02-HH3C-L2TP-MIB | 162.86 KB |
(1.3.6.1.4.1.25506.2.139.1.5.1)
(1.3.6.1.4.1.25506.2.139.1.5.2)
(1.3.6.1.4.1.25506.2.139.1.5.3)
(1.3.6.1.4.1.25506.2.139.1.5.4)
(1.3.6.1.4.1.25506.2.139.1.5.5)
(1.3.6.1.4.1.25506.2.139.1.5.6)
(1.3.6.1.4.1.25506.2.139.1.5.7)
HH3C-L2TP-MIB
About this MIB
Use this MIB to obtain the L2TP module information.
MIB file name
hh3c-l2tp.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cL2tp(139)
Scalar objects
hh3cL2tpTUpOrDownLocalTID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpTUpOrDownLocalTID (1.3.6.1.4.1.25506.2.139.1.5.1) |
accessible-for-notify |
Integer32 |
Standard MIB values. |
Local L2TP tunnel ID |
As per the MIB. |
hh3cL2tpTUpOrDownTRemoteName
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpTUpOrDownTRemoteName (1.3.6.1.4.1.25506.2.139.1.5.2) |
SnmpAdminString |
SIZE(0..31) |
Peer L2TP tunnel name |
As per the MIB. |
hh3cL2tpTUpOrDownTPeerIPAdd
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpTUpOrDownTPeerIPAdd (1.3.6.1.4.1.25506.2.139.1.5.3) |
IpAddress |
Peer L2TP tunnel IP address |
As per the MIB. |
hh3cL2tpTUpOrDownTStatus
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpTUpOrDownTStatus (1.3.6.1.4.1.25506.2.139.1.5.4) |
INTEGER |
established(1) stopping(2) |
L2TP tunnel state |
As per the MIB. |
hh3cL2tpTUpOrDownTDownReason
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpTUpOrDownTDownReason (1.3.6.1.4.1.25506.2.139.1.5.5) |
SnmpAdminString |
SIZE(0..63) |
L2TP tunnel disconnection reason |
As per the MIB. |
hh3cL2tpTUpOrDownRemoteTID
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpTUpOrDownRemoteTID (1.3.6.1.4.1.25506.2.139.1.5.6) |
Integer32 |
Peer L2TP tunnel ID |
As per the MIB. |
hh3cL2tpTUpOrDownSessCount
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpTUpOrDownSessCount (1.3.6.1.4.1.25506.2.139.1.5.7) |
Integer32 |
Total number of L2TP tunnel sessions |
As per the MIB. |
Tabular objects
hh3cL2tpScalar
About this table
Use this table to obtain the L2TP scalar status and statistics.
Support for operations
Create:Not supported
Edit/Modify:Supported
Delete:Not supported
Read:Supported
Columns
No table index.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpStatsTotalTunnels (1.3.6.1.4.1.25506.2.139.1.1.1.1) |
read-only |
Counter32 |
Total number of L2TP tunnels. |
As per the MIB. |
hh3cL2tpStatsTotalSessions (1.3.6.1.4.1.25506.2.139.1.1.1.2) |
read-only |
Counter32 |
Total number of L2TP sessions. |
As per the MIB. |
hh3cL2tpSessionRate (1.3.6.1.4.1.25506.2.139.1.1.1.3) |
read-only |
Integer32 |
Number of L2TP sessions generated per second in real time. |
As per the MIB. |
hh3cL2tpStatsTemporarySessions (1.3.6.1.4.1.25506.2.139.1.1.1.4) |
read-only |
Unsigned32 |
Total number of temporary L2TP sessions. |
As per the MIB. |
hh3cL2tpStatsMaxSessions (1.3.6.1.4.1.25506.2.139.1.1.1.5) |
read-only |
Counter32 |
Maximum number of L2TP sessions. |
As per the MIB. |
hh3cL2tpProtocolVersions (1.3.6.1.4.1.25506.2.139.1.1.1.6) |
read-only |
OCTET STRING |
OCTET STRING (2..256) |
Local protocol version |
As per the MIB. |
hh3cL2tpVendorName (1.3.6.1.4.1.25506.2.139.1.1.1.7) |
read-only |
SnmpAdminString |
Protocol stack vendor |
As per the MIB. |
hh3cL2tpFirmwareRev (1.3.6.1.4.1.25506.2.139.1.1.1.8) |
read-only |
Integer32 |
Protocol stack firmware version |
As per the MIB. |
hh3cL2tpDrainingTunnels (1.3.6.1.4.1.25506.2.139.1.1.1.9) |
read-only |
TruthValue |
Whether the local end blocks L2TP sessions from other tunnels |
As per the MIB. |
hh3cL2tpAdminState (1.3.6.1.4.1.25506.2.139.1.1.2.1) |
read-write |
INTEGER |
enabled(1) disabled(2) |
Whether to enable L2TP |
As per the MIB. |
hh3cL2tpAging (1.3.6.1.4.1.25506.2.139.1.1.2.2) |
read-write |
Integer32 |
Integer32 (1..3600) |
LNS down aging time |
As per the MIB. |
hh3cL2tpTunnelTable
About this table
Use this table to obtain the L2TP tunnel information.
Edit/Modify:Not supported
Read:Supported
Columns
The table indexes are hh3cL2tpTunnelType, hh3cL2tpLocalIpAddress, and hh3cL2tpLocalTunnelID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpTunnelType (1.3.6.1.4.1.25506.2.139.1.2.1.1.1) |
not-accessible |
INTEGER |
global(1) instance(2) |
L2TP tunnel type. |
As per the MIB. |
hh3cL2tpLocalIpAddress (1.3.6.1.4.1.25506.2.139.1.2.1.1.2) |
not-accessible |
IpAddress |
Local L2TP tunnel IP address. |
As per the MIB. |
hh3cL2tpLocalTunnelID (1.3.6.1.4.1.25506.2.139.1.2.1.1.3) |
not-accessible |
Unsigned32 |
Unsigned32 (1..65535) |
Local L2TP tunnel ID. |
As per the MIB. |
hh3cL2tpSessions (1.3.6.1.4.1.25506.2.139.1.2.1.1.4) |
read-only |
Unsigned32 |
As per the MIB. |
hh3cL2tpRemoteIpAddress (1.3.6.1.4.1.25506.2.139.1.2.1.1.5) |
read-only |
IpAddress |
Peer L2TP tunnel IP address. |
As per the MIB. |
hh3cL2tpRemoteTunnelID (1.3.6.1.4.1.25506.2.139.1.2.1.1.6) |
read-only |
Unsigned32 |
Peer L2TP tunnel ID. |
As per the MIB. |
hh3cL2tpRemotePort (1.3.6.1.4.1.25506.2.139.1.2.1.1.7) |
read-only |
Unsigned32 |
Unsigned32 (0..65535) |
Peer L2TP tunnel port. |
As per the MIB. |
hh3cL2tpRemoteName (1.3.6.1.4.1.25506.2.139.1.2.1.1.8) |
read-only |
DisplayString |
OCTET STRING (0..255) |
Peer L2TP tunnel name. |
As per the MIB. |
hh3cL2tpTunnelState (1.3.6.1.4.1.25506.2.139.1.2.1.1.9) |
read-only |
INTEGER |
idle(0) waitReply(1) established(2) stopping(3) |
Current L2TP tunnel state. |
As per the MIB. |
hh3cL2tpGroupConfigTable
About this table
Use this table to obtain and modify the L2TP group configuration.
Create:Supported
Delete:Supported
Read:Supported
Columns
The table index is hh3cL2tpGroupConfigGroupID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpGroupConfigGroupID (1.3.6.1.4.1.25506.2.139.1.3.1.1.1) |
read-only |
Interger32 |
Interger32 (1..65535) |
L2TP group index |
As per the MIB. |
hh3cL2tpGroupConfigDomainId (1.3.6.1.4.1.25506.2.139.1.3.1.1.2) |
read-create |
SnmpAdminString |
OCTET STRING (0..80) |
Domain name of the L2TP tunnel |
Read-only in the current software version |
hh3cL2tpGroupConfigHelloInterval (1.3.6.1.4.1.25506.2.139.1.3.1.1.3) |
read-create |
Interger32 |
Interger32 (60..1000) |
Interval of sending Hello packets to the peer end |
As per the MIB. |
hh3cL2tpGroupConfigIdleTimeout (1.3.6.1.4.1.25506.2.139.1.3.1.1.4) |
read-create |
Interger32 |
Interger32 (-1..86400) |
Idle time for disconnecting a connection without sessions |
hh3cL2tpGroupConfigCtrlRWS (1.3.6.1.4.1.25506.2.139.1.3.1.1.5) |
read-create |
Interger32 |
Interger32 (1..5000) |
Receiving window size for a control channel |
As per the MIB. |
hh3cL2tpGroupConfigCtrlMaxRetx (1.3.6.1.4.1.25506.2.139.1.3.1.1.6) |
read-create |
Interger32 |
Interger32 (0..32) |
Maximum retransmissions of an L2TP tunnel |
hh3cL2tpGroupConfigCtrlMaxRetxTO (1.3.6.1.4.1.25506.2.139.1.3.1.1.7) |
read-create |
Interger32 |
Interger32 (1..32) |
Maximum retransmission timeout timer |
hh3cL2tpGroupConfigAuthentication (1.3.6.1.4.1.25506.2.139.1.3.1.1.8) |
read-create |
TruthValue |
Whether to perform L2TP tunnel authentication |
As per the MIB. |
hh3cL2tpGroupConfigAvpHidden (1.3.6.1.4.1.25506.2.139.1.3.1.1.9) |
read-create |
TruthValue |
Whether to transfer AVP data in hidden mode |
As per the MIB. |
hh3cL2tpGroupConfigLoadsharing (1.3.6.1.4.1.25506.2.139.1.3.1.1.10) |
read-create |
TruthValue |
Whether to implement load balancing |
As per the MIB. |
hh3cL2tpGroupConfigTunnelName (1.3.6.1.4.1.25506.2.139.1.3.1.1.11) |
read-create |
DisplayString |
OCTET STRING (0..31) |
Local L2TP tunnel name |
As per the MIB. |
hh3cL2tpGroupConfigLnsIP1 (1.3.6.1.4.1.25506.2.139.1.3.1.1.13) |
read-create |
IpAddress |
LNS IP address 1 for load balancing |
As per the MIB. |
hh3cL2tpGroupConfigLnsWeight1 (1.3.6.1.4.1.25506.2.139.1.3.1.1.14) |
read-create |
Interger32 |
Interger32 (1..10) |
LNS weight 1 for load balancing |
As per the MIB. |
hh3cL2tpGroupConfigLnsIP2 (1.3.6.1.4.1.25506.2.139.1.3.1.1.15) |
read-create |
IpAddress |
LNS IP address 2 for load balancing |
As per the MIB. |
hh3cL2tpGroupConfigLnsWeight2 (1.3.6.1.4.1.25506.2.139.1.3.1.1.16) |
read-create |
Interger32 |
LNS weight 2 for load balancing |
As per the MIB. |
hh3cL2tpGroupConfigLnsIP3 (1.3.6.1.4.1.25506.2.139.1.3.1.1.17) |
read-create |
IpAddress |
LNS IP address 3 for load balancing |
As per the MIB. |
hh3cL2tpGroupConfigLnsIP4 (1.3.6.1.4.1.25506.2.139.1.3.1.1.19) |
read-create |
IpAddress |
LNS IP address 4 for load balancing |
As per the MIB. |
hh3cL2tpGroupConfigLnsWeight4 (1.3.6.1.4.1.25506.2.139.1.3.1.1.20) |
read-create |
Interger32 |
LNS weight 4 for load balancing |
As per the MIB. |
hh3cL2tpGroupConfigLnsIP5 (1.3.6.1.4.1.25506.2.139.1.3.1.1.21) |
read-create |
IpAddress |
LNS IP address 5 for load balancing |
As per the MIB. |
hh3cL2tpGroupConfigLnsWeight5 (1.3.6.1.4.1.25506.2.139.1.3.1.1.22) |
read-create |
Interger32 |
LNS weight 5 for load balancing |
As per the MIB. |
hh3cL2tpGroupConfigGroupName (1.3.6.1.4.1.25506.2.139.1.3.1.1.23) |
read-create |
DisplayString |
OCTET STRING (0::32) |
L2TP group name |
As per the MIB. |
hh3cL2tpGroupConfigRemoteName (1.3.6.1.4.1.25506.2.139.1.3.1.1.24) |
read-create |
DisplayString |
OCTET STRING (0::31) |
Accepted peer L2TP tunnel name |
As per the MIB. |
hh3cL2tpGroupConfigForceChap (1.3.6.1.4.1.25506.2.139.1.3.1.1.25) |
read-create |
TruthValue |
Whether to perform CHAP authentication by force |
As per the MIB. |
hh3cL2tpGroupConfigVTNumber (1.3.6.1.4.1.25506.2.139.1.3.1.1.27) |
read-create |
Interger32 |
Interger32 (0..65535) |
Bound virtual template interface |
As per the MIB. |
hh3cL2tpGroupConfigMode (1.3.6.1.4.1.25506.2.139.1.3.1.1.28) |
read-create |
INTEGER |
lac(1) lns(2) |
L2TP group mode |
As per the MIB. |
hh3cL2tpGroupConfigRowStatus (1.3.6.1.4.1.25506.2.139.1.3.1.1.29) |
read-create |
RowStatus |
Adding/deleting/modifying/querying flag |
As per the MIB. |
hh3cL2tpTunnelStatsTable
About this table
Use this table to obtain L2TP performance parameters of an access server.
Read:Supported
Columns
The table indexes are hh3cL2tpTStatsUpID and hh3cL2tpTStatsLocalTID.
Object (OID) |
Access |
Syntax |
Value range |
Implementation |
hh3cL2tpTStatsUpID (1.3.6.1.4.1.25506.2.139.1.4.1.1.1) |
not-accessible |
Interger32 |
Interger32 (0..2047) |
UP index ID |
As per the MIB. |
hh3cL2tpTStatsLocalTID (1.3.6.1.4.1.25506.2.139.1.4.1.1.2) |
not-accessible |
Interger32 |
As per the MIB. |
hh3cL2tpTStatsRemoteTID (1.3.6.1.4.1.25506.2.139.1.4.1.1.3) |
read-only |
Interger32 |
As per the MIB. |
hh3cL2tpTStatsState (1.3.6.1.4.1.25506.2.139.1.4.1.1.4) |
read-only |
INTEGER |
idle(1) connecting(2) established(3) disconnecting(4) |
Control L2TP tunnel status |
As per the MIB. |
hh3cL2tpTStatsInitiated (1.3.6.1.4.1.25506.2.139.1.4.1.1.5) |
read-only |
INTEGER |
locally(1) remotely(2) |
Indicates the L2TP tunnel is initiated by the local end or peer end |
As per the MIB. |
hh3cL2tpTStatsRemoteHostName (1.3.6.1.4.1.25506.2.139.1.4.1.1.6) |
read-only |
SnmpAdminString |
OCTET STRING (1..31) |
Peer host name |
As per the MIB. |
hh3cL2tpTStatsRemoteVendorName (1.3.6.1.4.1.25506.2.139.1.4.1.1.7) |
read-only |
SnmpAdminString |
OCTET STRING (1..256) |
Provider name of the peer L2TP |
As per the MIB. |
hh3cL2tpTStatsRemoteFirmwareRev (1.3.6.1.4.1.25506.2.139.1.4.1.1.8) |
read-only |
Interger32 |
Firmware version of the peer L2TP |
As per the MIB. |
hh3cL2tpTStatsRemoteProtocolVer (1.3.6.1.4.1.25506.2.139.1.4.1.1.9) |
read-only |
OCTET STRING |
OCTET STRING (2) |
Protocol version of the peer L2TP |
As per the MIB. |
hh3cL2tpTStatsBearerCaps (1.3.6.1.4.1.25506.2.139.1.4.1.1.10) |
read-only |
INTEGER |
none(1) digital(2) analog(3) digitalAnalog(4) |
Bearing capability of the L2TP tunnel |
As per the MIB. |
hh3cL2tpTStatsFramingCaps (1.3.6.1.4.1.25506.2.139.1.4.1.1.11) |
read-only |
INTEGER |
none(1) sync(2) async(3) syncAsync(4) |
Framing capability of the L2TP tunnel |
As per the MIB. |
hh3cL2tpTStatsControlRxPkts (1.3.6.1.4.1.25506.2.139.1.4.1.1.12) |
read-only |
Counter32 |
Number of control packets received |
As per the MIB. |
hh3cL2tpTStatsControlRxZLB (1.3.6.1.4.1.25506.2.139.1.4.1.1.13) |
read-only |
Counter32 |
Number of ZLB control packets received |
As per the MIB. |
hh3cL2tpTStatsControlTxPkts (1.3.6.1.4.1.25506.2.139.1.4.1.1.14) |
read-only |
Counter32 |
Number of control packets sent to the peer entity |
As per the MIB. |
hh3cL2tpTStatsControlTxZLB (1.3.6.1.4.1.25506.2.139.1.4.1.1.15) |
read-only |
Counter32 |
Number of ZLB control packets sent to the peer entity |
As per the MIB. |
hh3cL2tpTStatsControlAckTO (1.3.6.1.4.1.25506.2.139.1.4.1.1.16) |
read-only |
Counter32 |
Number of control packets that time out because ACK packets are not timely received |
As per the MIB. |
hh3cL2tpTStatsCurrentRemoteRWS (1.3.6.1.4.1.25506.2.139.1.4.1.1.17) |
read-only |
Gauge32 |
Gauge32 (0..65535) |
Receiving window size of the current peer |
As per the MIB. |
hh3cL2tpTStatsTxSeq (1.3.6.1.4.1.25506.2.139.1.4.1.1.18) |
read-only |
Interger32 |
Next sequence number sent by the control channel |
As per the MIB. |
hh3cL2tpTStatsTxSeqAck (1.3.6.1.4.1.25506.2.139.1.4.1.1.19) |
read-only |
Interger32 |
Sending sequence number of a received ACK |
As per the MIB. |
hh3cL2tpTStatsRxSeq (1.3.6.1.4.1.25506.2.139.1.4.1.1.20) |
read-only |
Interger32 |
Next receiving sequence number of the control channel |
As per the MIB. |
hh3cL2tpTStatsTotalSessions (1.3.6.1.4.1.25506.2.139.1.4.1.1.21) |
read-only |
Counter32 |
Total number of L2TP sessions |
As per the MIB. |
hh3cL2tpTStatsFailedSessions (1.3.6.1.4.1.25506.2.139.1.4.1.1.22) |
read-only |
Counter32 |
Number of L2TP sessions initiated but not established |
As per the MIB. |
hh3cL2tpTStatsActiveSessions (1.3.6.1.4.1.25506.2.139.1.4.1.1.23) |
read-only |
Gauge32 |
Number of established L2TP sessions |
As per the MIB. |
Notifications
hh3cL2tpSessionFail
Basic information
OID |
Event |
Type |
Severity |
Recovery notification |
Default status |
1.3.6.1.4.1.25506.2.139.1.8.0.1 |
Failure of session addtion. |
Informational |
Warning |
OFF |
Notification triggers
This notification is generated when an L2TP user fails to come online.
Possible reasons include:
The number of L2TP sessions has reached the maximum limit.
Negotiation fails during the online process.
During the online process, the tunnel's carrier port goes down.
System impact
When the number of L2TP users on the device exceeds the device's capacity, subsequent L2TP user online attempts fail.
User traffic is interrupted.
Status control
ON
CLI: snmp-agent trap enable l2tp session-add-fail
OFF
CLI: undo snmp-agent trap enable l2tp session-add-fail
Object
OID (object name) |
Index |
Type |
Value range |
1.3.6.1.4.1.25506.2.139.1.7.1 (hh3cL2tpSessFailChassisID) |
Chassis ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.139.1.7.2 (hh3cL2tpSessFailSlotID) |
Slot ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.139.1.7.3 (hh3cL2tpSessFailLocalTID) |
Local tunnel ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.139.1.7.4 (hh3cL2tpSessFailLocalSID) |
Local session ID |
N/A |
Integer32 |
1.3.6.1.4.1.25506.2.139.1.7.5 (hh3cL2tpSessFailPeerIPAdd) |
Peer address |
N/A |
IpAddress |
1.3.6.1.4.1.25506.2.139.1.7.6 (hh3cL2tpSessFailLocalIPAdd) |
Local address |
N/A |
IpAddress |
Recommended action
1.Replace the card or use a new device.
2.Check if the carrier port status of the tunnel is normal.
