- 04-Layer 2 - LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-Port isolation configuration
- 04-Spanning tree configuration
- 05-Loop detection configuration
- 06-VLAN configuration
- 07-MVRP configuration
- 08-QinQ configuration
- 09-VLAN mapping configuration
- 10-LLDP configuration
09-VLAN mapping configuration | 290.21 KB |
Application scenario of one-to-one VLAN mapping
Application scenario of one-to-two and two-to-two VLAN mapping
VLAN mapping configuration task list
Configuring one-to-one VLAN mapping
Configuring the customer-side port
Configuring the network-side port
Configuring one-to-two VLAN mapping
Configuring two-to-two VLAN mapping
Configuring an uplink policy for the customer-side port
VLAN mapping configuration examples
One-to-one VLAN mapping configuration example
One-to-two and two-to-two VLAN mapping configuration example
The Layer 3 Ethernet interfaces of the switch do not support VLAN mapping.
For more information about the QoS policy commands, including remark service-vlan-id, nest top-most, traffic classifier, traffic behavior, and qos policy, see ACL and QoS Command Reference.
Overview
VLAN mapping re-marks VLAN tagged traffic with new VLAN IDs. The switch provides the following types of VLAN mapping:
· One-to-one VLAN mapping—Replaces one VLAN tag with another. You can use one-to-one VLAN mapping to subclassify traffic from a particular VLAN for granular QoS control, or adapt the VLAN schemes of two service providers.
· One-to-two VLAN mapping—Tags single-tagged packets with an outer VLAN tag. One-to-two VLAN mapping expands the VLAN tag space, and enables a service provider and its customers to independently assign VLANs without the risk of VLAN assignment conflicts.
· Two-to-two VLAN mapping—Replaces the outer and inner VLAN IDs of double tagged traffic with a new pair of VLAN IDs. The switch supports replacing only the outer VLAN ID. You can use two-to-two VLAN mapping on the switch to enable two remote sites in the same VLAN to communicate at Layer 2 across two service provider networks that use different VLAN assignment schemes.
Figure 1 shows an application scenario in which a customer uses a VLAN scheme different than the service provider. For example, the customer uses VLAN 10 to transmit voice traffic. The service provider uses VLAN 100. Switch A must replace the VLAN 10 tag of incoming traffic with the VLAN 100 tag, before transmitting the traffic in the service provider network.
Figure 1 Application scenario of one-to-one VLAN mapping
Figure 2 shows a typical application scenario in which two remote sites in VPN A, Site 1 and Site 2, must communicate across two SP networks, SP 1 and SP 2.
Figure 2 Application scenario of one-to-two and two-to-two VLAN mapping
If Site 1 sends a packet to Site 2, the packet is processed on the way to its destination by using the following workflow:
1. When the packet tagged with VLAN 2 arrives at the edge of network SP 1, PE 1 tags the packet with SVLAN 10 by using one-to-two VLAN mapping.
2. When the double-tagged packet enters the SP 2 network, PE 3 replaces the S VLAN tag (VLAN 10) with VLAN 20 by performing two-to-two VLAN mapping.
3. When PE 4 receives the packet with SVLAN tag 20, it removes the SVLAN tag and forwards the packet to VLAN 2.
You can use QinQ to implement one-to-two VLAN mapping. For more information about QinQ, see "Configuring QinQ."
One-to-two VLAN mapping provides the following benefits:
· Enables a VPN user to plan the CVLANs in the network without conflicting with SVLANs.
· Adds a VLAN tag to a tagged packet and expands the number of available VLANs to 4094 × 4094.
· Reduces the stress on the SVLAN resources, which were 4094 VLANs in the SP network before the mapping process was initiated.
Concepts and terms
Figure 3 shows a simplified network that illustrates basic VLAN mapping terms.
Basic VLAN mapping terms include the following:
· Uplink traffic—Traffic transmitted from the customer network to the service provider network.
· Downlink traffic—Traffic transmitted from the service provider network to the customer network.
· Network-side port—A port connected to or closer to the service provider network.
· Customer-side port—A port connected to or closer to the customer network.
· Uplink policy—A QoS policy that defines VLAN mapping rules for uplink traffic.
· Downlink policy—A QoS policy that defines VLAN mapping rules for downlink traffic.
· Customer VLANs (CVLANs)—VLANs assigned to customers.
· Service provider VLANs (SVLANs)—VLANs assigned for transmitting traffic across the service provider network.
For more information about QoS policies, see ACL and QoS Configuration Guide.
Figure 3 Basic VLAN mapping terms
VLAN mapping implementations
This section describes how VLAN mapping is implemented on the switch.
Implement one-to-one VLAN mapping through the following configurations, as shown in Figure 4:
· Apply an uplink policy to the incoming traffic on the customer-side port, mapping each CVLAN ID to a unique SVLAN ID. When a packet arrives, the switch replaces its CVLAN ID with the matching SVLAN ID.
· Apply a downlink policy to the outgoing traffic, mapping each SVLAN ID back to its corresponding CVLAN ID. When forwarding a packet out of the port, the switch replaces its SVLAN ID with the matching CVLAN ID.
Figure 4 One-to-one VLAN mapping implementation
Implement one-to-two VLAN mapping through the following configurations, as shown in Figure 5:
· Apply an uplink policy to the incoming traffic on the customer-side port to tag the incoming packets from a certain CVLAN with an outer SVLAN tag.
· Configure the customer-side port as a hybrid port, and assign the port to SVLANs as an untagged member. When the port forwards the packets from these SVLANs, it removes their SVLAN tag.
Figure 5 One-to-two VLAN mapping implementation
Implement two-to-two VLAN mapping through the following configurations, as shown in Figure 6. For uplink traffic from the SP 1 network, apply an uplink policy to the customer-side port of the SP 2 network to replace the SVLAN with a new SVLAN. The process is the same for uplink traffic from the SP 2 network.
Figure 6 Two-to-two VLAN mapping implementation
Use the VLAN mapping methods as appropriate to the roles of your switches in the network.
Task |
Switch role |
Access switch in an SP network (see Figure 1) |
Edge switch between SP networks, for example, PE 1 and PE 4 in Figure 2 |
Edge switch between SP networks, for example, PE 3 in Figure 2 |
Task |
(Required.) Configuring an uplink policy |
Creates CVLAN-to-SVLAN mappings. |
(Required.) Configuring a downlink policy |
Creates SVLAN-to-CVLAN mappings. |
(Required.) Configuring the customer-side port |
Configures settings required for one-to-one VLAN mapping. |
(Required.) Configuring the network-side port |
Configures VLAN settings required for normal communication. |
Configuration prerequisites
Create CVLANs and SVLANs, and plan CVLAN-SVLAN mappings.
To configure an uplink policy to map each CVLAN to a unique SVLAN:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Configure one class for a CVLAN. |
a. Create a class and enter class view: b. Specify one CVLAN as the match criterion: c. Return to system view: |
Repeat these steps to configure one class for each CVLAN. In one-to-one VLAN mapping, the if-match service-vlan-id command is for matching both CVLANs and SVLANs, because the switch uses the command for matching the outmost VLAN tag. |
3. Configure one behavior for an SVLAN. |
a. Create a traffic behavior and enter traffic behavior view: b. Configure an SVLAN marking action: c. Return to system view: |
Repeat these steps to configure one behavior for each SVLAN. |
4. Create a QoS policy and enter QoS policy view. |
qos policy policy-name |
N/A |
5. Associate the class with the behavior to map the CVLAN to the SVLAN. |
classifier tcl-name behavior behavior-name |
Repeat these steps to create other CVLAN-to-SVLAN mappings. |
To configure a downlink policy to map SVLANs back to CVLANs:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure one class for an SVLAN. |
a. Create a class and enter class view: b. Specify one SVLAN
Repeat these steps to configure one class for each SVLAN. |
3. Configure one behavior for a CVLAN. |
Repeat these steps to configure a behavior for each CVLAN. In one-to-one VLAN mapping, the remark service-vlan-id command is for marking both the CVLAN and SVLAN tags, because the switch uses the command for marking the outmost VLAN tag. |
N/A |
5. Associate the class with the behavior to map the SVLAN to the CVLAN. |
N/A Repeat these steps to create other CVLAN-to-SVLAN mappings. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Ethernet interface view. |
N/A |
3. Configure the link type of the port. |
port link-type { hybrid | trunk } |
The default link type of an Ethernet port is access. |
4. Assign the port to the CVLANs. |
· As a hybrid port: · As a trunk port: |
By default, ports of any link type permit VLAN 1. |
5. Apply the uplink policy to the incoming traffic. |
qos apply policy policy-name inbound |
N/A |
6. Apply the downlink policy to the outgoing traffic. |
qos apply policy policy-name outbound |
N/A |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
The default link type of ports is access. |
4. Assign the port to the SVLANs. |
Perform one-to-two VLAN mapping on the edge switches from which customer traffic enters SP networks, on PE 1 and PE 4 in Figure 2 for example. One-to-two VLAN mapping enables the edge devices to insert an outer VLAN tag to each incoming VLAN-tagged packet.
Perform these tasks to configure one-to-two VLAN mapping:
Task |
Configures an uplink policy for the customer-side port. |
Configures VLAN and other settings required for one-to-two VLAN mapping. |
Create VLANs, and plan CVLAN-to-SVLAN mappings.
To configure an uplink policy to insert an SVLAN to VLAN tagged packets:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
a. Create a traffic behavior and enter traffic behavior view: b. Add a VLAN nest action to insert an outer VLAN tag into the
incoming packets from the CVLAN or CVLANs: c. Return to system view: |
N/A |
5. Associate the class with the behavior. |
N/A Repeat this step to create class-behavior associations for other CVLANs. |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the port as a hybrid port. |
port link-type hybrid |
4. Assign the port to the SVLANs as an untagged member. |
port hybrid vlan vlan-id-list untagged |
By default, a hybrid port is an untagged member of only VLAN 1. |
5. Assign the port to the CVLANs as a tagged member. |
port hybrid vlan vlan-id-list tagged |
N/A |
6. Apply the uplink policy to the incoming traffic. |
N/A |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
· Configure the port as a trunk port: · Configure the port as a hybrid port: |
4. Assign the port to all SVLANs. |
· As a trunk port: · As a hybrid port: |
By default: · A trunk port is assigned to only VLAN 1. · A hybrid port is an untagged member of VLAN 1. |
Perform two-to-two VLAN mapping on an edge device that connects two SP networks, for example, on PE 2 (edge device of the SP 1 network) and PE 3 (edge device of the SP 2 network) in Figure 2. The two-to-two VLAN mapping implementation of the switch enables two remote sites in the same VLAN to communicate at Layer 2 across two service provider networks that use different VLAN assignment schemes.
In two-to-two VLAN mapping, foreign SVLANs refer to the outer VLANs of double-tagged frames that arrive at the customer-side port, local VLANs refer to VLANs that replace the foreign SVLANs, and CVLANs refer to inner VLANs.
Perform these tasks to configure two-to-two VLAN mapping:
Task |
(Required.) Configuring an uplink policy for the customer-side port |
Replaces foreign SVLANs with local SVLANs for uplink traffic. |
Configures VLAN and other settings required for two-to-two VLAN mapping. |
The uplink policy on the customer-side port changes the SVLAN ID of incoming traffic.
To configure an uplink policy for the customer-side port:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure one class for a CVLAN and a SVLAN. |
a. Create a class and enter class view: b. Specify one CVLAN as the match criterion: c. Specify one SVLAN as the match criterion: d. Return to system view: |
Repeat these steps to create one class for each CVLAN and foreign SVLAN pair. |
a. Create a traffic behavior and enter traffic behavior view: b. Configure an SVLAN marking action to replace the foreign SVLAN ID
with a local SVLAN ID: c. Return to system view: |
Repeat these steps to configure one SVLAN marking action for each CVLAN and foreign SVLAN pair. |
N/A |
Repeat this step to create other class-behavior associations. |
6. Return to system view. |
quit |
N/A |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
4. Assign the port to the foreign SVLANs. |
N/A |
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
4. Assign the port to the local SVLANs. |
By default, Ethernet, VLAN, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up. These examples assume that all these interfaces are already up.
Network requirements
As shown in Figure 7, perform one-to-one VLAN mapping on Switch A to replace the VLAN 10 tag with the VLAN 100 tag for transmission in the service provider network.
Configuring Switch A
# Create VLAN 100.
[SwitchA] vlan 100
# Configure uplink policy p1 to map CVLAN 10 to SVLAN 100.
[SwitchA] traffic classifier c1
[SwitchA-classifier-c1] if-match service-vlan-id 10
[SwitchA-classifier-c1] quit
[SwitchA] traffic behavior b1
[SwitchA-behavior-b1] remark service-vlan-id 100
[SwitchA-behavior-b1] quit
[SwitchA] qos policy p1
[SwitchA-policy-p1] classifier c1 behavior b1
[SwitchA-policy-p1] quit
# Configure downlink policy p11 to map the SVLAN back to the CVLAN.
[SwitchA] traffic classifier c11
[SwitchA-classifier-c11] if-match service-vlan-id 100
[SwitchA-classifier-c11] quit
[SwitchA] traffic behavior b11
[SwitchA-behavior-b11] remark service-vlan-id 10
[SwitchA-behavior-b11] quit
[SwitchA] qos policy p11
[SwitchA-policy-p11] classifier c11 behavior b11
[SwitchA-policy-p11] quit
# Assign the customer-side port GigabitEthernet 4/0/1 to CVLAN 10 and SVLAN 100.
[SwitchA] interface gigabitethernet 4/0/1
[SwitchA-GigabitEthernet4/0/1] port link-type trunk
[SwitchA-GigabitEthernet4/0/1] port trunk permit vlan 10 100
# Apply uplink policy p1 to the incoming traffic and downlink policy p11 to the outgoing traffic
[SwitchA-GigabitEthernet4/0/1] qos apply policy p1 inbound
[SwitchA-GigabitEthernet4/0/1] qos apply policy p11 outbound
# Assign the network-side port GigabitEthernet 4/0/2 to the CVLAN and SVLAN.
[SwitchA] interface ethernet gigabitethernet 4/0/2
[SwitchA-GigabitEthernet4/0/2] port link-type trunk
[SwitchA-GigabitEthernet4/0/2] port trunk permit vlan 10 100
As shown in Figure 8:
· Site 1 and Site 2, two remote users in VPN A, are in VLAN 10.
· SP 1 assigns VLAN 100 to VPN A. SP 2 assigns VLAN 200 to VPN A.
Configure one-to-two and two-to-two VLAN mappings to enable the two sites to communicate across the two SP networks.
Configuring PE 1
# Configure uplink policy test to add outer VLAN tag 100 to VLAN 10 tagged traffic.
<PE1> system-view
[PE1] traffic classifier test
[PE1-classifier-test] if-match service-vlan-id 10
[PE1-classifier-test] quit
[PE1] traffic behavior test
[PE1-behavior-test] nest top-most vlan 100
[PE1-behavior-test] quit
[PE1] qos policy test
[PE1-qospolicy-test] classifier test behavior test
[PE1-qospolicy-test] quit
# Configure the customer-side port GigabitEthernet 4/0/1 as a hybrid port, and assign it to VLAN 100 as an untagged member.
[PE1] interface gigabitethernet 4/0/1
[PE1-GigabitEthernet4/0/1] port link-type hybrid
[PE1-GigabitEthernet4/0/1] port hybrid vlan 100 untagged
# Apply uplink policy test to the incoming traffic of GigabitEthernet 4/0/1.
[PE1-GigabitEthernet4/0/1] qos apply policy test inbound
[PE1-GigabitEthernet4/0/1] quit
# Configure the network-side port GigabitEthernet 4/0/2 as a trunk port, and assign it to VLAN 100.
[PE1] interface gigabitethernet 4/0/2
[PE1-GigabitEthernet4/0/2] port link-type trunk
[PE1-GigabitEthernet4/0/2] port trunk permit vlan 100
Configuring PE 2
# Configure the uplink policy down_uplink for the customer-side port GigabitEthernet 4/0/2 to substitute SVLAN ID 100 for the SVLAN ID in the incoming traffic tagged with CVLAN 10 and SVLAN 200.
<PE2> system-view
[PE2] traffic classifier down_uplink
[PE2-classifier-down_uplink] if-match customer-vlan-id 10
[PE2-classifier-down_uplink] if-match service-vlan-id 200
[PE2-classifier-down_uplink] quit
[PE2] traffic behavior down_uplink
[PE2-behavior-down_uplink] remark service-vlan-id 100
[PE2-behavior-down_uplink] quit
[PE2] qos policy down_uplink
[PE2-qospolicy-down_uplink] classifier down_uplink behavior down_uplink
[PE2-qospolicy-down_uplink] quit
# Configure the customer-side port GigabitEthernet 4/0/2 as a trunk port, and assign the port to VLAN 100.
[PE2] interface Gigabitethernet 4/0/2
[PE2-GigabitEthernet4/0/2] port link-type trunk
[PE2-GigabitEthernet4/0/2] port trunk permit vlan 100
# Apply uplink policy down_uplink to the incoming traffic of GigabitEthernet 4/0/2.
[PE2-GigabitEthernet4/0/2] qos apply policy down_uplink inbound
[PE2-GigabitEthernet4/0/2] quit
# Configure the network-side port GigabitEthernet 4/0/1 as a trunk port, and assign it to VLAN 100.
[PE2] interface Gigabitethernet 4/0/1
[PE2-GigabitEthernet4/0/1] port link-type trunk
[PE2-GigabitEthernet4/0/1] port trunk permit vlan 100
[PE2-GigabitEthernet4/0/1] quit
Configuring PE 3
# Configure the uplink policy down_uplink for the customer-side port GigabitEthernet 4/0/1 to substitute SVLAN ID 200 for the SVLAN ID in the incoming traffic tagged with CVLAN 10 and SVLAN 100.
<PE3> system-view
[PE3] traffic classifier down_uplink
[PE3-classifier-down_uplink] if-match customer-vlan-id 10
[PE3-classifier-down_uplink] if-match service-vlan-id 100
[PE3-classifier-down_uplink] quit
[PE3] traffic behavior down_uplink
[PE3-behavior-down_uplink] remark service-vlan-id 200
[PE3-behavior-down_uplink] quit
[PE3] qos policy down_uplink
[PE3-qospolicy-down_uplink] classifier down_uplink behavior down_uplink
[PE3-qospolicy-down_uplink] quit
# Configure the customer-side port GigabitEthernet 4/0/1 as a trunk port, and assign it to VLAN 200.
[PE3] interface gigabitethernet 4/0/1
[PE3-GigabitEthernet4/0/1] port link-type trunk
[PE3-GigabitEthernet4/0/1] port trunk permit vlan 200
# Apply uplink policy down_uplink to the incoming traffic on GigabitEthernet 4/0/1.
[PE3-GigabitEthernet4/0/1] qos apply policy down_uplink inbound
[PE3-GigabitEthernet4/0/1] quit
# Configure the network-side port GigabitEthernet 4/0/2 as a trunk port, and assign it to VLAN 200.
[PE3] interface gigabitethernet 4/0/2
[PE3-GigabitEthernet4/0/2] port link-type trunk
[PE3-GigabitEthernet4/0/2] port trunk permit vlan 200
[PE3-GigabitEthernet4/0/2] quit
Configuring PE 4
# Configure uplink policy test to add outer VLAN tag 200 to VLAN 10 tagged traffic.
<PE4> system-view
[PE4] traffic classifier test
[PE4-classifier-test] if-match service-vlan-id 10
[PE4-classifier-test] quit
[PE4] traffic behavior test
[PE4-behavior-test] nest top-most vlan 200
[PE4-behavior-test] quit
[PE4] qos policy test
[PE4-qospolicy-test] classifier test behavior test
[PE4-qospolicy-test] quit
# Configure the customer-side port GigabitEthernet 4/0/1 as a hybrid port, and assign the port to VLAN 200 as an untagged member.
[PE4] interface Gigabitethernet 4/0/1
[PE4-GigabitEthernet4/0/1] port link-type hybrid
[PE4-GigabitEthernet4/0/1] port hybrid vlan 200 untagged
# Apply plink policy test to the incoming traffic of GigabitEthernet 4/0/1.
[PE4-GigabitEthernet4/0/1] qos apply policy test inbound
[PE4-GigabitEthernet4/0/1] quit
# Configure the network-side port GigabitEthernet 4/0/2 as a trunk port, and assign the port to VLAN 200.
[PE4] interface Gigabitethernet 4/0/2
[PE4-GigabitEthernet4/0/2] port link-type trunk
[PE4-GigabitEthernet4/0/2] port trunk permit vlan 200
