H3C S9500 Command Manual-Release1648[v1.24]-03 IP Routing Volume
HomeSupportSwitchesH3C S9500 Series SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-03 IP Routing Volume
07-Route Capacity Configuration Commands
07-Route Capacity Configuration Commands 14.71 KB
Chapter 1  Route Capacity Configuration Commands
1.1  Route Capacity Configuration Commands
1.1.1  router route-limit
router route-limit { 128K | 256K | 512K }
View
128K: Sets the maximum number of route entries supported by current system to 128 K.
256K: Sets the maximum number of route entries supported by current system to 256 K.
512K: Sets the maximum number of route entries supported by current system to 512 K.
Use the router route-limit command to set the maximum number of route entries supported by the current system.
If the maximum number of route entries supported by a card is less than this number, the system will inhibit the card from working.
By default, the maximum number of route entries is 128 K.
# Set the maximum number of route entries supported by the current system to 256 K.
<H3C>system-view
[H3C]router route-limit 256K
1.1.2  router vrf-limit
router vrf-limit { 256 | 512 | 1024 }
View
256: Sets the maximum number of VPN routing & forwarding instances (VRFs) supported by current system to 256.
512: Sets the maximum number of VRFs supported by current system to 512.
1024: Sets the maximum number of VRFs supported by current system to 1024.
Use the router vrf-limit command to set the maximum number of VPN routing and forwarding instances (VRFs) supported by current system.
If the number of VRFs supported by a card is less than this number, the system will inhibit the card from working. This number is 256 by default.
# Set the maximum number of VRFs supported by current system to 512.
<H3C> system-view
[H3C] router VRF-limit 512
