17-Commonly-used commands
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10117-Commonly-used commands
01-Commonly Used Commands on H3C Access Controllers
New H3C Technologies Co., Ltd.
http://www.h3c.com
Document version: 6W101-20230331
Commands
display boot-loader
Use display boot-loader to display current software images and startup software images.
display boot-loader [ slot slot-number ]
slot slot-number: Specifies the member ID of an IRF member device. If you do not specify a member device, this command displays the software images on each IRF member device.
# (IRF not supported) Display the current software images and startup software images.
<Sysname> display boot-loader
Software images on the device:
Current software images:
  flash:/boot.bin
  flash:/system.bin
Main startup software images:
  flash:/boot.bin
  flash:/system.bin
Backup startup software images:
  flash:/boot.bin
  flash:/system.bin
# (IRF supported.) Display the current software images and startup software images.
Software images on slot 1:
  cfa0:/boot.bin
  cfa0:/system.bin
  cfa0:/boot.bin
  cfa0:/system.bin
  cfa0:/boot.bin
  cfa0:/system.bin
Software images that have been loaded.
Primary software images for the next startup.
Backup software images for the next startup.
boot-loader file
display cloud-management state
Use display cloud-management state to display cloud connection state information.
# Display cloud connection state information.
<Sysname> display cloud-management state
Cloud connection state                      : Established
Device state                                : Request_success
Cloud server address                        : 101.36.161.141
Cloud server domain name                    : oasis.h3c.com
Cloud connection mode                       : Https
Cloud server port                           : 19443
Connected at                                : Wed Jan 27 14:18:40 2018
Duration                                    : 00d 00h 02m 01s
Process state                               : Message received
Failure reason                              : N/A
Last down reason                            : socket connection error (Details:N/A)
Last down at                                : Wed Jan 27 13:18:40 2018
Last report failure reason                  : N/A
Last report failure at                      : N/A
Dropped packets after reaching buffer limit : 0
Total dropped packets                       : 1
Last report incomplete reason               : N/A
Last report incomplete at                   : N/A
Buffer full count                           : 0
Cloud connection state: Unconnected, Request, and Established.
Device state
Local device state:
·     Idle—In idle state.
·     Connecting—Connecting to the cloud server.
·     Request_CAS_url—Sent a central authentication service (CAS) URL request.
·     Request_CAS_url_success—Requesting CAS URL succeeded.
·     Request_CAS_TGT—Sent a ticket granting ticket (TGT) request.
·     Request_CAS_TGT_success—Requesting TGT succeeded.
·     Request_CAS_ST—Sent a service ticket (ST) request.
·     Request_CAS_ST_success—Requesting ST succeeded.
·     Request_cloud_auth—Sent an authentication request.
·     Request_cloud_auth_success—Authentication succeeded.
·     Register—Sent a registration request.
·     Register_success—Registration succeeded.
·     Request—Sent a handshake request.
·     Request_success—Handshake succeeded.
IP address of the cloud server.
Domain name of the cloud server.
Cloud server port
TCP port number used to establish cloud connections.
Connected at
Time when the cloud connection was established.
Duration
Duration since the establishment of the cloud connection.
Process state
Cloud connection processing state:
·     DNS not parsed.
·     DNS parsed.
·     Message not sent.
·     Message sent.
·     Message not received.
·     Message received.
Failure reason
Cloud connection failure reason:
·     DNS parse failed.
·     Socket connection failed.
·     SSL creation failed.
·     Sending CAS url request failed.
·     Sending CAS TGT failed.
·     Sending CAS ST failed.
·     Sending cloud auth failed.
·     Sending register failed.
·     Processing CAS url response failed.
·     Processing CAS TGT response failed.
·     Processing CAS ST response failed.
·     Processing cloud auth response failed.
·     Processing register response failed.
·     Sending handshake request failed.
·     Processing handshake failed.
·     Sending websocket request failed.
·     Processing websocket packet failed.
Last down reason
Reason for the most recent cloud connection interruption:
·     Device or process rebooted.
·     Socket connection error.
·     Configuration changed.
·     Received websocket close packet from cloud.
·     Keepalive expired.
·     Packet processing failed.
·     Main connection went down.
·     Cloud reset connection.
·     Memory reached threshold.
This field displays N/A if the detailed reason of the most recent disconnection cannot be obtained.
Last down at
Time when the cloud connection went down most recently.
Reason for the most recent cloud connection packet sending failure:
·     Tunnel is being deleted.
·     Tunnel socket is invalid.
·     Failed to convert string to json.
·     Failed to convert json to string.
·     Failed to create message node.
·     Tunnel is not ready.
·     Failed to create packet buffer.
·     SSL sending failure.
If the reason is SSL sending failure, one of the following detailed reason will be displayed:
·     ssl error none.
·     ssl error ssl.
·     ssl error read.
·     ssl error write.
·     ssl error x509 lookup.
·     ssl error syscall.
·     ssl error zero return.
·     ssl error connect.
·     ssl error accept.
Time when the most recent cloud connection packet sending failure occurred.
Number of packets that are dropped because the CMTNL buffer limit is reached.
Total number of dropped packets.
Reason for the most recent unfinished packet sending:
·     Interrupted system call.
·     Socket buffer is full.
Time when the most recent unfinished packet sending occurred.
Buffer full count
Number of times that the buffer becomes full.
display dot1x connection
Use display dot1x connection to display information about online 802.1X users.
display dot1x connection [ ap ap-name [ radio radio-id ] | slot slot-number | user-mac mac-addr | user-name name-string ]
ap ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). If you do not specify an AP, this command displays information about online 802.1X users for all APs.
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command displays information about online 802.1X users for all radios on the specified AP.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays online 802.1X user information for all member devices.
user-mac mac-address: Specifies an 802.1X user by MAC address. The mac-address argument represents the MAC address of the user, in the form of H-H-H. If you do not specify an 802.1X user, this command displays online user information for all 802.1X users.
user-name name-string: Specifies an 802.1X user by its name. The name-string argument represents the username, a case-sensitive string of 1 to 253 characters. If you do not specify an 802.1X user, this command displays online user information for all 802.1X users.
If you do not specify any parameters, this command displays information about online 802.1X users for all member devices.
# Display all online 802.1X user information.
<Sysname> display dot1x connection
Total connections: 1
Slot ID: 1
Username: ias
Authentication domain: h3c
IPv4 address: 192.168.1.1
Authentication method: CHAP
Initial VLAN: 1
Authorization untagged VLAN: N/A
Authorization tagged VLAN list: 1 to 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 29 31 33
                                35 37 40 to 100
Authorization ACL ID: 3001
Termination action: Default
Session timeout period: 2 s
Online from: 2013/03/02  13:14:15
Online duration: 0h 2m 15s
Level flow statistic             :
Level-0     Sent packets/bates  : 1/54
        Received packets/bates  : 0/0
Level-1     Sent packets/bates  : 0/0
        Received packets/bates  : 45/1248
User MAC address                : 0015-e9a6-7cfe
AP name                         : ap1
Radio ID                        : 1
SSID                            : wlan_dot1x_ssid
BSSID                           : 0015-e9a6-7cf0
User name                       : ias
Authentication domain           : 1
IPv4 address                    : 192.168.1.1
IPv6 address                    : 2000:0:0:0:1:2345:6789:abcd
Authentication method           : CHAP
Initial VLAN                    : 1
Authorization VLAN              : N/A
Authorization ACL number        : 3001
Authorization user profile      : N/A
Authorization CAR               :
  Average input rate            : 102400 bps
  Average output rate           : 102400 bps
Authorization URL               : http://oauth.h3c.com
Authorization IPv6 URL          : N/A
Termination action              : Default
Session timeout period          : 2 sec
Online from                     : 2013/03/02 13:14:15
Online duration                 : 0 h 2 m 15 s
Total 1 connections matched.
Total connections
Number of online 802.1X users.
User MAC address
MAC address of the user.
Access interface
Interface through which the user access the device.
AP name
Name of the AP with which the user is associated.
Radio ID
ID of the radio with which the user is associated.
SSID
SSID with which the user is associated.
BSSID
ID of the BSS with which the user is associated.
ISP domain used for 802.1X authentication.
IPv4 address
IPv4 address of the user.
If the device does not get the IPv4 address of the user, this field is not available.
IPv6 address
IPv6 address of the user.
If the device does not get the IPv6 address of the user, this field is not available.
EAP message handling method:
·     CHAP—Performs EAP termination and uses CHAP to communicate with the RADIUS server.
·     EAP—Relays EAP packets and supports any of the EAP authentication methods to communicate with the RADIUS server.
·     PAP—Performs EAP termination and uses PAP to communicate with the RADIUS server.
Initial VLAN
VLAN to which the user belongs before 802.1X authentication.
Untagged VLAN authorized to the user.
Tagged VLANs authorized to the user.
Number of the ACL authorized to the user.
User profile authorized to the user.
Authorization CAR
Authorization CAR attributes assigned by the server.
·     Average input rate—Average rate of inbound traffic in bps.
·     Average output rate—Average rate of outbound traffic in bps.
If no authorization CAR attributes are assigned, this field displays N/A.
Authorization URL
Authorization redirect URL.
Authorization IPv6 redirect URL.
Termination action
Action attribute assigned by the server to terminate the user session:
·     Default—Logs off the online authenticated 802.1X user when the session timeout timer expires. This attribute does not take effect when 802.1X periodic reauthentication is enabled and the periodic reauthentication timer is shorter than the session timeout timer.
·     Radius-request—Reauthenticates the online user when the session timeout timer expires, regardless of whether the 802.1X periodic reauthentication feature is enabled or not.
If the device performs local authentication, this field displays N/A.
Session timeout timer assigned by the server.
Online from
Time from which the 802.1X user came online.
Online duration
Online duration of the 802.1X user.
Statistics about traffic flows at each accounting level:
·     Level-n—Traffic accounting level. Available levels include level-0 to level-8. Accounting levels are defined in the WLAN accounting policy.
·     Sent packets/bytes—Number of sent packets and bytes.
·     Received packets/bytes—Number of received packets and bytes.
This field is not displayed for a user if no WLAN accounting policy has been assigned to the user.
This field does not display statistics for an accounting level if no traffic of that level has been sent or received.
display irf
Use display irf to display IRF information.
display irf
# Display IRF information.
<Sysname> display irf
Member ID  Role     Priority    CPU MAC           Description
   1        Loading  1            00e0-fcbe-3102    F1Num001
 *+2        Master   1            00e0-fcb1-ade2    F1Num002
The asterisk (*) indicates the master.
The plus sign (+) indicates the device through which you are logged in.
The right angle bracket (>) indicates the device's stack capability is disabled.
Bridge MAC of the IRF: 00e0-fc00-1000
Auto upgrade             : Disabled
MAC persistence          : Disabled
Topo-domain ID           : 30
Auto merge               : Enabled
Member ID
IRF member ID:
·     A prefix of asterisk sign (*) indicates the master device.
·     A prefix of plus sign (+) indicates the device where you are logged in.
·     A prefix of right angle bracket (>) indicates the device that has been temporarily removed from the IRF fabric by using the undo irf member stack enable command.
Role
Role of the member device in the IRF fabric:
·     Master—Master device.
·     Standby—Standby device.
·     Loading—The device is loading software images.
Priority
IRF member priority.
CPU MAC
MAC address of the CPU in the device.
Description you have configured for the member device.
·     If no description is configured, this field displays a dashed line (---).
·     If the description exceeds the maximum number of characters that can be displayed, an ellipsis (…) is displayed in place of the exceeding text. To display the complete description, use the display current-configuration command.
Bridge MAC address of the IRF fabric.
Auto upgrade
Status of the software auto-update feature:
·     Enabled.
·     Disabled.
MAC persistence
IRF bridge MAC persistence setting:
·     6 min—Bridge MAC address of the IRF fabric remains unchanged for 6 minutes after the address owner leaves.
·     Always—Bridge MAC address of the IRF fabric does not change after the address owner leaves.
·     Disabled—Bridge MAC address of the current master replaces the original bridge MAC address as soon as the owner of the original address leaves.
Topo-domain ID
Topo-domain ID of the IRF fabric. The topo-domain ID you assign to an IRF fabric must uniquely identify the IRF fabric in a multi-IRF network.
Auto merge
Status of the auto-merge feature:
·     Enabled.
·     Disabled.
display irf configuration
Use display irf configuration to display IRF settings for each member device in an IRF fabric.
# Display IRF settings on all member devices.
<Sysname> display irf configuration
The New ID, Topo-domain, Stack, and Member interfaces fields display settings for the next startup.
Member ID   New ID   Topo-domain        Stack    Member interfaces
1            1         0                     Enabled  Disabled
Table 5 Command output
Member ID
Current IRF member ID of the device.
New ID
IRF member ID assigned to the device. This member ID takes effect at reboot.
Topo-domain
IRF topo-domain ID. The topo-domain ID takes effect at reboot.
Stack
Whether multimember stacking capability is enabled:
·     Enabled—The device can form an IRF fabric with other member devices.
·     Disabled—The device cannot form an IRF fabric with other member devices. The device will be removed from the IRF fabric in a maximum of 5 seconds.
Member interfaces
Network interfaces bound to the IRF port. This field displays Disabled if no network interfaces have been bound to the IRF port.
The channel type of each IRF link is enclosed in brackets. Available channel types include:
·     ctrl—Control channel.
·     data—Data channel.
·     ctrl&data—Hybrid channel.
display irf forwarding
Use display irf forwarding to display information about the IRF hello packets received on a member device.
display irf forwarding [ slot slot-number ]
slot slot-number: Specifies a member device by its IRF member ID. The member ID is in the range of 0 to 255. If you do not specify a member device, this command displays information about the IRF hello packets received on the master.
# Display information about the IRF hello packets received on the master.
<Sysname> display irf forwarding
Member ID      CPU MAC              Hello timeout (sec)
1               00e0-fc0f-8c02      5
2               00e0-fc0f-8c04      5
# Display information about the IRF hello packets received on member device 2.
<Sysname> display irf forwarding slot 2
2               00e0-fc0f-8c04      5
1               00e0-fc0f-8c02      4
Table 6 Command output
Member ID
IRF member ID of the packet sender.
CPU MAC
CPU MAC address of the packet sender.
Hello timeout (sec)
The remaining amount of time before the hello packet times out, in seconds. If a new hello packet is not received before the existing hello packet expires, the member device determines that the sender has left the IRF fabric. If a new hello packet is received before the existing hello packet expires, the device refreshes the hello timeout time for the sender based on the received packet.
display irf link
Use display irf link to display IRF link information.
display irf link
# Display IRF link information.
<Sysname> display irf link
Member ID     Member interfaces                   Status
1             Disabled                            --
Table 7 Command output
Member ID
IRF member ID.
Member interfaces
Status
Link status of the network interface:
·     Up—The link is up.
·     Down—The link is down.
·     ADM—The interface has been manually shut down by using the shutdown command.
·     Blocked—The link is blocked. In this state, the device cannot join an IRF fabric.
This field displays two hyphens (--) if no network interfaces are bound to the IRF port.
display license
Use display license to display detailed license information.
display license [ activation-file | activation-key ] [ slot slot-number ]
activation-file: Displays license information about activation files.
activation-key: Displays information about activation keys.
slot slot-number: Specifies the member ID of an IRF member device. If no member device is specified, this command displays license information for all IRF member devices.
If you do not specify any parameters, this command displays detailed information about all licenses.
# Display detailed information about all licenses.
<Sysname> display license
cfa0:/license/210235A1AMB1450000272015052317092592481.ak
Feature: APMGR
Product Description: Enhanced Access Controller License,128 APs,for Verticals,for V7 Registered at: 2015-05-28 16:54:24
License Type: Trial (days restricted)
Trial Time Left (days): 30
Current State: In use
Pre-installed License
Feature: APMGR
Feature Description: PreAtom This is APMGR license
Time Left (days): 0
Current State: Expired
Table 8 Command output
Feature
Feature name.
Product Description
License description.
Registered at
Time when the license was installed.
License Type
License type by validity period:
·     NA—The system cannot obtain the license type.
·     Permanent—Purchased license that never expires and is always valid.
·     Days restricted—Purchased license that is valid for a period of days, for example, 30 days.
·     Trial (days restricted)—Free trial license that is valid for a period of days.
Time Left (days)
Remaining days of the license. This field is available for a purchased license.
Remaining days of the trial period. This field is available for a trial license.
Current State
State of the license:
·     In use—The license is being used.
·     Usable—The license is available for use.
¡     If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state.
¡     A date restricted license is in this state if its start date is not reached.
·     Expired—The license has expired.
·     Uninstalled—The license has been uninstalled.
·     Unusable—The license cannot be used.
·     Invalid—The license is invalid and cannot be used.
Uninstall Key
This field is available for licenses that have been uninstalled.
Uninstall Date
Date when the activation file was uninstalled.
display license device-id
Use display license device-id to display SN and DID information.
display license device-id slot slot-number
When you register a license for a device, you must provide its unique SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
# Display the device SN and DID.
<Sysname> display license device-id
SN: 210235A0VSB011000029
SN CHECK_SUM: FFFFFFEA
Device ID: cfa0:/license/210235A0VSB011000029.did
display license feature
Use display license feature to display brief license information for features.
# Display brief feature license information.
<Sysname> display license feature
Total: 128  Usage: 2
Feature                         Licensed        State
APMGR                           Y                 Trial
Table 9 Command output
Total
Total number of licenses that can be installed.
Usage
Number of licenses stored in the license storage.
Feature
Feature that must be licensed before being used.
Licensed
Licensing state of the feature:
·     N—Not licensed.
·     Y—Licensed.
License type by purchasing state:
·     Formal—Purchased license.
·     Trial—Trial license.
·     Pre-licensed—Pre-installed license.
If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license file.
display portal user
Use display portal user to display information about portal users.
display portal user { all | ap ap-name [ radio radio-id ] | auth-type { cloud | email | facebook | local | mac-trigger | normal | qq | wechat } | interface interface-type interface-number | ip ip-address | ipv6 ipv6-address | mac mac-address | pre-auth [ interface interface-type interface-number | ip ip-address | ipv6 ipv6-address ] | username username } [ brief | verbose ]
all: Displays information about all portal users.
ap ap-name: Specifies an AP by its name, a case-insensitive string of 1 to 64 characters. Valid characters are letters, digits, underscores (_), left brackets ([), right brackets (]), slashes (/), and minus signs (-).
radio radio-id: Specifies a radio by its ID. The value range for the radio-id argument varies by AP model. If you do not specify a radio, this command displays information about portal users for all radios of the AP.
auth-type: Specifies an authentication type.
cloud: Specifies the cloud authentication (a cloud portal authentication server performs portal authentication on portal users).
email: Specifies the email authentication.
facebook: Specifies the Facebook authentication.
local: Specifies the local authentication (a local portal authentication server performs portal authentication on portal users).
mac-trigger: Specifies the MAC-trigger authentication.
normal: Specifies the normal authentication (a remote portal authentication server performs portal authentication on portal users).
qq: Specifies QQ authentication.
wechat: Specifies WeChat authentication.
interface interface-type interface-number: Displays information about portal users on the specified interface.
ip ipv4-address: Specifies the IPv4 address of a portal user.
ipv6 ipv6-address: Specifies the IPv6 address of a portal user.
mac mac-address: Specifies the MAC address of a portal user, in the format of H-H-H.
username username: Specifies the username of a portal user, a case-sensitive string of 1 to 253 characters. The username cannot contain the domain name.
pre-auth: Displays information about users before portal authentication is performed. If you do not specify this keyword, the command displays information about portal users.
brief: Displays brief information about portal users.
verbose: Displays detailed information about portal users.
If you specify neither the brief nor the verbose keyword, this command displays portal authentication-related information for portal users.
# Display information about all portal users.
<Sysname> display portal user all
Total portal users: 1
Username: def
  AP name: ap1
  Radio ID: 1
  SSID: portal
  Portal server: pts
  State: Online
  VPN instance: vpn1
  MAC                IP                 VLAN   Interface
  000d-88f8-0eac     4.4.4.4            2      Bss1/2
  Authorization information:
    DHCP IP pool: N/A
    User profile: N/A
    Session group profile: N/A
    ACL number: 3000
    Inbound CAR: CIR 9000       bps PIR 20500      bps
                   CBS 20500      bit (active, AAA)
    Outbound CAR: CIR 9000       bps PIR 20400      bps
                  CBS 20400      bit (active, AAA)
    Web URL: http://1.1.1.1
# Display information about portal users whose authentication type is normal authentication.
<Sysname> display portal user auth-type normal
Total remote users: 1
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
  000d-88f8-0eab     2.2.2.2            2      WLAN-BSS1/0/1
    DHCP IP pool: N/A
    User profile: abc (active, OAuth)
    Session group profile: cd (inactive, OAuth)
    ACL number: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
# Display information about the portal user whose MAC address is 000d-88f8-0eab.
<Sysname> display portal user mac 000d-88f8-0eab
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    Session group profile: cd (inactive, AAA)
    ACL number: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
# Display information about the portal user whose username is abc.
<Sysname> display portal user username abc
Username: abc
  Portal server: pts
  State: Online
  VPN instance: N/A
    DHCP IP pool: N/A
    ACL number: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Table 10 Command output
Total portal users
Total number of portal users.
Total normal users
Total number of portal users whose authentication type is normal authentication.
Total local users
Total number of portal users whose authentication type is local authentication.
Total email users
Total number of portal users whose authentication type is email authentication.
Total cloud users
Total number of portal users whose authentication type is cloud authentication.
Total QQ users
Total number of portal users whose authentication type is QQ authentication.
Total WeChat users
Total number of portal users whose authentication type is WeChat authentication.
Total facebook users
Total number of portal users whose authentication type is Facebook authentication.
Total MAC-trigger users
Total number of portal users whose authentication type is MAC-trigger authentication.
Username
Name of the user.
Portal server
Name of the portal authentication server.
Current state of the portal user:
·     Initialized—The user is initialized and ready for authentication.
·     Authenticating—The user is being authenticated.
·     Waiting SetRule—Deploying portal rules to the user.
·     Authorizing—The user is being authorized.
·     Online—The user is online.
·     Waiting Traffic—Waiting for traffic from the user.
·     Stop Accounting—Stopping accounting for the user.
·     Done—The user is offline.
VPN instance
MPLS L3VPN the portal user belongs to. If the portal user is on a public network, this field displays N/A.
MAC
MAC address of the portal user.
IP
IP address of the portal user.
VLAN
VLAN where the portal user resides.
Access interface of the portal user.
Authorization information for the portal user.
DHCP IP pool
Name of the authorized IP address pool. If no IP address pool is authorized for the portal user, this field displays N/A.
User profile
Authorized user profile:
·     N/A—No user profile is authorized.
·     active, AAA—The AAA server has authorized the user profile successfully.
·     inactive, AAA—The AAA server failed to authorize the user profile or the user profile does not exist on the device.
·     active, OAuth—The OAuth server has authorized the user profile successfully.
·     inactive, OAuth—The OAuth server failed to authorize the user profile.
Authorized session group profile:
·     N/A—No session group profile is authorized.
·     active, AAA—The AAA server has authorized the session group profile successfully.
·     inactive, AAA—The AAA server failed to authorize the session group profile or the session group profile does not exist on the device.
·     active, OAuth—The OAuth server has authorized the session group profile successfully.
·     inactive, OAuth—The OAuth server failed to authorize the session group profile.
ACL number/name
Number or name of the authorized ACL:
·     N/A—No ACL is authorized.
·     active, AAA—The AAA server has authorized the ACL successfully.
·     inactive, AAA—The AAA server failed to authorize the ACL or the ACL does not exist on the device.
·     active, OAuth—The OAuth server has authorized the ACL successfully.
·     inactive, OAuth—The OAuth server failed to authorize the ACL.
Inbound CAR
Authorized inbound CAR information:
·     N/A—No inbound CAR is authorized.
·     CIR—Committed information rate in bps.
·     PIR—Peak information rate in bps.
·     CBS—Committed burst size in bits.
·     active, AAA—The AAA server has authorized the inbound CAR successfully.
·     inactive, AAA—The AAA server failed to authorize the inbound CAR.
·     active, OAuth—The OAuth server has authorized the inbound CAR successfully.
·     inactive, OAuth—The OAuth server failed to authorize the inbound CAR.
Outbound CAR
Authorized outbound CAR information:
·     N/A—No outbound CAR is authorized.
·     active, AAA—The AAA server has authorized the outbound CAR successfully.
·     inactive, AAA—The AAA server failed to authorize the outbound CAR.
·     active, OAuth—The OAuth server has authorized the outbound CAR successfully.
·     inactive, OAuth—The OAuth server failed to authorize the outbound CAR.
Web URL
Authorized Web URL. This field displays N/A if no Web URL is authorized.
# Display detailed information about the portal user whose IP address is 18.18.0.20.
<Sysname> display portal user ip 18.18.0.20 verbose
Basic:
AP name: ap1
  Radio ID: 1
  SSID: portal
  Current IP address: 18.18.0.20
  Original IP address: 18.18.0.20
  Username: chap1
  User ID: 0x10000001
  Access interface: WLAN_BSS1/0/1
  Service-VLAN/Customer-VLAN: 50/-
  MAC address: 7854-2e1c-c59e
  Authentication type: Normal
  Domain name: portal
  VPN instance: N/A
  Status: Online
  Portal server: pt
  Vendor: Apple
  Portal authentication method: Direct
AAA:
  Realtime accounting interval: 720s, retry times: 5
  Idle cut: N/A
  Session duration: 0 sec, remaining: 0 sec
  Remaining traffic: N/A
  Online duration (hh:mm:ss): 1:53:7
  Login time: 2014-12-25 10:47:53 UTC
  DHCP IP pool: N/A
ACL&QoS&Multicast:
  Inbound CAR: N/A
  Outbound CAR: N/A
  ACL number/name: N/A
  User profile: N/A
  Max multicast addresses: 4
Traffic statistic:
  Uplink packets/bytes: 6/412
  Downlink packets/bytes: 0/0
Dual-stack traffic statistics:
  IPv4 address: 18.18.0.20
            Uplink   packets/bytes: 3/200
  IPv6 address: 2001::2
            Uplink   packets/bytes: 3/212
Accounting-separate traffic statistics:
  18.18.0.20:
  2001::2:
  2001::3:
            Uplink   packets/bytes: 4/300
  2001::4:
Table 11 Command output
Current IP address
IP address of the portal user after passing authentication.
Original IP address
IP address of the portal user during authentication.
Username
Name of the portal user.
User ID
Portal user ID.
Access interface
Public VLAN/Private VLAN to which the portal user belongs. If no VLAN is configured for the portal user, this field displays -/-.
MAC address
Authentication type
Type of portal authentication:
·     Normal—Normal authentication.
·     Local—Local authentication.
·     Email—Email authentication.
·     Cloud—Cloud authentication.
·     QQ—QQ authentication.
·     WeChat—WeChat authentication.
·     Facebook—Facebook authentication.
·     MAC-trigger—MAC-trigger authentication.
Domain
ISP domain name for portal authentication.
VPN instance
MPLS L3VPN to which the portal user belongs. If the portal user is on a public network, this field displays N/A.
Status
Status of the portal user:
Portal server
Name of the portal server.
Vendor
Vendor name of the endpoint.
Portal authentication method on the access interface.
The value Direct indicates direct authentication.
AAA
AAA information about the portal user.
Interval for sending real-time accounting updates, and the maximum number of accounting attempts. If the real-time accounting is not authorized, this field displays N/A.
Idle-cut
Idle timeout period and the minimum traffic threshold. If idle-cut is not authorized, this field displays N/A.
Session duration
Session duration and the remaining session time. If the session duration is not authorized, this field displays N/A.
Remaining traffic
Remaining traffic for the portal user. If the remaining traffic is not authorized, this field displays N/A.
Login time
Time when the user logged in. The field uses the device time format, for example, 2023-1-19  2:42:30 UTC.
DHCP IP pool
Authorized DHCP IP address pool. If no DHCP IP address pool is authorized for the portal user, this field displays N/A.
Web URL
Authorized Web URL. If no Web URL is authorized for the portal user, this field displays N/A.
Inbound CAR
Outbound CAR
ACL number/name
·     N/A—No ACL is authorized..
User profile
Maximum number of multicast groups the portal user can join.
Multicast address list
Multicast group list the portal user can join. If no multicast group is authorized, this field displays N/A.
Traffic statistic
Traffic statistics for the portal user.
Packet and byte statistics of the upstream traffic.
Packet and byte statistics of the downstream traffic.
IPv4 and IPv6 traffic statistics for the dual-stack user.
Traffic statistics of dual-stack users or users with multiple IPv6 addresses.
IPv4 address
IPv4 address of the portal user.
IPv6 address
IPv6 address of the portal user.
# Display brief information about all portal users.
<Sysname> display portal user all brief
IP address       MAC address       Online duration       Username
4.4.4.4          000d-88f8-0eac    1:53:7                def
Table 12 Command output
IP address
MAC address
Online duration
Online duration of the portal user, in hh:ss:mm.
Username
Username of the portal user.
portal enable
display process cpu
Use display process cpu to display CPU usage of all processes.
display process cpu [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays CPU usage of all processes on the master device.
cpu cpu-number: Specifies a CPU by its number.
# Display CPU usage of all processes.
<Sysname> display process cpu
CPU utilization in 5 secs: 16.8%; 1 min: 4.7%; 5 mins: 4.7%
    JID      5Sec      1Min      5Min    Name
      1      0.0%      0.0%      0.0%    scmd
      2      0.0%      0.0%      0.0%    [kthreadd]
      3      0.1%      0.0%      0.0%    [ksoftirqd/0]
      4      0.0%      0.0%      0.0%    [watchdog/0]
      5      0.0%      0.0%      0.0%    [events/0]
      6      0.0%      0.0%      0.0%    [khelper]
     29      0.0%      0.0%      0.0%    [kblockd/0]
     49      0.0%      0.0%      0.0%    [vzmond]
     52      0.0%      0.0%      0.0%    [pdflush]
     53      0.0%      0.0%      0.0%    [pdflush]
     54      0.0%      0.0%      0.0%    [kswapd0]
    110      0.0%      0.0%      0.0%    [aio/0]
    712      0.0%      0.0%      0.0%    [mtdblockd]
    719      0.0%      0.0%      0.0%    [TNetJob]
    720      0.0%      0.0%      0.0%    [TMTH]
    727      0.0%      0.0%      0.0%    [CF]
    730      0.0%      0.0%      0.0%    [DIBC]
    752      0.0%      0.0%      0.0%    [lipc_topology]
    762      0.0%      0.0%      0.0%    [MNET]
    763      0.0%      0.0%      0.0%    [SYSM]
---- More ----
Table 13 Command output
System CPU usage within the last 5 seconds, 1 minute, and 5 minutes.
JID
Job ID of a process. It never changes.
5Sec
CPU usage of the process within the last 5 seconds.
1Min
CPU usage of the process within the last minute.
5Min
CPU usage of the process within the last 5 minutes.
Name
Name of the process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process memory
Use display process memory to display memory usage of all user processes.
display process memory [ slot slot-number [ cpu cpu-number ] ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays memory usage of all user processes on the master device.
When a user process starts, it requests the following types of memory from the system:
·     Text memory—Stores code for the user process.
·     Data memory—Stores data for the user process.
·     Stack memory—Stores temporary data.
·     Dynamic memory—Heap memory dynamically assigned and released by the system according to the needs of the user process. To view dynamic memory information, execute the display process memory heap command.
# Display memory usage for all user processes.
<Sysname> display process memory
   JID       Text      Data      Stack    Dynamic    Name
1         156       9844         32        1256    scmd
891           8     431052          40      43124    drvuserd
914          32       1248          20         980    lipcd
915          24       1228          16         968    eventd
917          40    1343908          36     281696    forward
922         136      10220          20       1136    fsd
---- More ----
Table 14 Command output
JID
Text
Text memory used by the user process, in KB. The value for a kernel thread is 0.
Data
Data memory used by the user process, in KB. The value for a kernel thread is 0.
Stack
Stack memory used by the user process, in KB. The value for a kernel thread is 0.
Dynamic
Dynamic memory used by the user process, in KB. The value for a kernel thread is 0.
Name
Name of the user process. If square brackets ([ ]) exist in a process name, the process is a kernel thread.
display process memory heap address
display process memory heap size
display wips sensor
Use display wips sensor to display information about all sensors.
display wips sensor
# Display information about all sensors.
<Sysname> display wips sensor
Total number of sensors: 1
Sensor ID    Sensor name                VSD name               Radio ID   Status
3            ap1                        aaa                    1          Active
Table 15 Command output
VSD name
Name of the VSD to which the AP belongs.
Radio ID
ID of the radio enabled with WIPS.
Status
Status of the sensor:
·     Active—The sensor is enabled with WIPS.
·     Inactive—The sensor is not enabled with WIPS.
display wips statistics
Use display wips statistics to display WLAN attack detection statistics collected from sensors.
display wips statistics [ receive | virtual-security-domain vsd-name ]
receive: Displays attack detection statistics information for all VSDs.
virtual-security-domain vsd-name: Displays attack detection statistics information for the specified VSD. The vsd-name argument represents the name of a VSD, a case-sensitive string of 1 to 63 characters.
# Display attack detection statistics information for all VSDs.
<Sysname> display wips statistics receive
Information from sensor 3
 Information about attack statistics:
   Detected association-request flood messages: 0
   Detected authentication flood messages: 0
   Detected beacon flood messages: 0
   Detected block-ack flood messages: 0
   Detected cts flood messages: 0
   Detected deauthentication flood messages: 0
   Detected disassociation flood messages: 0
   Detected eapol-start flood messages: 0
   Detected null-data flood messages: 0
   Detected probe-request flood messages: 0
   Detected reassociation-request flood messages: 0
   Detected rts flood messages: 0
   Detected eapol-logoff flood messages: 0
   Detected eap-failure flood messages: 0
   Detected eap-success flood messages: 0
   Detected duplicated-ie messages: 0
   Detected fata-jack messages: 0
   Detected illegal-ibss-ess messages: 0
   Detected invalid-address-combination messages: 0
   Detected invalid-assoc-req messages: 0
   Detected invalid-auth messages: 0
   Detected invalid-deauth-code messages: 0
   Detected invalid-disassoc-code messages: 0
   Detected invalid-ht-ie messages: 0
   Detected invalid-ie-length messages: 0
   Detected invalid-pkt-length messages: 0
   Detected large-duration messages: 0
   Detected null-probe-resp messages: 0
   Detected overflow-eapol-key messages: 0
   Detected overflow-ssid messages: 0
   Detected redundant-ie messages: 0
   Detected AP spoof AP messages: 0
   Detected AP spoof client messages: 0
   Detected AP spoof ad-hoc messages: 0
   Detected ad-hoc spoof AP messages: 0
   Detected client spoof AP messages: 0
   Detected weak IV messages: 0
   Detected excess AP messages: 0
   Detected excess client messages: 0
   Detected signature rule messages: 0
   Detected 40MHZ messages: 0
   Detected power save messages: 0
   Detected omerta messages: 0
   Detected windows bridge messages: 0
   Detected soft AP messages: 0
   Detected broadcast disassoc messages: 2
   Detected broadcast deauth messages: 0
   Detected AP impersonate messages: 0
   Detected HT greenfield messages: 0
   Detected association table overflow messages: 0
   Detected wireless bridge messages: 0
   Detected AP flood messages: 11
Table 16 Command output
Information from sensor n
Information collected from sensor n, where n represents the ID of the sensor.
Number of detected messages for association request flood attacks.
Number of detected messages for authentication request flood attacks.
Number of detected messages for beacon flood attacks.
Number of detected messages for Block Ack flood attacks.
Number of detected messages for CTS flood attacks.
Number of detected messages for deauthentication flood attacks.
Number of detected messages for disassociation flood attacks.
Number of detected messages for EAPOL-start flood attacks.
Number of detected messages for null data flood attacks.
Number of detected messages for probe request flood attacks.
Number of detected messages for reassociation request flood attacks.
Number of detected messages for RTS flood attacks.
Number of detected messages for EAPOL-logoff flood attacks.
Number of detected messages for EAP-failure flood attacks.
Number of detected messages for EAP-success flood attacks.
Number of detected messages for malformed packets with duplicated IE.
Number of detected messages for FATA-Jack malformed packets.
Number of detected messages for malformed packets with abnormal IBSS and ESS setting.
Number of detected messages for malformed packets with invalid source address.
Number of detected messages for malformed association request frames.
Number of detected messages for malformed authentication request frames.
Number of detected messages for malformed packets with invalid deauthentication code.
Number of detected messages for malformed packets with invalid disassociation code.
Number of detected messages for malformed packets with malformed HT IE.
Number of detected messages for malformed packets with invalid IE length.
Number of detected messages for malformed packets with invalid packet length.
Number of detected messages for malformed packets with oversized duration.
Number of detected messages for malformed probe response frames.
Number of detected messages for malformed packets with oversized EAPOL key.
Number of detected messages for malformed packets with oversized SSID.
Number of detected messages for malformed packets with redundant IE.
Number of detected messages for AP spoofing (AP spoofs AP) attacks.
Number of detected messages for client spoofing (AP spoofs client) attacks.
Number of detected messages for Ad hoc spoofing (AP spoofs Ad hoc) attacks.
Number of detected messages for AP spoofing (Ad hoc spoofs AP) attacks.
Number of detected messages for AP spoofing (client spoofs AP) attacks.
Number of detected messages for weak IVs.
Number of detected messages for AP entry attacks.
Number of detected messages for client entry attacks.
Number of detected messages for clients disabled with the 40 MHz bandwidth mode.
Number of detected messages for power saving attacks.
Number of detected messages for Omerta attacks.
Number of detected messages for Windows bridge.
Number of detected messages for soft APs.
Number of detected messages for broadcast disassociation attacks.
Number of detected messages for broadcast deauthentication attacks.
Number of detected messages for AP impersonation attacks.
Number of detected messages in HT greenfield mode.
Number of detected messages for association and reassociation DoS attacks.
Number of messages detected by wireless bridges.
Number of detected messages for AP flood attacks.
# Display attack detection statistics information for the specified VSD.
<Sysname> display wips statistics virtual-security-domain 111
Information from VSD 111
   Detected hotspot attack messages: 1
   Detected unencrypted authorized AP messages: 0
   Detected unencrypted trust client messages: 0
   Detected honeypot AP messages: 1
   Detected man in the middle messages: 1
   Detected AP channel change messages: 0
Table 17 Command output
Number of detected hotspot attack messages.
Number of detected unencrypted authorized AP messages.
Number of detected unencrypted trust client messages.
Number of detected honeypot AP messages.
Number of detected man-in-the-middle messages.
Number of detected AP channel change messages.
reset wips statistics
display wips virtual-security-domain countermeasure record
Use display wips virtual-security-domain countermeasure record to display information about countermeasures that WIPS has taken against rogue devices.
display wips virtual-security-domain vsd-name countermeasure record
vsd-name: Specifies a VSD by its name, a case-sensitive string of 1 to 63 characters.
# Display information about countermeasures that WIPS has taken against rogue devices for VSD office.
<Sysname> display wips virtual-security-domain office countermeasure record
Total 3 times countermeasure, current 3 countermeasure record in virtual-security-domain office
Reason: Attack; Ass - associated; Black - blacklist;
        Class - classification; Manu - manual;
MAC address    Type   Reason   Countermeasure AP     Radio ID   Time
1000-0000-00e3 AP     Manu     ap1                    1          2016-05-03/09:32:01
1000-0000-00e4 AP     Manu     ap2                    1          2016-05-03/09:32:11
2000-0000-f282 Client Black    ap3                    1          2016-05-03/09:31:56
Table 18 Command output
Total number times countermeasure, current number countermeasure record in virtual-security-domain name
Number of successful countermeasures. This field can display up to 1024 countermeasure records.
MAC Address
MAC address of the wireless device against which WIPS has taken countermeasures.
Type of the wireless device: AP or Client.
Reason
Reason why WIPS takes countermeasures against the wireless device:
·     Att—WIPS takes countermeasures against the device because it is an attacker.
·     Ass—WIPS takes countermeasures against the device because WIPS has taken countermeasures against its associated AP.
·     Black—After WIPS takes countermeasures against the client, the client is added to the blacklist when it associates with an AP.
·     Class—WIPS takes countermeasures against the device based on its device type.
·     Manu—WIPS takes countermeasures against the device based on its MAC address.
Countermeasure AP
Name of the sensor that takes countermeasures against the wireless device.
Radio ID
Radio ID of the sensor that takes countermeasures against the wireless device.
Time
Time when the AC informs the sensor of taking countermeasures against the wireless device.
reset wips virtual-security-domain countermeasure record
display wips virtual-security-domain device
Use display wips virtual-security-domain device to display information about wireless devices detected in a VSD.
display wips virtual-security-domain vsd-name device [ ap [ ad-hoc | authorized | external | mesh | misconfigured | potential-authorized | potential-external | potential-rogue | rogue | uncategorized ] |client [ [ dissociative-client ] | [ authorized | misassociation | unauthorized | uncategorized ] ] | mac-address mac-address ] [ verbose ]
device: Specifies wireless devices.
ap: Specifies APs.
ad-hoc: Specifies APs operating in Ad hoc mode.
authorized: Specifies authorized APs.
external: Specifies external APs.
mesh: Specifies MPs.
misconfigured: Specifies misconfigured APs.
potential-authorized: Specifies potential-authorized APs.
potential-rogue: Specifies potential-rogue APs.
potential-external: Specifies potential-external APs.
rogue: Specifies rogue APs.
uncategorized: Specifies uncategorized APs.
client: Specifies clients.
dissociative-client: Specifies unassociated clients.
authorized: Specifies authorized clients.
misassociation: Specifies misassociated clients.
unauthorized: Specifies unauthorized clients.
uncategorized: Specifies uncategorized clients.
mac-address mac-address: Specifies a wireless device by its MAC address in the H-H-H format.
verbose: Displays detailed device information.
# Display information about wireless devices detected in VSD office.
<Sysname> display wips virtual-security-domain office device
Total 200 detected devices in virtual-security-domain office
Class: Auth - authorization; Ext - external; Mis - mistake;
       Unauth - unauthorized; Uncate - uncategorized;
       (A) - associate; (C) - config; (P) - potential
MAC address    Type   Class    Duration    Sensors Channel Status
1000-0000-0000 AP     Ext(P)   00h 10m 46s 1       11      Active
1000-0000-0001 AP     Ext(P)   00h 10m 46s 1       6       Active
1000-0000-0002 AP     Ext(P)   00h 10m 46s 1       1       Active
Table 19 Command output
Wireless device type: AP, Client, or Mesh.
Class
Category of the wireless device.
Duration
Duration since the wireless device entered the current state.
Sensors
Number of sensors that have detected the wireless device.
Channel
Channel on which the wireless device was most recently detected.
Status
Status of the AP or client:
·     Active—The AP or client is active.
·     Inactive—The AP or client is inactive.
# Display detailed information about wireless devices detected in VSD a.
<Sysname> display wips virtual-security-domain a device verbose
Total 2 detected devices in virtual-security-domain a
 AP: 1000-0000-0000
   Mesh Neighbor: None
   Classification: Mis(C)
   Severity level: 0
   Classify way: Auto
   Status: Active
   Status duration: 00h 27m 57s
   Vendor: Not found
   SSID: service
   Radio type: 802.11g
   Countermeasuring: No
   Security: None
   Encryption method: None
   Authentication method: None
   Broadcast SSID: Yes
   QoS supported: No
   Ad-hoc: No
   Beacon interval: 100 TU
   Up duration: 00h 27m 57s
Channel band-width supported: 20MHZ
   Hotspot AP: No
   Soft AP: No
   Honeypot AP: No
   Total number of reported sensors: 1
     Sensor 1:
       Sensor ID: 3
       Sensor name: 1
       Radio ID: 1
       RSSI: 15
       Channel: 149
       First reported time: 2014-06-03/09:05:51
       Last reported time: 2014-06-03/09:05:51
   Total number of associated clients: 1
     01: 2000-0000-0000
Client: 2000-0000-0000
  Last reported associated AP: 1000-0000-0000
  Classification: Uncate
  Severity level: 0
  Classify way: Auto
  Dissociative status: No
  Status: Active
  Status duration: 00h 00m 02s
  Vendor: Not found
  Radio type: 802.11a
  40mhz intolerance: No
  Man in the middle: No
     Sensor 1:
       Sensor ID: 2
       Sensor name: 1
       Radio ID: 1
       RSSI: 50
       Channel: 149
       First reported time: 2014-06-03/14:52:56
       Last reported time: 2014-06-03/14:52:56
       Reported associated AP: 1000-0000-0000
Table 20 Command output
AP
MAC address of the AP.
Mesh Neighbor
MAC address of the mesh AP's neighbor.
Client
MAC address of the client.
MAC address of the associated AP that the client most recently reports.
Classification
Category of the AP or client:
·     AP category:
¡     ad_hoc.
¡     authorized.
¡     rogue.
¡     misconfigured.
¡     external.
¡     potential-authorized.
¡     potential-rogue.
¡     potential-external.
¡     uncategorized.
·     Client category:
¡     authorized.
¡     unauthorized.
¡     misassociated.
¡     uncategorized.
Severity level
Severity level of the device.
Classify way
AP or client classification method:
·     Manual—Manual classification.
·     Invalid OUI—Added to the invalid OUI list.
·     Block List—Added to the prohibited device list.
·     Associated—APs that are connected to the AC.
·     Trust List—Added to the permitted device list.
·     User Define—User-defined classification.
·     Auto—Automatic classification.
Dissociative status
Whether the client is an unassociated client.
Status
Status duration
Vendor
OUI of the device. This field displays the device OUI if the OUI matches an imported OUI. This field displays Not found if no OUI is configured for the device or the OUI does not match any imported OUIs.
SSID
SSID of the wireless service provided by the AP.
Radio Type
Radio mode of the wireless device.
40MHz intolerance
Whether the client supports 40 MHz bandwidth mode.
Countermeasuring
Whether WIPS is taking countermeasures against the wireless device:
·     No.
·     Yes.
Man in the middle
Whether an MITM attack is detected.
Security
Security method:
·     None.
·     WEP.
·     WPA.
·     WPA2.
Encryption method
Data encryption method:
·     TKIP.
·     CCMP.
·     WEP.
·     WAPI-SMS4.
·     None.
·     None.
·     PSK.
·     802.1X.
·     Others—Authentication methods except for PSK authentication and 802.1X authentication.
Broadcast SSID
Whether the AP broadcasts the SSID. This field displays nothing if the AP does not broadcast the SSID.
QoS supported
Whether the wireless device supports QoS.
Ad-hoc
Whether the wireless device is in Ad hoc mode.
Beacon interval
Beacon interval in TUs. One TU is equal to 1024 microseconds.
Supported channel bandwidth mode:
·     20/40/80MHZ.
·     20/40MHZ.
·     20MHZ.
Hotspot AP
Whether the AP is a hotspot attack AP.
Soft AP
Whether the AP is a soft AP.
Honeypot AP
Whether the AP is a honeypot AP.
Sensor n
Sensor that detected the wireless device. n represents the ID assigned by the system.
Channel
Channel on which the sensor most recently detected the wireless device.
First reported time
Time when the sensor first detected the wireless device.
Last reported time
Time when the sensor most recently detected the wireless device.
n: H-H-H
MAC address of the client associated with the AP. n represents the number assigned by the system.
MAC address of the associated AP that the sensor reports.
reset wips virtual-security-domain device
display wlan ap
Use display wlan ap to display AP information.
display wlan ap { all | name ap-name } [ verbose ]
all: Specifies all APs.
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
verbose: Displays detailed information.
# Display information about all APs.
<Sysname> display wlan ap all
Total number of APs: 3
Total number of connected APs: 3
Total number of connected manual APs: 3
Total number of connected auto APs: 0
Total number of connected common APs: 2
Total number of connected WTUs: 1
Total number of inside APs: 0
Maximum supported APs: 2048
Remaining APs: 2046
Total AP licenses: 128
Local AP licenses: 128
Server AP licenses: 0
Remaining local AP licenses: 126.75
Sync AP licenses: 0
                                 AP information
 State : I = Idle,       J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,     DC = DataCheck,  R  = Run   M = Master,  B = Backup
AP name                        APID  State Model           Serial ID
ap1                             1     I      WA6320          219801A28N819CE0002T
ap2                             2     R      WT1020          219801A0SS9156G00072
ap3                             3     R      WTU420H         219801A0SS9156G00169
Table 21 Command output
Total number of APs
Total number of fit APs, WTs, and WTUs.
Total number of connected fit APs, WTs, and WTUs.
Total number of connected manual fit APs, WTs, and WTUs.
Total number of connected auto fit APs, WTs, and WTUs.
Total number of connected fit APs.
Total number of connected inside APs. Inside APs are manual APs that are automatically created when anchor APs act as ACs. The name and the serial ID of an inside AP are the local MAC address and local serial ID, respectively.
Maximum number of APs supported by the AC, including fit APs and WTUs.
Total AP licenses
Total number of AP licenses, including the number of common AP licenses and a quarter of the WTU license quantity.
The number of AP licenses used for activating an AP varies by AP type:
·     Common AP—One.
·     WTU—A quarter.
·     WT—None.
Local AP licenses
Number of AP licenses installed on the AC.
Server AP licenses
Number of AP licenses requested from the license server.
Number of unused AP licenses installed on the AC. Each AP occupies one AP license and each WTU occupies 0.25 AP licenses. WTs do not require AP licenses.
Sync AP licenses
Number of synchronized AP licenses.
APID
ID of the AP to uniquely identify the AP on the AC.
Current state of the AP:
·     I—Idle.
·     J—Join.
·     JA—Join acknowledge.
·     IL—The AP is downloading the image file.
·     C—The AP is downloading initial configurations.
·     DC—The AP is checking data.
·     R—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel.
·     R/M—The master CAPWAP tunnel is operating. It indicates that the AP and the master AC have established a CAPWAP tunnel.
·     R/B—The backup CAPWAP tunnel is operating. It indicates that the AP and the backup AC have established a CAPWAP tunnel.
·     M—The AP is connected to the master AC.
·     B—The AP is connected to the backup AC.
·     R/IL—The CAPWAP tunnel is operating and the AP is downloading the image file.
Serial ID
Serial ID of the AP. This field displays Not configured if the serial ID of the AP is not configured.
# Display detailed information about AP ap1.
<Sysname> display wlan ap name ap1 verbose
AP name                       : ap1
AP ID                         : 1
AP group name                 : default-group
State                         : Run
Backup type                   : Master
Online time                   : 0 days 1 hours 25 minutes 12 seconds
System uptime                 : 0 days 2 hours 22 minutes 12 seconds
Model                         : WA6320
Region code                   : CN
Region code lock              : Disable
Serial ID                     : 219801A0CNC138011454
MAC address                   : 0AFB-423B-893C
IP address                    : 192.168.1.50
UDP control port number       : 18313
UDP data port number          : N/A
H/W version                   : Ver.C
S/W version                   : E2321
Boot version                  : 1.01
USB state                     : N/A
Power level                   : N/A
Power info                    : N/A
Description                   : wtp1
Priority                      : 4
Echo interval                 : 10 seconds
Echo count                    : 3 counts
Keepalive interval            : 10 seconds
Discovery-response wait-time  : 2 seconds
Statistics report interval    : 50 seconds
Fragment size (data)          : 1500
Fragment size (control)       : 1450
MAC type                      : Local MAC & Split MAC
Tunnel mode                   : Local Bridging & 802.3 Frame & Native Frame
CWPCAP data-tunnel status     : Down
Discovery type                : Static Configuration
Retransmission count          : 3
Retransmission interval       : 5 seconds
Firmware upgrade              : Enabled
Sent control packets          : 1
Received control packets      : 1
Echo requests                 : 147
Lost echo responses           : 0
Average echo delay            : 3
Last reboot reason            : User soft reboot
Last reboot reason (AP check) : The radio physical status was down
Last reboot reason (AC check) : The radio physical status was down
Latest IP address             : 10.1.0.2
Current AC IP                 : 192.168.1.1
Tunnel down reason            : Request wait timer expired
Connection count              : 1
Backup IPv4                   : Not configured
Backup IPv6                   : Not configured
Ctrl-tunnel encryption        : Disabled
Ctrl-tunnel encryption state  : Not encrypted
Data-tunnel encryption        : Disabled
Data-tunnel encryption state  : Not encrypted
LED mode                      : Normal
Remote configuration          : Enabled
Radio 1:
    Basic BSSID               : 7848-59f6-3940
    Admin state               : Up
    Radio type                : 802.11ac
    Antenna type              : internal
    Client dot11ac-only       : Disabled
    Client dot11n-only        : Disabled
    Channel band-width        : 20/40/80MHz
    Active band-width         : 20/40/80MHz
    Secondary channel offset  : SCB
    Short GI for 20MHz        : Supported
    Short GI for 40MHz        : Supported
    Short GI for 80MHz        : Supported
    Short GI for 160MHz       : Not supported
    MIMO                      : Not Config
    Green-Energy-Management   : Disabled
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Not Supported
    STBC                      : Supported
    Operational VHT-MCS Set:
        Mandatory             : Not configured
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
        Multicast             : Not configured
    Operational HT MCS Set:
        Supported             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15
    Channel                   : 44(auto)
    Channel usage(%)          : 15
    Max power                 : -102 dBm
    Operational rate:
        Mandatory             : 6, 12, 24 Mbps
        Multicast             : Auto
        Supported             : 9, 18, 36, 48, 54 Mbps
        Disabled              : Not configured
    Distance                  : 1 km
    ANI                       : Enabled
    Fragmentation threshold   : 2346 bytes
    Beacon interval           : 100 TU
    Protection threshold      : 2346 bytes
    Long retry threshold      : 4
    Short retry threshold     : 7
    Maximum rx duration       : 2000 ms
    Noise Floor               : 5 dBm
    Smart antenna             : Enabled
    Smart antenna policy      : Auto
    Protection mode           : rts-cts
    Continuous mode           : N/A
    Client dot11ax-only       : Disabled
    Operational HE-MCS Set:
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9,10,11
                                NSS2 0,1,2,3,4,5,6,7,8,9,10,11
    OFDMA random access RUs   : Not Supported
    DL-OFDMA                  : Disabled
    UL-OFDMA                  : Disabled
    UL-MU-MIMO                : Disabled
    BSS-COLOR                 : Disabled
    TWT negotiation           : Disabled
    Radar-detect              : Enabled
    HT protection mode        : No protection
Radio 2:
    Basic BSSID               : 7848-59f6-3950
    Admin state               : Down
    Radio type                : 802.11b
    Channel band-width        : 20MHz
    Active band-width         : 20MHz
    Secondary channel offset  : SCN
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    STBC                      : Supported
    Channel                   : 5(auto)
    Channel usage(%)          : 0
    Max power                 : 20 dBm
    Preamble type             : Short
    Operational rate:
        Mandatory             : 1, 2, 5.5, 11 Mbps
        Multicast             : Auto
        Supported             : 6, 9, 12, 18, 24, 36, 48, 54 Mbps
    Distance                  : 1 km
    ANI                       : Enabled
    Noise Floor               : 0 dBm
    DL-OFDMA                  : Disabled
    UL-OFDMA                  : Disabled
Table 22 Command output
·     Idle—Idle.
·     Join—Join.
·     JoinAck—Join acknowledge.
·     Image—The AP is downloading the version.
·     Config—The AP is downloading initial configurations.
·     Data Check—The AP is checking data.
·     Run—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel.
Backup type
CAPWAP tunnel type:
·     Idle—The AP has not established a CAPWAP tunnel with the AC.
·     Master—The CAPWAP tunnel established between the AP and the master AC.
·     Backup—The CAPWAP tunnel established between the AP and the backup AC.
Region code lock
·     Enabled.
·     Disabled.
Serial ID
Serial ID of the AP. If no serial ID is configured, this field displays Not configured.
MAC address
MAC address of the AP. If no MAC address is configured, this field displays Not configured.
Port number used by the AP to establish the CAPWAP control tunnel.
Port number used by the AP to establish the CAPWAP data tunnel.
H/W version
Hardware version of the AP.
S/W version
Software version of the AP.
WT serial ID
Serial ID of the WT that connects to the WTU. This field is displayed only for WTUs.
WT name
Name of the WT that connects to the WTU. This field is displayed only for WTUs.
WT MAC address
MAC address of the WT that connects to the WTU. This field is displayed only for WTUs.
USB state
USB state:
·     Enabled.
·     Disabled.
This field displays N/A if no USB state information is available.
Power level
Power level:
·     Low.
·     Middle.
·     High.
This field displays N/A if the power level is unknown.
Support for this field depends on the AP model.
Power info
Power supply information.
·     Power adapter—The AP uses local power supply.
·     PoE (port1+port2)—The AP uses PoE power supply. The port1 and port2 arguments represent the power supply status of PoE+ ports.
¡     N/A.
¡     802.3af.
¡     802.3at.
AP type
AP type:
·     Unknown—This field displays Unknown before the AP comes online.
·     WTU.
·     Virtual AP.
·     Fat AP.
·     Cloud AP.
·     Normal AP.
PoE status
PoE power supply state for each PI:
·     Enabled.
·     Disabled.
Description for the AP. If no description is configured, this field displays Not configured.
Priority
AP connection priority for the AC.
Echo interval
Interval for an AP to send echo requests to the AC.
Echo count
Maximum number of echo request transmission attempts.
Keepalive interval
Interval for an AP to send keepalive packets through the CAPWAP data tunnel.
Discovery-response timeout timer.
Interval for an AP to send statistics reports to the AC.
Maximum fragment size for CAPWAP data packets.
Maximum fragment size for CAPWAP control packets.
MAC type
MAC type of the AP-AC connection:
·     Local MAC—The AP encapsulates frames in 802.3 format before sending them to the AC.
·     Split MAC—The AP encapsulates frames in 802.11 format before sending them to the AC.
·     Local & Split MAC—The AP can encapsulate frames in either 802.3 format or 802.11 format before sending them to the AC.
Tunnel mode
Supported tunnel mode of the AP:
·     Local Bridging—The AP supports local bridging and does not forward data to the AC.
·     802.3 Frame—The AP encapsulates the frames in 802.3 format to send them to the AC.
·     Native Frame—The AP encapsulates the frames in 802.11 format to send them to the AC.
·     Local Bridging & 802.3 Frame—The AP supports the Local Bridging mode and the 802.3 Frame mode.
·     802.3 Frame & Native Frame—The AP supports the 802.3 Frame mode and the Native Frame mode.
·     Local Bridging & Native Frame—The AP supports the Local Bridging mode and the Native Frame mode.
Running status of the CAPWAP data tunnel:
·     Up.
·     Down.
Discovery type
Discovery type of the AP:
·     Static Configuration—The AP uses the manually configured IPv4 or IPv6 address of the AC.
·     DHCP—The AP gets the IP address of an AC through DHCP.
·     DNS—The AP gets the IP address of an AC through DNS.
·     Unknown.
In a dual-link backup network, the discovery method of an AP on the backup AC is consistent with that on the master AC.
Number of retransmission attempts for an AC request.
Interval at which AC requests can be retransmitted.
Firmware upgrade
AP software upgrade:
·     Enabled.
·     Disabled.
Number of sent packets, including Change State Event Response packets after the AC enters Run state. .
Number of received packets, including Change State Event Response packets after the AC enters Run state.
Echo requests
Number of echo requests sent by the AP in RUN state.
Lost echo responses
Number of echo responses not received by the AP in RUN state.
Average echo delay
Average echo delay in milliseconds.
Last reboot reason
Last reboot reason for the AP:
·     Power on.
·     Hard reboot.
·     Watchdog reboot.
·     Unknown reboot.
·     User soft reboot.
·     Kernel exception soft reboot.
·     Kernel deadloop soft reboot.
·     Auto update soft reboot.
·     Unknown soft reboot.
·     Memory exhausted.
·     Other unknown soft reboot.
Last reboot reason(AP check)
Reason for the most recent AP check failure that caused an AP reboot:
·     The radio state was incorrect.
·     The radio channel was incorrect.
·     The radio type was incorrect.
·     The radio bandwidth was incorrect.
·     The radio rate was incorrect.
·     The radio dependence was incorrect.
·     The radio physical status was down.
Last reboot reason(AC check)
Reason for the most recent AC check failure that caused an AP reboot:
Latest IP address
IP address that was most recently used by the AP.
Current AC IP
IP address of the AC that is associated with the AP.
Tunnel down reason
CAPWAP tunnel down reason:
·     Failed to create timer.
·     Neighbor dead timer expired.
·     Request wait timer expired.
·     Data check timer expired.
·     Failed to process data channel keep-alive message.
·     Failed to process request.
·     AP was reset.
·     AP was deleted.
·     Failed to come online.
·     Serial number changed.
·     MAC address changed.
·     Number of APs exceeded the limit.
·     Processed join request in Run state.
·     Failed to create AP context.
·     Received failure result code.
·     Failed to retransmit message.
·     Failed to download image file.
·     Image file downloaded successfully.
·     File operation timer expired.
·     Failed to add tunnel.
·     Received WTP tunnel down event from AP.
·     Backup AC closed the backup tunnel.
·     Master and backup tunnel switchover.
·     Failed to inherit configuration.
·     AP authentication failed.
·     Encryption status mismatch.
·     AP was reset due to inconsistent local and reported radio statistics.
·     AP was reset due to inconsistent AP state on APMGR and lib.
·     AP was reset due to inconsistent BSS state on AC and AP.
·     The AP mode will change from fat or cloud-managed AP to fit AP.
This field displays N/A if the CAPWAP tunnel did not go down.
Connection count
Number of times that the AP connects to the AC. It is cleared in either one of the following cases:
·     The AC reboots.
·     The serial ID of the AP changes.
The reset wlan ap command does not clear the connection count.
Backup IPv4
IPv4 address of the backup AC. If no backup AC is specified, this field displays Not configured.
Backup IPv6
IPv6 address of the backup AC. If no backup AC is specified, this field displays Not configured.
CAPWAP control tunnel encryption:
·     Enabled.
·     Disabled.
CAPWAP control tunnel encryption state:
·     Encrypted.
·     Not encrypted.
CAPWAP data tunnel encryption:
·     Enabled.
·     Disabled.
CAPWAP data tunnel encryption state:
·     Encrypted.
·     Not encrypted.
LED mode
LED lighting mode:
·     quiet—All LEDs are off.
·     awake—All LEDs flash once every minute.
·     always-on—All LEDs are steady on.
·     normal—How LEDs flash in this mode varies by AP model.
Remote configuration assignment:
·     Enabled.
·     Disabled.
EnergySaving Level
Energy saving level:
·     0—Energy saving disabled.
·     1—Level 1.
·     2—Level 2.
Basic BSSID
MAC address of the radio. This field displays N/A if the AP has not established a CAPWAP tunnel with the AC.
Admin state
Radio state:
·     Up.
·     Down.
Radio type
Wireless mode:
·     5 GHz:
¡     802.11a.
¡     802.11n(5GHz).
¡     802.11ac.
¡     802.11ax.
·     2.4 GHz:
¡     802.11b.
¡     802.11g.
¡     802.11n(2.4GHz).
¡     802.11gac.
¡     802.11gax.
Client dot11ax-only
·     Disabled—Allows 802.11a/b/g/n/ac/ax clients to associate with the radio.
·     Enabled—Allows only 802.11ax clients to associate with the radio.
Client dot11ac-only
·     Enabled—Allows only 802.11ac and 802.11ax clients to associate with the radio.
Client dot11n-only
·     Enabled—Allows only 802.11n, 802.11ac, and 802.11ax clients to associate with the radio.
Channel bandwidth
Channel bandwidth mode:
·     20 MHz.
·     20 or 40 MHz.
·     20/40/80 MHz.
·     20/40/80/160MHz.
·     20/40/80/160/(80+80)MHz.
Operating bandwidth
Bandwidth being used by the radio.
This field displays (auto switch) if automatic bandwidth switching between 20 MHz and 40 MHz is enabled.
Secondary channel mode
Secondary channel information for the 802.11n, 802.11ac, and 802.11ax radio mode:
·     SCA (Second Channel Above)—The AP operates in 40 MHz bandwidth mode, and the secondary channel is above the primary channel.
·     SCB (Second Channel Below)—The AP operates in 40 MHz bandwidth mode, and the secondary channel is below the primary channel.
·     SCN—The AP does not operate in 40 MHz bandwidth mode.
This field is available only when the bandwidth that the radio is using is 20/40/80MHz.
Secondary channel center frequency
Center frequency information about the 80 MHz bandwidth of the secondary channel when the radio operates in 802.11ac or 802.11ax radio mode with a channel bandwidth of 160/(80+80)MHz.
This field is available only when the bandwidth that the radio is using is 160/(80+80)MHz.
Short GI for 20MHz
Whether the radio supports short GI when it operates in 20 MHz mode.
Short GI for 40MHz
Whether the radio supports short GI when it operates in 40 MHz mode.
Short GI for 80MHz
Whether the radio supports short GI when it operates in 80 MHz mode.
Short GI for 160MHz
Whether the radio supports short GI when it operates in 160 MHz mode.
MIMO
MIMO mode:
·     1x1—The radio sends and receives signals through one spatial stream.
·     2x2—The radio sends and receives signals through two spatial streams.
·     3x3—The radio sends and receives signals through three spatial streams.
·     4x4—The radio sends and receives signals through four spatial streams.
·     5x5—The radio sends and receives signals through five spatial stream.
·     6x6—The radio sends and receives signals through six spatial streams.
·     7x7—The radio sends and receives signals through seven spatial streams.
·     8x8—The radio sends and receives signals through eight spatial streams.
·     Not configured—The radio sends and receives signals through the maximum number of spatial streams supported by the radio.
If this field also displays (PowerLow) after any value option to indicate low power level, the radio can send and receive signals only through one spatial stream.
Energy-saving:
·     Disabled.
·     Enabled.
A-MSDU
·     Disabled.
·     Enabled.
A-MPDU
·     Disabled.
·     Enabled.
LDPC
·     Supported.
·     Not supported.
STBC
·     Supported.
·     Not supported.
·     Supported—Supported HE MCS set.
·     Mandatory—Mandatory HE MCS set.
·     Multicast—Multicast HE MCS set.
Operational VHT MCS Set
·     Supported—Supported VHT MCS set.
·     Mandatory—Mandatory VHT MCS set.
·     Multicast—Multicast VHT MCS set.
·     Supported—Supported HT MCS set.
·     Mandatory—Mandatory HT MCS set.
·     Multicast—Multicast HT MCS set.
Channel
This field displays Number<auto> if the current channel is the optimal channel automatically selected by the AP.
This field displays Number if the current channel is manually configured.
This field displays Number<avoid radar> if the current channel is automatically selected by the AP to avoid radar signals.
Max power
Maximum transmission power of the radio.
Preamble type
Preamble type:
·     Short.
·     Long.
Operational rate
·     Mandatory.
·     Supported.
·     Multicast.
·     Disabled.
·     Not configured.
Distance
Maximum distance that the radio signal can reach.
ANI
·     Enabled.
·     Disabled.
Frame length threshold required for triggering the protection mechanism.
Maximum number of retransmission attempts for frames whose length exceeds the RTS threshold.
Maximum number of retransmission attempts for frames whose length is below the RTS threshold.
Maximum rx duration
Maximum buffer duration for frames.
Smart antenna
·     Enabled.
·     Disabled.
·     Auto.
·     High availability.
·     High throughput.
Protection mode
Conflict avoidance mode:
·     cts-to-self.
·     rts-cts.
Continuous mode
Continuous mode configuration:
·     Rate.
·     MCS index.
·     NSS index.
·     VHT-MCS index.
This field displays N/A if the continuous mode is not configured.
·     Supported.
·     Not Supported.
TWT negotiation
TWT negotiation:
·     Enabled.
·     Disabled.
DL-OFDMA
Downlink OFDMA:
·     Enabled.
·     Disabled.
UL-OFDMA
Uplink OFDMA:
·     Enabled.
·     Disabled.
UL-MU-MIMO
Uplink MU-MIMO:
·     Enabled.
·     Disabled.
BSS-COLOR
BSS coloring:
·     Enabled.
·     Disabled.
HT protection mode
802.11n protection mode:
·     No protection.
¡     AP-associated clients and nearby wireless devices are operating in 802.11n mode and AP-associated clients are 802.11n clients with a bandwidth of 40 MHz.
¡     AP-associated clients are 802.11n clients with a bandwidth of 20 MHz.
·     Non-member protection.
In this mode, all AP-associated clients are 802.11n clients but some nearby wireless devices are non-802.11n clients.
·     20 MHz protection.
In this mode, the AP's radio has a bandwidth of 40 MHz. AP-associated clients and nearby wireless devices are operating in 802.11n mode and a minimum of one 802.11n client with a bandwidth of 20 MHz is associated with the AP's radio.
·     Non-HT mixed.
The mode applies when none of the above mentioned modes can apply.
MU-TxBF
·     Enabled.
·     Disabled.
SU-TxBF
·     Enabled.
·     Disabled.
ATF
·     Enabled.
·     Disabled.
display wlan ap address
Use display wlan ap address to display AP address information.
display wlan ap { all | name ap-name } address
# Display address information for all APs.
<Sysname> display wlan ap all address
Total number of APs: 1
Total number of connected APs: 1
Total number of connected manual APs: 1
AP name                          IP address                     MAC address
ap1                              1.1.1.5                        000b-6b8f-fc6a
Table 23 Command output
Total number of APs
IP address
IP address of an AP.
This field displays N/A for an offline AP.
MAC address
MAC address of an AP.
display wlan ap connection-record
Use display wlan ap connection-record to display AP connection records on the AC.
display wlan ap { all | name ap-name } connection-record
# Display all AP connection records on an AC.
<Sysname> display wlan ap all connection-record
AP name                         IP address    State     Time
ap1                              2001::3       Run        05-06 09:47:44
ap2                              2001::5       Run        05-06 09:50:38
Table 24 Command output
·     Discovery—AC discovery.
·     Join—The CAPWAP tunnel is being established.
·     Offline—Offline.
·     Run—The CAPWAP tunnel is operating. It indicates that the AP and the AC have established a CAPWAP tunnel successfully.
Time
Most recent time when the AP established a CAPWAP tunnel with the AC.
display wlan ap files
Use display wlan ap files to display information about files and file folders on an AP.
display wlan ap name ap-name files
# Display information about files and file folders on AP ap1.
<Sysname> display wlan ap name ap1 files
Directory of flash:
   0   13638656  wa6300-system.bin
   1   2573312   wa6300-boot.bin
131072 KB total (114208 KB free)
Table 25 Command output
0   13638656  xx.xx
File or file folder information:
·     0—Serial number, which is automatically assigned by the system.
·     13638656— File size in bytes. A hyphen (-) is displayed if it is a file folder.
·     xx.xx—Name of the file or file folder.
delete file
download file
display wlan ap gps
Use display wlan ap gps to display Global Positioning System (GPS) information for the specified APs.
display wlan ap { all | name ap-name } gps
This command takes effect only on APs that support the GPS module.
# Display GPS information for AP ap1.
<Sysname> display wlan ap name ap1 gps
AP name    : ap1
Serial ID  : 219801A17C817200001
Model      : WA5630X
Longitude  : 117.788887
Latitude   : 30.822136
Velocity   : 25.445878
Orientation: 8.054548
Elevation  : 156.655897
Obtained at: 2017-02-20 15:32:19
Table 26 Command output
AP name
Name of the AP.
Serial ID
Model
AP model.
Longitude
Longitude rounded to six decimal places.
Latitude
Latitude rounded to six decimal places.
Velocity
Horizontal velocity rounded to six decimal places.
Orientation
Orientation rounded to six decimal places.
Elevation
Elevation rounded to six decimal places.
Obtained at
Time when the GPS information was obtained.
display wlan ap online-time
Use display wlan ap online-time to display the online duration for APs.
display wlan ap { all | name ap-name } online-time
# Display online duration for all APs.
<Sysname> display wlan ap all online-time
AP name            IP address               Time
ap1                1.1.1.2                  0 days 0 hours 2 minutes 6 seconds
ap2                1.1.1.1                  0 days 0 hours 5 minutes 6 seconds
ap3                1.1.1.6                  0 days 0 hours 2 minutes 1 seconds
Table 27 Command output
IP address
Time
Realtime association duration of an AP since the AP came online.
display wlan ap radio
Use display wlan ap radio to display AP radio information.
display wlan ap { all | name ap-name } radio [ frequency-band { 5 | 2.4 } ]
frequency-band: Specifies a frequency band.
5: Specifies the 5 GHz frequency band.
2.4: Specifies the 2.4 GHz frequency band.
# Display radio information for all APs.
<Sysname> display wlan ap all radio
Total number of connected common APs: 1
Total number of connected WTUs: 0
Maximum supported APs: 6144
Remaining APs: 6144
local AP licenses: 0
Remaining local AP licenses: 127
Sync AP licenses: 0
AP name                  RID State Channel          BW    Usage TxPower Clients
                                                    (MHz) (%)   (dBm)
ap1                      1   Up    48(auto)         40    10     20     5
ap1                      2   Up    56(auto)         20    15     20     10
# Display 2.4 GHz radio information for AP ap1.
<Sysname> display wlan ap name ap1 radio frequency-band 2.4
                                                    (MHz) (%)   (dBm)
ap1                      2   Up    48(auto)         20    15     20     15
Table 28 Command output
Total number of connected WTUs.
An inside AP is a manual AP automatically created for radio management when an anchor AP acts as an AC. The name and serial ID of the inside AP are the MAC address and serial ID of the anchor AP, respectively.
Maximum number of supported APs, including fit APs and WTUs, on the AC.
Remaining APs
Remaining number of supported APs. The value equals the number of maximum supported APs minus the number of connected common APs and the number of connected WTUs.
Total AP licenses
Total number of AP licenses. Each WTU license is considered as 0.25 AP licenses.
local AP licenses
Number of local AP licenses on the AC.
Server AP licenses
Number of AP licenses requested from the server by the AC.
Number of remaining local AP licenses. Each AP occupies one AP license and each WTU occupies 0.25 AP licenses. WTs do not require AP licenses.
Sync AP licenses
Radio state:
·     Up.
·     Down.
BW(MHz)
Maximum supported bandwidth.
Usage
Channel usage.
TxPower (dBm)
Transmission power. By default, the maximum supported power is used to transmit packets.
Clients
Number of online clients.
display wlan ap radio channel
Use display wlan ap radio channel to display radio channel information.
display wlan ap { all | name ap-name } radio channel
# Display radio channel information for AP ap3.
<Sysname> display wlan ap name ap3 radio channel
AP name                  RID Channel          Band-width           CenterFreq
                                              (MHz)
ap3                       1  36(auto)         20/40/80/160/(80+80) 42/58
ap3                       2  52               20/40/80             155
ap3                       3  11(auto)         20                   0
Table 29 Command output
Band-width (MHz)
Supported channel bandwidth.
CenterFreq
Central frequencies. This field is available only when the supported channel bandwidth reaches 80 MHz. This field displays the central frequencies for both the main and the secondary channels when 160 MHz or 80+80 MHz bandwidth is supported.
display wlan ap radio type
Use display wlan ap radio type to display radio type information.
display wlan ap { all | name ap-name } radio type
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display radio type information for AP ap1.
<Sysname> display wlan ap name ap1 radio type
AP name                  RID  AP state  Radio state  Radio type
ap1                      1    Up        Up           802.11n(5GHz)
ap1                      2    Up        Down         802.11n(2.4GHz)
Table 30 Command output
AP state
AP state:
·     Up—The AP has established a CAPWAP tunnel with the AC.
·     Down—The AP has not established a CAPWAP tunnel with the AC.
Radio state
Radio state:
·     Up.
·     Down.
display wlan ap reboot-log
Use display wlan ap reboot-log to display reboot logs for an AP.
display wlan ap name ap-name reboot-log
If the AP has suffered a system crash, you can use this command to view detailed information about the crash.
To use this command, make sure the specified AP is in Run state.
# Display reboot logs for AP ap1.
<Sysname> display wlan ap name ap1 reboot-log
Debugging information is not available on the AC.
Downloading debugging data from AP. Continue? [Y/N]:y
Downloading debugging data. Please wait...
Please enter the same command again to view the log messages.
<Sysname>dis wlan ap name ap1 reboot-log
--------------------- Reboot record 1 ---------------------
Recorded at           : 2018-07-20  03:29:43.324529
Occurred at           : 2018-07-20  03:29:43.324529
Reason                : 0x8
Thread                : devd (TID: 50)
Context               : thread context
Cpu                   : 0
Kernel module info    : module name (system) module address (0xd145a000)
                        module name (addon) module address (0xd00d5000)
Last 5 thread switches : WDRVFwdKthread (3:29:43.323999)-->
                         swapper (3:29:43.324011)-->
                         WDRVFwdKthread (3:29:43.324467)-->
                         swapper (3:29:43.324478)-->
                         devd (3:29:43.324502)-->
reset wlan ap reboot-log
display wlan ap region-code
Use display wlan ap region-code to display region code information for all APs or the specified AP.
display wlan ap { all | name ap-name } region-code
# Display region code information for all APs.
<Sysname> display wlan ap all region-code
Region Code
AP name                         Region Code
ap1                             CN  CHINA
ap2                             CN  CHINA
ap3                             CN  CHINA
Table 31 Command output
Region Code
Region code.
display wlan ap running-configuration
Use display wlan ap running-configuration to display running configuration for the specified AP or all APs.
display wlan ap running-configuration { all | ap-name ap-name } [ verbose ]
verbose: Displays detailed running configuration.
# Display detailed running configuration for all APs.
<Sysname> display wlan ap running-configuration all verbose
(i) -- Inherited from AP group
(g) -- Inherited from AP global-configuration
wlan ap ap1 model WA6320 id 5
  ap group name 1
  serial-id 210235A1BSC123000050
  region code CN (g)
  echo interval 10 (i)
  echo count 3 (i)
  keepalive interval 10 (i)
  retransmission count 3 (i)
  retransmission interval 5 (i)
  statistics interval 50 (i)
  fragment-size data 1500 (i)
  fragment-size control 1450 (i)
  tunnel-preempt disable (g)
  firmware update 1
  priority 4 (i)
  radio 1
    radio type 802.11ax (i)
    radio disable (i)
    channel auto<64> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    distance 1 kilometer (i)
    ANI Enabled (i)
  radio 2
    radio type 802.11gax (i)
    radio disable (i)
    channel auto<11> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
wlan ap ap2 model WA6320 id 6
  ap group name 2
  serialid 219801A28N819CE0002T
  region code CN (g)
  echo count 3 (i)
  preempt disable (g)
  firmware-upgrade disable (g)
  priority 4 (i)
  radio 1
    radio type 802.11ac (i)
    radio disable (i)
    channel auto<60> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
  radio 2
    radio type 802.11n(2.4GHz) (i)
    radio disable (i)
    channel auto<13> (i)
    channel unlock (i)
    max-power 20 (i)
    power unlock (i)
    ANI Enabled (i)
display wlan ap-distribution
Use display wlan ap-distribution to display AP distribution information.
display wlan ap-distribution { all | local-ac-name local-ac-name | slot slot-number }
all: Displays distribution information for APs attached to ACs.
·     On a non-IRF and non-AC hierarchical network, this command displays distribution information for APs attached to the current device.
·     On an IRF fabric, this command displays distribution information for APs attached to all IRF member devices.
·     On a AC hierarchical network, the command output depends on the AC's role.
¡     Central AC—Distribution information for APs attached to the central AC and all local ACs.
¡     Local AC—Distribution information for APs attached to the current local AC.
local-ac-name local-ac-name: Specifies a local AC by its AC name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-). This option is supported only on the central AC.
# Display distribution information for all APs.
<Sysname> display wlan ap-distribution all
Slot               : 1
AP name            : 722a-d561-0301
# On the central AC, display distribution information for APs attached to the central AC and all local ACs.
Central AC            Slot 0         Total number of APs: 1
AP name               AP ID          AP IP        AC IP
ap1                   1              1.1.1.1      1.1.1.10
Local AC              local-ac1     Total number of APs: 3
Ap2                   2              1.1.1.2      1.1.1.11
Ap3                   3              1.1.1.3      1.1.1.11
Ap4                   4              1.1.1.4      1.1.1.11
Table 32 Command output
Central AC
Distribution information for APs attached to the central AC.
Slot
Member ID of the IRF member device.
This field indicates the member ID only for centralized IRF devices.
AC IP
IP address of the associated AC. The AP can associate with a local AC or the central AC.
Local AC
Distribution information for APs attached to the local AC.
local-ac1
Local AC name.
# On the central AC, display distribution information for APs attached to local AC local-ac1.
<Sysname> display wlan ap-distribution local-ac-name local-ac1
          C = Config,    DC = DataCheck,  R  = Run,   M = Master,  B = Backup
722a-d561-0300                 8     R/M   WA6320          219801A28N819CE0002T
# On an IRF fabric, display distribution information for APs attached to the specified slot.
<Sysname> display wlan ap-distribution slot 0
                                 AP information
722a-d561-0300                4     R/M    WA6320          210235A1BSC123000050
Table 33 Command output
APID
·     I—Idle.
·     J—Join.
·     IL—The AP is downloading the software image version.
Model
AP model information.
Serial ID
display wlan ap-group
Use display wlan ap-group to display information about all AP groups or the specified AP group.
display wlan ap-group [ brief | name group-name ]
brief: Displays brief information about all AP groups.
name group-name: Displays detailed information about the specified AP group. The group-name argument represents the name of an AP group, a case-insensitive string of 1 to 31 characters.
If you do not specify any parameter, this command displays detailed information about all AP groups.
# Display detailed information about all AP groups.
[Sysname] display wlan ap-group
Total number of AP groups: 2
Description         : Not configured
AP model            : Not configured
APs                 : Not configured
AP group name       : group1
Description         : abcd
AP model            : WA6320
AP grouping rules:
  AP name           : ap1, ap2
  Serial ID         : 219801A28N819CE0002T
  IPv4 address      : Not configured
  IPv6 address      : Not configured
APs                 : ap1 (AP name)
# Display detailed information about AP group group1.
[Sysname] display wlan ap-group group1
AP model            : WA6320
AP grouping rules:
  AP name           : ap1, ap2
APs                 : ap1 (AP name)
# Display brief information about all AP groups.
<Sysname> display wlan ap-group brief
Total number of AP groups: 4
AP group name                  Group ID  Member APs   Online APs
default-group                  1         1            0
group1                         2         2006         1986
group2                         3         10           10
group3                         4         4            4
wlan ap-group
display wlan ap-model
Use display wlan ap-model to display AP model information.
display wlan ap-model { all | name model-name }
all: Specifies all AP models.
name model-name: Specifies an AP model by its name.
# Display information about AP model WA6320.
<Sysname> display wlan ap-model name WA6320
AP model        : WA6320
Alias           : WA6320
Vendor name     : H3C
Vendor ID       : 25506
License weight  : 100
Radio count     : 2
 Radio 1:
  Mode          : 802.11a, 802.11an, 802.11ac
  Default mode  : 802.11ac
  BSS count     : 16
 Radio 2:
  Mode          : 802.11b, 802.11g, 802.11gn
  Default mode  : 802.11gn
  BSS count     : 16
Version Support List :
 Hardware Version Ver.A:
  Software Version         : R2206P02
  Default Software Version : R2206P02
  Image Name               : wa6300.ipe
 Hardware Version Ver.B:
 Hardware Version Ver.C:
 Hardware Version Ver.D:
 Hardware Version Ver.E:
Hardware Version Ver.F:
Table 34 Command output
AP model
AP model name.
Alias
AP model alias.
License weight
Weight of the AP model in using an AP license, in percentage.
Radio count
Number of radios.
Mode
Supported radio types.
Default mode
Default radio type.
BSS count
Maximum number of BSSs that the radio supports.
Software Version
Fit AP's software version used to compare with the software version reported by the AP.
The default value is the AP software version stored in the APDB.
Fit AP's software version stored in the APDB.
Image Name
Name of the fit AP image file.
Oasis AP Software Version
Cloud-managed AP's software version.
Fat AP Software Version
Fat AP's software version.
display wlan blacklist
Use display wlan blacklist to display blacklist entries.
display wlan blacklist { dynamic | static }
dynamic: Specifies the dynamic blacklist.
static: Specifies the static blacklist.
# Display static blacklist entries.
<Sysname> display wlan blacklist static
Total number of clients: 3
 MAC addresses:
  000e-35b2-000e
  0019-5b8e-b709
  001c-f0bf-9c92
# Display dynamic blacklist entries.
<Sysname> display wlan blacklist dynamic
MAC address     APID   RID   Lifetime (s)  Duration (hh:mm:ss)
000f-e2cc-0001  1      1     300           00:02:11
000f-e2cc-0002  2      1     300           00:01:17
000f-e2cc-0003  3      1     300           00:02:08
Table 35 Command output
MAC address
Client MAC address.
APID
ID of the AP that detected the rogue client.
RID
Radio ID of the AP that detected the rogue client.
Lifetime (s)
Lifetime of the entry in seconds.
Duration (hh:mm:ss)
Duration for the entry since the entry was added to the dynamic blacklist.
display wlan client
Use display wlan client to display client information.
display wlan client [ ap ap-name [ radio radio-id ] | mac-address mac-address | service-template service-template-name | frequency-band { 2.4 | 5 } | vlan vlan-id ] [ verbose ]
ap ap-name: Displays information about clients that are connected to the specified AP. The AP name is a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
radio radio-id: Displays information about clients that are connected to the specified radio. The value range for the radio-id argument varies by device model. If you do not specify this option, the command displays information about all clients that are connected to the specified AP.
mac-address mac-address: Specifies a client by its MAC address.
service-template service-template-name: Displays information about clients that are associated with the specified service template. The service template name is a case-insensitive string of 1 to 63 characters.
frequency-band: Displays information about clients working on the specified band.
2.4: Specifies the 2.4 GHz band.
5: Specifies the 5 GHz band.
verbose: Displays detailed client information. If you do not specify this keyword, the command displays brief client information.
vlan vlan-id: Displays information about clients in the specified VLAN. The vlan-id argument represents the VLAN ID in the range of 1 to 4094.
# Display brief information about all clients.
<Sysname> display wlan client
MAC address    Username             AP name               R IP address      VLAN
000f-e265-6400 N/A                  ap1                   1 1.1.1.1         100
000f-e265-6401 user                 ap2                   1 3.0.0.3         200
84db-ac14-dd08 N/A                  ap1                   1 5.5.5.3         1
Table 36 Command output
MAC address
Client MAC address.
Username
Client username:
·     The field displays the client username if the client uses 802.1X or MAC authentication.
·     The field displays N/A if the client does not use 802.1X or MAC authentication.
If the client uses portal authentication, this field does not display the portal username of the client.
AP name
Name of the AP that the client is associated with.
R
ID of the radio that the client is associated with.
IP address
IPv4 address of the client.
VLAN ID
ID of the VLAN to which the client belongs.
# Display detailed information about the client with MAC address 000f-e265-6400.
<Sysname> display wlan client mac-address 000f-e265-6400 verbose
Total number of clients: 1
MAC address                        : 000f-e265-6400
IPv4 address                       : 10.1.1.114
IPv6 address                       : 2001::1234:5678:0102:0304
Username                           : N/A
AID                                : 1
AP ID                              : 1
AP name                            : ap1
Radio ID                           : 1
Channel                            : 36
SSID                               : office
BSSID                              : 0026-3e08-1150
VLAN ID                            : 3
VLAN ID2                           : N/A
Sleep count                        : 3
Wireless mode                      : 802.11gn
Channel bandwidth                  : 20MHz
20/40 BSS Coexistence Management   : Not supported
SM power save                      : Enabled
Short GI for 160/80+80MHz          : Not supported
STBC RX capability                 : Not supported
STBC TX capability                 : Not supported
LDPC RX capability                 : Not supported
SU beamformee capability           : Not supported
MU beamformee capability           : Not supported
Beamformee STS capability          : N/A
Block Ack                          : TID 0 In
Supported VHT-MCS set              : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8, 9
Supported HT MCS set               : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15
Supported rates                    : 1, 2, 5.5, 6, 9, 11,
QoS mode                           : WMM
Listen interval                    : 10
RSSI                               : 62
Rx/Tx rate                         : 130/195 Mpbs
Speed                              : N/A
Authentication method              : Open system
Security mode                      : PRE-RSNA
AKM mode                           : Not configured
Cipher suite                       : N/A
User authentication mode           : Bypass
WPA3 status                        : Disabled
Authorization ACL ID               : 3001(Not effective)
Authorization user profile         : N/A
Authorization CAR                  :
  Average input rate               : 102400 bps
  Average output rate              : 102400 bps
Roam status                        : N/A
Key derivation                     : SHA1
PMF status                         : Enabled
Forwarding policy name             : Not configured
Online time                        : 0days 0hours 1minutes 13seconds
FT status                          : Inactive
BTM status                         : Disabled
Table 37 Command output
MAC address
Client MAC address.
IPv4 address
Client IPv4 address.
IPv6 address
Client IPv6 address.
Username
Client username:
AID
Association ID.
AP ID
ID of the AP that the client is associated with.
AP name
Radio ID
Channel
Working channel of the associated radio.
SSID
SSID with which the client is associated.
VLAN ID
ID of the inner VLAN to which the client belongs.
VLAN ID2
ID of the outer VLAN to which the client belongs.
This field displays N/A if no outer VLAN is specified.
Sleep count
Client sleep times.
Wireless mode
Wireless mode:
·     802.11a.
·     802.11b.
·     802.11g.
·     802.11gn.
·     802.11an.
·     802.11ac.
·     802.11ax.
·     802.11gax.
Channel bandwidth
Channel bandwidth:
·     20 MHz.
·     40 MHz.
·     80 MHz.
·     160 MHz.
Whether the client supports 20/40MHz channel bandwidth coexistence.
SM Power Save
SM Power Save status:
·     Enabled—Only one antenna of a client operates in active state, and others operate in sleep state to save power.
·     Disabled.
Short GI for 20MHz
Whether the client supports short GI when its channel bandwidth is 20 MHz:
·     Supported.
·     Not supported.
Short GI for 40MHz
Whether the client supports short GI when its channel bandwidth is 40 MHz:
·     Supported.
·     Not supported.
Short GI for 80MHz
Whether the client supports short GI when its channel bandwidth is 80 MHz:
·     Supported.
·     Not supported.
Whether the client supports short GI when its channel bandwidth is 160 MHz or 80 + 80 MHz:
·     Supported.
·     Not supported.
STBC Rx Capability
Client STBC receive capability;
·     Not Supported.
·     Supported.
STBC Tx Capability
Client STBC transmission capability:
·     Not Supported.
·     Supported.
LDPC Rx capability
Client LDPC receive capability;
·     Not Supported.
·     Supported.
Client SU beamformee capability:
·     Not Supported.
·     Supported.
Client MU beamformee capability:
·     Not Supported.
·     Supported.
Supported spatial stream quantity if the client is a beamformee receiver, in the range of 0 to 7 (the maximum spatial stream quantity specified by the MIMO mode minus one). This field displays N/A if the client cannot act as a beamformee receiver.
Number of Sounding Dimensions
Supported spatial stream quantity if the client is a beamformee transmitter, in the range of 0 to 7 (the maximum spatial stream quantity specified by the MIMO mode minus one). This field displays N/A if the client cannot act as a beamformee transmitter.
Block Ack
Negotiation result of Block ACK with TID:
·     TID 0 In—Sends Block ACK for inbound traffic.
·     TID 0 Out—Sends Block ACK for outbound traffic.
·     TID 0 Both—Sends Block ACK for both inbound and outbound traffic.
·     N/A—Does not send Block ACK for both inbound and outbound traffic.
VHT-MCS supported by the client.
2.4G 40MHz Channel bandwidth
Client support for 2.4G 40 MHz channel bandwidth:
·     Not Supported.
·     Supported.
5G 40And80MHz  Channel bandwidth
Client support for 5G 40 MHz and 80 MHz channel bandwidth:
·     Not Supported.
·     Supported.
5G 160MHz  Channel bandwidth
Client support for 5G 160 MHz channel bandwidth:
·     Not Supported.
·     Supported.
5G 8080MHz  Channel bandwidth
Client support for 5G 80+80 MHz channel bandwidth:
·     Not Supported.
·     Supported.
Support for OFDMA random selection of RUs.
·     Not Supported.
·     Supported.
Supported HE80MHz-MCS set
Supported 80 MHz HE-MCS sets.
Supported HE160MHz-MCS set
Supported 160 MHz HE-MCS sets.
Supported HE 8080MHz-MCS set
Supported 80+80 MHz HE-MCS sets.
TWT scheduled
Whether the client is a TWT scheduled client. A TWT scheduled client can calculate and negotiate TWT scheduling information.
·     Yes.
·     No.
QoS mode
QoS mode:
·     N/A—WMM is not supported.
·     WMM—WMM is supported.
WMM information negotiation is carried out between an AP and a client that both support WMM.
Listen interval
Interval at which the client wakes up to listen for beacon frames. It is counted by beacon interval.
RSSI
Received signal strength indication. This value indicates the client signal strength detected by the AP.
Rx/Tx rate
Sending and receiving rates of data, management, and control frames.
Speed
Sending and receiving rates in the past 2 minutes in Kbps, rounded to three decimal places.
This field displays N/A if both the sending and receiving rates are 0.
·     Open system.
·     Shared key.
·     SAE.
·     FT.
Security mode
Security mode:
·     RSN—Beacons and probe responses carry RSN IE.
·     WPA—Beacons and probe responses carry WPA IE.
·     PRE-RSNA—Beacons and probe responses do not carry RSN IE or WPA IE.
AKM mode
AKM mode:
·     802.1X.
·     PSK.
·     OWE.
·     Not configured.
Cipher suite
Cipher suite:
·     N/A.
·     WEP40.
·     WEP104.
·     WEP128.
·     CCMP.
·     TKIP.
·     GCMP.
User authentication mode:
·     Bypass—No client authentication.
·     MAC.
·     802.1X.
·     OUI.
WPA3 status
WPA3 status:
·     Disabled.
·     Enabled.
·     N/A.
Authorized ACL number:
·     This field displays the ACL number if the authorized ACL takes effect.
·     This field displays ACL number(Not effective) if the authorized ACL does not take effect.
·     This field displays N/A if the authentication server is configured without any authorized ACL.
Name of the authorized user profile:
·     This field displays the authorized user profile name if the authorized user profile takes effect.
·     This field displays authorized user profile name + Not effective if the authorized user profile does not take effect.
·     This field displays N/A if the authentication server is configured without any authorized user profile.
Authorization CAR
Authorization CAR:
·     Average input rate—Average uplink rate in bps.
·     Average output rate—Average downlink rate in bps.
·     N/A—This field displays N/A if the authentication server is not configured with authorization CAR for users.
Roam status
Roam status:
·     Roaming in progress.
·     Inter-AC roam.
·     Inter-MA roam.
·     Intra-AC roam.
·     Intra-MA roam.
·     This field displays N/A if the client stays in one BSS after coming online.
Key derivation
Key derivation type:
·     SHA1—Uses the HMAC-SHA1 hash algorithm.
·     SHA256—Uses the HMAC-SHA256 hash algorithm.
·     SHA384—Uses the HMAC-SHA384 hash algorithm.
·     N/A—No key derivation algorithm is involved for the authentication type.
PMF status
PMF status:
·     Enabled—Management frame protection is enabled.
·     Disabled—Management frame protection is disabled.
·     N/A—Management frame protection is not involved.
WLAN forwarding policy name:
·     Not configured.
·     Policy-name.
Online time
Client online duration.
FT status
Fast BSS transition (FT) status:
·     Active—FT is enabled.
·     Inactive—FT is disabled.
BTM status
BSS transition management (BTM) status:
·     Disabled.
·     Enabled.
display wlan client status
Use display wlan client status to display client status information.
display wlan client status [ mac-address mac-address ] [ verbose ]
mac-address mac-address: Specifies a client by its MAC address in the format of H-H-H. If you do not specify this option, the command displays status information about all clients.
verbose: Displays detailed client status information. If you do not specify this keyword, the command displays brief client status information.
# Display brief status information about the specified client.
<Sysname> display wlan client status mac-address 001c-f08f-f804
MAC address      RSSI  Rx/Tx rate    Speed(bps)   Discard  AP name          RID
001c-f08f-f804  0      39M/117M       N/A           0.00%    ap2               2
# Display brief status information about all clients.
Total number of clients: 2
000b-c002-9d09   65    39M/117M       N/A           0.00%    ap2               2
000f-e265-6401   62    130M/195M      N/A           0.00%    ap1               1
Table 38 Command output
MAC address
Client MAC address.
RSSI
RSSI of the client.
Rx/Tx rate
Rates at which the client receives and sends data, management packets, and control packets.
Speed(bps)
Rates at which the client receives and sends packets in the past 2 minutes, rounded to one decimal place.
·     If a rate is smaller than 1 Mbps, the value is displayed in Kbps.
·     If a rate equals 1 Mbps or is larger than 1 Mbps, the value is displayed in Mbps.
·     If a rate equals 1 Gbps or is larger than 1 Gbps, the value is displayed in Gbps.
Discard
Ratio of packets discarded by the client.
AP name
Name of the AP with which the client is associated.
RID
ID of the radio with which the client is associated.
# Display detailed status information about the specified client.
<Sysname> display wlan client status mac-address 001c-f08f-f804 verbose
MAC address                       : 001c-f08f-f804
AP name                           : ap2
Radio ID                          : 2
RSSI                              : 0
Rx/Tx rate                        : 39/117 Mbps
Speed                             N/A
Received:
 Retransmitted packets            : 84
 Retransmitted packet ratio       : 64.12 %
Sent:
 Retransmitted packets            : 0
 Retransmitted packet ratio       : 0.00 %
Discarded:
 Discarded packets                : 0
 Discarded packet ratio           : 0.00 %
Table 39 Command output
MAC address
Client MAC address.
AP name
Radio ID
RSSI
RSSI of the client.
Rx/Tx rate
Speed
Received
Received packet statistics:
·     Retransmitted packets.
·     Retransmitted packet ratio.
Sent
Sent packet statistics:
Discarded
Discarded packet statistics:
·     Discarded packets.
·     Discarded packet ratio.
display wlan service-template
Use display wlan service-template to display service template information.
display wlan service-template [ service-template-name ] [ verbose ]
service-template-name: Specifies a service template by its name, a case-insensitive string of 1 to 63 characters. If you do not specify this argument, the command displays information about all service templates.
verbose: Displays detailed service template information.
# Display brief information about all service templates.
<Sysname> display wlan service-template
Total number of service templates: 2
Service template name          SSID                 Status
1                                  2333                 Enabled
2                                  3222                 Enabled
# Display detailed information about all service templates.
<Sysname> display wlan service-template verbose
Service template name         : service1
SSID                          : wuxianfuwu
SSID-hide                     : Disabled
User-isolation                : Disabled
Service template status       : Disabled
Maximum clients per BSS       : 64
Frame format                  : Dot3
Seamless roam status          : Disabled
Seamless roam RSSI threshold  : 50
Seamless roam RSSI gap        : 20
VLAN ID                       : 1
AKM mode                      : PSK
Security IE                   : RSN
Cipher suite                  : CCMP
WEP key ID                    : 1
TKIP countermeasure time      : 100 sec
PTK lifetime                  : 43200 sec
GTK rekey                     : Enabled
GTK rekey method              : Time-based
GTK rekey time                : 86400 sec
GTK rekey client-offline      : Enabled
PPSK                              : Disabled
PPSK Fail Permit                : Disabled
Enhance-open status             : Enabled
Enhanced-open transition-mode service-template   : N/A
Intrusion protection          : Disabled
Intrusion protection mode     : Temporary-block
Temporary block time          : 180 sec
Temporary service stop time   : 20 sec
Fail VLAN ID                  : 1
802.1X handshake              : Enabled
802.1X handshake secure       : Disabled
802.1X domain                 : my-domain
MAC-auth domain               : Not configured
Max 802.1X users per BSS      : 4096
Max MAC-auth users per BSS    : 4096
802.1X re-authenticate        : Enabled
Authorization fail mode       : Online
Accounting fail mode          : Online
Authorization                 : Permitted
PMF status                    : Optional
Hotspot policy number         : Not configured
Forwarding policy status      : Disabled
Forward policy name           : Not configured
Forwarder                     : AC
FT status                     : Enabled
QoS trust                     : Port
QoS priority                  : 0
Table 40 Command output
SSID
SSID of the service template.
SSID-hide
Whether the SSID is hidden in beacons:
·     Disabled.
·     Enabled.
User-isolation
Use isolation:
·     Disabled.
·     Enabled.
Service template status:
·     Disabled.
·     Enabled.
Maximum number of clients that the BSS supports.
Frame format
Client data frame encapsulation format:
·     Dot3—802.3 format.
·     Dot11—802.11 format.
Seamless roaming status:
·     Disabled.
·     Enabled.
Seamless roaming RSSI threshold.
Seamless roaming RSSI gap.
VLAN ID
ID of the inner VLAN to which clients belong after they come online through the service template.
Service VLAN ID
ID of the outer VLAN to which clients belong after they come online through the service template.
Service VLAN TPID
TPID of the outer VLAN.
·     dot1q—0x8100.
·     dot1ad—0x88A8.
AKM mode
AKM mode:
·     802.1X.
·     PSK.
Security IE
Security IE:
·     RSN.
·     WPA.
Cipher suite
Cipher suite:
·     WEP40.
·     WEP104.
·     WEP128.
·     TKIP.
·     CCMP.
·     GCMP.
TKIP countermeasure time. The value 0 indicates no countermeasures are taken.
PTK rekey
Whether PTK rekey is enabled:
·     Enabled.
·     Disabled.
GTK rekey
Whether GTK rekey is enabled:
·     Enabled.
·     Disabled.
GTK rekey method
GTK rekey method:
·     Time-based.
·     Packet-based.
GTK rekey time
GTK rekey interval.
GTK rekey packets
Number of packets that can be transmitted before the GTK is refreshed.
Whether client-off GTK rekey is enabled:
·     Enabled.
·     Disabled.
WPA3 status
WPA3 security mode:
·     Disabled.
·     Mandatory.
·     Optional.
PPSK
Whether PPSK is enabled:
·     Disabled.
·     Enabled.
PPSK Fail Permit
Whether PPSK fail permit is enabled:
·     Disabled.
·     Enabled.
Enhance-open status
Whether enhanced open system authentication is enabled:
·     Disabled.
·     Enabled.
Recommended service template in transition mode. If no service template is specified, this field displays N/A.
Authentication mode:
·     Bypass—No authentication.
·     MAC.
·     MAC-or-802.1X—MAC authentication is performed first. If MAC authentication fails, 802.1X authentication is performed.
·     802.1X.
·     802.1X-or-MAC—802.1X authentication is performed first. If 802.1X authentication fails, MAC authentication is performed.
·     OUI-or-802.1X—OUI authentication is performed first. If OUI authentication fails, 802.1X authentication is performed.
·     MAC-and-802.1X—MAC authentication is performed first. If MAC authentication succeeds, 802.1X authentication is performed.
Whether intrusion protection is enabled:
·     Enabled.
·     Disabled.
Intrusion protection mode:
·     Temporary-block—Temporarily adds intruders to the block list.
·     Service-stop—Stops all services provided by the BSS that receives illegal packets until it resets.
·     Temporary-service-stop—Temporarily stops the access service provided by the BSS that receives illegal packets.
Temporary block time in seconds.
Temporary service stop time in seconds.
Fail VLAN ID
ID of the VLAN to which clients are added if they cannot pass the authentication when the authentication server can be reached. This field displays Not configured if the fail VLAN ID is not configured.
Critical VLAN ID
ID of the VLAN to which clients are added if they cannot pass the authentication because the authentication server cannot be reached. This field displays Not configured if the critical VLAN ID is not configured.
802.1X handshake
Whether 802.1X handshake is enabled:
·     Enabled.
·     Disabled.
Whether secure 802.1X handshake is enabled:
·     Enabled.
·     Disabled.
802.1X domain
802.1X authentication domain. This field displays Not configured if the domain is not configured.
MAC-auth domain
MAC authentication domain. This field displays Not configured if the domain is not configured.
Maximum number of supported 802.1X users in a BSS.
Maximum number of supported users that pass the MAC authentication in a BSS.
Whether 802.1X reauthentication is enabled:
·     Enabled.
·     Disabled.
Authorization fail mode:
·     Offline—Clients are logged off when authorization fails.
·     Online—Clients are not logged off when authorization fails.
Accounting fail mode:
·     Offline—Clients are logged off when accounting fails.
·     Online—Clients are not logged off when accounting fails.
Authorization
Authorization information:
·     Permitted—Applies the authorization information issued by the RADIUS server or the local device.
·     Ignored—Ignores the authorization information issued by the RADIUS server or the local device.
Key derivation
·     SHA1-AND-SHA256—Uses the HMAC SHA1 and SHA256 hash algorithm.
PMF status
PMF status:
·     Optional—Management frame protection in optional mode is enabled.
·     Mandatory—Management frame protection in mandatory mode is enabled.
Hotspot 2.0 policy number.
WLAN forwarding policy status:
·     Disabled.
·     Enabled.
Forward policy name
·     Not configured—No WLAN forwarding policy is configured.
·     policy-name.
Forwarder
Client traffic forwarder:
·     AC—AC in a non-AC hierarchical network and local AC in an AC hierarchical network.
·     AP.
·     Central AC.
FT status
FT status:
·     Disabled.
·     Enabled.
FT method
FT method:
·     over-the-air.
·     over-the-ds.
FT reassociation deadline
FT reassociation timeout timer in seconds.
QoS trust
QoS priority trust mode:
·     Port—Port priority trust mode.
·     Dot11e—802.11e priority trust mode.
QoS priority
Port priority in the range of 0 to 7.
BTM status
BSS Transition Management (BTM) status:
·     Disabled.
·     Enabled.
display wlan statistics ap radio
Use display wlan statistics ap radio to display radio statistics.
display wlan statistics ap { all | name ap-name } radio
# Display radio statistics for AP ap1.
<Sysname> display wlan statistics ap name ap1 radio
                                 Radio Statistics
 AP name: ap1                                   Radio ID: 1
Transmitted frame statistics:
  Total frames                              : 836532
  Total frame bytes                         : 214040681
  Unicast frames                            : 4
  Unicast frame bytes                       : 900
  Broadcast/Multicast frames                : 836528
  Broadcast/Multicast frame bytes           : 214039781
  Other frames                              : 0
  Other frame bytes                         : 0
  Discarded frames                          : 0
  Failed RTS frames                         : 0
  Retransmissions                           : 6
  Successful RTS frames                     : 0
  Retransmitted frames                      : 3
  No-ACK frames                             : 1555
  Authentication frames                     : 1
  Association frames                        : 1
  Packet statistics by size:
    Smaller than or equal to 128            : 747
    Between 128 and 512 (inclusive)         : 85983
    Between 512 and 1024 (inclusive)        : 0
    Larger than 1024                        : 0
  Packet statistics by rate:
         1 Mbps                    : 0                   2 Mbps    : 0
       5.5 Mbps                    : 0                   6 Mbps    : 0
         9 Mbps                    : 0                  11 Mbps    : 0
        12 Mbps                    : 0                  18 Mbps    : 0
        24 Mbps                    : 880                36 Mbps    : 0
        48 Mbps                    : 0                  54 Mbps    : 0
  Packet statistics by 802.11n rate:
       6.5 Mbps                    : 0                 7.2 Mbps    : 0
        13 Mbps                    : 0                13.5 Mbps    : 0
      14.4 Mbps                    : 0                  15 Mbps    : 0
      19.5 Mbps                    : 0                21.7 Mbps    : 0
        26 Mbps                    : 0                  27 Mbps    : 0
      28.9 Mbps                    : 0                29.3 Mbps    : 0
        30 Mbps                    : 0                32.5 Mbps    : 0
        39 Mbps                    : 0                40.5 Mbps    : 0
      43.3 Mbps                    : 0                  45 Mbps    : 0
        52 Mbps                    : 0                  54 Mbps    : 0
      57.8 Mbps                    : 0                58.5 Mbps    : 0
        60 Mbps                    : 0                  65 Mbps    : 0
      72.2 Mbps                    : 0                  78 Mbps    : 1
        81 Mbps                    : 0                86.7 Mbps    : 0
      87.8 Mbps                    : 0                  90 Mbps    : 0
      97.5 Mbps                    : 0                 104 Mbps    : 3
       108 Mbps                    : 0               115.6 Mbps    : 0
       117 Mbps                    : 0                 120 Mbps    : 0
     121.5 Mbps                    : 0                 130 Mbps    : 0
       135 Mbps                    : 0               144.4 Mbps    : 0
       150 Mbps                    : 0                 156 Mbps    : 0
       162 Mbps                    : 0               173.3 Mbps    : 0
     175.5 Mbps                    : 0                 180 Mbps    : 0
       195 Mbps                    : 0                 200 Mbps    : 0
       216 Mbps                    : 0               216.7 Mbps    : 0
       234 Mbps                    : 0                 240 Mbps    : 0
       243 Mbps                    : 0                 260 Mbps    : 0
     263.3 Mbps                    : 0                 270 Mbps    : 0
     288.9 Mbps                    : 0               292.5 Mbps    : 0
       300 Mbps                    : 0                 324 Mbps    : 0
       325 Mbps                    : 0                 351 Mbps    : 0
       360 Mbps                    : 0               364.5 Mbps    : 0
       390 Mbps                    : 0                 400 Mbps    : 0
       405 Mbps                    : 0               433.3 Mbps    : 0
       450 Mbps                    : 0                 468 Mbps    : 0
       486 Mbps                    : 0                 520 Mbps    : 0
     526.5 Mbps                    : 0                 540 Mbps    : 0
       585 Mbps                    : 0                 600 Mbps    : 0
       650 Mbps                    : 0                 702 Mbps    : 0
       780 Mbps                    : 0               866.7 Mbps    : 0
     877.5 Mbps                    : 0                 975 Mbps    : 0
      1053 Mbps                    : 0                1170 Mbps    : 0
      1300 Mbps                    : 0
Received frame statistics:
  Total frames                         : 420815
  Total frame bytes                    : 24112652
  Unicast frames                       : 585
  Unicast frame bytes                  : 15357
  Broadcast/Multicast frames           : 420230
  Broadcast/Multicast frame bytes      : 24097295
  Fragmented frames                    : 0
  Duplicate frames                     : 0
  FCS failures                         : 474471639
  Decryption errors                    : 0
    Smaller than or equal to 128            : 420759
    Between 128 and 512 (inclusive)         : 54
         6 Mbps                    : 420115              9 Mbps    : 0
        24 Mbps                    : 0                  36 Mbps    : 1
        48 Mbps                    : 0                  54 Mbps    : 2
        52 Mbps                    : 1                  54 Mbps    : 2
      57.8 Mbps                    : 0                58.5 Mbps    : 17
        60 Mbps                    : 0                  65 Mbps    : 10
      72.2 Mbps                    : 0                  78 Mbps    : 48
        81 Mbps                    : 0                86.7 Mbps    : 70
      97.5 Mbps                    : 0                 104 Mbps    : 87
       108 Mbps                    : 0               115.6 Mbps    : 170
       117 Mbps                    : 130               120 Mbps    : 0
     121.5 Mbps                    : 0                 130 Mbps    : 140
       135 Mbps                    : 0               144.4 Mbps    : 22
      1300 Mbps                    : 0
                                 Radio Statistics
 AP name: ap1                                   Radio ID: 2
  Total frames                              : 13134
  Total frame bytes                         : 3259997
  Unicast frames                            : 11
  Unicast frame bytes                       : 3518
  Broadcast/Multicast frames                : 13123
  Broadcast/Multicast frame bytes           : 3256479
  Other frames                              : 0
  Retransmissions                           : 58
  Retransmitted frames                      : 11
  No-ACK frames                             : 7541
  Authentication frames                     : 14
  Association frames                        : 8
    Smaller than or equal to 128            : 1020
    Between 128 and 512 (inclusive)         : 11386
         9 Mbps                    : 0                  11 Mbps    : 1121
        24 Mbps                    : 0                  36 Mbps    : 0
       6.5 Mbps                    : 3                 7.2 Mbps    : 0
        13 Mbps                    : 1                13.5 Mbps    : 0
      19.5 Mbps                    : 4                21.7 Mbps    : 0
        39 Mbps                    : 1                40.5 Mbps    : 0
      72.2 Mbps                    : 0                  78 Mbps    : 0
      97.5 Mbps                    : 0                 104 Mbps    : 1
       117 Mbps                    : 1                 120 Mbps    : 0
      1300 Mbps                    : 0
  Total frames                         : 32156
  Total frame bytes                    : 3076192
  Unicast frames                       : 1613
  Unicast frame bytes                  : 102957
  Broadcast/Multicast frames           : 30543
  Broadcast/Multicast frame bytes      : 2973235
  Duplicate frames                     : 2
  FCS failures                         : 9978084
    Smaller than or equal to 128            : 25327
    Between 128 and 512 (inclusive)         : 6097
         1 Mbps                    : 28718               2 Mbps    : 1895
       5.5 Mbps                    : 284                 6 Mbps    : 29
         9 Mbps                    : 12                 11 Mbps    : 0
        12 Mbps                    : 10                 18 Mbps    : 24
        24 Mbps                    : 11                 36 Mbps    : 5
        48 Mbps                    : 4                  54 Mbps    : 0
       6.5 Mbps                    : 45                7.2 Mbps    : 0
        13 Mbps                    : 53               13.5 Mbps    : 0
      19.5 Mbps                    : 120              21.7 Mbps    : 0
        26 Mbps                    : 136                27 Mbps    : 0
        39 Mbps                    : 59               40.5 Mbps    : 0
        52 Mbps                    : 17                 54 Mbps    : 0
      57.8 Mbps                    : 0                58.5 Mbps    : 20
        60 Mbps                    : 0                  65 Mbps    : 4
      97.5 Mbps                    : 0                 104 Mbps    : 0
      1300 Mbps                    : 0
Table 41 Command output
Total frames
Total number of transmitted frames, including probe responses and beacon frames.
Total frame bytes
Total bytes of transmitted frames, including probe responses and beacon frames.
Unicast frames
Total number of transmitted unicast frames, excluding probe responses.
Unicast frame bytes
Total bytes of transmitted unicast frames, excluding probe responses.
Total number of transmitted broadcast and multicast frames, excluding beacon frames.
Total bytes of transmitted broadcast and multicast frames, excluding beacon frames.
Others frames
Total number of other transmitted frames.
Others frame bytes
Total bytes of other transmitted frames.
Total number of packets classified by 802.11a/b/g rates.
Packet statistics based on data rate
Total number of packets classified by 802.11n rates. This field is not available if the device does not support 802.11n.
Total frames
Total number of received frames.
Total frame bytes
Total bytes of received frames.
Unicast frames
Total number of received unicast frames.
Unicast frame bytes
Total bytes of received unicast frames.
Total number of received broadcast and multicast frames.
Total bytes of received broadcast and multicast frames.
Fragmented frames
Total number of received fragmented frames.
FCS failures
Total number of received packets with FCS failures.
Decryption errors
Total number of received packets with decryption errors.
display wlan statistics client
Use display wlan statistics client to display client statistics.
display wlan statistics client [ mac-address mac-address ]
mac-address mac-address: Specifies a client by its MAC address. If you do not specify this option, the command displays statistics for all clients.
# Display statistics for all clients.
<Sysname> display wlan statistics client
MAC address                : 0014-6c8a-43ff
AP name                    : ap1
Radio ID                   : 1
SSID                       : office
BSSID                      : 000f-e2ff-7700
RSSI                       : 31
Sent frames
  Back ground              : 0/0 (frames/bytes)
  Best effort              : 9/1230 (frames/bytes)
  Video                    : 0/0 (frames/bytes)
  Voice                    : 2/76 (frames/bytes)
Received frames:
  Best effort              : 18/2437 (frames/bytes)
  Voice                    : 7/468 (frames/bytes)
Discarded frames
  Best effort              : 0/0 (frames/bytes)
  Voice                    : 5/389 (frames/bytes)
Table 42 Command output
SSID
MAC address
Client MAC address.
Back ground
AC-BK queue.
Best effort
AC-BE queue.
Video
AC-VI queue.
Voice
AC-VO queue.
display wlan statistics connect-history
Use display wlan statistics connect-history to display client connection history.
On ACs:
display wlan statistics connect-history { ap { all | name ap-name } | service-template service-template-name }
On fat APs:
display wlan statistics connect-history service-template service-template-name
ap: Specifies APs. (On ACs)
all: Specifies all APs. (On ACs)
name ap-name: Specifies an AP by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).(On ACs)
service-template service-template-name: Specifies a service template by its name.
# Display the connection history for service template 1.
<Sysname> display wlan statistics connect-history service-template 1
AP name                     : ap1
Radio ID                    : 1
Associations                : 132
Association failures        : 3
Reassociations              : 30
Rejections                  : 12
Abnormal disassociations    : 2
Current associations        : 57
# Display the connection history for AP ap1.
<Sysname> display wlan statistics connect-history ap name ap1
AP name                       : ap1
Associations                  : 1
Reassociations                : 0
Failures                      : 0
Rejections                    : 0
Abnormal disassociations      : 0
Current associations          : 1
Current 2G sta                : 0
   11b sta                    : 0
   11g sta                    : 0
   11gn sta                   : 0
   11gac sta                  : 0
   11gax sta                  : 0
Current 5G sta                : 0
   11a sta                    : 0
   11an sta                   : 0
   11ac sta                   : 2
   11ax sta                   : 0
Received bytes                1000
Sent bytes                    : 2000
display wlan statistics service template
Use display wlan statistics service-template to display service template statistics.
display wlan statistics service-template service-template-name
# Display statistics for service template 1.
<Sysname> display wlan statistics service-template 1
AP name                       : ap1
Radio ID                      : 1
Received
  Frame count                 : 1713
  Frame bytes                 : 487061
  Data frame count            : 1683
  Data frame bytes            : 485761
  Association request count   : 2
Sent
  Frame count                 : 62113
  Frame bytes                 : 25142076
  Data frame count            : 55978
  Data frame bytes            : 22626600
  Association response count  : 2
display wlan whitelist
Use display wlan whitelist to display whitelist entries.
# Display whitelist entries.
<Sysname> display wlan whitelist
 MAC addresses:
  000e-35b2-000e
  0019-5b8e-b709
  001c-f0bf-9c92
display wlan wt
Use display wlan wt to display wireless terminator (WT) information and information about the wireless terminator units (WTUs) connected to it.
display wlan wt { all | name wt-name }
all: Specifies all WTs.
name wt-name: Specifies a WT by its name, a case-sensitive string of 1 to 64 characters. The string can contain letters, digits, underscores (_), dots (.), left brackets ([), right brackets (]), forward slashes (/), and hyphens (-).
# Display information about all WTs.
<Sysname> display wlan wt all
WT name          : wt1
Model            : WT1020
Serial ID        : 219801A0SS9156G00072
MAC address      : 0000-f3ea-0a3e
WTU number       : 2
  Wireless Terminator Unit:
  WTU name      Port         Model      Serial ID
  wtu1          1            WTU430     219801A0SS9156G00185
  wtu2          2            WTU430     219801A0SS9156G00133
WT name          : wt2
Model            : WT1020
Serial ID        : 219801A0SS9156G00068
MAC address      : 0000-f3ea-0a3a
WTU number       : 2
  wtu3          3            WTU430     219801A0SS9156G00054
  Wtu4          4            WTU430     219801A0SS9156G00167
Table 43 Command output
Fields
WTU number
Number of WTUs that are connected to the WT.
WTU information.
Port
Port that connects the WT to a WTU.
wlan ap-execute exec-console enable
Use wlan ap-execute exec-console enable to enable the execution console for an online AP.
Use wlan ap-execute exec-console disable to disable the execution console for an online AP.
wlan ap-execute ap-name exec-console { disable | enable }
When an AP comes online, the execution console is automatically disabled. When the AP goes offline, the execution console is automatically enabled.
Probe view
When the execution console of an AP is disabled, users cannot log in to the AP through the console port or through Telnet. This command does not affect logged-in users.
wlan ap-link-test
Use wlan ap-link-test to test the CAPWAP tunnel performance.
wlan ap-link-test { ipv4-address | ipv6-address } [ destination port-number | source port-number | packet-length value | { burst | continuous } rate rate time time ] *
Probe view
ipv4-address: Specifies an AP by its IPv4 address.
ipv6-address: Specifies an AP by its IPv6 address.
destination port-number: Specifies the destination UDP port in the range of 1 to 65535. The default destination UDP port is 5246.
source port-number: Specifies the source UDP port in the range of 1 to 65535. The default source UDP port is 5246.
packet-length value: Specifies the tested packet length in bytes. The value range for the value argument is 66 to 2048. The default value is 128.
burst: Enables burst packet-sending mode. Fragmented packets are sent at a one-time attempt every 1 second.
continuous: Enables continuous packet sending mode. Fragmented packets are sent every 10 milliseconds within a second. If all fragmented packets are sent within a second, the device does not send packets until the next second starts.
rate rate: Specifies the packet transmit rate in packets per second. The value range for the rate argument is 1 to 10000.
time time: Specifies the test duration in seconds. The value range for the time argument is 1 to 100.
