H3C S9500 Command Manual-Release1648[v1.24]-03 IP Routing Volume
HomeSupportSwitchesH3C S9500 Series SwitchesReference GuidesCommand ReferencesH3C S9500 Command Manual-Release1648[v1.24]-03 IP Routing Volume
08-Recursive Routing Commands
08-Recursive Routing Commands 19.98 KB
Chapter 1  Recursive Routing Configuration Commands
1.1  Recursive Routing Configuration Commands
1.1.1  route-rely
route-rely [ bgp | static ]
undo route-rely [ bgp | static ]
View
bgp: Specifies routes learned by the BGP as the type of routes to be controlled.
static: Specifies static routes as the type of routes to be controlled.
Use the route-rely command to enable recursive routing.
Use the undo route-rely command to disable the recursive routing.
By default, both routes learned by the BGP and static routes support recursive routing.
&  Note:
Currently, only 2-layer recursive routing is supported.
# Disable recursive routing for static routes.
<H3C>system-view
[H3C] undo route-rely static
# Restore the default recursive routing function.
[H3C] route-rely
