10-设备管理命令
本章节下载: 10-设备管理命令 (1.20 MB)
1.1.14 display cpu-usage configuration
1.1.15 display cpu-usage history
1.1.16 display cpu-usage overload
1.1.17 display cpu-usage overload summary
1.1.19 display device manuinfo
1.1.20 display device manuinfo chassis-only
1.1.21 display device manuinfo fan
1.1.22 display device manuinfo power
1.1.23 display diagnostic-information
1.1.27 display hardware-failure-detection
1.1.28 display hardware-failure-protection
1.1.30 display kernel memory alloc-failure
1.1.31 display kernel memory fragment free
1.1.34 display memory-threshold
1.1.35 display memory-threshold dma
1.1.36 display non-stop-routing status
1.1.38 display power-off high-temp-board
1.1.39 display power-information
1.1.40 display resource-monitor
1.1.42 display scheduler logfile
1.1.43 display scheduler reboot
1.1.44 display scheduler schedule
1.1.45 display system stable state
1.1.46 display system-working-mode
1.1.47 display transceiver alarm
1.1.48 display transceiver brief
1.1.49 display transceiver diagnosis
1.1.50 display transceiver interface
1.1.51 display transceiver itu-channel
1.1.52 display transceiver manuinfo
1.1.53 display transceiver status
1.1.55 display version-update-record
1.1.58 forward-path-detection enable
1.1.59 hardware-failure-detection
1.1.60 hardware-failure-detection card-reboot enable
1.1.61 hardware-failure-protection aggregation
1.1.62 hardware-failure-protection auto-down
1.1.70 memory-threshold usage resend-interval
1.1.71 monitor cpu-usage enable
1.1.72 monitor cpu-usage interval
1.1.73 monitor cpu-usage threshold
1.1.74 monitor disk-usage disk
1.1.75 monitor disk-usage interval
1.1.76 monitor kernel memory fragment interval
1.1.77 monitor kernel memory fragment ratio
1.1.78 monitor resend cpu-usage
1.1.79 monitor resend cpu-usage core-interval
1.1.80 monitor resend memory-threshold
1.1.81 monitor resend memory-threshold dma
1.1.82 parity-error consistency-check log enable
1.1.83 parity-error consistency-check threshold
1.1.84 parity-error monitor log enable
1.1.85 parity-error monitor period
1.1.86 parity-error monitor threshold
1.1.87 parity-error unrecoverable log enable
1.1.88 parity-error unrecoverable period
1.1.89 parity-error unrecoverable reboot
1.1.90 parity-error unrecoverable threshold
1.1.91 password-recovery enable
1.1.93 power-off high-temp-board clear
1.1.94 power-off high-temp-board enable
1.1.98 reset scheduler logfile
1.1.99 reset transceiver interface
1.1.100 reset version-update-record
1.1.101 resource-monitor minor resend enable
1.1.102 resource-monitor output
1.1.103 resource-monitor resource
1.1.104 restore factory-default
1.1.106 scheduler logfile size
1.1.108 scheduler reboot delay
1.1.110 seu-error unrecoverable reboot
1.1.113 switch-fabric removal-signal-report enable
1.1.115 system forward-mode extended
1.1.124 transceiver lane enable
1.1.125 transceiver power-mode
card-mode命令用来配置接口卡的工作模式。
(独立运行模式)
card-mode slot slot-number subslot subslot-number mode-name
card-mode chassis chassis-number slot slot-number subslot subslot-number mode-name
MIC-SP4L接口子卡的工作模式为oc-3-pos,RX-NIC-LGQ2L接口子卡的工作模式为ethernet。
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
subslot subslot-number:子卡所在的子槽位号。
mode-name:指定接口子卡的工作模式。工作模式如下所示:
· oc-12-atm:配置接口子卡的工作模式为oc-12-atm模式。配置后,该接口子卡上的所有接口都可作为基于SONET/SDH承载的ATM OC-12c/STM-4接口来工作。关于ATM接口的详细介绍请参见“接口管理配置指导”中“ATM接口”。
· oc-12-pos:配置接口子卡的工作模式为oc-12-pos模式。该接口子卡上的所有接口都可作为622M POS接口来工作。关于POS接口的详细介绍请参见“接口管理配置指导”中“POS接口”。
· oc-3-atm:配置接口子卡的工作模式为oc-3-atm模式。配置后,该接口子卡上的所有接口都可作为基于SONET/SDH承载的ATM OC-3c/STM-1接口来工作。关于ATM接口的详细介绍请参见“接口管理配置指导”中“ATM接口”。
· oc-3-pos:配置接口子卡的工作模式为oc-3-pos模式。该接口子卡上的所有接口都可作为155M POS接口来工作。关于POS接口的详细介绍请参见“接口管理配置指导”中“POS接口”。
· ethernet:配置接口子卡的工作模式为标准以太模式。配置后,该接口子卡上的所有接口可作为以太网接口使用。关于以太网接口的详细介绍请参见“接口管理配置指导”中“以太网接口”。
· flexe:配置接口子卡的工作模式为灵活以太模式。配置后,该接口子卡上的所有接口可作为FlexE物理接口使用。关于FlexE物理接口的详细介绍请参见“接口管理配置指导”中“FlexE接口”。
模式切换后接口子卡会自动重启,重启后新配置的模式才会生效。
若当前接口子卡损坏,更换相同型号的接口子卡后,新子卡上以当前设备配置的工作模式生效。
# 将位于指定接口子卡的工作模式配置为oc-12-atm模式。(独立运行模式)
[Sysname] card-mode slot 2 subslot 1 oc-12-atm
clock datetime命令用来配置设备的系统时间。
clock datetime time date
设备的系统时间为出厂时间。
time:配置的时间,格式为HH:MM:SS(小时:分钟:秒),HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。比如将time参数配置为0表示零点。
date:配置的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日),MM的取值范围为1~12,DD的取值范围与月份有关,YYYY的取值范围为2000~2035。
执行本命令会修改设备的系统时间,会影响和系统时间相关特性的执行(例如定时执行任务功能),以及和其他设备的协同操作(例如日志上报和统计),请谨慎执行。
请先配置clock protocol none命令,再执行本命令。clock datetime命令中指定的时间会立即生效,作为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
修改夏令时或时区后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
# 配置设备的系统时间为2012年1月1日8时8分8秒。
<Sysname> clock datetime 8:8:8 1/1/2012
# 配置设备的系统时间为2012年1月1日8时10分。
<Sysname> clock datetime 8:10 2012/1/1
· clock protocol
· clock summer-time
· clock timezone
· display clock
clock protocol命令用来配置系统时间的获取方式。
undo clock protocol命令用来恢复缺省情况。
clock protocol { none | { ntp | ptp } mdc mdc-id }
undo clock protocol
通过NTP协议获取时间。
none:表示通过命令行配置系统时间。
ptp:表示通过PTP(Precision Time Protocol,精确时间协议)协议获取时间。关于PTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“PTP”。
ntp:表示通过NTP(Network Time Protocol,网络时间协议)协议获取时间。关于NTP的详细介绍和配置,请参见“网络管理和监控配置指导”中的“NTP”。
mdc mdc-id:表示时钟的来源MDC编号。
系统时间的获取方式有:
· 配置clock protocol none命令后,通过clock datetime命令直接配置。clock datetime命令中指定的时间即为当前的系统时间。后续,设备使用内部晶体震荡器产生的时钟信号计时。
· 配置clock protocol { ntp | ptp }命令后,通过NTP/PTP协议从网络中获取时间。该方式下,设备会周期性的同步服务器的UTC(Coordinated Universal Time,国际协调时间)时间,并用同步得到的UTC时间和设备上配置的本地时区、夏令时参数运算,得出当前的系统时间。该方式获取的时间比命令行配置的时间更精准,推荐使用。
多次执行本命令,最后一次执行的命令生效。
# 配置获取UTC时间的方式为通过命令行配置。
[Sysname] clock protocol none
clock summer-time命令用来配置夏令时。
undo clock summer-time命令用来恢复缺省情况。
未配置夏令时。
start-time:开始时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
start-date:开始日期,有两种输入方式:
· 直接一次性输入月和日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
· 分次输入月、日,各参数之间以<空格>键隔开。首先输入开始的月份,取值如下:January、February、March、April、May、June、July、August、September、October、November或December;然后输入开始的星期,用当月的第几个星期表示,取值如下:first、second、third、fourth、fifth或last;最后输入起始日,取值为Sunday、Monday、Tuesday、Wednesday、Thursday、Friday或Saturday。
end-time:结束时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
end-date:结束日期,有两种输入方式:
· 直接一次性输入月日,参数格式为MM/DD,MM取值范围为1~12,DD的取值范围与月份有关。
add-time:偏移时间,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59。如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
配置该命令后,设备会自动重新计算当前的系统时间,计算后得到的系统时间可通过display clock命令查看。
请将所有网络设备的夏令时和当地夏令时保持一致。
# 配置夏令时PDT,从每年的8月1日的06:00:00开始,到9月1日的06:00:00结束,比当前设备标准时间增加1小时。
[Sysname] clock summer-time PDT 6 08/01 6 09/01 1
· clock datetime
· clock timezone
· display clock
clock timezone命令用来配置系统所在的时区。
undo clock timezone命令用来恢复缺省情况。
undo clock timezone
系统所在的时区为零时区,即设备采用格林威治标准时间。
zone-name:时区名称,为1~32个字符的字符串,区分大小写。
add:在UTC时间的基础上增加指定时间。
minus:在UTC时间的基础上减少指定时间。
zone-offset:与UTC的时间差,格式为HH:MM:SS,HH取值范围为0~23,MM和SS取值范围为0~59,如果要配置成整分,则可以不输入秒;如果要配置成整点,则可以不输入分和秒。
请将所有网络设备的时区和当地地理时区保持一致。
# 配置本地时区名称为Z5,比UTC标准时间增加5小时。
[Sysname] clock timezone Z5 add 5
· clock datetime
· clock summer-time
· display clock
command命令用来为Job分配命令。
undo command命令用来取消为Job分配的命令。
command id command
undo command id
没有为Job分配命令。
Job视图
command:为Job分配的命令。
多次输入command命令可以为当前Job分配多条命令,不同命令用编号来唯一区别。如果新分配命令的编号和已分配的某命令的编号相同,则新分配的命令会覆盖已分配的命令。
通过command分配的命令行必须是设备上可成功执行的命令行,不包括telnet、ftp、ssh2和monitor process。由用户保证配置的正确性,否则,命令行不能自动被执行。
如果需要分配的命令(假设为A)是用户视图下的命令,则直接使用command命令分配即可,比如:command 1 display interface;如果需要分配的命令(假设为A)是非用户视图下的命令,则必须先分配进入A所在视图的命令(指定较小的id值),再分配A。比如:要使用Job定时执行shutdown命令,则需执行三次command命令,分别分配system-view、interface、shutdown命令,且各command命令的id值逐渐增大。
定时执行任务时,设备不会与用户交互信息。当需要用户交互确认时,系统将自动输入“Y”或“Yes”;当需要用户交互输入字符信息时,系统将自动输入缺省字符串,没有缺省字符串的将自动输入空字符串。
# 为名称为backupconfig的Job分配命令,以便将配置文件startup.cfg备份到TFTP服务器192.168.100.11。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig] command 2 tftp 192.168.100.11 put flash:/startup.cfg backup.cfg
# 为Job(假设名称为shutdownGE)分配命令,以便将接口Ten-GigabitEthernet3/1/1关闭。
[Sysname] scheduler job shutdownGE
[Sysname-job-shutdownGE] command 1 system-view
[Sysname-job-shutdownGE] command 2 interface ten-gigabitethernet 3/1/1
[Sysname-job-shutdownGE] command 3 shutdown
· scheduler job
copyright-info enable命令用来开启版权信息显示功能。
undo copyright-info enable命令用来关闭版权信息显示功能。
版权信息显示功能处于开启状态。
# 开启版权信息显示功能。
[Sysname] copyright-info enable
重新登录设备后,会显示如下信息:
* Copyright (c) 2004-2022 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent, *
* no decompiling or reverse-engineering shall be allowed. *
display alarm命令用来显示设备的告警信息。
(独立运行模式)
display alarm [ slot slot-number [ cpu cpu-number ] ]
display alarm [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:显示指定单板的告警信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的告警信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的告警信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
当设备的电源、CPU、风扇等运行异常时,使用display alarm命令可以查看到相应的告警信息。对于过去发生的、已经恢复的告警可以使用display alarm history命令查看;对于过去发生的、当前仍未恢复的告警可以使用display alarm active命令查看。
# 显示设备的告警信息。
<Sysname> display alarm
Slot CPU Level Info
2 0 ERROR Board is faulty
表1-1 display alarm命令显示信息描述表
Slot |
产生告警的slot,显示为“-”,表示产生告警的元件位于机框上 |
CPU |
告警CPU的编号 |
Level |
告警的级别,级别由高到低依次为ERROR、WARNING、NOTICE、INFO |
Info |
告警的详细信息。取值为: · Board is faulty:表示该slot处于faulty状态(该slot可能正在启动,或者当前处于故障状态) · Fan n is absent:风扇n当前不在位 · Power n is absent:电源n当前不在位 · The temperature of sensor n exceeds the lower limit:传感器n的温度低于低温门限 · The temperature of sensor n exceeds the upper limit:传感器n的温度高于高温门限 |
display alarm active命令用来显示设备当前仍未恢复的告警信息。
display alarm active [ verbose ]
verbose:显示告警项的详细信息。不指定该参数时,显示告警项的概要信息。
# 显示设备当前仍未恢复的告警信息。(独立运行模式)
<Sysname> display alarm active
Seq Level Time Info
24 Warning 2020-01-11 12:40:00 CPU usage is in minor alarm state on slot 1.
23 Warning 2020-01-11 12:30:00 Memory minor threshold has been exceeded on slot 1.
22 Minor 2020-01-11 12:18:00 Board state changed to Fault on slot 1.
表1-2 display alarm active命令显示信息描述表
Seq |
告警序列号,告警发生时分配。 |
Level |
告警的级别,级别由高到低依次为Critical、Major、Minor、Warning |
Time |
告警产生的时间 |
Info |
告警的详细信息,涉及风扇、电源、设备温度等故障,主要取值包括: · Board state changed to Fault on slot xx:slot xx变成Fault状态(该slot可能正在启动,或者处于故障状态) · Slot xx fan xx is absent:Slot xx上风扇xx未插入 · Slot xx fan xx is failed:Slot xx上风扇xx处于异常状态 · Slot xx power xx is absent:Slot xx上电源xx未插入 · Slot xx power xx failed:Slot xx上电源xx处于异常状态 · Temperature is higher than the high-temperature alarming threshold on slot xx sensor inflow xx:slot xx上的传感器xx的温度高于高温门限 · Memory minor threshold has been exceeded on slot xx:slot xx的空闲内存高于minor门限 · CPU usage is in minor alarm state on slot xx:slot xx的CPU使用率高于minor门限 · Interface-name: RX power is high!:接口Interface-name光功率过高 · Interface-name:The bit error ratio exceeds the upper threshold:接口Interface-name误码率超过了上限 · SSH user username (IP: IP-Address) connected to the server successfully:SSH用户的用户名(IP:IP地址)成功登录服务器 · Member port xx of aggregation group xx changed to the inactive state, because xx.:聚合xx内成员接口xx因为xx原因非选中 · LDP Session ($1, $2) status changed to $3.:LDP会话状态变化 ¡ $1:对等体的LDP ID。如果无法获得对等体的LDP ID,显示为0.0.0.0:0 ¡ $2:VPN实例名。如果该会话属于公网,显示为public instance ¡ $3:LDP会话状态,取值包括:nonexistent,initialized,openrec,opensent,operational · PCEP Session ($1, $2) is $3.:PCEP会话状态变化 ¡ $1:会话对端IP地址 ¡ $2:会话所在VPN实例名称,如果无法获取则显示为unknown ¡ $3:会话的状态变更,up或者down,如果状态变更为down,则一并显示会话down的原因 · Address pool pool-name has run out of assignable subnets:地址池子网段耗尽 · Address pool pool-name has run out of IP addresses:地址池地址资源耗尽 · Address pool group pool-group-name has run out of IP addresses:地址池组地址资源耗尽 · Address pool group pool-group-name has run out of assignable subnets:地址池组子网段耗尽 · Address pool pool-name has run out of IPv6 prefix ranges:地址池前缀段资源耗尽 · IPv6 pool pool-name has run out of addresses:IPv6地址池地址资源耗尽 · Address pool pool-name has run out of IPv6 prefix:IPv6地址池前缀资源耗尽 · IPv6 pool group pool-group-name has run out of addresses:IPv6地址池组地址资源耗尽 · Address pool group pool-group-name has run out of assignable subnets:IPv6地址池组地址网段耗尽 · Address pool group pool-group-name has run out of IPv6 prefix ranges:IPv6地址池组前缀段耗尽 · Memory alert has been triggered for reaching the minor threshold:达到minor门限后内存门限告警 |
# 显示设备当前仍未恢复的告警信息详细内容。(独立运行模式)
<Sysname> display alarm active verbose
Seq 4
Alarm name: BoardStatus
Alarm source: slot 2
Level: Minor
Start time: 2022-05-16 18:58:46
Info: Board state changed to Fault on slot 2.
表1-3 display alarm active verbose命令显示信息描述表
Seq |
告警序列号,告警发生时由系统自动分配 |
Alarm name |
告警的名称 |
Alarm source |
告警对象所在位置 |
Level |
Start time |
告警发生时间 |
Info |
告警的详细信息 |
# 显示设备当前仍未恢复的告警信息。(IRF模式)
Seq Level Time Info
24 Warning 2020-01-11 12:40:00 CPU usage is in minor alarm state on chassis 1 slot 1.
23 Warning 2020-01-11 12:30:00 Memory minor threshold has been exceeded on chassis 1 slot 1.
22 Minor 2020-01-11 12:18:00 Board state changed to Fault on chassis 1 slot 1.
表1-4 display alarm active命令显示信息描述表
Seq |
告警序列号,告警发生时分配。 |
Level |
Time |
告警产生的时间 |
Info |
告警的详细信息,涉及风扇、电源、设备温度等故障,主要取值包括: · Board state changed to Fault on chassis xx slot xx:框xx槽位xx上的单板变成Fault状态(该单板可能正在启动,或者处于故障状态) · Chassis xx slot xx fan xx is absent:框xx槽位xx上的风扇xx未插入 · Chassis xx slot xx fan xx is failed:框xx槽位xx上的风扇xx处于异常状态 · Chassis xx slot xx power xx is absent:框xx槽位xx上的电源xx未插入 · Chassis xx slot xx power xx failed:框xx槽位xx上的电源xx处于异常状态 · Temperature is higher than the high-temperature alarming threshold on chassis xx slot xx sensor inflow xx:框xx槽位xx上的传感器xx的温度高于高温门限 · Memory minor threshold has been exceeded on chassis xx slot xx:框xx槽位xx的空闲内存高于minor门限 · CPU usage is in minor alarm state on chassis xx slot xx:框xx槽位xx的CPU使用率高于minor门限 · Interface-name: RX power is high!:接口Interface-name光功率过高 · Interface-name:The bit error ratio exceeds the upper threshold:接口Interface-name误码率超过了上限 · SSH user username (IP: IP-Address) connected to the server successfully:SSH用户的用户名(IP:IP地址)成功登录服务器 · Member port xx of aggregation group xx changed to the inactive state, because xx.:聚合xx内成员接口xx因为xx原因非选中 · LDP Session ($1, $2) status changed to $3.:LDP会话状态变化 ¡ $1:对等体的LDP ID。如果无法获得对等体的LDP ID,显示为0.0.0.0:0 ¡ $2:VPN实例名。如果该会话属于公网,显示为public instance ¡ $3:LDP会话状态,取值包括:nonexistent,initialized,openrec,opensent,operational · PCEP Session ($1, $2) is $3.:PCEP会话状态变化 ¡ $1:会话对端IP地址 ¡ $2:会话所在VPN实例名称,如果无法获取则显示为unknown ¡ $3:会话的状态变更,up或者down,如果状态变更为down,则一并显示会话down的原因 · Address pool pool-name has run out of assignable subnets:地址池子网段耗尽 · Address pool pool-name has run out of IP addresses:地址池地址资源耗尽 · Address pool group pool-group-name has run out of IP addresses:地址池组地址资源耗尽 · Address pool group pool-group-name has run out of assignable subnets:地址池组子网段耗尽 · Address pool pool-name has run out of IPv6 prefix ranges:地址池前缀段资源耗尽 · IPv6 pool pool-name has run out of addresses:IPv6地址池地址资源耗尽 · Address pool pool-name has run out of IPv6 prefix:IPv6地址池前缀资源耗尽 · IPv6 pool group pool-group-name has run out of addresses:IPv6地址池组地址资源耗尽 · Address pool group pool-group-name has run out of assignable subnets:IPv6地址池组地址网段耗尽 · Address pool group pool-group-name has run out of IPv6 prefix ranges:IPv6地址池组前缀段耗尽 · Memory alert has been triggered for reaching the minor threshold:达到minor门限后内存门限告警 |
# 显示设备当前仍未恢复的告警信息详细内容。(IRF模式)
Seq 13
Alarm name: IPC_PKT_LOSS
Alarm source: e0003-0/ffff/0
Level: Major
Start time: 2022-05-25 19:22:40
Info: Chassis 1 slot 8: Packet loss occurred on inter-board IPC channel. Sourc
e port = Chassis 1 Slot 2, Destination port = Chassis 1 Slot 8. Detailed informa
tion = BLOCKED.
表1-5 display alarm active verbose命令显示信息描述表
Seq |
Alarm name |
告警的名称 |
Alarm source |
告警对象所在位置 |
Level |
Start time |
告警发生时间 |
Info |
告警的详细信息 |
· display alarm
· display alarm history
display alarm history命令用来显示已经恢复的告警信息。
display alarm history [ verbose ]
verbose:显示告警项的详细信息。不指定该参数时,显示概要信息。
# 显示设备告警历史信息。(独立运行模式)
<Sysname> display alarm history
Seq Time Info
23 2020-01-11 12:40:00 CPU usage recovered to normal state on slot 1.
本命令显示信息描述表请参见表1-2。
# 显示设备告警历史信息详细内容。(独立运行模式)
<Sysname> display alarm history verbose
Seq 23
Alarm name: CPUUsageMinor
Alarm position: slot 1
Start time: 2020-01-11 12:30:00
Level: Warning
Info: CPU usage is in minor alarm state on slot 1
Recovery time: 2020-01-11 12:40:30
Info: CPU usage minor alarm removed on slot 1.
表1-6 display alarm history verbose命令显示信息描述表
Seq |
Alarm name |
告警的名称 |
AlarmPosition |
告警对象所在位置 |
Start time |
告警发生时间 |
Level |
Recovery time |
告警恢复时间 |
Info |
告警的详细信息 |
# 显示设备告警历史信息。(IRF模式)
Seq Time Info
23 2020-01-11 12:40:00 CPU usage recovered to normal state on chassis 1 slot 1.
本命令显示信息描述表请参见表1-4。
# 显示设备告警历史信息详细内容。
Seq 23
Alarm position: chassis 1 slot 1
Level: Warning
Info: CPU usage is in minor alarm state on chassis 1 slot 1
Info: CPU usage minor alarm removed on chassis 1 slot 1.
表1-7 display alarm history verbose命令显示信息描述表
Seq |
Alarm name |
告警的名称 |
Alarm position |
告警对象所在位置 |
Start time |
告警发生时间 |
Level |
Recovery time |
告警恢复时间 |
Info |
告警的详细信息 |
· display alarm
display clock命令用来显示系统当前的时间、日期、本地时区以及夏令时配置。
display clock
# 未配置本地时区时,显示系统当前日期和时间。
<Sysname> display clock
10:09:00 UTC Fri 03/16/2015
# 配置了本地时区Z5后,显示系统当前日期和时间。
15:10:00 Z5 Fri 03/16/2015
Time Zone : Z5 add 05:00:00
# 配置了本地时区Z5和夏令时PDT后,显示系统当前日期和时间。
15:11:00 Z5 Fri 03/16/2015
· clock datetime
· clock timezone
· clock summer-time
display copyright命令用来显示设备的版权信息。
display copyright
# 显示设备的版权信息。
<Sysname> display copyright
显示信息略……。
display cpu-usage命令用来显示CPU利用率的统计信息。
(独立运行模式)
display cpu-usage [ summary ] [ slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane ] [ summary ] [ slot slot-number [ cpu cpu-number ]
display cpu-usage [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number [ core { core-number | all } ] ] ]
display cpu-usage [ control-plane ] [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ]
control-plane:显示控制平面CPU利用率的统计信息。
summary:以列表形式显示CPU利用率的统计信息。不指定该参数时,以区段形式显示CPU利用率的统计信息。
slot slot-number:显示指定单板的CPU利用率的统计信息。slot-number表示单板所在的槽位号。不指定该参数时,显示的是所有单板的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备指定单板的CPU利用率的统计信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的利用率统计信息。cpu-number表示CPU的编号。
core { core-number | all }:显示CPU核利用率的统计信息。其中,all表示显示所有CPU核利用率的统计信息;core-number表示CPU核的编号,显示指定CPU核利用率的统计信息。
当最近5秒、最近1分钟、最近5分钟的CPU利用率取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 以段的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage
Slot 1 CPU 0 CPU usage:
1% in last 5 seconds
1% in last 1 minute
1% in last 5 minutes
# 以表的形式显示当前CPU利用率统计信息。(独立运行模式)
<Sysname> display cpu-usage summary
Slot CPU Last 5 sec Last 1 min Last 5 min
1 0 17% 29% 28%
表1-8 display cpu-usage命令显示信息描述表
1% in last 5 seconds |
设备启动后,会以5秒为周期计算并记录一次该5秒内的CPU或CPU核的平均利用率。该字段显示的是最近一个5秒统计周期内CPU或CPU核的平均利用率 |
Last 5 sec |
1% in last 1 minute |
设备启动后,会以1分钟为周期计算并记录一次该1分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个1分钟统计周期内CPU或CPU核的平均利用率 |
Last 1 min |
1% in last 5 minutes |
设备启动后,会以5分钟为周期计算并记录一次该5分钟内的CPU或CPU核的平均利用率。该字段显示的是最近一个5分钟统计周期内CPU或CPU核的平均利用率 |
Last 5 min |
display cpu-usage configuration命令用来显示CPU利用率监控功能的相关配置。
(独立运行模式)
display cpu-usage configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,显示的是主用主控板上的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。不指定该参数时,显示的是全局主用主控板上的相应信息。(IRF模式)
cpu cpu-number:表示CPU的编号。
# 显示CPU利用率监控功能的相关配置。
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 79%.
Current recovery threshold is 69%.
表1-9 display cpu-usage configuration命令显示信息描述表
CPU usage monitor is enabled. |
CPU利用率监控功能处于开启状态 |
Current monitor interval is 60 seconds. |
CPU利用率监控功能的采样周期为60秒 |
Current severe alarm threshold is 99%. |
CPU利用率的严重级阈值为99% |
Current minor alarm threshold is 79%. |
CPU利用率提示级阈值为79% |
Current recovery threshold is 69% |
CPU利用率恢复门限为69% |
· monitor cpu-usage enable
· monitor cpu-usage interval
· monitor cpu-usage threshold
display cpu-usage history命令用来以图表方式显示CPU利用率的历史信息。
(独立运行模式)
display cpu-usage history [ job job-id ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
job job-id:显示指定进程的CPU利用率的历史信息。job-id表示进程的编号,取值范围为1~2147483647。不指定该参数时,显示的是整个系统的相应信息(整个系统的CPU利用率等于所有进程CPU利用率之和)。可以使用display process命令可以查看当前运行的进程的编号和名称,display process命令的详细介绍请参见“网络管理与监控”中的“系统维护与调试”。
slot slot-number:显示指定单板的CPU利用率的历史信息。slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是主用主控板上指定进程的相应信息。(独立运行模式)
chassis chassis-number slot slot-number:显示指定成员设备上指定单板的CPU利用率的历史信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。当不指定job和该参数时,显示的是所有单板上所有进程的相应信息;当指定job参数,但不指定该参数时,显示的是全局主用主控板上指定进程的相应信息。(IRF模式)
cpu cpu-number:显示指定CPU的利用率的历史信息。cpu-number表示CPU的编号。当不指定job和该参数时,表示所有CPU。当指定job参数,但不指定该参数时,表示默认CPU。
开启CPU利用率历史记录功能后,系统每隔一定时间(可通过monitor cpu-usage interval命令配置)会对CPU的利用率进行采样,并把采样结果保存到历史记录区。通过display cpu-usage history命令可以查看到最近60个采样点的值。结果以坐标的形式进行显示,显示信息中:
· 纵坐标表示利用率,采用就近显示的原则。比如,利用率的间隔为5%,则实际统计值53%将被显示成55%,实际统计值52%将被显示成50%。
· 横坐标表示时间,时间越靠左表示距离当前时间越近。
· 用连续的#号表示该时刻的利用率,某个时间点上最高处的#号对应的纵坐标值即为该时刻CPU的利用率。
# 以图表方式显示CPU利用率的历史记录。(独立运行模式)
<Sysname> display cpu-usage history
100%|
95%|
90%|
85%|
80%|
75%|
70%|
65%|
60%|
55%|
50%|
45%|
40%|
35%|
30%|
25%|
20%|
15%| #
10%| ### #
5%| ########
10 20 30 40 50 60 (minutes)
cpu-usage (Slot 1 CPU 0) last 60 minutes (SYSTEM)
以上显示信息表明系统(用“SYSTEM”表示,运行在Slot 1 CPU 0上)在最近60分钟内CPU的利用率情况:12分钟前大约为5%,13分钟前大约为10%,14分钟前大约为15%,15分钟前大约为10%,16、17分钟前大约为5%,18分钟前大约为10%,19分钟前大约为5%,其它时间均小于或等于2%。
display cpu-usage overload命令用来显示CPU过载记录的具体信息。
(独立运行模式)
display cpu-usage overload show-number [ stack-info ] slot slot-number [ cpu cpu-number ]
display cpu-usage overload show-number [ stack-info ] chassis chassis-number slot slot-number [ cpu cpu-number ]
show-number:显示指定数目的CPU过载记录的具体信息,取值范围为1~10。
stack-info:显示CPU过载时,占用CPU最多的前三条进程的堆栈信息。不指定该参数时,不会显示堆栈信息。
slot slot-number:指定单板。slot-number为单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
CPU过载记录的具体信息包括CPU过载记录的汇总信息、CPU过载时占用CPU较多的进程的信息以及占用CPU最多的前三条进程的堆栈信息。
# 显示指定单板最近1次CPU过载记录的具体信息,不包括占用CPU最多的前三条进程的堆栈信息。(独立运行模式)
<Sysname> display cpu-usage overload 2 slot 1
CPU overload summary information:
Slot/CPU Time Overload status Processes
1/0 0000-00-00 00:00:00:000 No overloaded NA
No CPU overload history.
# 显示指定单板最近1次CPU过载记录的具体信息,不包括占用CPU最多的前三条进程的堆栈信息。(IRF模式)
<Sysname> display cpu-usage overload 1 chassis 1 slot 2 cpu 0
Chassis/Slot/CPU Time Overload status Processes
1/2/0 2018-11-12 12:00:00:000 Recovered 300
2018-11-12 11:00:00:000 Minor alarm 400
2018-11-12 10:00:00:000 Severe alarm 500
2018-11-12 09:00:00:000 Minor alarm 400
CPU overload history on overload time 2018-11-12 11:00:00:000.
CPU utilization in recent 5 secs: 100.0%; 1 min: 100.0%; 5 mins: 100.0%.
Top processes in recent 5 secs:
JID PID PPID CPU State Mem 5sec 1min 5min Name
811795 811795 811792 0 S 21584K 0.6% 0.0% 0.0% login
811801 811801 811799 0 S 21524K 0.6% 0.0% 0.0% login
811796 811796 811794 0 S 21524K 0.5% 0.0% 0.0% login
257 257 2 0 S 0K 0.0% 0.0% 0.0% [CLKM]
206 206 2 0 S 0K 0.0% 0.0% 0.0% [DIPC]
679 679 342 0 S 137324K 0.1% 0.0% 0.0% comsh
211 211 2 0 D 0K 0.0% 0.0% 0.0% [DTIM]
1778 1778 342 0 S 95352K 0.0% 0.0% 0.0% comsh
261 261 2 0 D 0K 0.0% 0.0% 0.0% [TEMP]
# 显示指定单板最近2次CPU过载记录的具体信息,包括占用CPU最多的前三条进程的堆栈信息。(IRF模式)
<Sysname> display cpu-usage overload 2 stack-info chassis 1 slot 2 cpu 0
CPU overload information:
1/2/0 2018-11-12 11:00:00:000 Minor alarm 400
CPU utilization in 5 secs: 100.0%; 1 min: 100.0%; 5 mins: 100.0%.
1 1 0 0 S 21584K 0.6% 0.0% 0.0% scmd
152 152 1 0 S 21524K 0.6% 0.0% 0.0% ifmgr
153 153 1 0 S 21524K 0.5% 0.0% 0.0% edev
805 805 804 0 S 21440K 0.4% 0.0% 0.0% login
Stack information of process 1 (scmd):
Thread LWP 1:
Switches: 2205
User stack:
#0 0x00007f957d47b320 in epoll_wait+0x14/0x2e
#1 0x0000000000422c1c in ScmMainThread+0x51/0x125
#2 0x0000000000422650 in main+0xd0/0xd7
#3 0x00007f957d4a7ad0 in __uClibc_main+0x242/0x26c
#4 0x0000000000407519 in _start+0x29/0x2a
Kernel stack:
[<ffffffff811eeca3>] ep_poll+0x2f3/0x370
[<ffffffff811eedf0>] SyS_epoll_wait+0xd0/0xe0
[<ffffffff814deb39>] system_call_fastpath+0x16/0x1b
[<ffffffffffffffff>] 0xffffffffffffffff
Stack information of process 152 (ifmgr):
Thread LWP 152:
Switches: 177
User stack:
#0 0x00007f4418429154 in pthread_cond_wait+0xc4/0x203
#1 0x00007f4416b138d0 in logicFlowRoutine+0x1b/0x49
#2 0x0000000000403e33 in main+0x12c/0x133
#3 0x00007f4415deaad0 in __uClibc_main+0x242/0x26c
#4 0x00000000004038f9 in _start+0x29/0x2a
Kernel stack:
[<ffffffff81107287>] futex_wait_queue_me+0xd7/0x140
[<ffffffff811074f0>] futex_wait+0x190/0x280
[<ffffffff81109725>] do_futex+0xe5/0xcf0
[<ffffffff8110a477>] SyS_futex+0x147/0x180
Thread LWP 154:
Switches: 3222
User stack:
#0 0x00007f4415dbe320 in epoll_wait+0x14/0x2e
#1 0x00007f4416b106ef in lipcRoutine+0x6f/0xa5
#2 0x00007f44184219e0 in ??
#3 0x00007f4418427fe5 in __clone+0x79/0x83
Kernel stack:
Thread LWP 156:
Switches: 3151
User stack:
#1 0x00007f4416b15cf8 in miscJobsRoutine+0x18/0x80
Kernel stack:
Stack information of process 153 (edev):
Thread LWP 153:
Switches: 163
User stack:
#0 0x00007f7d3c276320 in epoll_wait+0x14/0x2e
#1 0x0000000000413748 in main+0x9f/0x10f
#2 0x00007f7d3c2a2ad0 in __uClibc_main+0x242/0x26c
#3 0x00000000004082f9 in _start+0x29/0x2a
Kernel stack:
Thread LWP 155:
Switches: 1
User stack:
#0 0x00007f7d3c2a22fd in __read+0x2d/0x5e
#1 0x0000000000414be6 in EdevDisioctlThread+0x2d/0x72
#2 0x00007f7d3dacc9e0 in ??
#3 0x00007f7d3dad2fe5 in __clone+0x79/0x83
Kernel stack:
[<ffffffff811f15dd>] eventfd_ctx_read+0x15d/0x210
[<ffffffff811f16dd>] eventfd_read+0x4d/0x80
[<ffffffff811ab621>] vfs_read+0xa1/0x160
[<ffffffff811ab7c4>] SyS_read+0x54/0xc0
CPU Overload history on overload time 2018-11-12 10:00:00:000.
Thread (LWP 1):
Switches: 2205
User stack:
Kernel stack:
Thread (LWP 152):
Switches: 177
User stack:
Kernel stack:
Thread (LWP 154):
Switches: 3222
User stack:
Kernel stack:
Thread (LWP 156):
Switches: 3151
User stack:
Kernel stack:
Thread (LWP 153):
Switches: 163
User stack:
Kernel stack:
Thread (LWP 155):
Switches: 1
User stack:
Kernel stack:
表1-10 display cpu-usage overload命令显示信息描述表
CPU overload summary information |
CPU的简要过载信息 |
Time |
过载时间,未过载时显示0000-00-00 00:00:00:000 |
Overload status |
过载状态,取值为: · No overloaded:未过载状态,初始状态 · Minor alarm:低级别过载状态,超过低级别告警门限 · Severe alarm:高级别过载状态,超过高级别告警门限 · Recovered:过载恢复状态,降到恢复门限以下 |
Processes |
过载时的进程数目,没有过载时显示NA |
CPU overload history on overload time 2018-11-12 10:00:00:000: |
CPU的详细过载信息,如果没有显示No CPU overload history. |
Overload time |
过载时间,没有过载时显示0000-00-00 00:00:00:000 |
CPU utilization in recent 5 secs: 100.0%; 1 min: 100.0%; 5 mins: 100.0% |
系统最近5秒CPU使用率;最近1分钟CPU使用率;最近5分钟CPU使用率 |
Top processes in recent 5 secs |
按5 sec利用率由高到低排序 |
JID |
任务编号(用于唯一标识一个进程,该编号不会随着进程的重启而改变) |
PID |
进程编号 |
PPID |
父进程编号 |
CPU |
进程最近一次被调度时,所在的CPU |
State |
进程状态,可能的取值为: · R:running,运行状态或处于运行队列 · S:sleeping,可中断睡眠状态 · T:traced or stopped,暂停状态 · D:uninterruptible sleep,不可中断睡眠状态 · Z:zombie,僵死状态 |
Mem |
进程所使用的内存大小(内核线程该项显示为0) |
5sec |
最近5秒钟内进程的CPU使用率 |
1min |
最近1分钟内进程的CPU使用率 |
5min |
最近5分钟内进程的CPU使用率 |
Name |
进程名称(如果进程名称带有“[ ]”标记,则表示该进程为内核线程) |
Stack information of process 1 (scmd): |
进程的堆栈信息,进程的PID为1,进程名称为scmd |
Thread LWP 1: |
被跟踪进程的子进程 |
Switches |
调度计数 |
User stack |
用户态堆栈信息,仅用户态进程显示该信息 |
Kernel stack |
内核态堆栈信息,仅内核态进程显示该信息 |
· display cpu-usage overload summary
display cpu-usage overload summary用来显示所有CPU过载记录的汇总信息。
# 显示所有CPU过载记录的汇总信息。(独立运行模式)
<Sysname> display cpu-usage overload summary
1/0 2018-11-12 12:00:00:000 Recovered 300
# 显示所有CPU过载记录的汇总信息。(IRF模式)
1/1/0 0000-00-00 00:00:00:000 No overloaded NA
1/3/0 0000-00-00 00:00:00:000 No overloaded NA
本命令显示信息描述请参见表1-10。
display device命令用来显示设备信息。
(独立运行模式)
display device [ cf-card | flash | sd-card ] [ slot slot-number [ cpu cpu-number ] [ subslot subslot-number ] | verbose ]
display device [ cf-card | flash | sd-card ] [ chassis chassis-number [ slot slot-number [ cpu cpu-number ] [ subslot subslot-number ] ] | verbose ]
cf-card:显示CF卡的信息。
flash:显示Flash的信息。
sd-card:显示SD卡的信息。仅CSR05SRP1P3单板支持本参数。
chassis chassis-number:显示指定成员设备的详细信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,表示所有成员设备。(IRF模式)
slot slot-number:显示指定单板的信息。slot-number表示单板所在的槽位号。不指定该参数时,表示所有单板。
subslot subslot-number:显示指定子卡的信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息,且此时不会显示防火墙插卡的信息。
cpu cpu-number:显示指定CPU的信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
不指定cf-card、flash、sd-card参数时,显示单板的信息。
# 显示设备信息。(独立运行模式)
<Sysname> display device
显示信息略……。
表1-11 display device命令显示信息描述表
Brd Type |
单板的硬件类型 |
Brd Status |
单板状态: · Standby表示该板是备用主控板 · Master表示该板是主用主控板 · Absent表示该槽位没有插入单板 · Fault表示该槽位单板出错,不能正常启动 · Normal表示该槽位单板是接口板并处于正常工作状态 · Off:表示该槽位的单板没有上电 · Illegal:表示当前软件版本不支持该单板,单板无法正常使用 · Offline:表示该槽位单板处于被隔离状态 · Mismatched:表示该子卡所在的单板类型或槽位不支持 |
Software Version |
软件版本信息 |
display device manuinfo命令用来显示设备的电子标签信息。
(独立运行模式)
display device manuinfo [ slot slot-number [ cpu cpu-number ] [ subslot subslot-number ] ]
display device manuinfo [ chassis chassis-number [ slot slot-number [ cpu cpu-number ] [ subslot subslot-number ] ] ]
chassis chassis-number:显示指定成员设备的电子标签信息。chassis-number表示设备在IRF中的成员编号。不输入该参数时,显示所有成员设备的相应信息。(IRF模式)
slot slot-number:显示指定单板的电子标签信息。slot-number表示单板所在的槽位号。不输入该参数时,显示所有单板的相应信息。
subslot subslot-number:显示指定子卡的电子标签信息。subslot-number表示子卡所在的子槽位号。不指定该参数时,不会显示子卡的信息。
cpu cpu-number:显示指定CPU的电子标签信息。cpu-number表示CPU的编号。只有指定的slot支持多CPU时,才能配置该参数。
电子标签信息也可以称为永久配置数据或档案信息等,在硬件的调测(调试、测试)过程中被写入到设备的存储器件中,包括硬件的名称、生产序列号、MAC地址、制造商等信息。
# 显示设备的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo
显示信息略……。
表1-12 display device manuinfo命令信息显示描述表
DEVICE_NAME |
设备名称 |
DEVICE_SERIAL_NUMBER |
设备序列号 |
MAC_ADDRESS |
设备出厂MAC地址 |
MANUFACTURING_DATE |
设备调测日期 |
VENDOR_NAME |
制造商名称 |
display device manuinfo chassis-only命令用来显示背板的电子标签信息。
(独立运行模式)
display device manuinfo chassis chassis-number chassis-only
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
# 显示机框背板的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo chassis-only
显示信息略……。
表1-13 display device manuinfo chassis-only命令信息显示描述表
DEVICE_NAME |
设备名称 |
设备序列号 |
MAC_ADDRESS |
设备出厂MAC地址 |
设备调测日期 |
VENDOR_NAME |
制造商名称 |
display device manuinfo fan命令用来显示风扇的电子标签信息。
(独立运行模式)
display device manuinfo fan fan-id
display device manuinfo chassis chassis-number fan fan-id
fan-id:表示设备上风扇的ID编号。
# 显示指定风扇的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo fan 1
Fan 1:
DEVICE_NAME : fan
DEVICE_SERIAL_NUMBER : 210235A36L1234567890
MAC_ADDRESS : NONE
MANUFACTURING_DATE : 2010-01-20
VENDOR_NAME : H3C
display device manuinfo power命令用来显示电源的电子标签信息。
(独立运行模式)
display device manuinfo power power-id
display device manuinfo chassis chassis-number power power-id
power-id:表示设备上电源的ID编号。
# 显示指定电源的电子标签信息。(独立运行模式)
<Sysname> display device manuinfo power 1
显示信息略……。
表1-14 display device manuinfo power命令信息显示描述表
DEVICE_NAME |
设备名称 |
设备序列号 |
MAC_ADDRESS |
设备出厂MAC地址 |
设备调测日期 |
VENDOR_NAME |
制造商名称 |
display diagnostic-information命令用来收集诊断信息。
display diagnostic-information [ hardware | infrastructure | l2 | l3 | service ] [ key-info | verbose ] [ filename ] [ background ]
background:在后台收集诊断信息。不指定该参数时,如果设备生成的诊断信息较多,则收集诊断信息会耗费较长时间,且在诊断信息收集期间,命令行输入界面会被占用,用户不能输入并执行其它命令行。指定该参数后,系统会在后台收集诊断信息,在此过程中,用户可在命令行输入界面输入并执行其它命令行。
hardware:收集硬件相关的诊断信息。
infrastructure:收集基础模块的诊断信息。
l2:收集二层特性相关诊断信息。
l3:收集三层特性相关诊断信息。
service:收集上层业务模块相关诊断信息。
key-info:收集关键诊断信息。当设备异常或者运行时间较长时,可能会产生较多诊断信息,此时,使用该关键字,即可以收集到关键的诊断信息,又可以缩短诊断信息的收集时间。不指定该参数时,收集当前全部诊断信息。
verbose:收集详细的诊断信息。
filename:表示将收集到的诊断信息保存到指定文件。filename表示文件的名称,后缀必须为“.tar.gz”。不指定该参数时,用户可根据提示信息选择将诊断信息保存到指定文件或者是直接显示诊断信息。
在日常维护或系统出现故障时,为了便于问题定位,用户需要查看各个模块的诊断信息。因为各个功能模块都有其对应的运行信息,所以一般情况下,用户需要逐条运行相应的display命令。为便于一次性收集更多信息,用户可以在任意视图下执行display diagnostic-information命令,收集多个模块的诊断信息。
使用该命令,用户可以直接显示指定的诊断信息或者将诊断信息直接保存到指定文件,因为诊断信息较多,系统会自动将该文件压缩后保存,文件名后缀为“.tar.gz”。如果要在设备上查看该文件的内容,请执行以下操作:
(1) 使用tar extract命令将文件XXXX.tar.gz解包成文件XXXX.gz。
(2) 使用gunzip命令将文件XXXX.gz解包成文件XXXX。
(3) 使用more命令查看文件XXXX的内容。
如果收集诊断文件过程半途中止,可能导致gunzip命令无法正常解压,但诊断文件中仍包括已经生成的诊断信息,可以导出到PC上使用Linux系统下的gunzip -c命令解压查看。
未指定hardware、infrastructure、l2、l3和service参数时,将收集设备产生的所有诊断信息。
不指定filename参数执行display diagnostic-information命令,当系统提示用户输入文件名时直接回车,设备会自动将当前诊断信息保存到一个新文件,并使用设备名称和当前系统时间为该文件命名,以免和现有文件重名,导致现有文件被覆盖。如果设备名称中包含“/”、“\”、“:”、“*”、“?”、“<”、“>”、“|”、“"”等特殊字符,在给诊断文件命名时,这些特殊字符会被转换为下划线“_”。比如设备的名称为A/B,设备会使用形如flash:/diag_A_B_20160101-000438.tar.gz的字符串为新生成的诊断文件命名。
该命令不支持“|”、“>”和“>>”参数。
执行本命令收集诊断信息时,请不要配置设备,以免影响收集结果。
# 收集系统当前各个功能模块运行的统计信息。
14:03:55 UTC Thu 01/05/2012
其他显示信息略……。
# 将收集到的诊断信息保存到缺省文件。
Save or display diagnostic information (Y=save, N=display)? [Y/N]:y
Please input the file name(*.tar.gz)[flash:/diag_Sysname_20160101-024601.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20160101-024601.tar.gz.
Please wait...
Save successfully.
请在“Please input the file name”提示信息处,直接回车。
# 将收集到的诊断信息保存到文件test.tar.gz。
<Sysname> display diagnostic-information test.tar.gz
Diagnostic information is outputting to flash:/test.tar.gz.
Please wait...
Save successfully.
# 后台收集诊断信息到缺省文件。
<Sysname> display diagnostic-information background
Please input the file name (*.tar.gz)[flash:/diag_Sysname_20201215-163501.tar.gz]:
Diagnostic information is outputting to flash:/diag_Sysname_20201215-163501.tar.gz in the background.
· gunzip(基础配置命令参考/文件系统管理)
· more(基础配置命令参考/文件系统管理)
· tar extract(基础配置命令参考/文件系统管理)
display environment命令用来显示设备上温度传感器的温度信息。
(独立运行模式)
display environment [ chassis chassis-number [ slot slot-number ] ]
chassis chassis-number:显示IRF中指定成员设备上温度传感器的温度信息。chassis-number表示设备在IRF中的成员编号。不指定该参数时,显示所有成员设备的对应信息。(IRF模式)
slot slot-number:显示设备中指定单板上的温度传感器的温度信息。slot-number表示单板所在的槽位号。不指定该参数时,显示所有单板的对应信息。
不指定slot参数时,显示的是设备上所有温度传感器的温度信息。(独立运行模式)
不指定chassis参数时,显示的是IRF中所有温度传感器的温度信息;指定chassis但不指定slot参数时,显示的是指定成员设备上所有温度传感器的温度信息。(IRF模式)
# 显示设备上所有温度传感器的温度信息。(独立运行模式)
<Sysname> display environment
System temperature information (degree centigrade):
Slot Sensor Temperature Lower Warning Alarm Shutdown
0 inflow 1 25 0 48 60 NA
0 hotspot 1 31 0 80 95 NA
2 inflow 1 29 0 80 97 NA
2 outflow 1 26 0 80 97 NA
2 hotspot 1 31 0 80 97 NA
2 hotspot 2 42 0 80 97 NA
3 inflow 1 31 0 80 97 NA
3 outflow 1 32 0 80 97 NA
3 hotspot 1 47 0 80 97 NA
3 hotspot 2 38 0 80 97 NA
4 hotspot 1 30 0 75 90 NA
6 hotspot 1 41 0 88 100 110
表1-15 display environment命令显示信息描述表
System Temperature information (degree centigrade) |
系统温度信息,单位为摄氏度 |
Slot |
槽位编号。当显示数字时表示指定slot上温度传感器的温度信息; |
sensor |
温度传感器 · hotspot:表示热点温度传感器 · inflow:表示入风口温度传感器 · outflow:表示出风口温度传感器 |
Temperature |
当前温度 |
Lower |
低温告警门限。当显示为NA时,表示不支持该门限 |
Warning |
一般级(Warning)高温告警门限。当显示为NA时,表示不支持该门限 |
Alarm |
严重级(Alarm)高温告警门限。当显示为NA时,表示不支持该门限 |
Shutdown |
关断级(Shutdown)高温告警门限,当温度传感器的温度大于该门限时,设备会自动关闭。当显示为NA时,表示不支持该门限 |
display fan命令用来显示风扇的工作状态。
(独立运行模式)
display fan [ fan-id ]
display fan [ chassis chassis-number [ fan-id ] ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定chassis参数时,表示所有风扇。(IRF模式)
fan-id:表示设备内置风扇的编号。不指定该参数时,表示指定位置的所有风扇。
# 显示设备上所有风扇的工作状态。
<Sysname> display fan
Fan Frame 0 State: Normal
表1-16 display fan命令显示信息描述表
Fan Frame |
风扇框的编号 |
State |
风扇状态: · Absent:风扇不在位 · Normal:风扇正常工作 · Fault:风扇故障 |
display fan-speed命令用来显示风扇的当前工作模式与转速。
(独立运行模式)
display fan-speed
display fan-speed [ chassis chassis-number ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定chassis参数时,表示显示所有风扇的当前工作模式与转速。(IRF模式)
# 显示设备上所有风扇的当前工作模式与转速。(独立运行模式)
<Sysname> display fan-speed
Current fan speed mode is auto
Frame 0 fan 1 speed is 2414 (R.P.M)
Frame 0 fan 2 speed is 2406 (R.P.M)
Frame 0 fan 3 speed is 3364 (R.P.M)
Frame 0 fan 4 speed is 3342 (R.P.M)
Frame 0 fan 5 speed is 3357 (R.P.M)
Frame 0 fan 6 speed is 3324 (R.P.M)
Frame 0 fan 7 speed is 3361 (R.P.M)
Frame 0 fan 8 speed is 3288 (R.P.M)
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息。
display hardware-failure-detection命令用来显示设备的硬件故障检测和修复信息,包括各种故障对应的修复操作,以及系统中每个单板最近十次故障修复的历史信息。
硬件故障检测和修复的历史信息保存在主用主控板上,即使某个槽位单板已拔出或者更换过,只要在主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(独立运行模式)
硬件故障检测和修复的历史信息保存在本地主用主控板上,即使某个槽位单板已拔出或者更换过,只要在本地主用主控板上已经保存,都可以通过display hardware-failure-detection命令显示出来。当本地主用主控板插拔或断电重启后,硬件故障检测和修复信息将会丢失。(IRF模式)
# 查看设备的硬件故障检测和故障修复信息。(独立运行模式)
<Sysname> display hardware-failure-detection
Current level:
chip : warning
board : warning
forwarding : warning
Recent record:
--------------------------Slot 0 executed records:-----------------------------
--------------------------Slot 0 trapped records:-----------------------------
表1-17 display hardware-failure-detection命令显示信息描述表
Current level |
当前故障检测对应的修复操作 |
chip : |
器件类故障对应的修复操作 |
board : |
单板类故障对应的修复操作 |
forwarding : |
转发类故障对应的修复操作 |
Recent record: |
最近记录 |
Slot n executed records: |
主控板n上记录的各个单板的历史操作记录(独立运行模式) |
Chassis n, Slot m executed records: |
成员设备n主控板m上记录的各个单板的历史操作记录(IRF模式) |
Slot n trapped records: |
主控板n上记录的各个单板的trap告警信息(独立运行模式) |
Chassis n, Slot m trapped records: |
成员设备n主控板m上记录的各个单板的trap告警信息(IRF模式) |
display hardware-failure-protection命令用来显示设备上硬件故障保护的配置信息。
display hardware-failure-protection [ aggregation | port { auto-down | interface-type interface-number } ]
aggregation:显示聚合组的硬件故障保护配置信息。
port:显示端口硬件故障保护的配置信息。
auto-down:显示已配置端口硬件故障保护的端口列表。
interface-type interface-number:显示指定端口上硬件故障保护的配置信息。
如果不带参数,则显示设备上所有硬件故障保护的配置信息,包括是否配置了针对聚合组的硬件故障保护和所有配置了端口硬件故障保护的端口列表。
# 显示设备上所有硬件故障保护的配置信息。
<Sysname> display hardware-failure-protection
Aggregation: on
Port: XGE3/1/1 XGE3/1/2
# 显示配置了端口硬件故障保护的端口列表。
<Sysname> display hardware-failure-protection port auto-down
# 显示端口XGE3/1/2是否配置了硬件故障保护。
<Sysname> display hardware-failure-protection port ten-gigabitethernet 3/1/2
Hardware failure protection is enabled on the interface. The system will shut down the interface when it detects a hardware failure on the interface.
表1-18 display hardware-failure-protection命令显示信息描述表
Aggregation |
显示是否配置了针对聚合组的硬件故障保护功能。取值为: · on:表示针对聚合组的硬件故障保护功能处于开启状态 · off:表示针对聚合组的硬件故障保护功能处于关闭状态 |
Port: |
显示配置了端口硬件故障保护的端口列表 |
Hardware failure protection is enabled on the interface. The system will shut down the interface when it detects a hardware failure on the interface. |
硬件故障保护功能处于开启状态,当系统检测到接口硬件故障时,会自动关闭该接口 |
Hardware failure protection is disabled on the interface. |
接口的硬件故障保护功能处于关闭状态 |
display health命令用来显示CPU和内存的使用情况。
(独立运行模式)
display health [ slot slot-number [ cpu cpu-number ] ]
display health [ chassis chassis-number [ slot slot-number [ cpu cpu-number ] ] ]
slot slot-number [ cpu cpu-number ]:显示指定单板上CPU和内存的使用情况。slot-number表示单板所在的槽位号,不指定slot参数时,显示所有单板上CPU和内存的使用情况。cpu-number表示CPU的槽位号,指定slot不指定cpu参数时,显示指定单板上CPU和内存的使用情况。(独立运行模式)
chassis chassis-number [ slot slot-number [ cpu cpu-number ] ]:显示指定单板上CPU和内存的使用情况。chassis-number表示设备在IRF中的成员编号,不指定该参数时,显示所有成员设备上CPU和内存的使用情况。slot-number表示单板所在的槽位号,指定chassis不指定slot参数时,显示指定成员设备上CPU和内存的使用情况。cpu-number表示CPU的槽位号,指定chassis和slot、不指定cpu参数时,显示指定单板上CPU和内存的使用情况。(IRF模式)
# 显示所有slot上CPU和内存的使用情况。(独立运行模式)
<Sysname> display health
Slot CPU Role CPU Usage(%) Memory Usage(%) Used/Total(MB)
1 0 MPU(Master) 7 23 1902504/8130012
2 0 LPU 9 48 963064/1991292
3 0 LPU 7 47 1913916/4052524
5 0 LPU 4 18 1538196/8158684
6 0 SFU 3 36 361296/984332
7 0 SFU 6 36 361348/984332
表1-19 display health命令显示信息描述表
Role |
成员设备在IRF中的角色,取值为: · MPU(Master)表示主用主控板(独立运行模式) · MPU(Standby)表示备用主控板(独立运行模式) · MPU(Master)表示全局主用主控板(IRF模式) · MPU(Standby)表示全局备用主控板(IRF模式) · LPU表示接口板 · BLADE表示Blade单板 |
CPU Usage(%) |
CPU利用率信息,表示系统在过去5秒内CPU利用率的平均值 |
Memory Usage(%) |
单板上当前的内存利用率 |
Used/Total(MB) |
单板上当前已使用的内存大小/单板上内存总大小,单位为MB |
display kernel memory alloc-failure命令用来显示内核内存申请失败信息。
(独立运行模式)
display kernel memory alloc-failure [ slot slot-number [ cpu cpu-number ] ]
display kernel memory alloc-failure [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定Master设备主用主控板。(IRF模式)
# 显示内核内存申请失败信息。
<System> display kernel memory alloc-failure
kmalloc_tag failures: 55.
kcalloc_tag failures: 0.
kzalloc_tag failures: 0.
krealloc_tag failures: 0.
kmem_cache_alloc_tag failures: 0.
表1-20 display kernel memory alloc-failure 命令显示信息描述表
kmalloc_tag failures |
调用kmalloc_tag申请内存失败的次数 |
kcalloc_tag failures |
调用kcalloc_tag申请内存失败的次数 |
kzalloc_tag failures |
调用kzalloc_tag申请内存失败的次数 |
krealloc_tag failures |
调用krealloc_tag申请内存失败的次数 |
kmem_cache_alloc_tag failures |
调用kmem_cache_alloc_tag申请内存失败的次数 |
display kernel memory fragment free命令用来显示内核空间空闲内存的统计信息。
(独立运行模式)
display kernel memory fragment free [ slot slot-number [ cpu cpu-number ] ]
display kernel memory fragment free [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
# 显示内核空间空闲内存的统计信息。
<Sysname> display kernel memory fragment free
Kernel memory free ratio: 0.13%
cfq_io_context memory free (in kbytes): 0
LFIB_NhlfeEntryCache26 memory free (in kbytes): 0
LFIB_NhlfeEntryCache74 memory free (in kbytes): 0
L2VFIB_TUNNELBMP_Cache memory free (in kbytes): 0
NAT_SESSION_EXT_INFO memory free (in kbytes): 0
ARP_VSISUP_Entry_cache memory free (in kbytes): 0
LFIB_NhlfeEntryCache1 memory free (in kbytes): 0
FVN_FwdCache19 memory free (in kbytes): 0
---- More ----
表1-21 display kernel memory fragment 命令显示信息描述表
Kernel memory free ratio |
内核空间空闲内存占内核空间总内存的比例 |
cfq_io_context memory free (in kbytes) |
Slab名为cfq_io_context的空闲内存大小,单位为千字节 |
display memory命令用来显示内存使用情况。
(独立运行模式)
display memory [ summary ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
summary:显示内存使用情况的简要信息。不指定该参数时,显示内存使用情况的详细信息。
slot slot-number:表示单板所在的槽位号,不指定时显示当前所有单板的内存使用情况。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示所有主控板。(IRF模式)
cpu cpu-number:表示CPU编号。
当显示信息中某一行所有参数的取值均显示为“--”时,可能原因为命令行从设备内部数据库获取数据失败,请稍候重试。
# 显示设备的内存使用情况的详细信息。(独立运行模式)
<Sysname> display memory
Memory statistics are measured in KB:
Slot 1:
Total Used Free Shared Buffers Cached FreeRatio
Mem: 984560 456128 528432 0 4 45616 53.7%
-/+ Buffers/Cache: 410508 574052
Swap: 0 0 0
LowMem: 739824 375552 364272 -- -- -- 49.2%
HighMem: 244736 80576 164160 -- -- -- 67.1%
# 显示设备的内存使用情况的简要信息。(独立运行模式)
<Sysname> display memory summary
Slot CPU Total Used Free Buffers Caches FreeRatio
1 0 984560 456128 528432 4 45616 53.7%
Low memory statistics are measured in KB:
1 0 739824 375552 364272 -- -- 49.2%
High memory statistics are measured in KB:
1 0 244736 80576 164160 -- -- 67.1%
表1-22 display memory命令显示信息描述表
Memory statistics are measured in KB: |
系统内存使用情况,以下统计信息均以KB为单位 |
Mem |
内存使用信息 |
Total |
系统可分配的物理内存的大小 设备总物理内存分为不可分配物理内存和可分配物理内存。其中,不可分配物理内存用于内核代码段存储、内核管理开销等;可分配物理内存用于支撑业务模块的运行、文件存储等操作。不可分配内存的大小由设备根据系统运行需要自动计算划分,可分配物理内存的大小等于设备总物理内存减去不可分配内存的大小 |
Used |
整个系统已用的物理内存大小 |
Free |
整个系统可用的物理内存大小 |
Shared |
多个进程共享的物理内存总额。取值为“--”时,表示不支持统计该参数的值 |
Buffers |
已使用的文件缓冲区的大小。取值为“--”时,表示不支持统计该参数的值 |
Cached |
高速缓冲寄存器已使用的内存大小。取值为“--”时,表示不支持统计该参数的值 |
Caches |
高速缓冲寄存器已使用的内存大小 |
FreeRatio |
整个系统物理内存的空闲率 |
-/+ buffers/cache |
-/+ Buffers/Cache:used = Mem:Used – Mem:Buffers – Mem:Cached,表示应用程序已用的物理内存大小 -/+ Buffers/Cache:free = Mem:Free + Mem:Buffers + Mem:Cached,表示应用程序可用的物理内存大小 |
Swap |
交换分区的使用信息 |
LowMem |
低端内存使用信息 |
HighMem |
高端内存使用信息 |
display memory dma命令用来显示DMA内存的使用情况。
(独立运行模式)
display memory dma [ slot slot-number [ cpu cpu-number ] ]
display memory dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
# 显示slot1的DMA内存使用相关信息。(独立运行模式)
<System> display memory dma slot 1
DMA memory statistics measured in KB on slot 1:
Total Used Free FreeRatio
16384 6140 10244 63%
表1-23 display memory dma 命令显示信息描述表
DMA memory statistics measured in KB |
系统使用DMA内存情况,单位为KB |
Total |
内存分片的总个数,为Free和Used之和 |
Used |
系统已使用的DMA内存大小 |
Free |
系统可使用的DMA内存大小 |
FreeRatio |
Free与Total的比率,可以反映系统DMA内存的空闲率 |
display memory-threshold命令用来显示内存告警门限相关信息。
(独立运行模式)
display memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
slot slot-number:表示单板所在的槽位号。不指定该参数时,表示主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,表示全局主用主控板。(IRF模式)
当设备已经使用的物理内存大小超过内存某个告警门限阈值时,系统会认为发生了一次该类型内存异常,并记录第一次、最近一次发生异常的时间,以及这段时间内发生的该类异常的次数。如果想了解该类异常的详细情况,请查看日志信息,可按日志摘要关键字“MEM_EXCEED_THRESHOLD”或“MEM_BELOW_THRESHOLD”进行搜索。
# 显示内存告警门限相关信息。
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
Minor: 64M
Severe: 48M
Critical: 32M
Normal: 96M
Current memory state: Normal
Event statistics:
[Back to normal state]
First notification: 2012-5-15 09:21:35.546
Latest notification: 2012-5-15 09:21:35.546
Total number of notifications sent: 1
[Enter minor low-memory state]
First notification at: 2012-5-15 09:07:05.941
Latest notification at: 2012-5-15 09:07:05.941
[Back to minor low-memory state]
First notification at: 0.0
Latest notification at: 0.0
Total number of notifications sent: 0
[Enter severe low-memory state]
[Back to severe low-memory state]
[Enter critical low-memory state]
表1-24 display memory-threshold命令显示信息描述表
Memory usage threshold |
内存利用率阈值 |
Free-memory thresholds Minor Severe Critical Normal Early-warning Secure |
剩余内存门限阈值: · Minor:一级告警门限,单位为MB。显示为--时,表示未获取到一级告警门限的取值 · Severe:二级告警门限,单位为MB。显示为--时,表示未获取到二级告警门限的取值 · Critical:三级告警门限,单位为MB。显示为--时,表示未获取到三级告警门限的取值 · Normal:恢复到正常状态的阈值,单位为MB。显示为--时,表示未获取到恢复到正常状态阈值的取值 · Early-warning:预警门限,单位为MB。显示为--时,表示未获取到预警门限的取值 · Secure:恢复预警门限状态的阈值,单位为MB。显示为--时,表示未获取到恢复预警门限状态阈值的取值 |
Current free-memory state |
系统当前内存使用状态: · Normal:正常状态 · Minor:一级告警门限状态 · Severe:二级告警门限状态 · Critical:三级告警门限状态 · Normal (early-warning):预告警状态 · Normal (secure):安全状态 |
Event statistics: |
门限事件统计信息,事件分为: · Back to normal state:内存恢复到正常状态 · Enter minor low-memory state:进入一级告警门限状态 · Back to minor low-memory state:恢复到一级告警门限状态 · Enter severe low-memory state:进入二级告警门限状态 · Back to severe low-memory state:恢复到二级告警门限状态 · Enter critical low-memory state:进入三级告警门限状态 |
First notification at |
事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification at |
事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notifications send |
事件发生的总次数 |
display memory-threshold dma命令用来显示DMA内存告警相关信息。
(独立运行模式)
display memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
display memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
# 显示DMA内存告警相关信息。
<Sysname> display memory-threshold dma
Free DMA memory thresholds:
Critical: 2048KB
Normal: 4096KB
Current DMA memory state: Normal
Free memory event statistics:
First notification: 0.0
Latest notification: 0.0
[Entered to critcal state]
表1-25 display memory-threshold dma 命令显示信息描述表
Free DMA memory thresholds: Critical: Normal: |
DMA内存告警阈值(单位为KB): · Critical:告警阈值 · Normal:告警恢复阈值 |
Current DMA memory state |
DMA内存的当前状态: · Critical:告警状态 · Normal:正常状态 |
Free memory event statistics: |
告警事件统计信息,事件分为: · Back to normal state:内存恢复到正常状态 · Entered to critcal state:进入告警状态 |
First notification |
告警事件第一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Latest notification |
告警事件最近一次发生的时间,格式yyyy-mm-dd hh:mm:ss.msec |
Total number of notifications sent |
告警事件发生的总次数 |
display non-stop-routing status命令用来显示所有支持NSR(Nonstop Routing,不间断路由)功能模块的NSR状态信息。
# 显示所有支持NSR功能模块的NSR状态信息。
<Sysname> display non-stop-routing status
NSR status: Not ready
Module name(instance name/process ID) Status
MSDP Not ready
OSPF(1) Ready
OSPF(2) Ready
BGP(default) Ready
BGP(aaa) Ready
PIM Not configured
表1-26 display non-stop-routing status命令显示信息描述表
NSR status |
系统的NSR状态: · Ready:系统的NSR处于稳定状态,即设备上所有使能NSR的模块的NSR状态均处于稳定状态 · Not ready:系统的NSR处于未稳定状态,即设备上有些模块的NSR状态处于未稳定状态 · Not configured:系统的NSR处于未使能状态,即设备上没有模块使能NSR · No standby:由于没有备用硬件,而导致设备无法实施NSR |
Module name(instance name/process ID) |
支持NSR功能的模块名称(实例名称/进程编号)。部分模块用instance name区分不同的实例,例如BGP (default);用process ID区分不同的进程,例如OSPF(1)。当模块无具体实例名称或进程时,仅显示模块名称,例如MSDP |
Status |
NSR的状态信息: · Ready:NSR处于稳定状态 · Not ready:NSR处于未稳定状态,此时不能进行进程倒换或者主备倒换 · Not configured:NSR处于未使能状态,此时不能进行进程倒换或者主备倒换 |
display power命令用来显示设备电源的信息。
(独立运行模式)
display power [ power-id ]
display power [ chassis chassis-number [ power-id ] ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示所有电源。(IRF模式)
power-id:表示电源模块的编号。不指定该参数时,表示指定位置的所有电源。
# 显示设备电源的状况。
Power 0 State: Normal
Power 1 State: Absent
Power 2 State: Absent
Power 3 State: Absent
· display power命令显示信息描述表
Power n State |
电源模块的状态: · Normal:表示该槽位电源模块处于正常工作状态 · Absent:表示该槽位没有插入电源模块 · Error:表示该槽位电源模块出错,不能正常运行 |
display power-off high-temp-board命令用来显示单板过温下电功能是否使能。
# 查询单板过温下电功能是否使能。
<Sysname> display power-off high-temp-board
Power off high temperature board mode: Enable
display power-information命令用来显示设备电源和单板的功率信息。
(独立运行模式)
display power-information [ verbose ]
display power-information [ chassis chassis-number ] [ verbose ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,表示显示所有设备电源和单板的功率信息。(IRF模式)
verbose:显示设备的详细信息。不指定该参数时,显示设备的简要信息。
# 显示设备电源及单板的功率信息。(独立运行模式)
<Sysname> display power-information
Power control mode: strict
Device power: 2500W
Surplus power: 1296W (contain 100W reserve power)
Fan power: 300W
Slot No. Power(W)
0 100 reserve for mainboard
1 100 reserve for mainboard
3 95
4 300
5 164
6 65
7 80
表1-27 display power-information命令显示信息描述表
Chassis n |
设备在IRF中的成员编号(IRF模式) |
Device Power |
设备的额定功率 |
Power control mode |
单板上电控制模式: · loose:宽松模式 · strict:严格模式 |
Surplus power |
设备的剩余功率 |
Fan Power |
风扇的最大功率 |
contain 100 reserve power |
保留100W电源功率 |
Slot No. |
单板的槽位号 |
Power(W) |
单板的最大功率 |
reserve for mainboard |
主控板的保留功率 |
Power No. |
电源的槽位号 |
Status |
电源的状态 |
Input(V) |
电源当前的输入电压 |
Output(V) |
电源当前的输出电压 |
Input(A) |
电源当前的输入电流 |
Output(A) |
电源当前的输出电流 |
Input(W) |
电源当前的输入功率 |
Output(W) |
电源当前的输出功率 |
Current input total power |
当前的电源输入总功率 |
Current output total power |
当前的电源输出总功率 |
display resource-monitor命令用来显示资源监控功能的相关信息。
(独立运行模式)
display resource-monitor [ resource resource-name ] [ slot slot-number [ cpu cpu-number ] ]
display resource-monitor [ resource resource-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
resource resource-name:需要监测的资源的名称。参数的取值请参见表1-45。
slot slot-number:显示指定单板的资源监控功能的相关信息。slot-number表示单板所在的槽位号。不指定该参数时,则表示所有单板。(独立运行模式)
chassis chassis-number slot slot-number:显示指定单板的资资源监控功能的相关信息。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。不指定该参数时,则表示IRF中的所有单板。(IRF模式)
cpu cpu-number:显示指定CPU的资源监控功能的相关信息。cpu-number表示需要检测的资源所在CPU的编号。
# 显示ARP资源监控的相关信息。(独立运行模式)
<Sysname> display resource-monitor resource arpnd
Minor alarms resending: Enabled
Slot 1:
Resource Minor Severe Free/Total
(percentage)
arpnd 50% 20% 99
表1-28 display resource-monitor命令显示信息描述表
Minor alarms resending |
周期发送低级别资源告警通知功能的开启状态: · Enabled:表示该功能已开启 · Disabled:表示该功能未开启 |
Resource |
监控资源的名称 |
Minor |
低级别告警门限,单位为百分比 |
Severe |
高级别门限,单位为百分比 |
Free/Total (percentage) |
剩余资源的数量/该资源的总数,用百分比形式表示 |
· resource-monitor minor resend enable
· resource-monitor resource
display scheduler job命令用来显示Job的配置信息。
job-name:Job的名称,为1~47个字符的字符串,区分大小写。不指定该参数时,则显示所有Job的配置信息。
# 查看所有Job的配置信息。
<Sysname> display scheduler job
Job name: saveconfig
copy startup.cfg backup.cfg
Job name: backupconfig
Job name: 123
以上显示信息表明,设备当前配置了3个Job,分别显示了Job的名称,以及为Job分配的命令(如果没有为Job分配命令,则只显示Job的名称),不同Job间用空行分隔。
display scheduler logfile命令用来显示Job的执行日志信息。
# 显示Schedule日志文件的相关信息。
<Sysname> display scheduler logfile
Logfile Size: 1902 Bytes.
Job name : shutdown
Schedule name : shutdown
Execution time : Tue Dec 27 10:44:42 2011
Completion time : Tue Dec 27 10:44:47 2011
<Sysname>system-view
[Sysname]interface rang ten-gigabitethernet 3/1/1 to ten-gigabitethernet 3/1/3
[Sysname-if-range]shutdown
表1-29 display scheduler logfile命令显示信息描述表
Logfile Size |
Schedule日志文件的大小,单位为字节 |
Job name |
Job的名称 |
Schedule name |
Schedule的名称 |
Execution time |
开始执行Job的时间 |
Completion time |
Job执行结束的时间(没有调度的或者没有分配命令的Job,均不会显示该信息) |
Job output |
Job中的命令执行时的输出信息 |
· reset scheduler logfile
display scheduler reboot命令用来显示定时重启功能的相关配置。
# 显示定时重启功能的相关配置。
<Sysname> display scheduler reboot
System will reboot at 16:32:00 05/23/2011 (in 1 hours and 39 minutes).
· scheduler reboot at
· scheduler reboot delay
display scheduler schedule命令用来显示Schedule的相关信息。
schedule-name:Schedule的名称,为1~47个字符的字符串,区分大小写。如果不指定该参数,则显示所有Schedule的信息。
# 显示所有Schedule的信息。
<Sysname> display scheduler schedule
Schedule type : Run once after 0 hours 2 minutes
Start time : Tue Dec 27 10:44:42 2011
Last execution time : Tue Dec 27 10:44:42 2011
Last completion time : Tue Dec 27 10:44:47 2011
Execution counts : 1
Job name Last execution status
shutdown Successful
表1-30 display scheduler schedule命令显示信息描述表
Schedule name |
Schedule的名称 |
Schedule type |
Schedule的执行时间配置。如果没有为Schedule配置执行时间,则不会显示该信息 |
Start time |
Schedule第一次开始执行的时间。如果没有为Schedule配置执行时间,则不会显示该信息 |
Last execution time |
Schedule上一开始执行的时间 · 如果没有为Schedule配置执行时间,则不会显示该信息 · 如果还没有执行,则显示Yet to be executed |
Last completion time |
Schedule上一次执行完成的时间。如果没有为Schedule配置执行时间,则不会显示该信息 |
Execution counts |
Schedule已经执行的次数。如果Schedule还没有执行,则不会显示该信息 |
Job name |
Schedule下关联的Job的名称 |
Last execution status |
Job上一次被执行的状态(Job下分配的命令是否执行以及执行结果,请通过display scheduler logfile命令查看) · Successful:表示执行成功 · Failed:表示执行失败 · Waiting:表示正在等待被执行 · In process:表示正在执行 · -NA-:表示还没有到执行时间 |
display system stable state命令用来显示系统的稳定状态。
display system stable state[ summary ]
summary:显示系统稳定状态的汇总信息,包括CPU的运行状态、主备状态、NSR的稳定状态。不指定该参数时,显示CPU的运行状态、主备状态,以及CPU运行状态的详细信息。
设备/单板启动需要一定的时间,才能达到Stable状态。如果设备/单板长时间未能进入Stable状态,可通过该命令的显示信息找出未稳定的设备/单板,根据其具体状态,采取进一步措施。
系统处于不稳定状态时,需要结合相关命令查看设备的具体情况。例如:
· 通过display device命令查看设备是否处于故障状态。
· 通过display ha service-group命令查看HA服务组的状态,以找出未批备完成的模块。
· 通过Probe视图下的display system internal process state命令查看服务启动状态。
操作时,建议多次执行命令,以确认稳定状态的连续性。
执行display system stable state命令时,会自动执行display ha service-group all命令。通过display ha service-group all命令获取的信息判断系统的稳定状态。有关display ha service-group all命令的详细介绍,请参见“可靠性命令参考”中的“进程分布优化”。
# 显示系统的稳定状态的汇总信息。
<Sysname> display system stable state summary
System state : Stable
Redundancy state : No redundancy
NSR state : No standby
# 显示CPU的运行状态、主备状态,以及CPU运行状态的详细信息。
Redundancy state : No redundance
Slot CPU Role State
0 0 Active Stable
2 0 Other Stable
3 0 Other Stable
表1-31 display system stable state命令显示信息描述表
System state |
所有CPU的运行状态的汇总,取值为: · Stable:稳定运行 · Not ready:未稳定 所有CPU的运行状态为Stable时,该字段将显示为Stable;只要有一个CPU的运行状态不是Stable,该字段将显示为Not ready |
Redundancy state |
主备状态: · Stable:主备状态稳定,可以倒换 · No redundance:系统无冗余,不能倒换 · Not ready:未稳定,不可以倒换 |
NSR state |
各模块NSR(Nonstop Routing,不间断路由)状态的汇总,取值为: · Ready:稳定状态,表示所有开启的NSR功能均能正常工作 · Not ready:未稳定状态,此时不能进行进程倒换或者主备倒换 · No standby:没有备用主控板 · Not configured:未开启NSR功能 |
Role |
Slot在系统中的身份: · Active:主用主控板 · Standby:备用主控板,提供冗余备份 · Other:业务板 |
State |
单板的运行状态: · Stable:单板稳定运行 · Board inserted:单板插入 · Kernel initiating:单板内核初始化 · Service starting:单板上的服务正在启动 · Service stopping:单板上的服务正在关闭 · HA Batch backup:HA批量备份中 · Interface data batch backup:正在进行接口管理数据批量备份 · Service module data batch backup:正在进行业务模块数据批量备份 |
当前对象处于未稳定状态 |
· display device
· display ha service-group(可靠性命令参考/进程分布优化)
display system-working-mode命令用来显示设备当前的工作模式。
# 显示设备当前的工作模式。
<Sysname> display system-working-mode
The current system working mode is standard.
The system working mode for next startup is standard.
· system-working-mode
display transceiver alarm命令用来显示可插拔接口模块的当前故障告警信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的当前故障告警信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
目前,使用的可插拔接口模块可能出现的故障告警信息见“display transceiver alarm命令输出信息描述表”。如果没有故障,则显示为None。
表1-32 SFP/SFP28/SFP+/GBIC/SFF的display transceiver alarm命令输出信息描述表
RX signal loss |
接收信号丢失 |
RX power high alarm |
接收光功率高告警 |
RX power high warning |
接收光功率高预警 |
RX power low alarm |
接收光功率低告警 |
RX power low warning |
接收光功率低预警 |
TX fault |
发送错误 |
TX bias high alarm |
偏置电流高告警 |
TX bias high warning |
偏置电流高预警 |
TX bias low alarm |
偏置电流低告警 |
TX power high warning |
发送光功率高预警 |
TX power high alarm |
发送光功率高告警 |
发送光功率高预警 |
TX power low alarm |
发送光功率低告警 |
TX power low warning |
发送光功率低预警 |
Temp high alarm |
温度高告警 |
Temp high warning |
温度高预警 |
Temp low alarm |
温度低告警 |
Temp low warning |
温度低预警 |
Voltage high alarm |
电压高告警 |
Voltage high warning |
电压高预警 |
Voltage low alarm |
电压低告警 |
Voltage low warning |
电压低预警 |
Transceiver info I/O error |
模块信息读写错误 |
Transceiver info checksum error |
模块信息校验和错误 |
Transceiver type and port configuration mismatch |
模块类型和端口配置不匹配 |
Transceiver type not supported by port hardware |
端口不支持该模块类型 |
RX CDR loss of lock |
接收侧CDR失锁,表示信号不好 |
TX CDR loss of lock |
发送侧CDR失锁,表示信号不好 |
表1-33 QSFP+/QSFP28的display transceiver alarm命令输出信息描述表
Temp high alarm |
温度高告警 |
Temp high warning |
温度高预警 |
Temp low alarm |
温度低告警 |
Temp low warning |
温度低预警 |
电压高告警 |
电压高预警 |
Voltage low alarm |
电压低告警 |
电压低预警 |
RX loss of signal(channel x) |
通道x接收到的信号丢失 |
TX fault(channel x) |
通道x发送报文时出错 |
TX loss of signal(channel x) |
通道x发送的信号丢失 |
RX power high(channel x) |
通道x接收到的光的功率太高 |
RX power low(channel x) |
通道x接收到的光的功率太低 |
TX power high alarm(channel x) |
通道x发送光功率高告警 |
TX power high warning(channel x) |
通道x发送光功率高预警 |
TX power low alarm(channel x) |
通道x发送光功率低告警 |
TX power low warning(channel x) |
通道x发送光功率低预警 |
TX bias high(channel x) |
通道x的偏置电流高 |
TX bias low(channel x) |
通道x的偏置电流低 |
模块读写错误 |
模块信息校验和错误 |
Transceiver type and port configuration mismatched |
模块类型和端口配置不匹配 |
Transceiver type not supported |
端口不支持该类型的模块 |
表1-34 CFP的display transceiver alarm命令输出信息描述表
TX jitter PLL unlocked |
发送Jitter PLL失锁 |
TX CMU unlocked |
发送CMU失锁 |
Overloaded |
负载过大 |
Loss of REFCLK input |
缺乏参考时钟 |
Channel signals out of alignment |
主机通道信号不对齐 |
PLD or flash initialization error |
初始化错误 |
Power supply fault |
电源错误 |
CFP checksum error |
校验和错误 |
TX bias high |
偏置电流高 |
TX bias low |
偏置电流低 |
Temp high |
温度高 |
Temp low |
温度低 |
Voltage high |
电压高 |
Voltage low |
电压低 |
RX signal loss in channel x |
通道x接收到的信号丢失 |
RX IC unlocked in channel x |
通道x接收到的IC时钟失锁 |
RX FIFO error in channel x |
通道x接收到FIFO错误 |
TX signal loss in channel x |
通道x发送的信号丢失 |
TX IC unlocked in channel x |
通道x发送的IC时钟失锁 |
TX FIFO error in channel x |
主机通道x的发送FIFO出错 |
主机通道x发送的IC时钟失锁 |
APD supply fault in channel x |
通道x出现APD错误 |
TEC fault in channel x |
通道x出现TEC错误 |
Wavelength unlocked in channel x |
通道x的光信号波长失锁 |
RX power high in lane x |
通道x接收到的光的功率太高 |
RX power low in lane x |
通道x接收到的光的功率太低 |
TX power high in lane x |
通道x发送的光的功率太高 |
TX power low in lane x |
通道x发送的光的功率太低 |
TX bias high in lane x |
通道x的偏置电流高 |
TX bias low in lane x |
通道x的偏置电流低 |
Temp high in lane x |
通道x的温度高 |
Temp low in lane x |
通道x的温度低 |
模块读写错误 |
模块信息校验和错误 |
模块类型和端口配置不匹配 |
端口不支持该类型的模块 |
表1-35 XFP的display transceiver alarm命令输出信息描述表
RX signal loss |
接收信号丢失 |
RX not ready |
接收状态未就绪 |
RX CDR时钟失锁 |
接收光功率高告警 |
接收光功率高预警 |
接收光功率低告警 |
接收光功率低预警 |
TX not ready |
发送状态未就绪 |
TX fault |
发送错误 |
TX CDR时钟失锁 |
偏置电流高告警 |
偏置电流高预警 |
TX bias low alarm |
偏置电流低告警 |
TX bias low warning |
偏置电流低预警 |
发送光功率高告警 |
发送光功率高预警 |
发送光功率低告警 |
发送光功率低预警 |
Module not ready |
模块状态未就绪 |
APD supply fault |
APD(Avalanche Photo Diode,雪崩光电二极管)错误 |
TEC fault |
TEC(Thermoelectric Cooler,热点冷却器)错误 |
Wavelength unlocked |
光信号波长失锁 |
Temp high alarm |
温度高告警 |
Temp high warning |
温度高预警 |
Temp low alarm |
温度低告警 |
Temp low warning |
温度低预警 |
Voltage high alarm(3.3V) |
电压高告警(3.3V) |
Voltage high warning(3.3V) |
电压高预警(3.3V) |
Voltage low alarm(3.3V) |
电压低告警(3.3V) |
Voltage low warning(3.3V) |
电压低预警(3.3V) |
Voltage high alarm(5.5V) |
电压高告警(5.5V) |
Voltage high warning(5.5V) |
电压高预警(5.5V) |
Voltage low alarm(5.5V) |
电压低告警(5.5V) |
Voltage low warning(5.5V) |
电压低预警(5.5V) |
Voltage high alarm(1.8V) |
电压高告警(1.8V) |
Voltage high warning(1.8V) |
电压高预警(1.8V) |
Voltage low alarm(1.8V) |
电压低告警(1.8V) |
Voltage low warning(1.8V) |
电压低预警(1.8V) |
Voltage high alarm(5.2V) |
电压高告警(5.2V) |
Voltage high warning(5.2V) |
电压高预警(5.2V) |
Voltage low alarm(5.2V) |
电压低告警(5.2V) |
Voltage low warning(5.2V) |
电压低预警(5.2V) |
模块信息读写错误 |
模块信息校验错误 |
模块类型和端口配置不匹配 |
端口不支持该模块类型 |
# 显示接口Ten-GigabitEthernet3/1/1上插入的可插拔接口模块的当前故障告警信息。
<Sysname> display transceiver alarm interface ten-gigabitethernet 3/1/1
Ten-GigabitEthernet3/1/1 transceiver current alarm information:
RX signal loss
RX power low
表1-36 display transceiver alarm显示信息描述表
transceiver current alarm information |
接口光模块当前故障告警信息 |
RX signal loss |
接收信号丢失 |
RX power low |
接收光功率低告警 |
display transceiver brief命令用来一键式显示设备所有可插拔接口模块的类型和收发功率等信息。
# 显示设备所有可插拔接口模块的类型和收发功率。
<Sysname> display transceiver brief
Interface TransceiverType WaveL(nm) Mode Rx(dBm) Tx(dBm) Status
Current/Range Current/Range
XGE3/1/1 10G-10km-QSFPDD 1310 SM -15.0/[-18.5,-3.0] -15.0/[-18.5,-3.0] Normal
XGE3/1/2 10G-10km-QSFPDD 1310 SM -15.0/[-18.5,-3.0] -29.0/[-18.5,-3.0] Beyond threshold
XGE3/1/3 10G-10km-QSFPDD 1310 SM NA/[-18.5,-3.0] NA/[-18.5,-3.0] Unknown
HGE4/0/4 100G-10km-QSFPDD 1310 SM -15.0/[-18.5,-3.0] -29.0/[-18.5,-3.0] Normal
表1-37 display transceiver brief命令显示信息描述表
接口简称 |
Type |
可插拔接口模块的类型,由速率、传输距离、类型拼接,"--"表示数据获取失败或者不支持 |
WaveL |
接口的波长,"--"表示数据获取失败或者不支持 |
Mode |
可插拔接口模块的模式,取值为: · MM:表示多模(Multimode) · SM:表示单模(Single Mode) · --:表示数据获取失败或者不支持 |
Rx(dBm) Current/Range |
当前输入功率/输入功率的正常范围,"--"表示数据获取失败或者不支持,"N/A"表示获取功率值无效 |
Tx(dBm) Current/Range |
当前输出功率/输出功率的正常范围,"--"表示数据获取失败或者不支持,"N/A"表示获取功率值无效 |
Status |
当前功率的状态。取值为: · Normal:表示功率处于正常范围 · Beyond threshold:表示功率超出正常范围 · Unknown:表示未知状态 · --:表示数据获取失败或者不支持 |
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的数字诊断参数的当前测量值。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口Ten-GigabitEthernet3/1/1上插入的可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface ten-gigabitethernet 3/1/1
Ten-GigabitEthernet3/1/1 transceiver diagnostic information:
Temp(°C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
36 3.31 6.13 -35.64 -5.19
Alarm thresholds:
Temp(°C) Voltage(V) Bias(mA) RX power(dBM) TX power(dBM)
High 50 3.55 1.44 -10.00 5.00
Low 30 3.01 1.01 -30.00 0.00
Warning thresholds:
High 45 3.25 1.25 -15.00 4.00
Low 25 2.85 0.85 -25.00 1.00
# 显示接口HundredGigE3/1/1上插入的QSFP28可插拔光模块的数字诊断参数的当前测量值。
<Sysname> display transceiver diagnosis interface hundredgige 3/1/1
HundredGigE3/1/1 transceiver diagnostic information:
[module] Temp.(°C) Voltage(V) Total RX power(dBm) Total TX power(dBm)
29 3.33 -33.61 8.41
[channel] Bias(mA) RX power(dBm) TX power(dBm)
1 0.00 -36.96 -36.96
2 0.00 -36.96 -36.96
3 0.00 -36.96 -36.96
4 0.00 -36.96 -36.96
Alarm thresholds:
Temp.(°C) Voltage(V) Bias(mA) RX power(dBm) TX power(dBm)
High 75 3.47 13.00 3.40 5.00
Low -5 3.13 3.00 -14.00 -10.00
Warning thresholds:
High 70 3.45 11.00 2.40 3.00
Low 0 3.15 5.00 -11.00 -8.00
Total average launch power(dBm): 5.90
表1-38 display transceiver diagnosis显示信息描述表
transceiver diagnostic information |
接口插入的光模块的数字诊断信息 |
Current diagnostic parameters |
当前的诊断参数 |
Temp.(°C) |
数字诊断参数——温度,单位为°C,精确到1°C |
Voltage(V) |
数字诊断参数——电压,单位为V,精确到0.01V |
Total RX power(dBm) |
数字诊断参数——总接收光功率,单位为dBm,精确到0.01dBm |
Total TX power(dBm) |
数字诊断参数——总发送光功率,单位为dBm,精确到0.01dBm |
Bias(mA) |
数字诊断参数——偏置电流,单位为mA,精确到0.01mA |
RX power(dBm) |
数字诊断参数——接收光功率,单位为dBm,精确到0.01dBm |
TX power(dBm) |
数字诊断参数——发送光功率,单位为dBm,精确到0.01dBm |
Alarm thresholds |
告警门限 |
High |
高告警门限或高预警门限 |
Low |
低告警门限或高预警门限 |
Warning threshold |
预警门限 |
Total average launch power(dBm) |
针对多通道光模块的各通道发射总功率,单位为mBM,精确到0.01dBm |
display transceiver interface命令用来显示可插拔接口模块的主要特征参数。
interface-type interface-number:显示接口上插入的可插拔接口模块的主要特征参数。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口Ten-GigabitEthernet3/1/1上插入的可插拔接口模块的主要特征参数。
<Sysname> display transceiver interface ten-gigabitethernet 3/1/1
Ten-GigabitEthernet3/1/1 transceiver information:
Transceiver Type : 1000_BASE_SX_SFP
Connector Type : LC
Wavelength(nm) : 850
Transfer Distance(m) : 550(50um),275(62.5um)
Digital Diagnostic Monitoring : YES
Vendor Name : H3C
表1-39 display transceiver interface命令显示信息描述表
transceiver information |
可插拔接口模块信息 |
Transceiver Type |
可插拔接口模块的物理型号 |
Connector Type |
可插拔接口模块的连接器类型,其中: · 光纤连接器包括SC(SC Connector,NTT公司推出的拔插锁紧式光纤连接器)、LC(LC Connector,Lucent公司推出的1.25mm/RJ45锁紧式光纤连接器)两种类型 · 其他连接器包括RJ-45、CX4等类型 |
Wavelength(nm) |
· 光模块:显示发送激光中心波长,单位nm;对于支持多条不同波长光路的模块(例如10GBASE-LX4模块),各个波长值之间用逗号分隔 · 电模块:显示为“N/A” |
Transfer Distance(xx) |
传输距离,xx为传输距离的单位,对于单模模块xx为km,对于其他模块xx为m。当模块支持多种传输介质时,各个传输距离值之间用逗号分隔。距离值后面括号里包含对应的“传输介质”。下面是各个介质的名称: · 9um:表示9/125um单模光纤 · 50um:表示50/125um OM2多模光纤 · 62.5um:表示62.5/125um OM1多模光纤 · CX4:表示CX4电缆 · OM3:表示50um OM3多模光纤 · OM4:表示50um OM4多模光纤 · OM5:表示50um OM5多模光纤 · STACK:表示堆叠线 · TP:表示双绞线 |
Digital Diagnostic Monitoring |
对数字诊断功能的支持情况,其中: · YES:表示支持数字诊断 · NO:表示不支持数字诊断 |
Vendor Name |
模块生产或定制厂商名称 |
display transceiver itu-channel命令用来显示光模块的ITU通道信息。
display transceiver itu-channel interface [ interface-type interface-number [ supported-channel ] ]
interface:显示接口上插入的光模块当前使用的ITU通道的信息。
interface-type interface-number:显示指定光模块当前使用的ITU通道的信息。interface-type interface-number表示接口类型和接口编号。不指定该参数时,表示所有接口上光模块当前使用的ITU通道的信息。
supported-channel:仅显示接口支持配置的ITU通道的信息。不指定该参数时,仅显示光模块当前使用的ITU通道的信息。
本命令仅HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A)、SFP-XG-LH80-Tunable和CFP2-200G-DCO-Tunable光模块支持。
# 显示Ten-GigabitEthernet3/1/1上插入的光模块当前使用的ITU通道的信息。
<Sysname> display transceiver itu-channel interface ten-gigabitethernet 3/1/1
Interface Channel WaveLength(nm) Frequency(THz)
XGE3/1/1 1 1566.72 191.35
# 显示Ten-GigabitEthernet3/1/1上插入的光模块支持配置的ITU通道的信息。
<Sysname> display transceiver itu-channel interface ten-gigabitethernet 3/1/1 supported-channel
ITU channel settings supported on Ten-GigabitEthernet3/1/1 :
1 1566.72 191.35
2 1566.31 191.40
3 1565.90 191.45
4 1565.50 191.50
5 1565.09 191.55
6 1564.68 191.60
7 1564.27 191.65
8 1563.86 191.70
其它显示信息略……。
表1-40 display transceiver itu-channel interface命令显示信息描述表
光模块所在接口的简称 |
Channel |
ITU通道编号 |
WaveLength(nm) |
通道编号对应的波长,单位为nm,精确到0.01nm。取值为“-”时,表示对应接口显示ITU通道信息失败,失败原因有: · 该接口上未插入光模块 · 该接口上光模块不支持配置ITU通道编号 · 光模块获取ITU通道信息失败 · 设备不支持光模块上当前存储的ITU通道编号 |
Frequency(THz) |
通道编号对应的频率,单位为THZ,精确到0.01THZ。取值为“-”时,表示对应接口显示ITU通道信息失败,失败原因有: · 该接口上未插入光模块 · 该接口上光模块不支持配置ITU通道编号 · 光模块获取ITU通道信息失败 · 设备不支持光模块上当前存储的ITU通道编号 |
· itu-channel
display transceiver manuinfo命令用于显示可插拔接口模块的电子标签信息。
interface [ interface-type interface-number ]:显示接口上插入的可插拔接口模块的部分电子标签信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
# 显示接口Ten-GigabitEthernet3/1/1上插入的可插拔接口模块的电子标签信息。
<Sysname> display transceiver manuinfo interface ten-gigabitethernet 3/1/1
Ten-GigabitEthernet3/1/1 transceiver manufacture information:
Manu. Serial Number : 213410A0000054000251
Manufacturing Date : 2012-09-01
Vendor Name : H3C
表1-41 display transceiver manuinfo命令显示信息描述表
Manu. Serial Number |
在生产过程中生成的序列号 |
Manufacturing Date |
写入电子标签的日期 |
Vendor Name |
厂商名称 |
display transceiver status命令用来显示可插拔光模块的状态信息。
display transceiver status interface [ interface-type interface-number ]
interface [ interface-type interface-number ]:显示接口上插入的可插拔光模块的状态信息。interface-type interface-number表示接口类型和接口编号,如果不指定该参数,表示所有接口。
当设备端口上的可插拔模块出异常时,可使用本命令查看光模块的状态信息,例如光模块是否发生过复位、光模块的功耗模式、光模块当前各通道的发光情况等。
仅可插拔SFP和QSFP系列光模块支持本命令。
# 显示接口HundredGigE3/1/1上插入的可插拔QSFP系列光模块的状态信息。
<Sysname> display transceiver status interface hundredgige 3/1/1
HundredGigE3/1/1 transceiver status information:
Initialization Complete Flag : Finish
Power Mode : High
Lane Tx Disable Tx CDR Rx CDR
Lane1 Yes ON OFF
Lane2 Yes ON OFF
Lane3 Yes ON OFF
Lane4 Yes ON OFF
表1-42 QSFP系列光模块display transceiver status命令显示信息描述表
interface-name transceiver status information |
接口interface-name上插入的可插拔QSFP光模块的状态信息 |
Initialization Complete Flag |
光模块是否完成初始化,取值为: · Finish:表示已完成初始化 · Unkown:表示未检测到初始化状态 |
Power Mode |
光模块当前处于的功耗模式,取值为: · High:表示模块当前处于高功耗模式 · Low:表示模块当前处于低功耗模式 |
Tx Disable |
是否允许光模块的光通道发送报文,取值为: · Yes:表示处于关闭状态 · No:表示处于开启状态 |
Tx CDR |
光模块发送侧时钟和数据恢复功能开启/关闭状态,取值为: · On:表示开启CDR功能 · Off:表示关闭CDR功能 |
Rx CDR |
光模块接收侧时钟和数据恢复功能开启/关闭状态,取值为: · On:表示开启CDR功能 · Off:表示关闭CDR功能 |
Lane |
光通道的编号 |
# 显示接口Ten-GigabitEthernet3/1/1上插入的可插拔SFP系列模块的状态信息。
<Sysname> display transceiver status interface ten-gigabitethernet 3/1/1
Ten-GigabitEthernet3/1/1 transceiver status information:
Hardware Tx Disable : YES
表1-43 SFP系列模块display transceiver status 命令显示信息描述表
接口interface-name上插入的可插拔SFP光模块的状态信息 |
Hardware Tx Disable |
通过硬件管脚设置是否允许光模块的光通道发送报文,取值为: · Yes:表示处于关闭状态 · No:表示处于开启状态 |
· reset transceiver interface
· transceiver cdr
· transceiver lane enable
· transceiver power-mode
display version命令用来显示系统版本信息。
display version
# 查看系统版本信息。
<Sysname> display version
……显示信息略……
display version-update-record命令用来显示启动软件包版本更新操作的记录。
设备启动时会记录当前使用的启动软件包版本信息,如果在运行过程中进行启动软件包版本更新操作,系统会记录该次更新的简要信息,包括升级时间和版本,以便管理员了解相关信息。设备重启这些记录也不会被删除。
# 显示设备启动软件包版本更新操作的记录。
<Sysname> display version-update-record
Record 1 (updated on Apr 18 2014 at 06:23:54):
*Name : boot-test.bin
Version : 7.1.053 Alpha 7153
Compile time: Mar 25 2014 15:52:43
*Name : system-test.bin
表1-44 display version-update-record命令显示信息描述表
Record n (updated on Apr 18 2014 at 06:23:54) |
最近的第n次更新的时间,Record 1为最新的一次更新 |
*Name |
软件包的名称。带*符号,表示软件包的版本和升级前的版本有变化;不带*符号,表示版本没有变化 |
Version |
软件包的版本号 |
Compile time |
版本编译时间 |
· reset version-update-record
fan-speed命令用来配置风扇的工作模式。
undo fan-speed命令用来恢复缺省情况。
(独立运行模式)
fan-speed { auto | high | middle | low }
undo fan-speed
fan-speed [ chassis chassis-number ] { auto | high | middle | low }
风扇的工作模式为auto。
chassis chassis-number:chassis-number表示设备在IRF中的成员编号。(IRF模式)
auto:表示风扇的工作模式为自动调速模式。该模式下,设备会根据单板温度进行自动调速,推荐使用该模式。
high:表示风扇的工作模式为高速模式。该模式下,风扇转速快,散热效果好,但是噪音比较大。
middle:表示风扇的工作模式为中速模式。该模式下,风扇转速较快,散热较好,噪声较轻。
low:表示风扇的工作模式为低速模式。该模式下,风扇转速较低,噪音较小,但是单板散热效果比较差。
# 配置风扇的工作模式为自动调速模式。(独立运行模式)
[Sysname] fan-speed auto
Fan speed changed successfully!
forward per-packet命令用来配置逐包负载分担转发模式。
undo forward per-packet命令配置逐流负载分担转发模式。
(独立运行模式)
forward per-packet [ slot slot-number ]
undo forward per-packet [ slot slot-number ]
forward per-packet [ chassis chassis-number slot slot-number ]
undo forward per-packet [ chassis chassis-number slot slot-number ]
逐流负载分担转发模式。
slot slot-number:表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:指定成员设备上指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
本功能仅在测试场景下使用。
配置逐包负载分担转发模式后,设备内报文从业务板转发到网板时,将报文按先后次序负载分担转发。
配置逐流负载分担转发模式后,设备内报文从业务板转发到网板时,将报文按一定的规则分成不同的流再负载分担转发。
切换负载分担转发模式可能会导致报文丢失,请在技术支持人员指导下使用。
# 配置逐包负载分担转发模式。
[Sysname] forward per-packet
forward-path-detection enable命令用来开启转发通道自动检测功能。
undo forward-path-detection enable命令用来关闭转发通道自动检测功能。
转发通道自动检测功能处于开启状态。
转发通道自动检测功能可以检测设备中的数据转发通道是否正常。如果不正常,会打印日志信息提醒用户。
# 开启转发通道自动检测功能。
[Sysname] forward-path-detection enable
hardware-failure-detection命令用来配置当系统检测到硬件故障时自动采取的修复操作。
undo hardware-failure-detection命令用来恢复缺省情况。
hardware-failure-detection { chip | forwarding } { isolate | off | reset | warning }
undo hardware-failure-detection { chip | forwarding }
当系统检测到器件(chip)的硬件故障时,修复操作为warning,当系统检测到转发(forwarding)的硬件故障时,修复操作为reset。
chip:对器件故障进行在线检测,包括单板上各种器件(比如芯片、电容、电阻等)的检测。
forwarding:对转发层面的故障进行在线检测,包括业务自动检测和其他转发相关的检测。
isolate:检测到故障时,设备会自动关闭端口、隔离单板、禁止单板加载或给单板下电,从而尽量减小故障的影响。
off:检测到故障时,设备不进行任何操作。
reset:检测到故障时,设备会自动重启器件/单板以尝试修复故障。
warning:检测到故障时,设备发送Trap信息,不会修复故障。
设备启动后,系统会持续自动检测器件、单板和转发的硬件故障。
# 配置系统检测到器件故障时自动告警。
[Sysname] hardware-failure-detection chip warning
hardware-failure-detection card-reboot enable命令用来开启系统检测到单板芯片硬件故障后自动重启单板功能。
undo hardware-failure-detection card-reboot enable命令用来关闭系统检测到单板芯片硬件故障后自动重启单板功能。
系统检测到单板芯片硬件故障后自动重启单板。
开启本功能后,当系统检测到单板芯片硬件故障后,将自动重启故障单板。
# 开启系统检测到单板芯片硬件故障后自动重启单板功能。
[Sysname] hardware-failure-detection card-reboot enable
hardware-failure-protection aggregation命令用来开启针对聚合组的硬件故障保护功能。
undo hardware-failure-protection aggregation命令用来关闭针对聚合组的硬件故障保护功能。
针对聚合组的硬件故障保护功能处于关闭状态。
只有配置hardware-failure-detection forwarding isolate命令后,该命令才生效。
配置该命令后,当系统检测到硬件故障时,会按顺序遵循如下原则处理:
· 如果聚合组成员端口配置undo hardware-failure-protection auto-down命令,而且该端口不是聚合组中最后一个UP状态的端口,则该端口会被自动关闭;
· 如果聚合组成员端口配置undo hardware-failure-protection auto-down命令,而该端口是聚合组中最后一个UP状态的端口,则该端口不会被关闭;
· 如果聚合组成员端口配置了hardware-failure-protection auto-down命令,则不管该端口是不是聚合组中最后一个UP状态的端口,该端口都会被关闭。
出现以下任意一种情况时,hardware-failure-protection aggregation命令会对聚合组中的该成员端口失效:
· 端口下配置了以太网接口环回测试功能,即loopback { external | internal }命令;
· 端口下配置了以太网接口的强制开启功能,即port up-mode命令;
· 该端口配置为IRF物理端口。
# 开启针对聚合组的硬件故障保护功能。
[Sysname] hardware-failure-protection aggregation
· hardware-failure-detection
· hardware-failure-protection auto-down
hardware-failure-protection auto-down命令用来开启针对端口的硬件故障保护功能。
undo hardware-failure-protection auto-down命令用来关闭针对端口的硬件故障保护功能。
针对端口的硬件故障保护功能处于开启状态。
以太网接口视图
在端口上配置该命令前,请确保该端口存在备份的链路,以免造成业务中断。
在端口上配置hardware-failure-protection auto-down命令后,当系统检测到硬件故障时,会自动关闭该端口。此时使用display interface命令可看到该端口状态为Protect DOWN。端口硬件故障解除后,请在接口下执行undo shutdown命令来恢复端口状态。
配置了hardware-failure-detection forwarding isolate后,本命令才会生效。
出现以下任意一种情况时,hardware-failure-protection auto-down命令会对该端口失效:
· 该端口配置为IRF物理端口。
# 对端口配置硬件故障保护。
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] hardware-failure-protection auto-down
header命令用来配置欢迎信息。
undo header命令用来取消配置的欢迎信息。
header { legal | login | motd | shell } text
undo header { legal | login | motd | shell }
未配置欢迎信息。
legal:配置登录终端界面前的授权信息,在输入认证用户名和密码前输出。
login:配置登录验证时的欢迎信息。
motd:配置登录终端界面前的欢迎信息。
shell:配置用户登录进入用户视图时的欢迎信息。
text:欢迎信息的内容。内容的输入支持单行和多行两种方式,具体输入规则请参见“基础配置指导”中的“设备管理”。
# 配置legal欢迎信息。
[Sysname] header legal
Welcome to use the legal banner%
isolate fabric-number命令用来配置系统可自动隔离网板的数量。
undo isolate fabric-number命令用来恢复缺省情况。
isolate fabric-number fabric-number
系统可自动隔离网板的数量为1。
fabric-number:系统可自动隔离网板的数量,取值范围为0~3。
配置隔离网板数目后,当系统自动检测出网板故障后去隔离网板。设备有4个网板时最多可以隔离2块网板,设备有5个网板时最多可以隔离3块网板,保证2块网板可正常工作。
当设备的网板数量小于等于2时,本功能将不生效。
[Sysname] isolate fabric-number 2
This command might cause packet loss. Continue? [Y/N]:
itu-channel命令用来配置光模块的ITU通道编号。
undo itu-channel命令用来恢复缺省情况。
itu-channel channel-number
undo itu-channel
光模块的ITU通道编号为1。
以太网接口视图
channel-number:表示光模块的ITU通道编号。
仅HPE X130 10G SFP+ LC LH80 tunable Transceiver (JL250A)、SFP-XG-LH80-Tunable和CFP2-200G-DCO-Tunable光模块支持本命令。
配置该命令后,设备会将ITU通道编号保存在光模块内部的寄存器中,不会保存到配置文件中。
# 将Ten-GigabitEthernet3/1/1上插入的光模块的ITU通道编号配置为2。
[Sysname-Ten-GigabitEthernet3/1/1] itu-channel 2
Changing the channel number causes the service to be down for a while. Continue? [Y/N]:Y
· display transceiver itu-channel
job命令用来为Schedule分配Job。
undo job命令用来将Job从Schedule中删除。
job job-name
undo job job-name
未为Schedule分配Job。
Schedule视图
多次执行该命令,可以为Schedule分配多个Job。多个Job在Schedule指定的时间同时执行,没有先后顺序。
分配的Job必须是设备上已经创建的Job,否则不能分配。Job可以通过scheduler job命令来创建。
# 为Schedule分配一个名称为save-job的Job。
[Sysname] scheduler schedule saveconfig
[Sysname-schedule-saveconfig] job save-job
· scheduler job
· scheduler schedule
memory-threshold命令用来配置空闲内存告警的门限值。
undo memory-threshold命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ]
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] minor minor-value severe severe-value critical critical-value normal normal-value [ early-warning early-warning-value secure secure-value ]
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
不同设备空闲内存告警的门限值可能不同,请先使用undo memory-threshold命令恢复缺省情况后,再通过display memory-threshold命令查看设备的缺省内存告警门限。
ratio:表示以百分比形式配置门限。不指定该参数时,表示配置的是门限的大小,单位为MB。
minor minor-value:一级告警门限,单位为兆字节(MB),minor-value应小于等于normal-value;为0则表示关闭该级门限告警功能。
severe severe-value:二级告警门限,单位为兆字节(MB),severe-value必须小于等于minor-value;为0则表示关闭该级门限告警功能。
critical critical-value:三级告警门限,单位为兆字节(MB),critical-value必须小于等于severe-value;为0则表示关闭该级门限告警功能。
normal normal-value:系统内存恢复正常状态时的内存大小,单位为兆字节(MB),normal-value必须小于等于实际内存大小。
early-warning early-warning-value:预告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。取值为0时,表示关闭该级别的告警功能。
secure secure-value:预告警恢复门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
系统实时监控剩余空闲内存大小,当条件达到时,就产生相应的告警/告警解除通知,以便通知关联的业务模块/进程采取相应的措施,以便最大限度的利用内存,又能保证设备的正常运行。
对于支持低端内存的slot,设备监控的是低端内存中剩余空闲内存的大小;对于不支持低端内存的slot,设备监控的是系统内存中剩余空闲内存的大小。执行display memory命令,如果显示信息中包含LowMem字段,则表示该slot支持低端内存。
关于告警门限的详细介绍请参见“基础配置指导”中的“设备管理”。
# 配置一级、二级、三级告警门限分别为64MB、48MB、32MB,当剩余空闲内存大于96MB时,恢复到正常状态。
[Sysname] memory-threshold minor 64 severe 48 critical 32 normal 96
· display memory-threshold
memory-threshold dma命令用来配置DMA(Direct Memory Access,直接内存存取)内存告警阈值。
undo memory-threshold dma命令用来恢复缺省情况。
(独立运行模式)
memory-threshold dma [ slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ slot slot-number [ cpu cpu-number ] ]
memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] [ ratio ] critical critical-value normal normal-value
undo memory-threshold dma [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
DMA内存告警阈值为2048KB,告警恢复阈值为4096KB。
cpu cpu-number:表示CPU的编号。
ratio:以百分比配置阈值。
critical critical-value:告警阈值。当指定ratio参数时,critical-value为百分比,取值范围为0~100;当不指定ratio参数时,critical-value单位为KB,取值范围为0~3145728。
normal normal-value:告警恢复阈值。当指定ratio参数时,normal-value为百分比;当不指定ratio参数时,normal-value单位为KB。取值范围为critical-value的配置值~3145728。
部分业务的运行需要使用DMA内存,如果DMA内存不足,会导致业务模块功能异常。系统周期监控DMA空闲内存大小:当DMA空闲内存小于或等于告警阈值,产生告警事件,表示DMA内存可能不足;当DMA空闲内存大于告警恢复阈值,产生告警解除事件,表示DMA内存充足。
# 配置Slot 1的DMA内存告警的阈值为32KB,告警恢复阈值为96KB。(独立运行模式)
[Sysname] memory-threshold dma slot 1 critical 32 normal 96
memory-threshold usage命令用来配置内存利用率阈值。
undo memory-threshold usage命令用来恢复缺省情况。
(独立运行模式)
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage memory-threshold
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage
内存利用率阈值为100%。
slot slot-number:表示单板所在的槽位号,不指定该参数时,表示主用主控板。(独立运行模式)
memory-threshold:内存利用率阈值百分比,取值范围为0~100。
系统每隔1分钟会对内存利用率进行采样,并将采样值和用户配置的内存利用率阈值比较。当采样值大时,则认为内存利用率过高,设备会发送Trap报文。
# 配置内存利用率阈值为80%。
[Sysname] memory-threshold usage 80
memory-threshold usage resend-interval命令用来配置内存利用率告警的重发间隔。
undo memory-threshold usage resend-interval命令用来恢复缺省情况。
(独立运行模式)
memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage resend-interval interval-value
undo memory-threshold [ slot slot-number [ cpu cpu-number ] ] usage resend-interval
memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage resend-interval interval-value
undo memory-threshold [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] usage resend-interval
内存利用率告警的重发间隔为300秒,即持续300秒超过内存利用率门限则发送一次告警。
interval-value:表示内存利用率告警发送间隔,取值范围为1~3600,单位为分钟。
设备定期对内存使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,进入告警状态并生成告警(日志和Trap)来提醒管理员。如果内存利用率告警的重发间隔到达,内存利用率仍处于告警状态,则再次输出告警。
# 配置slot 1 CPU 0内存利用率告警的重发间隔为1小时。(独立运行模式)
[Sysname] memory-threshold slot 1 cpu 0 usage resend-interval 60
monitor cpu-usage enable命令用来开启CPU利用率历史记录功能。
undo monitor cpu-usage enable命令用来关闭CPU利用率历史记录功能。
(独立运行模式)
undo monitor cpu-usage enable [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录功能处于开启状态。
slot slot-number:表示单板所在的槽位号,不指定表示主用主控板。(独立运行模式)
# 打开CPU利用率历史记录功能。
[Sysname] monitor cpu-usage enable
· display cpu-usage configuration
· display cpu-usage history
· monitor cpu-usage interval
monitor cpu-usage interval命令用来配置CPU利用率历史记录的采样周期。
undo monitor cpu-usage interval命令用来恢复缺省情况。
(独立运行模式)
undo monitor cpu-usage interval [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage interval interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率历史记录采样周期为1分钟。
interval:CPU利用率历史记录采用周期,取值为5Sec、1Min或者5Min,不区分大小写。输入该参数时,请完整输入,否则,系统会提示参数错误。
# 配置CPU利用率历史记录的采样周期为5秒。
[Sysname] monitor cpu-usage interval 5Sec
· monitor cpu-usage enable
monitor cpu-usage threshold命令用来配置CPU利用率告警门限。
undo monitor cpu-usage threshold命令用来恢复缺省情况。
(独立运行模式)
monitor cpu-usage threshold cpu-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] [ slot slot-number [ cpu cpu-number ] ]
monitor cpu-usage threshold cpu-threshold [ minor-threshold minor-threshold recovery-threshold recovery-threshold ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor cpu-usage threshold [ minor-threshold recovery-threshold ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
CPU利用率高级别告警门限为99%,CPU利用率低级别告警门限为79%,CPU利用率恢复门限为69%。
cpu-threshold:CPU利用率高级别告警门限,取值范围为2~100,单位为百分比。
minor-threshold minor-threshold:CPU利用率低级别告警门限,取值范围为1~“severe-threshold的配置值减1”,单位为百分比。不指定该参数时,该参数的取值为severe-threshold*0.8。
recovery-threshold recovery-threshold:CPU利用率恢复门限,取值范围为0~“minor-threshold的配置值减1”,单位为百分比。不指定该参数时,该参数的取值为severe-threshold*0.7。
系统每隔1分钟会对CPU的利用率进行采样,并将采样值和用户配置的CPU利用率告警门限比较。当采样值大时,则认为CPU利用率过高,设备会发送Trap报文。
当采样值回落,小于等于CPU利用率恢复门限时,则认为CPU利用率已经恢复到正常范围。
# 配置CPU利用率高级别告警门限为80%。
[Sysname] monitor cpu-usage threshold 80
monitor disk-usage disk命令用来配置磁盘利用率告警门限。
undo monitor disk-usage disk命令用来恢复缺省情况。
(独立运行模式)
monitor disk-usage [ slot slot-number [ cpu cpu-number ] ] disk disk-name threshold threshold-value
undo monitor disk-usage [ slot slot-number [ cpu cpu-number ] ] disk disk-name threshold
monitor disk-usage [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] disk disk-name threshold threshold-value
undo monitor disk-usage [ chassis chassis-number slot slot-number [ cpu cpu-number ] ] disk disk-name threshold
磁盘利用率告警门限为95%。
disk disk-name:表示磁盘的名称。输入该参数时,请完整输入,需要区分大小写,否则,系统会提示参数错误。
threshold threshold-value:表示磁盘利用率告警门限,为百分比数值,取值范围为1~100。
配置本命令后,系统会按照指定周期(可通过monitor disk-usage interval命令配置)对磁盘利用率进行采样,并将采样值和用户配置的告警门限比较。当采样值大时,则认为磁盘利用率过高,系统会将磁盘利用率过高事件通知给NETCONF模块。通过NETCONF功能,可以将这个信息反馈给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
# 配置磁盘利用率告警门限为80%。
[Sysname] monitor disk-usage disk flash threshold 80
· monitor disk-usage interval
monitor disk-usage interval命令用来配置磁盘利用率的采样周期。
undo monitor disk-usage interval命令用来恢复缺省情况。
monitor disk-usage interval interval
磁盘利用率的采样周期为300秒。
interval:磁盘利用率的采样周期,取值范围为5~1800,且必须为5的倍数,单位为秒。
配置本命令后,系统会按照指定周期对磁盘利用率进行采样。
# 配置磁盘利用率的采样周期为120秒。
[Sysname] monitor disk-usage interval 120
· monitor disk-usage disk
monitor kernel memory fragment interval命令用来配置内核空间的内存分片信息收集周期。
undo monitor kernel memory fragment interval命令用来恢复缺省情况。
(独立运行模式)
monitor kernel memory fragment interval interval-value [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment interval [ slot slot-number [ cpu cpu-number ] ]
monitor kernel memory fragment interval interval-value [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
内核空间的内存分片信息收集周期为5分钟。
interval-value:内核空间的内存分片信息收集周期,取值范围1~65535,单位为分钟。
配置本命令后,设备会按周期收集内核空间的内存分片信息,该信息可以通过命令display kernel memory fragment free、display kernel memory fragment used查看,用于判断内核空间的内存分片的空置率是否正常。
# 配置内核空间的内存分片信息收集周期为5分钟。
[Sysname] monitor kernel memory fragment interval 5
monitor kernel memory fragment ratio命令用来配置内核空间的内存分片空闲率告警阈值。
undo monitor kernel memory fragment ratio命令用来恢复缺省情况。
(独立运行模式)
monitor kernel memory fragment ratio ratio-value [ slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment ratio [ slot slot-number [ cpu cpu-number ] ]
monitor kernel memory fragment ratio ratio-value [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor kernel memory fragment ratio [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
内核空间的内存分片空闲率告警阈值为20%。
ratio-value:配置内核空间的内存分片空闲率告警阈值,取值范围为1~100。
内核线程运行时,会向系统申请内存,这块内存作为一个整体被申请和释放,就算部分内存块在线程运行过程中,已经被使用过且不再需要使用,也不能提前释放给系统使用,这种空闲但当前不能被使用的内存块也称为内存碎片。使用本命令可以监控内核空间内存碎片占内核空间总内存的比例。当内存碎片的比例大于或等于告警阈值时,表示内核内存的利用率较低,生成告警日志;当内存碎片的比例降低,小于告警阈值时,表示内核内存恢复到正式使用状态,生成告警恢复日志。
# 配置slot 1内核空间的内存空闲率告警阈值为80。(独立运行模式)
[Sysname] monitor kernel memory fragment ratio 80 slot 1
monitor resend cpu-usage命令用来配置发送CPU告警事件的间隔。
undo monitor resend cpu-usage命令用来取消CPU告警事件发送间隔的配置。
(独立运行模式)
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
monitor resend cpu-usage { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage [ minor-interval | severe-interval ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU高级别告警事件。
minor-interval minor-interval:CPU低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU使用率进行采样,并将采样值与告警门限进行比较。当采样值从小于或等于变成大于某级别告警门限时,CPU将进入该级别告警状态并生成相应的告警事件。
CPU处于低级别告警状态时,会周期发送CPU低级别告警事件,直到CPU进入高级别告警状态或者低级别告警状态解除。CPU处于高级别告警状态时,会周期发送CPU高级别告警事件,直到高级别告警状态解除。使用本命令可以修改CPU告警事件的发送周期。
执行undo monitor resend cpu-usage命令不指定minor-interval和severe-interval参数时,表示将这两个参数恢复到缺省情况。当指定某一个参数时,仅将该参数恢复到缺省值。
# 配置slot 1 CPU 0低级别告警事件的发送周期为60秒。(独立运行模式)
[Sysname] monitor resend cpu-usage minor-interval 60 slot 1 cpu 0
monitor resend cpu-usage core-interval命令用来配置发送CPU核告警事件的间隔。
undo monitor resend cpu-usage core-interval命令用来取消CPU核告警事件发送间隔的配置。
(独立运行模式)
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ slot slot-number [ cpu cpu-number ] ]
monitor resend cpu-usage core-interval { minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend cpu-usage core-interval [ minor-interval | severe-interval ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续300秒超过低级别告警门限则上报一次CPU核低级别告警事件,持续60秒超过高级别告警门限则上报一次CPU核高级别告警事件。
minor-interval minor-interval:CPU核低级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
severe-interval severe-interval:CPU核高级别告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对CPU核使用率进行统计,并将统计值与告警门限进行比较。当统计值从小于或等于变成大于告警门限时,CPU核将进入该告警状态并生成告警事件。
CPU核处于告警状态时,会周期发送CPU核告警事件,直到CPU核告警状态解除。使用本命令可以修改CPU核告警事件的发送周期。
# 配置设备上所有CPU核发送告警事件的间隔:低级别告警为100秒、高级别告警为60秒。
[Sysname] monitor resend cpu-usage core-interval minor-interval 100 severe-interval 60
monitor resend memory-threshold命令用来配置发送内存告警事件的间隔。
undo monitor resend memory-threshold命令用来取消内存告警事件发送间隔的配置。
(独立运行模式)
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ slot slot-number [ cpu cpu-number ] ]
monitor resend memory-threshold { critical-interval critical-interval | early-warning-interval early-warning-interval | minor-interval minor-interval | severe-interval severe-interval } * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold [ critical-interval | early-warning-interval | minor-interval | severe-interval ] * [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
持续1小时超过预告警门限则上报一次预告警事件,持续12小时超过一级告警门限则上报一次一级告警事件,持续3小时超过二级告警门限则上报一次二级告警事件,持续1小时超过三级告警门限则上报一次三级告警事件。
critical-interval critical-interval:内存三级告警事件周期发送的间隔,取值范围1~48,单位为小时。
early-warning-interval early-warning-interval:内存预告警事件周期发送的间隔,取值范围1~48,单位为小时。
minor-interval minor-interval:内存一级告警事件周期发送的间隔,取值范围1~48,单位为小时。
severe-interval severe-interval:内存二级告警事件周期发送的间隔,取值范围1~48,单位为小时。
设备定期对内存剩余值进行采样,并将采样值与告警门限进行比较。当采样值从大于变成小于或等于某级别告警门限时,内存将进入该级别告警状态并生成相应的告警事件。
内存支持多个级别的告警,这些告警的严重程度从高到低依次为:内存三级告警、内存二级告警、内存一级告警、内存预告警。
内存处于低级别告警状态时,会周期发送内存低级别告警事件,直到设备进入更高级别告警状态或者低级别告警状态解除。内存处于高级别告警状态时,会周期发送内存高级别告警事件,直到高级别告警状态解除。使用本命令可以修改内存告警事件的发送周期。
# 配置slot 1 CPU 0内存一级告警事件的发送周期为12小时。(独立运行模式)
[Sysname] monitor resend memory-threshold minor-interval 12 slot 1 cpu 0
monitor resend memory-threshold dma命令用来配置发送DMA内存告警事件的间隔。
undo monitor resend memory-threshold dma命令用来恢复缺省情况。
(独立运行模式)
monitor resend memory-threshold dma critical-interval critical-interval [ slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ slot slot-number [ cpu cpu-number ] ]
monitor resend memory-threshold dma critical-interval critical-interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
undo monitor resend memory-threshold dma critical-interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
DMA内存告警事件周期发送的间隔为300秒。
critical-interval:DMA内存告警事件周期发送的间隔,取值范围为10~3600,且只能是5的倍数,单位为秒。
设备定期对DMA内存使用率进行统计,并将统计值与告警门限进行比较。当统计值从小于或等于变成大于告警门限时,DMA内存将进入该告警状态并生成告警事件。
# 配置发送DMA内存告警事件的间隔为100秒。
[Sysname] monitor resend memory-threshold dma critical-interval 100
parity-error consistency-check log enable命令用来开启软硬件表项一致性检查日志信息功能。
undo parity-error consistency-check log enable命令用来关闭软硬件表项一致性检查日志信息功能。
软硬件表项一致性检查日志信息功能处于开启状态。
设备在运行过程中,会对转发芯片中的硬件表项和软件表项进行一致性检查。配置本命令后,在转发芯片扫描一次软硬件表项后,如果检查软硬件表项的不一致次数达到通过parity-error consistency-check threshold命令配置的错误次数阈值,则生成软硬件表项一致性检查日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启软硬件表项一致性检查日志信息功能。
[Sysname] parity-error consistency-check log enable
· parity-error consistency-check threshold
parity-error consistency-check threshold命令用来配置软硬件表项一致性检查的错误次数阈值。
undo parity-error consistency-check threshold命令用来恢复缺省情况。
parity-error consistency-check threshold value
软硬件表项一致性检查的错误次数阈值为10次。
value:表示软硬件表项一致性检查的错误次数阈值,取值范围为1~3600,单位为次数。
在开启软硬件表项一致性检查日志信息功能后,配置本命令后,设备在软硬件表项完整扫描一次后,当检查到软硬件表项不一致的错误次数达到配置的阈值时,会生成软硬件表项一致性检查日志信息。
# 配置软硬件表项一致性检查的错误次数阈值为20次。
[Sysname] parity-error consistency-check threshold 20
· parity-error consistency-check log enable
parity-error monitor log enable命令用来开启硬件表项奇偶校验和ECC校验日志信息功能。
undo parity-error monitor log enable命令用来关闭硬件表项奇偶校验和ECC校验日志信息功能。
硬件表项奇偶校验和ECC校验日志信息功能处于开启状态。
设备在运行过程中,会自动对转发芯片中硬件表项进行奇偶校验和ECC校验,并记录错误次数。配置本命令后,在通过parity-error monitor period命令配置的采样周期内,如果硬件表项的奇偶校验和ECC校验的错误次数达到通过parity-error monitor threshold命令配置的错误次数阈值,则生成硬件表项奇偶校验和ECC校验日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启硬件表项奇偶校验和ECC校验日志信息功能。
[Sysname] parity-error monitor log enable
· parity-error monitor period
· parity-error monitor threshold
parity-error monitor period命令用来配置硬件表项奇偶校验和ECC校验错误次数的采样周期。
undo parity-error monitor period命令用来恢复缺省情况。
parity-error monitor period period
硬件表项奇偶校验和ECC校验错误次数的采样周期为300秒。
period:表示硬件表项奇偶校验和ECC校验错误次数的采样周期,取值范围为1~86400,单位为秒。
在开启硬件表项奇偶校验和ECC校验日志信息功能后,配置本命令后,设备在配置的采样周期内,当硬件表项奇偶校验和ECC校验的错误次数达到阈值时,会生成硬件表项奇偶校验和ECC校验日志信息。
# 配置奇偶校验和ECC校验错误次数的采样周期为120秒。
[Sysname] parity-error monitor period 120
· parity-error monitor log enable
parity-error monitor threshold命令用来配置硬件表项奇偶校验和ECC校验的错误次数阈值。
undo parity-error monitor threshold命令用来恢复缺省情况。
parity-error monitor threshold value
硬件表项奇偶校验和ECC校验的错误次数阈值为50次。
value:表示硬件表项奇偶校验和ECC校验的错误次数阈值,取值范围为1~86400,单位为次数。
在开启硬件表项奇偶校验和ECC校验日志信息功能后,配置本命令后,设备在硬件表项奇偶校验和ECC校验错误次数的采样周期内,当校验错误次数达到配置的阈值时,会生成硬件表项奇偶校验和ECC校验日志信息。
# 配置硬件表项奇偶校验和ECC校验的错误次数阈值为8000次。
[Sysname] parity-error monitor threshold 8000
parity-error unrecoverable log enable命令用来开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
undo parity-error unrecoverable log enable命令用来关闭关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能处于开启状态。
设备在运行过程中,会对转发芯片中的硬件表项进行奇偶校验和ECC校验。在硬件表项奇偶校验和ECC校验发现错误时,会尝试恢复这些错误。配置本命令后,当一些关键硬件表项的校验错误不可恢复时,在通过parity-error unrecoverable period命令配置的采样周期内,如果关键硬件表项的校验错误不可恢复的次数达到通过parity-error unrecoverable threshold命令配置的不可恢复次数阈值,则会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息,并将该日志信息交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能。
[Sysname] parity-error unrecoverable log enable
· parity-error unrecoverable period
· parity-error unrecoverable reboot
· parity-error unrecoverable threshold
parity-error unrecoverable period命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期。
undo parity-error unrecoverable period命令用来恢复缺省情况。
parity-error unrecoverable period period
关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为60秒。
period:表示关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期,取值范围为1~86400,单位为秒。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在配置的采样周期内,当关键硬件表项奇偶校验和ECC校验错误的不可恢复次数达到阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期为120秒。
[Sysname] parity-error unrecoverable period 120
· parity-error unrecoverable log enable
parity-error unrecoverable reboot命令用来开启生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启功能。
undo parity-error unrecoverable reboot命令用来关闭生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备自动重启功能。
生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后设备不会自动重启。
如果设备转发芯片上关键硬件表项发生奇偶校验和ECC校验错误,且不可恢复时,可能会影响业务正常进行,则需要配置本命令,使设备通过重启来恢复关键硬件表项。
配置本命令后,当设备生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息后,将自动重启。
如果需要重启的单板是主控板,且设备只安装了单个主控板时,本命令不生效。
# 开启生成关键硬件表项不可恢复日志信息后设备的自动重启功能。
[Sysname] parity-error unrecoverable reboot
parity-error unrecoverable threshold命令用来配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值。
undo parity-error unrecoverable threshold命令用来恢复缺省情况。
parity-error unrecoverable threshold value
关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为1。
value:表示关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值,取值范围为1~86400,单位为次数。
在开启关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息功能后,配置本命令,设备在关键硬件表项奇偶校验和ECC校验错误不可恢复次数的采样周期内,当校验错误不可恢复次数达到配置的阈值时,会生成关键硬件表项奇偶校验和ECC校验错误不可恢复日志信息。
# 配置关键硬件表项奇偶校验和ECC校验错误不可恢复的次数阈值为10。
[Sysname] parity-error unrecoverable log threshold 10
password-recovery enable命令用来开启密码恢复功能。
undo password-recovery enable命令用来关闭密码恢复功能。
密码恢复功能处于开启状态。
清除认证密码的操作必须在主用主控板的启动过程中进入BootWare菜单进行。
BootWare菜单中支持配置的选项与密码恢复功能的配置有关,详见设备的版本说明书。
# 关闭密码恢复功能。
[Sysname] undo password-recovery enable
power control-mode命令用来设置单板上电控制模式。
undo power control-mode命令用来恢复缺省情况。
power control-mode { loose | strict }
单板上电控制模式为严格模式。
loose:设置单板上电控制模式为宽松模式。当有新的业务板或网板插入时,若风扇、主控板保留功率和所有的业务板和网板(包括新插入的)的最大功率之和不超过设备额定功率的1.2倍时,该业务板或网板可以正常上电。
strict:设置单板上电控制模式为严格模式。在此模式下,当有新的业务板或网板插入时,若风扇、主控板保留功率和所有的业务板和网板(包括新插入的)的最大功率之和超过设备额定功率,该业务板或网板无法上电。
# 设置单板上电控制模式为宽松模式。
[Sysname] power control-mode loose
power-off high-temp-board clear命令用来将过温下电的单板恢复上电。
(独立运行模式)
power-off high-temp-board clear chassis chassis-number
chassis chassis-number:表示设备在IRF中的成员编号。(IRF模式)
当单板上的热点传感器的温度超过shutdown阈值,系统会自动给单板下电。通过该命令行能够给因上述情况而下电的单板重新上电重启。
# 将过温下电的单板恢复上电。
[Sysname] power-off high-temp-board clear
power-off high-temp-board enable命令用来使能单板过温下电功能。
undo power-off high-temp-board enable
单板过温下电功能处于开启状态。
开启单板过温下电功能后,当单板上的热点传感器的温度超过shutdown阈值,系统会自动给该单板下电。
# 使能单板过温下电功能。
[Sysname] power-off high-temp-board enable
· display power-off high-temp-board
reboot命令用来重启设备。
(独立运行模式)
reboot [ slot slot-number [ cpu cpu-number | subslot subslot-number ] ] [ force ]
reboot [ chassis chassis-number [ slot slot-number [ cpu cpu-number | subslot subslot-number ] ] ] [ force ]
chassis chassis-number:表示设备在IRF中的成员编号。不指定该参数时,会重启整个IRF。(IRF模式)
slot slot-number:表示单板所在的槽位号。不指定该参数时,会重启成员设备。(IRF模式)
slot slot-number:表示单板所在的槽位号。不指定该参数时,会重启整个设备。(独立运行模式)
cpu cpu-number:CPU的编号。不指定该参数时,会重启slot。
subslot subslot-number:子卡所在的子槽位号。不指定该参数时,会重启slot。
force:强制重启:
· 不指定该参数时,重启设备,系统会做一些保护性检查(如启动文件是否存在,是否正在写磁盘等),若检查不通过则退出处理,不会重启设备;
· 指定该参数时,系统将不进行任何检查,直接执行重启操作。
· 重新启动可能会导致业务中断,请谨慎使用该命令。
· 使用force参数时,系统在重启时不会做任何保护性措施。重启后,可能导致文件系统损坏,请谨慎使用该参数。建议在系统故障或无法正常重启时,才使用该参数。
如果主用启动文件损坏或者不存在,则不能通过reboot命令重启设备。此时,可以通过指定新的主用启动文件再重启。
(独立运行模式)
重启主用主控板时,如果备用主控板不存在,会重启整个系统;如果备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响系统和单板的运行。可使用display system stable state命令来显示系统的稳定状态。
重启全局主用主控板时,如果全局备用主控板不存在,会重启整个IRF;如果全局备用主控板存在并稳定运行,会引起主备倒换。当系统中有单板处于非稳定状态时,请不要使用reboot命令来触发主备倒换,以免影响IRF和单板的运行。可使用display system stable state命令来显示IRF的稳定状态。
# 重启设备,并保存配置文件。(独立运行模式)
<Sysname> reboot
Current configuration will be lost after the reboot, save current configuration? [Y/N]:y
Configuration is saved to mainboard device successfully.
Now rebooting, please wait...
# 强制重启设备。
<Sysname> reboot force
A forced reboot might cause the storage medium to be corrupted. Continue? [Y/N]:y
· display system stable state
receive命令用来配置负载分担收包模式。
undo receive命令用来恢复缺省情况。
receive { per-flow { non-dip | non-sip } | per-packet }
undo receive
逐流负载分担收包模式。
per-flow:配置负载分担收包模式为逐流模式。即端口收到报文后,将报文分成不同的流上送CPU,同一条流的报文将在同一条链路上发送。
per-packet:配置负载分担收包模式为逐包模式。即端口收到报文后,将报文按收包次序均匀得负载分担到每条链路再上送CPU。
non-dip:配置逐流负载分担收包模式不受目的IP影响。
non-sip:配置逐流负载分担收包模式不受源IP影响。
本功能仅在测试场景下使用。
本命令仅IM-SFMX单板支持。
请在技术支持人员指导下使用本命令。
# 配置负载分担收包模式为逐包模式。
<Sysname> system
[Sysname] receive per-packet
reset alarm active命令用来清除设备当前仍未恢复的告警信息。
reset alarm active { all | sequence-number sequence-number }
未清除设备当前仍未恢复的告警信息。
all:清除设备当前仍未恢复的所有告警信息。
sequence-number sequence-number:清除指定序列号的未恢复的告警信息。sequence-number表示告警信息的序列号,取值范围为1~4294967295。
当系统中存在无法恢复的告警记录信息时,用户可使用该命令自主清除其告警记录信息。清除后,在显示告警信息时,系统不会再对用户展现这些告警信息。
# 清除序列号为1的未恢复告警信息。
[Sysname] reset alarm active sequence-number 1
· display alarm active
· display alarm history
reset scheduler logfile命令用来清除Schedule日志文件的相关信息。
# 清除Schedule日志文件的相关信息。
<Sysname> reset scheduler logfile
· display scheduler logfile
reset transceiver interface命令用来通过软件复位可插拔QSFP系列光模块。
reset transceiver interface [ interface-type interface-number ]
interface-type interface-number:表示接口类型和接口编号。不指定该参数时,表示所有接口。
当光模块工作异常时,可以通过软件复位光模块来尝试修复光模块。正常情况下,不建议配置。
执行本命令会重启光模块,请谨慎使用。
# 通过软件复位接口HundredGigE3/1/1上插入的可插拔QSFP系列光模块。
<Sysname> reset transceiver interface hundredgige 3/1/1
This operation causes services on the transceiver module to be down for a while. Continue? [Y/N]: Y
reset version-update-record命令用来清除启动软件包版本更新操作的记录。
# 清除设备启动软件包版本更新操作的记录。
[Sysname] reset version-update-record
This command will delete all records of version update. Continue? [Y/N]:y
· display version-update-record
resource-monitor minor resend enable命令用来开启周期发送低级别资源告警通知功能。
undo resource-monitor minor resend enable命令用来关闭周期发送低级别资源告警通知功能。
周期发送低级别资源告警通知功能处于开启状态。
如果剩余的资源小于或等于低级别告警门限且大于高级别告警门限,则资源进入低级别告警状态,并生成低级别告警通知。
当资源一直处于低级别告警状态时:
· 开启周期发送低级别资源告警通知功能后,第一次达到低级别告警状态时,会生成低级别告警通知,后续还会周期生成低级别告警通知。当剩余资源达到更高级别告警门限时,将会生成更高级别的告警通知,暂时抑制低级别的告警通知。直到高级别的告警状态解除,再周期输出低级别的告警通知。
· 关闭周期发送低级别资源告警通知功能后,只有第一次达到低级别告警状态时,才生成低级别告警通知,不会连续生成低级别告警通知。
高级别告警通知重发功能一直处于开启状态,不能通过命令行配置。
高级别告警通知的重发周期是24小时,低级别告警通知的重发周期是7x24小时,不能配置。
# 开启周期发送低级别资源告警通知功能。
<sysname> system-view
[Sysname] resource-monitor minor resend enable
· display resource-monitor
· resource-monitor output
resource-monitor output命令用来配置资源告警通知的输出方向。
undo resource-monitor output命令用来关闭资源告警通知的输出方向。
undo resource-monitor output [ netconf-event | snmp-notification | syslog ]*
资源告警通知会同时向NETCONF、SNMP和 信息中心三个方向输出。
netconf-event:将资源告警通知输出到NETCONF模块。
syslog:将资源告警通知输出到信息中心模块。
snmp-notification:将资源告警通知输出到SNMP模块。
设备会实时监控一些重要资源的是使用情况,当达到指定门限时,设备会生成对应的资源告警通知,这些通知可以输出到以下三个方向:
· NETCONF模块。通过配置NETCONF模块的参数,可以将资源告警通知以NETCONF事件的形式发送给用户。关于NETCONF的详细介绍请参见“网络管理和监控配置指导”中的“NETCONF”。
· 信息中心模块。通过配置信息中心模块的参数,可以将资源告警通知以系统日志的形式发送给用户。关于信息中心的详细介绍请参见“网络管理和监控配置指导”中的“信息中心”。
· SNMP模块。通过配置SNMP模块的参数,可以将资源告警通知以Trap或者Inform消息的形式发送给用户。关于SNMP的详细介绍请参见“网络管理和监控配置指导”中的“SNMP”。
执行undo resource-monitor output命令,并且不指定可选参数时,表示资源告警通知不会向NETCONF、SNMP和信息中心三个方向输出。
# 将资源告警通知输出到信息中心模块。
[Sysname] resource-monitor output syslog
resource-monitor resource命令用来配置生成资源告警通知的门限。
undo resource-monitor resource命令用来取消资源告警通知的门限配置。
(独立运行模式)
resource-monitor resource resource-name slot slot-number cpu cpu-number { by-absolute | by-percent } minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name slot slot-number cpu cpu-number
resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number { by-absolute | by-percent } minor-threshold minor-threshold severe-threshold severe-threshold
undo resource-monitor resource resource-name chassis chassis-number slot slot-number cpu cpu-number
不同类型资源的缺省情况不同,请使用display resource-monitor命令查看。
resource-name:需要监测的资源的名称,不区分大小写,需要完整输入参数的值。参数的取值请参见表1-45。不同单板上支持监测的资源不同,请以单板的实际情况为准。
取值 |
含义 |
acl_car |
CAR模板资源 |
acl_counter |
ACL计数器资源 |
arp |
ARP表项资源 |
arpnd |
ARP和ND表项资源 |
bfd_hardbfd_session |
硬件BFD会话数目 |
bpa_counter_in |
入方向BGP统计资源 |
bpa_counter_out |
出方向BGP统计资源 |
cfd_counterid_index |
CFD counterid索引资源 |
cfd_watchdog_index |
CFD watchdog索引资源 |
ecmp |
路由等价资源 |
efp_acl |
出方向ACL资源 |
eth_subif_statistic |
路由子接口统计计数器资源 |
flow_mirror |
流镜像资源 |
Ifp_acl |
入方向ACL资源 |
ipmc |
组播复制表项资源 |
ipv4_acl |
IPv4 ACL资源 |
ipv4_defip |
IPv4路由表项资源 |
ipv4fib |
IPv4 FIB硬件表项资源 |
ipv4mc |
IPv4组播转发表项资源 |
ipv6_acl |
IPv6 acl资源 |
ipv6_defip |
IPv6路由表项资源 |
ipv6_defip64 |
掩码长度为0~64位的IPv6路由表项资源 |
ipv6_defip128 |
掩码长度为65~128位的IPv6路由表项资源 |
ipv6_sr_list |
SRv6 list资源 |
ipv6fib |
IPv6 FIB硬件表项资源 |
ipv6mc |
IPv6组播转发表项资源 |
mac |
MAC地址表项资源 |
maptable_in |
入方向灵活优先级映射表资源 |
maptable_out |
出方向灵活优先级映射表资源 |
mpls_cbts |
CBTS统计资源 |
mpls_dynvpnid |
VXLAN 泛洪MAC资源 |
mpls_ecmplsp |
ECMP LSP等价资源 |
mpls_ilm |
ILM标签资源 |
mpls_inlabel |
入方向mpls标签资源 |
mpls_l3vpn |
L3VPN实例数目 |
mpls_label |
标签索引资源 |
mpls_lsp |
MPLS LSP统计资源 |
mpls_outlabel |
出方向MPLS标签资源 |
mpls_te |
MPLS TE隧道的配置数目 |
mpls_outlif |
MPLS outlif资源 |
mpls_vp |
MPLS VP资源 |
mpls_vpls_pw |
VPLS 实例PW数目 |
mpls_vpws |
VPWS配置数目 |
mpls_vsi |
VSI(Virtual Switch Instance,虚拟交换实例)数目 |
mpls_vxlan_tunnel |
VXLAN 隧道数目 |
mpls_vxlanvni |
VXLAN 专线统计资源 |
mtunnel |
组播隧道接口资源 |
mpls_tecar_profile |
MPLS TE隧道CAR限速的profile资源 |
mpls_tecar_tb |
MPLS TE隧道CAR限速的TB资源 |
nd |
ND表项资源 |
nexthop |
下一跳资源 |
nqa_client_1564 |
NQA 客户端1564会话数 |
nqa_client_2544 |
NQA 客户端2544会话数 |
nqa_client_twamplight |
NQA 客户端twamp会话数 |
nqa_reflector_remote |
NQA 服务器1564、2544会话数 |
nqa_reflector_twamplight |
NQA 服务器twamp会话数 |
nqa_veinlif |
NQA VEinlif资源 |
port_shape |
主接口整形资源 |
qinq_inlif_0 |
子接口QinQ Inlif表项资源,0表示转发芯片号 |
qinq_inlif_tree_0 |
子接口QinQ Inlif tree表项资源,0表示转发芯片号 |
qos_queue |
Qos八队列资源 |
queue_shape |
队列整形资源 |
queue_buffer |
队列缓存资源 |
rport |
协议端口表项资源 |
sampler |
采样器资源 |
share_policy_in |
入方向共享MQC资源 |
share_policy_out |
出方向共享MQC资源 |
subif_tb_in |
入方向子接口统计资源 |
subif_tb_out |
出方向子接口统计资源 |
subport_shape |
子接口整形资源 |
tunnel |
隧道接口资源 |
v4mcpro |
IPv4协议组播表项资源 |
v6mcpro |
IPv6协议组播表项资源 |
vfp_acl |
VLAN相关ACL资源 |
wfq_weight |
加权公平队列权重资源 |
wred_table |
WRED模板资源 |
bras_out |
出方向Bras用户计数资源 |
bras_in |
入方向Bras用户计数资源 |
bras_car |
Bras用户使用的CAR profile资源 |
slot slot-number:表示监测指定单板上的资源。slot-number表示单板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示监测指定单板上的资源。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。(IRF模式)
cpu cpu-number:表示监测指定CPU上的资源。cpu-number表示在CPU的编号。
by-absolute:以绝对值的方式配置告警门限。
by-percent:以百分比的方式配置告警门限。
minor-threshold minor-threshold:低级别告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
severe-threshold severe-threshold:高级别门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
配置本命令后,设备会监测资源的剩余情况,周期采样监测对象的值,并和配置的告警门限进行比较。当达到条件时,设备会生成告警通知。
# 配置slot 1上ARP资源的低级别门限为30%,高级别门限为10%。(独立运行模式)
[Sysname] resource-monitor resource arpnd slot 1 cpu 0 by-percent minor-threshold 30 severe-threshold 10
restore factory-default命令用来将设备恢复到出厂状态。
使用本命令会将设备恢复到出厂状态,请谨慎使用。
当设备使用场景更改,或者设备出现故障时,可以使用本命令来将设备恢复到出厂状态。
执行该命令后,需手工重启设备才能使该命令生效。
# 将设备恢复到出厂状态。
<Sysname> restore factory-default
This command will restore the system to the factory default configuration and clear the operation data. Continue [Y/N]:y
Restoring the factory default configuration. This process might take a few minutes. Please wait..........................................................................................................Done.
Please reboot the system to place the factory default configuration into effect.
· reboot
scheduler job命令用来创建Job,并进入Job视图。如果指定的Job已存在,则直接进入Job视图。
undo scheduler job命令用来删除已创建的Job。
scheduler job job-name
undo scheduler job job-name
不存在Job。
一个Job可以被多个Schedule引用。Job视图下用户可以通过command命令为Job分配命令。
# 创建名称为backupconfig的Job并进入Job视图。
[Sysname] scheduler job backupconfig
[Sysname-job-backupconfig]
· command
scheduler logfile size命令用来配置Schedule日志文件的大小。
scheduler logfile size value
Schedule日志文件的大小为16KB。
value:Schedule日志文件的大小,取值范围为16~1024,单位是KB。
Schedule日志文件用来记录Job下命令行的执行结果。如果该文件的大小超过了用户配置值,则系统会把老的记录删除,用来记录新的记录。如果要记录的日志信息超长,超过了日志文件的大小,则该日志超出的部分不会记录。
# 配置Schedule日志文件的大小为32KB。
[Sysname] scheduler logfile size 32
scheduler reboot at命令用来配置设备重启的具体时间和日期。
undo scheduler reboot命令用来取消定时重启配置。
未配置设备重启的具体时间和日期。
time:设备重启的时间,格式为HH:MM。HH代表小时,取值范围为0~23,MM代表分钟,取值范围为0~59。
date:设备重启的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
· YYYY的取值范围为2000~2035;
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
本命令会使设备在将来的某个时间点重新启动,从而导致业务中断,请谨慎使用。
如果没有指定date参数,并且:
· 配置的时间点在当前时间之后,则设备将在当天的该时间点重启;
· 配置的时间点在当前时间之前,则设备将在第二天的该时间点重启。
多次配置scheduler reboot at、scheduler reboot delay命令,最后一次执行的命令生效。
# 假设系统的当前时间为2011年6月6日11:43,配置设备在当天中午12:00重启。
<Sysname> scheduler reboot at 12:00
Reboot system at 12:00:00 06/06/2011 (in 0 hours and 16 minutes). Confirm? [Y/N]:
scheduler reboot delay命令用来配置重启设备的延迟时间。
scheduler reboot delay time
未配置重启设备的延迟时间。
time:设备重启的等待时延,格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,HH:MM的最大长度为6个字符。
· 使用MM格式时,最大长度为6个字符。
# 假设系统的当前时间为2011年6月6日11:48,配置设备在88分钟后重启。
<Sysname> scheduler reboot delay 88
Reboot system at 13:16 06/06/2011(in 1 hours and 28 minutes). Confirm? [Y/N]:
scheduler schedule命令用来创建Schedule,并进入相应的Schedule视图。如果指定的Schedule已存在,则直接进入Schedule视图。
undo scheduler schedule命令用来删除指定Schedule。
undo scheduler schedule schedule-name
不存在Schedule。
使用scheduler schedule命令可以配置定时执行任务,让设备在指定时间执行指定命令。
配置步骤如下:
(1) 使用scheduler job命令创建Job。
(2) 在Job视图下,使用command命令配置需要执行的命令。
(3) 使用scheduler schedule命令创建Schedule。
(4) 在Schedule视图下,使用job命令为Schedule分配Job。一个Schedule下可以分配多个Job,但必须是已创建的Job,否则分配失败。
(5) 在Schedule视图下,使用user-role命令为Schedule配置用户角色。一个Schedule下最多可以分配64个角色。
(6) 在Schedule视图下,使用time at、time once或者time repeating命令来配置任务执行的时间。一个Schedule下只能配置一个执行时间。
# 创建名为saveconfig的Schedule。
· job
· time at
· time once
seu-error unrecoverable reboot命令用来开启检测单板和接口子卡芯片发生不可修复的SEU错误后设备自动重启功能。
undo seu-error unrecoverable reboot命令用来关闭检测单板和接口子卡芯片发生不可修复的SEU错误后设备自动重启功能。
检测单板和接口子卡芯片发生不可修复的SEU错误后设备自动重启。
开启本功能后,当设备检测到单板和接口子卡芯片发生不可修复的SEU错误后,将自动重启。
仅以下单板支持本功能:CSPEX-1104-E、CSPC-GE24L-E、CSPC-GP24GE8XP2L-E、CSPC-GE16XP4L-E、CSPEX-1204。
# 开启检测单板和接口子卡芯片发生不可修复的SEU错误后设备自动重启功能。
[Sysname] seu-error unrecoverable reboot
shutdown-interval命令用来配置端口状态检测定时器的时长。
undo shutdown-interval命令用来恢复缺省情况。
shutdown-interval interval
端口状态检测定时器的时长为30秒。
interval:端口状态检测定时器的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动检测端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
某些协议模块在特定情况下会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。在协议自动关闭端口的同时,系统会启动一个检测端口状态的定时器。如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,系统自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
· 若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
· 若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置端口状态检测定时器的时长为100秒。
[Sysname] shutdown-interval 100
switch-fabric isolate命令用来将网板从转发平面隔离出去,所有数据流量都不经过指定网板。
undo switch-fabric isolate命令用来取消对网板的隔离。
(独立运行模式)
switch-fabric isolate slot slot-number
undo switch-fabric isolate slot slot-number
switch-fabric isolate chassis chassis-number slot slot-number
undo switch-fabric isolate chassis chassis-number slot slot-number
网板处于转发平面,数据流量会经过网板进行转发。
slot slot-number:表示网板所在的槽位号。(独立运行模式)
chassis chassis-number slot slot-number:表示指定成员设备上的指定网板。(IRF模式)
· 每块网板都有一定的转发带宽,隔离一块网板后会减少相应的转发带宽,使设备整体转发带宽降低。请根据需要配置。
· 当设备上仅存在一块网板时,请不要隔离该网板。
本命令不支持对主控板进行隔离。
该命令主要用于定位网板是否能够正常转发,以及更换网板前,为避免报文丢失,可配置本命令。网板隔离后仍能与主控板正常通信,控制平面上协议报文的解析与协议的计算等功能均不受影响,从而保证取消隔离后可以快速恢复网板的转发能力。
网板隔离期间不要重启设备。
网板隔离后,请使用undo switch-fabric isolate命令对该网板取消隔离,网板才能恢复正常转发功能。
# 将10号槽位的网板隔离。(独立运行模式)
[Sysname] switch-fabric isolate slot 10
The command will isolate the switch fabric or a channel from the system. Continu
e? [Y/N]y
switch-fabric removal-signal-report enable命令用来打开上报网板中断信号功能。
undo switch-fabric removal-signal-report enable命令用来恢复缺省情况。
上报网板中断信号功能处于关闭状态。
打开上报网板中断信号功能后,网板拔出前,会触发一次中断信号。系统收到中断信号后会将网板的业务迁移到其他网板上,以便网板拔出的时候,不影响当前业务。
# 打开上报网板中断信号功能。
[Sysname] switch-fabric removal-signal-report enable
sysname命令用来配置设备的名称。
undo sysname用来恢复缺省情况。
sysname sysname
undo sysname
设备名称是H3C。
sysname:设备名称,为1~64个字符的字符串。
设备的名称对应于命令行接口的提示符,如设备的名称为Sysname,则用户视图的提示符为<Sysname>。
# 配置设备的名称为R2000。
[Sysname] sysname R2000
system forword-mode extended命令用来配置系统的转发模式为扩展模式。
undo system forward-mode extended命令用来配置系统的转发模式为标准模式。
系统的转发模式为标准模式。
标准模式下,设备的系统运行处于较好的工作状态。
扩展模式下,设备系统可以记录转发模块的日志,仅维护设备时使用。
切换系统的转发模式后需要重启设备才能生效。
# 将设备系统的转发模式切换到扩展模式。
<Sysname> system
[Sysname] system forward-mode extended
Do you want to change the system forwarding mode? [Y/N]:y
System forwarding mode changed. For the change to take effect, save the running configuration and reboot the device.
system turbo enable命令用来开启系统性能优化功能。
undo system turbo enable命令用来关闭系统性能优化功能。
system turbo enable
本功能仅在测试场景下使用。
本功能请在技术支持人员指导下使用。
# 将开启或关闭系统性能优化功能。
<Sysname> system
[Sysname] system turbo enable
system-working-mode命令用来配置设备的工作模式。
undo system-working-mode命令用来恢复缺省情况。
system-working-mode { sdn-wan | standard }
设备工作在标准模式。
sdn-wan:将设备的工作模式配置为广域网SDN模式。
standard:将设备的工作模式配置为标准模式。
不同模式下设备支持的特性不同,或者相同的特性支持的规格不同,请根据实际需要配置。
要使修改的工作模式生效,必须重启设备。
# 将设备工作模式配置为广域网SDN模式。
[Sysname] system-working-mode sdn-wan
Do you want to change the system working mode? [Y/N]:y
System working mode changed. For the change to take effect, save the running configuration and reboot the device.
· display system-working-mode
subslot-working-mode命令用来切换子卡槽位的工作模式。
undo subslot-working-mode命令用来恢复缺省情况。
(独立运行模式)
subslot-working-mode slot slot-number subslot subslot-number { ethernet | ethernet-flexe }
undo subslot-working-mode slot slot-number subslot subslot-number [ ethernet | ethernet-flexe ]
subslot-working-mode chassis chassis-number slot slot-number subslot subslot-number { ethernet | ethernet-flexe }
undo subslot-working-mode chassis chassis-number slot slot-number subslot subslot-number [ ethernet | ethernet-flexe ]
工作模式为ethernet模式。
chassis chassis-number slot slot-number:表示指定成员设备上的指定单板。(IRF模式)
subslot subslot-number:表示子卡所在的子卡槽位号。
ethernet:将当前接口子卡槽位的工作模式切换ethernet模式。该模式下,子卡槽位插入的子卡接口仅支持标准以太模式,不支持灵活以太模式。
ethernet-flexe:将当前接口子卡槽位的工作模式切换ethernet-flexe模式。该模式下,子卡槽位插入的子卡接口支持标准以太模式与灵活以太模式切换。
本命令仅对以下子卡生效:RX-NIC-LGQ4L。
当配置的槽位插入的子卡不支持本命令时,会自动删除此配置或无法配置。
关于标准以太模式与灵活以太模式切换功能的详细介绍,请参见“接口管理”中的“FlexE接口”。
执行本命令后,注意以下几点:
· 对应槽位的子卡会自动重启,以配置的子卡槽位工作模式启动。
· 会删除当前子卡槽位的工作模式下,对应槽位的子卡接口不支持的配置。
# 设置2号子卡槽位的工作模式为ethernet-flexe工作模式。
<Sysname> system
[Sysname] subslot-working-mode slot 3 sublot 2 ethernet-flexe
Change of the subslot working mode will reboot the subcard. Continue? [Y/N]:
temperature-limit命令用于配置设备的温度告警门限。
undo temperature-limit命令用来恢复缺省情况。
(独立运行模式)
temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit slot slot-number { hotspot | inflow | outflow } sensor-number
temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number lowlimit warninglimit [ alarmlimit ]
undo temperature-limit chassis chassis-number slot slot-number { hotspot | inflow | outflow } sensor-number
不同温度传感器的温度门限可能不同,请先使用undo temperature-limit命令恢复缺省情况后,再通过display environment命令查看设备的缺省温度告警门限。
slot slot-number:配置指定单板上温度传感器的温度门限。slot-number表示单板所在的槽位号。
hotspot:配置热点传感器的温度门限。热点传感器一般置于发热量较大的芯片附近,监测芯片温度。
inflow:配置入风传感器的温度门限。入风传感器一般置于入风口附近,监测环境温度。
outflow:配置出风传感器的温度门限。出风传感器一般置于出风口附近,监测设备温度。
sensor-number:温度传感器的编号,输入该参数的值时可通过输入?,来获取该参数的取值范围。
lowlimit:低温告警门限,单位为摄氏度。不同温度传感器的低温告警门限取值范围不同,输入该参数的值时可通过输入?,来获取该参数的取值范围。
warninglimit:一般级高温告警门限,单位为摄氏度,必须大于低温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
alarmlimit:严重级高温告警门限,单位为摄氏度,必须大于一般级高温告警门限。输入该参数的值时可通过输入?,来获取该参数的取值范围。
如果温度低于低温告警门限、高于一般级或严重级高温门限,系统均会生成相应的日志信息和告警信息提示用户,并通过设备面板上的指示灯来告警,以便用户及时进行处理。
# 配置指定slot上热点1号温度传感器,低温门限为-10摄氏度,一般级高温门限为50摄氏度,严重级高温门限为60摄氏度。(独立运行模式)
[sysname] temperature-limit slot 1 hotspot 1 -10 50 60
· display environment
time at命令用来配置在指定时刻执行Schedule。
undo time命令用来为Schedule取消执行时间配置。
time at time date
undo time
未为Schedule配置执行时间。
Schedule视图
time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
date:Schedule执行的日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
配置的时间点必须晚于系统当前时间点,否则配置失败。
一个Schedule只能配置一个执行时间。因此,同一Schedule视图下,多次执行time at、time once或time repeating命令时,最后一次执行的命令生效。
# 配置2011年5月11日1点1分执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time at 1:1 2011/05/11
time once命令用来为Schedule配置执行时间。
time once delay time
undo time
未为Schedule配置执行时间。
Schedule视图
at time:Schedule的执行时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。
month-date month-day:Schedule在一个月中的哪天被执行。month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。
week-day week-day&<1-7>:Schedule在一周中的哪(些)天被执行。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
delay time:指定Schedule延迟执行的时间。格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,HH:MM最大长度为6个字符。
配置该命令后,Schedule在该设定时间点到达时执行,若当天/本月/本周该时间点已过去,则顺延到第二天/下月/下周。执行后下次再到达该时间点时Schedule不再执行。
# 当天的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00
# 最近到达的15号的15点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 15:00 month-date 15
# 最近一个周一和周五的12点整执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once at 12:00 week-day mon fri
# 延迟10分钟执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time once delay 10
time repeating命令用来配置重复执行Schedule的时间。
time repeating [ at time [ date ] ] interval interval
undo time
未配置重复执行Schedule的时间。
Schedule视图
at time:表示重复执行的时间,格式为HH:MM(小时:分钟)。HH取值范围为0~23,MM取值范围为0~59。不指定该参数时,表示从现在开始。
date:指定Schedule重复执行的开始日期,格式为MM/DD/YYYY(月/日/年)或者YYYY/MM/DD(年/月/日)。不指定该参数时,表示将来第一次到达time的时间点的日期。
· MM的取值范围为1~12;
· DD的取值范围与具体月份有关。
interval interval:指定重复执行的时间间隔。格式为HH:MM(小时:分钟)或MM(分钟)。
· 使用HH:MM格式时,MM的取值范围为0~59,最大长度为6个字符。
· 使用MM格式时,取值的最小值为1,最大长度为6个字符。
month-date [ month-day | last ]:表示每月中的某一天。其中,month-day表示日期,取值范围为1~31。如果指定了一个本月不存在的日期,则实际生效的时间为下一个月的该日期,比如,二月没有30号,则实际生效的时间为三月的30号。last表示每月的最后一天。
week-day week-day&<1-7>:表示每周中的某(些)天。week-day&<1-7>表示一周中任一天或几天的组合,week-day取值为:Mon、Tue、Wed、Thu、Fri、Sat、Sun,&<1-7>表示前面的参数最多可以输入7次。配置多天时,字符串之间用空格分开。
time repeating [ at time [ date ] ] interval interval表示从指定时间开始,周期性执行Schedule。
time repeating at time [ month-date [ month-day | last ] | week-day week-day&<1-7> ]表示每月/每周的某(些)天重复执行Schedule。
# 配置从早上八点开始,每隔1小时执行一次名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 interval 60
# 配置从现在开始每天的12:00执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 12:00
# 配置从现在开始每个月5号的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date 5
# 配置从现在开始每个月的最后一天8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 month-date last
# 配置从现在开始每个周五和周六的上午8点执行名称为saveconfig的Schedule。
[Sysname-schedule-saveconfig] time repeating at 8:00 week-day fri sat
transceiver lane cdr命令用来配置可插拔QSFP系列光模块发送通道和接收通道的时钟和数据恢复功能。
undo transceiver lane cdr命令用来恢复缺省情况。
transceiver lane [ lane-number ] cdr { tx | rx } { on | off }
undo transceiver lane [ lane-number ] cdr { tx | rx }
光模块发送通道和接收通道的时钟和数据恢复功能处于开启状态。
以太网接口视图
lane-number:表示光通道的编号。取值范围为1~4,不指定该参数时,表示所有光通道。
tx:光模块的发送链路。
rx:光模块的接收链路。
on:开启光模块链路的时钟和数据恢复功能。
Off:关闭光模块链路的时钟和数据恢复功能。
使用本命令配置光模块时钟和数据恢复功能,减少信号抖动,会提高光模块传输性能;关闭光模块时钟和数据恢复功能会降低其传输性能。无论开启还是关闭操作,都可能引起设备端口状态震荡。
本命令的配置会保存在光模块内部的寄存器中,不会保存到配置文件中。
仅可插拔QSFP系列光模块支持本命令。
# 开启接口HundredGigE3/1/1上插入的可插拔QSFP系列光模块的Tx CDR功能。
[Sysname] interface hundredgige 3/1/1
[Sysname-HundredGigE3/1/1] transceiver lane cdr tx on
This command will engage the internal retiming function of transceiver Tx route. Continue? [Y/N]:Y
# 关闭接口HundredGigE3/1/1上插入的可插拔QSFP系列光模块的Rx CDR功能。
[Sysname-HundredGigE3/1/1] transceiver lane cdr rx off
This command will enable an internal bypassing mode of transceiver Rx route, which directs traffic around the internal CDR. Continue? [Y/N]:Y
· display transceiver status
transceiver lane enable命令用来开启可插拔SFP和QSFP系列光模块的光通道。
undo transceiver lane命令用来关闭可插拔SFP和QSFP系列光模块的光通道。
transceiver lane [ lane-number ] enable
undo transceiver lane [ lane-number ] enable
光模块的光通道处于开启状态。
以太网接口视图
lane-number:表示光通道的编号,对于SFP系列模块,取值为1;对于QSFP系列模块,取值范围为1~4,不指定该参数时,表示所有光通道。
本命令主要用于调测光模块的功能是否正常,正常情况下,不建议配置。
关闭光通道将导致光模块不能传输信号。
关闭某个光通道将导致该光通道所属的光接口不能传输信号。
# 开启HundredGigE3/1/1上插入的QSFP系列光模块的通道1。
[Sysname-HundredGigE3/1/1] transceiver lane 1 enable
transceiver power-mode命令用来配置可插拔QSFP系列光模块的功耗模式。
undo transceiver power-mode命令用来恢复缺省情况。
transceiver power-mode { high | low }
光模块处于高功耗工作模式。
以太网接口视图
通常情况下,光模块处于高功耗工作模式。当光模块长时间不需要工作时,可将光模块切换到低功耗工作模式,节省能耗。低功耗模式下,光模块不能传输信号,如果有流量传输需求,需要手工将光模块调整到高功耗工作模式。
仅可插拔QSFP系列光模块支持本命令。
# 将HundredGigE3/1/1上插入的QSFP系列光模块设置为高功耗模式。
[Sysname-HundredGigE3/1/1] transceiver power-mode high
# 将HundredGigE3/1/1上插入的QSFP系列光模块设置为低功耗模式。
[Sysname-HundredGigE3/1/1] transceiver power-mode low
This command will place the transceiver module in low-power-consumption mode, disabling the transceiver module from transmitting data. Continue? [Y/N]:Y
user-role命令用来配置执行Schedule时使用的用户角色。
undo user-role命令用来将已经配置的用户角色从Schedule中删除。
user-role role-name
undo user-role role-name
执行Schedule时使用的用户角色,为创建该Schedule的用户的用户角色。
Schedule视图
role-name:用户角色的名称,为1~63个字符的字符串,区分大小写。可以是系统预定义的角色名称,包括network-admin、network-operator和level-0~level-15,也可以是自定义的用户角色名称。
设备支持的每条命令执行时都需要相应的用户角色。只有本命令中配置的用户角色具有权限,Schedule中的command命令中指定的命令行才能执行。关于用户角色的详细描述请参见“基础配置指导”中的“RBAC”。
同一Schedule最多可配置64个用户角色,超过该上限后,新配置会执行失败。
安全日志管理员角色与其它用户角色互斥:配置安全日志管理员角色后,系统会自动删除已配置的其它用户角色;配置其它用户角色后,系统会自动删除已配置的安全日志管理员角色。
# 配置执行定时任务test时使用的用户角色为rolename。
[Sysname] scheduler schedule test
[Sysname-schedule-test] user-role rolename
# 配置执行定时任务test时使用的用户角色为security-audit。
[Sysname-schedule-test]user-role security-audit
This operation will delete all other user roles for the schedule. Are you sure? [Y/N]:y
# 将执行定时任务test时使用的用户角色从security-audit修改为network-admin。
[Sysname-schedule-test]user-role network-admin
This operation will delete security auditor user role for the schedule. Are you sure? [Y/N]:y
· command
