- H3C S5500-SI Series Ethernet Switches Operation Manual(V1.01)
- 00-1Cover
- 00-2Overview
- 01-Login Configuration
- 02-VLAN Configuration
- 03-IP Addressing and IP Performance Configuration
- 04-QinQ-BPDU TUNNEL Configuration
- 05-Port Correlation Configuration
- 06-Link Aggregation Configuration
- 07-MAC Address Table Management Configuration
- 08-Port Security Configuration
- 09-MSTP Configuration
- 10-IPv6 Configuration
- 11-IP Routing Overview Configuration
- 12-IPv4 Routing Configuration
- 13-IPv6 Routing Configuration
- 14-Multicast Configuration
- 15-802.1x-HABP-MAC Authentication Configuration
- 16-AAA-RADIUS-HWTACACS Configuration
- 17-ARP Configuration
- 18-DHCP Configuration
- 19-ACL Configuration
- 20-QoS Configuration
- 21-Port Mirroring Configuration
- 22-UDP Helper Configuration
- 23-Cluster Management Configuration
- 24-SNMP-RMON Configuration
- 25-NTP Configuration
- 26-DNS Configuration
- 27-File System Management Configuration
- 28-Information Center Configuration
- 29-System Maintaining and Debugging Configuration
- 30-NQA Configuration
- 31-SSH Configuration
- 32-Track Configuration
- 33-PoE Configuration
- 34-SSL-HTTPS Configuration
- 35-PKI Configuration
- 36-Stack Management Configuration
- 37-Appendix
28-Information Center Configuration | 132 KB |
Table of Contents
Chapter 1 Information Center Configuration
1.1 Information Center Overview
1.1.1 Introduction to Information Center
1.1.2 System Information Format
1.2 Configuring Information Center
1.2.1 Information Center Configuration Task List
1.2.2 Setting to Output System Information to the Console
1.2.3 Setting to Output System Information to a Monitor Terminal
1.2.4 Setting to Output System Information to a Log Host
1.2.5 Setting to Output System Information to the Trap Buffer
1.2.6 Setting to Output System Information to the Log Buffer
1.2.7 Setting to Output System Information to the SNMP NMS
1.2.8 Configuring Synchronous Information Output
1.3 Displaying and Maintaining Information Center
1.4 Information Center Configuration Examples
1.4.1 Outputting Log Information to a Unix Log Host
1.4.2 Outputting Log Information to a Linux Log Host
1.4.3 Outputting Log Information to the Console
When configuring information center, go to these sections for information you are interested in:
l Configuring Information Center
l Displaying and Maintaining Information Center
l Information Center Configuration Examples
Acting as the system information hub, information center classifies and manages system information. Together with the debugging functionality, information center offers a powerful support for network administrators and developers in monitoring network performance and diagnosing network problems.
& Note:
By default, the information center is enabled. An enabled information center affects the system performance in some degree due to information classification and output. Such impact becomes more obvious in the event that there is enormous information waiting for processing.
The information center of the system has the following features:
I. Classification of system information
The system is available with three types of information:
l Log information
l Trap information
l Debugging information
II. Eight levels of system information
The information is classified into eight levels by severity and can be filtered by level. More emergent information has a smaller severity level.
Table 1-1 Severity description
Severity |
Severity value |
emergencies |
0 |
The system is unavailable. |
alerts |
1 |
Information that demands prompt reaction |
critical |
2 |
Critical information |
errors |
3 |
Error information |
warnings |
4 |
Warnings |
notifications |
5 |
Normal information that needs to be noticed |
informational |
6 |
Informational information to be recorded |
debugging |
7 |
Information generated during debugging |
Information filtering by severity works this way: information with the severity value greater than the configured threshold is not output during the filtering.
l If the threshold is set to 0, only information with the severity being emergencies will be output;
l If the threshold is set to 7, information of all severities will be output.
III. Ten channels and six output destinations of system information
The system supports six information output destinations, including the console, monitor, logbuffer, loghost, trapbuffer, and SNMP.
The system supports ten channels. The channels 0 through 5 have their default channel names and are associated with six output destinations by default. Both the channel names and the associations between the channels and output destinations can be changed through commands.
Table 1-2 Information channels and output destinations
Information channel number |
Default channel name |
Default output destination |
0 |
console |
Console (Receives log, trap and debugging information) |
1 |
monitor |
Monitor terminal (Receives log, trap and debugging information, facilitating remote maintenance) |
2 |
loghost |
Log host (Receives log, trap and debugging information and information will be stored in files for future retrieval.) |
3 |
trapbuffer |
Trap buffer (Receives trap information, a buffer inside the router for recording information.) |
4 |
logbuffer |
Log buffer (Receives log information, a buffer inside the router for recording information.) |
5 |
snmpagent |
SNMP NMS (Receives trap information) |
6 |
channel6 |
Not specified (Receives log, trap, and debugging information) |
7 |
channel7 |
8 |
channel8 |
9 |
channel9 |
& Note:
Configurations for the six output destinations function independently and take effect only after the information center is enabled.
IV. Outputting system information by source module
The system is composed of a variety of protocol modules, board drivers, and configuration modules. The system information can be classified, filtered, and output by source module. Some source module names and descriptions are shown in Table 1-3.
Module name |
8021X |
802.1X module |
ACL |
Access Control List module |
ARP |
Address Resolution Protocol module |
BGP |
Border Gateway Protocol module |
CFM |
Configuration File Management module |
CLST |
Cluster Configuration module |
CMD |
Command line module |
default |
Default setting of all modules |
DEV |
Device management module |
DHCP |
Dynamic Host Configuration Protocol module |
DNS |
Domain Name System module |
ETH |
Ethernet module |
FTPS |
FTP Server module |
GARP |
Generic Attribute Registration Protocol module |
HABP |
Huawei Authentication Bypass Protocol module |
HWCM |
Huawei Configuration Management MIB module |
IFNET |
Interface management module |
IP |
Internet Protocol module |
ISIS |
Intermediate System-to-Intermediate System intra-domain routing information exchange protocol module |
LAGG |
Link Aggregation module |
LINE |
Line module |
MSDP |
Multicast Source Discovery Protocol module |
MSTP |
Multiple Spanning Tree Protocol module |
NAT |
Network Address Translation module |
NTP |
Network Time Protocol module |
PKI |
Public Key Infrastructure module |
OSPF |
Open Shortest Path First module |
POE |
Power over Ethernet module |
QoS |
Quality of Service module |
RDS |
Radius module |
RM |
Routing Management module |
RMON |
Remote monitor module |
SHELL |
User interface module |
SNMP |
Simple Network Management Protocol module |
SOCKET |
Socket module |
SSH |
Secure Shell module |
SYSMIB |
System MIB module |
TAC |
Terminal Access Controller module |
TELNET |
Telnet module |
UDPH |
UDP Helper module |
VFS |
Virtual File System module |
VLAN |
Virtual Local Area Network module |
VOS |
Virtual Operating System module |
VRRP |
Virtual Router Redundancy Protocol module |
VTY |
Virtual Type Terminal module |
To sum up, the major task of the information center is to output the three types of information of the modules onto the ten channels in terms of the eight severity levels and according to the user’s settings, and then redirect the system information from ten channels to the six output destinations.
System information has the following format:
<priority>timestamp sysname module/level/digest:content
& Note:
l The closing set of angel brackets < >, the space, the forward slash /, and the colon are all required in the above format.
l Before the <priority>, there may be a %, “#, or * followed with a space, indicating log, alarm, or debugging information respectively.
l This format is the standard format of system information. After the system information is sent to the log host, the displayed format depends on the tools you use to view the logs.
Below is an example of the format of log information to be output to a log host:
% <188>Sep 28 15:33:46:235 2005 MyDevice SHELL/5/LOGIN: Console login from aux0
What follows is a detailed explanation of the fields involved:
I. Priority
The priority is calculated using the following formula: facility*8+severity, in which facility represents the logging facility name and can be configured when you set the log host parameters. The facility ranges from local0 to local7 (16 to 23 in decimal integers) and defaults to local7. The facility is mainly used to mark different log sources on the log host, query and filter the logs of the corresponding log source. Severity ranges from 0 to 7. Table 1-1 details the value and meaning associated with each severity.
Note that there is no space between the priority and timestamp fields and that the priority takes effect only when the information has been sent to the log host.
II. Timestamp
Timestamp records the time when system information is generated to allow users to check and identify system events.
Note that there is a space between the timestamp and sysname (host name) fields.
III. Sysname
Sysname is the system name of the current host. You can use the sysname command to modify the system name. (Refer to System Maintaining and Debugging for details)
Note that there is a space between the sysname and module fields.
IV. Module
The module field represents the name of the module that generates system information. You can enter the info-center source ? command in system view to view the module list.
Refer to Table 1-3 for module name and description.
Between “module” and “level” is a “/”.
V. Level (Severity)
System information can be divided into eight levels based on its severity, from 0 to 7. Refer to Table 1-1 for definition and description of these severity levels. Note that there is a forward slash between the levels (severity) and digest fields.
VI. Digest
The digest field is a string of up to 32 characters, outlining the system information.
Note that there is a colon between the digest and content fields.
VII. Content
This field provides the content of the system information.
Complete the following tasks to configure information center:
Task |
Remarks |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
Optional |
I. Setting to output system information to the console
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable information center |
info-center enable |
Optional Enabled by default |
Name the channel with a specified channel number |
info-center channel channel-number name channel-name |
Optional Refer to Table 1-2 for default channel names. |
Configure the channel through which system information can be output to the console |
info-center console channel { channel-number | channel-name } |
Optional System information is output to the console by default, with channel 0 as the default channel. |
Configure the output rules of system information |
info-center source { module-name | default } channel { channel-number | channel-name } [ debug { level severity | state state } * | log { level severity | state state } * | trap { level severity | state state } * ] * |
Optional Refer to Table 1-4 for the default output rules of system information. |
Configure the format of the time stamp |
info-center timestamp { debugging | log | trap } { boot | date | none } |
Optional The time stamp format for log, trap and debugging information is date by default. |
Table 1-4 Default output rules for different output destinations
Output destination |
Modules allowed |
LOG |
TRAP |
DEBUG |
Enabled/disabled |
Severity |
Enabled/disabled |
Severity |
Enabled/disabled |
Severity |
Console |
default (all modules) |
Enabled |
warnings |
Enabled |
debugging |
Enabled |
debugging |
Monitoring terminal |
Enabled |
warnings |
Enabled |
debugging |
Enabled |
debugging |
Log host |
Enabled |
informational |
Enabled |
debugging |
Disabled |
debugging |
Trap buffer |
Disabled |
informational |
Enabled |
warnings |
Disabled |
debugging |
Log buffer |
Enabled |
warnings |
Disabled |
debugging |
Disabled |
debugging |
SNMP NMS |
Disabled |
debugging |
Enabled |
warnings |
Disabled |
debugging |
II. Enabling the display of system information on the console
After setting to output system information to the console, you need to enable the associated display function to display the output information on the console.
Follow these steps in user view to enable the display of system information on the console:
To do… |
Use the command… |
Remarks |
Enable the monitoring of system information on the console |
terminal monitor |
Optional Enabled on the console and disabled on the monitoring terminal by default. |
Enable the display of debugging information on the console |
terminal debugging |
Required Disabled by default |
Enable the display of log information on the console |
terminal logging |
Enable the display of trap information on the console |
terminal trapping |
System information can also be output to a monitor terminal, which is a user terminal that has login connections through the AUX, or VTY user interface.
I. Setting to output system information to a monitor terminal
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure the channel through which system information can be output to a monitor terminal |
info-center monitor channel { channel-number | channel-name } |
Optional System information is output to the monitor terminal by default with channel 1 as the default channel. |
Configure the output rules of the system information |
Optional Refer to Table 1-4 for the default output rules of the system information. |
Optional By default, the time stamp format for log, trap and debugging information is date. |
II. Enabling the display of system information on a monitor terminal
After setting to output system information to a monitor terminal, you need to enable the associated display function in order to display the output information on the monitor terminal.
Follow these steps to enable the display of system information on a monitor terminal:
To do… |
Use the command… |
Remarks |
Enable the monitoring of system information on a monitor terminal |
terminal monitor |
Required Enabled on the console disabled on the monitoring terminal by default. |
Enable the display of debugging information on a monitor terminal |
Enable the display of log information on a monitor terminal |
terminal logging |
Enable the display of trap information on a monitor terminal |
terminal trapping |
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Specify a log host and configure the parameters when system information is output to the log host |
info-center loghost host-ip [ channel { channel-number | channel-name } | facility local-number ] * |
Required By default, the system does not output information to a log host. If you specify to output system information to a log host, the system uses channel 2 (loghost) by default. |
Configure the source interface through which log information can be output to a log host |
info-center loghost source interface-type interface-number |
Optional No source interface is configured by default, and the system selects an interface as the source interface. |
Optional Refer to Table 1-4 for the output rules of the system information. |
Configure the format of the time stamp for log information |
info-center timestamp loghost { date | no-year-date | none } |
Optional date by default. |
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure the channel through which system information can be output to the trap buffer and specify the buffer size |
info-center trapbuffer [ channel { channel-number | channel-name } | size buffersize ] * |
Optional System information is output to the trap buffer by default with a default channel of channel 3 (known as trapbuffer) and a default buffer size of 256. |
To do… |
Use the command… |
Remarks |
Enter system view |
Optional Enabled by default. |
Configure the channel through which system information can be output to the log buffer and specify the buffer size |
info-center logbuffer [ channel { channel-number | channel-name } | size buffersize ] * |
Optional System information is output to the log buffer by default with a default channel of channel 4 (known as logbuffer) and a default buffer size of 512. |
Configure the format of the timestamp |
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Configure the channel through which system information can be output to the SNMP NMS |
info-center snmp channel { channel-number | channel-name } |
Optional System information is output to the SNMP NMS by default with channel 5 (known as snmpagent) as the default channel. |
& Note:
To ensure that system information can be output to the SNMP NMS, you need to make the necessary configurations on the SNMP agent and the NMS. For detailed information on SNMP, refer to the SNMP-RMON Configuration part of the manual.
Synchronous information output refers to the feature that if the user’s input is interrupted by system output such as log, trap, or debugging information, then after the completion of system output the system will display a command line prompt (in command editing mode a prompt, or a [Y/N] string in interaction mode) and your input so far.
This command is used in the case that your input is interrupted by a large amount of system output. With this feature enabled, you can continue your operations from where you were stopped.
Follow these steps to enable synchronous information output:
To do… |
Use the command… |
Remarks |
Enter system view |
system-view |
Enable synchronous information output |
info-center synchronous |
& Note:
l If you do not input any information following the current command line prompt, the system does not display any command line prompt after system information output.
l In the interaction mode, you are prompted for some information input. If the input is interrupted by system output, no system prompt will be made, rather only your input will be displayed in a new line.
To do… |
Use the command… |
Remarks |
Display channel information for a specified channel |
display channel [ channel-number | channel-name ] |
Available in any view |
Display the configurations on each output destination |
display info-center |
Display the state of the log buffer and the log information recorded |
display logbuffer [ level severity | size buffersize ] * [ | { begin | exclude | include } text ] |
Display a summary of the log buffer |
display logbuffer summary [ level severity ] |
Display the state of the trap buffer and the trap information recorded |
display trapbuffer [ size buffersize ] |
Reset the log buffer |
reset logbuffer |
Available in user view |
Reset the trap buffer |
reset trapbuffer |
& Note:
Support for the display logfile buffer and display logfile summary commands varies with devices.
I. Network requirements
l Send log information to a Unix log host with an IP address of 1.2.0.1/16;
l Log information with severity higher than informational will be output to the log host;
l The source modules are ARP and IP.
II. Network diagram
Figure 1-1 Network diagram for outputting log information to a Unix log host
III. Configuration procedure
Before the configuration, make sure that there is a route between Device and PC.
1) Configuring the device
# Enable information center.
[Sysname] info-center enable
# Specify the host with IP address 1.2.0.1/16 as the log host, use channel loghost to output log information (optional, loghost by default), and specify local4 as the logging facility.
[Sysname] info-center loghost 1.2.0.1 channel loghost facility local4
# Disable the output of log, trap, and debugging information of all modules on the channel loghost.
[Sysname] info-center source default channel loghost debug state off log state off trap state off
Caution:
As the default system configurations for different channels are different, you need to disable the output of log, trap, and debugging information of all modules on the specified channel (loghost in this example) first and then configure the output rule as needed so that unnecessary information will not be output.
# Configure the information output rule: allow log information of ARP and IP modules with severity equal to or higher than informational to be output to the log host.
[Sysname] info-center source arp channel loghost log level informational state on
[Sysname] info-center source ip channel loghost log level informational state on
2) Configuring the log host
The following configurations were performed on SunOS 4.0 which has similar configurations to the Unix operating systems implemented by other vendors.
Step 1: Issue the following commands as a root user.
# mkdir /var/log/MyDevice
# touch /var/log/MyDevice/information
Step 2: Edit the file /etc/syslog.conf as a root user and add the following selector/action pair.
# MyDevice configuration messages
local4.info /var/log/MyDevice/information
& Note:
Be aware of the following issues while editing the /etc/syslog.conf file:
l Comments must be on a separate line and must begin with the # sign.
l The selector/action pair must be separated with a tab key, rather than a space.
l No redundant spaces are allowed in the file name.
l The device name and the accepted severity of log information specified by the /etc/syslog.conf file must be identical to those configured on the device using the info-center loghost or info-center source command; otherwise the log information may not be output properly to the log host.
Step three: After the log file information has been created and the configuration file /etc/syslog.conf has been modified, ensure that the configuration file /etc/syslog.conf is reread:
# ps -ae | grep syslogd
147
# kill -HUP 147
After the above configurations, the system will be able to keep log information in the related file.
l Send log information to a Linux log host with an IP address of 1.2.0.1/16;
l All modules can output log information.
II. Network diagram
Figure 1-2 Network diagram for outputting log information to a Linux log host
Before configuration, make sure that there is a route between Device and PC.
# Specify the host with IP address 1.2.0.1/16 as the log host, use channel loghost to output log information (optional, loghost by default), and specify local5 as the logging facility.
[Sysname] info-center loghost 1.2.0.1 channel loghost facility local5
Caution:
# Configure the information output rule: allow log information of all modules with severity equal to or higher than informational to be output to the log host.
[Sysname] info-center source default channel loghost log level informational state on
local7.info /var/log/MyDevice/information
& Note:
l The device name and the accepted severity of the log information specified by the /etc/syslog.conf file must be identical to those configured on the device using the info-center loghost or info-center source command; otherwise the log information may not be output properly to the log host.
Step 3: After the log file information has been created and the /etc/syslog.conf file has been modified, issue the following commands to display the process ID of syslogd, terminate a syslogd process, and restart syslogd using the -r option.
147
# kill -9 147
# syslogd -r &
& Note:
Ensure that the syslogd process is started with the -r option on a Linux log host.
l Log information with a severity higher than informational will be output to the console;
II. Network diagram
Figure 1-3 Network diagram for sending log information to the console
# Use channel console to output log information to the console (optional, console by default).
[Sysname] info-center console channel console
# Disable the output of log, trap, and debugging information of all modules on the channel console.
[Sysname] info-center source default channel console debug state off log state off trap state off
Caution:
As the default system configurations for different channels are different, you need to disable the output of log, trap, and debugging information of all modules on the specified channel (console in this example) first and then configure the output rule as needed so that unnecessary information will not be output.
# Configure the information output rule: allow log information of ARP and IP modules with severity equal to or higher than informational to be output to the console.
[Sysname] info-center source arp channel console log level informational state on
[Sysname] info-center source ip channel console log level informational state on
[Sysname] quit
# Enable the display of log information on a monitor terminal.
<Sysname> terminal monitor
% Current terminal monitor is on
<Sysname> terminal logging
% Current terminal logging is on
After the above configuration takes effect, if the specified module generates log information, the information center automatically sends the log information to the console and displays it on the console.
