- 13-Network Management and Monitoring Configuration Guide
- 01-System Maintenance and Debugging Configuration
- 02-NQA Configuration
- 03-NTP Configuration
- 04-Clock Monitoring Configuration
- 05-IPC Configuration
- 06-SNMP Configuration
- 07-RMON Configuration
- 08-CWMP Configuration
- 09-Sampler Configuration
- 10-Mirroring Configuration
- 11-Protocol Packet Statistics Configuration
- 12-sFlow Configuration
- 13-Information Center Configuration
04-Clock Monitoring Configuration | 127.79 KB |
Classification of clock sources
Working mode of the clock monitoring module
Working mode of the port clock
Clock monitoring module configuration task list
Configuring the working mode of the clock monitoring module of the SRPU
Configuring the reference source priority
Configuring the SSM for reference sources
Setting the ways of deriving SSM level
Setting the bit position for transmitting bits clock source information
Configuring SSM levels for the reference source
Setting the input port of the line clock (LPU port)
Displaying and maintaining clock monitoring module
Clock monitoring module configuration example
Overview
Clock monitoring module is responsible for providing highly-precise, highly-reliable SDH (synchronous digital hierarchy) line interface 38.88 MHz clock signals for different LPUs (line processing unit). It implements such functions as input clock source automatic selection, software phase-lock, and real-time monitoring of the clock status of the interface card. The clock monitoring module supports hardware reset of the clock card.
The clock monitoring module supports 14 reference clock sources (referred to as reference source hereafter). The first and the second are Bits clock sources, which correspond to external and others are line clock sources. The following figure shows the reference-slot relationship of the S9500E series switches:
Figure 1 Correspondence between reference source and slot
Clock sources can be classified into the following categories according to different sources of the clock source:
· Local clock source—38.88 MHz clock signals generated by a crystal oscillator inside the clock monitoring module.
· Bits clock source—Clock signals generated by a specific Bits clock device. The signals are sent to the clock monitoring module through a specific interface on the switching & routing processing unit (SRPU) and then sent to all cards by the clock monitoring module.
· Line clock source—Provided by the upper level device, whose precision is lower than that of the Bits clock source. The signals are derived from the specified WAN interface and sent to the clock monitoring module, which then sends the signals to all cards.
Reference source level
The reference source level is decided together by the priority and the SSM (synchronization status marker) level of the reference source.
Priority of the reference source
You can set a high priority for the reference source with high-precision and high-reliability to make it be first selected as the clock source.
SSM level of the reference source
SSM, also known as synchronization state marker, is used to indicate the synchronization timing signal level on a synchronization timing transmission link.
The priority of SSM level of the reference source, from high to low:
· PRC—G.811 clock signal
· TNC—G.812 transit node clock signal
· LNC—G.812 local node clock signal
· SETS—SDH device clock source signal
· Unknown—Unknown synchronization quality
· DNU—Cannot be used as a clock source
NOTE: The reference source whose SSM level is DNU cannot be used as a clock source. |
The clock monitoring module can be configured to work in one of the following two modes:
Manual mode
In this mode, the clock source is configured manually. The clock monitoring module does not switch the clock source automatically, but just tracks the primary reference source. If the primary reference source is lost, the clock monitoring module enters a holdover state.
Auto mode
In auto mode, the clock source is selected by the system automatically. When the primary clock source is lost or not available, the clock monitoring module selects another clock source based on the following rules:
· If SSM level is not activated, the clock source is decided by reference source priority. If two reference sources have the same priority, the one with the smaller reference source number (1 to 14) is selected. When the reference source with the highest priority is lost, the next available reference source with the highest priority is selected. When the former clock source becomes available, the system switches to that clock again.
· If SSM is activated, the clock source is decided by the SSM level. If two reference sources have the same SSM level, the reference source priority takes effect, in the way described above.
NOTE: The following clock sources are excluded in clock selection (when SSM is activated): · Clock sources whose signals are lost. · Clock sources whose priority is 255. · Clock sources whose SSM level is DNU (DoNotUse). |
Depending on the source of the port clock, a port supports the master clock mode and the slave clock mode.
Master mode
In this mode, the system uses the clock signals provided by the clock monitoring module. The signals include local clock signals and clock signals derived from LPU Port. If you have configured on the switch to derive clock signals from LPU Port, these derived signals are adopted; otherwise, local clock signals are adopted.
Slave mode
In this mode, the system uses line clock signals. Only when you specify LPU Port of the switch as the current port can the system derive the clock source from the line signals received on the current port and then send the clock source information to the clock monitoring module, which then sends the information to all cards.
IMPORTANT: When connected to SONET/SDH switches, a switch should be set to work in slave clock mode, because the SONET/SDH clock is more precise than that of the switch. |
Complete these tasks to configure clock monitoring module:
Task |
Remarks |
Configuring the working mode of the clock monitoring module of the SRPU |
Optional |
Optional |
Optional |
Setting the bit position for transmitting bits clock source information |
Optional |
Optional |
Optional |
Optional |
To configure the working mode of the clock monitoring module of the SRPU:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Set the working mode of the clock monitoring module. |
clock { auto | manual source source-number } |
The default working mode is auto. |
NOTE: After you set the working mode of the clock monitoring module, it takes a period of time for device response. You can check whether your configuration takes effect through the display clock device command and the logging information. |
In auto mode, the clock monitoring module selects and switches to a reference source with a higher priority based on SSM level and reference source priority.
To configure reference source priority:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure the reference source priority. |
clock priority value source source-number |
The default priority is 255. |
To derive the SSM level, use either of the following ways:
· For bits clock source, SSM level can be derived from the interface card and reported to the SRPU, which then sends the SSM level to the clock monitoring module.
· Configure SSM level as described in this section.
To set the ways of deriving SSM level:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the ways to derive SSM level. |
clock forcessm { on | off } source source-number |
By default, no SSM level is derived from any clock source. The SSM level is set by users. |
The bit position for transmitting Bits clock source information can be configured as sa4, sa5, sa6, sa7 and sa8. They are 5 bits in timeslot 0 of the even frame in a multi-frame as specified by ITU-TG.704 CRC4. You can choose one from the five bits to carry SSM information.
To set the bit for transmitting Bits clock source information:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the bit for transmitting the Bits clock source information. |
clock sa-bit { sa4 | sa5 | sa6 | sa7 | sa8 } source source-number |
The default setting is sa4. |
Follow these rules to manually set the SSM level for the clock source:
· For the line clock source, the SSM level configured is that of the clock source.
· For Bits clock source, if the input signal is a 2048 kbps (E1) signal and the clock forcessm off source source-number command is executed, the clock source adopts the SSM level derived from the input signals and the SSM configured is omitted.
· For Bits clock source, if the input signal is a 2048 kHz signal or a 2048 kbps signal and the clock forcesssm on source source-number command is executed, the clock source adopts the SSM level configured.
To set the SSM levels:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the SSM levels of the reference source. |
clock ssm { dnu | lnc | prc | sets | tnc | unknown } source source-number |
The default setting is unknown. |
Activating/deactivating SSM
Whether the SSM levels are obtained through clock signals or configured manually, you have to set to activate or deactivate them before they can take effect.
· When SSM is activated, the reference source level is decided by the SMM level first and then the priority of the reference source in automatic clock source selection.
· When SSM is not activated, you can still set and view the SSM levels, but they are ignored and the reference source level is decided by the priority of the reference source in automatic clock source selection.
To activate or deactivate SSM:
Step |
Command |
Remarks |
system-view |
N/A |
2. Activate/deactivate SSM. |
clock ssmcontrol { on | off } |
By default, SSM is deactivated. |
To set the input port of the line clock (LPU port):
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the input port of the line clock. |
clock lpuport interface-type interface-number |
Optional. By default, the clock input port is the first configurable port by port name in alphabetical order of the interface card. |
3. Enter interface view (POS interface). |
N/A |
4. Set the input interface to work in Slave mode. |
clock slave |
Optional. By default, the input interface works in Slave mode. |
NOTE: For a POS interface card, if you set the port clock to work in Slave mode, you must use the clock lpuport command to set the input port of the card clock source. |
Task |
Command |
Remarks |
Display the current configuration of the clock monitoring module. |
display clock config [ | { begin | exclude | include } regular-expression ] |
Available in any view |
Display the detailed information of the clock monitoring module. |
display clock device [ | { begin | exclude | include } regular-expression ] |
Display the input clock source port of the line card. |
display clock lpuport [ | { begin | exclude | include } regular-expression ] |
Display the lock state of the clock monitoring module. |
display clock phase-lock-state [ | { begin | exclude | include } regular-expression ] |
Display the priority of all reference sources. |
display clock priority [ | { begin | exclude | include } regular-expression ] |
Display the self-test result of the clock monitoring module. |
display clock self-test-result [ | { begin | exclude | include } regular-expression ] |
Display the state of all reference sources. |
display clock source [ | { begin | exclude | include } regular-expression ] |
Display the SSM level of all reference sources. |
display clock ssm-level [ | { begin | exclude | include } regular-expression ] |
Display the SSM level of the output clock signal. |
display clock ssm-output [ | { begin | exclude | include } regular-expression ] |
Display the clock monitoring module version. |
display clock version [ | { begin | exclude | include } regular-expression ] |
Display the working mode of the clock monitoring module of the SRPU. |
display clock work-mode [ | { begin | exclude | include } regular-expression ] |
NOTE: By default, Ethernet, VLAN, and aggregate interfaces are in DOWN state. To configure these interfaces, use the undo shutdown command to bring up these interfaces first. |
Network requirements
· Device A and Device B are connected through the POS interfaces. Device A is equipped with clock monitoring module on its SRPU.
· The synchronized clock of Device A is provided by the clock monitoring module on its SRPU.
· Device B adopts the line clock from Device A to synchronize with the SDH line of Device A.
Figure 2 Network diagram
Configuration procedure
1. Configure Device A (Master clock):
# Set interface POS 3/1/1 to work in master clock mode, using local clock signals.
[DeviceA] interface pos 3/1/1
[DeviceA-Pos3/1/1] clock master
2. Configure Device B (Slave clock):
# Set the line clock source input interface on Device B to POS 3/1/1.
[DeviceB] clock lpuport pos 3/1/1
# Set the interface POS 3/1/1 to work in slave clock mode.
[DeviceB] interface pos 3/1/1
[DeviceB-Pos3/1/1] clock slave
[DeviceB-Pos3/1/1] quit
# Enable the clock source from POS 3/1/1; set the clock to work in manual mode and adopt clock source 8, which is the master clock source, and corresponds to slot 3 (see Figure 1 for the correspondence between reference source and slot).
[DeviceB] clock manual source 8
After the configuration is complete, all the other WAN interface cards get the same clock frequency derived by the clock card from the port 1 line clock of the POS interface card in slot 3. In this way, all the interface cards on the device can get precise, reliable, synchronized SDH line interface clock signals.
