10-Security Command Reference
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release7178-6W10010-Security Command Reference
18-MFF commands
18-MFF commands 47.53 KB
MFF commands
display mac-forced-forwarding interface
Use display mac-forced-forwarding interface to display MFF port configuration information.
# Display MFF port configuration information.
<Sysname> display mac-forced-forwarding interface
Network Port:
GigabitEthernet1/0/1     GigabitEthernet1/0/2
User Port:
GigabitEthernet1/0/3     GigabitEthernet1/0/4
Network Port
List of network ports.
User Port
List of user ports.
mac-forced-forwarding network-port
display mac-forced-forwarding vlan
Use display mac-forced-forwarding vlan to display the MFF configuration information for a VLAN.
display mac-forced-forwarding vlan vlan-id
vlan-id: Specifies a VLAN by its number.
# Display the MFF configuration information for VLAN 2.
<Sysname> display mac-forced-forwarding vlan 2
VLAN 2
Mode: Auto/Single
Gateway:
192.168.1.42         000f-e200-8046
Server:
192.168.1.48         192.168.1.49
VLAN 2
ID of the VLAN to which the gateways belong.
Mode
MFF operating mode: automatic (Auto), manual (Manual), and single-gateway (Single).
Gateway
IP and MAC addresses of gateways. If no address is learned, this field displays N/A.
Server
Server IP addresses.
·     mac-forced-forwarding
·     mac-forced-forwarding server
Use mac-forced-forwarding to enable MFF and specify an MFF operating mode. To enable the manual mode, you must specify a default gateway.
Use undo mac-forced-forwarding to disable MFF.
mac-forced-forwarding { auto | default-gateway gateway-ip }
MFF is disabled.
VLAN view
auto: Specifies the automatic mode.
default-gateway gateway-ip: Specifies the IP address of the default gateway in the manual mode.
In MFF automatic mode, enable DHCP snooping on the device and configure DHCP snooping trusted ports.
In MFF manual mode, enable ARP snooping on the device.
For a network (or VLAN) with IP addresses manually configured, the gateway IP address must be manually configured. MFF checks for and denies only all-zero and all-one IP addresses as gateway addresses.
For a network (or VLAN) that allocates IP addresses to hosts through DHCP, the gateway IP address can be obtained in either of the following ways:
·     Configured manually.
·     Resolved from the Option field in the DHCP messages.
# Enable MFF in the automatic mode for VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] mac-forced-forwarding auto
mac-forced-forwarding gateway probe
Use mac-forced-forwarding gateway probe to enable periodic gateway MAC address probe.
Use undo mac-forced-forwarding gateway probe to restore the default.
Periodic gateway MAC address probe is disabled.
VLAN view
Make sure you have enabled MFF before enabling periodic gateway MAC address probe.
The probe interval is 30 seconds, and the periodic probe is supported in both manual and automatic modes.
# Enable periodic gateway MAC address probe.
[Sysname] vlan 2
[Sysname-vlan2] mac-forced-forwarding gateway probe
Use mac-forced-forwarding network-port to configure the Ethernet port as a network port.
Use undo mac-forced-forwarding network-port to restore the default.
The Ethernet port is a user port.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
You should configure the following ports as network ports:
·     Upstream ports connected to a gateway.
·     Ports connected to the MFF devices in a cascaded network (a network with multiple MFF devices connected to one another).
·     Ports between devices in a ring network.
You can configure multiple ports as network ports.
You can configure a port as a network port regardless of whether MFF is enabled for the VLAN of the port. However, the configuration takes effect only after MFF is enabled.
Link aggregation is supported by network ports in an MFF-enabled VLAN, but is not supported by user ports in the VLAN. To cancel the network port configuration of a link aggregation member port in a MFF-enabled VLAN, remove the network port from the link aggregation group first. For more information about link aggregation, see Layer 2—LAN Switching Configuration Guide.
# Configure GigabitEthernet 1/0/1 as a network port.
[Sysname-GigabitEthernet1/0/1] mac-forced-forwarding network-port
Use mac-forced-forwarding server to specify the IP addresses of servers.
Use undo mac-forced-forwarding server to remove server IP addresses.
mac-forced-forwarding server server-ip&<1-10>
undo mac-forced-forwarding server server-ip&<1-10>
No server IP address is specified.
VLAN view
server-ip&<1-10>: Specifies the IP address of a server in the network. &<1-10> means you can specify a maximum of 10 server IP addresses in one command line.
You need to maintain a server list on the MFF device to ensure communication between the servers and clients.
Specify the IP addresses of the following items if they are in the network:
·     DHCP servers.
·     Servers providing some other service.
·     Interfaces on a router in a VRRP group.
When the MFF device receives an ARP request from a server, it searches the IP-to-MAC address entries it has stored. Then the device replies with the requested MAC address to the server.
In this way, packets from the server to a host are not forwarded by the gateway. However, packets from a host to the server are forwarded by the gateway.
MFF does not check whether the IP address of a server is on the same network segment as that of a gateway. Instead, it checks whether the IP address of a server is all-zero or all-one. An all-zero or all-one server IP address is invalid.
You can use this command in either manual or automatic MFF mode.
Make sure MFF is enabled before you execute the mac-forced-forwarding server command.
# Specify the server at 192.168.1.100.
[Sysname] vlan 2
[Sysname-vlan2] mac-forced-forwarding server 192.168.1.100
