H3C IMC Centralized Deployment Guide with Remote Database-7.3-5W111
HomeSupportNetwork Operations & ManagementIntelligent Management Center 7Install & UpgradeInstallation GuidesH3C IMC Centralized Deployment Guide with Remote Database-7.3-5W111
01-Text
01-Text 3.54 MB
Overview·· 1
IMC components· 1
IMC platform·· 1
Service components· 1
IMC editions· 3
Installation and deployment 4
Obtaining IMC installation and deployment methods· 4
Preparing for installation· 5
Hardware requirements· 5
Hardware requirements of the IMC platform·· 6
Hardware requirements of the EIA component 7
Hardware requirements of the WSM component 10
Software requirements· 11
VM requirements· 12
Preparing the installation environment 13
Uninstalling previous versions of IMC· 13
Checking ports and firewalls· 13
Checking the database configuration· 13
Checking the installation environment (optional) 14
Superuser account 15
Setting the system time· 17
Installing and deploying the IMC platform·· 18
Selecting the installation type· 18
Installing the IMC platform in typical mode· 19
Installing the IMC platform in custom mode· 20
Managing IMC by using the Intelligent Deployment Monitoring Agent 28
Starting the Intelligent Deployment Monitoring Agent 28
Monitor tab· 29
Process tab· 30
Deploy tab· 31
Environment tab· 33
Installing and deploying IMC service components· 34
Installing and deploying IMC BIMS· 35
Installing and deploying IMC UAM·· 41
Installing and deploying IMC MVM·· 47
Installing plug-ins· 50
Installing DHCP plug-ins· 50
Restrictions and guidelines· 50
Installing a DHCP plug-in on an MS DHCP server 50
Installing a DHCP plug-in on a Linux DHCP server 51
Installing LLDP plug-ins· 52
Installing an LLDP Windows agent 52
Installing an LLDP Linux agent 53
Accessing IMC·· 54
Hardware, software, and browser requirements· 54
Accessing IMC from a PC· 54
Accessing IMC· 54
Accessing the UAM self-service center 54
Accessing IMC from a mobile device· 55
Securing IMC· 55
Displaying a user agreement 55
Upgrading IMC·· 57
Preparing for the upgrade· 57
Upgrading IMC· 57
Upgrading the IMC platform·· 57
Restoring IMC· 62
Uninstalling IMC·· 64
Uninstalling an IMC component 64
Uninstalling all IMC components at one time· 64
Registering IMC·· 66
Security settings· 67
Port settings· 67
Backing up and restoring the database· 68
Configuration restrictions and guidelines· 69
Installing and upgrading DBMan on the database server 69
Installing DBMan· 69
Upgrading DBMan· 72
Backing up and restoring databases for a single IMC system·· 73
Backing up databases· 73
Restoring databases· 75
Backing up and restoring databases in stateless failover scenarios· 76
Backing up databases· 76
Restoring databases· 76
Backing up and restoring databases· 78
FAQ·· 79
Overview
The following information describes how to deploy IMC in centralized mode and to use a remote database. This deployment scheme scales to networks from 200 to 10000 devices.
IMC components
IMC includes the IMC platform and service components.
IMC platform
The IMC platform is the base component to provide IMC services and includes the following subcomponents:
·     Resource Management
·     Alarm Management
·     User Self Service Management
·     Guest Access Management
·     Intelligent Configuration Center
·     Report Management
·     Network Element (NE) Management
·     Performance Management
·     ACL Management
·     Network Asset Management
·     Security Control Center
·     General Search Service Management
·     Syslog Management
·     VLAN Management
·     WeChat Server
Service components
Service components are optional and purchased separately from the IMC platform. The IMC platform is the basis for implementing various services and must be installed before you install a service component.
IMC includes the following service components:
·     Endpoint Intelligent Access (EIA)—Includes User Access Manager (UAM) and TACACS+ Authentication Manager (TAM).
¡     User Access Manager (UAM)—Provides policy-based Authentication, Authorization, and Accounting (AAA) services. UAM software extends management to wired, wireless and remote network users and enables the integration of network device, user, guest and terminal management on a single unified platform.
¡     TACACS+ Authentication Manager (TAM)—Provides basic AAA functions for network devices or IT users for network device management security. TAM can assign users with different privileges, monitor login and command execution operations, and simplify user management.
·     Endpoint Admission Defense (EAD) Security PolicyEndpoint Admission Defense integrates security policy management and endpoint posture assessment to identify and isolate risks at the network edge. The security policy component allows administrators to control endpoint admission based on an endpoint's identity and posture.
·     MPLS VPN Manager (MVM)—Provides functions such as VPN autodiscovery, topology, monitoring, fault location, auditing, and performance evaluation, as well as VPN and service deployment. MVM also contains a traffic engineering component that helps operators monitor an entire network and deliver service quality by distributing suitable network resources as needed.
·     IPsec VPN Manager (IVM)—Provides features for all aspects of IPSec VPN management for administrators to construct an IPSec VPN network, effectively monitor the operation and performance of the VPN network, and quickly locate device faults for full IPSec VPN lifecycle management.
·     Wireless Service Manager (WSM)—Provides unified management of wired and wireless networks, adding network management functions into existing wired network management systems. WSM software offers wireless LAN (WLAN) device configuration, topology, performance monitoring, RF heat mapping, and WLAN service reports.
·     User Behavior Auditor (UBA)—Provides comprehensive log collection and audit functions supporting log formats such as NAT, flow, NetStreamV5, and DIG. UBA provides DIG logs to audit security-sensitive operations and digest information from HTTP, FTP, and SMTP packets.
·     QoS Manager (QoSM)Enhances visibility and control over QoS configurations and helps administrators focus on QoS service planning by providing a robust set of QoS device and configuration management functions. It allows administrators to organize traffic into different classes based on the configured matching criteria to provide differentiated services, committed access rate (CAR), generic traffic shaping (GTS), priority marking, queue scheduling, and congestion avoidance.
·     Branch Intelligent Management System (BIMS)Provides support for service operations, delivering high reliability, scalability, flexibility, and IP investment returns. Based on the TR-069 protocol, IMC BIMS offers resource, configuration, service, alarm, group, and privilege management. It allows the remote management of customer premise equipment (CPE) in WANs.
·     VAN Fabric Manager (VFM)—Provides an integrated solution for managing both the LANs and SANs in data centers by working with HP devices. VFM depends on VRM to obtain virtual machine (VM) migration information.
·     Intelligent Analysis Reporter (iAR)—Extends the reporting capabilities within IMC to include customized reporting. iAR includes a report designer, which can save designs into report templates. Report formats include charts. Reports can be automatically generated at specified intervals and distributed to key stakeholders.
·     Endpoint Mobile Office (EMO)—Provides mobile office services based on virtualization technologies and the cloud service platform. EMO allows remote access to Windows applications and desktops, provides local resources in the apps store, and manages mobile devices.
·     Security Service Manager (SSM)—Contains SSM and LBM. SSM provides centralized network security management on security devices. LBM deploys configurations to LB devices to implement load balancing through virtual services, real servers, and server farms.
·     Intelligent Portal Management (IPM)—Management platform that provides Wi-Fi marketing for enterprises and organizations. IPM supports site-based authentication policy customization, monitors and analyzes customer flow data, and flexibly pushes advertisements to customers. IPM meets the management and marketing requirements of portal sites, upgrades service quality, and improves customers' online experiences.
·     Endpoints Profiling System (EPS)—IMC service component developed for endpoint identification and monitoring. EPS can immediately identify new or abnormal endpoints by executing periodical or one-time tasks to scan endpoints in areas of the network.
·     U-Center O&M PlatformAs a new-generation intelligent O&M management platform, U-Center O&M Platform provides powerful Infrastructure Operations Management (IOM), including APM and SSA.
IMC editions
The following editions of IMC are available:
·     Professional
·     Standard
·     SNS
Table 1 Differences between IMC editions
Item
SNS
Standard
Professional
Number of nodes
40
Extensible
Extensible
Hierarchical network
management
Not supported
Lower-level NMS only
Supported
Distributed deployment
Not supported
Supported
Supported
Operating system
Windows
Windows and Linux
Windows and Linux
Embedded database
Supported
Supported only on Windows
Not supported
Separate database
Supported
Supported
Supported
For information about installing a separate database for IMC on Windows, see the following documents:
·     SQL Server 2012 Installation and Configuration Guide
·     SQL Server 2014 Installation and Configuration Guide
·     SQL Server 2016 Installation and Configuration Guide
·     SQL Server 2017 Installation and Configuration Guide
·     SQL Server 2019 Installation and Configuration Guide
·     MySQL 5.5 Installation and Configuration Guide (for Windows)
·     MySQL 5.6 Installation and Configuration Guide (for Windows)
·     MySQL 5.7 Installation and Configuration Guide (for Windows)
·     MySQL 8.0 Installation and Configuration Guide (for Windows)
For information about installing a separate database for IMC on Linux, see the following documents:
·     Oracle 11g Installation and Configuration Guide
·     Oracle 11g R2 Installation and Configuration Guide
·     Oracle 12c Installation and Configuration Guide
·     Oracle 12c R2 Installation and Configuration Guide
·     Oracle 19c Installation and Configuration Guide
·     MySQL 5.5 Installation and Configuration Guide (for Linux)
·     MySQL 5.6 Installation and Configuration Guide (for Linux)
·     MySQL 5.7 Installation and Configuration Guide (for Linux)
·     MySQL 8.0 Installation and Configuration Guide (for Linux)
IMC uses the install + deploy model:
·     During installation, the installation package of the IMC component is copied to the server and loaded to the Intelligent Deployment Monitoring Agent.
·     During deployment, the installation package is decompressed on the server and database scripts are created for the component.
The IMC components are operational only after they are deployed. In centralized deployment, all IMC components are installed and deployed on the same server.
IMC automatically creates a database user for each component when the component is deployed. As a best practice, do not modify the database user configuration, including the database user password and password policy.
If the deployment or upgrade process is interrupted, IMC automatically stores logs in a compressed file in the \tmp directory of the IMC installation path. You can use the logs to quickly locate the issue or error.
You can use the following methods to obtain the IMC installation and deployment procedure:
·     View the video case on H3C website at http://www.h3c.com/en/Support/Resource_Center/Technical_Documents/Network_Management/Catalog/H3C_IMC/IMC/Configure/Videos/iMC_Platform_QS-5W100/.
You can also perform the following tasks to view the video case:
a.     Access https://www.h3c.com/en/.
b.     Select Support > Technical Documents > Network Management > H3C Intelligent Management Center.
c.     Click the video installation case, download the video to your computer, and decompress it.
·     Read this document.
This document describes information about installing and deploying IMC on Windows Server 2012 R2. Installing and deploying IMC on Linux is the same as that on Windows.
The IMC software is included in the DVD delivered with the product.
The tables in this section use the following terminology:
·     Node—IMC servers, database servers, and devices managed by IMC are called nodes.
·     Collection unit—The number of collection units equals the total number of performance instances collected at 5-minute intervals. If the collection interval is greater than 5 minutes, the number of collection units decreases. If the collection interval is smaller than 5 minutes, the number of collection units increases.
For example, if performance instances listed in Table 2 are collected every 5 minutes, the total collection units are the same as the number of performance instances, which is 24. If the collection unit is twice as the 5-minute interval (10 minutes), the number of collection units is half the total number of performance instances, which is 12.
Table 2 Performance instances
Monitored item
Number
Performance index
CPU
1
CPU usage
1
Memory
1
Memory usage
1
10
Receiving rate
10
Sending rate
10
Device
1
Unreachability rate
1
Response time
1
Total
24
·     Java heap sizeJava heap size that can be used by the IMC Web server.
To set the Java heap size for IMC:
¡     On Windows, run the setmem.bat heap size script in the \client\bin directory of the IMC installation path.
¡     On Linux, run the setmem.sh heap size script in the /client/bin directory of the IMC installation path.
Set heap size to a value in the range of 256 to 32768 for a 64-bit OS. The java heap size cannot exceed the physical memory size.
To improve the I/O performance, follow these guidelines:
·     When the number of the collection units is from 100 K to 200 K, install two or more disks and a RAID card with a cache of at least 256 MB.
·     When the number of collection units is from 200 K to 300 K, install two or more disks and a RAID card with a cache of at least 512 MB.
·     When the number of collection units is 300 K to 400 K, install four or more disks and a RAID card with a cache of at least 1 GB.
·     Install three disks in RAID 5, and four or more disks in RAID 0+1.
Optimal hardware requirements vary with scale, other management factors, and are specific to each installation. Please consult H3C Support, or your local account teams for exact requirements.
If service components are added to the IMC platform, be sure to read the release notes of each component. When multiple components are deployed, the resources must be combined. Suppose the required CPU resource, memory resource, and disk resource of a component are A(num), B(num), and C(num), respectively. When multiple components are deployed, the required hardware resources are as follows:
·     CPU=A0+A1+A2+A3
·     Memory=B0+B1+B2+B3
·     Disk=C0+C1+C2+C3
Table 3 Hardware requirements for a 64-bit Windows operating system
Management scale
System minimum requirements
Nodes
Collection units
Online operators
CPU (2.5GHz or above)
Server memory
Java heap size
Disk space for installation
Disk space for data storage
0 to 200
0 to 5 K
20
2 cores
12 GB
4 GB
100 GB
100 GB
0 to 200
5 K to 50 K
10
2 cores
12 GB
4 GB
100 GB
200 GB
200 to 1 K
0 to 10 K
30
4 cores
16 GB
4 GB
100 GB
100 GB
200 to 1 K
10 K to 100 K
10
4 cores
16 GB
4 GB
100 GB
200 GB
1 K to 2 K
0 to 20 K
30
6 cores
24 GB
8 GB
150 GB
100 GB
1 K to 2 K
20 K to 200 K
10
6 cores
24 GB
8 GB
150 GB
200 GB
2 K to 5 K
0 to 30 K
40
8 cores
32 GB
12 GB
200 GB
120 GB
2 K to 5 K
30 K to 300 K
20
8 cores
32 GB
12 GB
200 GB
250 GB
5 K to 10 K
0 to 40 K
50
16 cores
48 GB
16 GB
200 GB
150 GB
5 K to 10 K
40 K to 400 K
20
16 cores
48 GB
16 GB
200 GB
300 GB
10 K to 15 K
0 to 40 K
50
24 cores
64 GB
24 GB
200 GB
200 GB
10 K to 15 K
40 K to 400 K
20
24 cores
64 GB
24 GB
200 GB
600 GB
Table 4 Hardware requirements for a 64-bit Linux operating system
Management scale
Nodes
Collection units
Online operators
Server memory
Java heap size
0 to 200
0 to 5 K
20
2 cores
12 GB
4 GB
100 GB
100 GB
0 to 200
5 K to 50 K
10
2 cores
12 GB
4 GB
100 GB
200 GB
200 to 1 K
0 to 10 K
30
4 cores
16 GB
6 GB
100 GB
100 GB
200 to 1 K
10 K to 100 K
10
4 cores
16 GB
6 GB
100 GB
200 GB
1 K to 2 K
0 to 20 K
30
6 cores
24 GB
8 GB
150 GB
100 GB
1 K to 2 K
20 K to 200 K
10
6 cores
24 GB
8 GB
150 GB
200 GB
2 K to 5 K
0 to 30 K
40
8 cores
32 GB
12 GB
200 GB
120 GB
2 K to 5 K
30 K to 300 K
20
8 cores
32 GB
12 GB
200 GB
250 GB
5 K to 10 K
0 to 40 K
50
16 cores
64 GB
16 GB
200 GB
150 GB
5 K to 10 K
40 K to 400 K
20
16 cores
64 GB
16 GB
200 GB
300 GB
10 K to 15 K
0 to 40 K
50
24 cores
80 GB
24 GB
200 GB
200 GB
10 K to 15 K
40 K to 400 K
20
24 cores
80 GB
24 GB
200 GB
600 GB
UAM
You can deploy the portal component on multiple servers in distributed mode. When there are high requirements for portal access, as a best practice, deploy the portal component in distributed mode. When you deploy the portal component in distributed mode, as a best practice, support more users on a dedicated portal server. A dedicated portal server must have at least a configuration that is one level lower than the current configuration.
If the number of managed access users is above 5k and self-service center is needed, you must deploy self-service center in distributed mode. A dedicated self-service center must have at least a configuration that is one level lower than the current configuration.
The following deployment scheme is given based on some reasonable assumptions. More specifically:
·     In the following tables, the 802.1X access method represents any access method that does not need the collaboration of UAM, except portal access.
·     The CPU requirements of EIA specified here are requirements for Intel CPUs. The requirements for Kunpeng and Feiteng ARM CPUs must be twice the requirements for Intel CPUs.
Table 5 64-bit Windows
Management scale
Managed access users
Online operators
Access method
Authentication method
Online users
Concurrent online users
CPU (2.0GHz or above)
Memory
Java heap size
Disk size for installing IMC
(imcInstallDir)
Disk size for running IMC
(imcDataDir)
Maximum IOPS of running disks
<=20K
5
802.1X
PAP/CHAP/EAP-MD5
10000
100
4-core CPU
16G
4G
150GB
100GB
300 (as a best practice, configure a RAID controller with the cache higher than 192M)
EAP-PEAP/TLS/TTLS
3000
10
Portal
PAP/CHAP
6000
50
EAP-PEAP/TLS/TTLS
3000
10
<=100K
10
802.1X
PAP/CHAP/EAP-MD5
50000
200
8-core CPU
32G
8G
300GB
150GB
600 (as a best practice, configure a RAID controller with the cache higher than 256M)
EAP-PEAP/TLS/TTLS
15000
20
Portal
PAP/CHAP
20000
150
EAP-PEAP/TLS/TTLS
15000
20
<=500K
15
802.1X
PAP/CHAP/EAP-MD5
100000
500
16-core CPU
64G
12G
600GB
300GB
1000 (as a best practice, configure a RAID controller with the cache higher than 1G)
EAP-PEAP/TLS/TTLS
30000
50
Portal
PAP/CHAP
40000
300
EAP-PEAP/TLS/TTLS
20000
40
Table 6 64-bit Linux
Management scale
Online operators
Access method
Online users
Memory
Java heap size
(imcInstallDir)
(imcDataDir)
<=20K
5
802.1X
PAP/CHAP/EAP-MD5
10000
100
4-core CPU
16G
4G
150GB
100GB
800 (as a best practice, configure a RAID controller with the cache higher than 192M)
EAP-PEAP/TLS/TTLS
3000
10
Portal
PAP/CHAP
6000
50
EAP-PEAP/TLS/TTLS
3000
10
<=100K
10
802.1X
PAP/CHAP/EAP-MD5
50000
200
8-core CPU
32G
8G
300GB
150GB
1800 (as a best practice, configure a RAID controller with the cache higher than 256M)
EAP-PEAP/TLS/TTLS
15000
20
Portal
PAP/CHAP
20000
150
EAP-PEAP/TLS/TTLS
15000
20
<=500K
15
802.1X
PAP/CHAP/EAP-MD5
100000
500
16-core CPU
64G
12G
600GB
300GB
2400 (as a best practice, configure a RAID controller with the cache higher than 1G)
EAP-PEAP/TLS/TTLS
30000
50
Portal
PAP/CHAP
40000
300
EAP-PEAP/TLS/TTLS
20000
40
TAM
The managed devices refer to the devices added to the device list for the device authentication service.
Table 7 64-bit Windows/Linux
Management scale
Managed devices
Memory
Java heap size
(imcInstallDir)
(imcDataDir)
<=5000
4-core CPU
8G
2G
3GB
160GB
<=20K
8-core CPU
16G
4G
3GB
320GB
When the number of collection units is 0 to 5k, no or few performance monitors are enabled.
Table 8 64-bit Windows
Management scale
Nodes
Collection units
Online operators
Memory
Java heap size
(imcInstallDir)
(imcDataDir)
Fit APs: 0 to 500
0 to 50K
10
2-core CPU
4G
1G
3GB
60GB
Fit APs: 500 to 1000
16K to 90K
10
4-core CPU
8G
4G
3GB
100GB
Fit APs: 1000 to 3000
32K to 150K
10
6-core CPU
16G
6G
4GB
200GB
Fit APs: 3000 to 5000
100K to 250K
10
8-core CPU
24G
8G
5GB
250GB
Enterprise network: fit APs: 5000 to 10000
160K to 400K
10
12-core CPU
32G
12G
7GB
300GB
Service provider: Fit APs: 5000 to 8000
Table 9 64-bit Linux
Management scale
Nodes
Collection units
Online operators
Memory
Java heap size
(imcInstallDir)
(imcDataDir)
Fit APs: 0 to 500
0 to 50K
10
2-core CPU
4G
1G
3GB
60GB
16K to 90K
10
4-core CPU
8G
4G
3GB
100GB
32K to 150K
10
6-core CPU
16G
6G
4GB
200GB
100K to 250K
10
8-core CPU
24G
8G
5GB
250GB
160K to 400K
10
12-core CPU
32G
12G
7GB
300GB
Table 10 Software requirements
Item
Requirement
Remarks
Windows
Operating system
Windows Server 2012 (64-bit)
KB2836988
Windows Server 2012 R2 (64-bit)
N/A
Windows Server 2016 (64-bit)
N/A
Windows Server 2019 (64-bit)
N/A
Database
SQL Server 2012 Enterprise
Service Pack 4
SQL Server 2014 Enterprise
Service Pack 3
SQL Server 2016 Enterprise
Service Pack 3
SQL Server 2017 Enterprise
N/A
SQL Server 2019 Enterprise
N/A
SQL Server 2017 Express
Used as the embedded database for SNS and standard editions only.
Linux
Operating system
Red Hat Enterprise Linux Server 7.x (64-bit)
N/A
Red Hat Enterprise Linux Server 8.x (64-bit)
N/A
CentOS 7.x (64bit)
N/A
Kylin Advanced Server Operating System V10 (AMD64 Edition)
N/A
Database
Oracle 11g Release 1 (64-bit)
N/A
Oracle 11g Release 2 (64-bit)
N/A
Oracle 12c Release 1 (64-bit)
N/A
Oracle 12c Release 2 (64-bit)
N/A
Oracle 18c (64 bit)
N/A
Oracle 19c (64 bit)
N/A
DM Database Management System V8.1.1.126
Available only on Kylin V10
Both Linux and Windows
Database
MySQL Enterprise Server 5.5
A maximum of 1000 devices are supported.
MySQL Enterprise Server 5.6
MySQL Enterprise Server 5.7
MySQL Enterprise Server 8.0
MariaDB 5.5.x
N/A
MariaDB 10.3.x
MariaDB 10.5.x
VM requirements
As a best practice, install IMC on a physical server.
When installed on a virtual machine, IMC supports the following virtual platforms:
·     VMware:
¡     VMware ESXi 5.5
¡     VMware ESXi 6.0
¡     VMware ESXi 6.5
¡     VMware ESXi 6.7
·     CAS:
¡     CAS 2.0
¡     CAS 3.0
¡     CAS 5.0
·     Hyper-V:
¡     Hyper-V 2008 R2
¡     Hyper-V 2012
¡     Hyper-V 2012 R2
If IMC is installed on a virtual machine, do not change the following virtual machine settings:
·     CPU cores
·     Number, model, and MAC addresses of network adapters
·     Number of disk drives
·     Storage paths
·     Assignment of storage
If the settings are changed, IMC might not operate correctly.
To ensure the correct installation and operation of IMC, do not install IMC with other network management products on the same server.
Do not install IMC in an IPv6 environment. However, IMC allows users to manage IPv6 devices.
If IMC was previously installed on the system, then thoroughly uninstall it first. For information about uninstalling IMC, see "Uninstalling IMC."
After you uninstall IMC:
·     On Windows, delete the iMC-Reserved folder from the WINDOWS folder of the system disk.
·     On Linux, delete the iMC-Reserved folder from the /etc directory.
Make sure the IMC Web service ports and database listening ports are open in the firewall. Table 11 lists the default IMC Web service ports and database listening ports for the IMC platform.
Table 11 IMC port requirements
Server
Usage: protocol/default port
Direction
Web
HTTP: TCP/8080
HTTPS: TCP/8443
Browser to IMC
Database
SQL Server database: TCP/1433
Oracle database: TCP/1521
IMC and components to the database
Other IMC components might have additional port requirements. For more information, see "Security settings."
Make sure the javaw.exe and java.exe programs are not blocked by the firewall. On Windows, these programs are located in the \common\jre\bin directory of the IMC installation path. On Linux, these programs are located in the /common/jre/bin/java directory of the IMC installation path.
Use tools such as netstat -a and telnet hostname port to verify access between systems.
Before you install IMC, make sure the database server and client are correctly installed and configured.
IMC uses a local database client to communicate with a remote database server. The client version must match the version of the database server.
On the remote database server, you must create a data file folder for storing IMC data. You will need to specify the path to the folder during IMC installation.
Additional database requirements vary by the database type: SQL Server or Oracle.
For a SQL Server database, the following requirements must be met:
·     Set the startup type of the SQL Server and SQL Server Agent services to Automatic.
To view the service startup type, click Start, and then select Administrative Tools > Services.
·     The startup account of the SQL Server service must have write permissions to all disks on the database server. As a best practice, use the Local System account.
For an Oracle database, the following requirements must be met:
·     Configure the Oracle database service to start automatically with the operating system.
·     The database server and client use the same network service name, which contains the IP address of the database server as the host name.
The IMC installation package provides a tool (envcheck) to check the system environment and database connectivity.
To use the envcheck tool:
1.     Copy the envcheck tool (envcheck.bat for Windows or envcheck.sh for Linux) from the tools folder to the install folder of the IMC installation package.
2.     Run the tool.
The Checking installation environments dialog box opens.
The system checks the port availability, free physical memory, and legacy database server or client.
After the checks are complete, the Checking installation parameters dialog box opens, as shown in Figure 1. The following information uses Windows and Microsoft SQL Server as an example.
Figure 1 Checking installation parameters
3.     Configure the parameters for checking database connectivity:
¡     Database Type—Select the database type. Options are Microsoft SQL Server, MySQL, and Oracle. The default is Microsoft SQL Server.
¡     Instance NameTo connect to the default instance of the database, select Default Instance. To connect to a named instance, select Other Instance, and then enter the instance name.
If you install IMC on Linux and use an Oracle database, configure the network service name and the tablespace name.
-     You can select a network service name or click the Add Network Service Name icon  to add a network service name. For more information about configuring the network service name, see Oracle 11g Installation and Configuration Guide or Oracle 11g R2 Installation and Configuration Guide.
-     To connect to the default tablespace of the database, select Default Tablespace. To connect to a named tablespace, select Other Tablespace, and then enter the tablespace name.
¡     Superuser—Enter the database superuser name. The default is sa.
¡     Password—Enter the password of the superuser.
¡     Database Location—Select other server from the list.
¡     Database Server AddressEnter the IP address of the database server.
¡     Listening PortEnter the listening port of the database server. The default is 1433.
¡     Installation LocationSpecify the local directory for storing the IMC installation package.
¡     Data File LocationSpecify the directory on the database server for storing IMC data files. Make sure the specified data file location exists on the database server and does not include any files.
¡     HTTP Port—Enter the HTTP port number for the IMC Web server. The default is 8080.
¡     HTTPS Port—Enter the HTTPS port number for the IMC Web server. The default is 8443.
4.     Click OK.
The Checking installation environments dialog box displays the check results, as shown in Figure 2.
Figure 2 Check results
5.     Click Exit.
Fix any failed check items according to the check results.
Superuser account
Before IMC installation, obtain the password of the database superuser account or other database user accounts that have superuser privileges.
During the IMC platform installation, IMC uses the superuser account and password for database access, and then creates database files and user accounts for each deployed component. The deployed IMC platform subcomponents and service components use their own user accounts for database access.
If the password of the superuser account is changed after IMC deployment, be sure to update the password in IMC. If the password is not promptly updated, you cannot view database information on the Environment tab, deploy new components, or update existing components for IMC.
To update the database user password in IMC:
1.     Start the Intelligent Deployment Monitoring Agent, and then click the Environment tab.
2.     Click Change Password.
The Change Password button is displayed only when the Intelligent Deployment Monitoring Agent detects an incorrect database user password.
3.     Enter the new database password, and then click OK, as shown in Figure 3.
Figure 3 Changing the superuser password
Table 12 lists the default superuser accounts of SQL Server, MySQL, and Oracle databases.
Table 12 Database superuser accounts
Database
Superuser
SQL Server
sa
Oracle
·     system
·     sys
MySQL
root
As a best practice, configure the following settings:
·     Do not enable seasonal time adjustments such as daylight savings time.
·     Before installing IMC, verify that the system time, date, and time zone settings on the server are correct.
Do not modify the system time on the server after IMC is started. If you modify the system time, the following issues might occur:
·     When jumping to a future time, the system might get so occupied in processing the sudden burst of expired data that real-time data sampling will be delayed. The delay is automatically recovered after the processing of expired data is complete.
·     When you modify the system time to a past time, data with overlapping time occurs, and data processing might become abnormal. After the overlapping time is past, data processing becomes normal again.
The following information describes how to install and deploy the IMC platform on a Windows host that uses a remote SQL Server 2012 database. For more information about installing the SQL Server 2012 database, see SQL Server 2012 Installation and Configuration Guide.
1.     Log on to Windows as an administrator.
2.     Run the install.bat script in the install directory of the IMC installation package.
The Select Country/Region, Language, and Installation Type dialog box opens, as shown in Figure 4.
Figure 4 Select Country/Region, Language, and Installation Type dialog box
3.     Select the country/region, language, and installation type.
IMC supports typical and custom installations.
¡     Typical—In typical installation mode, all platform subcomponents are automatically installed and deployed on the local host without manual intervention.
¡     CustomIn custom installation mode, you can select desired platform subcomponents to install on the local host. After installation is complete, you must manually deploy the platform subcomponents.
4.     Click OK.
To install the IMC platform on a Linux host, use the following guidelines:
·     Run the install.sh script in the install directory of the IMC installation package as a root user.
·     If Linux is used, copy the IMC installation package to a local directory before you run the install.sh script.
·     If the IMC installation package is transferred through FTP, grant read access to the install.sh script by executing chmod –R 775 install.sh in the directory of the script.
When you install or upgrade iMC, restart the iMC server if a socket issue exists in the iMC installation environment. If no socket issue exists, you do not need to restart the iMC server.
The installation packages of the following components are located in the tools\components directory: ACL, EUPLAT, GAM, RestPlugin, VLAN, and WeChat. Before you install and deploy the IMC platform, copy the installation packages of the components you want to install to the install\components directory.
1.     In the Select Country/Region, Language, and Installation Type dialog box, select the Typical installation type, and then click OK.
The Checking installation parameters dialog box opens, as shown in Figure 5.
Figure 5 Checking installation environment
2.     Configure the parameters as needed.
In this example, enter the password of the database superuser sa, use the default settings for other parameters, and then click OK.
The system checks the installation environment and database connectivity, and then displays the check results.
After the checks are passed, the system installs and deploys all IMC platform subcomponents.
After IMC installation and deployment is complete, the Batch deploy succeeded dialog box opens, as shown in Figure 6.
Figure 6 Batch deploy succeeded
3.     Click OK.
1.     In the Select Country/Region, Language, and Installation Type dialog box, select the Custom installation type, and then click OK.
The Checking Database Connectivity dialog box opens, as shown in Figure 7.
Figure 7 Checking Database Connectivity dialog box
After the checks are passed, the IMC installation wizard opens, as shown in Figure 8.
Figure 8 IMC installation wizard
3.     Click Next.
The Agreement page opens, as shown in Figure 9.
Figure 9 Agreement page
4.     Read the license agreement, select Accept, and then click Next.
The Choose Target Folder page opens, as shown in Figure 10.
Figure 10 Choose Target Folder page
5.     Select the components you want to install and specify a local path as the installation location.
The installation program checks whether the specified installation path contains any files. If the path contains files, a message is displayed. Click OK to delete the files.
The default installation location is X:\Program Files\iMC, where X is the drive letter of the disk that has the largest amount of free space.
·     If you install the IMC platform on a Linux host, do not use a symlink path as the installation location.
·     On Linux, the default installation location is /opt/iMC.
6.     Click Next.
The Deployment and Upgrade Options page opens, as shown in Figure 11.
Figure 11 Deployment and Upgrade Options page
7.     Select Deploy or upgrade later.
8.     Click Next.
The Installation Summary page opens, as shown in Figure 12.
Figure 12 Installation Summary page
9.     Verify the installation summary, and then click Install.
After the installation is complete, the Installation Completed page opens, as shown in Figure 13.
Figure 13 Installation Completed page
10.     Select Open deployment monitoring agent, and then click Finish.
The system automatically starts the Intelligent Deployment Monitoring Agent and displays the Batch deploy dialog box, as shown in Figure 14.
Figure 14 Batch deploy dialog box
11.     Select the components to be deployed, and then click OK.
The Database Configuration page opens, as shown in Figure 15.
Figure 15 Database Configuration page
12.     Enter the password of the superuser.
13.     In the Data File Location field, enter the data file folder you created on the database server.
Make sure the specified data file location is on a readable, writable, and uncompressed disk drive and does not include any files.
14.     Click Next.
The Configure Web Service Port page opens, as shown in Figure 16.
Figure 16 Configure Web Service Port page
15.     Enter the HTTP and HTTPS port numbers. This example uses the default port numbers 8080 and 8443.
If you specify other port numbers, make sure the specified ports are not used by other services.
16.     Click Deploy.
After the deployment is complete, the Batch deploy succeeded dialog box opens, as shown in Figure 17.
Figure 17 Batch deploy succeeded dialog box
17.     Click OK
The Intelligent Deployment Monitoring Agent is automatically installed after the IMC platform is installed.
As the IMC management and maintenance tool, the Intelligent Deployment Monitoring Agent provides IMC operation information as well as a variety of management options, such as:
·     Starting and stopping IMC.
·     Installing new components.
·     Upgrading existing components.
·     Deploying and removing components.
To start the Intelligent Deployment Monitoring Agent, click Start, access the all applications page, and then select iMC > Deployment Monitoring Agent.
To start the Intelligent Deployment Monitoring Agent on Linux, run the dma.sh script in the /deploy directory of the IMC installation path.
As shown in Figure 18, the agent contains the following tabs: Monitor, Process, Deploy, and Environment. By default, the Monitor tab is displayed.
The following information describes the functionality of each tab.
Figure 18 Intelligent Deployment Monitoring Agent
Monitor tab
As shown in Figure 19, the Monitor tab displays the performance information of the IMC server, including the disk, CPU, and physical memory usage information.
The tab also provides the following options:
·     Start—Click this button to start IMC. This button is available when IMC is stopped.
IMPORTANT
IMPORTANT:
For correct operation, the Intelligent Management Server service must start with an account that has read/write permissions on the IMC installation folder. By default, the Intelligent Management Server service starts with the Local System account.
·     Stop—Click this button to stop IMC. This button is available when IMC is already started.
·     Automatically start the services when the OS starts—Select this option to automatically start IMC when the operating system starts.
·     Install—Click this button to install new components or upgrade existing components.
Figure 19 Monitor tab of the Intelligent Deployment Monitoring Agent
Process tab
As shown in Figure 20, the Process tab displays IMC process information.
Figure 20 Process tab of the Intelligent Deployment Monitoring Agent
The right-click menu of a manageable process provides the following options:
·     Start Process—Select this option to start the process. This option is available when the process is stopped.
·     Stop Process—Select this option to stop the process. This option is available when the process is started.
·     Auto Start—Select this option to enable automatic startup of the process when IMC is started.
·     Manual Start—Select this option to require manual startup of the process.
·     Refresh Process Status—Select this option to refresh the status of the process.
Deploy tab
As shown in Figure 21, the Deploy tab displays information about all deployed components.
Figure 21 Deploy tab of the Intelligent Deployment Monitoring Agent
The right-click menu of a component provides the following options:
·     Deploy—Select this option to deploy the component on the local host.
This option is available only when the selected component is in Undeployed state.
·     Batch Deploy—Select this option to batch deploy components on the local host.
Components can be deployed only when they have been installed but in Undeployed state.
·     Undeploy—Select this option to undeploy the component.
This option is available only when the selected component is in Deployed state.
·     Undeploy From ConductorSelect this option to delete component information from the conductor server.
This option is available only when the |member server where the component is deployed cannot operate correctly.
·     Batch UndeploySelect this option to undeploy multiple components.
·     UpgradeSelect this option to upgrade the component.
·     Batch UpgradeSelect this option to upgrade components in batches.
·     RemoveSelect this option to remove the component from the host.
·     Show PrerequisitesSelect this option to view all components that the selected component depends on. The component can be deployed only after the dependent components have been deployed.
This option is unavailable if the component does not depend on any other components.
·     Show DependenciesSelect this option to view all components that depend on the selected component.
This option is unavailable if no other components depend on the selected component.
Environment tab
As shown in Figure 22, the Environment tab displays the software, hardware, and database information for the current IMC server.
The tab also provides database backup and restoration options in the Database Backup and Restore area. For more information, see "Backing up and restoring the database."
Figure 22 Environment tab of the Intelligent Deployment Monitoring Agent
The following information describes how to install and deploy the service components. Table 13 lists all service components and subcomponents in IMC
Table 13 Service components and subcomponents
Component
Subcomponent
·     User Access Manager:
¡     Intelligent Strategy Proxy
¡     User Access Management
¡     User Access Management Sub Server
¡     Portal Server
¡     EIP Server
¡     EIP Sub Server
¡     Policy Server
¡     Policy Proxy Server
¡     User SelfService
¡     Third-Party Page Publish Server
·     TACACS+ Authentication Manager
EAD Security Policy
·     Security Policy Configuration
·     Desktop Asset Manager
·     Desktop Asset Manager Proxy Server
MPLS VPN Manager
·     MPLS VPN Management
·     MPLS TE management
·     L2VPN Management
IPsec VPN Manager
IPsec VPN Manager
·     Wireless Intrusion Prevention System
·     Wireless Location Manager
·     Wireless Location Engine
·     User Behavior Auditor Server
·     Network Behavior Analyzer
·     Network Behavior Analyzer Server
Application Manager
·     Application Management
·     Application Management Service
Server & Storage Automation
QoS Manager
QoS Management
·     Auto-Configuration Server
·     Mobile Branch Manager
Resource Automation Manager
VAN Fabric Manager
VAN Fabric Manager
·     Mobile Office Manager
·     Mobile Office MDM Proxy
·     Intelligent Strategy Proxy
·     Load Balancing Manager
All the service components can be installed in the same way, but their deployment procedure might differ. Based on the deployment procedure, the service components can be classified into several categories, as shown in Table 14.
Table 14 Service components classified by deployment procedure
Example component
Similar components
BIMS
IVM, WSM, UBA, QoSM, RAM, VFM, SSM, U-Center
UAM
EMO, EAD, TAM, IPM, EPS
MVM
N/A
The following information describes how to install and deploy BIMS, UAM, and MVM.
IMPORTANT
IMPORTANT:
U-Center must be deployed on IMC PLAT 7.3 (E0706P09). Before deploying U-Center, upgrade the platform to this version.
1.     Start the Intelligent Deployment Monitoring Agent, and then click Install on the Monitor tab.
The Choose folder dialog box opens, as shown in Figure 23.
Figure 23 Choose folder dialog box
2.     Click Browse and select the \install\components folder in the BIMS installation package.
3.     Click OK.
The IMC installation wizard opens, as shown in Figure 24.
Figure 24 IMC installation wizard
4.     Click Next.
The Agreement page opens, as shown in Figure 25.
Figure 25 Agreement
5.     Read the license agreement and third-party license, and then select Accept.
6.     Click Next.
The Choose Target Folder page opens, as shown in Figure 26.
The Installation Location field is automatically populated with the installation location of the IMC platform and cannot be modified.
Figure 26 Choose Target Folder page
7.     Select the BIMS subcomponents you want to install.
8.     Click Next.
The Deployment and Upgrade Options page opens, as shown in Figure 27.
Figure 27 Deployment and Upgrade Options page
9.     Select Deploy or upgrade later.
10.     Click Next.
The Installation Summary page opens, as shown in Figure 28.
Figure 28 Installation Summary page
11.     Verify the installation information, and then click Install.
After the installation is complete, the Installation Completed page opens, as shown in Figure 29.
Figure 29 Installation Completed page
12.     Select Open deployment monitoring agent, and then click Finish.
The Batch deploy dialog box opens, as shown in Figure 30.
Figure 30 Batch deploy dialog box
13.     Select the BIMS subcomponents you want to deploy.
In this example, select all the BIMS subcomponents.
14.     Click OK.
The Configure Web Service Port page opens, as shown in Figure 31.
Figure 31 Configure Web Service Port page
15.     Enter the HTTP and HTTPS port numbers. This example uses the default port numbers 9090 and 9443.
16.     Click Deploy.
The system starts to deploy the selected BIMS subcomponents.
After the deployment is complete, the Batch deploy succeeded dialog box opens, as shown in Figure 32.
Figure 32 Batch deploy succeeded dialog box
17.     Configure the Start Server now option as needed, and then click OK.
1.     Install IMC UAM in the same way IMC BIMS is installed. For information about the procedure, see "Installing and deploying IMC BIMS."
2.     On the Installation Completed page shown in Figure 33, select Open deployment monitoring agent, and then click Finish.
Figure 33 Installation Completed page
The Batch deploy dialog box opens, as shown in Figure 34.
Figure 34 Batch deploy dialog box
3.     Select the UAM subcomponents you want to deploy, and then click OK.
In this example, select all the UAM subcomponents except EIP Sub Server and Third-Party Page Publish Server.
The EIP Sub Server subcomponent must be deployed on |member servers in distributed deployment.
The IMC deployment wizard starts and displays the Intelligent Strategy Proxy Configuration page, as shown in Figure 35.
Figure 35 Intelligent Strategy Proxy Configuration page
4.     Configure the following parameters:
¡     IPv4 Address(Client)—Enter the IP address of the Intelligent Strategy Proxy component. By default, this field is automatically populated with the IP address of the local host.
¡     IPv4 Address(Server)—Enter the IP address of the User Access Management component. By default, this field is automatically populated with the IP address of the local host.
Modify the default settings only when the local host has multiple network interface cards (NICs) and you want to associate Intelligent Strategy Proxy and User Access Management with different NICs.
5.     Click Deploy.
The Configure User Access Management page opens, as shown in Figure 36.
Figure 36 Configure User Access Management page
6.     Configure the following parameters:
¡     Database Password/Confirm Password—These fields are automatically populated with the password of the database superuser sa specified during IMC platform installation.
If the database user password is changed after IMC platform installation, enter the new password in these fields.
¡     UAM Server's IPv4 Address—This field is automatically populated with the IP address of the local host.
7.     Click Deploy.
The Configure Portal Component page opens, as shown in Figure 37.
Figure 37 Configure Portal Component page
8.     Use the default settings, and then click Deploy.
The Configure EIP Server page opens, as shown in Figure 38.
Figure 38 Configure EIP Server page
9.     Use the default settings, and then click Deploy.
The Configure Policy Server page opens, as shown in Figure 39.
Figure 39 Configure Policy Server page
10.     Use the default settings, and then click Deploy.
The Configure User SelfService page opens, as shown in Figure 40.
Figure 40 Configure User SelfService page
11.     Use the default settings, and then click Deploy.
The Configure WeChat Authentication Server page opens, as shown in Figure 41.
Figure 41 Configure WeChat Authentication Server page
12.     Use the default settings, and then click Deploy.
All the selected UAM subcomponents are deployed.
The Batch deploy succeeded dialog box opens, as shown in Figure 42.
Figure 42 Batch deploy succeeded dialog box
13.     Configure the Start Server now option as needed, and then click OK.
1.     Install IMC MVM in the same way IMC BIMS is installed. For information about the procedure, see "Installing and deploying IMC BIMS."
2.     On the Installation Completed page shown in Figure 43, select Open deployment monitoring agent, and then click Finish.
Figure 43 Installation Completed page
The Batch deploy dialog box opens, as shown in Figure 44.
Figure 44 Batch deploy dialog box
3.     Select the MVM subcomponents you want to deploy, and then click OK.
In this example, select all the MVM subcomponents.
The Please Choose L2VPN Global Parameter Operate page opens, as shown in Figure 45.
Figure 45 Please Choose L2VPN Global Parameter Operate page
4.     Configure the L2VPN parameters as needed.
VPLS can use either LDP or BGP for signaling. When BGP is selected, the VLL and PBB options become unavailable.
5.     Click Deploy.
After the deployment is complete, the Batch deploy succeeded dialog box opens, as shown in Figure 46.
Figure 46 Batch deploy succeeded dialog box
6.     Configure the Start Server now option as needed, and then click OK.
Installing plug-ins
To enable IMC to obtain endpoint names from a DHCP server, install the DHCP plug-in on the DHCP server.
For IMC to obtain endpoint names from a DHCP server correctly, the following requirements must be met:
·     The DHCP server must exist, and it is the only DHCP server that has the DHCP plug-in installed and is reachable from the IMC server.
·     The DHCP Server service and iMC DHCP Plug service are enabled on the DHCP server.
·     The DHCP server is added to IMC and its configuration is synchronized to IMC.
·     The IMGAddress value in file server\imf\server\conf\imf.cfg on the DHCP server is set correctly.
By default, IMC does not obtain reserved or allocated IP addresses from the DHCP server. To enable IMC to obtain such addresses, perform the following tasks:
1.     On the DHCP server, set the value of GetDHCPAllocAndReservedIpInfoFlag to 1 in file server\imf\server\conf\ dhcp_agent.cfg.
2.     Restart the iMC DHCP Plug service on the DHCP server.
3.     On the IMC server, synchronize the DHCP server configuration to IMC.
1.     On the IMC server, edit the qvdm.conf file to enable IMC to obtain endpoint names or FQDNs from DHCP servers:
a.     In the \server\conf directory of the IMC installation path, use Notepad to open the qvdm.conf file.
b.     Add the following line to the file:
l2topoPCNameDhcpSwitch=1
c.     Save and close the file.
d.     Restart IMC in the Intelligent Deployment Monitoring Agent.
2.     On the MS DHCP server, edit the imf.cfg file so that the DHCP server can communicate with IMC:
a.     Transfer the plug-in installation package dhcp-plug-windows.zip from the \windows\tools directory of the IMC installation package on the IMC server to the MS DHCP server.
b.     Decompress the installation package.
c.     Use Notepad to open the imf.cfg file in the \dhcp-plug-windows\server\imf\server\conf directory.
d.     Edit the imf.cfg file:
-     Set the value of IMGAddress to the IP address of the IMC server.
-     Set the value of IMGPort to the IMG port number, which is 8800 by default.
e.     Save and close the file.
3.     Run the install.bat script in the dhcp-plug-windows directory.
After the installation is complete, a new service iMC DHCP Plug is added to the system services.
4.     Start the iMC DHCP Plug service:
a.     Click Start, and then select Administrative Tools > Component Services.
b.     On the Component Services page, select Services (Local) from the navigation tree.
c.     On the Services (Local) list, right-click the iMC DHCP Plug service, and then select Start.
To uninstall the DHCP plug-in, run the uninstall.bat script in the dhcp-plug-windows directory.
Do not delete the directory where the plug-in installation package dhcp-plug-windows.zip is decompressed. If you delete the directory, you cannot uninstall the DHCP plug-in completely.
2.     On the Linux DHCP server, edit the imf.cfg file so that the DHCP server can communicate with IMC.
a.     Transfer the plug-in installation package dhcp-plug-linux.zip from the tools directory of the IMC installation package on the IMC server to the Linux DHCP server.
c.     Use the vi editor to open the imf.cfg file in the /dhcp-plug-linux/server/imf/server/conf/ directory.
vi imf.cfg
3.     Set the path of the dhcpd.leases file, which stores DHCP address allocation information:
a.     Determine the path of the dhcpd.leases file. The default path is /var/lib/dhcp.
b.     Use the vi editor to open the qvdm.conf file in the /dhcp-plug-linux/server/imf/server/conf directory, and then add the following line to the file:
DhcpPlugIpAllocPath=<file-path>/dhcpd.leases
Replace <file-path> with the path of the dhcpd.leases file.
4.     Run the install.sh script in the dhcp-plug-linux directory.
After the installation is complete, the system automatically starts the dhcp-plug service and adds the service to the system services.
To manually start the dhcp-plug service, execute the service dhcp-plug start command.
To stop the dhcp-plug service, execute the service dhcp-plug stop command.
To uninstall the DHCP plug-in, run the uninstall.sh script in the dhcp-plug-linux directory.
IMPORTANT
IMPORTANT:
·     Do not delete the directory to which the plug-in installation package dhcp-plug-linux.zip is decompressed. If you delete the directory, you cannot uninstall the DHCP plug-in completely.
·     You cannot configure the Linux DHCP server by using the Terminal Access > DHCP Configuration feature.
If topology calculation fails for displaying connection to servers, install an LLDP plug-in.
An LLDP plug-in contains the following packages:
·     lldp-agent-redhat.zip
·     lldp-agent-ubuntu.zip
·     lldp-agent-windows.zip
Packages lldp-agent-redhat.zip and lldp-agent-ubuntu.zip apply to KVM servers and the lldp-agent-windows.zip package applies to Microsoft Hyper-V servers. Before you install the LLDP plug-ins, save and decompress the packages to the target servers.
Make sure the lldp-agent-windows.zip package is saved to a non-system disk.
IMPORTANT
IMPORTANT:
Do not delete the folder where the decompressed installation packages are located after the LLDP agent installation because the LLDP plug-ins will not be uninstalled completely.
LLDP Windows agents support 32-bit and 64-bit Windows operating systems.
To install and configure an LLDP Windows agent:
1.     Run the install.bat script in the LLDP Windows agent installation path.
The LLDP Windows agent is installed.
2.     Configure the LLDP Windows agent.
The LLDP Windows agent supports either LLDP or CDP, but not both at the same time. By default, the agent supports LLDP.
To enable the LLDP agent to support CDP and set the packet sending interval:
a.     Open the lldpagent.conf file in the \Program Files\lldpAgent directory on the Windows system disk.
b.     Delete the pound sign (#) from the string #Agent=CDP.
c.     Delete the pound sign (#) from the string #INTERVAL=10, and then set the interval as needed.
The default setting is 300 seconds.
d.     Save and close the file.
3.     Restart the lldp-agent service.
The installation procedures for packages lldp-agent-redhat.zip and lldp-agent-ubuntu.zip are the same. The following information describes the installation procedure for the lldp-agent-redhat.zip package.
An LLDP Linux agent must be installed on 64-bit Linux, including Red Hat 5.5, Ubuntu 11.0, and their later versions.
To install and configure an LLDP Linux agent:
1.     Set the executable permission to the install.sh script and run the script in the LLDP Linux agent installation path.
The LLDP Linux agent is installed.
2.     Configure the LLDP Linux agent.
The LLDP Linux agent supports either LLDP or CDP, but not both at the same time. By default, the agent supports LLDP.
a.     Open the lldpagent.conf file in the conf directory.
vi lldpagent.conf
c.     Delete the pound sign (#) from the string #INTERVAL=10 and set the interval as needed.
service lldp-agent restart
Accessing IMC
IMC is a browser-based management tool accessible from PCs. IMC of the Professional edition is also accessible from a mobile device.
Table 15 lists the hardware, software, and browser requirements for accessing IMC.
Table 15 Requirements for accessing IMC from a PC
OS
Hardware and software
Browser version
Browser setting requirements
Windows
·     Recommended resolution: 1280 pixels in width.
·     JRE 1.7.0_update76 or later is installed.
·     IE 10 or 11.
·     Firefox 50 or later.
·     Chrome 44 or later.
·     Turn off the popup blocker.
·     Enable Cookies.
·     Add IMC as a trusted site.
Accessing IMC
1.     Enter a URL in either of the following formats in the address bar of the browser:
¡     http://ip-address:port/imc
¡     https://ip-address:port/imc
In the URL strings, ip-address is the IP address of the IMC server, and port is the HTTP or HTTPS port number used by IMC. By default, IMC uses HTTP port 8080 and HTTPS port 8443.
The IMC login page opens.
2.     Enter the user name and password, and then click Login.
The default username for the iMC super administrator is admin. For versions earlier than iMC PLAT 7.3 (E0706), the default password is admin. For iMC PLAT 7.3 (E0706) and later versions, the default password is Pwd@12345.
IMPORTANT
IMPORTANT:
·     For security purposes, change the password of the IMC superuser admin immediately after the first login.
·     When you attempt to access IMC using HTTPS, a certificate error message might be displayed. For more information, see H3C Getting Started Guide.
When the UAM User SelfService subcomponent is deployed, access the user self-service center by entering a URL in either of the following formats in the address bar of the browser:
·     http://ip-address:port
·     http://ip-address:port/selfservice
In the URL, ip-address is the IP address of the IMC server where the UAM SelfService subcomponent is deployed and port is the HTTP port number used by IMC. The default HTTP port number is 8080.
1.     Open the browser on the mobile device.
2.     Enter http://ip-address:port/imc in the browser's address bar.
In the URL, ip-address is the IP address of the IMC server and port is the HTTP port number of IMC. The default HTTP port number is 8080.
3.     Enter the user name and the password in Operator and Password fields.
The operator must have been added to IMC. The operator account used for login must belong to an operator group that has the iMC Platform - Resource Management > Mobile Client Access operation privilege.
4.     Select Mobile or PC as needed.
The PC version of IMC requires complex operations and provides all functions. The mobile version of IMC allows you to perform the following operations:
¡     View information about faulty devices and interfaces.
¡     Query devices.
¡     View device alarms.
¡     Receive real-time alarms.
¡     Test device reachability by using a ping or tracert command.
¡     View custom views and device views.
5.     Click Login.
Securing IMC
As a best practice to secure IMC, perform the following tasks:
·     Change the password of the IMC superuser admin immediately after the first login.
·     Tie the administrative accounts to a central AAA server via LDAP or RADIUS.
·     Retain one administrative account (not named admin) with a local password to recover from loss of access to the AAA server.
·     Enable the verification code feature on the IMC login page. For more information, see H3C IMC Getting Started Guide.
A user agreement on the IMC login page informs operators of the rights and obligations for IMC login. To log in to IMC, operators must accept terms of the user agreement.
To display a user agreement on the IMC login page:
1.     On the IMC server, enter the \client\conf directory of the IMC installation path (/client/conf on Linux).
2.     Use WordPad (or vi on Linux) to open the commonCfg.properties file.
3.     Change the value of the enableTerms parameter to true.
4.     Save and close the commonCfg.properties file.
5.     Prepare a user agreement in an HTML file named terms.html.
6.     Save the terms.html file to the \client\web\apps\imc directory of the IMC installation path (/client/web/apps/imc on Linux).
7.     Display the IMC login page.
A User agreement link is displayed, as shown in Figure 47.
8.     Click the link to view the terms of the user agreement.
Figure 47 Viewing the user agreement on the login page
Upgrading IMC
The following example describes how to upgrade the IMC platform. Upgrade IMC service components in the same way the IMC platform is upgraded.
Before you upgrade the IMC platform, complete the following tasks:
·     Obtain compatible upgrade packages for the IMC platform and all the deployed service components. After the IMC platform upgrade, you must upgrade all the service components to match the new IMC platform version.
·     Back up IMC database files using DBMan manual backup (see "Backing up and restoring the database"). Stop all IMC processes, and then save the IMC installation directory to a backup path. If the upgrade fails, you can use these files to restore IMC.
Upgrading IMC
CAUTION
CAUTION:
·     Make sure you have compatible upgrade packages for all deployed IMC components. If components do not have upgrade packages, they cannot be upgraded after the IMC platform upgrade and might become invalid.
·     Do not upgrade IMC by running the \install\install.bat script in the IMC installation path.
·     If the reporting function of an upgraded service component relies on the Report Management component, upgrade the Report Management component to match the service component version.
You can use one of the following methods to upgrade components that are installed in the tools\components directory:
·     Copy files of the following components from the tools\components directory to the IMC installation directory install\components: ACL, EUPLAT, GAM, RestPlugin, VLAN, and WeChat. These components are upgraded when you upgrade the IMC platform.
·     Click Install in the Monitor tab of the Intelligent Deployment Monitoring Agent and select to upgrade components in the tools\components directory.
The Choose folder dialog box opens, as shown in Figure 48.
Figure 48 Choose folder dialog box
2.     Click Browse, and then select the \install\components directory in the upgrade package.
3.     Click OK.
The IMC installation wizard opens, as shown in Figure 49.
Figure 49 IMC installation wizard
4.     Click Next.
The Agreement page opens, as shown in Figure 50.
Figure 50 Agreement page
5.     Read the license agreement, select Accept, and then click Next.
The Upgrade Common Components dialog box opens, as shown in Figure 51.
Common components include the Intelligent Deployment Monitoring Agent and common background services.
Figure 51 Upgrade Common Components dialog box
6.     Click OK.
The system automatically upgrades common components and displays the upgrade progress, as shown in Figure 52.
Figure 52 Upgrading common components
After the common components are upgraded, the Choose Target Folder page opens, as shown in Figure 53.
The page displays the components to be installed and the installation location.
Figure 53 Choose Target Folder page
7.     Verify the information, and then click Next.
The Deployment and Upgrade Options page opens, as shown in Figure 54.
Figure 54 Deployment and Upgrade Options page
8.     Select Deploy or upgrade at once, and then click Next.
The Installation Summary page opens, as shown in Figure 55.
Figure 55 Installation Summary page
After the installation is complete, the Batch upgrade dialog box opens, as shown in Figure 56.
Figure 56 Batch upgrade dialog box
10.     Select the components you want to upgrade, and then click OK.
After the upgrade is complete, the Batch upgrade result dialog box shown in Figure 57 or Figure 58 opens. The dialog box content varies depending on whether auto backup and restoration settings have been configured in DBMan before the upgrade.
Figure 57 Batch upgrade result without auto backup and restoration
Figure 58 Batch upgrade result with auto backup and restoration
11.     Click OK.
12.     If the Auto Backup and Restore Settings dialog box opens, configure the auto backup and restoration settings, and then click OK.
13.     To start IMC, click Start on the Monitor tab of the Intelligent Deployment Monitoring Agent.
Restoring IMC
If the IMC upgrade fails, restore IMC to the version before the upgrade.
To restore IMC:
1.     Manually restore the IMC database. For more information, see "Backing up and restoring the database."
2.     After the database restoration is complete, stop IMC in the Intelligent Deployment Monitoring Agent.
3.     Close the Intelligent Deployment Monitoring Agent.
4.     Stop the Intelligent Management Server service in the server manager.
5.     In the IMC installation directory, back up log files necessary for upgrade failure analysis, and then delete all the files in the directory.
6.     Copy the backup IMC installation directory to the IMC installation path.
7.     Start the Intelligent Management Server service in the server manager.
8.     Start IMC in the Intelligent Deployment Monitoring Agent.
For IMC running in stateful failover mode, restore IMC only on the primary server in the failover system.
Uninstalling IMC
Uninstall IMC component by component or uninstall all components at one time.
If you want to reinstall IMC, complete the following tasks before the reinstallation:
·     If you have reinstalled the database after IMC is uninstalled, you must manually delete the folder that stores data files of the previous IMC system. The default folder is named imcdata.
·     If IMC installation or uninstallation is interrupted with an error, manually delete the IMC installation directory and the iMC-Reserved folder. The iMC-Reserved folder is located in the WINDOWS folder or the Linux etc directory.
Uninstalling an IMC component
Before uninstalling an IMC component, uninstall all components that depend on it.
To uninstall an IMC component:
1.     Open the Intelligent Deployment Monitoring Agent.
2.     On the Monitor tab, click Stop.
3.     On the Deploy tab, right-click the component to be uninstalled, and then select Undeploy.
A confirmation dialog box opens.
4.     Click Yes.
The Intelligent Deployment Monitoring Agent undeploys the component. After the undeployment is complete, an operation success dialog box opens.
5.     Click OK.
6.     On the Deploy tab, right-click the undeployed component and select Remove.
7.     Click Yes.
The Intelligent Deployment Monitoring Agent uninstalls the component. After the uninstallation is complete, an operation success dialog box opens.
8.     Click OK.
Uninstalling all IMC components at one time
3.     On Windows, click Start, access the all applications page, and then select iMC > Deployment Monitoring Agent..
On Linux, run the uninstall.sh script in the /deploy directory of the IMC installation path.
An uninstall wizard opens.
4.     Click Uninstall.
5.     Click Yes.
The Intelligent Deployment Monitoring Agent uninstalls all components. After the uninstallation is complete, the Uninstallation Completed dialog box opens.
6.     Clear the OS reboot option, and then click OK.
7.     Delete the iMC-Reserved folder in the WINDOWS folder or the Linux /etc directory.
8.     Reboot the operating system.
Registering IMC
An unregistered IMC version delivers the same functions as those of a registered version, but can be used only for 45 days since the date the service was first started. Register IMC to unlock the time limitation.
For more information about requesting and installing the IMC licenses, see H3C Intelligent Management Center Licensing Guide.
Security settings
Port settings
As a best practice, use a firewall to protect the IMC server cluster by filtering out non-service data sent to the cluster.
IMPORTANT
IMPORTANT:
·     As a best practice to avoid legitimate packet fragments being filtered, do not use ACLs on switches to filter data packets destined for the IMC server cluster.
·     NTA/UBA typically uses probes for log collection. When a firewall is deployed between the probes and IMC, configure ACLs on the firewall to allow IP packets sent by the probes to IMC.
Make sure the ports used by the IMC components (listed in Table 16 and Table 17) are not blocked by the firewall.
Table 16 Port numbers used by the IMC platform
Default port number
Usage
Location
UDP 161
Port to add a device to the IMC
Device
UDP 22
Port for SSH operations
Device
TCP 23
Port for Telnet operations
Device
UDP 514, 515
Port for syslog operations
IMC server
UDP 162
Port for trap operations
IMC server
TCP 8080, configurable
HTTP access to IMC
IMC server
TCP 8443, configurable
HTTPS access to IMC
IMC server
UDP 69
Port for Intelligent Configuration Center to perform configuration management through TFTP
IMC server
TCP 20, 21
Port for Intelligent Configuration Center to perform configuration management through FTP
IMC server
TCP 2810
Port for data file backup and restoration by using DBMan
IMC server
Table 17 Port numbers used by the IMC NTA/UBA
Default port number
Usage
Location
UDP 9020, 9021, 6343
Port for the IMC server to receive logs
IMC server
TCP 8051
Listening port used to monitor the command for stopping the NTA/UBA service
IMC server
TCP 9099
JMX listening port for the NTA/UBA service
IMC server
UDP 18801, 18802, 18803
Communication ports between NTA and UBA
IMC server
DBMan is the automatic backup and restoration tool for the IMC platform and service component databases, and provides a full-range system disaster backup solution. DBMan uses a standard database backup and restoration mechanism to process the complete databases.
DBMan supports both manual and automatic database backup and restoration. It is integrated in the Environment tab of the Intelligent Deployment Monitoring Agent, as shown in Figure 59.
Figure 59 Environment tab
The Environment tab includes the following areas:
·     Running Environment—Displays software and hardware information on the IMC server.
·     Database Space Usage—Displays the database and log file usage information on the IMC server.
·     Database Backup and Restore—Provides the following database backup and restoration options:
¡     Configure—Allows you to configure automatic database backup and restoration settings. The automatic backup and restoration function is typically used in stateless failover scenarios.
¡     Backup—Immediately backs up all IMC data files (including configuration files and database files) to a specified path.
¡     Restore—Immediately restores previously backed up database files.
¡     Backup And Restore—Immediately backs up the database on the primary server to the backup server and performs automatic restoration. This option is applicable to stateless failover scenarios.
To ensure correct operation, do not back up and restore IMC databases between different operating systems.
When you use DBMan to back up and restore IMC databases, follow these restrictions and guidelines:
·     In automatic backup configuration, use the Upload to Backup System option to back up database files to a backup IMC system or an FTP server.
·     The Upload to Backup System option requires one of the following configurations:
¡     The Conductor Server IP of Backup System is specified for database backup.
¡     An FTP server is configured in the dbman_ftp.conf file in the \dbman\etc directory of the IMC installation path. For example:
ftp_ip=1.1.1.1
ftp_user=admin
ftp_password=1234
·     To add additional backup and restoration settings, edit the dbman_addons.conf file in the \dbman\etc directory of the IMC installation path. The settings take effect immediately after the file is saved.
For example, add the following strings to the dbman_addons.conf file to specify tasks to perform before or after database restoration:
BeforeSQLScript_monitor_db_IMC_monitor = D:\1.bat
AfterSQLScript_monitor_db_IMC_monitor = D:\2.bat
·     After Oracle database restoration is complete, make sure the tablespace name is the same as that before restoration.
Installing and upgrading DBMan on the database server
By default, DBMan is not installed on the remote database server. Before database backup and restoration, install DBMan on the database server.
DBMan can be installed automatically when you install the Intelligent Deployment Monitoring Agent.
Installing DBMan
1.     On the database server, enter the install directory of the IMC installation package.
2.     Right-click the installslave.bat script, and then select Run as Administrator from the shortcut menu.
The Address of Conductor  page opens, as shown in Figure 60.
Figure 60 Configuring the IMC server IP address
3.     Enter the IP address of the IMC server, and then click OK.
The Checking Database Connectivity dialog box opens, as shown in Figure 61.
Figure 61 Checking Database Connectivity dialog box
4.     Configure the parameters as needed.
5.     Click OK.
The system checks the installation environment and database connectivity.
After the checks are passed, the system displays the remote IMC installation wizard, as shown in Figure 62.
Figure 62 Remote IMC installation wizard
6.     Specify the deployment location.
7.     Click Install.
After the installation is complete, the Installation Completed page opens, as shown in Figure 63.
Figure 63 Installation Completed page
8.     Click Finish.
DBMan automatically starts when the operating system is started.
Upgrading DBMan
When IMC is upgraded, the database server displays the Upgrade Common Component dialog box, as shown in Figure 64. Click Yes. DBMan is automatically upgraded as a common component.
Figure 64 Upgrade Common Component dialog box
Backing up and restoring databases for a single IMC system
Backing up databases
A single IMC system supports both manual and automatic backup:
·     Manual backup—Immediately backs up all IMC data files.
·     Automatic backup—Allows you to schedule a task to automatically back up selected data files at the specified time.
Manual backup
1.     On the Environment tab, click Backup.
2.     Click Yes.
The Select database backup path dialog box opens.
3.     Specify a local path to save the backed up data files.
Make sure the specified path has enough space.
4.     Click OK.
Automatic backup
1.     On the Environment tab, click Configure.
2.     Click OK.
The Auto Backup and Restore Settings dialog box opens, as shown in Figure 65.
Figure 65 Auto Backup and Restore Settings
3.     Read information in the Auto Backup and Restore Settings dialog box, select Auto Backup Mode, and click OK.
The page for configuring automatic backup settings opens, as shown in Figure 66.
Figure 66 Configuring automatic backup settings
4.     In the General settings area, configure the Backup File Lifetime (days) parameter:
¡     Backup File Lifetime (days)—Enter how many days a backup file can be kept. Expired files are automatically deleted. By default, the backup file lifetime is 7 days.
5.     On the Basic Configuration tab, and then configure the following parameters:
¡     Daily backup time (HH:mm) parameter. Enter the time at which the automatic backup operation starts every day. By default, the daily backup time is 04:00.
¡     Conductor Server IP of Backup SystemThis parameter is applicable to database backup in stateless failover scenarios. To upload the database files to the conductor  server of the backup system, specify the conductor  server IP address in this field. Make sure automatic restoration is enabled for the backup system. To verify the component and version consistency between the primary IMC system and the backup IMC system, click Validate.
¡     Backup exported data filesSelect this parameter to back up exported data files.
6.     Click the Conductor Server tab and configure the following parameters:
¡     Backup Path— Enter or browse to a local path to store the backup data files.
¡     Database Backup PathSpecify the path where the backup database files are stored on the database server.
¡     Local BackupSelect the databases to back up locally on the database server. By default, all databases are selected.
¡     Upload To Backup SystemSelect the databases to upload to an FTP server or the conductor  server of a backup system. By default, no database is selected. When you select Upload To Backup System for a database, the Local Back Up option is forcibly selected for the database. To configure the FTP server, see "Configuration restrictions and guidelines."
7.     Click the Extension Configuration tab and configure the following parameters:
¡     Delete local files after upload even if upload failsSpecify whether to delete local backup files after they are uploaded.
8.     Click OK.
Restoring databases
A single IMC system supports only manual restoration of the databases. Manual restoration immediately replaces the current database files with previously backed up files.
When you perform manual restoration, follow these restrictions and guidelines:
·     Make sure IMC has been started at least once after installation before you restore the IMC databases.
·     Make sure the automatic backup and restoration parameters have been configured. Otherwise, DBMan cannot locate IMC data files or database files during restoration.
·     Restore database files for the IMC platform and service components together. If you restore only some of the database files, data loss or inconsistency might occur.
·     During manual database restoration, the IMC service and database service are automatically stopped and restarted.
To perform a manual restoration:
1.     On the Environment tab, click Restore.
The Restoration Type dialog box opens, as shown in Figure 67.
Figure 67 Restoration Type dialog box
2.     Click Remotely Restore.
The Configure Remote Restoration page opens, as shown in Figure 68.
Figure 68 Remote restoration settings
3.     Click Configure to select the database files to be restored, and then click OK.
The Confirm dialog box opens.
4.     Click Yes.
The system starts restoring the database files.
The Message dialog box opens after the restoration is complete.
5.     Click OK.
The IMC service will be automatically started.
Backing up and restoring databases in stateless failover scenarios
A typical stateless failover scenario includes a primary IMC system and a backup IMC system. For stateless failover, configure automatic backup on the primary IMC system and configure automatic restoration on the backup IMC system.
During automatic backup and restoration, DBMan of the primary IMC system performs the following operations:
1.     Periodically or immediately backs up database files locally.
2.     Uploads the backed up database files to the backup IMC system.
3.     Instructs the backup IMC system to restore the received database files locally.
In stateless failover, configure automatic backup on the conductor server of the primary IMC system.
Before the configuration, make sure the following settings are consistent on the primary and backup IMC systems:
·     OS
·     Database type and version
·     IMC version and patches
When you configure automatic backup, make sure you specify the correct conductor  server of the backup system on the Basic Configuration tab. For more information about configuring automatic backup, see "Automatic backup."
Restoring databases
This example describes the automatic restoration settings on a backup IMC system that is deployed in centralized mode and uses a remote database.
To configure automatic restoration:
The Auto Backup and Restore Settings dialog box opens, as shown in Figure 69.
Figure 69 Auto Backup and Restore Settings dialog box
2.     Read information in the Auto Backup and Restore Settings dialog box, select Auto Restore Mode, and click OK.
The page for configuring auto restoration settings opens, as shown in Figure 70.
Figure 70 Configuring auto restoration settings
3.     Click the Conductor  Server tab, and then configure the following parameters:
¡     Backup Files Location—Specify the local path that stores the backup IMC data files uploaded by the primary IMC system.
¡     Backup Files Location of DatabaseSpecify the path on the remote database server that stores the backup database files uploaded by the primary IMC system.
¡     RestoreSelect databases to restore. By default, all databases are selected.
4.     Click OK.
In a stateless failover scenario, use this option to back up the database on the primary server to the backup server and configure automatic restoration on the backup server.
To configure backup and restoration:
1.     Configure automatic backup on the primary server in the same way you configure database backup in a single IMC system. For more information, see "Automatic backup."
2.     Configure automatic restoration on the backup server. For more information, see "Restoring databases."
3.     Click Backup and Restore on the Environment tab in the Intelligent Deployment Monitoring Agent, as shown in Figure 71.
Figure 71 Configuring backup and restoration
FAQ
After IMC installation is complete, how do I change the database file storage path?
1.     Stop the IMC service by using the Intelligent Deployment Monitoring Agent.
2.     Transfer the databases of IMC components to the new storage path on the database server. This example uses D:\imcdata.
3.     At the CLI, access the \deploy directory of the IMC installation path and modify the database file storage path.
pwdmgr.bat –changeDataDir "D:\imcdata"
Figure 72 shows that the storage path has been successfully modified.
Figure 72 Modifying the database file storage path
4.     Start the IMC service.
On Linux, the time displayed on IMC (such as the login time and operation log record time) is different from the time on the server, and the difference might be several hours.
This issue might occur if the time zone settings on the server where IMC runs are changed after IMC installation. To resolve the issue, use the tzselect command to modify the time zone of the server.
During the component deployment process, a deployment failure occurs and the system displays a database script execution error message. The log file includes an error message that the object dbo.qv.id already exists. How do I resolve the issue?
1.     Log in to the Query Analyzer of SQL Server as sa, and then execute the following commands:
use model
EXEC sp_droptype 'qv_id'
2.     Redeploy the component that failed to be deployed.
On Linux, how do I start JavaService when Xwindows is closed?
Use the service IMCdmsd start command to start the JavaService.
On Windows, the IMC service cannot be started or stopped after IMC runs for a period of time.
This issue is caused by insufficient virtual memory.
To resolve the issue, set the virtual memory to the system managed size:
1.     On the IMC server, click Control Panel, and then click the System icon.
The System Properties dialog box opens, as shown in Figure 73.
Figure 73 System Properties dialog box
2.     Click the Advanced tab, and then click Settings in the Performance area.
The Performance Options dialog box opens, as shown in Figure 74.
Figure 74 Performance Options dialog box
3.     Click the Advanced tab, and then click Change in the Virtual memory area.
The Virtual Memory dialog box opens, as shown in Figure 75.
Figure 75 Virtual Memory dialog box
4.     Select System managed size, and then click Set.
5.     Click OK.
On Linux, popup windows cannot be found during IMC deployment or upgrade.
When Xshell or Xstart is used for remote access on Linux, a window might open on top of popup windows. To resolve this issue, move the window away to view the popup windows.
License verification fails after the Windows operating system reboots. How can I resolve this issue?
The license file contains only one MAC address if the license is requested after NIC teaming. After the operating system reboots, license verification fails because the MAC address of the NIC team has changed.
To resolve this issue, assign a static MAC address to the NIC team, as shown in Figure 76.
Figure 76 Assigning a static MAC address to the NIC team
  • Become a Partner
  • Partner Resources
