HomeSupportSwitchesH3C S7500E-XS Switch SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Switch Series Configuration Guides-Release7178-6W10001-Fundamentals Configuration Guide
09-Automatic configuration
09-Automatic configuration 185.20 KB
Using automatic configuration
Overview
With the automatic configuration feature, the device can automatically obtain a set of configuration settings when it starts up without a configuration file. This feature simplifies network configuration and maintenance.
As shown in Figure 1, automatic configuration requires the following servers:
·           DHCP server.
·           File server (TFTP or HTTP server).
·           (Optional.) DNS server.
Figure 1 Automatic configuration network diagram
Automatic configuration task list
Tasks at a glance
(Required.) Configuring the file server
(Required.) Preparing the files for automatic configuration
(Required.) Configuring the DHCP server
(Optional.) Configuring the DNS server
(Optional.) Configuring the gateway
(Required.) Preparing the interfaces used for automatic configuration
(Required.) Starting and completing automatic configuration
For devices to obtain configuration information from a TFTP server, start TFTP service on the file server.
For devices to obtain configuration information from an HTTP server, start HTTP service on the file server.
The device can use a script file or configuration file for automatic configuration.
·           For devices to use configuration files for automatic configuration, you must create and save the configuration files to the file server as described in "Configuration files." If you do not configure the DHCP server to assign configuration file names, you must also create a host name file on the TFTP server.
·           For devices to use script files for automatic configuration, you must create and save the script files to the file server as described in "Script files."
Host name file
The host name file contains host name-IP address mappings and must be named network.cfg.
All mapping entries in the host name file must use the ip host host-name ip-address format. Each mapping entry must reside on a separate line. For example:
ip host host1 101.101.101.101
ip host host2 101.101.101.102
ip host client1 101.101.101.103
ip host client2 101.101.101.104
Configuration files
To prepare configuration files:
·           For devices that require different configurations, perform the following tasks:
¡  Determine the name for each device's configuration file.
The configuration file names must use the extension .cfg. For simple file name identification, use configuration file names that do not contain spaces.
¡  Use the file names to save the configuration files for the devices to the file server.
·           For devices that share all or some configurations, save the common configurations to a .cfg file on the file server.
·           If a TFTP file server is used, you can save a default configuration file named device.cfg on the server. This file contains only common configurations that devices use to start up. This file is assigned to a device only when the device does not have other configuration files to use.
During the automatic configuration process, a device first tries to obtain a configuration file dedicated for it. If no dedicated configuration file is found, the device tries to obtain the common configuration file. If no common configuration file is found when a TFTP file server is used, the device obtains and uses the default configuration file.
Script files
Script files can be used for automatic software upgrade and automatic configuration. The device supports Python scripts (.py files) and Tcl scripts (.tcl files). For more information about Python and Tcl scripts, see "Using Python" and "Using Tcl."
To prepare script files:
·           For devices that share all or some configurations, create a script file that contains the common configurations.
·           For the other devices, create a separate script file for each of them.
The DHCP server assigns the following items to devices that need to be automatically configured:
·           IP addresses.
·           Paths of the configuration files or scripts.
Configuration guidelines
When you configure the DHCP server, follow these guidelines:
·           For devices for which you have prepared different configuration files, perform the following tasks for each of them on the DHCP server:
¡  Create a DHCP address pool.
¡  Configure a static address binding.
¡  Specify a configuration file or script file.
·           For devices for which you have prepared the same configuration file, perform the following tasks on the DHCP server:
¡  Create a DHCP address pool for the devices.
¡  Configure a static address binding for each of the devices in the address pool.
¡  Specify the configuration file for the devices.
·           If all devices on a subnet share the same configuration file or script file, perform the following tasks on the DHCP server:
¡  Configure dynamic address allocation.
The configuration file can contain only the common settings for the devices. You can provide a method for the device administrators to change the configurations after their devices start up.
Configuring the DHCP server when an HTTP file server is used
Step
Remarks
1.      Enter system view.
N/A
2.      Enable DHCP.
dhcp enable
By default, DHCP is disabled.
3.      Create a DHCP address pool and enter its view.
dhcp server ip-pool pool-name
By default, no DHCP address pool is created.
4.      Configure the address pool.
·          (Method 1.) Specify the primary subnet for the address pool:
network
network-address [ mask-length |
mask mask ]
·          (Method 2.) Configure a static binding:
static-bind ip-address
ip-address [ mask-length | mask mask ] { client-identifier client-identifier | hardware-address hardware-address [ ethernet | token-ring ] }
Use either or both methods.
By default, no primary subnet or static binding is configured.
You can add multiple static bindings.
One IP address can be bound to only one client. To change the binding for a DHCP client, you must remove the binding and reconfigure a binding.
5.      Specify the URL of the configuration file or script file.
bootfile-name url
By default, no configuration file URL is specified.
Configuring the DHCP server when a TFTP file server is used
Step
Remarks
N/A
2.      Enable DHCP.
dhcp enable
network
mask mask ]
5.      Specify a TFTP server.
·          (Method 1.) Specify the IP address of the TFTP server:
tftp-server ip-address
ip-address
·          (Method 2.) Specify the name of the TFTP server:
tftp-server domain-name
domain-name
By default, no TFTP server is specified.
If you specify a TFTP server by its name, a DNS server is required on the network.
6.      Specify the configuration file name.
bootfile-name bootfile-name
By default, no configuration file name is specified.
A DNS server is required in the following situations:
·           The TFTP server does not have a host name file. However, devices need to perform the following operations:
¡  Use their IP addresses to obtain their host names.
¡  Obtain configuration files named in the host name.cfg format from the TFTP server.
·           The DHCP server assigns the TFTP server domain name through the DHCP reply message. Devices must use the domain name to obtain the IP address of the TFTP server.
If the devices to be automatically configured and the servers for automatic configuration reside in different network segments, you must perform the following tasks:
·           Deploy a gateway and make sure the devices can communicate with the servers.
·           Configure the DHCP relay agent feature on the gateway.
·           Configure the UDP helper feature on the gateway.
When a device sends a request through a broadcast packet to the file server, the UDP helper changes the broadcast packet to a unicast packet and forwards the unicast packet to the file server. For more information about UDP helper, see Layer 3—IP Services Configuration Guide.
The device uses the following steps to select the interface for automatic configuration:
1.      Identifies the status of the management Ethernet interface at Layer 2. If the status is up, the device uses the management Ethernet interface.
2.      Identifies the status of Layer 2 Ethernet interfaces. If one or more Layer 2 Ethernet interfaces are in up state, the device uses the VLAN interface of the default VLAN.
3.      Sorts all Layer 3 Ethernet interfaces in up state first in lexicographical order of interface types and then in ascending order of interface numbers. Uses the interface with the smallest interface number among the interfaces of the first interface type.
4.      If no Layer 3 Ethernet interfaces are in up state, the device waits 30 seconds and goes to step 1 to try again.
For fast automatic device configuration, connect only the management Ethernet interface on each device to the network.
1.      Power on the devices to be automatically configured.
If a device does not find a next-start configuration file locally, it starts the automatic configuration process to obtain a configuration file. If one attempt fails, the device waits 30 seconds and then automatically starts the process again. To stop the process, press Ctrl+C or Ctrl+D.
After obtaining a configuration file, the device automatically executes the configuration file.
2.      Use the save command to save the running configuration.
The device does not save the obtained configuration file locally. If you do not save the running configuration, the device must use the automatic configuration feature again after a reboot.
For more information about the save command, see Fundamentals Command Reference.
Automatic configuration examples
Automatic configuration using TFTP server
Network requirements
As shown in Figure 2, two departments of a company are connected to the network through gateways (Switch B and Switch C). Access devices Switch D, Switch E, Switch F, and Switch G do not have a configuration file.
Configure the servers and gateways so the access devices can obtain a configuration file to complete the following configuration tasks:
·           Enable administrators of access devices to Telnet to and manage their respective access devices.
·           Require administrators to enter their respective usernames and passwords at login.
Figure 2 Network diagram
Configuration procedure
1.      Configure the DHCP server:
# Create a VLAN interface and assign an IP address to the interface.
[SwitchA] vlan 2
[SwitchA-vlan2] port ten-gigabitethernet 1/1/1
[SwitchA-vlan2] quit
[SwitchA-Vlan-interface2] ip address 192.168.1.42 24
# Enable DHCP.
[SwitchA] dhcp enable
# Enable the DHCP server on VLAN-interface 2.
[SwitchA-Vlan-interface2] dhcp select server
# Configure the address pool market to assign IP addresses on subnet 192.168.2.0/24 to clients in the Marketing department. Specify the TFTP server, gateway, and configuration file name for the clients.
[SwitchA] dhcp server ip-pool market
[SwitchA-dhcp-pool-market] network 192.168.2.0 24
[SwitchA-dhcp-pool-market] tftp-server ip-address 192.168.1.40
[SwitchA-dhcp-pool-market] gateway-list 192.168.2.1
[SwitchA-dhcp-pool-market] bootfile-name market.cfg
[SwitchA-dhcp-pool-market] quit
# Configure the address pool rd to assign IP addresses on subnet 192.168.3.0/24 to clients in the R&D department. Specify the TFTP server, gateway, and configuration file name for the clients.
[SwitchA] dhcp server ip-pool rd
[SwitchA-dhcp-pool-rd] network 192.168.3.0 24
[SwitchA-dhcp-pool-rd] tftp-server ip-address 192.168.1.40
[SwitchA-dhcp-pool-rd] gateway-list 192.168.3.1
[SwitchA-dhcp-pool-rd] bootfile-name rd.cfg
[SwitchA-dhcp-pool-rd] quit
# Configure static routes to the DHCP relay agents.
[SwitchA] ip route-static 192.168.2.0 24 192.168.1.41
[SwitchA] ip route-static 192.168.3.0 24 192.168.1.43
[SwitchA] quit
2.      Configure the gateway Switch B:
# Create VLAN interfaces and assign IP addresses to the interfaces.
[SwitchB] vlan 2
[SwitchB-vlan2] port ten-gigabitethernet 1/1/3
[SwitchB-vlan2] quit
[SwitchB-Vlan-interface2] ip address 192.168.1.41 24
[SwitchB] vlan 3
[SwitchB-vlan3] port ten-gigabitethernet 1/1/1
[SwitchB-vlan3] port ten-gigabitethernet 1/1/2
[SwitchB-vlan3] quit
[SwitchB-Vlan-interface3] ip address 192.168.2.1 24
# Enable DHCP.
[SwitchB] dhcp enable
# Enable the DHCP relay agent on VLAN-interface 3.
[SwitchB-Vlan-interface3] dhcp select relay
# Specify the DHCP server address.
[SwitchB-Vlan-interface3] dhcp relay server-address 192.168.1.42
3.      Configure the gateway Switch C:
[SwitchC] vlan 2
[SwitchC-vlan2] port ten-gigabitethernet 1/1/3
[SwitchC-vlan2] quit
[SwitchC-Vlan-interface2] ip address 192.168.1.43 24
[SwitchC] vlan 3
[SwitchC-vlan3] port ten-gigabitethernet 1/1/1
[SwitchC-vlan3] port ten-gigabitethernet 1/1/2
[SwitchC-vlan3] quit
[SwitchC-Vlan-interface3] ip address 192.168.3.1 24
# Enable DHCP.
[SwitchC] dhcp enable
[SwitchC-Vlan-interface3] dhcp select relay
[SwitchC-Vlan-interface3] dhcp relay server-address 192.168.1.42
4.      Configure the TFTP server:
# On the TFTP server, create the configuration file market.cfg.
 sysname Market
 telnet server enable
vlan 3
local-user market
 password simple market
 service-type telnet
interface Vlan-interface3
 ip address dhcp-alloc
interface ten-gigabitethernet1/1/1
 port access vlan 3
user-interface vty 0 4
 authentication-mode scheme
 user-role network-admin
return
# On the TFTP server, create the configuration file rd.cfg.
 sysname RD
vlan 3
local-user rd
 password simple rd
 service-type telnet
 port access vlan 3
return
# Start TFTP service software, and specify the folder where the two configuration files reside as the working directory. (Details not shown.)
# Verify that the TFTP server and DHCP relay agents can reach each other. (Details not shown.)
1.      Power on Switch D, Switch E, Switch F, and Switch G.
2.      After the access devices start up, display assigned IP addresses on Switch A.
<SwitchA> display dhcp server ip-in-use
IP address       Client-identifier/    Lease expiration      Type
                 Hardware address
192.168.2.2      3030-3066-2e65-3233-  May 6 05:21:25 2013   Auto(C)
                 642e-3561-6633-2d56-
                 6c61-6e2d-696e-7465-
                 7266-6163-6533
192.168.2.3      3030-3066-2e65-3230-  May 6 05:22:50 2013   Auto(C)
                 302e-3232-3033-2d56-
                 7266-6163-6533
192.168.3.2      3030-6530-2e66-6330-  May 6 05:23:15 2013   Auto(C)
                 302e-3335-3131-2d56-
                 7266-6163-6531
192.168.3.3      3030-6530-2e66-6330-  May 6 05:24:10 2013   Auto(C)
                 302e-3335-3135-2d56-
                 7266-6163-6532
3.      Telnet to 192.168.2.2 from Switch A.
<SwitchA> telnet 192.168.2.2
4.      Enter the username market and password market as prompted. (Details not shown.)
You are logged in to Switch D or Switch E.
Automatic configuration using HTTP server and Tcl script
As shown in Figure 3, Device A does not have a configuration file.
Configure the servers so Device A can obtain a Tcl script to complete the following configuration tasks:
·           Enable the administrator to Telnet to Device A to manage Device A.
·           Require the administrator to enter the correct username and password at login.
Figure 3 Network diagram
# Enable DHCP.
[DeviceB] dhcp enable
# Configure the address pool 1 to assign IP addresses on subnet 192.168.1.0/24 to clients.
[DeviceB] dhcp server ip-pool 1
[DeviceB-dhcp-pool-1] network 192.168.1.0 24
# Specify the URL of the script file for the clients.
[DeviceB-dhcp-pool-1] bootfile-name http://192.168.1.40/device.tcl
2.      Configure the HTTP server:
# Create the configuration file device.tcl on the HTTP server.
return
local-user user
password simple abcabc
service-type telnet
interface ten-gigabitethernet 1/1/1
port link-mode route
return
# Start HTTP service software and enable HTTP service. (Details not shown.)
1.      Power on Device A.
2.      After Device A starts up, display assigned IP addresses on Device B.
<DeviceB> display dhcp server ip-in-use
IP address       Client identifier/    Lease expiration      Type
                 Hardware address
192.168.1.2      0030-3030-632e-3239-  Dec 12 17:41:15 2013  Auto(C)
                 3035-2e36-3736-622d-
                 4574-6830-2f30-2f32
3.      Telnet to 192.168.1.2 from Device B.
<DeviceB> telnet 192.168.1.2
4.      Enter the username user and password abcabc as prompted. (Details not shown.)
You are logged in to Device A.
Automatic configuration using HTTP server and Python script
As shown in Figure 4, Device A does not have a configuration file.
Configure the servers so Device A can obtain a Python script to complete the following configuration tasks:
Figure 4 Network diagram
# Enable DHCP.
[DeviceB-dhcp-pool-1] bootfile-name http://192.168.1.40/device.py
# Create the configuration file device.py on the HTTP server.
#!usr/bin/python
import comware
comware.CLI(‘system-view ;telnet server enable ;local-user user ;password simple abcabc ;service-type telnet ;quit ;user-interface vty 0 4 ;authentication-mode scheme ;user-role network-admin ;quit ;interface ten-gigabitethernet 1/1/1 ;port link-mode route ;ip address dhcp-alloc ;return’)
                 Hardware address
                 4574-6830-2f30-2f32
Automatic IRF setup
As shown in Figure 5, Switch A and Switch B do not have a configuration file.
Configure the servers so the switches can obtain a Python script to complete their respective configuration and form an IRF fabric.
Figure 5 Network diagram
1.      Assign IP addresses to the interfaces. Make sure the devices can reach each other. (Details not shown.)
2.      Configure the following files on the HTTP server:
File
Content
Remarks
.cfg configuration file
Commands required for IRF setup.
You can create a configuration file by copying and modifying the configuration file of an existing IRF fabric.
sn.txt
Serial numbers of the member switches.
Each SN uniquely identifies a switch.
These SNs will be used for assigning a unique IRF member ID to each member switch.
(Optional.) .ipe or .bin software image file
Software images.
If the member switches are running different software versions, you must prepare the software image file used for software upgrade.
.py Python script file
Python commands and APIs that complete the following tasks:
·          (Optional.) Verifies that the flash memory has sufficient space for the files to be downloaded.
·          Downloads the configuration file and sn.txt.
·          (Optional.) Downloads the software image file and sets it as the main startup image file.
·          Resolves sn.txt and assigns a unique IRF member ID to each SN.
·          Sets the configuration file as the main next-startup configuration file.
·          Reboots the member switches.
For more information about Python script configuration, see "Using Python."
3.      Configure Device A as the DHCP server:
# Enable DHCP.
[DeviceA] dhcp enable
[DeviceA] dhcp server ip-pool 1
[DeviceA-dhcp-pool-1] network 192.168.1.0 24
# Enable the DHCP server on Ten-GigabitEthernet 1/1/1.
[DeviceA] interface ten-gigabitethernet 1/1/1
[DeviceA-Ten-gigabitethernet1/1/1] dhcp select server
[DeviceA-Ten-gigabitethernet1/1/1] quit
[DeviceA-dhcp-pool-1] bootfile-name http://192.168.1.40/device.py
[DeviceA-dhcp-pool-1] quit
4.      Power on Switch A and Switch B.
Switch A and Switch B will obtain the Python script file from the DHCP server and execute the script. After completing the IRF configuration, Switch A and Switch B reboot.
5.      After Switch A and Switch B start up again, use a cable to connect Switch A and Switch B through their IRF physical ports.
Switch A and Switch B will elect a master member. The subordinate member will reboot to join the IRF fabric.
# On Switch A, display IRF member devices. You can also use the display irf command on Switch B to display IRF member devices.
<Switch A> display irf
MemberID  Slot  Role    Priority  CPU-Mac         Description
   1      6     Standby 1         00e0-fc0f-8c02  ---
 *+2      7     Master  30        00e0-fc0f-8c14  ---
 The Bridge MAC of the IRF is: 000c-1000-1111
 Auto upgrade                : yes
 Mac persistent              : always
 Domain ID                   : 0
 Auto merge                  : yes
The output shows that the switches have formed an IRF fabric.
