11-VLAN映射命令
本章节下载: 11-VLAN映射命令 (174.80 KB)
display vlan mapping命令用来显示VLAN映射信息。
display vlan mapping [ interface interface-type interface-number ]
interface interface-type interface-number:显示指定接口的VLAN映射信息,interface-type interface-number为接口类型和接口编号。如果未指定该参数,将显示所有接口的VLAN映射信息。
# 显示所有接口上的VLAN映射信息。
<Sysname> display vlan mapping
Interface Ten-GigabitEthernet1/0/1:
Outer VLAN Inner VLAN Translated Outer VLAN Translated Inner VLAN
10 N/A 120 N/A
Interface Ten-GigabitEthernet1/0/2:
1024-4094 N/A 100 N/A
Interface Ten-GigabitEthernet1/0/3:
12 N/A 110 12
Interface Ten-GigabitEthernet1/0/4:
11 30 130 40
Interface Ten-GigabitEthernet1/0/5:
50 60 70 N/A
表1-1 display vlan mapping命令显示信息描述表
接口信息 |
Outer VLAN |
原始外层VLAN: · 对于1:1 VLAN映射、N:1 VLAN映射和1:2 VLAN映射,Outer VLAN表示原始VLAN |
Inner VLAN |
原始内层VLAN: · 对于1:1 VLAN映射、N:1 VLAN映射和1:2 VLAN映射,Inner VLAN显示为N/A |
Translated Outer VLAN |
转换后的外层VLAN: · 对于1:1 VLAN映射、2:1 VLAN映射和N:1 VLAN映射,Translated Outer VLAN表示转换后VLAN |
Translated Inner VLAN |
转换后的内层VLAN: · 对于1:1 VLAN映射、2:1 VLAN映射和N:1 VLAN映射,Translated Inner VLAN显示为N/A |
· vlan mapping
vlan mapping命令用来在接口上配置VLAN映射。
undo vlan mapping命令用来取消VLAN映射配置。
vlan mapping { vlan-id translated-vlan vlan-id | nest { range vlan-range-list | single vlan-id-list } nested-vlan vlan-id | nni | tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id | uni { range vlan-range-list | single vlan-id-list } translated-vlan vlan-id}
undo vlan mapping { vlan-id translated-vlan vlan-id | all | nest { range vlan-range-list | single vlan-id-list } nested-vlan vlan-id | nni | tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id | uni { range vlan-range-list | single vlan-id-list } translated-vlan vlan-id}
接口上未配置VLAN映射。
二层以太网接口视图
二层聚合接口视图
vlan-id translated-vlan vlan-id:表示1:1 VLAN映射的原始VLAN ID和转换后的VLAN ID。vlan-id取值范围为1~4094。原始VLAN ID和转换后的VLAN ID不允许相同。
uni range vlan-range-list translated-vlan vlan-id:表示N:1 VLAN映射的用户侧配置,指定映射的原始VLAN段列表和转换后的VLAN ID。其中vlan-range-list = { vlan-id1 to vlan-id2 }&<1-10>,vlan-id2的值要大于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。参数涉及的vlan-id取值范围都为1~4094。不同VLAN段之间不允许出现交叉重叠。原始VLAN与转换后VLAN不允许相同。
uni single vlan-id-list translated-vlan vlan-id:表示N:1 VLAN映射的用户侧配置,指定映射的原始VLAN ID列表和转换后的VLAN ID。其中vlan-id-list = { vlan-id }&<1-10>,&<1-10>表示前面的参数最多可以重复输入10次。参数涉及的vlan-id取值范围都为1~4094。原始VLAN与转换后VLAN不允许相同。
nni:表示N:1 VLAN映射的网络侧配置,用于指导网络侧发往用户侧的流量进行三层转发,并将报文的VLAN Tag替换为对应的N:1 VLAN映射前的VLAN Tag。
nest range vlan-range-list nested-vlan vlan-id:表示1:2 VLAN映射的原始VLAN段列表和添加的外层VLAN ID。其中vlan-range-list = { vlan-id1 to vlan-id2 }&<1-10>,vlan-id2的值要大于vlan-id1的值,&<1-10>表示前面的参数最多可以重复输入10次。参数涉及的vlan-id取值范围都为1~4094。不同VLAN段之间不允许出现交叉重叠。
nest single vlan-id-list nested-vlan vlan-id:表示1:2 VLAN映射的原始VLAN ID列表和添加的外层VLAN ID。其中vlan-id-list = { vlan-id }&<1-10>,&<1-10>表示前面的参数最多可以重复输入10次。参数涉及的vlan-id取值范围都为1~4094。
tunnel outer-vlan-id inner-vlan-id translated-vlan outer-vlan-id inner-vlan-id:表示2:2 VLAN映射的原始外层VLAN ID、内层VLAN ID和转换后的外层VLAN ID、内层VLAN ID。outer-vlan-id和inner-vlan-id的取值范围为1~4094。
all:表示删除接口上所有的VLAN映射配置。
VLAN映射功能只对接口收到的携带VLAN Tag的报文生效。
配置VLAN映射时,对原始VLAN和转换后VLAN具有如下要求:
· 同一接口上不同类型VLAN映射表项的原始VLAN不允许相同,转换后VLAN也不允许相同。
· 同一接口上,多次配置1:1 VLAN映射/2:2 VLAN映射,表项的转换后VLAN不允许和已有配置的转换后VLAN相同;多次配置1:1 VLAN映射/2:2 VLAN映射且指定的原始VLAN相同时,最后一次执行的命令生效。
· 同一接口上,2:2 VLAN映射的转换后内、外层VLAN与2:1 VLAN映射的原始内、外层VLAN不允许完全相同。
同一接口下使用vlan mapping nest range命令配置1:2 VLAN映射时,最多支持配置8组原始VLAN段列表和添加的外层VLAN ID。如需增加1:2 VLAN映射关系,请使用vlan mapping nest single命令增加1:2 VLAN映射关系。
配置N:1 VLAN映射时,需要注意:
· 用户侧配置和网络侧配置需要成对配置,否则N:1 VLAN映射功能不能正确执行。
· 同一个接口不能同时配置为N:1 VLAN映射的用户侧接口和网络侧接口。
· 接口配置为N:1 VLAN映射网络侧接口后,不建议再配置其他类型的映射表项。
· N:1 VLAN映射功能不能与uRPF(Unicast Reverse Path Forwarding,单播反向路径转发)功能同时使用,否则会造成网络侧发往用户侧的流量不能正常转发。有关uRPF的详细介绍,请参见“安全配置指导”中的“uRPF”。
VLAN映射功能和MAC地址数学习上限不能同时在一个接口上配置,后进行配置的功能将配置失败。
VLAN映射功能和QinQ功能之间存在如下限制:
· 使能或关闭QinQ功能之前,要先清除已有的VLAN映射表项。
· 使能QinQ的端口上,不允许配置2:2 VLAN映射功能(使能QinQ功能后,接口只能识别一层VLAN Tag,所以该接口无法再实现2:2 VLAN映射功能)。
同一接口上同时配置VLAN透传和VLAN映射时:
· 透传VLAN不能为1:1 VLAN映射、1:2 VLAN映射和N:1 VLAN映射的原始VLAN和转换后VLAN。
· 透传VLAN不能为2:2 VLAN映射的原始外层VLAN和转换后外层VLAN。
接口为报文添加外层VLAN Tag后,内层VLAN Tag将被当作报文的数据部分进行传输,报文长度将增加4个字节。因此,在携带两层VLAN Tag的报文的传输路径上,建议用户适当增加接口的MTU(Maximum Transmission Unit,最大传输单元)值(至少为1504字节)。
# 在接口Ten-GigabitEthernet1/0/1上配置1:1 VLAN映射:原始VLAN为1,映射后VLAN为101。
[Sysname-Ten-GigabitEthernet1/0/1] vlan mapping 1 translated-vlan 101
# 将接口Ten-GigabitEthernet1/0/2配置为N:1 VLAN映射用户侧接口:原始VLAN范围为1~50、80,映射后VLAN为101。同时将接口Ten-GigabitEthernet1/0/3配置为N:1 VLAN映射网络侧接口,使接口将发往用户侧报文的VLAN Tag替换为N:1 VLAN映射的原始VLAN Tag。
[Sysname-Ten-GigabitEthernet1/0/2] vlan mapping uni range 1 to 50 translated-vlan 101
[Sysname-Ten-GigabitEthernet1/0/2] vlan mapping uni single 80 translated-vlan 101
[Sysname-Ten-GigabitEthernet1/0/2] quit
[Sysname] interface ten-gigabitethernet 1/0/3
[Sysname-Ten-GigabitEthernet1/0/3] vlan mapping nni
# 在接口Ten-GigabitEthernet1/0/4上配置1:2 VLAN映射:原始VLAN范围为1~10、80,映射后添加的外层VLAN为101。
[Sysname] interface ten-gigabitethernet 1/0/4
[Sysname-Ten-GigabitEthernet1/0/4] vlan mapping nest range 1 to 10 nested-vlan 101
[Sysname-Ten-GigabitEthernet1/0/4] vlan mapping nest single 80 nested-vlan 101
# 在接口Ten-GigabitEthernet1/0/5上配置2:2 VLAN映射:原始外层VLAN为101、内层VLAN为1,映射后外层VLAN为201、内层VLAN为10。
[Sysname] interface ten-gigabitethernet 1/0/5
[Sysname-Ten-GigabitEthernet1/0/5] vlan mapping tunnel 101 1 translated-vlan 201 10
· display vlan mapping
vlan mapping egress命令用来配置发送报文时将报文的两层VLAN Tag替换为一层VLAN Tag。
undo vlan mapping egress命令用来取消发送报文时将报文的两层VLAN Tag替换为一层VLAN Tag。
vlan mapping egress outer-vlan outer-vlan-id inner-vlan inner-vlan-id translated-vlan vlan-id
undo vlan mapping egress outer-vlan outer-vlan-id inner-vlan inner-vlan-id translated-vlan vlan-id
接口上未配置发送报文时将报文的两层VLAN Tag替换为一层VLAN Tag。
二层以太网接口视图
二层聚合接口视图
outer-vlan outer-vlan-id:表示原始外层VLAN ID,outer-vlan-id的取值范围为1~4094。
inner-vlan inner-vlan-id:表示原始内层VLAN ID,inner-vlan-id的取值范围为1~4094。
translated-vlan vlan-id:表示替换的VLAN ID,vlan-id取值范围为1~4094。
配置本命令后,端口仅在发送携带指定两层VLAN Tag的报文时,将两层VLAN Tag替换为指定VLAN Tag。收到报文携带的VLAN Tag为转换后VLAN时,不会将VLAN Tag还原为原始的两层VLAN Tag。
在同一接口上,2:1 VLAN映射的原始内、外层VLAN与2:2 VLAN映射的转换后内、外层VLAN不允许完全相同。
在同一接口上,同时配置VLAN映射和VLAN透传功能时,2:1 VLAN映射的原始外层VLAN和转换后VLAN不能与透传VLAN相同。有关VLAN透传的详细介绍,请参见“二层技术-以太网交换配置指导”中的“QinQ”。
在同一接口上,如果指定的内、外层VLAN ID分别相同,则不允许多次配置vlan mapping egress命令。若需修改已有vlan mapping egress配置,须先执行undo vlan mapping egress命令清除已有配置,再执行vlan mapping egress命令。
# 在端口Ten-GigabitEthernet1/0/1上配置发送报文时,如果报文携带了两层VLAN Tag,且内层VLAN ID为30,外层VLAN ID为20,则将报文的VLAN Tag替换为一层VLAN Tag,VLAN ID为40。
[Sysname-Ten-GigabitEthernet1/0/1] vlan mapping egress outer-vlan 20 inner-vlan 30 translated-vlan 40
