H3C S5590-HI[EI] Switch Series Hardware Information and Specifications-6W103
HomeSupportSwitchesS5590-EI SeriesProduct LiteratureHardware Information & SpecificationsH3C S5590-HI[EI] Switch Series Hardware Information and Specifications-6W103
01-Hardware Information and Specifications
1 Product models and technical specifications· 1-3
Product models· 1-3
Technical specifications· 1-4
S5590-HI switch series· 1-4
S5590-EI switch series· 1-8
2 Chassis views· 2-25
S5590-HI switch series· 2-25
S5590-EI switch series· 2-29
3 Removable components and compatibility matrixes· 3-39
4 Removable power supplies· 4-42
250W power supplies (PSR250-12A and PSR250-12A1) 4-42
180W AC power supplies (PSR180-12A-F and PSR180-12A-B) 4-43
180W DC power supply (PSR180-12D-B) 4-44
600W power supply (PSR600-54A-B) 4-45
920W power supply (PSR920-54A-B) 4-46
1600W power supply (PSR1600-54A-B) 4-47
5 Removable fan trays· 5-49
LSPM1FANSA-SN· 5-49
LSPM1FANSB-SN· 5-50
6 Expansion cards· 6-51
LSWM2QP2P· 6-51
LSWM2SP8P/LSWM2SP8PM·· 6-51
LSWM2ZQP2P· 6-52
LSWM2ZSP8P· 6-52
LSWM2EC· 6-53
LSPM6FWD·· 6-54
LSWM2SP2PB· 6-55
LSWM2SP4PB· 6-55
LSWM2ZSP4P· 6-56
LSWM2QP2PB· 6-57
7 Ports and LEDs· 7-59
Ports· 7-59
Console port 7-59
Management Ethernet port 7-59
USB port 7-59
SFP port 7-60
SFP+ port 7-63
SFP28 port 7-65
QSFP+ port 7-67
QSFP28 ports· 7-69
10/100/1000BASE-T Ethernet port 7-71
10G/5G/2.5G/1000BASE-T autosensing Ethernet port 7-71
Combo interface· 7-72
Ports on an LSWM2EC EPS scanner module· 7-72
Ports on an LSPM6FWD firewall module· 7-73
Connecting cables to the ports on expansion cards· 7-74
LEDs· 7-74
System status LED·· 7-74
Power status LED·· 7-74
Mode LED·· 7-75
Management Ethernet port LED·· 7-75
SFP port LED·· 7-75
SFP+ port LED·· 7-76
SFP28 port LED·· 7-76
QSFP+ port LED·· 7-76
QSFP28 port LED·· 7-77
10/100/1000BASE-T autosensing Ethernet port LED·· 7-77
10G/5G/2.5G/1000BASE autosensing Ethernet port LED·· 7-77
Expansion card status LED·· 7-78
Fan tray status LED on a fan tray· 7-78
Status LED on a PSR250-12A/PSR250-12A1 power supply· 7-78
Status LEDs on a 600W/920W/1600W power supply· 7-79
LEDs on an LSWM2SP8P/LSWM2SP8PM interface card· 7-79
LEDs on an LSWM2EC EPS scanner module· 7-79
LEDs on an LSPM6FWD firewall module· 7-80
8 Cooling system·· 8-81
Unless otherwise stated, interface modules and interface cards are used interchangeably in this document.
Product models
Table1-1 Switch series and models
Switch series
Model
Product code (PID)
Non-PoE models
S5590-28T8XC-HI
LS-5590-28T8XC-HI
S5590-48T4XC-HI
LS-5590-48T4XC-HI
S5590-28S8XC-HI
LS-5590-28S8XC-HI
S5590-48S4XC-HI
LS-5590-48S4XC-HI
Non-PoE models
S5590-28T8XC-EI
LS-5590-28T8XC-EI
LS-5590-28T8XC-EI-GL
LS-5590-28T8XC-EI-H3
LS-5590-28T8XC-EI-G3
S5590-48T4XC-EI
LS-5590-48T4XC-EI
LS-5590-48T4XC-EI-GL
LS-5590-48T4XC-EI-H3
LS-5590-48T4XC-EI-G3
S5590-28S8XC-EI
LS-5590-28S8XC-EI
LS-5590-28S8XC-EI-GL
S5590-48S4XC-EI
LS-5590-48S4XC-EI
LS-5590-48S4XC-EI-GL
S5590-24X4YC-EI
LS-S5590-24X4YC-EI
S5590-48TS4X2QC-EI
LS-S5590-48TS4X2QC-EI
PoE models
S5590-28P8XC-EI
LS-5590-28P8XC-EI
LS-5590-28P8XC-EI-GL
LS-5590-28P8XC-EI-G3
S5590-48P6XC-EI
LS-5590-48P6XC-EI
LS-5590-48P6XC-EI-GL
LS-5590-48P6XC-EI-G3
S5590-24UXM4YC-EI
LS-5590-24UXM4YC-EI
LS-5590-24UXM4YC-EI-GL
S5590-48UXM4YC-EI
LS-5590-48UXM4YC-EI
LS-5590-48UXM4YC-EI-GL
·     Switches of the same model but different PIDs might differ in hardware and software features. You can view the PID of a switch on the label located on its rear panel or top panel.
·     To obtain the purchase information, see the product data sheet at https://www.h3c.com/en/Products_and_Solutions/InterConnect/Switches/ and pay attention to the switch product lifecycle management announcement at https://www.h3c.com/en/Support/Policy_Dynamics/Management_Strategy/Products_End_of_Life_Announcement/Switches/.
·     For information about product and software compatibility, see the release notes.
Table1-2 Technical specifications
Item
S5590-28T8XC-HI
S5590-48T4XC-HI
S5590-28S8XC-HI
S5590-48S4XC-HI
Physical specifications
Dimensions (H × W × D)
44 × 440 × 400 mm (1.73 × 17.32 × 15.75 in)
Dimensions (H × W × D, with package materials)
148 × 575 × 520 mm (5.83 × 22.64 × 20.47 in)
Weight (fully configured with power supplies and fan trays)
≤ 8 kg (17.64 lb)
Memory (RAM)
4 GB
Flash
1 GB
Port types and quantity
Console port
1 × serial console port
USB port
1
1
SFP+ port
8
4
8
4
SFP port
4 (Each and its corresponding 10/100/1000BASE-T autosensing Ethernet port form a combo interface.)
N/A
28 (The four highest-numbered SFP ports and their corresponding 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces.)
48 (The four highest-numbered SFP ports cannot be used when the port rate mode of the expansion slots is mode2.)
28 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports and their corresponding SFP ports form combo interfaces.)
48 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports cannot be used when the port rate mode of the expansion slots is mode 2.)
4 (Each and its corresponding SFP port form a combo interface.)
N/A
IRF physical ports
The following ports on the switch panel and expansion cards support IRF connection:
·     SFP+ ports (The SFP+ ports on the LSWM2SP2PB or LSWM2SP4PB interface module cannot be used as IRF physical ports.)
·     SFP28 ports
·     QSFP+ ports
·     QSFP28 ports
10G, 25G, 40G, and 100G IRF links are supported.
Fan tray, power supply, and expansion card slots
Expansion slot
2
Power supply slot
2
Fan tray slot
2
Power supply specifications
Power input
AC input
Power specifications
See "Removable power supplies"
Power consumption
Power consumption (static)
Data collection standard: no load
Single power input: 42 W
Dual power inputs: 47 W
Single power input: 44 W
Dual power inputs: 50 W
Single power input: 43 W
Dual power inputs: 49 W
Single power input: 47 W
Dual power inputs: 55 W
Power consumption (typical)
Data collection standard: fully configured with copper cables or network cables, at 30% load
Single power input: 57 W
Dual power inputs: 60 W
Single power input: 67 W
Dual power inputs: 70 W
Single power input: 54 W
Dual power inputs: 57 W
Single power input: 62 W
Dual power inputs: 65 W
Power consumption (full load)
Data collection standard: fully configured with transceiver modules or network cables, at 100% load
Single power input: 136 W
Dual power inputs: 141 W
Single power input: 132 W
Dual power inputs: 136 W
Single power input: 138 W
Dual power inputs: 142 W
Single power input: 152 W
Dual power inputs: 156 W
Thermal consumption
Thermal consumption (static)
Single power input: 143 BTU/h
Dual power inputs: 160 BTU/h
Single power input: 150 BTU/h
Dual power inputs: 170 BTU/h
Single power input: 146 BTU/h
Dual power inputs: 167 BTU/h
Single power input: 160 BTU/h
Dual power inputs: 187 BTU/h
Thermal consumption (typical)
Single power input: 194 BTU/h
Dual power inputs: 204 BTU/h
Single power input: 228 BTU/h
Dual power inputs: 238 BTU/h
Single power input: 184 BTU/h
Dual power inputs: 194 BTU/h
Single power input: 211 BTU/h
Dual power inputs: 221 BTU/h
Thermal consumption (full load)
Single power input: 464 BTU/h
Dual power inputs: 481 BTU/h
Single power input: 450 BTU/h
Dual power inputs: 464 BTU/h
Single power input: 470 BTU/h
Dual power inputs: 484 BTU/h
Single power input: 518 BTU/h
Dual power inputs: 532 BTU/h
Heat dissipation
Heat dissipation method
Air cooling
Ventilation aisle
Front-to-rear or rear-to-front airflow, determined by the selected fan tray model
Reliability and availability
Power supply redundancy
1+1
Fan tray redundancy
You must install two fan trays on the switch.
Hot swapping
Power supplies and fan trays support hot swapping.
Expansion cards support hot swapping, but do not hot swap an expansion card when the switch is starting up
Mean Time Between Failure (MTBF) (year)
90.99
101.63
95.79
92.43
Mean time to repair (MTTR) (hour)
1
1
1
1
Availability
99.999876%
99.999863%
99.999882%
99.999879%
Environment specifications
Sound pressure level at 27°C (80.6°F)
47.6 dB
49 dB
48 dB
48.8 dB
Altitude
0 m to 5000 m (0 ft to 16404.20 ft)
Operating temperature
–5°C to +45°C (23°F to 113°F)
Note:
The allowed maximum temperature decreases by 0.33 °C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 0 m (0 ft).
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Operating humidity
5% RH to 95% RH, noncondensing
Compliance
Product compliance
·     Safety standards
·     EMC standards
·     Environmental and eco-friendly standards
Table1-3 Technical specifications for non-PoE switch models (1)
Item
S5590-28T8XC-EI (LS-5590-28T8XC-EI/LS-5590-28T8XC-EI-G3)
S5590-28T8XC-EI (LS-5590-28T8XC-EI-GL/LS-5590-28T8XC-EI-H3)
S5590-48T4XC-EI (LS-5590-48T4XC-EI/LS-5590-48T4XC-EI-G3)
S5590-48T4XC-EI (LS-5590-48T4XC-EI-GL/LS-5590-48T4XC-EI-H3)
44 × 440 × 360 mm (1.73 × 17.32 × 14.17 in)
125 × 562 × 550 mm (4.92 × 22.13 × 21.65 in)
LS-5590-28T8XC-EI-GL: 125 × 580 × 562 mm (4.92 × 22.83 × 22.13 in)
LS-5590-28T8XC-EI-H3: 125 × 562 × 550 mm (4.92 × 22.13 × 21.65 in)
LS-5590-48T4XC-EI-GL: 125 × 580 × 562 mm (4.92 × 22.83 × 22.13 in)
LS-5590-48T4XC-EI-H3: 125 × 562 × 550 mm (4.92 × 22.13 × 21.65 in)
≤ 7 kg (15.43 lb)
Memory (RAM)
2 GB
Flash
4 GB
Console port
USB port
1
1
SFP+ port
8
8
4
4
SFP port
N/A
N/A
48
48
IRF physical ports
·     SFP28 ports
·     QSFP+ ports
·     QSFP28 ports
Expansion slot
1
Power supply slot
2
Fan tray slot
2
Power input
AC input, DC input
Note:
The S5590-EI switch series does not support HVDC input.
For DC input, you can use a –48 VDC power source in the equipment room or an RPS (H3C RPS1600-A).
Power consumption
Single power input: 38 W
Dual power inputs: 45 W
Single power input: 39 W
Dual power inputs: 46 W
Single power input: 41 W
Dual power inputs: 48 W
N/A
Single power input: 52 W
Dual power inputs: 58 W
N/A
Single power input: 65 W
Single power input: 108 W
Dual power inputs: 114 W
Single power input: 110 W
Dual power inputs: 115 W
Single power input: 105 W
Dual power inputs: 108 W
Single power input: 115 W
Dual power inputs: 120 W
Thermal consumption
Single power input: 129 BTU/h
Dual power inputs: 153 BTU/h
N/A
Single power input: 139 BTU/h
Dual power inputs: 163 BTU/h
N/A
Single power input: 191 BTU/h
Dual power inputs: 201 BTU/h
N/A
Single power input: 221 BTU/h
Dual power inputs: 232 BTU/h
N/A
Single power input: 368 BTU/h
Dual power inputs: 388 BTU/h
N/A
Single power input: 358 BTU/h
Dual power inputs: 368 BTU/h
N/A
Heat dissipation
Air cooling
Ventilation aisle
1+1
Fan tray redundancy
Hot swapping
105.15
105.15
101.63
101.63
1
1
1
1
Availability
99.999893%
99.999893%
99.999888%
99.999888%
49 dB
49 dB
46.6 dB
46.6 dB
Altitude
Note:
Storage temperature
Operating humidity
Compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-4 Technical specifications for non-PoE switch models (2)
Item
S5590-24X4YC-EI
S5590-48TS4X2QC-EI
S5590-28S8XC-EI (LS-5590-28S8XC-EI-GL/LS-5590-28S8XC-EI)
S5590-48S4XC-EI (LS-5590-48S4XC-EI-GL/LS-5590-48S4XC-EI)
LS-5590-28S8XC-EI-GL: 125 × 580 × 562 mm (4.92 × 22.83 × 22.13 in)
LS-5590-28S8XC-EI: 125 × 562 × 550 mm (4.92 × 22.13 × 21.65 in)
LS-5590-48S4XC-EI-GL: 125 × 580 × 562 mm (4.92 × 22.83 × 22.13 in)
LS-5590-48S4XC-EI: 125 × 562 × 550 mm (4.92 × 22.13 × 21.65 in)
≤ 7 kg (15.43 lb)
Memory (RAM)
2 GB
2 GB
2 GB
2 GB
Flash
8 GB
8 GB
4 GB
4 GB
Console port
USB port
1
1
SFP+ port
24
4
8
4
SFP port
N/A
24
48
SFP28 port
4
N/A
N/A
N/A
QSFP+ port
N/A
2
N/A
N/A
N/A
24
N/A
IRF physical ports
·     SFP28 ports
·     QSFP+ ports
·     QSFP28 ports
Expansion slot
1
Power supply slot
2
Fan tray slot
2
Power input
AC input, DC input
Note:
Power consumption
Single AC input: 30 W
Dual AC inputs: 37 W
Single DC input: 29 W
Dual DC inputs: 36 W
Single AC input: 40 W
Dual AC inputs: 43 W
Single DC input: 34 W
Dual DC inputs: 42 W
Dual AC inputs: 47 W
Single DC input: 39 W
Dual DC inputs: 46 W
Single AC input: 56 W
Dual AC inputs: 64 W
Single DC input: 57 W
Dual DC inputs: 64 W
Single power input: 48 W
Dual power inputs: 53 W
Single AC input: 95 W
Dual AC inputs: 102 W
Single DC input: 93 W
Dual DC inputs: 98 W
Single AC input: 120 W
Dual AC inputs: 125 W
Single DC input: 120 W
Dual DC inputs: 125 W
Single power input: 119 W
Dual power inputs: 123 W
Single power input: 137 W
Thermal consumption
N/A
N/A
Single power input: 133 BTU/h
Dual power inputs: 156 BTU/h
N/A
N/A
Single power input: 170 BTU/h
Dual power inputs: 180 BTU/h
Single power input: 177 BTU/h
N/A
N/A
Single power input: 406 BTU/h
Dual power inputs: 419 BTU/h
Single power input: 467 BTU/h
Heat dissipation
Air cooling
Ventilation aisle
1+1
Fan tray redundancy
Hot swapping
238.58
162.05
101.74
101.01
1
1
1
1
Availability
N/A
N/A
99.999898%
99.999885%
40.9 dB
40.9 dB
46.6 dB
47.4 dB
Altitude
Note:
Storage temperature
Relative humidity
Compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-5 Technical specifications for PoE switch models (1)
Item
S5590-28P8XC-EI
S5590-48P6XC-EI
150 × 556 × 528 mm (5.91 × 21.89 × 20.79 in)
≤ 7 kg (15.43 lb)
Memory (RAM)
2 GB
Flash
4 GB
Console port
USB port
1
1
SFP+ port
8
6
SFP port
N/A
48
IRF physical ports
·     SFP28 ports
·     QSFP+ ports
·     QSFP28 ports
Expansion slot
1
Power supply slot
2
Fan tray slot
2
Power input
AC input
PoE power capacity
Max PoE power capacity per port
30 W or 35 W
Note:
The maximum PoE power capacity per port varies by software version. For more information about the maximum PoE power capacity per port, see the software release for the product or verify it on the switch.
Total PoE power capacity
See Table1-9
Power consumption
Dual power inputs: 59 W
Single power input: 73 W
Dual power inputs: 86 W
Single power input: 938 W
Dual power inputs: 1046 W
Single power input: 945 W
Dual power inputs: 1745 W
Thermal consumption
Single power input: 164 BTU/h
Dual power inputs: 181 BTU/h
Single power input: 192 BTU/h
Dual power inputs: 225 BTU/h
Single power input: 246 BTU/h
Dual power inputs: 287 BTU/h
Single power input: 3200 BTU/h
Dual power inputs: 3569 BTU/h
Single power input: 3224 BTU/h
Dual power inputs: 5956 BTU/h
Heat dissipation
Air cooling
Ventilation aisle
1+1
Fan tray redundancy
Hot swapping
32.15/55.18
28.62/55.18
1
1
Availability
99.999653%
99.999612%
48.6 dB
62.8 dB
Altitude
Note:
Storage temperature
Relative humidity
Compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-6 Technical specifications for PoE switch models (2)
Item
S5590-24UXM4YC-EI
S5590-48UXM4YC-EI
180 × 678 × 576 mm (7.09 × 26.69 × 22.68 in)
≤ 9.5 kg (20.94 lb)
Memory (RAM)
2 GB
Flash
8 GB
Console port
USB port
1
1
SFP28 port
4
4
16
32
10G/5G/2.5G/1000/100/10BASE-T autosensing Ethernet port
8
16
IRF physical ports
·     SFP28 ports
·     QSFP+ ports
·     QSFP28 ports
Expansion slot
1
Power supply slot
2
Fan tray slot
2
Power input
AC input
PoE power capacity
100 W
See Table1-9
Power consumption
Single power input: 56 W
Dual power inputs: 66 W
Single power input: 63 W
Dual power inputs: 74 W
Single power input: 82 W
Dual power inputs: 90 W
Dual power inputs: 125 W
See Table1-7
Thermal consumption
Single power input: 214 BTU/h
Dual power inputs: 252 BTU/h
Single power input: 279 BTU/h
Dual power inputs: 307 BTU/h
Single power input: 375 BTU/h
Dual power inputs: 427 BTU/h
See Table1-8
Heat dissipation
Air cooling
Ventilation aisle
Port-to-power supply airflow
1+1
Fan tray redundancy
Hot swapping
72.5
68.97
1
1
Availability
99.99984%
99.999832%
47.9 dB
47.9 dB
Altitude
Note:
Storage temperature
Operating humidity
Compliance
Product compliance
·     Safety standards
·     EMC standards
Table1-7 Power consumption for the S5590-24UXM4YC-EI and S5590-48UXM4YC-EI switches (full load)
Power supply configuration
S5590-24UXM4YC-EI
S5590-48UXM4YC-EI
1 × PSR600-54A-B
530 W
550 W
1 × PSR920-54A-B
870 W
910 W
1 × PSR1600-54A-B (90 VAC to 176 VAC)
925 W
954 W
1 × PSR1600-54A-B (176 VAC to 290 VAC)
1630 W
1645 W
2 × PSR600-54A-B
1160 W
1780 W
2 × PSR920-54A-B
1765 W
1800 W
2 × PSR1600-54A-B (90 VAC to 176 VAC)
2020 W
1982 W
2 × PSR1600-54A-B (176 VAC to 290 VAC)
2660 W
3152 W
Table1-8 Thermal consumption for the S5590-24UXM4YC-EI and S5590-48UXM4YC-EI switches (full load)
S5590-24UXM4YC-EI
S5590-48UXM4YC-EI
1 × PSR600-54A-B
1808 BTU/h
1877 BTU/h
1 × PSR920-54A-B
2969 BTU/h
3105 BTU/h
3156 BTU/h
3255 BTU/h
5562 BTU/h
5613 BTU/h
2 × PSR600-54A-B
3958 BTU/h
6074 BTU/h
2 × PSR920-54A-B
6022 BTU/h
6142 BTU/h
6893 BTU/h
6762 BTU/h
9076 BTU/h
10755 BTU/h
Table1-9 PoE power capacity of the S5590-EI switch series
S5590-28P8XC-EI
S5590-48P6XC-EI
S5590-24UXM4YC-EI
S5590-48UXM4YC-EI
1 × PSR600-54A-B
450 W
30 W
450 W
30 W
400 W
100 W
400 W
100 W
1 × PSR920-54A-B
770 W
30 W
770 W
30 W
720 W
100 W
720 W
100 W
1 × PSR1600-54A-B (input voltage: 90 VAC to 176 VAC)
770 W
30 W
770 W
30 W
720 W
100 W
720 W
100 W
1 × PSR1600-54A-B (input voltage: 176 VAC to 290 VAC or 180 VDC to 320 VDC)
1000 W
30 W
1450 W
30 W
1400 W
100 W
1400 W
100 W
2 × PSR600-54A-B
1000 W
30 W
1020 W
30 W
970 W
100 W
970 W
100 W
1 × PSR600-54A-B and 1 × PSR920-54A-B
1000 W
30 W
1020 W
30 W
970 W
100 W
970 W
100 W
1 × PSR920-54A-B and 1 × PSR1600-54A-B (input voltage: 90 VAC to 176 VAC)
1000 W
30 W
1260 W
30 W
1210 W
100 W
1210 W
100 W
1 × PSR920-54A-B and 1 × PSR1600-54A-B (input voltage: 176 VAC to 290 VAC or 180 VDC to 320 VDC)
1000 W
30 W
1600 W
30 W
1550 W
100 W
1550 W
100 W
1 × PSR1600-54A-B (input voltage: 90 VAC to 176 VAC) and 1 × PSR1600-54A-B (input voltage: 176 VAC to 1290 VAC or 180 VDC to 320 VDC)
1000 W
30 W
1600 W
30 W
1550 W
100 W
1550 W
100 W
2 × PSR920-54A-B
1000 W
30 W
1600 W
30 W
1550 W
100 W
1550 W
100 W
2 × PSR1600-54A-B (input voltage: 90 VAC to 176 VAC)
1000 W
30 W
1600 W
30 W
1600 W
100 W
1600 W
100 W
2 × PSR1600-54A-B (input voltage: 176 VAC to 1290 VAC or 180 VDC to 320 VDC)
1000 W
30 W
1680 W
30 W
2400 W
100 W
2800 W
100 W
2 Chassis views
S5590-28T8XC-HI
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) Console port (CONSOLE)
(4) Mode button
(5) System status LED (SYS)
(6) Mode LED (MODE)
(7) Expansion card status LED 1 (SLOT1)
(8) Expansion card status LED 2 (SLOT2)
(9) USB port
(10) Management Ethernet port LED (ACT/LINK)
(11) Management Ethernet port (MGMT)
(12) SFP+ port LED
(13) SFP+ port
(14) SFP port
(15) SFP port LED
Figure2-2 Rear panel
(1) Grounding screw
(2) Fan tray 1
(3) Expansion card 1
(4) Expansion card 2
(5) Fan tray 2
(6) Power supply 1
(7) Power supply 2
The S5590-28T8XC-HI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-2, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S5590-28T8XC-HI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-2, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-28T8XC-HI switch came with two expansion slots each installed with a filler panel. You can select expansion cards for the switch as required. In Figure2-2, two LSWM2QP2P interface cards are installed in the expansion slots.
S5590-48T4XC-HI
Figure2-3 Front panel
(3) SFP+ port
(4) Console port (CONSOLE)
(5) Mode button
(6) System status LED (SYS)
(7) Mode LED (MODE)
(8) Expansion card status LED 1 (SLOT1)
(9) Expansion card status LED 2 (SLOT2)
(10) USB port
(11) Management Ethernet port LED (ACT/LINK)
(12) Management Ethernet port (MGMT)
(13) SFP+ port LED
Figure2-4 Rear panel
(1) Grounding screw
(2) Fan tray 1
(5) Fan tray 2
(6) Power supply 1
(7) Power supply 2
The S5590-48T4XC-HI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-4, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S5590-48T4XC-HI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-4, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48T4XC-HI switch came with two expansion slots each installed with a filler panel. You can select expansion cards for the switch as required. In Figure2-4, two LSWM2QP2P interface cards are installed in the expansion slots.
S5590-28S8XC-HI
Figure2-5 Front panel
(1) SFP port
(2) SFP port LED
(4) Mode button
(6) Mode LED (MODE)
(9) USB port
(12) SFP+ port LED
(13) SFP+ port
(14) 10/100/1000BASE-T autosensing Ethernet port
(15) 10/100/1000BASE-T autosensing Ethernet port LED
Figure2-6 Rear panel
(1) Grounding screw
(2) Fan tray 1
(5) Fan tray 2
(6) Power supply 1
(7) Power supply 2
The S5590-28S8XC-HI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-6, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S5590-28S8XC-HI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-6, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-28S8XC-HI switch came with two expansion slots each installed with a filler panel. You can select expansion cards for the switch as required. In Figure2-6, two LSWM2QP2P interface cards are installed in the expansion slots.
S5590-48S4XC-HI
Figure2-7 Front panel
(1) SFP port
(2) SFP port LED
(3) SFP+ port
(5) Mode button
(7) Mode LED (MODE)
(10) USB port
(13) SFP+ port LED
Figure2-8 Rear panel
(1) Grounding screw
(2) Fan tray 1
(5) Fan tray 2
(6) Power supply 1
(7) Power supply 2
The S5590-48S4XC-HI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-8, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S5590-48S4XC-HI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-8, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48S4XC-HI switch came with two expansion slots each installed with a filler panel. You can select expansion cards for the switch as required. In Figure2-8, two LSWM2QP2P interface cards are installed in the expansion slots.
S5590-28T8XC-EI
Figure2-9 Front panel
(3) SFP port
(4) SFP+ port
(5) Management Ethernet port (MGMT)
(6) Console port (CONSOLE)
(7) Mode button
(8) USB port
(9) System status LED (SYS)
(10) Mode LED (MODE)
(11) Expansion card status LED (SLOT)
(12) Power supply 2 status LED (PWR2)
(13) Power supply 1 status LED (PWR1)
(14) Management Ethernet port LED (ACT/LINK)
(15) SFP+ port LED
(16) SFP port LED
Figure2-10 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-28T8XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-10, two PSR180-12A-B AC power supplies are installed in the power supply slots.
The S5590-28T8XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-10, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-28T8XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-10, an LSWM2QP2P interface card is installed in the expansion slot.
S5590-48T4XC-EI
Figure2-11 Front panel
(3) Management Ethernet port (MGMT)
(5) Mode button
(6) USB port
(7) System status LED (SYS)
(8) SFP+ port
(9) Mode LED (MODE)
(10) Expansion card status LED (SLOT)
(11) Power supply 2 status LED (PWR2)
(12) Power supply 1 status LED (PWR1)
(13) Management Ethernet port LED (ACT/LINK)
(14) SFP+ port LED
Figure2-12 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-48T4XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-12, two PSR180-12A-B AC power supplies are installed in the power supply slots.
The S5590-48T4XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-12, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48T4XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-12, an LSWM2QP2P interface card is installed in the expansion slot.
S5590-28S8XC-EI
Figure2-13 Front panel
(1) SFP port
(2) SFP port LED
(3) 10/100/1000BASE-T autosensing Ethernet port LED
(4) Management Ethernet port (MGMT)
(5) Console port (CONSOLE)
(6) Mode button
(7) USB port
(8) System status LED (SYS)
(9) Mode LED (MODE)
(14) SFP+ port
(15) SFP+ port LED
(16) 10/100/1000BASE-T autosensing Ethernet port
Figure2-14 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-28S8XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-14, two PSR180-12A-B AC power supplies are installed in the power supply slots.
The S5590-28S8XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-14, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-28S8XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-14, an LSWM2QP2P interface card is installed in the expansion slot.
The S5590-28S8XC-EI switch with PID LS-5590-28S8XC-EI-GL supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
S5590-48S4XC-EI
Figure2-15 Front panel
(1) SFP port
(2) SFP port LED
(5) Mode button
(6) USB port
(8) SFP+ port
(9) Mode LED (MODE)
(14) SFP+ port LED
Figure2-16 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-48S4XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-16, two PSR180-12A-B AC power supplies are installed in the power supply slots.
The S5590-48S4XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-16, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48S4XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-16, an LSWM2QP2P interface card is installed in the expansion slot.
The S5590-48S4XC-EI switch with PID LS-5590-48S4XC-EI-GL supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
S5590-28P8XC-EI
Figure2-17 Front panel
(3) SFP port
(4) SFP+ port
(7) Mode button
(8) USB port
(15) SFP+ port LED
(16) SFP port LED
Figure2-18 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-28P8XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-18, two PSR600-54A-B AC power supplies are installed in the power supply slots.
The S5590-28P8XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-18, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-28P8XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-18, an LSWM2QP2P interface card is installed in the expansion slot.
The S5590-28P8XC-EI switch with PID LS-5590-28P8XC-EI-GL supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
S5590-48P6XC-EI
Figure2-19 Front panel
(3) SFP+ port
(5) Mode LED (MODE)
(7) Power supply 1 status LED (PWR1)
(8) Power supply 2 status LED (PWR2)
(9) Expansion card status LED (SLOT)
(10) USB port
(11) Mode button
(12) Management Ethernet port LED (ACT/LINK)
(13) Management Ethernet port (MGMT)
(14) SFP+ port LED
Figure2-20 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-48P6XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-20, two PSR600-54A-B AC power supplies are installed in the power supply slots.
The S5590-48P6XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-20, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48P6XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-20, an LSWM2QP2P interface card is installed in the expansion slot.
The S5590-48P6XC-EI switch with PID LS-5590-48P6XC-EI-GL supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
S5590-24X4YC-EI
Figure2-21 Front panel
(1) SFP+ port
(2) SFP28 port
(5) Mode button
(6) USB port
(8) Mode LED (MODE)
(10) Power supply 2 status LED (PWR2)
(11) Power supply 1 status LED (PWR1)
(12) Management Ethernet port LED (LINK/ACT)
(13) SFP28 port LED (SFP28)
(14) SFP+ port LED
Figure2-22 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-24X4YC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-22, two PSR180-12A-B AC power supplies are installed in the power supply slots.
The S5590-24X4YC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-22, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-24X4YC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-22, an LSWM2SP8P interface card is installed in the expansion slot.
S5590-48TS4X2QC-EI
Figure2-23 Front panel
(3) SFP port
(4) SFP port LED
(5) SFP+ port
(6) SFP+ port LED
(7) QSFP+ port
(8) Management Ethernet port LED (ACT)
(9) Management Ethernet port (MGMT)
(10) Management Ethernet port LED (LINK)
(11) USB port
(12) Console port (CONSOLE)
(13) QSFP+ port LED
(14) System status LED (SYS)
(15) Expansion card status LED (SLOT)
(16) Power supply 2 status LED (PWR2)
(17) Power supply 1 status LED (PWR1)
Figure2-24 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-48TS4X2QC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-24, two PSR180-12A-B AC power supplies are installed in the power supply slots.
The S5590-48TS4X2QC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-24, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48TS4X2QC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-24, an LSWM2SP8P interface card is installed in the expansion slot.
S5590-24UXM4YC-EI
Figure2-25 Front panel
(3) 10G/5G/2.5G/1000 BASE-T autosensing Ethernet port
(4) 10G/5G/2.5G/1000 BASE-T autosensing Ethernet port LED
(5) SFP28 port
(7) Mode button
(8) USB port
(11) Management Ethernet port LED (LINK/ACT)
(13) SFP28 port LED
(14) Expansion card status LED (SLOT)
(15) Power supply 2 status LED (PWR2)
(16) Power supply 1 status LED (PWR1)
Figure2-26 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-24UXM4YC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-26, two PSR600-54A-B AC power supplies are installed in the power supply slots.
The S5590-24UXM4YC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-26, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-24UXM4YC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-26, an LSWM2SP2PB interface module is installed in the expansion slot.
S5590-48UXM4YC-EI
Figure2-27 Front panel
(7) Expansion card status LED (SLOT)
(8) Mode button
(9) USB port
(10) System status LED (SYS)
(11) SFP28 port LED
(12) Mode LED (MODE)
(13) Power supply 2 status LED (PWR2)
(14) Power supply 1 status LED (PWR1)
(15) SFP28 port
(16) Management Ethernet port LED (LINK/ACT)
Figure2-28 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-48UXM4YC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-28, two PSR600-54A-B AC power supplies are installed in the power supply slots.
The S5590-48UXM4YC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-28, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48UXM4YC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-28, an LSWM2SP2PB interface module is installed in the expansion slot.
The switch supports removable components. Table3-1 and Table3-2 describes the removable components available for the switch.
Table3-1 Compatibility matrix between switches and removable components (1)
FRU model
S5590-28T8XC-HI
S5590-28S8XC-HI
S5590-48T4XC-HI
S5590-48S4XC-HI
S5590-28T8XC-EI
S5590-28S8XC-EI
S5590-48T4XC-EI
S5590-48S4XC-EI
S5590-28P8XC-EI
S5590-48P6XC-EI
S5590-24UXM4YC-EI
S5590-48UXM4YC-EI
PSR250-12A
Supported
Supported
Not supported
Not supported
Not supported
PSR250-12A1
Supported
Supported
Not supported
Not supported
Not supported
PSR180-12A-B
Not supported
Not supported
Supported
Not supported
Not supported
PSR180-12A-F
Not supported
Not supported
Supported
Not supported
Not supported
PSR180-12D-B
Not supported
Not supported
Supported
Not supported
Not supported
PSR600-54A-B
Not supported
Not supported
Not supported
Supported
Supported
PSR920-54A-B
Not supported
Not supported
Not supported
Supported
Supported
PSR1600-54A-B
Not supported
Not supported
Not supported
Supported
Supported
Removable fan trays
LSPM1FANSA-SN
Supported
Supported
Supported
Supported
Not supported
LSPM1FANSB-SN
Supported
Supported
Supported
Supported
Supported
Expansion cards
LSPM6FWD
Supported
Expansion cards supported by expansion slots 1 and 2 depend on the port rate mode. For more information, see Table3-3.
Supported
Supported
Not supported
LSWM2EC
Supported
Supported
Supported
Supported
LSWM2QP2P
Supported
Supported
Supported
Not supported
LSWM2SP8P
Supported
Supported
Supported
Not supported
LSWM2ZQP2P
Supported
Supported
Supported
Not supported
LSWM2ZSP8P
Supported
Supported
Supported
Not supported
LSWM2SP2PB
Supported
Supported
Supported
Supported
LSWM2SP4PB
Supported
Supported
Supported
Supported
LSWM2ZSP4P
Not supported
Not supported
Not supported
Not supported
Supported
LSWM2QP2PB
Not supported
Not supported
Not supported
Not supported
Supported
Table3-2 Compatibility matrix between switches and removable components (2)
FRU model
S5590-24X4YC-EI
S5590-48TS4X2QC-EI
PSR180-12A-B
Supported
Supported
PSR180-12A-F
Supported
Supported
PSR180-12D-B
Supported
Supported
Removable fan trays
LSPM1FANSA-SN
Supported
Supported
LSPM1FANSB-SN
Supported
Supported
Expansion cards
LSPM6FWD
Not supported
Supported
LSWM2QP2P
Not supported
Supported
LSWM2SP8P
Not supported
Supported
LSWM2ZQP2P
Not supported
Supported
LSWM2ZSP8P
Not supported
Supported
LSWM2SP2PB
Supported
Supported
LSWM2SP4PB
Supported
Supported
LSWM2EC
Supported
Supported
LSWM2ZSP4P
Supported
Supported
LSWM2QP2PB
Supported
Supported
Table3-3 Expansion card and expansion slot compatibility for the S5590-48T4XC-HI and S5590-48S4XC-HI switches
Expansion card
S5590-48T4XC-HI
S5590-48S4XC-HI
Expansion slot 1
Expansion slot 2
mode0
mode1
mode2
mode0
mode1
mode2
LSPM6FWD
Supported
Not supported
Supported
Supported
Supported
Supported
LSWM2EC
Not supported
Supported
Supported
Supported
Supported
Supported
LSWM2QP2P
Supported
Not supported
Supported
Supported
Supported
Supported
LSWM2SP2PB
Not supported
Supported
Supported
Supported
Supported
Supported
LSWM2SP4PB
Not supported
Supported
Supported
Supported
Supported
Supported
LSWM2SP8P
Not supported
Not supported
Supported
Supported
Supported
Supported
LSWM2ZQP2P
Not supported
Not supported
Not supported
Supported
Supported
Supported
LSWM2ZSP8P
Not supported
Not supported
Not supported
Supported
Supported
Supported
The power supplies support asset management. You can use the display device manuinfo command to view the name, sequence number, and vendor of the power supply you have installed on the switch.
For non-PoE switches, you can install one power supply, or two power supplies for 1+1 redundancy on the switch.
For PoE switches, you can install one power supply, or two power supplies for 1+1 redundancy on the switch. PoE capabilities vary by power supply configuration. When a power supply fails, PoE capabilities of the switch might decrease. For more information about PoE power capacity, see Table1-9.
The switch uses removable fan trays. Do not power on the switch if it does not have two fan trays of the same model installed.
For the S5590-48T4XC-HI and S5590-48S4XC-HI switches, you can use the port-speed-mode command to configure the port rate mode for an expansion slot. By default, the port rate mode for an expansion slot is mode0. To have the configuration take effect, you must save the configuration and restart the switch. For more information about the port-speed-mode command, see Ethernet interface commands in the command reference for the switch.
The S5590-28P8XC-EI (LS-5590-28P8XC-EI-GL), S5590-48P6XC-EI (LS-5590-48P6XC-EI-GL), S5590-28S8XC-EI (LS-5590-28S8XC-EI-GL), and S5590-48S4XC-EI (LS-5590-48S4XC-EI-GL) switches support shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
View
Figure4-1 PSR250-12A AC power supply view
The views of the PSR250-12A and PSR250-12A1 AC power supplies are similar, with only differences in the latch color and identifier.
For information about the status LED, see "Status LED on a PSR250-12A/PSR250-12A1 power supply."
Features
PSR250-12A and PSR250-12A1 are AC power supplies with AC or HVDC input and DC output. Table4-1 describes the features provided by the PSR250-12A and PSR250-12A1 power supplies.
Table4-1 Features provided by the PSR250-12A and PSR250-12A1 power supplies
Feature
Protection function
Protection against input overcurrent, input undervoltage, output overvoltage, output current limiting, output shortcircuit, and overtemperature conditions.
Support for redundancy
Two power supplies can be connected in parallel to achieve 1+1 redundancy and load balancing.
Support for hot swapping
You can remove one of the power supplies in 1+1 redundancy when the switch is operating correctly.
Table4-2 Technical specifications
Item
Specification
40.2 × 50.5 × 246 mm (1.58 × 1.99 × 9.69 in), including the handle
Weight
0.6 kg (1.32 lb)
Rated AC input voltage range
AC input: 100 VAC to 240 VAC @ 50 or 60 Hz
HVDC input: 240 VDC
Max AC input voltage range
AC input: 90 VAC to 290 VAC @ 47 to 63 Hz
HVDC input: 180 to 320 VDC
Rated input current
2 A to 4 A
Rated output current
2.5 A to 5 A
Rated output voltage
3.3 V to 12 V
Rated output power
250 W
Melting current of power supply fuse
15 A/250 V
View
Figure4-2 PSR180-12A-B AC power supply view
The views of the PSR180-12A-F and PSR180-12A-B AC power supplies are similar, with only differences in the identifier.
Features
PSR180-12A-F and PSR180-12A-B are AC power supplies with AC input and DC output. The power supplies provide an output voltage of 12 V and a maximum output of 180 W. Table4-3 describes the features provided by the PSR180-12A-F and PSR180-12A-B power supplies.
Table4-3 Features provided by the PSR180-12A-F and PSR180-12A-B power supplies
Feature
Protection function
Table4-4 Technical specifications
Item
Specification
41.1 × 101.6 × 207 mm (1.62 × 4.00 × 8.15 in), including the handle
Weight
0.8 kg (1.76 lb)
90 VAC to 264 VAC @ 47 to 63 Hz
Rated input current
N/A
15 A
12 V
Rated output power
180 W
6.3 A/250 V
View
Figure4-3 PSR180-12D-B DC power supply view
Features
PSR180-12D-B is a DC power supply with DC input and DC output. The power supply provides an output voltage of 12 V and a maximum output of 180 W. Table4-5 describes the features provided by the PSR180-12D-B power supply.
Table4-5 Features provided by the PSR180-12D-B power supply
Feature
Protection function
Table4-6 Technical specifications
Item
Specification
Weight
1 kg (2.20 lb)
Rated input voltage range
–48 to –60 VDC
Max input voltage range
–36 to –72 VDC
Rated input current
N/A
15 A
12 V
Rated output power
180 W
8 A/125 V
View
Figure4-4 PSR600-54A-B AC power supply view
For information about the status LEDs, see "Status LEDs on a 600W/920W/1600W power supply."
Features
PSR600-54A-B is an AC power supply with AC or HVDC input and DC output. Table4-7 describes the features provided by the PSR600-54A-B power supply.
Table4-7 Features provided by the PSR600-54A-B power supply
Feature
Protection function
Table4-8 Technical specifications
Item
Specification
40.2 × 73.5 × 213.8 mm (1.58 × 2.89 × 8.42 in), including the handle
Weight
1 kg (2.20 lb)
HVDC input: 240 VDC
Rated input current
N/A
11 A
56 V
Rated output power
600 W
10 A/250 V
View
Figure4-5 PSR920-54A-B AC power supply view
Features
PSR920-54A-B is an AC power supply with AC or HVDC input and DC output. Table4-9 describes the features provided by the PSR920-54A-B power supply.
Table4-9 Features provided by the PSR920-54A-B power supply
Feature
Protection function
Table4-10 Technical specifications
Item
Specification
Weight
1 kg (2.20 lb)
HVDC input: 240 VDC
Rated input current
N/A
16.5 A
56 V
Rated output power
920 W
16 A/250 V
View
Figure4-6 PSR1600-54A-B AC power supply view
Features
PSR1600-54A-B is an AC power supply with AC or HVDC input and DC output. Table4-11 describes the features provided by the PSR1600-54A-B power supply.
Table4-11 Features provided by the PSR1600-54A-B power supply
Feature
Protection function
Table4-12 Technical specifications
Item
Specification
Weight
1 kg (2.20 lb)
HVDC input: 240 VDC
Rated input current
N/A
·     AC input:
¡     17 A: 90 to 176 V @ 47 to 63 Hz
¡     29 A: 176 to 290 V @ 47 to 63 Hz
·     HVDC input: 29 A
56 V
Rated output power
·     AC input:
¡     950 W: 90 to 176 V @ 47 to 63 Hz
¡     1600 W: 176 to 290 V @ 47 to 63 Hz
·     HVDC input: 1600 W
16 A/125 V
LSPM1FANSA-SN
View
Figure5-1 LSPM1FANSA-SN fan tray view
For information about the status LED, see "Fan tray status LED on a fan tray."
Features
The LSPM1FANSA-SN fan tray blows air from the power supply side to the port side. The fan tray features small size, fast heat dissipation, and hot swapping. It can automatically adjust the fan speed, providing powerful heat dissipation for the switch.
Table5-1 Technical specifications
Item
Specification
40 × 40.6 × 105 mm (1.57 × 1.60 × 4.13 in), including the handle
Fan quantity
1
Weight
N/A
Airflow direction
Air drawn in from the fan tray faceplate
Fan speed
20000 R.P.M
Max airflow
20 CFM (0.57 m3/min)
Input voltage
12 V
Max power consumption
9.8 W
LSPM1FANSB-SN
View
Figure5-2 LSPM1FANSB-SN fan tray view
Features
The LSPM1FANSB-SN fan tray draws air from the port side to the power supply side. The fan tray features small size, fast heat dissipation, and hot swapping. It can automatically adjust the fan speed, providing powerful heat dissipation for the switch.
Table5-2 Technical specifications
Item
Specification
Fan quantity
1
Weight
N/A
Airflow direction
Air exhausted from the fan tray faceplate
Fan speed
20000 R.P.M
Max airflow
Input voltage
12 V
9.8 W
6 Expansion cards
LSWM2QP2P
About LSWM2QP2P
The LSWM2QP2P interface card provides two QSFP+ ports.
Figure6-1 LSWM2QP2P interface card view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "QSFP+ port."
For information about the LEDs, see "QSFP+ port LED."
Table6-1 Technical specifications
Item
Specification
40.1 × 95 × 147.5 mm (1.58 × 3.74 × 5.81 in)
Weight
0.4 kg (0.88 lb)
9 W
Power consumption (with typical configuration)
10 W
Power consumption (fully configured)
14 W
About LSWM2SP8P and LSWM2SP8PM
The LSWM2SP8PM and LSWM2SP8P interface cards each provide eight SFP+ ports. The SFP+ ports on the LSWM2SP8PM interface card support MACsec. The views of LSWM2SP8P and LSWM2SP8PM are the same. This figure uses the LSWM2SP8P as an example.
Figure6-2 LSWM2SP8P interface card view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "SFP port" and "SFP+ port."
For information about the LEDs, see "LEDs on an LSWM2SP8P/LSWM2SP8PM interface card."
LSWM2ZQP2P
About LSWM2ZQP2P
The LSWM2ZQP2P interface module provides two QSFP28 ports.
Figure6-3 LSWM2ZQP2P interface module view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "QSFP+ port" and "QSFP28 ports."
For information about the LEDs, see "QSFP28 port LED."
LSWM2ZSP8P
About LSWM2ZSP8P
The LSWM2ZSP8P interface module provides eight SFP28 ports.
Figure6-4 LSWM2ZSP8P interface module view
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "SFP+ port" and "SFP28 port."
For information about the LEDs, see "SFP28 port LED."
To use the LSWM2ZSP8P interface module, make sure the four lowest-numbered or four highest-numbered ports on the interface module have the same port rate and duplex mode.
LSWM2EC
About LSWM2EC
The LSWM2EC EPS scanner module scans network-wide endpoints as instructed by the EPS server for port type and operating system type automatically and sends scanning results to the EPS server. Upon receiving the port information, the EPS server provides a baseline management over the endpoints that access the network system. By using this module on a switch, you can save hardware resources, increase the number of endpoints that can be scanned, and perform incremental scanning.
Figure6-5 LSWM2EC EPS scanner module view
LEDs
For information about the management port LEDs, see "LEDs on an LSWM2EC EPS scanner module."
Table6-2 Technical specifications
Item
Specification
Processor
Intel C3758, 2.2 GHz
DDR
8G DDR4
Flash
64GB EMMC
Operating system
Linux
Maximum number of endpoints that can be scanned
2500
Ports
·     1 × management Ethernet port (MGMT)
·     1 × console port
·     2 × USB 3.0 ports
41.1 × 95 × 197.5 mm (1.62 × 3.74 × 7.78 in)
Weight
0.5 kg (1.10 lb)
14 W
30 W
LSPM6FWD
About LSPM6FWD
The LSPM6FWD is a fourth-generation high performance firewall module. It provides features including firewall, VPN, content filtering, content identification, URL filtering, and NAT. By using this module on a switch, you can enhance the switch security capabilities without changing the network topology.
Figure6-6 LSPM6FWD front panel
(1) Management Ethernet port LED (ACT/LINK)
(2) 10/100/1000BASE-T management Ethernet port
(3) System status LED (SYS)
(5) Captive screw
Ports and LEDs
For information about the ports and transceiver modules and cables available for the ports, see "Ports on an LSPM6FWD firewall module."
For information about the LEDs, see "LEDs on an LSPM6FWD firewall module."
Table6-3 Technical specifications
Item
Specification
44.1 × 95 × 197.8 mm (1.74 × 3.74 × 7.79 in)
Weight
0.688 kg (1.52 lb)
N/A
N/A
50 W
LSWM2SP2PB
About LSWM2SP2PB
The LSWM2SP2PB interface module provides two SFP+ ports.
Figure6-7 LSWM2SP2PB interface module view
Ports and LEDs
LSWM2SP4PB
About LSWM2SP4PB
The LSWM2SP4PB interface module provides four SFP+ ports.
Figure6-8 LSWM2SP4PB interface module view
Ports and LEDs
LSWM2ZSP4P
About LSWM2ZSP4P
The LSWM2ZSP4P interface module provides four SFP28 ports.
Figure6-9 LSWM2ZSP4P interface module view
(1) SFP28 port LED
(2) SFP28 port
(3) Captive screw
(4) Ejector lever
Ports and LEDs
Table6-4 Technical specifications
Item
Specification
40.1 × 95.0 × 147.5 mm (1.58 × 3.74 × 5.81 in)
Weight
0.4 kg (0.88 lb)
5.0 W
6.0 W
11.0 W
LSWM2QP2PB
About LSWM2QP2PB
The LSWM2QP2PB interface module provides two QSFP+ ports.
Figure6-10 LSWM2QP2PB interface module view
(1) QSFP+ port
(2) Captive screw
(3) Ejector lever
(4) QSFP+ port LED
Ports and LEDs
Table6-5 Technical specifications
Item
Specification
Weight
0.4 kg (0.88 lb)
9 W
10 W
14 W
7 Ports and LEDs
Ports
Console port
Table7-1 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Port transmission rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal
·     Provides connection to the serial port of a local PC running terminal emulation program
Compatible devices
All device models
Table7-2 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     10 Mbps, half/full duplex
·     100 Mbps, half/full duplex
·     1000 Mbps, full duplex
·     MDI/MDI-X autosensing
Transmission medium
Category-5 or above twisted pair cable
Max transmission distance
100 m (328.08 ft)
Compliant standard
IEEE 802.3i, 802.3u, and 802.3ab
Functions and services
Switch software and Boot ROM upgrade, network management
Compatible devices
All device models
USB port
Table7-3 USB port specifications
Item
Specification
Port type
USB 2.0
Compliant standard
OHC
Uploads and downloads data at a rate up to 480 Mbps
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files
Compatible devices
All device models
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
SFP port
Table7-4 SFP port specifications
Item
Specification
Port type
SFP port
Compatible transceiver modules and cables
·     FE SFP transceiver modules in Table7-5
·     GE SFP transceiver modules and cables in Table7-6
Compatible devices
All device models (excluding the S5590-48T4XC-HI, S5590-48T4XC-EI, and S5590-48P6XC-EI switches)
·     When you use the SFP-GE-T or SFP-GE-T-D copper transceiver module, the interfaces can operate only at 1000 Mbps.
·     Only the S5590-28T8XC-EI (LS-5590-28T8XC-EI-GL and LS-5590-28T8XC-EI-H3) switch supports the SFP-FE-BX15-U-SM1310 transceiver module.
·     The S5590-28T8XC-EI (LS-5590-28T8XC-EI-GL and LS-5590-28T8XC-EI-H3) and S5590-48T4XC-EI (LS-5590-48T4XC-EI-GL and LS-5590-48T4XC-EI-H3) switches do not support the SFP-FE-LX-SM1310-D, SFP-FE-LX-SM1310-BIDI, and SFP-GE-SX-MM850-D transceiver modules.
·     The S5590-24X4YC-EI (LS-S5590-24X4YC-EI), S5590-24UXM4YC-EI, and S5590-48UXM4YC-EI switches do not support FE SFP transceiver modules.
·     The S5590-48TS4X2QC-EI (LS-S5590-48TS4X2QC-EI) switch does not support the SFP-FE-LX-SM1310-D and SFP-GE-SX-MM850-D transceiver modules.
Table7-5 FE SFP transceiver modules available for the SFP ports
Central wavelength (nm)
Connector
Fiber diameter (µm)
SFP-FE-SX-MM1310-A
1310
LC
Multi-mode, 50/125
2 km (1.24 miles)
Multi-mode, 62.5/125
SFP-FE-LX-SM1310-A
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
Single-mode, 9/125
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
Single-mode, 9/125
80 km (49.71 miles)
TX: 1310
RX: 1550
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
15 km (9.32 miles)
IMPORTANT
IMPORTANT:
The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-FE-LX-SM1550-BIDI transceiver module.
Table7-6 GE SFP transceiver modules and cables available for the SFP+ ports
GE SFP transceiver module and cable
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz × km)
SFP copper transceiver modules
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP fiber transceiver modules
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500 or 400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX10-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH20-SM1310-I
1310
LC
Single-mode, 9/125
N/A
20 km (12.43 miles)
SFP-GE-LH40-SM1310-I
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP cable
SFP-STACK-Kit
N/A
N/A
N/A
SFP cable
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, SFP-GE-LH70-SM1550-BIDI and SFP-GE-LH70-SM1490-BIDI transceiver modules, and SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-GE-LX-SM1490-BIDI transceiver module.
·     As a best practice, use H3C transceiver modules and network cables for the switch.
·     The H3C transceiver modules and network cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact H3C Support or marketing staff.
·     For the specifications of H3C transceiver modules and network cables, see H3C Transceiver Modules User Guide.
SFP+ port
Table7-7 SFP+ port specifications
Item
Specification
Port type
SFP+ port
·     10GE SFP+ transceiver modules and cables in Table7-8, Table7-9, and Table7-10
Compatible devices
All device models and the LSWM2SP8P, LSWM2SP2PB, and LSWM2SP4PB expansion cards
·     The S5590-28T8XC-EI (LS-5590-28T8XC-EI-GL and LS-5590-28T8XC-EI-H3) and S5590-48T4XC-EI (LS-5590-48T4XC-EI-GL and LS-5590-48T4XC-EI-H3) switches do not support the SFP-XG-SX-MM850-A and SFP-XG-LX-SM1310-E transceiver modules.
·     The S5590-24X4YC-EI, S5590-48TS4X2QC-EI, S5590-24UXM4YC-EI, and S5590-48UXM4YC-EI switches do not support the SFP-XG-SX-MM850-A, SFP-XG-LX-SM1310-E, and SFP-XG-LH80-Tunable transceiver modules.
Table7-8 10GE SFP+ transceiver modules available for the SFP+ ports
Connector
Fiber diameter (µm)
SFP-XG-SX-MM850-A
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-CPRI-IR-SM1310
1310
LC
Single-mode, 9/125
N/A
1.4 km (0.87 miles)
SFP-XG-CPRI-LR-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH80-Tunable
1547.75
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table7-9 SFP+ copper cables available for the SFP+ ports
SFP+ copper cable
Cable length
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
Table7-10 SFP+ fiber cables available for the SFP+ ports
SFP+ fiber cable
Cable length
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure7-1 SFP+ cable
(1) Connector
(2) Pull latch
SFP28 port
The LSWM2ZSP8P interface module and the S5590-24X4YC-EI, S5590-24UXM4YC-EI, and S5590-48UXM4YC-EI switches provide SFP28 ports. To connect peer SFP28/SFP+ ports over a long distance, use SFP28/SFP+ transceiver modules and fibers. To connect peer SFP28/SFP+ ports over a short distance, use SFP28/SFP+ cables.
SFP28 ports support the following transceiver modules and cables:
·     SFP28 transceiver modules in Table7-11.
·     SFP28 cables in Table7-12.
·     SFP+ transceiver modules in Table7-8.
·     SFP+ copper cables in Table7-9.
·     SFP+ fiber cables in Table7-10.
Table7-11 SFP28 transceiver modules available for the SFP28 ports
Connector
SFP-25G-SR-MM850
850
LC
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
SFP-25G-SR-MM850-H
850
LC
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
SFP-25G-CSR-MM850
850
LC
Multi-mode, 50/125
2000
200 m (656.17 ft)
>3500
300 m (984.25 ft)
>5500
400 m (1312.34 ft)
SFP-25G-LR-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-25G-LR-SM1310-I
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Table7-12 SFP28 cables available for the SFP28 ports
SFP28 cable
Cable length
SFP-25G-D-CAB-1M
1 m (3.28 ft)
SFP-25G-D-CAB-3M
3 m (9.84 ft)
SFP-25G-D-CAB-5M
5 m (16.40 ft)
SFP-25G-D-AOC-3M
3 m (9.84 ft)
SFP-25G-D-CAB-4M-A
4 m (13.12 ft)
SFP-25G-D-AOC-5M
5 m (16.40 ft)
SFP-25G-D-AOC-7M
7 m (22.97 ft)
SFP-25G-D-AOC-10M
10 m (32.81 ft)
SFP-25G-D-AOC-20M
20 m (65.62 ft)
Figure7-2 SFP28 cable
(1) Connector
(2) Pull latch
IMPORTANT
IMPORTANT:
The SFP-25G-D-CAB-4M-A cable is not supported by the S5590-24X4YC-EI, S5590-48TS4X2QC-EI, S5590-24UXM4YC-EI, or S5590-48UXM4YC-EI switch.
·     As a best practice, use H3C transceiver modules and cables for the switch.
·     The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff.
·     For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
QSFP+ port
Each LSWM2QP2P interface card or S5590-48TS4X2QC-EI switch provides two QSFP+ ports. You can install the QSFP+ transceiver modules in Table7-13, QSFP+ copper cables in Table7-14, and QSFP+ fiber cables in Table7-15.
Table7-13 QSFP+ transceiver modules available for the QSFP+ ports
Connector
QSFP-40G-SR4-MM850
850
MPO
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-CSR4-MM850
850
MPO
Multi-mode, 50/125
2000
300 m (984.25 ft)
4700
400 m (1312.34 ft)
QSFP-40G-BIDI-SR-MM850
Two lanes:
·     850
·     900
LC
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-BIDI-WDM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
240 m (787.40 ft)
4700
350 m (1148.29 ft)
QSFP-40G-LR4-PSM1310
1310
MPO
Multi-mode, 50/125
N/A
10 km (6.21 miles)
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-40G-ER4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
IMPORTANT
IMPORTANT:
·     The QSFP-40G-SR4-MM850 transceiver module is not supported by the S5590-28T8XC-EI (LS-5590-28T8XC-EI-GL and LS-5590-28T8XC-EI-H3) or S5590-48T4XC-EI (LS-5590-48T4XC-EI-GL and LS-5590-48T4XC-EI-H3) switch with LSWM2QP2P interface cards installed.
·     The QSFP-40G-CSR4-MM850 transceiver module is not supported by the S5590-24X4YC-EI and S5590-48TS4X2QC-EI switches.
Table7-14 40G QSFP+ copper cables available for the QSFP+ ports
QSFP+ copper cable
LSWM1QSTK0
1 m (3.28 ft)
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
Table7-15 40G QSFP+ fiber cables available for the QSFP+ ports
QSFP+ fiber cable
QSFP-40G-D-AOC-3M
3 m (9.84 ft)
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
Figure7-3 40G QSFP+ cable
(1) Connector
(2) Pull tab
QSFP28 ports
QSFP28 ports support the following transceiver modules and cables:
·     QSFP28 transceiver modules in Table7-16.
·     QSFP28 fiber cables in Table7-17.
·     QSFP28 fiber cables in Table7-18.
·     QSFP+ transceiver modules in Table7-13.
·     QSFP+ copper cables in Table7-14.
·     QSFP+ fiber cables in Table7-15.
Table7-16 QSFP28 transceiver modules available for the QSFP28 ports
Connector
Modal bandwidth (MHz*km)
Maximum transmission distance
QSFP-100G-SR4-MM850
850
MPO
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-SR4-MM850-H
850
MPO
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-SWDM4-MM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-eSR4-MM850
850
MPO
Multi-mode, 50/125
4700
300 m (984.25 ft)
QSFP-100G-PSM4-SM1310
1310
MPO
Single-mode, 9/125
N/A
0.5 km (0.31 miles)
QSFP-100G-LR4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-100G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-100G-ER4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
QSFP-100G-ZR4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
QSFP-100G-ER4L-WDM1300
Four lanes:
·     1295
·     1300
·     1304
·     1309
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
Table7-17 100G QSFP28 fiber cables available for the QSFP28 ports
QSFP28 fiber cable
Cable length
QSFP-100G-D-AOC-7M
7 m (22.97 ft)
QSFP-100G-D-AOC-7M-H
7 m (22.97 ft)
QSFP-100G-D-AOC-10M
10 m (32.81 ft)
QSFP-100G-D-AOC-10M-H
10 m (32.81 ft)
QSFP-100G-D-AOC-20M
20 m (65.62 ft)
QSFP-100G-D-AOC-20M-H
20 m (65.62 ft)
Table7-18 100G QSFP28 copper cables available for the QSFP28 ports
QSFP28 copper cable
Cable length
QSFP-100G-D-CAB-1M
1 m (3.28 ft)
QSFP-100G-D-CAB-3M
3 m (9.84 ft)
QSFP-100G-D-CAB-5M
5 m (16.40 ft)
Figure7-4 100G QSFP28 copper cable
(1) Connector
(2) Pull tab
10/100/1000BASE-T Ethernet port
Table7-19 10/100/1000BASE-T Ethernet port specifications
Item
Specification
Connector type
RJ-45
Rate, duplex mode, and auto-MDI/MDI-X
100 m (328.08 ft)
Transmission medium
Category 5 or above twisted pair cable
Compliant standard
Compatible devices
All device models (excluding the S5590-48S4XC-HI and S5590-48S4XC-EI switches)
10G/5G/2.5G/1000BASE-T autosensing Ethernet port
Table7-20 10G/5G/2.5G/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     5 Gbps, full duplex
·     2.5 Gbps, full duplex
·     1 Gbps, full duplex
·     100 Mbps, full duplex
·     10 Mbps, full duplex
10G mode:
·     55 m (180.45 ft) over Category-6 unshielded twisted pair cable
·     100 m (328.08 ft) over Category-6 shielded twisted pair cable
·     100 m (328.08 ft) over Category-6e twisted pair cable
5G mode:
·     55 m (180.45 ft) over Category-5e unshielded twisted pair cable
·     100 m (328.08 ft) over Category-5e shielded twisted pair cable
·     100 m (328.08 ft) over Category-6 twisted pair cable
2.5G mode: 100 m (328.08 ft) over Category-5e or above twisted pair cable
1G/100M/10M mode:
100 m (328.08 ft) over Category-5 or above twisted pair cable
Transmission medium
Compliant standard
IEEE 802.3an and IEEE 802.3ab
Compatible devices
S5590-24UXM4YC-EI, S5590-48UXM4YC-EI
Combo interface
The S5590-28T8XC-HI, S5590-28S8XC-HI, S5590-28T8XC-EI, S5590-28S8XC-EI, and S5590-28P8XC-EI switches each provide four combo interfaces on the front panel. A combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports can operate at a time.
Ports on an LSWM2EC EPS scanner module
Table7-21 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
115200 bps
Transmission medium and max transmission distance
15 m (49.21 ft) over a common asynchronous serial interface cable
Services
Table7-22 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
Supported
Transmission medium
100 m (328.08 ft)
Compliant standard
Connects to a local PC or remote station for network management or software upgrade
Table7-23 USB port specifications
Item
Specification
Port type
USB 3.0
Compliant standard
xHCI
5 Gbps
Uploads or downloads files, such as software image file and configuration file, from the flash file system on the module.
Table7-24 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
RS-232
Services
·     Supports command line interface (CLI)
Table7-25 10/100/1000BASE-T Ethernet copper port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
802.3, 802.3u, and 802.3ab
Port type
Transmission medium
Transmission distance
100 m (328.08 ft)
Rate and duplex mode
Connecting cables to the ports on expansion cards
To connect cables to the ports on expansion cards, follow these guidelines:
·     Do not bundle cables in their first 20 m (65.62 ft).
·     Separate power cords and twisted pair cables at and around the distribution frame.
·     For ports adjacent to one another on the device, the peer ports on the distribution frame is preferably not adjacent, for example:
¡     If the device connects to one distribution frame, connect port 1 on the device to port 1 on the distribution frame and port 2 on the device to port 3 on the distribution frame.
¡     If the device connects to two distribution frames, connect port 1 on the device to port 1 on distribution frame 1 and port 2 on the device to port 1 on distribution frame 2.
·     Keep the device and cables away from the interference source, such as a two-way radio and a high-power variable-frequency drive.
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table7-26 System status LED description
LED mark
Status
SYS
Steady green
The switch has started correctly.
Flashing green (1 Hz)
The switch is performing power-on self test (POST).
Steady red
The switch has failed the POST or is faulty.
Off
The switch is powered off.
Power status LED
For the S5590-EI switch series, the power status LED shows the operating status of a power supply.
Table7-27 Power status LED description
LED mark
Status
PWR1/PWR2
Steady green
The power supply is operating correctly.
Steady yellow
The power supply is present, but it is not operating or is faulty.
Off
No power supply is present.
Mode LED
The mode LED (MODE) works in conjunction with the port status LEDs to show more information about the switch.
The mode LED indicates the type of information that the port status LEDs are showing.
After you press the mode button to change the mode LED status into flashing green or flashing yellow, the mode LED keeps in that state for only 45 seconds and then turns steady green automatically.
Table7-28 Mode LED description
LED mark
Status
MODE
Steady green
The port status LEDs indicate link state of the ports.
Flashing green (available only for PoE switches)
The port status LEDs indicate the PoE status of the ports.
Flashing yellow
The port status LEDs indicate the IRF member ID of the switch. For example, if the LEDs for ports 1 to 4 are steady green and the others are off, the IRF member ID of the switch is 4.
Table7-29 Management Ethernet port LED description
Management Ethernet port LED status
Steady green
A link is present on the port.
Flashing yellow
The port is sending or receiving data.
Off
No link is present on the port.
SFP port LED
The SFP port LEDs work in conjunction and the mode LED to indicate the operating status of SFP ports.
Table7-30 SFP port LED description
Mode LED (MODE) status
SFP port LED status
Steady green (rate mode)
Steady green
The port is operating at 100/1000 Mbps.
Flashing green
The port is sending or receiving data at 100/1000 Mbps.
Off
Flashing yellow (IRF mode)
Steady green
The SFP port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LEDs for ports 1 to 4 are steady green and the others are off, the IRF member ID of the switch is 4.
SFP+ port LED
Table7-31 SFP+ port LED description
Mode LED status
SFP+ port LED status
Steady green
The port is operating at 10 Gbps.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
The port is operating at 1 Gbps.
Flashing yellow
The port is sending or receiving data at 1 Gbps.
Off
Flashing green (PoE mode, available only for PoE switches)
Off
The mode LED (MODE) is operating in PoE mode.
Off
When the mode LED (MODE) is flashing yellow (IRF mode), the SFP+ port LEDs are off.
SFP28 port LED
Table7-32 SFP28 port LED description
LED status
Steady green
The port is operating at 25 Gbps.
Flashing green
The port is sending or receiving data at 25 Gbps.
Steady yellow
Flashing yellow
Off
·     No module has been installed or no link is present on the port.
·     The mode LED is operating in PoE mode (available only for PoE switch models).
QSFP+ port LED
Table7-33 QSFP+ port LED description
LED status
Steady green
A module has been installed and the port is operating at 40 Gbps.
Flashing green
The port is sending or receiving data at 40 Gbps.
Steady yellow
A module has been installed and the port is operating at 10 Gbps.
Flashing yellow
Off
QSFP28 port LED
Table7-34 QSFP28 port LED description
LED status
Steady green
A module has been installed and the port is operating at 100 Gbps.
Flashing green
The port is sending or receiving data at 100 Gbps.
Steady yellow
Flashing yellow
Off
The 10/100/1000BASE-T autosensing Ethernet port LEDs work in conjunction with the mode LED to indicate the operating status of the ports from different aspects, as shown in Table7-35.
Table7-35 10/100/1000BASE-T autosensing Ethernet port LED description
Steady green
The port is operating at 10/100/1000 Mbps.
Flashing green
The port is sending or receiving data at 10/100/1000 Mbps.
Off
Steady green
PoE power supply is normal.
·     The maximum PoE power provided by the port does not meet the power requirement of the PD.
·     PoE power supply overcurrent, overvoltage, or short-circuit has occurred.
·     The remaining power of the switch does not meet the power supply requirement of the port.
Off
The port is not connected to a PD or PoE is not enabled on the port.
Steady green
The autosensing Ethernet port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LEDs for ports 1 to 4 are steady green and the others are off, the IRF member ID of the switch is 4.
10G/5G/2.5G/1000BASE autosensing Ethernet port LED
Table7-36 10G/5G/2.5G/1000BASE autosensing Ethernet port LED description
LED status
Steady green
Flashing green
Steady yellow
The port is operating at 10Mbps, 100Mbps, 1 Gbps, 2.5 Gbps, or 5 Gbps.
Flashing yellow
The port is sending or receiving data at 10Mbps, 100Mbps, 1 Gbps, 2.5 Gbps, or 5 Gbps.
Off
The S5590-HI switch series provides two expansion slots at the rear. The S5590-EI switch series provides one expansion slot at the rear. The expansion card status LED on the front panel indicates the operating status of the expansion card.
Table7-37 Expansion card status LED description
LED mark
Status
SLOT/SLOT1/SLOT2
Steady green
The expansion card is operating correctly.
Flashing yellow
The switch does not support the expansion card model, or the expansion card is faulty.
Off
The expansion slot is empty.
The LSPM1FANSA-SN and LSPM1FANSB-SN fan trays each have a LED to indicate the fan tray operating status.
Table7-38 Fan tray status LED description
Status
On
The fan tray is faulty.
Off
The fan tray is operating correctly.
The PSR250-12A and PSR250-12A1 power supplies each have a LED to indicate the power input and output status.
Table7-39 Description for the status LED on a PSR250-12A/PSR250-12A1 power supply
LED status
Steady green
The power supply is operating correctly in active state.
Flashing green
The power supply is operating correctly in standby state.
Steady red
The power supply has failed or entered protection state.
Red/Green flashing alternatively
The power supply has an output overvoltage, output undervoltage, output overcurrent, output overload, or overtemperature alarm but has not entered protection state.
Flashing red
The power supply does not have power input. If two power supplies are installed and only one power supply has power input, the status LED of the power supply that does not have power input flashes red.
Off
The PSR600-54A-B, PSR920-54A-B, and PSR1600-54A-B power supplies each have two status LEDs to indicate the power input and output status.
Table7-40 Description for the status LEDs on a 600W/920W/1600W power supply
LED
Mark
Status
Output status LED
OUT OK
Steady green
Normal power output.
Steady red
Abnormal power output.
Off
No power output
Input status LED
IN OK
Steady green
Normal power input.
Steady red
Abnormal power input.
Off
No power input.
The LSWM2SP8P and LSWM2SP8PM interface cards each provide eight SFP+ ports.
Table7-41 SFP+ port LED description
LED status
Steady green
Flashing green
Steady yellow
A module has been installed and the port is operating at 1 Gbps.
Flashing yellow
Off
Table7-42 Management port LED description
LED status
Steady green
The port is operating at 1000/100/10 Mbps.
Flashing green
The port is sending or receiving data at 1000/100/10 Mbps.
Off
Table7-43 Description for the LEDs on an LSPM6FWD firewall module
LED
Mark
Status
ACT/LINK
Off
Steady green
Flashing green
System status LED
SYS
Off
No power is input or the firewall module has failed.
Slowly flashing green
The system has started up and is operating correctly.
Fast flashing green
The system is loading software.
8 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
The switch uses removable fan trays and provides airflow from the port side to the power supply side or from the power supply side to the port side by using different types of fan trays. You must install both fan trays of the same model for the switch. Table8-1 describes the fan trays available for the switch.
Table8-1 Fan trays available for the switch
Switch model
Fan tray model
Airflow direction
S5590-28T8XC-HI
S5590-48T4XC-HI
S5590-28S8XC-HI
S5590-48S4XC-HI
S5590-28T8XC-EI
S5590-48T4XC-EI
S5590-28S8XC-EI
S5590-48S4XC-EI
S5590-28P8XC-EI
S5590-48P6XC-EI
S5590-24X4YC-EI
S5590-48TS4X2QC-EI
LSPM1FANSA-SN
From the power supply side to the port side
LSPM1FANSB-SN
From the port side to the power supply side
S5590-24UXM4YC-EI
S5590-48UXM4YC-EI
LSPM1FANSB-SN
Figure8-1 Airflow direction for LSPM1FANSA-SN (S5590-28P8XC-EI)
Figure8-2 Airflow direction for LSPM1FANSB-SN (S5590-28P8XC-EI)
不同款型规格的资料略有差异, 详细信息请向具体销售和400咨询。 H3C保留在没有任何通知或提示的情况下对资料内容进行修改的权利!
