07-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10207-Security Configuration Guide
00-Preface
00-Preface 114.85 KB
Preface
The H3C access controllers documentation set describes the software features for the H3C access controllers and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The Security Configuration Guide describes security features and configuration. It covers identity authentication features (such as AAA and PKI), access security features (such as 802.1X, MAC authentication, portal authentication, and port security), secure management features (such as SSH), security socket layer (SSL), and attack protection features (such as TCP attack protection and ARP attack protection).
Support of the H3C access controllers for features might vary by device model. For the feature matrixes, see About the H3C Access Controllers Configuration Guides.
·     Audience.
·     Conventions.
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
Wireless terminator unit.
Wireless terminator.
We appreciate your comments.
