to remove the configuration.
VLAN interface view
3: Manage level
authentication-keyid keyid: Specifies the key ID to be used for sending broadcast messages to broadcast clients, where keyid is in the range of 1 to 4294967295. This parameter is meaningless if authentication is not required.
version number: Specifies the NTP version, where number is in the range of 1 to 4 and defaults to 3.
# Configure the device to operate in broadcast server mode and send NTP broadcast messages on VLAN-interface 1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service broadcast-server authentication-keyid 4 version 3
ntp-service dscp
Use ntp-service dscp to set the DSCP value for NTP messages.
Use undo ntp-service dscp to restore the default.
ntp-service dscp dscp-value
The DSCP value for NTP messages is 16.
2: System level
dscp-value: Specifies the Differentiated Services Code Point (DSCP) value for NTP messages, in the range of 0 to 63.
# Set the DSCP value to 30 for NTP messages.
[Sysname] ntp-service dscp 30
Use ntp-service in-interface disable to disable an interface from receiving NTP messages.
Use undo ntp-service in-interface disable to restore the default.
All interfaces are enabled to receive NTP messages.
VLAN interface view
3: Manage level
# Disable VLAN-interface 1 from receiving NTP messages.
[Sysname-Vlan-interface1] ntp-service in-interface disable
Use ntp-service max-dynamic-sessions to set the maximum number of dynamic NTP sessions that are allowed to be established locally.
Use undo ntp-service max-dynamic-sessions to restore the maximum number of dynamic NTP sessions to the system default.
The number is 100.
3: Manage level
number: Sets the maximum number of dynamic NTP sessions that are allowed to be established, in the range of 0 to 100.
A single device can have a maximum of 128 concurrent associations, including static associations and dynamic associations. A static association refers to an association that a user has manually created by using an NTP command, while a dynamic association is a temporary association created by the system during operation. A dynamic association is removed if the system fails to receive messages from it over a specific long time. In client/server mode, for example, when you carry out a command to synchronize the time to a server, the system creates a static association, and the server just responds passively upon the receipt of a message, rather than creating an association (static or dynamic). In symmetric mode, static associations are created at the symmetric-active peer side, and dynamic associations are created at the symmetric-passive peer side. In broadcast or multicast mode, static associations are created at the server side, and dynamic associations are created at the client side.
# Set the maximum number of dynamic NTP sessions allowed to be established to 50.
[Sysname] ntp-service max-dynamic-sessions 50
ntp-service multicast-client
Use ntp-service multicast-client to configure the device to operate in NTP multicast client mode and use the current interface to receive NTP multicast packets.
Use undo ntp-service multicast-client to remove the configuration.
undo ntp-service multicast-client [ ip-address ]
VLAN interface view
3: Manage level
ip-address: Specifies a multicast IP address, in the range of 224.0.1.1 to 224.0.1.254. The default value is 224.0.1.1.
# Configure the device to operate in multicast client mode and receive NTP multicast messages on VLAN-interface 1, and set the multicast address to 224.0.1.1.
[Sysname-Vlan-interface1] ntp-service multicast-client 224.0.1.1
ntp-service multicast-server
Use ntp-service multicast-server to configure the device to operate in NTP multicast server mode and use the current interface to send NTP multicast packets.
Use undo ntp-service multicast-server to remove the configuration.
undo ntp-service multicast-server [ ip-address ]
VLAN interface view
3: Manage level
ttl ttl-number: Specifies the TTL of NTP multicast messages, where ttl-number is in the range of 1 to 255 and defaults to 16.
# Configure the device to operate in multicast server mode and send NTP multicast messages on VLAN-interface 1 to the multicast address 224.0.1.1, using key 4 for encryption, and set the NTP version to 3.
[Sysname-Vlan-interface1] ntp-service multicast-server 224.0.1.1 version 3 authentication-keyid 4
Use ntp-service reliable authentication-keyid to specify that the created authentication key is a trusted key. When NTP authentication is enabled, a client can only synchronize to a server that can provide a trusted authentication key.
Use undo ntp-service reliable authentication-keyid to remove the configuration.
undo ntp-service reliable authentication-keyid keyid
No authentication key is configured to be trusted.
3: Manage level
keyid: Specifies an authentication key number, in the range of 1 to 4294967295.
# Enable NTP authentication and specify the MD5 encryption algorithm, with the key ID of 37 and key value of BetterKey.
[Sysname] ntp-service authentication-keyid 37 authentication-mode md5 BetterKey
# Specify this key as a trusted key.
[Sysname] ntp-service reliable authentication-keyid 37
ntp-service source-interface
Use ntp-service source-interface to specify the source interface for NTP messages.
Use undo ntp-service source-interface to restore the default.
ntp-service source-interface interface-type interface-number
No source interface is specified for NTP messages, and the system uses the IP address of the interface determined by the matched route as the source IP address of NTP messages.
3: Manage level
If you do not want the IP address of a certain interface on the local device to become the destination address of response messages, use this command to specify the source interface for NTP messages so that the source IP address in NTP messages is the primary IP address of this interface.
# Specify the source interface of NTP messages as VLAN-interface 1.
[Sysname] ntp-service source-interface vlan-interface 1
ntp-service unicast-peer
Use ntp-service unicast-peer to designate a symmetric-passive peer for the device.
Use undo ntp-service unicast-peer to remove the symmetric-passive peer designated for the device.
ntp-service unicast-peer { ip-address | peer-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-peer { ip-address | peer-name }
No symmetric-passive peer is designated for the device.
3: Manage level
ip-address: Specifies the IP address of the symmetric-passive peer. It must be a unicast address, rather than a broadcast address, a multicast address, or the IP address of the local clock.
peer-name: Specifies a host name of the symmetric-passive peer, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the peer, where keyid is in the range of 1 to 4294967295.
priority: Specifies the peer designated by ip-address or peer-name as the first choice under the same condition.
source-interface interface-type interface-number: Specifies the source interface for NTP messages. In an NTP message that the local device sends to its peer, the source IP address is the primary IP address of this interface. The interface-type interface-number argument represents the interface type and number.
# Designate the device with the IP address of 10.1.1.1 as the symmetric-passive peer of the device, configure the device to run NTP version 3, and specify the source interface of NTP messages as VLAN-interface 1.
[Sysname] ntp-service unicast-peer 10.1.1.1 version 3 source-interface vlan-interface 1
ntp-service unicast-server
Use ntp-service unicast-server to designate an NTP server for the device.
Use undo ntp-service unicast-server to remove an NTP server designated for the device.
ntp-service unicast-server { ip-address | server-name } [ authentication-keyid keyid | priority | source-interface interface-type interface-number | version number ] *
undo ntp-service unicast-server { ip-address | server-name }
No NTP server is designated for the device.
3: Manage level
ip-address: IP address of the NTP server. It must be a unicast address, rather than a broadcast address, a multicast address or the IP address of the local clock.
server-name: Host name of the NTP server, a string of 1 to 20 characters.
authentication-keyid keyid: Specifies the key ID to be used for sending NTP messages to the NTP server, where keyid is in the range of 1 to 4294967295.
priority: Specifies this NTP server as the first choice under the same condition.
source-interface interface-type interface-number: Specifies the source interface for NTP messages. In an NTP message the local device sends to the NTP server, the source IP address is the primary IP address of this interface. The interface-type interface-number argument represents the interface type and number.
# Designate NTP server 10.1.1.1 for the device, and configure the device to run NTP version 3.
[Sysname] ntp-service unicast-server 10.1.1.1 version 3
