10-Security Command Reference
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release7178-6W10010-Security Command Reference
14-uRPF commands
14-uRPF commands 38.67 KB
IPv4 uRPF commands
display ip urpf
Use display ip urpf to display uRPF configuration.
In standalone mode:
display ip urpf [ slot slot-number ]
In IRF mode:
display ip urpf [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. (In IRF mode.)
# (In standalone mode.) Display uRPF configuration for the card in slot 3.
<Sysname> display ip urpf slot 3
Global uRPF configuration information(failed):
   Check type: strict
   Allow default route
Global uRPF configuration.
(failed)
Failed to deliver the uRPF configuration to the forwarding chip because of insufficient chip resources.
If this field does not exist, the delivery is successful.
Check type
uRPF check mode: loose or strict.
Allow default route
Allow use of the default route.
ip urpf
Use ip urpf to enable uRPF.
Use undo ip urpf to disable uRPF.
ip urpf { loose [ allow-default-route ] | strict [ allow-default-route ] }
undo ip urpf
uRPF is disabled.
loose: Enables loose uRPF check. To pass loose uRPF check, the source address of a packet must match the destination address of a FIB entry.
strict: Enables strict uRPF check. To pass strict uRPF check, the source address and receiving interface of a packet must match the destination address and output interface of a FIB entry.
allow-default-route: Allows using the default route for uRPF check.
uRPF can be deployed on a PE connected to a CE or another ISP, or on a CE.
For asymmetrical routing, configure loose uRPF to avoid discarding valid packets. For symmetrical routing, configure strict uRPF. An ISP usually adopts symmetrical routing on a PE device.
Typically, you do not need to configure the allow-default-route keyword on a PE device, because it has no default route pointing to a CE. If you enable uRPF on a CE that has a default route pointing to the PE, select the allow-default-route keyword.
# Enable strict uRPF check globally.
<Sysname>system-view
[Sysname]ip urpf strict
display ip urpf
IPv6 uRPF commands
display ipv6 urpf
Use display ipv6 urpf to display IPv6 uRPF configuration.
In standalone mode:
display ipv6 urpf [ slot slot-number ]
In IRF mode:
display ipv6 urpf [ chassis chassis-number slot slot-number ]
# (In standalone mode.) Display IPv6 uRPF configuration for the card in slot 3.
<Sysname> display ipv6 urpf slot 3
Global IPv6 uRPF configuration information(failed):
   Check type: strict
   Allow default route
Global IPv6 uRPF configuration.
(failed)
Failed to deliver the IPv6 uRPF configuration to the forwarding chip because of insufficient chip resources. If this field does not exist, the delivery is successful.
Check type
IPv6 uRPF check mode: loose or strict.
Allow default route
ipv6 urpf
Use ipv6 urpf to enable IPv6 uRPF.
Use undo ipv6 urpf to disable IPv6 uRPF.
ipv6 urpf { loose | strict } [ allow-default-route ]
undo ipv6 urpf
IPv6 uRPF is disabled.
loose: Enables loose IPv6 uRPF check. To pass loose IPv6 uRPF check, the source address of a packet must match the destination address of an IPv6 FIB entry.
strict: Enables strict IPv6 uRPF check. To pass strict IPv6 uRPF check, the source address and receiving interface of a packet must match the destination address and output interface of an IPv6 FIB entry.
allow-default-route: Allows using the default route for IPv6 uRPF check.
IPv6 uRPF can be deployed on a CE or on a PE connected to either a CE or another ISP.
For asymmetrical routing, configure loose IPv6 uRPF to avoid discarding valid packets. For symmetrical routing, configure strict IPv6 uRPF. An ISP usually adopts symmetrical routing on a PE device.
# Enable strict IPv6 uRPF check globally.
[Sysname]ipv6 urpf strict
display ipv6 urpf
