03-Security Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9X71)-6W70103-Security Command Reference
28-Flow manager commands
28-Flow manager commands 34.85 KB
flow-manager mac-forwarding enable
Use flow-manager mac-forwarding enable to enable the flow manager for Layer 2 forwarding.
Use undo flow-manager mac-forwarding enable to disable the flow manager for Layer 2 forwarding.
The flow manager is disabled for Layer 2 forwarding.
context-admin
An interface card cannot obtain packet information of the packets with two VLAN tags (such as QinQ packets), and therefore cannot send the packets to the correct security engine.
This feature can query OpenFlow entries for such packets and transparently transmit them to the correct security engine.
# Enable the flow manager for Layer 2 forwarding.
[Sysname] flow-manager mac-forwarding enable
