H3C SR6604-X SR6608-X SR6616-X Routers Hardware Information and Specifications-6W100
HomeSupportRoutersH3C SR6600-X Router SeriesProduct LiteratureHardware Information & SpecificationsH3C SR6604-X SR6608-X SR6616-X Routers Hardware Information and Specifications-6W100
01-Chassis Views and Technical Specifications
01-Chassis Views and Technical Specifications 1.95 MB
1 Chassis views and technical specifications
Chassis views
CAUTION
CAUTION:
Do not use the rear cover handle when you move the router chassis. This handle is designed to help you remove the rear cover and cannot support the chassis weight.
SR6604-X
Figure1-1 SR6604-X front view
(1) MPU slots (Slot 0 and Slot 1)
(2) Fan tray
(3) Power module slots
(4) Line processing unit (LPU) or switching fabric module slots (Slot 2 and Slot 3)
Figure1-2 SR6604-X rear view
(1) Rear cover handle
(2) Chassis handle
(3) Grounding screw and sign
(4) Air vents
SR6608-X
Figure1-3 SR6608-X front view
(2) Fan tray
(4) LPU or switching fabric module slots (Slot 2 to Slot 5)
Figure1-4 SR6608-X rear view
(2) Chassis handle
(4) Air vents
SR6616-X
Figure1-5 SR6616-X front view
(1) Fan tray
(2) Cable management bracket
(3) Switching fabric module or LPU slots (Slot 0 to Slot 3 and Slot 6 to Slot 9)
(4) MPU slots (Slot 4 and Slot 5)
(5) Air inlet vents (An optional air filter can be installed.)
(6) Power module slots
Figure1-6 SR6616-X rear view
(1) Chassis air exhaust vents
(2) Chassis handle
(3) Rear cover handle
(4) Grounding screw and sign
(5) Power module air exhaust vents
Dimensions and weights
Table1-1 Router dimensions and weights
Item
SR6604-X
SR6608-X
SR6616-X
Height (H)
220 mm (8.66 in, 5 RU)
308 mm (12.13 in, 7 RU)
886 mm (34.88 in, 20 RU)
Width (W)
436 mm (17.17 in)
436 mm (17.17 in)
436 mm (17.17 in)
Depth (D)
480 mm (18.90 in)
480 mm (18.90 in)
480 mm (18.90 in)
Weight (full configuration)
39 kg (85.98 lb)
51 kg (112.43 lb)
102 kg (224.87 lb)
Table1-2 Card weights and dimensions
Model
Net weight
Dimensions (H × W × D)
RSE-X2
1.8 kg (3.97 lb)
40 × 199 × 412 mm (1.57 × 7.83 × 16.22 in)
RSE-X3
1.8 kg (3.97 lb)
SFE-X1
3.25 kg (7.16 lb)
45 × 399 × 412 mm (1.77 × 15.71 × 16.22 in)
FIP-110
3.25 kg (7.16 lb)
FIP-210
3.35 kg (7.39 lb)
FIP-240
3.45 kg (7.61 lb)
FIP-300
3.60 kg (7.94 lb)
FIP-310
3.60 kg (7.94 lb)
FIP-600
3.55 kg (7.83 lb)
FIP-680
3.9 kg (8.60 lb)
SAP-48GBE
3.8 kg (8.38 lb)
SAP-24GBP
3.3 kg (7.28 lb)
SAP-48GBP
3.65 kg (8.05 lb)
SAP-4EXP
3.7 kg (8.16 lb)
SAP-20GE2XP
3.65 kg (8.05 lb)
SAP-28GE
4.15 kg (9.15 lb)
Power consumption
Table1-3 Card power consumption
Model
Min. power consumption
Max. power consumption
RSE-X2
34.37 W
45.60 W
RSE-X3
34.37 W
45.60 W
SFE-X1
65 W
67 W
FIP-110
27.40 W
60 W
FIP-210
57.30 W
104.70 W
FIP-240
72 W
156 W
FIP-300
73.64 W
132.72 W
FIP-310
77.76 W
128.64 W
FIP-600
89.24 W
113.38 W
FIP-680
88 W
148 W
SAP-48GBE
116 W
162 W
SAP-24GBP
72.79 W
124.6 W
SAP-48GBP
102.67 W
132.60 W
SAP-4EXP
101.17 W
108.80 W
SAP-20GE2XP
95.96 W
149.34 W
SAP-28GE
91.84 W
153.42 W
Table1-4 Fan tray power consumption
Model
Power consumption
RT-FAN-6604-X
40.5 W to 82 W
RT-FAN-6608-X
20.20 W to 109 W
RT-FAN-6616-X
65.46 W to 262.8 W
