Chapters Download(171 KB)
The command index includes all the commands in the H3C VG Series Voice Gateways Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
aaa accounting-scheme login |
aaa authentication-scheme login |
aaa-client |
aaa-enable |
aaa-enable |
accounting |
acct-method |
acl |
address |
ani |
ani-offset |
answer |
area |
area-id (gk-client) |
area-id (voice entity) |
arp static |
authentication |
authentication-did |
authorization |
authorization-did |
busytone-t-th |
callednumber |
caller-permit |
callmode |
card-digit |
cas |
cdr |
cid display |
cid enable |
cid send |
cid type |
clear-forward-ack |
clienttype |
clock |
clock |
cngced-detection |
cng-on |
code |
compression |
controller |
copy |
cptone |
debugging |
debugging aaa |
debugging arp |
debugging dhcp client |
debugging ethernet |
debugging filter |
debugging ftp-server |
debugging ip icmp |
debugging ip packet |
debugging ip routing |
debugging ip rtpro |
debugging isdn |
debugging physical |
debugging ppp |
debugging pppoe-client |
debugging snmp-agent |
debugging tcp |
debugging udp |
debugging voice data-flow |
debugging voice dpl |
debugging voice fax |
debugging voice h225 |
debugging voice h245 |
debugging voice ipp |
debugging voice r2 |
debugging voice radius |
debugging voice ras |
debugging voice rcv |
debugging voice rcv r2 |
debugging voice vas |
debugging voice vas fax |
debugging voice vcc |
debugging voice vmib |
debugging voice vpp |
debugging voice vpp r2 |
debugging web |
default |
default entity compression |
default entity fast-connect |
default entity fax |
default entity payload-size |
default entity vad-on |
default subscriber-line dtmf gain |
default subscriber-line receive gain |
default subscriber-line transmit gain |
delay |
delay |
delete |
description (interface) |
description (voice entity) |
description (voice subscriber-line) |
dialer bundle |
dial-prefix |
dial-program |
dialtone-generate |
display aaa unsent-h323-call-record |
display aaa user |
display acl |
display arp |
display base-information |
display client |
display clock |
display current-configuration |
display current-configuration voice |
display debugging |
display duration |
display firewall |
display ftp-server |
display history-command |
display icmp statistics |
display info-center |
display interfaces ethernet |
display ip fast-forwarding cache |
display ip host |
display ip interface |
display ip routing-table |
display ip routing-table radix |
display ip routing-table static |
display ip routing-table verbose |
display ip statistics |
display isdn active-channel |
display isdn call-info |
display isdn dss1-parameters |
display isdn q931-timer |
display isdn qsig-timer |
display level |
display local-user command-history |
display local-user level |
display local-user login-history |
display local-user online |
display pppoe-client session |
display reboot |
display saved-configuration |
display snmp-agent community |
display snmp-agent group |
display snmp-agent local-engineid |
display snmp-agent mib-view |
display snmp-agent statistics |
display snmp-agent sys-info contact |
display snmp-agent sys-info location |
display snmp-agent usm-user |
display sysname |
display system cpu |
display system memory |
display tcp status |
display version |
display voice aaa-client local-user |
display voice aaa-client statistic |
display voice call-history-record |
display voice call-history-record line |
display voice call-info |
display voice default |
display voice entity |
display voice fax statistics |
display voice gateway |
display voice ipp |
display voice number-substitute |
display voice r2 call-statistics |
display voice rcv ccb |
display voice rcv statistic |
display voice rcv statistic r2 |
display voice subscriber-line |
display voice vcc |
display voice voip |
display voice voip data-statistic |
display voice vpp |
dl-bits |
dot-match |
download config |
dtmf |
dtmf gain |
dtmf sensitivity-level |
dtmf threshold (Analog Voice Subscriber-line) |
dtmf threshold (Digital Voice Subscriber-line) |
duplex |
echo-canceller |
effect-time |
entity |
fast-connect |
fax baudrate |
fax ecm |
fax level |
fax local-train threshold |
fax nsf-on |
fax protocol |
fax redundancy |
fax support-mode |
fax train-mode |
final-callednum |
firewall |
firewall default |
firewall packet-filter |
first-rule |
force-metering |
frame-format |
ftp-server bootromfull-name |
ftp-server bootrom-name |
ftp-server enable |
ftp-server timeout |
ftp-server update |
fxo-monitoring |
get |
gk-2nd-id |
gk-client |
gk-id |
gk-security call |
gk-security register-pwd |
group-b |
gw-access-number |
gw-address |
gw-id |
handshake |
hookoff-mode |
http-server disable |
http-server enable |
http-server language |
http-server port |
http-server sleeptime |
http-server timeout |
hub-enable |
iad |
iadmode-on |
iadms-address |
icmp redirect send |
idle-timeout |
impedance |
info-center console |
info-center enable |
info-center logbuffer |
info-center loghost |
info-center monitor |
info-center syslog |
interface |
ip address |
ip address |
ip address ppp-negotiate |
ip fast-forwarding |
ip fast-forwarding cache-size |
ip host |
ip option source-route |
ip route-static |
ip route-static |
ip-precedence |
isdn callingnum |
isdn check-called-number |
isdn communicate italy |
isdn crlength |
isdn facility-passthrough |
isdn ignore callednum |
isdn ignore hlc |
isdn ignore llc |
isdn overlap-receiving |
isdn protocol-type |
isdn q931-timer |
isdn qsig-timer |
isdn sending-complete |
isdn service |
isdn waitconnectack |
kill ftp |
kill telnet |
line |
line |
link-protocol ppp |
local-user (aaa-client) |
local-user password |
local-user service-type |
login-method accounting-mode |
login-method authentication-mode |
logout |
loopback |
loopback |
match-template |
max-call (voice dial program) |
max-call (voice entity) |
mfc (R2 CAS) |
mmib-set-threshold |
mode |
mtu |
mtu |
multi-gwid |
number-match |
number-substitute |
operatorKey |
outband |
password-digit |
payload-size |
peer-signal-port |
ping |
plan-numbering |
plc-mode |
polarity-reverse |
ppp chap password |
ppp chap user |
ppp keepalive times |
ppp pap local-user |
ppp timer negotiate |
pppoe-client |
priority |
pri-set |
private-line |
private-type |
process-config |
quit |
radius retry |
radius server |
radius shared-key |
radius source-ip |
radius stop-resend |
radius timer quiet |
radius timer realtime-accounting |
radius timer response-timeout |
ras-on |
re-answer |
reboot |
receive gain |
redialtimes |
registering |
registerKey |
register-value |
renew |
reset acl counters |
reset arp-cache |
reset ip fast-forwarding cache |
reset ip statistics |
reset local-user history |
reset pppoe-client |
reset saved-configuration |
reset syslog |
reset voice aaa-client statistic |
reset voice fax |
reset voice ipp |
reset voice r2 |
reset voice rcv |
reset voice vcc |
reset voice voip data-statistic |
reset voice vpp |
respond-reqcallernum |
return |
reverse |
ring-generate |
rule |
rule |
save |
seizure-ack |
selectlanguage |
select-mode |
select-rule rule-order |
select-rule search-stop |
select-rule type-first |
select-stop |
send-frame-type |
send-number (voice entity) |
send-number (voice subscriber-line) |
sendring |
send-ring |
server-authorization |
shutdown (voice entity) |
shutdown (voice subscriber-line ) |
signal-value |
silence-th-span |
snmp trap enable mmib |
snmp-agent |
snmp-agent group |
snmp-agent packet max-size |
snmp-agent sys-info version |
snmp-agent target-host |
snmp-agent trap enable |
snmp-agent trap life |
snmp-agent trap queue-size |
snmp-agent trap source |
special-character |
special-service |
special-service switch-dialtone |
speed |
subscriber-line |
subscriber-line |
substitute |
substitute incoming-call |
substitute outgoing-call |
sysname |
tcp mss |
tcp timer fin-timeout |
tcp timer syn-timeout |
tcp window |
telnet |
terminator |
timer (digital E&M) |
timer dial-interval |
timer dl (R2) |
timer dtmf (R2) |
timer first-dial |
timer register-complete (R2) |
timer register-pulse (R2) |
timer ring (R2) |
timeslot-set |
trace interval |
tracert |
transmit gain |
trunk-direction |
ts |
tunnel-on |
type-number |
update |
update |
vad-on |
version |
vi-card busy-tone-detect |
vi-card cptone-custom |
vi-card custom-toneparam |
vi-card hook-sensitivity |
vi-card polarity-reverse |
vi-card reboot |
voice-setup |
voip calledtunnel |
voip call-start |
voip h323-config tcs-t38 |
voip h323-descriptor |
voip h323-timer |
vqa data-statistic |
vqa dsp-monitor |
vqa ip-precedence |
vqa jitter-buffer |
vqa performance |
