- 10-Segment Routing Configuration Guide
- 01-SR-MPLS configuration
- 02-SR-MPLS TE policy configuration
- 03-SRv6 configuration
- 04-SRv6 TE policy configuration
- 05-SRv6 VPN overview
- 06-IP L3VPN over SRv6 configuration
- 07-EVPN L3VPN over SRv6 configuration
- 08-Public network IP over SRv6 configuration
- 09-SRv6 OAM configuration
- 10-EVPN VPLS over SRv6 configuration
- 11-EVPN VPWS over SRv6 configuration
08-Public network IP over SRv6 configuration | 222.13 KB |
Configuring public network IP over SRv6
About public network IP over SRv6
Public network IP over SRv6 FRR
Public network IP over SRv6 tasks at a glance
Applying a locator to a BGP instance
Configuring PEs to exchange BGP IPv4 or IPv6 unicast routes
Configuring IPv6 peers to exchange SRv6 SIDs
Configuring next hop-based dynamic End.DX4 or End.DX6 SID allocation for public network routes
Configuring the route recursion mode
Specifying a source address for the outer IPv6 header of SRv6-encapsulated packets
Configuring public network IP over SRv6 FRR
Configuring SBFD for SRv6 locators
Verifying and maintaining public network IP over SRv6
Displaying the configuration and running status of public network IP over SRv6
Clearing flap statistics for BGP IPv6 unicast routes
Public network IP over SRv6 configuration examples
Example: Configuring public network IPv6 over SRv6 in SRv6-BE mode
Public network IP over SRv6 uses SRv6 tunnels to carry public network IP services. This technology establishes SRv6 tunnels among geographically dispersed customer sites over an IPv6 network and transparently forwards Layer 3 customer traffic to remote sites over the IPv6 network through the tunnels.
Basic principle
Figure 1 shows a typical public network IP over SRv6 network. PE 1 and PE 2 use BGP to advertise public network IPv6 routes to each other over the IPv6 backbone network. The PEs use an SRv6 tunnel between them to forward public network traffic across sites.
Public network IP over SRv6 connects geographically dispersed sites that belong to the public network over the IPv6 backbone network.
Route advertisement
Public network IPv4 over SRv6 and public network IPv6 over SRv6 use the same process to advertise routes. The following information uses public network IPv4 over SRv6 as an example to illustrate the process.
As shown in Figure 1, local routes of CE 1 are advertised to CE 2 by using the following process:
1. CE 1 uses static routing, RIP, OSPF, IS-IS, EBGP, or IBGP to advertise routes of the local site to PE 1.
2. After learning the route information of CE 1, PE 1 stores the routes of the local site to the routing table of the public network. At the same time, PE 1 converts the routes to BGP IPv4 unicast routes and adds the same End.DT4 or End.DT46 SID to the routes. Alternatively, PE 1 adds the same End.DX4 SID to the routes with the same next hop. Then, PE 1 advertises the BGP IPv4 unicast routes with the End.DT4, End.DT46, or End.DX4 SID to PE 2.
3. When PE 2 receives the IPv4 unicast routes advertised by PE 1, it adds the routes to the routing table of the public network. PE 2 removes the End.DT4, End.DT46, or End.DX4 SID information from the routes, records the End.DT4, End.DT46, and End.DX4 information, and then advertises the routes to CE 2.
4. By adding the received IPv4 unicast routes to the routing table, CE 2 learns the routes of CE 1.
Packet forwarding
Public network IP over SRv6 supports the following route recursion modes:
· SRv6-BE mode.
· SRv6-TE mode.
· SRv6-TE and SRv6-BE hybrid mode.
The packet forwarding process differs by the route recursion mode in use.
SRv6-BE mode
This mode is also called SID-based forwarding mode. In this mode, a PE forwards an SRv6 packet by searching the IPv6 routing table based on the SRv6 SID encapsulated in the packet.
Public network IPv4 over SRv6 and public network IPv6 over SRv6 use the same process to forward packets. The following information uses public network IPv4 over SRv6 as an example to illustrate the process.
As shown in Figure 1, CE 2 forwards an IPv4 packet to CE 1 as follows:
1. CE 2 sends the IPv4 packet to PE 2.
2. After PE 2 receives the packet, it searches for a route that matches the destination IPv4 address of the packet in the routing table of the public network. The corresponding End.DT4, End.DT46, or End.DX4 SID is found. Then, PE 2 encapsulates an outer IPv6 header for the packet. The End.DT4, End.DT46, or End.DX4 SID is encapsulated in the outer IPv6 header as the destination address.
3. PE 2 searches the IPv6 routing table based on the End.DT4, End.DT46, or End.DX4 SID for the optimal IGP route and forwards the packet to P through the route.
4. P searches the IPv6 routing table based on the End.DT4, End.DT46, or End.DX4 SID for the optimal IGP route and forwards the packet to PE 1 through the route.
5. When PE 1 receives the packet, it processes the packet as follows:
¡ If the packet header contains an End.DT4 or End.DT46 SID, PE 1 searches the local SID forwarding table for the SID and removes the outer IPv6 header. Then, PE 1 matches the packet to the public instance based on the SID, looks up the public network routing table, and forwards the packet to CE 1.
¡ If the packet header contains an End.DX4 SID, PE 1 searches the local SID forwarding table for the SID and removes the outer IPv6 header. Then, PE 1 forwards the packet to CE 1 according to the next hop and output interface bound to the SID.
SRv6-TE mode
This mode is also called SRv6 TE policy-based forwarding mode. In this mode, when a PE forwards a customer packet, it first searches for a matching SRv6 TE policy based on the packet attributes. Then, the PE adds an SRH to the packet. The SRH includes the destination SRv6 SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet based on the SRv6 TE policy.
The following modes are available to steer traffic to an SRv6 TE policy:
· Color—The device searches for an SRv6 TE policy that has the same color and endpoint address as the color and nexthop address of a BGP route. If a matching SRv6 TE policy exists, the device recurses the BGP route to that SRv6 TE policy. When the device receives packets that match the BGP route, it forwards the packets through the SRv6 TE policy.
· Tunnel policy—The device searches the tunnel policies for a matching SRv6 TE policy based on the next hop of a matching route. Configure a preferred tunnel or load sharing tunnel policy that uses the SRv6 TE policy. In this way, the SRv6 TE policy will be used as the public tunnel to carry the SRv6 PW that forwards the packets of customer network packets.
For more information about tunnel policies, see MPLS Configuration Guide. For more information about SRv6 TE policies, see "Configuring SRv6 TE policies."
In this mode, the PE preferentially uses the SRv6-TE mode to forward a packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6-BE mode.
Public network IP over SRv6 Fast Reroute (FRR) is applicable to a dualhomed scenario, as shown in Figure 2. By using static BFD to detect the primary link, FRR enables a PE to use the backup link when the primary link fails. The PE then selects a new optimal route, and uses the new optimal route to forward traffic.
Public network IP over SRv6 supports IPv4 unicast route backup for IPv4 unicast route and IPv6 unicast route backup for IPv6 unicast route.
Figure 2 Network diagram of public network IP over SRv6 FRR
IPv4 unicast route backup for IPv4 unicast route and IPv6 unicast route backup for IPv6 unicast route use the same FRR mechanism. This section uses IPv4 unicast route backup for IPv4 unicast route as an example to illustrate the mechanism.
As shown in Figure 2, configure FRR on the ingress node PE 1, and specify the backup next hop as PE 3 for the public IPv4 route to CE 2. When PE 1 receives a BGP IPv4 unicast route to CE 2 from both PE 2 and PE 3, it uses the route from PE 2 as the primary path, and the route from PE 3 as the backup path.
Configure static BFD for public tunnels on PE 1 to detect the connectivity of the public tunnel from PE 1 to PE 2. When the tunnel PE 1—PE 2 operates correctly, traffic from CE 1 to CE 2 goes through the path CE 1—PE 1—PE 2—CE 2. When the tunnel fails, the traffic goes through the path CE 1—PE 1—PE 3—CE 2.
In this scenario, PE 1 is responsible for primary path detection and traffic switchover.
For more information about static BFD, see BFD configuration in High Availability Configuration Guide.
To configure public network IP over SRv6, perform the following tasks:
1. Configuring route exchange between a PE and a CE
Configure an IPv4 routing protocol (static routing, RIP, OSPF, IS-IS, EBGP, or IBGP) or an IPv6 routing protocol (IPv6 static routing, RIPng, OSPFv3, IPv6 IS-IS, EBGP, or IBGP) to exchange routes between a PE and a CE
On the CE, configure an IPv4 or IPv6 routing protocol to advertise routes of the local site to the PE. For more information about routing protocol configurations, see Layer 3—IP Routing Configuration Guide.
2. Configuring route exchange between PEs
Perform this task to manually configure End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SIDs.
b. Applying a locator to a BGP instance
Perform this task to use BGP IPv4 or IPv6 unicast routes to advertise SRv6 SIDs in the specified locator.
c. Configuring PEs to exchange BGP IPv4 or IPv6 unicast routes
d. Configuring IPv6 peers to exchange SRv6 SIDs
This feature enables PEs to exchange End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SIDs through BGP IPv4 or IPv6 unicast routes.
e. (Optional.) Configuring next hop-based dynamic End.DX4 or End.DX6 SID allocation for public network routes
f. (Optional.) Configuring BGP IPv4 or IPv6 unicast routes
For more information about configuring BGP IPv4 or IPv6 unicast routes, see BGP configuration in Layer 3—IP Routing Configuration Guide.
3. Configuring the route recursion mode
4. Specifying a source address for the outer IPv6 header of SRv6-encapsulated packets
This feature specifies the source address of the outer IPv6 header for SRv6 packets that are delivered between two public network sites over the backbone network.
5. (Optional.) Configuring public network IP over SRv6 FRR
6. (Optional.) Configuring SBFD for SRv6 locators
Configuring SRv6 SIDs
1. Enter system view.
2. Enable SRv6 and enter SRv6 view.
segment-routing ipv6
3. Configure a locator and enter SRv6 locator view.
locator locator-name [ ipv6-prefix ipv6-address prefix-length [ args args-length | static static-length ] * ]
4. Configure an opcode. Perform one of the following tasks:
¡ Configure End.DT4 SIDs.
opcode { opcode | hex hex-opcode } end-dt4
¡ Configure End.DT6 SIDs.
opcode { opcode | hex hex-opcode } end-dt6
¡ Configure End.DT46 SIDs.
opcode { opcode | hex hex-opcode } end-dt46
¡ Configure End.DX4 SIDs.
opcode { opcode | hex hex-opcode } end-dx4 interface interface-type interface-number nexthop nexthop-ipv4-address
The same End.DX4 SIDs cannot be configured with different output interfaces or next hops.
¡ Configure End.DX6 SIDs.
opcode { opcode | hex hex-opcode } end-dx6 interface interface-type interface-number nexthop nexthop-ipv6-address
The same End.DX6 SIDs cannot be configured with different output interfaces or next hops.
In the public network IP over SRv6 scenario, use this feature in BGP IPv4 or IPv6 unicast address family view to apply for SRv6 SIDs for IPv4 or IPv6 routes.
Use this feature if the device will use End.DT4, End.DT6, End.DT46, End.DX4, or End.DX6 SIDs to deliver public network traffic across sites.
Before you perform this task, you must create the specified locator.
2. Enter BGP instance view.
3. Enter BGP IPv4 or IPv6 unicast address family view.
¡ Enter BGP IPv4 unicast address family view.
¡ Enter BGP IPv6 unicast address family view.
4. Apply a locator to the BGP instance.
¡ Apply a common locator to the BGP VPN instance.
segment-routing ipv6 locator locator-name [ auto-sid-disable ]
¡ Apply an anycast locator to the BGP VPN instance.
segment-routing ipv6 locator locator-name anycast
After configuring this command, you must configure the peer prefix-sid command with the anycast keyword in order to exchange SRv6 SID information in the anycast locator with the specified peer.
By default, no locator is applied to a BGP instance.
For more information about the commands in this task, see BGP in Layer 3—IP Routing Command Reference.
To ensure optimal route selection and SRv6 tunnel traffic forwarding, make sure a pair of PEs are not both IPv4 and IPv6 peers to each other.
3. Specify a remote PE as an IPv6 peer.
peer { group-name | ipv6-address [ prefix-length ] } as-number as-number
4. Specify a source interface (IPv6 address) for establishing TCP connections to an IPv6 peer or peer group.
By default, BGP uses the output interface in the optimal route destined for a BGP peer or peer group as the source interface for establishing TCP connections.
5. Enter BGP IPv4 or IPv6 unicast address family view.
6. Enable BGP to exchange IPv4 or IPv6 unicast routing information with an IPv6 peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } enable
By default, BGP cannot exchange IPv4 or IPv6 unicast routing information with an IPv6 peer or peer group.
Perform this task to configure IPv6 peers to exchange SRv6 SID information through BGP IPv4 or IPv6 unicast routes.
4. Enable BGP to exchange SRv6 SID information with an IPv6 peer or peer group.
peer { group-name | ipv6-address [ prefix-length ] } prefix-sid [ anycast ]
By default, BGP cannot exchange SRv6 SID information with an IPv6 peer or peer group.
After specifying the anycast keyword, you must configure the segment-routing ipv6 locator anycast command in order to exchange SRv6 SID information in the anycast locator with the specified peer.
This feature is applicable to the public network IPv6 over SRv6 scenario.
By default, a PE allocates the same SID to all BGP public network routes. When the PE removes the SRv6 encapsulation from a received packet, it looks up the routing table of the public network based on the SID for an optimal route. To forward the packet to the next hop without looking up the routing table, configure this feature.
This feature dynamically allocates End.DX4 or End.DX6 SIDs to all next hops for the BGP public network IPv4 or IPv6 routes. When forwarding a packet, the PE searches for the output interface and next hop based on the End.DX4 or End.DX6 SID of the packet. Then, the PE directly forwards the packet out of the output interface to the next hop.
This feature does not allocate End.DX4 or End.DX6 SIDs to direct routes.
Before you perform this task in BGP IPv4 or IPv6 unicast address family view, execute the segment-routing ipv6 locator command in the same view to apply a locator to the view. This ensures successful dynamic End.DX4 or End.DX6 SID allocation.
3. Enter BGP IPv4 unicast address family view or BGP IPv6 unicast address family view.
4. Allocate End.DX4 or End.DX6 SIDs to the next hops of BGP public network routes.
¡ Allocate End.DX4 or End.DX6 SIDs to all next hops of BGP public network routes.
segment-routing ipv6 apply-sid all-nexthop
¡ Execute the following commands in sequence to allocate End.DX4 or End.DX6 SIDs to the specified next hop of BGP public network routes.
segment-routing ipv6 apply-sid specify-nexthop
nexthop nexthop-address interface interface-type interface-number
By default, public instance-based SID allocation is used for public network routes.
After a PE receives a customer packet destined for an SRv6 SID, it forwards the packet according to the route recursion mode.
· SRv6-BE mode—This mode is also called SID-based forwarding mode. In this mode, the PE first encapsulates the End.DT4, End.DT6, or End.DT46 SID into the packet. Then, the PE searches the IPv6 routing table based on the SID encapsulated in the packet to forward the packet.
· SRv6-TE mode—This mode is also called SRv6 TE policy-based forwarding mode. In this mode, the PE first searches for a matching SRv6 TE policy based on the packet attributes. Then, the PE adds an SRH to the packet. The SRH includes the End.DT4, End.DT6, or End.DT46 SID and the SID list of the SRv6 TE policy. Finally, the PE forwards the encapsulated packet through the SRv6 TE policy. For more information, see "Configuring SRv6 TE policies."
· SRv6-TE and SRv6-BE hybrid mode—In this mode, the PE preferentially uses the SRv6-TE mode to forward the packet. If no SRv6 TE policy is available for the packet, the PE forwards the packet in SRv6-BE mode.
· SRv6 TE and SRv6 BE FRR mode—This mode implements FRR by using the SRv6 TE path (primary path) and SRv6 BE path (backup path). If the SRv6 TE path fails or does not exist, traffic is immediately switched to the SRv6 BE path to ensure service continuity.
To use the SRv6-TE mode or the SRv6-TE and SRv6-BE hybrid mode, you must configure a tunnel policy and SRv6 TE policy. For more information, see tunnel policy configuration in MPLS Configuration Guide and "Configuring SRv6 TE policies."
4. Configure the route recursion mode.
segment-routing ipv6 { best-effort | traffic-engineering | traffic-engineering best-effort | traffic-engineering best-effort-backup }
By default, a PE searches the IPv6 routing table based on the next hop of a matching route to forward traffic.
To ensure correct traffic forwarding in the public network IPv6 over SRv6 scenario, you must specify a source address for the outer IPv6 header of SRv6-encapsulated packets.
You cannot specify a loopback address, link-local address, multicast address, or unspecified address as the source IPv6 address. You must specify an IPv6 address of the local device as the source IPv6 address, and make sure the IPv6 address has been advertised by a routing protocol. As a best practice, specify a loopback interface address of the local device as the source IPv6 address.
2. Enter SRv6 view.
3. Specify a source address for the outer IPv6 header of SRv6-encapsulated packets.
encapsulation source-address ipv6-address [ ip-ttl ttl-value ]
By default, no source address is specified for the outer IPv6 header of SRv6-encapsulated packets.
You can enable public network IP over SRv6 FRR by enabling FRR for a specific address family. Public network IP over SRv6 FRR enables the device to automatically calculate backup next hops for all BGP routes in the VPN instance. If the device learns two unequal-cost routes destined for the same network from different peers, the optimal route is backed up by the other route.
This feature might cause routing loops in certain conditions. Make sure you are fully aware of this feature when you use it on a live network.
2. Configure static BFD.
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ discriminator local local-value remote remote-value ] [ track-interface interface-type interface-number ] ]
3. Return to system view.
4. Enter BGP instance view.
5. Configure BGP FRR to use the echo packet mode BFD to detect next hop connectivity for the primary route.
primary-path-detect bfd echo
By default, BGP FRR uses ARP to detect the connectivity to the next hop of the primary route.
For more information about this command, see BGP commands in Layer 3—IP Routing Command Reference.
6. (Optional.) Enter BGP IPv4 unicast address family view or BGP IPv6 unicast address family view.
¡ Enter BGP IPv4 unicast address family view:
¡ Enter BGP IPv6 unicast address family view:
7. Enable FRR for the address family.
pic
By default, FRR is disabled.
As shown in Figure 3, in the public network IP over SRv6 BE scenario, CE 2 is dual homed to PE 2 and PE 3. After you enable FRR on PE 1, a primary path and a backup path are generated on PE 1. When the primary path fails, you can configure this feature for fast traffic switchover to the backup path. Use SBFD to detect connectivity of SRv6 locators advertised by PE 2 through BGP to fast locate primary path failures and switch traffic over to the backup path.
Figure 3 Using SBFD to detect SRv6 locators in a dual-homed network
SBFD detects the connectivity of SRv6 locators advertised by BGP as follows:
1. PE 1 sends SBFD packets as the initiator. The SRv6 locators are the destination addresses of the SBFD packets. The IP address specified in the sbfd source-ipv6 command is used as the source IP address of SBFD packets.
2. When PE 2 and PE 3 receive the SBFD packets as reflectors, they compare the remote discriminators in the packets with the locally configured discriminators.
¡ If they are consistent, the reflectors send SBFD response packets to the initiator through IPv6 routes.
¡ If they are inconsistent, the reflectors drop the received SBFD packets.
3. If the initiator can receive SBFD response packets before the detection timer expires, it determines that the SRv6 locators are reachable. If not, the initiator determines that the SRv6 locators are unreachable, and switches over to the backup path.
To have this feature take effect, execute the sbfd destination ipv6 remote-discriminator command on PE 1 to configure the mappings between the detected SRv6 locators and remote discriminators. In addition, execute the sbfd local-discriminator command on PE 2 and PE 3 to configure the local discriminators on the reflector end. Make sure PE 1 have consistent discriminator settings with PE 2 and PE 3. For more information about the sbfd destination ipv6 remote-discriminator and sbfd local-discriminator commands, see BFD commands in High Availability Command Reference.
2. Enter SRv6 view.
3. Configure SBFD for SRv6 locators.
locator-sbfd enable [ template template-name ] [ prefix-list prefix-list-name ]
By default, SBFD is not configured for SRv6 locators.
To display BGP IPv6 unicast route information, execute the following command in any view:
display bgp [ instance instance-name ] routing-table ipv6 [ unicast ] [ ipv6-address prefix-length [ advertise-info ] | as-path-acl as-path-acl-number | community-list { { basic-community-list-number | comm-list-name } [ whole-match ] | adv-community-list-number } | peer ipv6-address { advertised-routes | received-routes } [ ipv6-address prefix-length | statistics ] | statistics ]
For more information about this command, see basic BGP commands in Layer 3—IP Routing Command Reference.
To clear flap statistics for BGP IPv6 unicast routes, execute the following command in user view:
reset bgp [ instance instance-name ] flap-info ipv6 [ unicast ] [ ipv6-address prefix-length | as-path-acl as-path-acl-number | peer ipv6-address [ prefix-length ] ]
Resetting BGP sessions
For BGP setting changes to take effect, you must reset BGP sessions. Resetting BGP sessions updates BGP routing information by tearing down and re-establishing the BGP sessions.
To reset BGP sessions of the BGP IPv6 unicast address family, execute the following command in user view:
reset bgp [ instance instance-name ] { as-number | ipv6-address [ prefix-length ] | all | external | group group-name | internal } ipv6 [ unicast ]
As shown in Figure 4, the backbone network is an IPv6 network. Deploy public network IPv6 over SRv6 between PE 1 and PE 2 and use an SRv6 tunnel to transmit IPv4 traffic between the PEs.
· Configure EBGP to exchange customer site routing information between the CEs and PEs.
· Configure IPv6 IS-IS on the PEs in the same AS to realize IPv6 network connectivity.
· Configure IBGP to exchange IPv4 routing information between the PEs.
Device |
IP address |
Device |
IP address |
CE 1 |
HGE1/0/1 |
111::1/96 |
PE 2 |
Loop0 |
3::3/128 |
PE 1 |
Loop0 |
1::1/128 |
HGE1/0/1 |
222::2/96 |
HGE1/0/1 |
111::2/96 |
HGE1/0/2 |
2002::1/96 |
HGE1/0/2 |
2001::1/96 |
CE 2 |
HGE1/0/1 |
222::1/96 |
P |
Loop0 |
2::2/128 |
HGE1/0/1 |
2001::2/96 |
HGE1/0/2 |
2002::2/96 |
Configure IP addresses for the interfaces (including the Loopback interfaces), as shown in Figure 4.
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
1. Configure IPv6 IS-IS on the PEs and device P for network connectivity between the devices:
# Configure PE 1.
<PE1> system-view
[PE1] isis 1
[PE1-isis-1] is-level level-1
[PE1-isis-1] cost-style wide
[PE1-isis-1] network-entity 10.1111.1111.1111.00
[PE1-isis-1] address-family ipv6 unicast
[PE1-isis-1-ipv6] quit
[PE1-isis-1] quit
[PE1] interface loopback 0
[PE1-LoopBack0] isis ipv6 enable 1
[PE1-LoopBack0] quit
[PE1] interface hundredgige 1/0/2
[PE1-HundredGigE1/0/2] isis ipv6 enable
[PE1-HundredGigE1/0/2] quit
# Configure P.
<P> system-view
[P] isis
[P-isis-1] is-level level-1
[P-isis-1] cost-style wide
[P-isis-1] network-entity 10.2222.2222.2222.00
[P-isis-1] address-family ipv6 unicast
[P-isis-1-ipv6] quit
[P-isis-1] quit
[P] interface loopback 0
[P-LoopBack0] isis ipv6 enable
[P-LoopBack0] quit
[P] interface hundredgige 1/0/1
[P-HundredGigE1/0/1] isis ipv6 enable
[P-HundredGigE1/0/1] quit
[P] interface hundredgige 1/0/2
[P-HundredGigE1/0/2] isis ipv6 enable
[P-HundredGigE1/0/2] quit
# Configure PE 2.
<PE2> system-view
[PE2] isis
[PE2-isis-1] is-level level-1
[PE2-isis-1] cost-style wide
[PE2-isis-1] network-entity 10.3333.3333.3333.00
[PE2-isis-1] address-family ipv6 unicast
[PE2-isis-1-ipv6] quit
[PE2-isis-1] quit
[PE2] interface loopback 0
[PE2-LoopBack0] isis ipv6 enable
[PE2-LoopBack0] quit
[PE2] interface hundredgige 1/0/2
[PE2-HundredGigE1/0/2] isis ipv6 enable
[PE2-HundredGigE1/0/2] quit
2. Set up an EBGP peer relationship between each PE and its local CE and distribute CE routes to EBGP:
# Configure CE 1.
<CE1> system-view
[CE1] bgp 65410
[CE1-bgp-default] peer 111::2 as-number 100
[CE1-bgp-default] address-family ipv6 unicast
[CE1-bgp-default-ipv6] peer 111::2 enable
[CE1-bgp-default-ipv6] import-route direct
[CE1-bgp-default-ipv6] quit
[CE1-bgp-default] quit
# Configure CE 2 in the same way as CE 1 is configured. (Details not shown.)
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] router-id 1.1.1.1
[PE1-bgp-default] peer 111::1 as-number 65410
[PE1-bgp-default] address-family ipv6 unicast
[PE1-bgp-default-ipv6] peer 111::1 enable
[PE1-bgp-default-ipv6] import-route direct
[PE1-bgp-default-ipv6] quit
[PE1-bgp-default] quit
# Configure PE 2 in the same way PE 1 is configured. (Details not shown.)
3. Set up an IBGP peer relationship between PE 1 and PE 2:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default] peer 3::3 as-number 100
[PE1-bgp-default] peer 3::3 connect-interface loopback 0
[PE1-bgp-default-ipv6] peer 3::3 enable
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default] peer 1::1 as-number 100
[PE2-bgp-default] peer 1::1 connect-interface loopback 0
[PE2-bgp-default] address-family ipv6 unicast
[PE2-bgp-default-ipv6] peer 1::1 enable
[PE2-bgp-default-ipv6] quit
[PE2-bgp-default] quit
4. Specify a source address for the outer IPv6 header of SRv6-encapsulated public network IP packets on PE 1 and PE 2:
# Configure PE 1.
[PE1] segment-routing ipv6
[PE1-segment-routing-ipv6] encapsulation source-address 1::1
# Configure PE 2.
[PE2] segment-routing ipv6
[PE2-segment-routing-ipv6] encapsulation source-address 3::3
5. Configure the destination address (End.DT4 SID) of the outer IPv6 header for SRv6-encapsulated public network IP packets:
# Configure PE 1.
[PE1-segment-routing-ipv6] locator aaa ipv6-prefix 1:2::1:0 96 static 8
[PE1-segment-routing-ipv6-locator-aaa] quit
[PE1-segment-routing-ipv6] quit
[PE1] isis 1
[PE1-isis-1-ipv6] segment-routing ipv6 locator aaa
[PE1-isis-1] quit
# Configure PE 2.
[PE2-segment-routing-ipv6] locator bbb ipv6-prefix 6:5::1:0 96 static 8
[PE2-segment-routing-ipv6-locator-bbb] quit
[PE2-segment-routing-ipv6] quit
[PE2] isis 1
[PE2-isis-1-ipv6] segment-routing ipv6 locator bbb
[PE2-isis-1] quit
6. Add End.DT4 SIDs to public network routes of the customer sites on PE 1 and PE 2:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-ipv6] segment-routing ipv6 locator aaa
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-ipv6] segment-routing ipv6 locator bbb
7. Enable IPv6 peers on the PEs to exchange End.DT4 SIDs and enable SRv6-BE route recursion mode:
# Configure PE 1.
[PE1] bgp 100
[PE1-bgp-default-ipv6] peer 3::3 prefix-sid
[PE1-bgp-default-ipv6] segment-routing ipv6 best-effort
# Configure PE 2.
[PE2] bgp 100
[PE2-bgp-default-ipv6] peer 1::1 prefix-sid
[PE2-bgp-default-ipv6] segment-routing ipv6 best-effort
# Display IPv6 routing table information on the PEs and verify that each PE has a route destined for the remote CE and the next hop of the route is the End.DT4 SID of the route. This step uses PE 1 as an example.
[PE1] display ipv6 routing-table 222::1 96
Summary count : 1
Destination: 222::/96 Protocol : BGP4+
NextHop : 6:5:: Preference: 255
Interface : HGE1/0/2 Cost : 0
# Verify that CE 1 and CE 2 can ping each other. (Details not shown.)
