13-WLAN advanced features
HomeSupportConfigure & DeployConfiguration ExamplesH3C Access Controllers Configuration Examples(V7)-6W10413-WLAN advanced features
02-Multicast Optimization Configuration Examples
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides examples for configuring multicast optimization.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of multicast optimization.
Example: Configuring multicast optimization
As shown in Figure 1:
·     The AC acts as a DHCP server to assign IP addresses to the AP and clients.
·     The AP provides wireless services service1 and service2 for Client 1 and Client 2, respectively.
·     The AC forwards client traffic.
Configure multicast optimization so that Client 1 can receive video stream for multicast group 224.1.1.1 and Client 2 cannot receive the video stream.
Figure 1 Network diagram
Procedures
Configuring the AC
1.     Configure interfaces on the AC:
# Create VLAN 100 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<AC> system-view
[AC] vlan 100
[AC-vlan100] quit
[AC-Vlan-interface100] ip address 2.2.1.1 24
[AC-Vlan-interface100] quit
# Create VLAN 200 and VLAN-interface 200, and assign an IP address to the VLAN interface. The AC will use VLAN 200 for client access.
[AC] vlan 200
[AC-vlan200] quit
[AC-Vlan-interface200] ip address 2.2.2.1 24
[AC-Vlan-interface200] quit
# Configure GigabitEthernet 1/0/1 as a trunk port. Remove the port from VLAN 1, assign the port to VLAN 100 and VLAN 200, and set the PVID to 100.
[AC] interface gigabitethernet1/0/1
[AC-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[AC-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[AC-GigabitEthernet1/0/1] port trunk pvid vlan 100
2.     Configure DHCP:
# Enable DHCP.
[AC] dhcp enable
# Configure DHCP address pool vlan100 and specify subnet 112.12.0.0/16 and gateway address 112.12.1.25 in the address pool.
[AC] dhcp server ip-pool vlan100
[AC-dhcp-pool-vlan100] network 112.12.0.0 mask 255.255.0.0
[AC-dhcp-pool-vlan100] gateway-list 112.12.1.25
[AC-dhcp-pool-vlan100] quit
# Configure a DHCP address pool vlan200, specify subnet 112.13.0.0/16 and gateway address 112.13.1.25 in this address pool, and specify the gateway as the DNS server. Configure the DNS server according to the actual network plan.
[AC] dhcp server ip-pool vlan200
[AC-dhcp-pool-vlan200] network 112.13.0.0 mask 255.255.0.0
[AC-dhcp-pool-vlan200] gateway-list 112.13.1.25
[AC-dhcp-pool-vlan200] dns-list 112.13.1.25
[AC-dhcp-pool-vlan200] quit
3.     Configure the AP:
In large-scale networks, configure AP groups instead of single APs as a best practice.
# Create an AP named ap1, and specify its model and serial ID.
[AC] wlan ap ap1 model WA6320
[AC-wlan-ap-ap1] serial-id 219801A28N819CE0002T
[AC-wlan-ap-ap1] quit
4.     Configure wireless services:
# Create a service template named service1.
[AC] wlan service-template service1
# Set the SSID to service1.
[AC-wlan-st-service1] ssid service1
# Assign clients coming online through the service template to VLAN 200.
[AC-wlan-st-service1] vlan 200
# Set the AKM mode to PSK, and specify plaintext string 12345678 as the preshared key.
[AC-wlan-st-service1] akm mode psk
[AC-wlan-st-service1] preshared-key pass-phrase simple 12345678
# Specify the cipher suite as CCMP and the security IE as RSN.
[AC-wlan-st-service1] cipher-suite ccmp
[AC-wlan-st-service1] security-ie rsn
# Configure the AC to forward client data traffic. You can skip this step if the AC is the client traffic forwarder by default.
[AC-wlan-st-service1] client forwarding-location ac
# Enable WLAN multicast optimization.
[AC-wlan-st-service1] multicast-optimization enable
# Enable the service template.
[AC-wlan-st-service1] service-template enable
[AC-wlan-st-service1] quit
# Create a service template named service2.
[AC] wlan service-template service2
# Set the SSID to service2.
[AC-wlan-st-service2] ssid service2
[AC-wlan-st-service2] vlan 200
[AC-wlan-st-service2] akm mode psk
[AC-wlan-st-service2] preshared-key pass-phrase simple 12345678
[AC-wlan-st-service2] cipher-suite ccmp
[AC-wlan-st-service2] security-ie rsn
[AC-wlan-st-service2] client forwarding-location ac
[AC-wlan-st-service2] service-template enable
[AC-wlan-st-service2] quit
# Create AP group group1, and add the AP to the AP group, and specify the AP model.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
[AC-wlan-ap-group-group1] ap-model WA6320
# Bind service template service1 to radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] service-template service1
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-1] quit
# Bind service template service2 to radio 2.
[AC-wlan-ap-group-group1-ap-model-WA6320] radio 2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] service-template service2
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6320-radio-2] quit
5.     Configure multicast optimization:
# Enable IGMP snooping globally.
[AC] igmp-snooping
[AC-igmp-snooping] quit
# Enable IGMP snooping and then enable dropping unknown multicast data packets for VLAN 200.
[AC] vlan 200
[AC-vlan200] igmp-snooping enable
[AC-vlan200] igmp-snooping drop-unknown
[AC-vlan200] quit
# Set the aging time to 300 seconds for IPv4 multicast optimization entries.
[AC] wlan multicast-optimization aging-time 300
# Configure the AP to receive a maximum of 100 IGMP packets from clients every 60 seconds.
[AC] wlan multicast-optimization packet-rate-limit interval 60 threshold 100
# Set the limit for IPv4 multicast optimization entries to 100.
[AC] wlan multicast-optimization global entry-limit 100
# Set the limit for multicast optimization entries per client to 8.
[AC] wlan multicast-optimization client entry-limit 8
# Set the maximum number of clients that WLAN multicast optimization supports to 10, and configure the AP to drop multicast packets when the number of clients reaches the threshold.
[AC] wlan multicast-optimization entry client-limit 10 drop
Configuring the switch
# Create VLAN 100. The switch will use this VLAN to forward the traffic on the CAPWAP tunnel between the AC and the AP.
<Switch> system-view
[Switch] vlan 100
[Switch-vlan100] quit
# Create VLAN 200. The switch will use this VLAN to forward client traffic.
[Switch] vlan 200
[Switch-vlan200] quit
# Configure GigabitEthernet 1/0/1 as a trunk port. Remove the port form VLAN 1, assign the port to VLAN 100, and set the PVID to VLAN 100.
[Switch] interface gigabitethernet1/0/1
[Switch-GigabitEthernet1/0/1] undo port trunk permit vlan 1
[Switch-GigabitEthernet1/0/1] port trunk permit vlan 100 200
[Switch-GigabitEthernet1/0/1] port trunk pvid vlan 100
# Configure GigabitEthernet 1/0/2 as an access port and assign the port to VLAN 100.
# Enable PoE.
1.     Connect Client 1 and Client 2 to wireless services service1 and service2, respectively. (Details not shown.)
2.     Verify that Client 1 can successfully associate with service1.
[AC] display wlan client service-template service1
Total number of clients: 1
MAC address     Username   AP name         RID  IP address      IPv6 address   VLAN
0024-d705-c600  N/A        ap1             1    112.13.1.26     N/A            200
3.     Verify that Client 2 can successfully associate with service2.
[AC] display wlan client service-template service2
0024-d710-18a4  N/A        ap1             2    112.13.1.27     N/A            200
4.     Verify that Client 1 can successfully receive demanded video stream.
# Demand video stream of multicast group 224.1.1.1 from Client 1. (Details not shown.)
# Send video stream from the source to multicast group 224.1.1.1. (Details not shown.)
# Display IGMP snooping group entries on the AC.
[AC] display igmp-snooping group
Total 1 entries.
VLAN 200: Total 1 entries.
  (0.0.0.0, 224.1.1.1)
    Host slots (0 in total):
    Host ports (2 in total):
      WLAN-BSS1/0/1                       (00:02:45)
The output shows that WLAN-BSS 1/0/1 (connected to Client 1) is a member port of multicast group 224.1.1.1.
# Display Layer 2 multicast fast forwarding entries on the AC.
[AC] display l2-multicast fast-forwarding cache
Total 1 entries, 1 matched
 (1.1.1.100,224.1.1.1)
    Status      : Enable                VLAN            : 200
    Source port : 63                    Destination port: 63
    Protocol    : 17                    Flag            : 0x2
    Ingress port: GigabitEthernet1/0/1
    List of 1 egress ports:
        WLAN-BSS1/0/1
          Status: Enable                Flag: 0x10
The output shows that only Client 1 can receive video stream of multicast group 224.1.1.1.
Configuration files
·     AC:
igmp-snooping
dhcp enable
vlan 100
vlan 200
vlan 200
 ssid service1
 vlan 200
akm mode psk
cipher-suite ccmp
security-ie rsn
 ssid service2
 vlan 200
akm mode psk
cipher-suite ccmp
security-ie rsn
interface Vlan-interface100
 ip address 112.12.1.25 255.255.0.0
interface Vlan-interface200
 ip address 112.13.1.25 255.255.0.0
ap ap1
ap-model WA6320
 radio 1
radio enable
radio 2
radio enable
·     Switch:
vlan 100
vlan 200
poe enable
Related documentation
·     Network Connectivity Command Reference in H3C Access Controllers Command References
·     Network Connectivity Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Traffic Optimization Command Reference in H3C Access Controllers Command References
·     WLAN Traffic Optimization Configuration Guide in H3C Access Controllers Configuration Guides
  • Become a Partner
  • Partner Resources
