00-Preface | 83.46 KB |
The H3C WX5540E Access Controller Switching Engine documentation set describes the commands and command syntax options available for the H3C WX5540E Access Controller Switching Engine.
The Network Management and Monitoring Command Reference describes network management and monitoring configuration commands.
This preface includes:
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the WX5540E Access Controller Switching Engine
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
Symbols
Convention |
NOTE |
Network topology icons
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
Documentation feedback
We appreciate your comments.
