- H3C Campus Fixed-Port Switches Installation Guide (Video)-6W100
- 01-Install the switch in a 19-inch rack (by using front mounting brackets)
- 02-Install the switch in a 19-inch rack (by using front and rear mounting brackets)
- 03-Install and replace a fan tray
- 04-Install and remove a power supply
- 05-Install and remove a power supply filler panel
- 06-Connect an AC or HVDC power cord
- 07-Connect a DC power cord
- 08-Install and remove an expansion module
01-Install the switch in a 19-inch rack (by using front mounting brackets) | 302.30 MB |
About this video
This video is for illustration only. The installation procedure in the video might differ depending on the hardware model.
To watch online, click the video below
