H3C S1850-X & S1850V2-X & S1850V2-EI Switch Series Hardware Information and Specifications-6W101
HomeSupportProduct LiteratureHardware Information & SpecificationsH3C S1850-X & S1850V2-X & S1850V2-EI Switch Series Hardware Information and Specifications-6W101
01-Hardware Information and Specifications
01-Hardware Information and Specifications 2.07 MB
1 Product models and technical specifications
Product models
This document is applicable to the following Ethernet switches.
Product series
Product model
Product code (PID)
S1850-X switch series
S1850-28X
LS-1850-28X
S1850-52X
LS-1850-52X
S1850-28X-PWR
LS-1850-28X-PWR
S1850-52X-PWR
LS-1850-52X-PWR
S1850V2-X switch series
S1850V2-28X
LS-1850V2-28X
LS-1850V2-28X-GL
S1850V2-52X
LS-1850V2-52X
LS-1850V2-52X-GL
S1850V2-28X-HPWR
LS-1850V2-28X-HPWR
LS-1850V2-28X-HPWR-GL
S1850V2-52X-PWR
LS-1850V2-52X-PWR
LS-1850V2-52X-PWR-GL
S1850V2-EI switch series
S1850V2-52P-EI
LS-1850V2-52P-EI
LS-1850V2-52P-EI-GL
S1850V2-28P-EI
LS-1850V2-28P-EI
LS-1850V2-28P-EI-GL
S1850V2-28P-HPWR-EI
LS-1850V2-28P-HPWR-EI
LS-1850V2-28P-HPWR-EI-GL
S1850V2-9P-EI
LS-1850V2-9P-EI
S1850V2-10P-EI
LS-1850V2-10P-EI
LS-1850V2-10P-EI-GL
S1850V2-10P-PWR-EI
LS-1850V2-10P-PWR-EI
S1850V2-10P-HPWR-EI
LS-1850V2-10P-HPWR-EI-GL
Switches of the same model but different PIDs might differ in hardware and software features. You can view the PID of a switch on the label located on its rear panel or top panel.
Technical specifications
Table1-1 Technical specifications of S1850-X non-PoE switch models
Item
S1850-28X
S1850-52X
Dimensions (H × W × D)
43.6 × 440 × 160 mm (1.72 × 17.32 × 6.30 in)
43.6 × 440 × 230 mm (1.72 × 17.32 × 9.06 in)
Weight
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
Console port
·     1 × serial console port
·     1 × micro USB console port
If you connect each of the console ports to a configuration terminal, only the micro USB console port takes effect.
10/100/1000BASE-T autosensing Ethernet port
24
48
SFP port
2
2
SFP+ port
2
2
Input voltage
·     Rated voltage range: 100 VAC to 240 VAC @ 50 or 60 Hz
·     Max voltage range: 90 VAC to 264 VAC @ 47 to 63 Hz
Power consumption (static)
9 W
19 W
Power consumption (fully loaded)
24 W
44 W
Chassis leakage current compliance
UL 62368-1/EN 62368-1/IEC 62368-1/UL 60950-1/IEC 60950-1/GB4943.1
Melting current of power supply fuse
2 A/250 V
3.15 A/250 V
Cooling system
The device uses fixed fan trays. It draws cool air from the chassis left side, right side, and port side and exhausts heated air from the power supply side.
The device uses fixed fan trays. It draws cool air from the chassis left side and right side and exhausts heated air from the power supply side.
Operating temperature
–5°C to +45°C (23°F to 113°F)
Operating humidity
5% to 95%, noncondensing
Fire resistance compliance
Table1-2 Technical specifications of S1850-X PoE switch models
Item
S1850-28X-PWR
S1850-52X-PWR
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in)
43.6 × 440 × 400 mm (1.72 × 17.32 × 15.75 in)
Weight
≤ 4 kg (8.82 lb)
≤ 6 kg (13.23 lb)
Console port
24
48
SFP port
2
2
SFP+ port
2
2
Input voltage
·     AC
¡     Rated voltage range: 100 VAC to 240 VAC @ 50 or 60 Hz
¡     Max voltage range: 90 VAC to 264 VAC @ 47 to 63 Hz
·     DC (supported only on the S1850-52X-PWR switch)
¡     Rated voltage range: –54 to –57 VDC
Single DC input: 44 to 60 VDC
AC+DC input: 54 to 57 VDC
You can only use an H3C RPS1600-A power supply to supply DC power to the device.
Max PoE power per port
30 W
30 W
Total PoE power
185 W
AC: 370 W
DC: 740 W
Static power consumption
15 W
AC: 32 W
DC: 26 W
Max power consumption (including PoE power output )
219 W
AC: 473 W
DC: 820 W
10 A/250 V
15 A/250 V
Cooling system
The device uses fixed fan trays. It draws cool air from the chassis left side and port side and exhausts heated air from the right side.
The device uses fixed fan trays. It draws cool air from the chassis left side and exhausts heated air from the chassis right side.
Operating humidity
Table1-3 Technical specifications of S1850V2-X non-PoE switch models
Item
S1850V2-28X
S1850V2-52X
Weight
≤ 2.5 kg (5.5115 lb)
≤ 3.5 kg (7.716 lb)
Console port
24
48
SFP+ port
4
4
Input voltage
10 W
19 W
24 W
44 W
2 A/250 V
3.15 A/250 V
Cooling system
Natural cooling without fan trays
Operating humidity
Table1-4 Technical specifications of S1850V2-X PoE switch models
Item
S1850V2-28X-HPWR
S1850V2-52X-PWR
Weight
≤ 4.5 kg (9.92 lb)
≤ 6 kg (13.23 lb)
Console port
24
48
SFP+ port
4
4
Input voltage
30 W
30 W
Total PoE power
370 W
370 W
19 W
36 W
448 W
467 W
10 A/250 V
15 A/250 V
Cooling system
The device uses fixed fan trays. It draws cool air from the chassis left side and port side and exhausts heated air from the chassis right side.
Operating humidity
Table1-5 Technical specifications of S1850V2-EI non-PoE switch models (1)
Item
S1850V2-10P-EI
S1850V2-9P-EI
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in)
Weight
≤ 1.5 kg (3.31 lb)
≤ 1.5 kg (3.31 lb)
Console port
8
8
SFP port
2
1
Input voltage
8 W
8 W
14 W
14 W
2 A/250 V
2 A/250 V
Cooling system
Operating humidity
Table1-6 Technical specifications of S1850V2-EI non-PoE switch models (2)
Item
S1850V2-28P-EI
S1850V2-52P-EI
Weight
2.5 kg (5.51 lb)
3.5 kg (7.72 lb)
Console port
24
48
SFP port
4
4
Input voltage
9 W
18 W
23 W
41 W
2 A/250 V
3.15 A/250 V
Cooling system
Using fixed fan trays to draw ambient air in from the left side and right side and exhaust heated air from the power supply side.
Operating humidity
Table1-7 Technical specifications of S1850V2-EI PoE switch models
Item
S1850V2-10P-HPWR-EI
S1850V2-28P-HPWR-EI
S1850V2-10P-PWR-EI
43.6 × 330 × 230 mm (1.72 × 12.99 × 9.06 in)
43.6 × 440 × 260 mm (1.72 × 17.32 ×10.24 in)
Weight
≤ 3 kg (6.61 lb)
≤ 4.5 kg (9.92 lb)
≤ 3 kg (6.61 lb)
Console port
8
24
8
SFP port
2
4
2
Input voltage
Maximum PoE power per port
30 W
30 W
30 W
Total PoE power
125 W
370 W
65 W
10 W
19 W
8 W
Power consumption (fully loaded, including PoE output)
155 W
448 W
90 W
6.3 A/250 V
10 A/250 V
6.3 A/250 V
Cooling system
The device uses fixed fan trays. It draws cool air in from the chassis left side and port side and exhaust heated air from the chassis right side.
The maximum allowed temperature is decreased by 0.33°C (32.59°F) for every increase of 100 m (328.08 ft) above 0 m (0 ft) in altitude.
Operating humidity
2 Chassis views
S1850-28X
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) SFP+ port LED
(4) System status LED (SYS)
(5) SFP port LED
(6) Micro USB console port
(7) Console port (CONSOLE)
(8) SFP+ port
(9) SFP port
Figure2-2 Rear panel
(1) Grounding screw
(2) AC-input power receptacle
S1850-52X
Figure2-3 Front panel
(3) SFP port LED
(4) Console port (CONSOLE)
(5) Micro USB console port
(6) SFP+ port LED
(7) System status LED (SYS)
(8) SFP+ port
(9) SFP port
Figure2-4 Rear panel
(1) Grounding screw
S1850-28X-PWR
Figure2-5 Front panel
(2) Port LED mode switching button
(3) 10/100/1000BASE-T autosensing Ethernet port LED
(4) SFP port LED
(5) System status LED (SYS)
(6) Mode LED (MODE)
(7) SFP+ port LED
(8) Micro USB console port
(9) Console port (CONSOLE)
(10) SFP+ port
(11) SFP port
Figure2-6 Rear panel
(1) Grounding screw
S1850-52X-PWR
Figure2-7 Front panel
(3) SFP port LED
(6) Port LED mode switching button
(8) RPS power supply status LED (RPS)
(9) Mode LED (MODE)
(10) SFP+ port
(11) SFP+ port LED
(12) SFP port
Figure2-8 Rear panel
(1) Grounding screw
(3) DC-input power receptacle
S1850V2-28X
Figure2-9 Front panel
(3) SFP+ port LED
(5) Console port (CONSOLE)
(6) SFP+ port
Figure2-10 Rear panel
(1) Grounding screw
S1850V2-52X
Figure2-11 Front panel
(3) Console port (CONSOLE)
(4) SFP+ port LED
(6) SFP+ port
Figure2-12 Rear panel
(1) Grounding screw
S1850V2-28X-HPWR
Figure2-13 Front panel
(4) SFP+ port LED
(6) Mode LED (MODE)
(8) SFP+ port
Figure2-14 Rear panel
(1) Grounding screw
S1850V2-52X-PWR
Figure2-15 Front panel
(4) Port LED mode switching button
(6) Mode LED (MODE)
(7) SFP+ port LED
(8) SFP+ port
Figure2-16 Rear panel
(1) Grounding screw
S1850V2-28P-EI
Figure2-17 Front panel
(3) SFP port LED
(6) SFP port
Figure2-18 Rear panel
(1) Grounding screw
S1850V2-52P-EI
Figure2-19 Front panel
(4) SFP port LED
(6) SFP port
Figure2-20 Rear panel
(1) Grounding screw
S1850V2-9P-EI
Figure2-21 Front panel
(3) SFP port LED
(6) SFP port
Figure2-22 Rear panel
(1) Grounding screw
S1850V2-10P-EI
Figure2-23 Front panel
(3) SFP port LED
(6) SFP port
Figure2-24 Rear panel
(1) Grounding screw
S1850V2-10P-HPWR-EI
Figure2-25 Front panel
(3) SFP port LED
(5) Mode LED (MODE)
(8) SFP port
Figure2-26 Rear panel
(1) AC-input power receptacle
(2) Grounding screw
S1850V2-28P-HPWR-EI
Figure2-27 Front panel
(4) SFP port LED
(6) Mode LED (MODE)
(8) SFP port
Figure2-28 Rear panel
(1) Grounding screw
S1850V2-10P-PWR-EI
Figure2-29 Front panel
(3) SFP port LED
(5) Mode LED (MODE)
(8) SFP port
Figure2-30 Rear panel
(2) Grounding screw
3 Ports and LEDs
Ports
Console port
Table3-1 Console port specifications
Item
Serial console port
Connector type
RJ-45
USB micro-type B
Compliant standard
EIA/TIA-232
USB 2.0
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to a serial port of a local PC running terminal emulation program.
·     Provides connection to a USB port of a local PC running terminal emulation program.
Available switch models
All switches
IMPORTANT
IMPORTANT:
If you connect both the serial console port and micro USB console port to a configuration terminal, only the micro USB console port takes effect.
Table3-2 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
Transmission rate, duplex mode, and auto MDI/MDI-X
·     10 Mbps, half/full duplex
·     100 Mbps, half/full duplex
·     1000 Mbps, full duplex
·     MDI/MDI-X autosensing
Max transmission distance
100 m (328.08 ft)
Transmission medium
Category-5 (or above) twisted pair cable
Compatible standards
·     IEEE 802.3i
·     IEEE 802.3u
·     IEEE 802.3ab
All switches
SFP port
Table3-3 SFP port specifications
Item
Specification
Compatible transceiver modules and cables
GE SFP transceiver modules and cables in Table3-4.
Compatible device models
S1850-X switch series and S1850V2-EI switch series.
·     To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles) on an S1850V2-9P-EI, S1850V2-10P-EI, S1850V2-10P-PWR-EI, S1850V2-10P-HPWR-EI, or S1850V2-28P-EI switch, make sure the ambient temperature does not exceed 40°C (104°F).
·     Only the S1850V2-10P-HPWR-EI switch supports the SFP-GE/FE-LX10-SM1310 transceiver module.
·     The S1850V2-10P-HPWR-EI switch does not support the SFP-GE-SX-MM850-S or SFP-GE-LX-SM1310-S transceiver module.
Table3-4 GE SFP transceiver modules and cables
GE SFP transceiver module/cable
Central wavelength
Connector
Cable specifications
Modal bandwidth (MHz*km)
Copper SFP transceiver module
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.09 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.09 ft)
Fiber SFP transceiver module
SFP-GE-SX-MM850-A
850 nm
LC
50/125 µm multi-mode optical fiber
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm multi-mode optical fiber
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850 nm
LC
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
Multi-mode, 62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310 nm
LC
9/125 µm single-mode optical fiber
N/A
10 km (6.21 miles)
500/400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310 nm
LC
N/A
10 km (6.21 miles)
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550 nm
LC
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550 nm
LC
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550 nm
LC
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310 nm
RX: 1490 nm
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490 nm
RX: 1310 nm
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310 nm
RX: 1550 nm
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550 nm
RX: 1310 nm
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490 nm
RX: 1550 nm
LC
Single-mode, 9/125
N/A
70 mm (2.76 in)
SFP-GE-LH70-SM1550-BIDI
TX: 1550 nm
RX: 1490 nm
LC
Single-mode, 9/125
N/A
70 mm (2.76 in)
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
·     As a best practice, use H3C SFP transceiver modules and cables for the switch.
·     The H3C SFP transceiver modules and cables available for the SFP ports are subject to change over time. For the most up-to-date list of H3C SFP transceiver modules and cables available for the SFP ports, contact your H3C sales representative or technical support engineer.
·     For the specifications of the H3C SFP transceiver modules and cables, see H3C Transceiver Modules User Guide.
SFP+ port
Table3-5 SFP+ port specifications
Item
Specification
·     GE SFP transceiver modules and cables in Table3-4
·     10-GE SFP+ transceiver modules and cables in Table3-6, Table3-7, and Table3-8
Compatible devices
Table3-6 10-GE SFP+ transceiver modules available for the SFP+ ports
Central wavelength (nm)
Connector
Fiber diameter (µm)
Modal bandwidth (MHz × km)
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850 nm
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850 nm
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-S
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
Table3-7 SFP+ copper cables available for the SFP+ ports
SFP+ copper cable
Cable length
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
Table3-8 SFP+ fiber cables available for the SFP+ ports
SFP+ fiber cable
Cable length
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
·     As a best practice, use H3C transceiver modules and network cables for the switch.
·     The H3C transceiver modules and network cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact H3C Support or marketing staff.
·     For the specifications of H3C transceiver modules and network cables, see H3C Transceiver Modules User Guide.
Figure3-1 SFP+ cable
(1) Connector
(2) Pull latch
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table3-9 System status LED description
LED mark
Status
SYS
Steady green
The switch has started up correctly.
Flashing green
POST in progress.
Steady red
The switch has failed POST or the switch is faulty.
Off
The switch is powered off or has not started up correctly.
The S1850-52X-PWR switch supports power input from an RPS power supply. You can determine the RPS power supply operating status by observing the RPS power supply status LED.
Table3-10 RPS power supply status LED description
LED mark
Status
RPS
Steady green
Normal AC power input and normal DC power input
Steady yellow
Normal DC power input, abnormal or no AC power input.
Off
Abnormal or no DC power input.
Mode LED (MODE)
Each PoE switch provides a mode LED (MODE). The mode LED works in conjunction with the Ethernet port LEDs to indicate the operating state of the Ethernet ports and the switch.
You can use the LED mode switching button to change the indication of the mode LED.
Table3-11 Description for the mode LED
LED mark
Status
Mode LED (MODE)
Steady green
The Ethernet port LEDs are showing link state of the ports.
Flashing green
The Ethernet port LEDs are showing the PoE status of the ports.
SFP/SFP+ port LED
Table3-12 SFP/SFP+ port LED description
Status
Steady green
A link is present on the port.
Flashing green
The port is sending or receiving data.
Off
·     No link is present on the port.
·     The mode LED is operating in PoE mode (available only for PoE switch models)
10/100/1000BASE-T autosensing Ethernet port LEDs
On a PoE switch, 10/100/1000BASE-T autosensing Ethernet port LEDs work in conjunction with the mode LED to indicate the operating state of the Ethernet ports and the switch from different aspects. Table3-13 describes the Ethernet port LEDs on a PoE switch.
Table3-14 describes the Ethernet port LEDs on a non-PoE switch.
Table3-13 Ethernet port LED description for PoE switch models
Mode LED status
Ethernet port LED status
Steady green (Link/Active mode)
Steady green
Flashing green
Off
Flashing green (PoE mode)
Steady green
PoE power supply is normal.
Flashing green (1 Hz)
·     The maximum PoE power provided by the port fails to meet the power requirement of the PD.
·     PoE power supply overcurrent, overvoltage, or short-circuit occurs.
·     The remaining power of the switch fails to meet the power supply requirement of the port.
Off
The port is not connected to a PD or PoE is not enabled on the port.
Table3-14 Ethernet port LED description for non-PoE switch models
LED status
Steady green
Flashing green
Off
