06-Layer 3 - IP Services Configuration Guide
HomeSupportSwitchesH3C S9500E Switch SeriesConfigure & DeployConfiguration GuidesH3C S9500E Configuration Guide-Release1728-6W17006-Layer 3 - IP Services Configuration Guide
08-IP Performance Optimization Configuration
08-IP Performance Optimization Configuration 149.48 KB
The switch supports two operation modes: standalone (default) and IRF. For more information about IRF mode, see IRF Configuration Guide.
IP performance optimization overview
In some network environments, you can adjust the IP parameters to achieve best network performance. IP performance optimization configuration includes:
·           Enabling the switch to forward directed broadcasts
·           Configuring TCP timers
·           Configuring the TCP buffer size
·           Enabling ICMP error packets sending
·           Enabling support for ICMP extensions
·           Enabling ICMP flow control
Enabling forwarding of directed broadcasts to a directly connected network
Directed broadcast packets are broadcast on a specific network. In the destination IP address of a directed broadcast, the network ID identifies the target network, and the host ID is all ones. If a switch is allowed to forward directed broadcasts to a directly connected network, hackers may mount attacks to the network. Therefore, the switch is disabled from receiving and forwarding directed broadcasts to a directly connected network by default. However, you should enable the feature when:
·           Using the UDP Helper function to convert broadcasts to unicasts and forward them to a specified server.
·           Using the Wake on LAN function to forward directed broadcasts to a host on the remote network.
To enable the switch to forward directed broadcasts:
Step
Remarks
1.     Enter system view.
N/A
2.     Enter VLAN interface view.
N/A
3.     Enable forwarding of directed broadcasts to a directly connected network on the interface.
ip forward-broadcast
By default, the switch is disabled from forwarding directed broadcasts to a directly connected network.
CAUTION
CAUTION:
·       You can enable forwarding of directed broadcasts to a directly connected network on a VLAN interface only. Although you can enable this feature on a super-VLAN interface, the switch cannot forward corresponding directed broadcasts.
·       After this feature is enabled on an interface, the switch automatically generates a forwarding entry for the network segment where the interface is located. H3C recommends you not configure a static ARP entry or a static route for the corresponding network segment because of possible configuration conflict. For example, if an interface on network segment 10.0.0.1/24 has this feature enabled, the switch generates a forwarding entry of 10.0.0.255/32. If a static ARP entry for 10.0.0.255 is configured, a configuration conflict occurs and logs may be generated. If such a conflict occurs, you must delete both the static ARP entry and the directed broadcast configuration, and reconfigure forwarding of directed broadcasts or a static ARP entry. After that, the service resumes.
·       To forward directed broadcasts, make sure the link status and protocol status of the interface must be up.
Configuration example
Network requirements
As shown in Figure 1, the interface of Host A and VLAN-interface 3 of Switch A are located on network segment 1.1.1.0/24. VLAN-interface 2 of Switch A and VLAN-interface 3 of Switch B are located on network segment 1.1.2.0/24. VLAN-interface 2 of Switch B, Host B, and Host C are located on network segment 1.1.3.0/24. The default gateway of Host A is VLAN-interface 3 (IP address 1.1.1.1/24) of Switch A. The default gateway of Host B and Host C is VLAN-interface 2 (IP address 1.1.3.1/24) of Switch B.
Configure static routes on Switch A and Switch B for reachability between Host A and Host B, and Host A and Host C, respectively.
Enable forwarding of directed broadcasts on Switch A and Switch B so that Host C and Host B can receive directed broadcasts from Host A.
Figure 1 Network diagram
Configuration procedure
·           Configure Switch A:
# Configure a static route on Switch A.
[SwitchA] ip route-static 1.1.3.0 255.255.255.0 1.1.2.2
# Configure IP addresses for VLAN-interface 3 and VLAN-interface 2.
[SwitchA-Vlan-interface3] ip address 1.1.1.1 24
[SwitchA-Vlan-interface3] quit
[SwitchA-Vlan-interface2] ip address 1.1.2.1 24
# Enable VLAN-interface 2 to forward directed broadcasts.
[SwitchA-Vlan-interface2] ip forward-broadcast
·           Configure Switch B:
# Configure a static route on Switch B.
[SwitchB] ip route-static 1.1.1.0 255.255.255.0 1.1.2.1
[SwitchB-Vlan-interface3] ip address 1.1.2.2 24
[SwitchB-Vlan-interface2] ip address 1.1.3.1 24
[SwitchB-Vlan-interface2] ip forward-broadcast
Ping the subnet broadcast address 1.1.3.255 of VLAN-interface 2 of Switch B from Host A. The ping packets can be received by Host B and Host C.
Configuring TCP attributes
Configuring the TCP send/receive buffer size
To configure the TCP send/receive buffer size:
Step
Remarks
N/A
2.     Configure the size of TCP receive/send buffer.
tcp window window-size
Optional.
8 KB by default.
You can configure the following TCP timers:
·           synwait timerWhen sending a SYN packet, TCP starts the synwait timer. If no response packets are received within the synwait timer interval, the TCP connection cannot be created.
·           finwait timerWhen a TCP connection is changed into FIN_WAIT_2 state, the finwait timer is started. If no FIN packets are received within the timer interval, the TCP connection is terminated. If a FIN packet is received, the TCP connection state changes to TIME_WAIT. If a non-FIN packet is received, the system restarts the timer upon receiving the last non-FIN packet. The connection is broken after the timer expires.
To configure TCP timers:
Step
Remarks
N/A
2.     Configure the TCP synwait timer.
Optional.
75 seconds by default.
3.     Configure the TCP finwait timer.
Optional.
675 seconds by default.
CAUTION
CAUTION:
The actual length of the finwait timer is determined by the following formula:
Actual length of the finwait timer = (Configured length of the finwait timer – 75) + configured length of the synwait timer
Configuring ICMP to send error packets
Introduction
Sending error packets is a major function of ICMP protocol. In case of network abnormalities, error packets are usually sent by the network or transport layer protocols to notify corresponding switches so as to facilitate control and management.
Advantages of sending ICMP error packets
There are three kinds of ICMP error packets: redirect packets, timeout packets and destination unreachable packets.
1.      ICMP redirect packets
A host may have only a default route to the default gateway in its routing table after startup. The default gateway will send ICMP redirect packets to the source host, telling it to reselect a correct next hop to send the subsequent packets, if the following conditions are satisfied:
¡  The receiving and forwarding interfaces are the same.
¡  The selected route has not been created or modified by ICMP redirect packet.
¡  The selected route is not the default route of the switch.
¡  There is no source route option in the packet.
ICMP redirect packets function simplifies host administration and enables a host to gradually establish a sound routing table to find out the best route.
2.      ICMP timeout packets
If the switch receives an IP packet with a timeout error, it drops the packet and sends an ICMP timeout packet to the source.
The switch sends an ICMP timeout packet under the following conditions:
¡  If the switch finds the destination of a packet is not itself and the TTL field of the packet is 1, it will send a “TTL timeout” ICMP error message.
¡  When the switch receives the first fragment of an IP datagram whose destination is the switch itself, it starts a timer. If the timer times out before all the fragments of the datagram are received, the switch will send a “reassembly timeout” ICMP error packet.
Disadvantages of sending ICMP error packets
Although sending ICMP error packets facilitates network control and management, it still has the following disadvantages:
·           Sending a lot of ICMP packets increases network traffic.
·           A device’s performance degrades if it receives a lot of malicious packets that cause it to respond with ICMP error packets.
·           A host’s performance degrades if the redirection function increases the size of its routing table.
·           End users can be affected if a host sends malicious ICMP destination unreachable packets.
To prevent such problems, you can disable the switch from sending ICMP error packets.
To disable sending of ICMP error packets:
Step
Remarks
N/A
2.     Enable sending of ICMP redirect packets.
ip redirects enable
Disabled by default
3.     Enable sending of ICMP timeout packets.
ip ttl-expires enable
Disabled by default
·       You can configure this feature only on the VLAN interfaces of an Ethernet interface card.
·       When sending ICMP timeout packets is disabled, the switch will not send “TTL timeout” ICMP error packets. However, “reassembly timeout” error packets will be sent normally.
Introduction
Generally, ICMP messages are of a fixed format and cannot carry extension information. With support for ICMP extensions enabled, a switch appends an extension information field to the ICMP messages as needed. The switch can append only MPLS label information to ICMP messages.
ICMP extensions for MPLS
In MPLS networks, when a packet's TTL expires, MPLS stripes the MPLS header, encapsulates the remaining datagram into an ICMP time exceeded message, and sends the message to the egress router of the MPLS tunnel. Then the egress router sends the message back to the ingress router of the tunnel. The ICMP message, however, does not contain the label information that is very important to the ingress router. With support for ICMP extensions enabled, the switch appends the MPLS label to the ICMP time exceeded message before sending it back to the ingress router of the tunnel.
ICMP extensions are usually used for an enhanced traceroute implementation in MPLS networks, in which MPLS label information of each hop the original datagram arrives at is printed.
Handling ICMP messages
ICMP messages can be classified into three types:
·           Common ICMP messagesWithout any extension information.
·           Extended ICMP messages with a length fieldCarries extension information and a length field. The length field indicates the length of the original datagram that is encapsulated within the ICMP header and excludes the ICMP extension length. Such an ICMP message complies with RFC 4884.
·           Extended ICMP messages without a length fieldCarries extension information but does not contain a length field. Such an ICMP message does not comply with RFC 4884.
Based on how these messages are handled, the switch can work in one of these modes: common mode, compliant mode, and non-compliant mode. Table 1 shows how ICMP messages are handled in different working modes.
Table 1 Handling ICMP messages
Device mode
ICMP messages sent
ICMP messages received
Remarks
Common mode
Extension information in extended ICMP messages will not be processed.
Compliant mode
Extended ICMP messages without a length field are handled as common ICMP messages.
Non-compliant mode
All three types of ICMP messages
N/A
ICMP/ICMPv6 messages that can carry extension information include only IPv4 redirect messages, IPv4/IPv6 time exceeded messages, and IPv4/IPv6 destination unreachable messages.
To enable support for ICMP extensions:
Step
Remarks
N/A
2.     Enable support for ICMP extensions in compliant mode.
ip icmp-extensions compliant
Optional.
Disabled by default.
3.     Enable support for ICMP extensions in non-compliant mode.
ip icmp-extensions non-compliant
Optional.
After support for ICMP extensions is disabled, no ICMP message sent by the switch contains extension information.
If a large number of ICMP packets are delivered to the CPU for processing, processing of other services is affected. To prevent this, you can enable ICMP flow control.
To enable ICMP flow control:
Step
Remarks
N/A
2.     Enable ICMP flow control.
ip icmp flow-control
Disabled by default
Displaying and maintaining IP performance optimization
Remarks
Display TCP connection statistics.
display tcp statistics [ | { begin | exclude | include } regular-expression ]
Available in any view
Display UDP statistics.
display udp statistics [ | { begin | exclude | include } regular-expression ]
Display statistics of IP packets (Standalone mode).
display ip statistics [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display statistics of IP packets (IRF mode).
display ip statistics [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression
Display statistics of ICMP flows (Standalone mode).
display icmp statistics [ slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display statistics of ICMP flows (IRF mode).
display icmp statistics [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Display socket information (Standalone mode).
display ip socket [ socktype sock-type ] [ task-id socket-id ] [ slot slot-number ] [ | { begin | exclude | include } regular-expression
Display socket information (IRF mode).
display ip socket [ socktype sock-type ] [ task-id socket-id ] [ chassis chassis-number slot slot-number ] [ | { begin | exclude | include } regular-expression ]
Clear statistics of IP packets (Standalone mode).
Available in user view
Clear statistics of IP packets (IRF mode).
reset ip statistics [ chassis chassis-number slot slot-number ]
Clear statistics of TCP connections.
reset tcp statistics
Clear statistics of UDP traffic.
reset udp statistics
