- 02-IP Services Volume
- 00-IP Services Volume Organization
- 01-IP Addressing Configuration
- 02-ARP Configuration.doc
- 03-DHCP Configuration.doc
- 04-DNS Configuration
- 05-IP Performance Configuration
- 06-UDP Helper Configuration
- 07-URPF Configuration
- 08-IPv6 Basics Configuration
- 09-Dual Stack Configuration
- 10-Tunneling Configuration
- 11-sFlow Configuration
03-DHCP Configuration.doc | 570.89 KB |
Dynamic IP Address Allocation Process
IP Address Allocation Sequence
DHCP Server Configuration Task List
Enabling the DHCP Server on an Interface
Configuring an Address Pool for the DHCP Server
Configuring an Address Allocation Mode
Configuring a Domain Name Suffix for the Client
Configuring DNS Servers for the Client
Configuring WINS Servers and NetBIOS Node Type for the Client
Configuring the BIMS Server Information for the Client
Configuring Gateways for the Client
Configuring Option 184 Parameters for the Client with Voice Service
Configuring the TFTP Server and Bootfile Name for the Client
Configuring Self-Defined DHCP Options
Configuring the DHCP Server Security Functions
Enabling Unauthorized DHCP Server Detection
Configuring IP Address Conflict Detection
Configuring the Handling Mode for Option 82
Displaying and Maintaining the DHCP Server
DHCP Server Configuration Examples
Static IP Address Assignment Configuration Example
Dynamic IP Address Assignment Configuration Example
Self-Defined Option Configuration Example
Troubleshooting DHCP Server Configuration
3 DHCP Relay Agent Configuration
Introduction to DHCP Relay Agent
DHCP Relay Agent Support for Option 82
Configuring the DHCP Relay Agent
Enabling the DHCP Relay Agent on an Interface
Correlating a DHCP Server Group with a Relay Agent Interface
Configuring the DHCP Relay Agent to Send a DHCP-Release Request
Configuring the DHCP Relay Agent Security Functions
Configuring the DHCP Relay Agent to Support Option 82
Displaying and Maintaining DHCP Relay Agent Configuration
DHCP Relay Agent Configuration Examples
DHCP Relay Agent Option 82 Support Configuration Example
Troubleshooting DHCP Relay Agent Configuration
Enabling the DHCP Client on an Interface
Displaying and Maintaining the DHCP Client
DHCP Client Configuration Example
Application Environment of Trusted Ports
DHCP Snooping Support for Option 82
Configuring DHCP Snooping Basic Functions
Configuring DHCP Snooping to Support Option 82
Displaying and Maintaining DHCP Snooping
DHCP Snooping Configuration Examples
DHCP Snooping Option 82 Support Configuration Example
The fast expansion and growing complexity of networks result in scarce IP addresses assignable to hosts. Meanwhile, as many people need to take their laptops across networks, the IP addresses need to be changed accordingly. Therefore, related configurations on hosts become more complex. The Dynamic Host Configuration Protocol (DHCP) was introduced to solve these problems.
DHCP is built on a client-server model, in which a client sends a configuration request and then the server returns a reply to send configuration parameters such as an IP address to the client.
A typical DHCP application, as shown in Figure 1-1, includes a DHCP server and multiple clients (PCs and laptops).
Figure 1-1 A typical DHCP application
A DHCP client can get an IP address and other configuration parameters from a DHCP server on another subnet via a DHCP relay agent. For information about the DHCP relay agent, refer to Introduction to DHCP Relay Agent.
DHCP Address Allocation
Allocation Mechanisms
DHCP supports three mechanisms for IP address allocation.
l Manual allocation: The network administrator assigns an IP address to a client like a WWW server, and DHCP conveys the assigned address to the client.
l Automatic allocation: DHCP assigns a permanent IP address to a client.
l Dynamic allocation: DHCP assigns an IP address to a client for a limited period of time, which is called a lease. Most DHCP clients obtain their addresses in this way.
Figure 1-2 Dynamic IP address allocation process
As shown in Figure 1-2, a DHCP client obtains an IP address from a DHCP server via four steps:
1) The client broadcasts a DHCP-DISCOVER message to locate a DHCP server.
2) A DHCP server offers configuration parameters such as an IP address to the client in a DHCP-OFFER message. The sending mode of the DHCP-OFFER is determined by the flag field in the DHCP-DISCOVER message. Refer to DHCP Message Format for related information.
3) If several DHCP servers send offers to the client, the client accepts the first received offer, and broadcasts it in a DHCP-REQUEST message to formally request the IP address.
4) All DHCP servers receive the DHCP-REQUEST message, but only the server from which the client accepts the offered IP address returns a DHCP-ACK message to the client, confirming that the IP address has been allocated to the client, or returns a DHCP-NAK unicast message, denying the IP address allocation.
l After the client receives the DHCP-ACK message, it will probe whether the IP address assigned by the server is in use by broadcasting a gratuitous ARP packet. If the client receives no response within the specified time, the client can use this IP address. Otherwise, the client sends a DHCP-DECLINE message to the server and requests an IP address again.
l IP addresses offered by other DHCP servers are still assignable to other clients.
IP Address Lease Extension
The IP address dynamically allocated by a DHCP server to a client has a lease. When the lease expires, the IP address will be reclaimed by the DHCP server. If the client wants to use the IP address longer, it has to extend the lease duration.
When the half lease duration elapses, the DHCP client sends to the DHCP server a DHCP-REQUEST unicast to extend the lease duration. Upon availability of the IP address, the DHCP server returns a DHCP-ACK unicast confirming that the client’s lease duration has been extended, or a DHCP-NAK unicast denying the request.
If the client receives no reply, it will broadcast another DHCP-REQUEST message for lease extension after 7/8 lease duration elapses. The DHCP server will handle the request as above mentioned.
DHCP Message Format
Figure 1-3 gives the DHCP message format, which is based on the BOOTP message format and involves eight types. These types of messages have the same format except that some fields have different values. The numbers in parentheses indicate the size of each field in bytes.
Figure 1-3 DHCP message format
l op: Message type defined in option field. 1 = REQUEST, 2 = REPLY
l htype, hlen: Hardware address type and length of a DHCP client.
l hops: The number of relay agents a request message traveled.
l xid: Transaction ID, a random number chosen by the client to identify an IP address allocation.
l secs: Filled in by the client, the number of seconds elapsed since the client began address acquisition or renewal process. Currently this field is reserved and set to 0.
l flags: The leftmost bit is defined as the BROADCAST (B) flag. If this flag is set to 0, the DHCP server sent a reply back by unicast; if this flag is set to 1, the DHCP server sent a reply back by broadcast. The remaining bits of the flags field are reserved for future use.
l ciaddr: Client IP address.
l yiaddr: 'your' (client) IP address, assigned by the server.
l siaddr: Server IP address, from which the clients obtained configuration parameters.
l giaddr: IP address of the first relay agent a request message traveled.
l chaddr: Client hardware address.
l sname: The server host name, from which the client obtained configuration parameters.
l file: Bootfile name and path information, defined by the server to the client.
l options: Optional parameters field that is variable in length, which includes the message type, lease, domain name server IP address, and WINS IP address.
DHCP Options
DHCP Options Overview
The DHCP message adopts the same format as the Bootstrap Protocol (BOOTP) message for compatibility, but differs from it in the option field, which identifies new features for DHCP.
DHCP uses the option field in DHCP messages to carry control information and network configuration parameters, implementing dynamic address allocation and providing more network configuration information for clients.
Figure 1-4 shows the DHCP option format.
Introduction to DHCP Options
The common DHCP options are:
l Option 3: Router option. It specifies the gateway address to be assigned to the client.
l Option 6: DNS server option. It specifies the DNS server IP address to be assigned to the client.
l Option 51: IP address lease option.
l Option 53: DHCP message type option. It identifies the type of the DHCP message.
l Option 55: Parameter request list option. It is used by a DHCP client to request specified configuration parameters. The option contains values that correspond to the parameters requested by the client.
l Option 66: TFTP server name option. It specifies a TFTP server to be assigned to the client.
l Option 67: Bootfile name option. It specifies the bootfile name to be assigned to the client.
l Option 150: TFTP server IP address option. It specifies the TFTP server IP address to be assigned to the client.
l Option 121: Classless route option. It specifies a list of classless static routes (the destination addresses in these static routes are classless) that the requesting client should add to its routing table.
l Option 33: Static route option. It specifies a list of classful static routes (the destination addresses in these static routes are classful) that a client should add to its routing table. If Option 121 exists, Option 33 is ignored.
For more information about DHCP options, refer to RFC 2132.
Self-Defined Options
Some options, such as Option 43, have no unified definitions in RFC 2132. The formats of some self-defined options are introduced as follows.
Vendor-specific option (Option 43)
DHCP servers and clients exchange vendor-specific information through messages containing the vendor-specific option (Option 43). Upon receiving a DHCP message requesting Option 43 (in Option 55), the DHCP server returns a response message containing Option 43 to assign vendor-specific information to the DHCP client.
The DHCP client can obtain the following information through Option 43:
l Auto-Configuration Server (ACS) parameters, including the ACS URL, username, and password.
l Service provider identifier acquired by the customer premises equipment (CPE) from the DHCP server and sent to the ACS for selecting vender-specific configurations and parameters.
l Preboot Execution Environment (PXE) server address for further obtaining the bootfile or other control information from the PXE server.
1) Format of Option 43
Figure 1-5 Format of Option 43
For the sake of scalability, network configuration parameters are carried in different sub-options of Option 43 so that the DHCP client can obtain more information through Option 43 as shown in Figure 1-5. The sub-option fields are described as follows:
l Sub-option type: Type of a sub-option. The field value can be 0x01, 0x02, or 0x80. 0x01 indicates an ACS parameter sub-option. 0x02 indicates a service provider identifier sub-option. 0x80 indicates a PXE server address sub-option.
l Sub-option length: Length of a sub-option excluding the sub-option type and sub-option length fields.
l Sub-option value: Value of a sub-option.
2) Format of the sub-option value field of Option 43
l As shown in Figure 1-6, the value field of the ACS parameter sub-option is filled in with variable ACS URL, username, and password separated with a space (0x20) in between.
Figure 1-6 Format of the value field of the ACS parameter sub-option
l The value field of the service provider identifier sub-option contains the service provider identifier.
l Figure 1-7 shows the format of the value field of the PXE server address sub-option. Currently, the value of the PXE server type can only be 0. The server number field indicates the number of PXE servers contained in the sub-option. The server IP addresses filed contains the IP addresses of the PXE servers.
Figure 1-7 Format of the value field of the PXE server address sub-option
Relay agent option (Option 82)
Option 82 is the relay agent option in the option field of the DHCP message. It records the location information of the DHCP client. When a DHCP relay agent or DHCP snooping device receives a client’s request, it adds Option 82 to the request message and sends it to the server.
The administrator can locate the DHCP client to further implement security control and accounting. The Option 82 supporting server can also use such information to define individual assignment policies of IP address and other parameters for the clients.
Option 82 involves at most 255 sub-options. At least one sub-option must be defined. Now the DHCP relay agent supports two sub-options: sub-option 1 (Circuit ID) and sub-option 2 (Remote ID).
Option 82 has no unified definition. Its padding formats vary with vendors.
You can use the following two methods to configure Option 82:
l User-defined method: Manually specify the content of Option 82.
l Non-user-defined method: Pad Option 82 in the default normal or verbose format.
If you choose the second method, you can specify the code type for the sub-options as ASCII or HEX.
1) Normal padding format
The padding contents for sub-options in the normal padding format are:
l sub-option 1: Padded with the VLAN ID and interface number of the interface that received the client’s request. Figure 1-8 gives its format. The value of the sub-option type is 1, and that of the circuit ID type is 0.
Figure 1-8 Sub-option 1 in normal padding format
l sub-option 2: Padded with the MAC address of the DHCP relay agent interface or the MAC address of the DHCP snooping device that received the client’s request. Figure 1-9 gives its format. The value of the sub-option type is 2, and that of the remote ID type is 0.
Figure 1-9 Sub-option 2 in normal padding format
2) Verbose padding format:
The padding contents for sub-options in the verbose padding format are:
l sub-option 1: Padded with the user-specified access node identifier (ID of the device that adds Option 82 in DHCP messages), and type, number, and VLAN ID of the interface that received the client’s request. Its format is shown in Figure 1-10.
Figure 1-10 Sub-option 1 in verbose padding format
In Figure 1-10, except that the VLAN ID field has a fixed length of 2 bytes, all the other padding contents of sub-option 1 are length variable.
l sub-option 2: Padded with the MAC address of the DHCP relay agent interface or the MAC address of the DHCP snooping device that received the client’s request. It has the same format as that in normal padding format, as shown in Figure 1-9.
Option 184
Option 184 is a reserved option, and parameters in the option can be defined as needed. The device supports Option 184 carrying the voice related parameters, so a DHCP client with voice functions can get an IP address along with specified voice parameters from the DHCP server.
Option 184 involves the following sub-options:
l Sub-option 1: IP address of the primary network calling processor, which is a server serving as the network calling control source and providing program downloads.
l Sub-option 2: IP address of the backup network calling processor that DHCP clients will contact when the primary one is unreachable.
l Sub-option 3: Voice VLAN ID and the result whether DHCP clients take this ID as the voice VLAN or not.
l Sub-option 4: Failover route that specifies the destination IP address and the called number (SIP users use such IP addresses and numbers to communicate with each other) that a SIP user uses to reach another SIP user when both the primary and backup calling processors are unreachable.
You must define the sub-option 1 to make other sub-options take effect.
Protocols and Standards
l RFC2131: Dynamic Host Configuration Protocol
l RFC2132: DHCP Options and BOOTP Vendor Extensions
l RFC1542: Clarifications and Extensions for the Bootstrap Protocol
l RFC 3046: DHCP Relay Agent Information Option
When configuring the DHCP server, go to these sections for information you are interested in:
l DHCP Server Configuration Task List
l Enabling the DHCP Server on an Interface
l Configuring an Address Pool for the DHCP Server
l Configuring the DHCP Server Security Functions
l Configuring the Handling Mode for Option 82
l Displaying and Maintaining the DHCP Server
l DHCP Server Configuration Examples
l Troubleshooting DHCP Server Configuration
l The DHCP server configuration is supported only on VLAN interfaces and loopback interfaces. The secondary IP address pool configuration is not supported on loopback interfaces.
l DHCP snooping must be disabled on the DHCP server.
Introduction to DHCP Server
The DHCP server is well suited to the network where:
l It is hard to implement manual configuration and centralized management.
l The hosts are more than the assignable IP addresses and it is impossible to assign a fixed IP address to each host. For example, an ISP limits the number of hosts to access the Internet at a time, so lots of hosts need to acquire IP addresses dynamically.
l A few hosts need fixed IP addresses.
DHCP Address Pool
Address pool structure
In response to a client’s request, the DHCP server selects an idle IP address from an address pool and sends it together with other parameters such as lease and DNS server address to the client.
The address pool database is organized as a tree. The root of the tree is the address pool for natural networks, branches are address pools for subnets, and leaves are addresses statically bound to clients. For the same level address pools, a previously configured pool has a higher selection priority than a new one.
At the very beginning, subnetworks inherit network parameters and clients inherit subnetwork parameters. Therefore, common parameters, for example a DNS server address, should be configured at the highest (network or subnetwork) level of the tree.
After establishment of the inheritance relationship, the new configuration at the higher level (father) of the tree will be:
l Inherited if the lower level (child) has no such configuration, or
l Overridden if the lower level (child) has such configuration.
The IP address lease does not enjoy the inheritance attribute.
Principles for selecting an address pool
The DHCP server observes the following principles to select an address pool when assigning an IP address to a client:
1) If there is an address pool where an IP address is statically bound to the MAC address or ID of the client, the DHCP server will select this address pool and assign the statically bound IP address to the client. For the configuration of this address pool, refer to section Configuring manual address allocation.
2) Otherwise, the DHCP server will select the smallest address pool that contains the IP address of the receiving interface (if the client and the server reside in the same network segment), or the smallest address pool that contains the IP address specified in the giaddr field of the client’s request (if a DHCP relay agent is in-between). If no IP address is available in the address pool, the DHCP server will fail to assign an address to the client because it cannot assign an IP address from the father address pool to the client. For the configuration of such address pool, refer to section Configuring dynamic address allocation.
For example, two address pools are configured on the DHCP server, 1.1.1.0/24 and 1.1.1.0/25. If the IP address of the interface receiving DHCP requests is 1.1.1.1/25, the DHCP server will select IP addresses for clients from address pool 1.1.1.0/25. If no IP address is available in the address pool, the DHCP server will fail to assign addresses to clients. If the IP address of the interface receiving DHCP requests is 1.1.1.130/25, the DHCP server will select IP addresses for clients from the 1.1.1.0/24 address pool.
Keep the IP addresses for dynamic allocation within the subnet where the interface of the DHCP server or DHCP relay agent resides to avoid wrong IP address allocation.
A DHCP server assigns an IP address to a client according to the following sequence:
1) The IP address manually bound to the client’s MAC address or ID
2) The IP address that was ever assigned to the client
3) The IP address designated by the Option 50 field in a DHCP-DISCOVER message
4) The first assignable IP address found in a proper DHCP address pool
5) The IP address that was a conflict or passed its lease duration
If no IP address is assignable, the server will not respond.
Complete the following tasks to configure the DHCP server:
Remarks |
Required |
Optional |
Required |
Optional |
Optional |
Enabling DHCP
Enable DHCP before performing other configurations.
Follow these steps to enable DHCP:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable DHCP |
dhcp enable |
Required Disabled by default. |
With the DHCP server enabled on an interface, upon receiving a client’s request, the DHCP server will assign an IP address from its address pool to the DHCP client.
Follow these steps to enable the DHCP server on an interface:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter interface view |
Enable the DHCP server on an interface |
dhcp select server global-pool [ subaddress ] |
Optional Enabled by default. |
If a DHCP relay agent exists between the DHCP server and client, the DHCP server, regardless of whether the subaddress keyword is used, will select an IP address from the address pool containing the primary IP address of the DHCP relay agent’s interface (connected to the client).
When the DHCP server and client are on the same subnet:
l With the keyword subaddress specified, the DHCP server will assign an IP address from the address pool containing the secondary IP address of the server’s interface (connected to the client); if the interface has multiple secondary IP addresses, the address pool containing the first assignable secondary IP address is selected. If the interface has no secondary IP addresses, the server is unable to assign an IP address to the client.
l Without the keyword subaddress specified, the DHCP server will assign an IP address from the address pool containing the primary IP address of the server’s interface (connected to the client).
Complete the following tasks to configure an address pool:
Task |
Remarks |
Required |
Required to configure either of the two |
Optional |
Configuring WINS Servers and NetBIOS Node Type for the Client |
Configuring Option 184 Parameters for the Client with Voice Service |
Configuring the TFTP Server and Bootfile Name for the Client |
Creating a DHCP Address Pool
Follow these steps to create a DHCP address pool:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Create a DHCP address pool and enter its view |
dhcp server ip-pool pool-name |
Required No DHCP address pool is created by default. |
You can configure either the static binding or dynamic address allocation for an address pool as needed.
It is required to specify an address range for the dynamic address allocation. A static binding is a special address pool containing only one IP address.
Some DHCP clients such as a WWW server need fixed IP addresses. You can create a static binding of a client’s MAC or ID to IP address in the DHCP address pool.
When the client with the MAC address or ID requests an IP address, the DHCP server will find the IP address from the binding for the client.
A DHCP address pool now supports only one static binding, which can be a MAC-to-IP or ID-to-IP binding.
Follow these steps to configure the static binding in a DHCP address pool:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter DHCP address pool view |
Bind IP addresses statically |
static-bind ip-address ip-address [ mask-length | mask mask ] |
Required No IP addresses are statically bound by default. |
Bind MAC addresses or IDs statically |
Specify the MAC address |
static-bind mac-address mac-address |
Required to configure either of the two Neither is bound statically by default. |
Specify the ID |
static-bind client-identifier client-identifier |
l Use the static-bind ip-address command together with static-bind mac-address or static-bind client-identifier command to accomplish a static binding configuration.
l In a DHCP address pool, if you execute the static-bind mac-address command before the static-bind client-identifier command, the latter will overwrite the former and vice versa.
l If you use the static-bind ip-address, static-bind mac-address, or static-bind client-identifier command repeatedly in the DHCP address pool, the new configuration will overwrite the previous one.
l The IP address of the static binding cannot be an interface address of the DHCP server. Otherwise, an IP address conflict may occur and the bound client cannot obtain an IP address correctly.
l The ID of the static binding must be identical to the ID displayed by using the display dhcp client verbose command on the client. Otherwise, the client cannot obtain an IP address.
l If the interfaces on a DHCP client share the same MAC address, you need to specify the client ID, rather than the MAC address, in a static binding to identify the requesting interface; otherwise, the client may fail to obtain an IP address.
You need to specify one and only one address range using a mask for the dynamic address allocation.
To avoid address conflicts, the DHCP server excludes IP addresses used by the gateway or FTP server from dynamic allocation.
You can specify the lease duration for a DHCP address pool different from others, and a DHCP address pool can only have the same lease duration. A lease does not enjoy the inheritance attribute.
Follow these steps to configure the dynamic address allocation:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Specify an IP address range |
network network-address [ mask-length | mask mask ] |
Required Not specified by default, meaning no assignable address. |
Specify the address lease duration |
expired { day day [ hour hour [ minute minute ] ] | unlimited } |
Optional One day by default. |
Return to system view |
quit |
Exclude IP addresses from automatic allocation |
dhcp server forbidden-ip low-ip-address [ high-ip-address ] |
Optional Except IP addresses of the DHCP server interfaces, all addresses in the DHCP address pool are assignable by default. |
l In DHCP address pool view, using the network command repeatedly overwrites the previous configuration.
l Using the dhcp server forbidden-ip command repeatedly can exclude multiple IP address ranges from allocation.
You can specify a domain name suffix in each DHCP address pool on the DHCP server to provide the clients with the domain name suffix. With this suffix assigned, the client only needs to input part of a domain name, and the system will add the domain name suffix for name resolution. For details about DNS, refer to DNS Configuration in the IP Services Volume.
Follow these steps to configure a domain name suffix in the DHCP address pool:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enter the DHCP address pool view |
Specify a domain name suffix for the client |
domain-name domain-name |
Required Not specified by default. |
When a DHCP client wants to access a host on the Internet via the host name, it contacts a Domain Name System (DNS) server holding host name-to-IP address mappings to get the host IP address. You can specify up to eight DNS servers in the DHCP address pool.
Follow these steps to configure DNS servers in the DHCP address pool:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Specify DNS servers for the client |
dns-list ip-address&<1-8> |
A Microsoft DHCP client using NetBIOS protocol contacts a Windows Internet Naming Service (WINS) server for name resolution. Therefore, the DHCP server should assign a WINS server address when assigning an IP address to the client.
You can specify up to eight WINS servers in a DHCP address pool.
You need to specify in a DHCP address pool a NetBIOS node type for the client to approach name resolution. There are four NetBIOS node types:
l b (broadcast)-node: The b-node client sends the destination name in a broadcast message. The destination returns its IP address to the client after receiving the message.
l p (peer-to-peer)-node: The p-node client sends the destination name in a unicast message to the WINS server, and the WINS server returns the destination IP address.
l m (mixed)-node: A combination of broadcast first and peer-to-peer second. The m-node client broadcasts the destination name, if no response is received, then unicasts the destination name to the WINS server to get the destination IP address.
l h (hybrid)-node: A combination of peer-to-peer first and broadcast second. The h-node client unicasts the destination name to the WINS server, if no response is received, then broadcasts it to get the destination IP address.
Follow these steps to configure WINS servers and NetBIOS node type in the DHCP address pool:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Specify WINS server IP addresses for the client |
nbns-list ip-address&<1-8> |
Required (optional for b-node) No address is specified by default. |
Specify the NetBIOS node type |
netbios-type { b-node | h-node | m-node | p-node } |
If b-node is specified for the client, you need to specify no WINS server address.
A DHCP client performs regular software update and backup using configuration files obtained from a branch intelligent management system (BIMS) server. Therefore, the DHCP server needs to offer DHCP clients the BIMS server IP address, port number, shared key from the DHCP address pool.
Follow these steps to configure the BIMS server IP address, port number, and shared key in the DHCP address pool:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Specify the BIMS server IP address, port number, and shared key |
bims-server ip ip-address [ port port-number ] sharekey key |
DHCP clients that want to access hosts outside the local subnet request gateways to forward data. You can specify gateways in each address pool for clients and the DHCP server will assign gateway addresses while assigning an IP address to the client. Up to eight gateways can be specified in a DHCP address pool.
Follow these steps to configure the gateways in the DHCP address pool:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Specify gateways |
gateway-list ip-address&<1-8> |
Required No gateway is specified by default. |
To assign voice calling parameters along with an IP address to DHCP clients with voice service, you need to configure Option 184 on the DHCP server. For information about Option 184, refer to Option 184.
If Option 55 in the request from a DHCP client contains Option 184, the DHCP server will return parameters specified in Option 184 to the client. The client then can initiate a call using parameters in Option 184.
Follow these steps to configure option 184 parameters in the DHCP address pool:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Specify the IP address of the primary network calling processor |
voice-config ncp-ip ip-address |
Specify the IP address of the backup network calling processor |
voice-config as-ip ip-address |
Optional Not specified by default. |
Configure the voice VLAN |
voice-config voice-vlan vlan-id { disable | enable } |
Optional Not configured by default. |
Specify the failover IP address and dialer string |
voice-config fail-over ip-address dialer-string |
Optional No failover IP address or dialer string is specified by default. |
Specify an IP address for the network calling processor before performing other configuration.
This task is to specify the IP address and name of a TFTP server and the bootfile name in the DHCP address pool. The DHCP clients use these parameters to contact the TFTP server, requesting the configuration file used for system initialization, which is called auto-configuration. The request process of the client is described below:
1) When a router starts up without loading any configuration file, the system sets an active interface (such as the interface of the default VLAN) as the DHCP client to request from the DHCP server for parameters, such as an IP address and name of a TFTP server, and the bootfile name.
2) After getting related parameters, the DHCP client will send a TFTP request to obtain the configuration file from the specified TFTP server for system initialization. If the client cannot get such parameters, it will perform system initialization without loading any configuration file.
To implement auto-configuration, you need to specify the IP address or name of a TFTP server and the bootfile name in the DHCP address pool on the DHCP server, but you do not need to perform any configuration on the DHCP client.
Currently, S7500E series Ethernet switches do not support the auto-configuration function, but they can assign parameters such as TFTP server addresses to devices that support auto-configuration when they are used as DHCP servers.
When Option 55 in the client’s request contains parameters of Option 66, Option 67, or Option 150, the DHCP server will return the IP address or name of the specified TFTP server, and bootfile name to the client.
Follow these steps to configure the IP address and name of the TFTP server and the bootfile name in the DHCP address pool:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Specify the TFTP server |
tftp-server ip-address ip-address |
Required Use either command Not specified by default. |
Specify the name of the TFTP server |
tftp-server domain-name domain-name |
Specify the bootfile name |
bootfile-name bootfile-name |
By configuring self-defined DHCP options, you can
l Define new DHCP options. New configuration options will come out with DHCP development. To support these new options, you can add them into the attribute list of the DHCP server.
l Define existing DHCP options. Some options have no unified definitions in RFC 2132; however, vendors can define such options as Option 43 as needed. The self-defined DHCP option enables DHCP clients to obtain vendor-specific information.
l Extend existing DHCP options. When the current DHCP options cannot meet the customers’ requirements (for example, you cannot use the dns-list command to configure more than eight DNS server addresses), you can configure a self-defined option for extension.
Follow these steps to configure a self-defined DHCP option in the DHCP address pool:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure a self-defined DHCP option |
option code { ascii ascii-string | hex hex-string&<1-16> | ip-address ip-address&<1-8> } |
Required No DHCP option is configured by default. |
Table 2-1 Description of common options
Option |
Option name |
Corresponding command |
Command parameter |
3 |
Router Option |
gateway-list |
ip-address |
6 |
Domain Name Server Option |
dns-list |
ip-address |
15 |
Domain Name |
domain-name |
ascii |
44 |
NetBIOS over TCP/IP Name Server Option |
nbns-list |
ip-address |
46 |
NetBIOS over TCP/IP Node Type Option |
netbios-type |
hex |
66 |
TFTP server name |
tftp-server |
ascii |
67 |
Bootfile name |
bootfile-name |
ascii |
43 |
Vendor Specific Information |
hex |
Be cautious when configuring self-defined DHCP options because such configuration may affect the DHCP operation process.
This configuration is necessary to secure DHCP services on the DHCP server.
Configuration Prerequisites
Before performing this configuration, complete the following configurations on the DHCP server:
l Enable DHCP
l Configure the DHCP address pool
Unauthorized DHCP servers may exist on networks, and they reply DHCP clients with wrong IP addresses.
With this feature enabled, upon receiving a DHCP request, the DHCP server will record the IP address of the DHCP server which assigned an IP address to the DHCP client and the receiving interface. The administrator can use this information to check out any unauthorized DHCP servers.
Follow these steps to enable unauthorized DHCP server detection:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable unauthorized DHCP server detection |
dhcp server detect |
With the unauthorized DHCP server detection enabled, the device puts a record once for each DHCP server. The administrator needs to find unauthorized DHCP servers from the log information.
To avoid IP address conflicts, the DHCP server checks whether the address to be assigned is in use by sending ping packets.
The DHCP server pings the IP address to be assigned using ICMP. If the server gets a response within the specified period, the server will select and ping another IP address; otherwise, the server will ping the IP addresses once again until the specified number of ping packets are sent. If still no response is received, the server will assign the IP address to the requesting client (The DHCP client probes the IP address by sending gratuitous ARP packets).
Follow these steps to configure IP address conflict detection:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Specify the number of ping packets |
dhcp server ping packets number |
Optional One ping packet by default. The value 0 indicates that no ping operation is performed. |
Configure a timeout waiting for ping responses |
dhcp server ping timeout milliseconds |
Optional 500 ms by default. The value 0 indicates that no ping operation is performed. |
If the server is configured to ignore Option 82, it will assign an IP address to the client without adding Option 82 in the response message.
Configuration prerequisites
Before performing this configuration, complete the following configuration on the DHCP server:
l Enable DHCP
Configuring the handling mode for Option 82
Follow these steps to enable the DHCP server to handle Option 82:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable the server to handle Option 82 |
dhcp server relay information enable |
To support Option 82, it is required to perform configuration on both the DHCP server and relay agent (or the device enabled with DHCP snooping). Refer to Configuring the DHCP Relay Agent to Support Option 82 and Configuring DHCP Snooping to Support Option 82 for related configuration details.
To do… |
Use the command… |
Remarks |
Display information about IP address conflicts |
display dhcp server conflict { all | ip ip-address } |
Available in any view |
Display information about lease expiration |
display dhcp server expired { all | ip ip-address | pool [ pool-name ] } |
Display information about assignable IP addresses |
display dhcp server free-ip |
Display IP addresses excluded from automatic allocation in the DHCP address pool |
display dhcp server forbidden-ip |
Display information about bindings |
display dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] } |
Display information about DHCP server statistics |
display dhcp server statistics |
Display tree organization information of address pool(s) |
display dhcp server tree { all | pool [ pool-name ] } |
Clear information about IP address conflicts |
reset dhcp server conflict { all | ip ip-address } |
Available in user view |
Clear information about dynamic bindings |
reset dhcp server ip-in-use { all | ip ip-address | pool [ pool-name ] } |
Clear information about DHCP server statistics |
reset dhcp server statistics |
Using the save command does not save DHCP server lease information. Therefore, when the system boots up or the reset dhcp server ip-in-use command is executed, no lease information will be available in the configuration file. In this case, the server will deny the request for lease extension from a client and the client needs to request an IP address again.
DHCP networking involves two types:
l The DHCP server and client are on the same subnet and exchange messages directly.
l The DHCP server and client are not on the same subnet and they communicate with each other via a DHCP relay agent.
The DHCP server configuration for the two types is the same.
Network requirements
Switch B (DHCP client) obtains a static IP address, DNS server address, and gateway address from Switch A (DHCP server).
Network diagram
Figure 2-1 Network diagram for static IP address assignment
Configuration procedure
1) Configure the IP address of VLAN-interface 2 on Switch A.
[SwitchA-Vlan-interface2] ip address 10.1.1.1 25
2) Configure the DHCP server
# Enable DHCP.
[SwitchA] dhcp enable
# Create DHCP address pool 0, configure a static IP-MAC binding, DNS server and gateway in it.
[SwitchA] dhcp server ip-pool 0
[SwitchA-dhcp-pool-0] static-bind ip-address 10.1.1.5
[SwitchA-dhcp-pool-0] static-bind mac-address 000f-e200-0002
[SwitchA-dhcp-pool-0] dns-list 10.1.1.2
[SwitchA-dhcp-pool-0] gateway-list 10.1.1.126
[SwitchA-dhcp-pool-0] quit
l The DHCP server (Switch A) assigns IP address to clients in subnet 10.1.1.0/24, which is subnetted into 10.1.1.0/25 and 10.1.1.128/25.
l The IP addresses of VLAN-interfaces 1 and 2 on Switch A are 10.1.1.1/25 and 10.1.1.129/25 respectively.
l In address pool 10.1.1.0/25, the address lease duration is ten days and twelve hours, domain name suffix aabbcc.com, DNS server address 10.1.1.2/25, gateway 10.1.1.126/25, and WINS server 10.1.1.4/25.
l In address pool 10.1.1.128/25, the address lease duration is five days, domain name suffix aabbcc.com, DNS server address 10.1.1.2/25, and gateway address 10.1.1.254/25, and there is no WINS server address.
l The domain name and DNS server address on subnets 10.1.1.0/25 and 10.1.1.128/25 are the same. Therefore, the domain name suffix and DNS server address can be configured only for subnet 10.1.1.0/24. Subnet 10.1.1.128/25 can inherit the configuration of subnet 10.1.1.0/24.
In this example, the number of requesting clients connected to VLAN-interface 1 should be less than 122, and that of clients connected to VLAN-interface 2 less than 124.
Network diagram
Figure 2-2 DHCP network diagram
1) Specify IP addresses for VLAN interfaces (omitted).
# Enable DHCP.
# Exclude IP addresses (addresses of the DNS server, WINS server and gateways).
[SwitchA] dhcp server forbidden-ip 10.1.1.2
[SwitchA] dhcp server forbidden-ip 10.1.1.4
[SwitchA] dhcp server forbidden-ip 10.1.1.126
[SwitchA] dhcp server forbidden-ip 10.1.1.254
# Configure DHCP address pool 0 (address range, client domain name suffix, and DNS server address).
[SwitchA-dhcp-pool-0] network 10.1.1.0 mask 255.255.255.0
[SwitchA-dhcp-pool-0] domain-name aabbcc.com
# Configure DHCP address pool 1 (address range, gateway, lease duration, and WINS server).
[SwitchA] dhcp server ip-pool 1
[SwitchA-dhcp-pool-1] network 10.1.1.0 mask 255.255.255.128
[SwitchA-dhcp-pool-1] gateway-list 10.1.1.126
[SwitchA-dhcp-pool-1] expired day 10 hour 12
[SwitchA-dhcp-pool-1] nbns-list 10.1.1.4
[SwitchA-dhcp-pool-1] quit
# Configure DHCP address pool 2 (address range, gateway, and lease duration).
[SwitchA] dhcp server ip-pool 2
[SwitchA-dhcp-pool-2] network 10.1.1.128 mask 255.255.255.128
[SwitchA-dhcp-pool-2] expired day 5
[SwitchA-dhcp-pool-2] gateway-list 10.1.1.254
l The DHCP client obtains an IP address and PXE server addresses from the DHCP server (Switch).
l The IP address that the DHCP client obtains belongs to network segment 10.1.1.0/24.
l The PXE server addresses that the DHCP client obtains are 1.2.3.4 and 2.2.2.2.
Network diagram
Figure 2-3 Network diagram for self-defined option configuration
l The DHCP server returns a response message containing Option 43 to the DHCP client that sent a DHCP request containing Option 43 (in Option 55) to it.
l Currently, when an S7500E series Ethernet switch working as a DHCP client sends a request message, Option 43 is not contained in that message.
1) Specify IP addresses for the interfaces (omitted).
# Enable DHCP.
<Switch> system-view
[Switch] dhcp enable
# Configure DHCP address pool 0.
[Switch] dhcp server ip-pool 0
[Switch-dhcp-pool-0] network 10.1.1.0 mask 255.255.255.0
[Switch-dhcp-pool-0] option 43 hex 80 0B 00 00 02 01 02 03 04 02 02 02 02
l When an S7500E series Ethernet switch works as a DHCP server, it assigns PXE server addresses to DHCP clients through Option 43, a self-defined option.
l The value of Option 43 configured on the DHCP server in this example is 80 0B 00 00 02 01 02 03 04 02 02 02 02. The number 80 is the value of the sub-option type. The number 0B is the value of the sub-option length. The numbers 00 00 are the value of the PXE server type. The number 02 indicates the number of servers. The numbers 01 02 03 04 02 02 02 02 indicate that the PXE server addresses are 1.2.3.4 and 2.2.2.2.
Symptom
A client’s IP address obtained from the DHCP server conflicts with another IP address.
Analysis
A host on the subnet may have the same IP address.
Solution
1) Disconnect the client’s network cable and ping the client’s IP address on another host with a long timeout time to check whether there is a host using the same IP address.
2) If a ping response is received, the IP address has been manually configured on the host. Execute the dhcp server forbidden-ip command on the DHCP server to exclude the IP address from dynamic allocation.
3) Connect the client’s network cable. Release the IP address and obtain another one on the client. Take WINDOW XP as an example, run cmd to enter DOS window. Type ipconfig/release to relinquish the IP address and then ipconfig/renew to obtain another IP address.
When configuring the DHCP relay agent, go to these sections for information you are interested in:
l Introduction to DHCP Relay Agent
l Configuring the DHCP Relay Agent
l Displaying and Maintaining DHCP Relay Agent Configuration
l DHCP Relay Agent Configuration Examples
l Troubleshooting DHCP Relay Agent Configuration
l The DHCP relay agent configuration is supported only on VLAN interfaces.
l DHCP snooping must be disabled on the DHCP relay agent.
Since DHCP clients request IP addresses via broadcast messages, the DHCP server and clients must be on the same subnet. Therefore, a DHCP server must be available on each subnet, which is not practical.
DHCP relay agent solves the problem. Via a relay agent, DHCP clients communicate with a DHCP server on another subnet to obtain configuration parameters. Thus, DHCP clients on different subnets can contact the same DHCP server for ease of centralized management and cost reduction.
Fundamentals
Figure 3-1 shows a typical application of the DHCP relay agent.
Figure 3-1 DHCP relay agent application
No matter whether a relay agent exists or not, the DHCP server and client interact with each other in a similar way (see section Dynamic IP Address Allocation Process). The following describes the forwarding process on the DHCP relay agent.
Figure 3-2 DHCP relay agent work process
As shown in Figure 3-2, the DHCP relay agent works as follows:
1) After receiving a DHCP-DISCOVER or DHCP-REQUEST broadcast message from a DHCP client, the DHCP relay agent fills the giaddr field of the message with its IP address and forwards the message to the designated DHCP server in unicast mode.
2) Based on the giaddr field, the DHCP server returns an IP address and other configuration parameters to the relay agent, which conveys them to the client.
Option 82 records the location information of the DHCP client. The administrator can locate the DHCP client to further implement security control and accounting. For more information, refer to Relay agent option (Option 82).
If the DHCP relay agent supports Option 82, it will handle a client’s request according to the contents defined in Option 82, if any. The handling strategies are described in the table below.
If a reply returned by the DHCP server contains Option 82, the DHCP relay agent will remove the Option 82 before forwarding the reply to the client.
If a client’s requesting message has… |
Handling strategy |
Padding format |
The DHCP relay agent will… |
Option 82 |
Drop |
Random |
Drop the message. |
Keep |
Random |
Forward the message without changing Option 82. |
Replace |
normal |
Forward the message after replacing the original Option 82 with the Option 82 padded in normal format. |
verbose |
Forward the message after replacing the original Option 82 with the Option 82 padded in verbose format. |
user-defined |
Forward the message after replacing the original Option 82 with the user-defined Option 82. |
no Option 82 |
normal |
Forward the message after adding the Option 82 padded in normal format. |
verbose |
Forward the message after adding the Option 82 padded in verbose format. |
user-defined |
Forward the message after adding the user-defined Option 82. |
Complete the following tasks to configure the DHCP relay agent:
Task |
Remarks |
Required |
Required |
Correlating a DHCP Server Group with a Relay Agent Interface |
Required |
Configuring the DHCP Relay Agent to Send a DHCP-Release Request |
Optional |
Optional |
Optional |
Enabling DHCP
Enable DHCP before performing other DHCP-related configurations.
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable DHCP |
dhcp enable |
With this task completed, upon receiving a DHCP request from the enabled interface, the relay agent will forward the request to a DHCP server for address allocation.
Follow these steps to enable the DHCP relay agent on an interface:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable the DHCP relay agent on the current interface |
dhcp select relay |
Required With DHCP enabled, interfaces work in the DHCP server mode. |
If the DHCP client obtains an IP address via the DHCP relay agent, the address pool of the subnet to which the IP address of the DHCP relay agent belongs must be configured on the DHCP server. Otherwise, the DHCP client cannot obtain a correct IP address.
To improve reliability, you can specify several DHCP servers as a group on the DHCP relay agent and correlate a relay agent interface with the server group. When the interface receives requesting messages from clients, the relay agent will forward them to all the DHCP servers of the group.
Follow these steps to correlate a DHCP server group with a relay agent interface:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Create a DHCP server group and add a server into the group |
dhcp relay server-group group-id ip ip-address |
Required Not created by default. |
Correlate the DHCP server group with the current interface |
dhcp relay server-select group-id |
Required By default, no interface is correlated with any DHCP server group. |
l You can specify up to twenty DHCP server groups on the relay agent and eight DHCP server addresses for each DHCP server group.
l The IP addresses of DHCP servers and those of relay agent’s interfaces cannot be on the same subnet. Otherwise, the client cannot obtain an IP address.
l A DHCP server group can correlate with one or multiple DHCP relay agent interfaces, while a relay agent interface can only correlate with one DHCP server group. Using the dhcp relay server-select command repeatedly overwrites the previous configuration. However, if the specified DHCP server group does not exist, the interface still uses the previous correlation.
l The group-id in the dhcp relay server-select command was specified by the dhcp relay server-group command.
Sometimes, you need to release a client’s IP address manually on the DHCP relay agent. With this task completed, the DHCP relay agent can actively send a DHCP-RELEASE request that contains the client’s IP address to be released. Upon receiving the DHCP-RELEASE request, the DHCP server then releases the IP address for the client; meanwhile, the corresponding binding entry recorded on the DHCP relay agent is deleted.
Follow these steps to configure the DHCP relay agent in system view to send a DHCP-RELEASE request:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure the DHCP relay agent to send a DHCP-RELEASE request |
dhcp relay release ip client-ip |
Required |
Creating static bindings and enable IP address check
The DHCP relay agent can dynamically record clients’ IP-to-MAC bindings after clients get IP addresses. It also supports static bindings, which means you can manually configure IP-to-MAC bindings on the DHCP relay agent, so that users can access external network using fixed IP addresses.
For avoidance of invalid IP address configuration, you can configure the DHCP relay agent to check whether a requesting client’s IP and MAC addresses match a binding (both dynamic and static bindings) on the DHCP relay agent. If not, the client cannot access outside networks via the DHCP relay agent.
Follow these steps to create a static binding and enable IP address check:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Create a static binding |
dhcp relay security static ip-address mac-address [ interface interface-type interface-number ] |
Optional No static binding is created by default. |
Enable invalid IP address check |
dhcp relay address-check { disable | enable } |
l The dhcp relay address-check command can be executed only on VLAN interfaces.
l The dhcp relay address-check enable command is independent of other commands of the DHCP relay agent. That is, the invalid address check takes effect when this command is executed, regardless of whether other commands are used.
l The dhcp relay address-check enable command only checks IP and MAC addresses of clients.
l You are recommended to configure IP address check on the interface enabled with the DHCP relay agent; otherwise, the valid DHCP clients may not be capable of accessing networks.
l When using the dhcp relay security static command to bind an interface to a static binding entry, make sure that the interface is configured as a DHCP relay agent; otherwise, address entry conflicts may occur.
Configuring dynamic binding update interval
Via the DHCP relay agent, a DHCP client sends a DHCP-RELEASE unicast message to the DHCP server to relinquish its IP address. In this case the DHCP relay agent simply conveys the message to the DHCP server, thus it does not remove the IP address from its bindings. To solve this problem, the DHCP relay agent can update dynamic bindings at a specified interval.
The DHCP relay agent uses the IP address of a client and the MAC address of the DHCP relay interface to periodically send a DHCP-REQUEST message to the DHCP server.
l If the server returns a DHCP-ACK message or does not return any message within a specified interval, which means the IP address is assignable now, the DHCP relay agent will update its bindings by aging out the binding entry of the IP address.
l If the server returns a DHCP-NAK message, which means the IP address is still in use, the relay agent will not age it out.
Follow these steps to configure dynamic binding update interval:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure binding update interval |
dhcp relay security tracker { interval | auto } |
Optional auto by default. (auto interval is calculated by the relay agent according to the number of bindings.) |
Enabling unauthorized DHCP servers detection
There are unauthorized DHCP servers on networks, which reply DHCP clients with wrong IP addresses.
With this feature enabled, upon receiving a DHCP request, the DHCP relay agent will record the IP address of the DHCP server which assigned an IP address to the DHCP client and the receiving interface. The administrator can use this information to check out any DHCP unauthorized servers.
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
dhcp relay server-detect |
With the unauthorized DHCP server detection enabled, the device puts a record once for each DHCP server. The administrator needs to find unauthorized DHCP servers from the log information. After the recorded information of a DHCP server is cleared, a new record will be put for the DHCP server.
You need to complete the following tasks before configuring the DHCP relay agent to support Option 82.
l Enabling DHCP
l Enabling the DHCP relay agent on the specified interface
l Correlating a DHCP server group with relay agent interfaces
Configuring the DHCP relay agent to support Option 82
Follow these steps to configure the DHCP relay agent to support Option 82:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable the relay agent to support Option 82 |
dhcp relay information enable |
Configure the handling strategy for requesting messages containing Option 82 |
dhcp relay information strategy { drop | keep | replace } |
Optional replace by default. |
Configure non-user-defined Option 82 |
Configure the padding format for Option 82 |
dhcp relay information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] } |
Optional normal by default. |
Configure the code type for the circuit ID sub-option |
dhcp relay information circuit-id format-type { ascii | hex } |
Optional By default, the code type depends on the padding format of Option 82. Each field has its own code type. The code type configuration applies to non-user-defined Option 82 only. |
Configure the code type for the remote ID sub-option |
dhcp relay information remote-id format-type { ascii | hex } |
Optional By default, the code type is hex. This code type configuration applies to non-user-defined Option 82 only. |
Configure user-defined Option 82 |
Configure the padding content for the circuit ID sub-option |
dhcp relay information circuit-id string circuit-id |
Optional By default, the padding content depends on the padding format of Option 82. |
Configure the padding content for the remote ID sub-option |
dhcp relay information remote-id string { remote-id | sysname } |
l To support Option 82, it is required to perform related configuration on both the DHCP server and relay agent. Refer to Configuring the Handling Mode for Option 82 for DHCP server configuration of this kind.
l If the handling strategy of the DHCP relay agent is configured as replace, you need to configure a padding format for Option 82. If the handling strategy is keep or drop, you need not configure any padding format.
l If sub-option 1 (node identifier) of Option 82 is padded with the device name (sysname) of a node, the device name must contain no spaces. Otherwise, the DHCP relay agent will drop the message.
To do… |
Use the command… |
Remarks |
Display information about DHCP server groups correlated to a specified or all interfaces |
display dhcp relay { all | interface interface-type interface-number } |
Display Option 82 configuration information on the DHCP relay agent |
display dhcp relay information { all | interface interface-type interface-number } |
Display information about bindings of DHCP relay agents |
display dhcp relay security [ ip-address | dynamic | static ] |
Display statistics information about bindings of DHCP relay agents |
display dhcp relay security statistics |
Display information about the refreshing interval for entries of dynamic IP-to-MAC bindings |
display dhcp relay security tracker |
Display information about the configuration of a specified or all DHCP server groups |
display dhcp relay server-group { group-id | all } |
Display packet statistics on relay agent |
display dhcp relay statistics [ server-group { group-id | all } ] |
Clear packet statistics from relay agent |
reset dhcp relay statistics [ server-group group-id ] |
VLAN-interface 1 on the DHCP relay agent (Switch A) connects to the network where DHCP clients reside. The IP address of VLAN-interface 1 is 10.10.1.1/24 and IP address of VLAN-interface 2 is 10.1.1.2/24 that communicates with the DHCP server 10.1.1.1/24. As shown in Figure 3-3, Switch A forwards messages between DHCP clients and the DHCP server.
Network diagram
Figure 3-3 Network diagram for DHCP relay agent
# Specify IP addresses for the interfaces (omitted).
# Enable DHCP.
# Add DHCP server 10.1.1.1 into DHCP server group 1.
[SwitchA] dhcp relay server-group 1 ip 10.1.1.1
# Enable the DHCP relay agent on VLAN-interface 1.
[SwitchA-Vlan-interface1] dhcp select relay
# Correlate VLAN-interface 1 to DHCP server group 1.
[SwitchA-Vlan-interface1] dhcp relay server-select 1
l Performing the configuration on the DHCP server is also required to guarantee the client-server communication via the relay agent. Refer to DHCP Server Configuration Examples for DHCP server configuration information.
l Because the DHCP relay agent and server are on different subnets, you need to configure a static route or dynamic routing protocol to make them reachable to each other.
l Enable Option 82 on the DHCP relay agent (Switch A).
l Configure the handling strategy for DHCP requests containing Option 82 as replace.
l Configure the padding content for the circuit ID sub-option as company001 and for the remote ID sub-option as device001.
l Switch A forwards DHCP requests to the DHCP server (Switch B) after replacing Option 82 in the requests, so that the DHCP clients can obtain IP addresses.
Network diagram
Refer to Figure 3-3.
# Enable DHCP.
# Enable the DHCP relay agent to support Option 82, and perform Option 82-related configurations.
[SwitchA-Vlan-interface1] dhcp relay information enable
[SwitchA-Vlan-interface1] dhcp relay information strategy replace
[SwitchA-Vlan-interface1] dhcp relay information circuit-id string company001
[SwitchA-Vlan-interface1] dhcp relay information remote-id string device001
You need to perform corresponding configurations on the DHCP server to make the Option 82 configurations function normally.
Symptom
DHCP clients cannot obtain any configuration parameters via the DHCP relay agent.
Analysis
Some problems may occur with the DHCP relay agent or server configuration. Enable debugging and execute the display command on the DHCP relay agent to view the debugging information and interface state information for locating the problem.
Solution
Check that:
l The DHCP is enabled on the DHCP server and relay agent.
l The address pool on the same subnet where DHCP clients reside is available on the DHCP server.
l The routes between the DHCP server and DHCP relay agent are reachable.
l The relay agent interface connected to DHCP clients is correlated with correct DHCP server group and IP addresses for the group members are correct.
When configuring the DHCP client, go to these sections for information you are interested in:
l Enabling the DHCP Client on an Interface
l Displaying and Maintaining the DHCP Client
l DHCP Client Configuration Example
l The DHCP client configuration is supported only on VLAN interfaces.
l When multiple VLAN interfaces with the same MAC address use DHCP for IP address acquisition via a relay agent, the DHCP server cannot be a Windows 2000 Server or Windows 2003 Server.
l You are not recommended to enable both the DHCP client and the DHCP snooping on the same device. Otherwise, DHCP snooping entries may fail to be generated, or the DHCP client may fail to obtain an IP address.
Introduction to DHCP Client
With the DHCP client enabled on an interface, the interface will use DHCP to obtain configuration parameters such as an IP address from the DHCP server.
Follow these steps to enable the DHCP client on an interface:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable the DHCP client on the interface |
ip address dhcp-alloc [ client-identifier mac interface-type interface-number ] |
l An interface can be configured to acquire an IP address in multiple ways, but these ways are mutually exclusive. The latest configuration will overwrite the previous one.
l After the DHCP client is enabled on an interface, no secondary IP address is configurable for the interface.
l If the IP address assigned by the DHCP server shares a network segment with the IP addresses of other interfaces on the device, the DHCP client enabled interface will not request any IP address of the DHCP server, unless the conflicted IP address is manually deleted and the interface is made UP again by first executing the shutdown command and then the undo shutdown command or the DHCP client is enabled on the interface by executing the undo ip address dhcp-alloc and ip address dhcp-alloc commands in sequence.
To do… |
Use the command… |
Remarks |
Display specified configuration information |
display dhcp client [ verbose ] [ interface interface-type interface-number ] |
On a LAN, Switch B contacts the DHCP server via VLAN-interface 1 to obtain an IP address.
Network diagram
See Figure 2-2.
The following is the configuration on Switch B shown in Figure 2-2.
# Enable the DHCP client on VLAN-interface 1.
[SwitchB] interface vlan-interface 1
[SwitchB-Vlan-interface1] ip address dhcp-alloc
To implement the DHCP client-server model, you need to perform related configuration on the DHCP server. For details, refer to DHCP Server Configuration Examples.
When configuring DHCP snooping, go to these sections for information you are interested in:
l Configuring DHCP Snooping Basic Functions
l Configuring DHCP Snooping to Support Option 82
l Displaying and Maintaining DHCP Snooping
l DHCP Snooping Configuration Examples
l DHCP snooping supports no link aggregation. If an Ethernet port is added into an aggregation group, DHCP snooping configuration on it will not take effect. When the port is removed from the group, DHCP snooping can take effect.
l The DHCP snooping enabled switch does not work if it is between the DHCP relay agent and DHCP server, and it can work when it is between the DHCP client and relay agent or between the DHCP client and server.
l The DHCP snooping enabled switch cannot be a DHCP server or DHCP relay agent.
l You are not recommended to enable the DHCP client and DHCP snooping on the same switch. Otherwise, DHCP snooping entries may fail to be generated, or the DHCP client may fail to obtain an IP address.
DHCP Snooping Overview
Function of DHCP Snooping As a DHCP security feature, DHCP snooping can implement the following:
1) Ensuring DHCP clients to obtain IP addresses from authorized DHCP servers
2) Recording IP-to-MAC mappings of DHCP clients
If there is an unauthorized DHCP server on a network, DHCP clients may obtain invalid IP addresses and network configuration parameters, and cannot normally communicate with other network devices. With DHCP snooping, the ports of a device can be configured as trusted or untrusted, ensuring the clients to obtain IP addresses from authorized DHCP servers.
l Trusted: A trusted port forwards DHCP messages normally.
l Untrusted: An untrusted port discards the DHCP-ACK or DHCP-OFFER messages from any DHCP server.
You should configure ports that connect to authorized DHCP servers or other DHCP snooping devices as trusted, and other ports as untrusted. With such configurations, DHCP clients obtain IP addresses from authorized DHCP servers only, while unauthorized DHCP servers cannot assign IP addresses to DHCP clients.
DHCP snooping reads DHCP-REQUEST messages and DHCP-ACK messages from trusted ports to record DHCP snooping entries, including MAC addresses of clients, IP addresses obtained by the clients, ports that connect to DHCP clients, and VLANs to which the ports belong. With DHCP snooping entries, DHCP snooping can implement the following:
l ARP detection: Whether ARP packets are sent from an authorized client is determined based on DHCP snooping entries. This feature prevents ARP attacks from unauthorized clients. For details, refer to ARP Configuration in the IP Services Volume.
l IP Source Guard: IP Source Guard uses dynamic binding entries generated by DHCP snooping to filter packets on a per-port basis, and thus prevents unauthorized packets from traveling through. For details, refer to IP Source Guard Configuration in the Security Volume.
l VLAN mapping: The device replaces service provider VLANs (SVLANs) in packets with customer VLANs (CVLANs) by searching corresponding DHCP snooping entries for DHCP client information including IP addresses, MAC addresses, and CVLANs, before sending the packets to clients. For details, refer to VLAN Mapping Configuration in the Access Volume.
Application Environment of Trusted Ports
Configuring a trusted port connected to a DHCP server
Figure 5-1 Configure trusted and untrusted ports
As shown in Figure 5-1, a DHCP snooping device’s port that is connected to an authorized DHCP server should be configured as a trusted port to forward reply messages from the DHCP server, so that the DHCP client can obtain an IP address from the authorized DHCP server.
Configuring trusted ports in a cascaded network
In a cascaded network involving multiple DHCP snooping devices, the ports connected to other DHCP snooping devices should be configured as trusted ports.
To save system resources, you can disable the trusted ports, which are indirectly connected to DHCP clients, from recording clients’ IP-to-MAC bindings upon receiving DHCP requests.
Figure 5-2 Configure trusted ports in a cascaded network
Table 5-1 describes roles of the ports shown in Figure 5-2.
Device |
Untrusted port |
Trusted port disabled from recording binding entries |
Trusted port enabled to record binding entries |
Switch A |
Ethernet2/0/1 |
Ethernet2/0/3 |
Ethernet2/0/2 |
Switch B |
Ethernet2/0/3 and Ethernet2/0/4 |
Ethernet2/0/1 |
Ethernet2/0/2 |
Switch C |
Ethernet2/0/1 |
Ethernet2/0/2 |
DHCP Snooping Support for Option 82
If DHCP snooping supports Option 82, it will handle a client’s request according to the contents defined in Option 82, if any. The handling strategies are described in the table below.
If a reply returned by the DHCP server contains Option 82, the DHCP snooping device will remove the Option 82 before forwarding the reply to the client. If the reply contains no Option 82, the DHCP snooping device forwards it directly.
Handling strategy |
Padding format |
The DHCP snooping device will… |
Option 82 |
Drop |
Random |
Drop the message. |
Keep |
Random |
Replace |
normal |
verbose |
user-defined |
no Option 82 |
normal |
verbose |
user-defined |
The handling strategy and padding format for Option 82 on the DHCP snooping device are the same as those on the relay agent.
Follow these steps to configure DHCP snooping basic functions:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable DHCP snooping |
dhcp-snooping |
Enter Ethernet interface view |
Specify the port as trusted |
dhcp-snooping trust [ no-user-binding ] |
Required Untrusted by default. |
l You need to specify the ports connected to the valid DHCP servers as trusted to ensure that DHCP clients can obtain valid IP addresses. The trusted port and the port connected to the DHCP client must be in the same VLAN.
l Configuring both the DHCP snooping and selective QinQ function on the switch is not recommended because it may result in malfunctioning of DHCP snooping.
You need to enable the DHCP snooping function before configuring DHCP snooping to support Option 82.
Follow these steps to configure DHCP snooping to support Option 82:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable DHCP snooping to support Option 82 |
dhcp-snooping information enable |
dhcp-snooping information strategy { drop | keep | replace } |
dhcp-snooping information format { normal | verbose [ node-identifier { mac | sysname | user-defined node-identifier } ] } |
dhcp-snooping information circuit-id format-type { ascii | hex } |
Optional By default, the code type depends on the padding format of Option 82. Each field has its own code type. This code type configuration applies to non-user-defined Option 82 only. |
dhcp-snooping information remote-id format-type { ascii | hex } |
Optional hex by default. The code type configuration applies to non-user-defined Option 82 only. |
dhcp-snooping information [ vlan vlan-id ] circuit-id string circuit-id |
dhcp-snooping information [ vlan vlan-id ] remote-id string { remote-id | sysname } |
l To support Option 82, it is required to perform related configuration on both the DHCP server and the device enabled with DHCP snooping. Refer to Configuring the Handling Mode for Option 82 for DHCP server configuration of this kind.
l If the handling strategy of the DHCP-snooping-enabled device is configured as replace, you need to configure a padding format for Option 82. If the handling strategy is keep or drop, you need not configure any padding format.
l If the Option 82 is padded with the device name (sysname) of a node, the device name must contain no spaces. Otherwise, the DHCP-snooping-enabled device will drop the message.
To do… |
Use the command… |
Remarks |
Display DHCP snooping IP-to-MAC bindings |
display dhcp-snooping [ ip ip-address ] |
Display Option 82 configuration information on the DHCP snooping device |
display dhcp-snooping information { all | interface interface-type interface-number } |
Display DHCP packet statistics on the DHCP snooping device |
display dhcp-snooping packet statistics [ slot slot-number ] |
Display information about trusted ports |
display dhcp-snooping trust |
Clear DHCP snooping entries |
reset dhcp-snooping { all | ip ip-address } |
Clear DHCP packet statistics on the DHCP snooping device |
reset dhcp-snooping packet statistics [ slot slot-number ] |
l Switch B is connected to a DHCP server through GigabitEthernet 2/0/1, and to two DHCP clients through GigabitEthernet 2/0/2 and GigabitEthernet 2/0/3.
l GigabitEthernet 2/0/1 forwards DHCP server responses while the other two do not.
l Switch B records clients’ IP-to-MAC address bindings in DHCP-REQUEST messages and DHCP-ACK messages received from trusted ports.
Network diagram
Figure 5-3 Network diagram for DHCP snooping configuration
# Enable DHCP snooping.
[SwitchB] dhcp-snooping
# Specify GigabitEthernet 2/0/1 as trusted.
[SwitchB] interface gigabitethernet 2/0/1
[SwitchB-GigabitEthernet2/0/1] dhcp-snooping trust
[SwitchB-GigabitEthernet2/0/1] quit
DHCP Snooping Option 82 Support Configuration Example
l Enable DHCP snooping and Option 82 support on Switch B.
l On GigabitEthernet 2/0/2, configure the padding content for the circuit ID sub-option as company001 and for the remote ID sub-option as device001.
l On GigabitEthernet 2/0/3, configure the padding format as verbose, access node identifier as sysname, and code type as ascii for Option 82.
l Switch B forwards DHCP requests to the DHCP server (Switch A) after replacing Option 82 in the requests, so that the DHCP clients can obtain IP addresses.
Network diagram
Refer to Figure 5-3.
# Configure GigabitEthernet 2/0/2 to support Option 82.
[SwitchB] interface gigabitethernet 2/0/2
[SwitchB-GigabitEthernet2/0/2] dhcp-snooping information enable
[SwitchB-GigabitEthernet2/0/2] dhcp-snooping information strategy replace
[SwitchB-GigabitEthernet2/0/2] dhcp-snooping information circuit-id string company001
[SwitchB-GigabitEthernet2/0/2] dhcp-snooping information remote-id string device001
[SwitchB-GigabitEthernet2/0/2] quit
# Configure GigabitEthernet 2/0/3 to support Option 82.
[SwitchB] interface gigabitethernet 2/0/3
[SwitchB-GigabitEthernet2/0/3] dhcp-snooping information enable
[SwitchB-GigabitEthernet2/0/3] dhcp-snooping information strategy replace
[SwitchB-GigabitEthernet2/0/3] dhcp-snooping information format verbose node-identifier sysname
[SwitchB-GigabitEthernet2/0/3] dhcp-snooping information circuit-id format-type ascii
[SwitchB-GigabitEthernet2/0/3] dhcp-snooping information remote-id format-type ascii
