H3C S5590-HI[EI] Switch Series Hardware Information and Specifications-6W100
HomeSupportResource CenterSwitchesS5590 SeriesS5590-EI SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C S5590-HI[EI] Switch Series Hardware Information and Specifications-6W100
01-Hardware Information and Specifications
01-Hardware Information and Specifications 1.52 MB
1 Product models and technical specifications
Unless otherwise stated, power supplies and power modules are used interchangeably in this document.
Product models
Table1-1 Switch series and models
Switch series
Model
Product code (PID)
S5590-HI switch series
Non-PoE models
S5590-28T8XC-HI
LS-5590-28T8XC-HI
S5590-48T4XC-HI
LS-5590-48T4XC-HI
S5590-28S8XC-HI
LS-5590-28S8XC-HI
S5590-48S4XC-HI
LS-5590-48S4XC-HI
S5590-EI switch series
Non-PoE models
S5590-28T8XC-EI
LS-5590-28T8XC-EI
S5590-48T4XC-EI
LS-5590-48T4XC-EI
S5590-28S8XC-EI
LS-5590-28S8XC-EI
LS-5590-28S8XC-EI-GL
S5590-48S4XC-EI
LS-5590-48S4XC-EI
LS-5590-48S4XC-EI-GL
PoE models
S5590-28P8XC-EI
LS-5590-28P8XC-EI
LS-5590-28P8XC-EI-GL
S5590-48P6XC-EI
LS-5590-48P6XC-EI
LS-5590-48P6XC-EI-GL
Technical specifications
Table1-2 Technical specifications
Item
S5590-28T8XC-HI
S5590-48T4XC-HI
S5590-28S8XC-HI
S5590-48S4XC-HI
Dimensions (H × W × D)
44 × 440 × 400 mm (1.73 × 17.32 × 15.75 in)
Weight
≤ 8 kg (17.64 lb)
≤ 8 kg (17.64 lb)
≤ 8 kg (17.64 lb)
≤ 8 kg (17.64 lb)
Console port
1 × serial console port
USB port
1
Management Ethernet port
1
SFP+ port
8
4
8
4
SFP port
4 (Each and its corresponding 10/100/1000BASE-T autosensing Ethernet port form a combo interface.)
N/A
28 (The four highest-numbered SFP ports and their corresponding 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces.)
48 (The four highest-numbered SFP ports cannot be used when the port rate mode of the expansion slots is mode2.)
28 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports and their corresponding SFP ports form combo interfaces.)
48 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports cannot be used when the port rate mode of the expansion slots is mode 2.)
4 (Each and its corresponding SFP port form a combo interface.)
N/A
Expansion slot
2
Power supply slot
2
Fan tray slot
2
Input voltage
AC input:
·     Rated voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Max voltage range: 90 VAC to 264 VAC @ 47 Hz to 63 Hz
HVDC input:
·     Rated voltage range: 240 VDC
·     Max voltage range: 180 VDC to 320 VDC
Minimum power consumption
Single power input: 42 W
Dual power inputs: 47 W
Single power input: 44 W
Dual power inputs: 50 W
Single power input: 43 W
Dual power inputs: 49 W
Single power input: 47 W
Dual power inputs: 55 W
Maximum power consumption
Single power input: 136 W
Dual power inputs: 141 W
Single power input: 132 W
Dual power inputs: 136 W
Single power input: 138 W
Dual power inputs: 142 W
Single power input: 152 W
Dual power inputs: 156 W
Chassis leakage current compliance
UL62368-1/EN62368-1/IEC62368-1/UL60950-1/EN60950-1/IEC60950-1/GB4943.1
Melting current of power supply fuse
6.3 A/250 V
Operating temperature
–5°C to +45°C (23°F to 113°F)
Operating humidity
5% RH to 95% RH, noncondensing
Fire resistance compliance
Table1-3 Technical specifications for non-PoE switch models
Item
S5590-28T8XC-EI
S5590-48T4XC-EI
S5590-28S8XC-EI
S5590-48S4XC-EI
44 × 440 × 360 mm (1.73 × 17.32 × 14.17 in)
Weight
≤ 7 kg (15.43 lb)
≤ 7 kg (15.43 lb)
≤ 7 kg (15.43 lb)
≤ 7 kg (15.43 lb)
Console port
USB port
1
1
SFP+ port
8
4
8
4
SFP port
N/A
48
48
N/A
Expansion slot
1
Power supply slot
2
Fan tray slot
2
Input voltage
PSR180-12A-F/PSR180-12A-B power supply:
·     Max voltage range: 90 VAC to 290 VAC @ 47 Hz to 63 Hz
PSR180-12D-B power supply:
·     Rated voltage range: –48 VDC to +60 VDC
·     Max voltage range: –36 VDC to +72 VDC
DC power source for the PSR180-12D-B power supply: –48 VDC power source in the equipment room or an RPS (H3C RPS800-A or RPS1600-A)
Single power input: 38 W
Dual power inputs: 45 W
Single power input: 41 W
Dual power inputs: 48 W
Single power input: 39 W
Dual power inputs: 46 W
Single power input: 108 W
Dual power inputs: 114 W
Single power input: 105 W
Dual power inputs: 108 W
Single power input: 119 W
Dual power inputs: 123 W
Single power input: 137 W
6.3 A/250 V
Operating humidity
Table1-4 Technical specifications for PoE switch models
Item
S5590-28P8XC-EI
S5590-48P6XC-EI
Weight
≤ 7 kg (15.43 lb)
≤ 7 kg (15.43 lb)
Console port
USB port
1
1
SFP+ port
8
6
SFP port
N/A
48
Expansion slot
1
Power supply slot
2
Fan tray slot
2
Input voltage
·     AC power input:
¡     Rated voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
¡     Max voltage range: 90 VAC to 290 VAC @ 47 Hz to 63 Hz
·     HVDC power input:
¡     Rated voltage range: 240 VDC
¡     Max voltage range: 180 VDC to 320 VDC
Single power input: 48 W
Dual power inputs: 53 W
Single power input: 52 W
Dual power inputs: 59 W
Single power input: 938 W
Dual power inputs: 1046 W
Single power input: 945 W
Dual power inputs: 1745 W
·     PSR600-54A-B power supply: 10 A/500 V
·     PSR920-54A-B power supply: 16 A/250 V
·     PSR1600-54A-B power supply: 16 A/250 V
Operating humidity
Table1-5 PoE power capacity of the S5590-28P8XC-EI and S5590-48P6XC-EI switches
Power supply configuration
S5590-28P8XC-EI
S5590-48P6XC-EI
Total PoE power capacity
Max PoE power capacity per port
1 × PSR600-54A-B
450 W
30 W
450 W
30 W
1 × PSR920-54A-B
770 W
30 W
770 W
30 W
1 × PSR1600-54A-B (input voltage: 90 VAC to 176 VAC)
770 W
30 W
770 W
30 W
1 × PSR1600-54A-B (input voltage: 176 VAC to 1290 VAC or 180 VDC to 320 VDC)
1000 W
30 W
1450 W
30 W
2 × PSR600-54A-B
1000 W
30 W
1020 W
30 W
1 × PSR600-54A-B and 1 × PSR920-54A-B
1000 W
30 W
1020 W
30 W
1 × PSR600-54A-B and 1 × PSR1600-54A-B (input voltage: 90 VAC to 176 VAC)
1000 W
30 W
1020 W
30 W
1 × PSR920-54A-B and 1 × PSR1600-54A-B (input voltage: 176 VAC to 1290 VAC)
1000 W
30 W
1260 W
30 W
1 × PSR600-54A-B and 1 × PSR1600-54A-B (input voltage: 176 VAC to 1290 VAC or 180 VDC to 320 VDC)
1000 W
30 W
1020 W
30 W
1 × PSR920-54A-B and 1 × PSR1600-54A-B (input voltage: 176 VAC to 1290 VAC or 180 VDC to 320 VDC)
1000 W
30 W
1600 W
30 W
1 × PSR1600-54A-B (input voltage: 176 VAC to 1290 VAC) and 1 × PSR1600-54A-B (input voltage: 176 VAC to 1290 VAC or 180 VDC to 320 VDC)
1000 W
30 W
1600 W
30 W
2 × PSR920-54A-B
1000 W
30 W
1600 W
30 W
2 × PSR1600-54A-B (input voltage: 90 VAC to 176 VAC)
1000 W
30 W
1600 W
30 W
2 × PSR1600-54A-B (input voltage: 176 VAC to 1290 VAC or 180 VDC to 320 VDC)
1000 W
30 W
1680 W
30 W
2 Chassis views
S5590-28T8XC-HI
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) Console port (CONSOLE)
(4) Mode button
(5) System status LED (SYS)
(6) Mode LED (MODE)
(7) Expansion card status LED 1 (SLOT1)
(8) Expansion card status LED 2 (SLOT2)
(9) USB port
(10) Management Ethernet port LED (ACT/LINK)
(11) Management Ethernet port (MGMT)
(12) SFP+ port LED
(13) SFP+ port
(14) SFP port
(15) SFP port LED
Figure2-2 Rear panel
(1) Grounding screw
(2) Fan tray 1
(3) Expansion card 1
(4) Expansion card 2
(5) Fan tray 2
(6) Power supply 1
(7) Power supply 2
The S5590-28T8XC-HI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-2, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S5590-28T8XC-HI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-2, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-28T8XC-HI switch came with two expansion slots each installed with a filler panel. You can select expansion cards for the switch as required. In Figure2-2, two LSWM2QP2P interface cards are installed in the expansion slots.
S5590-48T4XC-HI
Figure2-3 Front panel
(3) SFP+ port
(4) Console port (CONSOLE)
(5) Mode button
(6) System status LED (SYS)
(7) Mode LED (MODE)
(8) Expansion card status LED 1 (SLOT1)
(9) Expansion card status LED 2 (SLOT2)
(10) USB port
(11) Management Ethernet port LED (ACT/LINK)
(12) Management Ethernet port (MGMT)
(13) SFP+ port LED
Figure2-4 Rear panel
(1) Grounding screw
(2) Fan tray 1
(5) Fan tray 2
(6) Power supply 1
(7) Power supply 2
The S5590-48T4XC-HI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-4, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S5590-48T4XC-HI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-4, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48T4XC-HI switch came with two expansion slots each installed with a filler panel. You can select expansion cards for the switch as required. In Figure2-4, two LSWM2QP2P interface cards are installed in the expansion slots.
S5590-28S8XC-HI
Figure2-5 Front panel
(1) SFP port
(2) SFP port LED
(4) Mode button
(6) Mode LED (MODE)
(9) USB port
(12) SFP+ port LED
(13) SFP+ port
(14) 10/100/1000BASE-T autosensing Ethernet port
(15) 10/100/1000BASE-T autosensing Ethernet port LED
Figure2-6 Rear panel
(1) Grounding screw
(2) Fan tray 1
(5) Fan tray 2
(6) Power supply 1
(7) Power supply 2
The S5590-28S8XC-HI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-6, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S5590-28S8XC-HI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-6, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-28S8XC-HI switch came with two expansion slots each installed with a filler panel. You can select expansion cards for the switch as required. In Figure2-6, two LSWM2QP2P interface cards are installed in the expansion slots.
S5590-48S4XC-HI
Figure2-7 Front panel
(1) SFP port
(2) SFP port LED
(3) SFP+ port
(5) Mode button
(7) Mode LED (MODE)
(10) USB port
(13) SFP+ port LED
Figure2-8 Rear panel
(1) Grounding screw
(2) Fan tray 1
(5) Fan tray 2
(6) Power supply 1
(7) Power supply 2
The S5590-48S4XC-HI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-8, two PSR250-12A1 AC power supplies are installed in the power supply slots.
The S5590-48S4XC-HI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-8, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48S4XC-HI switch came with two expansion slots each installed with a filler panel. You can select expansion cards for the switch as required. In Figure2-8, two LSWM2QP2P interface cards are installed in the expansion slots.
S5590-28T8XC-EI
Figure2-9 Front panel
(3) SFP port
(4) SFP+ port
(5) Management Ethernet port (MGMT)
(6) Console port (CONSOLE)
(7) Mode button
(8) USB port
(9) System status LED (SYS)
(10) Mode LED (MODE)
(11) Expansion card status LED (SLOT)
(12) Power supply 2 status LED (PWR2)
(13) Power supply 1 status LED (PWR1)
(14) Management Ethernet port LED (ACT/LINK)
(15) SFP+ port LED
(16) SFP port LED
Figure2-10 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-28T8XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-10, two PSR180-12A-B AC power supplies are installed in the power supply slots.
The S5590-28T8XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-10, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-28T8XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-10, an LSWM2QP2P interface card is installed in the expansion slot.
S5590-48T4XC-EI
Figure2-11 Front panel
(3) Management Ethernet port (MGMT)
(5) Mode button
(6) USB port
(7) System status LED (SYS)
(8) SFP+ port
(9) Mode LED (MODE)
(10) Expansion card status LED (SLOT)
(11) Power supply 2 status LED (PWR2)
(12) Power supply 1 status LED (PWR1)
(13) Management Ethernet port LED (ACT/LINK)
(14) SFP+ port LED
Figure2-12 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-48T4XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-12, two PSR180-12A-B AC power supplies are installed in the power supply slots.
The S5590-48T4XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-12, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48T4XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-12, an LSWM2QP2P interface card is installed in the expansion slot.
S5590-28S8XC-EI
Figure2-13 Front panel
(1) SFP port
(2) SFP port LED
(3) 10/100/1000BASE-T autosensing Ethernet port LED
(4) Management Ethernet port (MGMT)
(5) Console port (CONSOLE)
(6) Mode button
(7) USB port
(8) System status LED (SYS)
(9) Mode LED (MODE)
(14) SFP+ port
(15) SFP+ port LED
(16) 10/100/1000BASE-T autosensing Ethernet port
Figure2-14 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-28S8XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-14, two PSR180-12A-B AC power supplies are installed in the power supply slots.
The S5590-28S8XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-14, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-28S8XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-14, an LSWM2QP2P interface card is installed in the expansion slot.
The S5590-28S8XC-EI switch with PID LS-5590-28S8XC-EI-GL supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
S5590-48S4XC-EI
Figure2-15 Front panel
(1) SFP port
(2) SFP port LED
(5) Mode button
(6) USB port
(8) SFP+ port
(9) Mode LED (MODE)
(14) SFP+ port LED
Figure2-16 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-48S4XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-16, two PSR180-12A-B AC power supplies are installed in the power supply slots.
The S5590-48S4XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-16, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48S4XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-16, an LSWM2QP2P interface card is installed in the expansion slot.
The S5590-48S4XC-EI switch with PID LS-5590-48S4XC-EI-GL supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
S5590-28P8XC-EI
Figure2-17 Front panel
(3) SFP port
(4) SFP+ port
(7) Mode button
(8) USB port
(15) SFP+ port LED
(16) SFP port LED
Figure2-18 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-28P8XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-18, two PSR600-54A-B AC power supplies are installed in the power supply slots.
The S5590-28P8XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-18, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-28P8XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-18, an LSWM2QP2P interface card is installed in the expansion slot.
The S5590-28P8XC-EI switch with PID LS-5590-28P8XC-EI-GL supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
S5590-48P6XC-EI
Figure2-19 Front panel
(3) SFP+ port
(5) Mode LED (MODE)
(7) Power supply 1 status LED (PWR1)
(8) Power supply 2 status LED (PWR2)
(9) Expansion card status LED (SLOT)
(10) USB port
(11) Mode button
(12) Management Ethernet port LED (ACT/LINK)
(13) Management Ethernet port (MGMT)
(14) SFP+ port LED
Figure2-20 Rear panel
(1) Grounding screw
(2) Expansion card
(3) Fan tray 1
(4) Fan tray 2
(5) Power supply 1
(6) Power supply 2
The S5590-48P6XC-EI switch came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as required. In Figure2-20, two PSR600-54A-B AC power supplies are installed in the power supply slots.
The S5590-48P6XC-EI switch came with two fan tray slots empty. You must install two fan trays of the same model for the switch. In Figure2-20, two LSPM1FANSB-SN fan trays are installed in the fan tray slots.
The S5590-48P6XC-EI switch came with one expansion slot installed with a filler panel. You can select an expansion card for the switch as required. In Figure2-20, an LSWM2QP2P interface card is installed in the expansion slot.
The S5590-48P6XC-EI switch with PID LS-5590-48P6XC-EI-GL supports shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
3 Removable components and compatibility matrixes
The switch supports removable components. Table3-1 describes the removable components available for the switch.
Table3-1 Compatibility matrix between switches and removable components
FRU model
S5590-28T8XC-HI
S5590-28S8XC-HI
S5590-48T4XC-HI
S5590-48S4XC-HI
S5590-28T8XC-EI
S5590-28S8XC-EI
S5590-48T4XC-EI
S5590-48S4XC-EI
S5590-28P8XC-EI
S5590-48P6XC-EI
Removable power supplies
PSR250-12A
Supported
Supported
Not supported
Not supported
PSR250-12A1
Supported
Supported
Not supported
Not supported
PSR180-12A-B
Not supported
Not supported
Supported
Not supported
PSR180-12A-F
Not supported
Not supported
Supported
Not supported
PSR180-12D-B
Not supported
Not supported
Supported
Not supported
PSR600-54A-B
Not supported
Not supported
Not supported
Supported
PSR920-54A-B
Not supported
Not supported
Not supported
Supported
PSR1600-54A-B
Not supported
Not supported
Not supported
Supported
Removable fan trays
LSPM1FANSA-SN
Supported
Supported
Supported
Supported
LSPM1FANSB-SN
Supported
Supported
Supported
Supported
Expansion cards
LSPM6FWD
Supported
Expansion cards supported by expansion slots 1 and 2 depend on the port rate mode. For more information, see Table3-2.
Supported
Supported
LSWM2EC
Supported
Supported
Supported
LSWM2QP2P
Supported
Supported
Supported
LSWM2SP8P
Supported
Supported
Supported
LSWM2ZQP2P
Supported
Supported
Supported
LSWM2ZSP8P
Supported
Supported
Supported
LSWM2SP2PB
Supported
Supported
Supported
LSWM2SP4PB
Supported
Supported
Supported
Table3-2 Expansion card and expansion slot compatibility for the S5590-48T4XC-HI and S5590-48S4XC-HI switches
Expansion card
S5590-48T4XC-HI
S5590-48S4XC-HI
Expansion slot 1
Expansion slot 2
mode0
mode1
mode2
mode0
mode1
mode2
LSPM6FWD
Supported
Not supported
Supported
Supported
Supported
Supported
LSWM2EC
Not supported
Supported
Supported
Supported
Supported
Supported
LSWM2QP2P
Supported
Not supported
Supported
Supported
Supported
Supported
LSWM2SP2PB
Not supported
Supported
Supported
Supported
Supported
Supported
LSWM2SP4PB
Not supported
Supported
Supported
Supported
Supported
Supported
LSWM2SP8P
Not supported
Not supported
Supported
Supported
Supported
Supported
LSWM2ZQP2P
Not supported
Not supported
Not supported
Supported
Supported
Supported
LSWM2ZSP8P
Not supported
Not supported
Not supported
Supported
Supported
Supported
The power supplies support asset management. You can use the display device manuinfo command to view the name, sequence number, and vendor of the power supply you have installed on the switch.
For non-PoE switches, you can install one power supply, or two power supplies for 1+1 redundancy on the switch.
For PoE switches, you can install one power supply, or two power supplies for 1+1 redundancy on the switch. PoE capabilities vary by power supply configuration. When a power supply fails, PoE capabilities of the switch might decrease. For more information about PoE power capacity, see Table1-5.
The switch uses removable fan trays. Do not power on the switch if it does not have two fan trays of the same model installed.
For the S5590-48T4XC-HI and S5590-48S4XC-HI switches, you can use the port-speed-mode command to configure the port rate mode for an expansion slot. By default, the port rate mode for an expansion slot is mode0. To have the configuration take effect, you must save the configuration and restart the switch. For more information about the port-speed-mode command, see Ethernet interface commands in the command reference for the switch.
The S5590-28P8XC-EI (LS-5590-28P8XC-EI-GL), S5590-48P6XC-EI (LS-5590-48P6XC-EI-GL), S5590-28S8XC-EI (LS-5590-28S8XC-EI-GL), and S5590-48S4XC-EI (LS-5590-48S4XC-EI-GL) switches support shipping with fan trays and power supplies installed. For the switch to be shipped with fan trays or power supplies installed, contact the marketing staff.
Table3-3 Power supplies available for the switch
Power supply model
AC or DC input
Specifications
Reference
PSR250-12A
PSR250-12A1
AC input
·     Rated input voltage range: 100 to 240 VAC @ 50/60 Hz
·     Max input voltage range: 90 to 290 VAC @ 47 to 63 Hz
·     Max output power: 250 W
H3C PSR250-12A & PSR250-12A1 Power Modules User Manual
HVDC input
·     Rated input voltage: 240 VDC
·     Max input voltage range: 180 to 320 VDC
PSR180-12A-B
PSR180-12A-F
AC input
·     Max output power: 180 W
H3C PSR180-12A & PSR180-12D Power Supply Series User Manual
PSR180-12D-B
DC input
·     Rated input voltage range: –48 to +60 VDC
·     Max input voltage range: –36 to +72 VDC
PSR600-54A-B
AC input
·     Max output power: 600 W
H3C PSR600-54A-B Power Module User Manual
HVDC input
PSR920-54A-B
AC input
¡     100 to 130 VAC @ 50/60 Hz
¡     200 to 240 VAC @ 50/60 Hz
·     Max output power: 920 W
H3C PSR920-54A-B Power Module User Manual
HVDC input
PSR1600-54A-B
AC input
·     Max output power:
¡     950 W: 90 to 176 VAC @ 47 to 63 Hz
¡     1600 W: 176 to 290 VAC @ 47 to 63 Hz
H3C PSR1600-54A-B Power Module User Manual
HVDC input
·     Max output power: 1600 W
Removable fan trays
Table3-4 Fan tray specifications
Fan tray model
Item
Specifications
·     LSPM1FANSA-SN (from the power supply side to the port side)
·     LSPM1FANSB-SN (from the port side to the power supply side)
40 × 40.6 × 105 mm (1.57 × 1.60 × 4.13 in)
Fan speed
20000 R.P.M
Max airflow
20 CFM (0.57 m3/min)
Input voltage
12 V
Power consumption
9.8 W
Documentation reference
H3C LSPM1FANSA-SN & LSPM1FANSB-SN Fan Trays User Guide
Expansion cards
Table3-5 Expansion cards
Item
Specifications
LSWM2QP2P
2-port 40GE QSFP+ interface card
Port type and quantity
2 × 40 Gbps QSFP+ fiber ports
Available transceiver modules and cables
See Table4-13, Table4-14, and Table4-15.
Reference
H3C LSWM2QP2P Interface Card User Manual
LSWM2SP8P
8-port 10GE SFP+ interface card
8 × 10 Gbps SFP+ fiber ports
See 10GE SFP+ transceiver modules and cables described in Table4-8, Table4-9, and Table4-10 and GE SFP transceiver modules and cables described in Table4-6.
Reference
H3C LSWM2SP8PM & LSWM2SP8P Interface Cards User Manual
LSWM2ZQP2P
2-port 100GE QSFP28 interface module
2 × 40/100 Gbps QSFP28 fiber ports
Available cables
See QSFP28 transceiver modules and cables described in Table4-16, Table4-17, and Table4-18 and QSFP+ transceiver modules and cables described in Table4-13, Table4-14, and Table4-15.
Reference
H3C LSWM2ZQP2P Interface Card User Manual
LSWM2ZSP8P
8-port 25GE SFP28 interface module
8 × 25 Gbps SFP28 fiber ports
See SFP28 transceiver modules and cables described in Table4-11 and Table4-12 and 10GE SFP+ transceiver modules and cables described in Table4-8, Table4-9, and Table4-10.
Reference
H3C LSWM2ZSP8P Interface Card User Manual
LSWM2EC
The LSWM2EC EPS scanner module scans network-wide endpoints as instructed by the EPS server for port type and operating system type automatically and sends scanning results to the EPS server. Upon receiving the port information, the EPS server provides a baseline management over the endpoints that access the network system. By using this module on a switch, you can save hardware resources, increase the number of endpoints that can be scanned, and perform incremental scanning.
Reference
H3C LSWM2EC EPS Scanner Module User Manual
LSPM6FWD
The module is a fourth-generation high performance firewall module. It provides features including firewall, VPN, content filtering, content identification, URL filtering, and NAT. By using this module on a switch, you can enhance the switch security capabilities without changing the network topology.
Reference
H3C LSPM6FWD Card Manual
LSWM2SP2PB
2-port 10GE SFP+ interface module
2 × 1/10 Gbps SFP+ fiber ports
Reference
H3C LSWM2SP2PB & LSWM2SP4PB Interface Cards User Manual
LSWM2SP4PB
4-port 10GE SFP+ interface module
4 × 1/10 Gbps SFP+ fiber ports
Reference
To use the LSWM2ZSP8P interface module, make sure the four lowest-numbered or four highest-numbered ports on the module have the same port rate and duplex mode.
Connecting cables to the ports on expansion cards
To connect cables to the ports on expansion cards, follow these guidelines:
·     Do not bundle cables in their first 20 m (65.62 ft).
·     Separate power cords and twisted pair cables at and around the distribution frame.
·     For ports adjacent to one another on the device, the peer ports on the distribution frame is preferably not adjacent, for example:
¡     If the device connects to one distribution frame, connect port 1 on the device to port 1 on the distribution frame and port 2 on the device to port 3 on the distribution frame.
¡     If the device connects to two distribution frames, connect port 1 on the device to port 1 on distribution frame 1 and port 2 on the device to port 1 on distribution frame 2.
·     Keep the device and cables away from the interference source, such as a two-way radio and a high-power variable-frequency drive.
4 Ports and LEDs
Ports
Console port
Table4-1 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Port transmission rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal
·     Provides connection to the serial port of a local PC running terminal emulation program
Compatible devices
All device models
Table4-2 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     10 Mbps, half/full duplex
·     100 Mbps, half/full duplex
·     1000 Mbps, full duplex
·     MDI/MDI-X autosensing
Transmission medium
Category-5 or above twisted pair cable
Max transmission distance
100 m (328.08 ft)
Compliant standard
IEEE 802.3i, 802.3u, and 802.3ab
Functions and services
Switch software and Boot ROM upgrade, network management
Compatible devices
All device models
USB port
Table4-3 USB port specifications
Item
Specification
Interface type
USB 2.0
Compliant standard
OHC
Uploads and downloads data at a rate up to 480 Mbps
Accesses the file system on the flash of the switch, for example, to upload or download application and configuration files
Compatible devices
All device models
USB devices from different vendors vary in compatibilities and drivers. H3C does not guarantee correct operation of USB devices from other vendors on the switch. If a USB device fails to operate on the switch, replace it with one from another vendor.
SFP port
Table4-4 SFP port specifications
Item
Specification
Interface type
SFP port
Compatible transceiver modules and cables
·     FE SFP transceiver modules in Table4-5
·     GE SFP transceiver modules and cables in Table4-6
Compatible devices
All device models (excluding the S5590-48T4XC-HI, S5590-48T4XC-EI, and S5590-48P6XC-EI switches)
When you use the SFP-GE-T or SFP-GE-T-D copper transceiver module, the interfaces can operate only at 1000 Mbps.
Table4-5 FE SFP transceiver modules available for the SFP ports
Central wavelength (nm)
Connector
Fiber diameter (µm)
SFP-FE-SX-MM1310-A
1310
LC
Multi-mode, 50/125
2 km (1.24 miles)
Multi-mode, 62.5/125
SFP-FE-LX-SM1310-A
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310
LC
Single-mode, 9/125
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550
LC
Single-mode, 9/125
80 km (49.71 miles)
SFP-FE-LX-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
15 km (9.32 miles)
IMPORTANT
IMPORTANT:
The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-FE-LX-SM1550-BIDI transceiver module.
Table4-6 GE SFP transceiver modules and cables available for the SFP+ ports
GE SFP transceiver module and cable
Connector
Cable/Fiber type and diameter (µm)
Modal bandwidth (MHz × km)
SFP copper transceiver modules
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP fiber transceiver modules
SFP-GE-SX-MM850-A
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
500 or 400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LH20-SM1310-I
1310
LC
Single-mode, 9/125
N/A
20 km (12.43 miles)
SFP-GE-LH40-SM1310-I
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550
LC
Single-mode, 9/125
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310
RX: 1490
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490
RX: 1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
70 km (43.50 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310
RX: 1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550
RX: 1310
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP cable
SFP-STACK-Kit
N/A
N/A
N/A
SFP cable
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, SFP-GE-LH70-SM1550-BIDI and SFP-GE-LH70-SM1490-BIDI transceiver modules, and SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-GE-LX-SM1490-BIDI transceiver module.
·     As a best practice, use H3C transceiver modules and network cables for the switch.
·     The H3C transceiver modules and network cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact H3C Support or marketing staff.
·     For the specifications of H3C transceiver modules and network cables, see H3C Transceiver Modules User Guide.
SFP+ port
Table4-7 SFP+ port specifications
Item
Specification
Interface type
SFP+ port
·     10GE SFP+ transceiver modules and cables in Table4-8, Table4-9, and Table4-10
Compatible devices
All device models and the LSWM2SP8P, LSWM2SP2PB, and LSWM2SP4PB expansion cards
Table4-8 10GE SFP+ transceiver modules available for the SFP+ ports
Connector
Fiber diameter (µm)
SFP-XG-SX-MM850-A
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-D
850
LC
Multi-mode, 50/125
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-D
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-CPRI-IR-SM1310
1310
LC
Single-mode, 9/125
N/A
1.4 km (0.87 miles)
SFP-XG-CPRI-LR-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH80-Tunable
1547.75
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
TX: 1270
RX: 1330
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330
RX: 1270
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1490-BIDI
TX: 1490
RX: 1550
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-BIDI
TX: 1550
RX: 1490
LC
Single-mode, 9/125
N/A
80 km (49.71 miles)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table4-9 SFP+ copper cables available for the SFP+ ports
SFP+ copper cable
Cable length
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
Table4-10 SFP+ fiber cables available for the SFP+ ports
SFP+ fiber cable
Cable length
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure4-1 SFP+ cable
(1) Connector
(2) Pull latch
SFP28 port
The LSWM2ZSP8P interface module provides SFP28 ports. To connect peer SFP28/SFP+ ports over a long distance, use SFP28/SFP+ transceiver modules and fibers. To connect peer SFP28/SFP+ ports over a short distance, use SFP28/SFP+ cables.
SFP28 ports support the following transceiver modules and cables:
·     SFP28 transceiver modules in Table4-11.
·     SFP28 cables in Table4-12.
·     SFP+ transceiver modules in Table4-8.
·     SFP+ copper cables in Table4-9.
·     SFP+ fiber cables in Table4-10.
Table4-11 SFP28 transceiver modules available for the SFP28 ports
Connector
SFP-25G-SR-MM850
850
LC
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
SFP-25G-LR-SM1310
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-25G-LR-SM1310-I
1310
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
Table4-12 SFP28 cables available for the SFP28 ports
SFP28 cable
Cable length
SFP-25G-D-CAB-1M
1 m (3.28 ft)
SFP-25G-D-CAB-3M
3 m (9.84 ft)
SFP-25G-D-CAB-5M
5 m (16.40 ft)
SFP-25G-D-AOC-3M
3 m (9.84 ft)
SFP-25G-D-CAB-4M-A
4 m (13.12 ft)
SFP-25G-D-AOC-5M
5 m (16.40 ft)
SFP-25G-D-AOC-7M
7 m (22.97 ft)
SFP-25G-D-AOC-10M
10 m (32.81 ft)
SFP-25G-D-AOC-20M
20 m (65.62 ft)
Figure4-2 SFP28 cable
(1) Connector
(2) Pull latch
·     As a best practice, use H3C transceiver modules and cables for the switch.
·     The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff.
·     For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
QSFP+ port
The LSWM2QP2P interface card provides two QSFP+ ports. You can install the QSFP+ transceiver modules in Table4-13, QSFP+ copper cables in Table4-14, and QSFP+ fiber cables in Table4-15.
Table4-13 QSFP+ transceiver modules available for the QSFP+ ports
Connector
QSFP-40G-SR4-MM850
850
MPO
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-CSR4-MM850
850
MPO
Multi-mode, 50/125
2000
300 m (984.25 ft)
4700
400 m (1312.34 ft)
QSFP-40G-BIDI-SR-MM850
Two lanes:
·     850
·     900
LC
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.13 ft)
QSFP-40G-BIDI-WDM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Multi-mode, 50/125
2000
240 m (787.40 ft)
4700
350 m (1148.29 ft)
QSFP-40G-LR4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
QSFP-40G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
2 km (1.24 miles)
QSFP-40G-ER4-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
Table4-14 40G QSFP+ copper cables available for the QSFP+ ports
QSFP+ copper cable
LSWM1QSTK0
1 m (3.28 ft)
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
Table4-15 40G QSFP+ fiber cables available for the QSFP+ ports
QSFP+ fiber cable
QSFP-40G-D-AOC-3M
3 m (9.84 ft)
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
Figure4-3 40G QSFP+ cable
(1) Connector
(2) Pull tab
QSFP28 ports
The LSWM2ZQP2P interface module provides two QSFP28 ports.
QSFP28 ports support the following transceiver modules and cables:
·     QSFP28 transceiver modules in Table4-16.
·     QSFP28 fiber cables in Table4-17.
·     QSFP28 fiber cables in Table4-18.
·     QSFP+ transceiver modules in Table4-13.
·     QSFP+ copper cables in Table4-14.
·     QSFP+ fiber cables in Table4-15.
Table4-16 QSFP28 transceiver modules available for the QSFP28 ports
Connector
Modal bandwidth (MHz*km)
Maximum transmission distance
QSFP-100G-SR4-MM850
850
MPO
Multimode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
QSFP-100G-eSR4-MM850
850
MPO
Multimode, 50/125
4700
300 m (984.25 ft)
QSFP-100G-PSM4-SM1310
1310
MPO
Single mode, 9/125
N/A
0.5 km (0.31 miles)
QSFP-100G-LR4-WDM1300
Four lanes:
·     1295.56
·     1300.05
·     1304.58
·     1309.14
LC
Single mode, 9/125
N/A
10 km (6.21 miles)
QSFP-100G-LR4L-WDM1300
Four lanes:
·     1271
·     1291
·     1311
·     1331
LC
Single mode, 9/125
N/A
2 km (1.24 miles)
QSFP-100G-ER4L-WDM1300
Four lanes:
·     1295
·     1300
·     1304
·     1309
LC
Single mode, 9/125
N/A
40 km (24.86 miles)
Table4-17 100G QSFP28 fiber cables available for the QSFP28 ports
QSFP28 fiber cable
Cable length
QSFP-100G-D-AOC-7M
7 m (22.97 ft)
QSFP-100G-D-AOC-10M
10 m (32.81 ft)
QSFP-100G-D-AOC-20M
20 m (65.62 ft)
Table4-18 100G QSFP28 copper cables available for the QSFP28 ports
QSFP28 copper cable
Cable length
QSFP-100G-D-CAB-1M
1 m (3.28 ft)
QSFP-100G-D-CAB-3M
3 m (9.84 ft)
QSFP-100G-D-CAB-5M
5 m (16.40 ft)
Figure4-4 100G QSFP28 copper cable
(1) Connector
(2) Pull tab
10/100/1000BASE-T Ethernet port
Table4-19 10/100/1000BASE-T Ethernet port specifications
Item
Specification
Connector type
RJ-45
Rate, duplex mode, and auto-MDI/MDI-X
100 m (328.08 ft)
Transmission medium
Category 5 or above twisted pair cable
Compliant standard
Compatible devices
All device models (excluding the S5590-48S4XC-HI and S5590-48S4XC-EI switches)
Combo interface
The S5590-28T8XC-HI, S5590-28S8XC-HI, S5590-28T8XC-EI, S5590-28S8XC-EI, and S5590-28P8XC-EI switches each provide four combo interfaces on the front panel. A combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports can operate at a time.
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table4-20 System status LED description
LED mark
Status
SYS
Steady green
The switch has started correctly.
Flashing green (1 Hz)
The switch is performing power-on self test (POST).
Steady red
The switch has failed the POST or is faulty.
Off
The switch is powered off.
Power status LED
For the S5590-EI switch series, the power status LED shows the operating status of a power supply.
Table4-21 Power status LED description
LED mark
Status
PWR1/PWR2
Steady green
The power supply is operating correctly.
Steady yellow
The power supply is present, but it is not operating or is faulty.
Off
No power supply is present.
Mode LED
The mode LED (MODE) works in conjunction with the port status LEDs to show more information about the switch.
The mode LED indicates the type of information that the port status LEDs are showing.
After you press the mode button to change the mode LED status into flashing green or flashing yellow, the mode LED keeps in that state for only 45 seconds and then turns steady green automatically.
Table4-22 Mode LED description
LED mark
Status
MODE
Steady green
The port status LEDs indicate link state of the ports.
Flashing green (available only for PoE switches)
The port status LEDs indicate the PoE status of the ports.
Flashing yellow
The port status LEDs indicate the IRF member ID of the switch. For example, if the LEDs for ports 1 to 4 are steady green and the others are off, the IRF member ID of the switch is 4.
Table4-23 Management Ethernet port LED description
Management Ethernet port LED status
Steady green
A link is present on the port.
Flashing yellow
The port is sending or receiving data.
Off
No link is present on the port.
The 10/100/1000BASE-T autosensing Ethernet port LEDs work in conjunction with the mode LED to indicate the operating status of the ports from different aspects, as shown in Table4-24.
Table4-24 10/100/1000BASE-T autosensing Ethernet port LED description
Mode LED (MODE) status
Steady green (rate mode)
Steady green
The port is operating at 10/100/1000 Mbps.
Flashing green
The port is sending or receiving data at 10/100/1000 Mbps.
Off
Flashing green (PoE mode, available only for PoE switches)
Steady green
PoE power supply is normal.
·     The maximum PoE power provided by the port does not meet the power requirement of the PD.
·     PoE power supply overcurrent, overvoltage, or short-circuit has occurred.
·     The remaining power of the switch does not meet the power supply requirement of the port.
Off
The port is not connected to a PD or PoE is not enabled on the port.
Flashing yellow (IRF mode)
Steady green
The autosensing Ethernet port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LEDs for ports 1 to 4 are steady green and the others are off, the IRF member ID of the switch is 4.
SFP port LED
The SFP port LEDs work in conjunction and the mode LED to indicate the operating status of SFP ports.
Table4-25 SFP port LED description
SFP port LED status
Steady green
The port is operating at 100/1000 Mbps.
Flashing green
The port is sending or receiving data at 100/1000 Mbps.
Off
Steady green
The SFP port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LEDs for ports 1 to 4 are steady green and the others are off, the IRF member ID of the switch is 4.
SFP+ port LED
Table4-26 SFP+ port LED description
Mode LED status
SFP+ port LED status
Steady green
The port is operating at 1/10 Gbps.
Flashing green
The port is sending or receiving data at 1/10 Gbps.
Off
Off
The mode LED (MODE) is operating in PoE mode.
Off
When the mode LED (MODE) is flashing yellow (IRF mode), the SFP+ port LEDs are off.
The S5590-HI switch series provides two expansion slots at the rear. The S5590-EI switch series provides one expansion slot at the rear. The expansion card status LED on the front panel indicates the operating status of the expansion card.
Table4-27 Expansion card status LED description
LED mark
Status
SLOT/SLOT1/SLOT2
Steady green
The expansion card is operating correctly.
Flashing yellow
The switch does not support the expansion card model, or the expansion card is faulty.
Off
The expansion slot is empty.
Port status LED on the expansion card
The expansion cards provide a port status LED for each port. For more information, see the user manual for the expansion card.
Status LED on a power supply
The PSR250-12A, PSR250-12A1, PSR600-54A-B, PSR920-54A-B, and PSR1600-54A-B power supplies each have a LED to indicate the power supply operating status. For more information, see the user manual for the power supply.
Fan tray status LED on a fan tray
The LSPM1FANSA-SN and LSPM1FANSB-SN fan trays each have a LED to indicate the fan tray operating status.
Table4-28 Fan tray status LED description
Status
On
The fan tray is faulty.
Off
The fan tray is operating correctly.
5 Cooling system
To dissipate heat timely and enhance system stability, the switch uses a high-performance cooling system. Consider the site ventilation design when you plan the installation site for the switch.
The switch uses removable fan trays and provides airflow from the port side to the power supply side or from the power supply side to the port side by using different types of fan trays. You must install both fan trays of the same model for the switch. Table5-1 describes the fan trays available for the switch.
Table5-1 Fan trays available for the switch
Switch model
Fan tray model
Airflow direction
S5590-28T8XC-HI
S5590-48T4XC-HI
S5590-28S8XC-HI
S5590-48S4XC-HI
S5590-28T8XC-EI
S5590-48T4XC-EI
S5590-28S8XC-EI
S5590-48S4XC-EI
S5590-28P8XC-EI
S5590-48P6XC-EI
LSPM1FANSA-SN
From the power supply side to the port side
LSPM1FANSB-SN
From the port side to the power supply side
Figure5-1 Airflow direction for LSPM1FANSA-SN (S5590-28P8XC-EI)
Figure5-2 Airflow direction for LSPM1FANSB-SN (S5590-28P8XC-EI)
  • Become a Partner
  • Partner Resources
