05-Tunnel interface commands | 116.00 KB |
destination
Use destination to specify the destination address for a tunnel interface.
Use undo destination to restore the default.
destination { ipv4-address | ipv6-address }
undo destination
No tunnel destination address is configured.
Tunnel interface view
ipv4-address: Specifies the tunnel destination IPv4 address.
ipv6-address: Specifies the tunnel destination IPv6 address.
For a manual tunnel interface, you must configure the destination address. For an automatic tunnel interface, you do not need to configure the destination address.
The tunnel destination address must be the address of the receiving interface on the tunnel peer. It is used as the destination address of tunneled packets.
The destination address of the local tunnel interface must be the source address of the peer tunnel interface. The source address of the local tunnel interface must be the destination address of the peer tunnel interface.
Do not specify the same tunnel source and destination addresses for the tunnel interfaces on the same device.
# VLAN-interface 100 on Sysname 1 uses the IP address 193.101.1.1 and VLAN-interface 100 on Sysname 2 uses the IP address 192.100.1.1. Configure the source address 193.101.1.1 and destination address 192.100.1.1 for the tunnel interface on Sysname 1.
<Sysname1> system-view
[Sysname1] interface tunnel 1 mode ipv6-ipv4
[Sysname1-Tunnel1] source 193.101.1.1
[Sysname1-Tunnel1] destination 192.100.1.1
# Configure the source address 192.100.1.1 and destination address 193.101.1.1 for the tunnel interface on Sysname 2.
<Sysname2> system-view
[Sysname2] interface tunnel 1 mode ipv6-ipv4
[Sysname2-Tunnel1] source 192.100.1.1
[Sysname2-Tunnel1] destination 193.101.1.1
display interface tunnel
display tunnel-interface
interface tunnel
source
Use display interface tunnel to display tunnel interface information.
display interface [ tunnel [ number ] ] [ brief [ description | down ] ]
tunnel [ number ]: Specifies a tunnel interface. The number argument specifies the tunnel interface number. The specified tunnel interface must have been created. If you do not specify the tunnel keyword, this command displays information about all interfaces on the device. If you specify the tunnel keyword without the number argument, this command displays information about all existing tunnel interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in the physical state of DOWN and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Tunnel 1.
<Sysname> display interface tunnel 1
Tunnel1
Current state: UP
Line protocol state: UP
Bandwidth: 64kbps
Maximum transmission unit: 1476
Tunnel source 2002::1:1 (Vlan-interface10), destination 2001::2:1
Tunnel TOS 0xC8, Tunnel TTL 255
Tunnel protocol/transport GRE/IPv6
GRE key disabled
Checksumming of GRE packets disabled
Tunnel1 |
Information about the tunnel interface Tunnel 1. |
Current state |
Physical link state of the tunnel interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · DOWN (Tunnel-Bundle administratively down)—The tunnel bundle interface to which the interface belongs has been shut down by using the shutdown command. · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces. · DOWN—The data link layer protocol is down. |
Description of the tunnel interface. |
Bandwidth |
Expected bandwidth of the tunnel interface. |
Maximum transmission unit |
MTU of the tunnel interface. |
Internet protocol processing |
IP packet processing capability of the interface when the interface is not assigned an IP address: · Disabled—The interface cannot process IP packets. · Enabled—The interface can process IP packets. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · Unnumbered—IP address borrowed from another interface. |
Tunnel source |
Source address of the tunnel. If a source interface is specified for the tunnel interface, this field also displays the source interface in parentheses. |
destination |
Destination address of the tunnel. |
Tunnel TOS |
ToS of tunneled packets. |
Tunnel TTL |
TTL of tunneled packets. |
Tunnel protocol/transport |
Tunnel mode and transport protocol: · GRE/IP—GRE/IPv4 tunnel mode. · GRE/IPv6—GRE/IPv6 tunnel mode. · IP/IP—IPv4 over IPv4 tunnel mode. · IP/IPv6—IPv4 over IPv6 tunnel mode. · IPv6/IP—IPv6 over IPv4 manual tunnel mode. · IPv6/IP 6to4—IPv6 over IPv4 6to4 tunnel mode. · IPv6/IP auto-tunnel—Automatic IPv6 over IPv4 tunnel mode. · IPv6/IP ISATAP—IPv6 over IPv4 ISATAP tunnel mode. · IPv6/IPv6—IPv6 over IPv6 tunnel mode. |
GRE key disabled |
No GRE tunnel interface key is configured. |
Checksumming of GRE packets disabled |
The GRE packet checksum feature is disabled. |
Last clearing of counters |
Last time when counters were cleared. |
Last 300 seconds input rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec |
Average input rate in the last 300 seconds. |
Last 300 seconds output rate: 0 bytes/sec, 0 bits/sec, 0 packets/sec |
Average output rate in the last 300 seconds. |
Input: 0 packets, 0 bytes, 0 drops |
Total input packets, total input bytes, and total input packets dropped. Input packets are counted after hardware or software de-encapsulation. Support for counting packets after hardware de-encapsulation depends on the device model. |
Output: 0 packets, 0 bytes, 0 drops |
Total output packets, total output bytes, and total output packets dropped. Output packets are counted before hardware or software encapsulation. Support for counting packets before hardware encapsulation depends on the device model. |
# Display brief information about Tunnel 1.
<Sysname> display interface tunnel 1 brief
Protocol: (s) - spoofing
Tun1 UP UP 1.1.1.1 aaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display brief information about Tunnel 1, including the complete interface description.
<Sysname> display interface tunnel 1 brief description
Tun1 UP UP 1.1.1.1 aaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
# Display information about interfaces in DOWN state and the causes.
<Sysname> display interface tunnel brief down
Interface Link Cause
Tun0 DOWN Not connected
Tun1 DOWN Not connected
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Description of the interface. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—The tunnel is not established. · DOWN (Tunnel-Bundle administratively down)—The tunnel bundle interface to which the tunnel interface belongs has been shut down by using the shutdown command. |
destination
interface tunnel
source
Use display tunnel-interface to display tunnel interface information.
display tunnel-interface [ number ]
number: Specifies a tunnel interface by its number. The specified tunnel interface must have been created. If you do not specify a tunnel interface, this command displays information about all existing tunnel interfaces.
# Display information about tunnel interface 1.
<Sysname> display tunnel-interface 1
Tunnel ID : 1
Tunnel mode : gre
Tunnel VPN instance : vpn1
Tunnel TTL : 255
Tunnel ToS : 0
Source interface : LoopBack1
Source address : 1.1.1.1
Destination address : 2.2.2.2
Tunnel BFD : Enabled
BFD source IP : -
BFD destination IP : -
BFD destination MAC : -
Tunnel VPN instance |
VPN instance to which the tunnel interface belongs. If the tunnel interface belongs to the public network, this field displays two hyphens (--). |
Tunnel TTL |
TTL for tunneled packets. |
Tunnel ToS |
ToS for tunneled packets. |
Tunnel BFD |
Status of the BFD feature. |
BFD source IP |
BFD source IP address. |
BFD destination IP |
BFD destination IP address. |
BFD destination MAC |
BFD destination MAC address. |
destination
interface tunnel
source
interface tunnel
Use interface tunnel to create a tunnel interface, specify the tunnel mode, and enter tunnel interface view, or enter the view of an existing tunnel interface.
Use undo interface tunnel to delete a tunnel interface.
interface tunnel number [ mode { gre [ ipv6 ] | ipv4-ipv4 | ipv4-ipv6 | ipv6-ipv4 [ 6to4 | auto-tunnel | isatap ] | ipv6-ipv6 } ]
undo interface tunnel number
No tunnel interfaces exist.
number: Specifies the number of the tunnel interface. The value range for this argument is 0 to 9214.The number of tunnel interfaces that can be created is restricted by the total number of interfaces and the memory.
mode gre: Specifies the GRE/IPv4 tunnel mode.
mode gre ipv6: Specifies the GRE/IPv6 tunnel mode.
mode ipv4-ipv4: Specifies the IPv4 over IPv4 tunnel mode.
mode ipv4-ipv6: Specifies the IPv4 over IPv6 tunnel mode.
mode ipv6-ipv4: Specifies the IPv6 over IPv4 manual tunnel mode.
mode ipv6-ipv4 6to4: Specifies the 6to4 tunnel mode.
mode ipv6-ipv4 auto-tunnel: Specifies the IPv4-compatible IPv6 automatic tunnel mode.
mode ipv6-ipv4 isatap: Specifies the ISATAP tunnel mode.
mode ipv6-ipv6: Specifies the IPv6 over IPv6 tunnel mode.
To create a new tunnel interface, you must specify the tunnel mode in this command. To enter the view of an existing tunnel interface, you do not need to specify the tunnel mode.
A tunnel interface number is locally significant. The tunnel interfaces on the two ends of a tunnel can use the same or different interface numbers.
# Create GRE/IPv4 tunnel interface Tunnel 1 and enter tunnel interface view.
[Sysname] interface tunnel 1 mode gre
[Sysname-Tunnel1]
destination
source
mtu
Use mtu to set the MTU on a tunnel interface.
mtu size
undo mtu
If the tunnel interface has never been up, the MTU is 64000 bytes.
If the tunnel interface is up, its MTU is identical to the outgoing interface's MTU minus the length of the tunnel headers. The outgoing interface is automatically obtained through routing table lookup based on the tunnel destination address.
size: Specifies the MTU, in the range of 100 to 64000 bytes.
If you do not configure an MTU for a tunnel interface or the configured MTU is 64000 bytes, the effective MTU depends on the tunnel interface status.
· If the tunnel interface is up, its MTU is identical to the outgoing interface's MTU minus the length of the tunnel headers.
· If the tunnel interface is down, the device does not calculate or update the MTU of the tunnel interface.
If you configure an MTU for a tunnel interface and the MTU is not 64000 bytes, the configured MTU applies regardless of the tunnel interface status (up/down) and the outgoing interface MTU.
To avoid fragmentation after tunnel encapsulation, set the tunnel interface MTU no greater than the value of the outgoing interface MTU minus the length of the tunnel headers.
# Set the MTU on Tunnel 1 to 10000 bytes.
[Sysname-Tunnel1] mtu 10000
source
Use source to specify the source address or source interface for a tunnel interface.
Use undo source to restore the default.
source { ipv4-address | ipv6-address | interface-type interface-number }
undo source
No source address or source interface is specified for a tunnel interface.
ipv4-address: Specifies the tunnel source IPv4 address.
ipv6-address: Specifies the tunnel source IPv6 address.
The specified source address or the address of the specified source interface is used as the source address of tunneled packets. To display the configured tunnel source address, use the display interface tunnel command.
# Specify VLAN-interface 10 as the source interface of Tunnel 1.
[Sysname-Tunnel1] source vlan-interface 10
# Specify 192.100.1.1 as the source address of Tunnel 1.
[Sysname-Tunnel1] source 192.100.1.1
destination
interface tunnel
tunnel accelerate
Use tunnel accelerate to enable tunnel traffic forwarding acceleration.
Use undo tunnel accelerate to disable tunnel traffic forwarding acceleration.
tunnel accelerate
Tunnel traffic forwarding acceleration is disabled.
Use this command to accelerate the forwarding of tunneled packets when the NAT, IPsec, AFT, and LB services are not deployed.
# Enable tunnel traffic forwarding acceleration.
[Sysname] tunnel accelerate
tunnel dfbit enable
Use tunnel dfbit enable to set the Don't Fragment (DF) bit for tunneled packets.
Use undo tunnel dfbit enable to restore the default.
tunnel dfbit enable
The DF bit is not set for tunneled packets.
To avoid fragmentation and delay, set the DF bit for tunneled packets. Make sure the path MTU is larger than the tunneled packet length. To avoid discarding tunneled packets whose length is larger than the path MTU, do not set the DF bit.
# Set the DF bit for tunneled packets on Tunnel 1.
[Sysname] interface tunnel 1 mode gre ipv6
[Sysname-Tunnel1] tunnel dfbit enable
tunnel discard ipv4-compatible-packet
Use tunnel discard ipv4-compatible-packet to enable dropping IPv6 packets that use IPv4-compatible IPv6 addresses.
Use undo tunnel discard ipv4-compatible-packet to restore the default.
IPv6 packets that use IPv4-compatible IPv6 addresses are not dropped.
This command enables the device to check the source and destination IPv6 addresses of the de-encapsulated IPv6 packets from a tunnel. If a packet uses an IPv4-compatible IPv6 address as the source or destination address, the device discards the packet.
# Enable dropping IPv6 packets that use IPv4-compatible IPv6 addresses.
[Sysname] tunnel discard ipv4-compatible-packet
tunnel tos
Use tunnel tos to set the ToS of tunneled packets.
Use undo tunnel tos to restore the default.
tunnel tos tos-value
undo tunnel tos
The ToS of tunneled packets is the same as the ToS of the original packets.
tos-value: Specifies the ToS of tunneled packets, in the range of 0 to 255.
After you configure this command, all the tunneled packets of different services sent on the tunnel interface will use the same configured ToS. For more information about ToS, see ACL and QoS Configuration Guide.
# Set the ToS of tunneled packets to 20 on Tunnel 1.
[Sysname-Tunnel1] tunnel tos 20
tunnel ttl
Use tunnel ttl to set the Time to Live (TTL) of tunneled packets.
Use undo tunnel ttl to restore the default.
tunnel ttl ttl-value
undo tunnel ttl
The TTL of tunneled packets is 255.
ttl-value: Specifies the TTL of tunneled packets, in the range of 1 to 255.
The TTL determines the maximum number of hops that the tunneled packets can pass. When the TTL expires, the tunneled packets are discarded to avoid loops.
# Set the TTL of tunneled packets to 100 on Tunnel 1.
[Sysname-Tunnel1] tunnel ttl 100
