H3C S5120V3-EI & S5120V3-LI & S5120V3-SI Switch Series Hardware Information and Specifications-6W100
HomeSupportResource CenterSwitchesS5120 SeriesS5120V3 LI SeriesTechnical DocumentsProduct LiteratureHardware Information & SpecificationsH3C S5120V3-EI & S5120V3-LI & S5120V3-SI Switch Series Hardware Information and Specifications-6W100
01-Hardware Information and Specifications
01-Hardware Information and Specifications 2.23 MB
Product models and technical specifications· 3
Product models· 3
Technical specifications· 4
S5120V3-EI switch series· 4
S5120V3-LI switch series· 8
S5120V3-SI switch series· 11
Chassis views· 14
S5120V3-EI switch series· 14
S5120V3-28S-EI 14
S5120V3-54S-EI 15
S5120V3-28P-EI 15
S5120V3-54P-EI 16
S5120V3-36F-EI 17
S5120V3-28S-HPWR-EI 17
S5120V3-54S-PWR-EI 18
S5120V3-30MS-UPWR-DP-EI 19
S5120V3-LI switch series· 20
S5120V3-10P-LI 20
S5120V3-20P-LI 20
S5120V3-28P-LI 21
S5120V3-28S-LI 21
S5120V3-52P-LI 22
S5120V3-52S-LI 23
S5120V3-28P-PWR-LI 23
S5120V3-28S-PWR-LI 24
S5120V3-52P-PWR-LI 25
S5120V3-52S-PWR-LI 25
S5120V3-10P-PWR-LI 26
S5120V3-12TP-HPWR-LI 27
S5120V3-28P-HPWR-LI 27
S5120V3-28S-HPWR-LI 28
S5120V3-28P-HPWR-LI-Q·· 29
S5120V3-SI switch series· 29
S5120V3-10P-SI 29
S5120V3-28P-SI 30
S5120V3-28S-SI 31
S5120V3-52P-SI 31
S5120V3-52S-SI 32
S5120V3-36F-SI 33
S5120V3-28P-HPWR-SI 33
S5120V3-28S-HPWR-SI-Q·· 34
S5120V3-54P-PWR-SI 35
Removable components· 36
Removable power supplies· 36
Ports and LEDs· 38
Ports· 38
Console port 38
10/100/1000BASE-T autosensing Ethernet port 38
2.5G/1000/100BASE-T autosensing Ethernet port 39
1000/100BASE-T Ethernet port 39
SFP port 39
SFP+ port 42
Combo interface· 44
LEDs· 45
System status LED·· 45
Power supply status LED·· 45
Mode LED (MODE) 45
10/100/1000BASE-T autosensing Ethernet port LED·· 46
2.5G/1000/100BASE-T autosensing Ethernet port LED·· 47
1000/100BASE-T autosensing Ethernet port LED·· 48
SFP/SFP+ port LED·· 48
Power input and output status LEDs on the power supplies· 49
Cooling system·· 50
Product models
This document provides an installation guide for the following switch series
·     S5120V3-EI switch series
·     S5120V3-LI switch series
·     S5120V3-SI switch series
Table 1 describes the switch models that each switch series includes.
Table 1 Switch series and models
Switch series
Model
Product code (PID)
Non-PoE models
S5120V3-28S-EI
LS-5120V3-28S-EI
S5120V3-54S-EI
LS-5120V3-54S-EI
S5120V3-28P-EI
LS-5120V3-28P-EI
S5120V3-54P-EI
LS-5120V3-54P-EI
S5120V3-36F-EI
LS-5120V3-36F-EI
PoE models
S5120V3-28S-HPWR-EI
LS-5120V3-28S-HPWR-EI
S5120V3-54S-PWR-EI
LS-5120V3-54S-PWR-EI
LS-5120V3-30MS-UPWR-DP-EI
Non-PoE models
S5120V3-10P-LI
LS-5120V3-10P-LI
LS-5120V3-10P-LI-GL
S5120V3-20P-LI
LS-5120V3-20P-LI
LS-5120V3-20P-LI-GL
S5120V3-28S-LI
LS-5120V3-28S-LI
LS-5120V3-28S-LI-GL
S5120V3-28P-LI
LS-5120V3-28P-LI
LS-5120V3-28P-LI-GL
S5120V3-52S-LI
LS-5120V3-52S-LI
LS-5120V3-52S-LI-GL
S5120V3-52P-LI
LS-5120V3-52P-LI
LS-5120V3-52P-LI-GL
PoE models
S5120V3-28S-PWR-LI
LS-5120V3-28S-PWR-LI
LS-5120V3-28S-PWR-LI-GL
S5120V3-28P-PWR-LI
LS-5120V3-28P-PWR-LI
LS-5120V3-28P-PWR-LI-GL
S5120V3-52S-PWR-LI
LS-5120V3-52S-PWR-LI
LS-5120V3-52S-PWR-LI-GL
S5120V3-52P-PWR-LI
LS-5120V3-52P-PWR-LI
LS-5120V3-52P-PWR-LI-GL
LS-5120V3-28P-HPWR-LI-Q
S5120V3-28P-HPWR-LI
LS-5120V3-28P-HPWR-LI-GL
S5120V3-28S-HPWR-LI
LS-5120V3-28S-HPWR-LI
LS-5120V3-28S-HPWR-LI-GL
S5120V3-10P-PWR-LI
LS-5120V3-10P-PWR-LI
LS-5120V3-10P-PWR-LI-GL
LS-5120V3-12TP-HPWR-LI
Non-PoE models
S5120V3-10P-SI
LS-5120V3-10P-SI
S5120V3-28P-SI
LS-5120V3-28P-SI
S5120V3-28S-SI
LS-5120V3-28S-SI
S5120V3-52P-SI
LS-5120V3-52P-SI
S5120V3-52S-SI
LS-5120V3-52S-SI
S5120V3-36F-SI
LS-5120V3-36F-SI
PoE models
S5120V3-28P-HPWR-SI
LS-5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
LS-5120V3-54P-PWR-SI
LS-5120V3-28S-HPWR-SI-Q
NOTE
Switches of the same model but different PIDs might differ in hardware and software features. You can view the PID of a switch on the label located on its rear panel or top panel.
Table 2 Technical specifications for the S5120V3-EI non-PoE switch models
Item
S5120V3-28S-EI
S5120V3-54S-EI
S5120V3-28P-EI
S5120V3-54P-EI
S5120V3-36F-EI
Dimensions (H × W × D)
43.6 × 440 × 160 mm (1.72 × 17.32 × 6.30 in)
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in)
Weight
≤ 2.2 kg (4.85 lb)
4.0 kg (8.82 lb)
≤ 2.2 kg (4.85 lb)
4.0 kg (8..82 lb)
≤ 3.5 kg (7.72 lb)
Console port
1 × serial console port
SFP+ port
4
6
N/A
N/A
4
SFP port
N/A
N/A
4
6
24
24
48
24
48
8
Input voltage
·     Rated voltage 100 VAC to 240 VAC @ 50 or 60 Hz
·     Max voltage 90 VAC to 264 VAC @ 47 to 63 Hz
Minimum power consumption
17 W
19 W
17 W
23 W
27 W
Maximum power consumption
37 W
53 W
36 W
52 W
54 W
Chassis leakage current compliance
UL 62368-1/EN 62368-1/IEC 62368-1/UL 60950-1/IEC 60950-1/GB4943.1
Melting current of power supply fuse
2 A/250 V
3.15 A/250 V
2 A/250 V
3.15 A/250 V
3.15 A/250 V
Operating temperature
–5°C to +45°C (23°F to 113°F)
Operating humidity
5% RH to 95% RH, noncondensing
Fire resistance compliance
Table 3 Technical specifications for S5120V3-EI PoE switch models
Item
S5120V3-28S-HPWR-EI
S5120V3-54S-PWR-EI
43.6 × 440 × 320 mm (1.72 × 17.32 × 12.60 in)
43.6 × 440 × 460 mm (1.72 × 17.32 × 18.11 in)
Weight
≤ 5 kg (11.02 lb)
≤ 5.5 kg (12.13 lb)
8.5 kg (18.74 lb)
Console port
SFP+ port
4
6
6
2.5G/100/1000BASE-T autosensing Ethernet port
N/A
N/A
16
N/A
N/A
8
24
48
N/A
Input voltage
AC input
·     AC input for the PSR360-56A/PSR720-56A power supply
¡     Rated voltage range 100 VAC to 240 VAC @ 50 Hz or 60 Hz
¡     Max voltage range 90 VAC to 264 VAC @ 47 Hz to 63 Hz
·     AC input for the PSR1110-56A power supply
¡     Rated voltage range 115 VAC to 240 VAC @ 50 Hz or 60 Hz
¡     Max voltage range 102.5 VAC to 264 VAC @ 47 Hz to 63 Hz
·     DC input for the PSR560-56D power supply
You can use a –48 VDC power source in the equipment room or an RPS (RPS1600-A).
¡     Rated voltage range –48 VDC to –60 VDC
¡     Max voltage range –36 VDC to –72 VDC
Maximum PoE power per port
30 W
30 W
Depends on the power supply configuration, as shown in Table 4.
Total PoE power
370 W
370W
24 W
30 W
·     Single AC input: 47 W
·     Dual AC inputs: 56 W
·     Single DC input: 45 W
·     Dual DC inputs: 64 W
460 W
470 W
·     Single AC input: 1270 W
·     Dual AC inputs: 2430 W
·     Single DC input: 670 W
·     Dual DC inputs: 1350 W
Power efficiency
80 PLUS Gold
N/A
10 A/250 V
·     PSR360-56A: 10 A/250 V
·     PSR720-56A: 10 A/250 V
·     PSR1110-56A: 15 A/250 V
·     PSR560-56D: 30 A/250 V
Operating humidity
Table 4 PoE power capacity of the S5120V3-30MS-UPWR-DP-EI switch
Power supply configuration
Total PoE power capacity
Max PoE power capacity per port
2 × PSR1110-56A
2140 W
90 W
1 × PSR1110-56A and 1 × PSR720-56A
1750 W
90 W
1 × PSR1110-56A and 1 × PSR560-56D
1590 W
90 W
1 × PSR1110-56A and 1 × PSR360-56A
1390 W
90 W
1 × PSR1110-56A
1040 W
90 W
2 × PSR720-56A
1360 W
90 W
1 × PSR720-56A and 1 × PSR560-56D
1200 W
90 W
1 × PSR720-56A and 1 × PSR360-56A
1000 W
90 W
1 × PSR720-56A
650 W
90 W
2 × PSR560-56D
1040 W
90 W
1 × PSR560-56D and 1 × PSR360-56A
840 W
90 W
1 × PSR560-56D
490 W
90 W
2 × PSR360-56A
640 W
90 W
1 × PSR360-56A
290 W
90 W
Table 5 Technical specifications for S5120V3-LI non-PoE switch models
Item
S5120V3-10P-LI
S5120V3-20P-LI
S5120V3-28P-LI
S5120V3-28S-LI
S5120V3-52P-LI
S5120V3-52S-LI
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in)
43.6 × 330 × 230 mm (1.72 × 12.99 × 9.06 in)
43.6 × 440 × 160 mm (1.72 × 17.32 × 6.30 in)4
43.6 × 440 × 230 mm (1.72 × 17.32 × 9.06 in)4
Weight
≤ 1.5 kg (3.31 lb)
≤ 2 kg (4.41 lb)
2.5 kg (5.51 lb)
2.5 kg (5.51 lb)
3.5 kg (7.72 lb)
3.5 kg (7.72 lb)
Console port
SFP port
2
4
4
N/A
4
N/A
SFP+ port
N/A
N/A
N/A
4
N/A
4
8
16
24
24
48
48
Input voltage
AC input
8 W
9 W
9 W
10 W
18 W
19 W
14 W
19 W
23 W
24 W
41 W
44 W
2 A/250 V
2 A/250 V
2 A/250 V
2 A/250 V
3.15 A/250 V
3.15 A/250 V
Operating humidity
Table 6 Technical specifications for the S5120V3-LI PoE switch models(1)
Item
S5120V3-28P-PWR-LI
S5120V3-28S-PWR-LI
S5120V3-52P-PWR-LI
S5120V3-52S-PWR-LI
43.6 × 440 × 400 mm (1.72 × 17.32 × 15.75 in)
43.6 × 440 × 422 mm (1.72 × 17.32 × 16.61 in)
Weight
≤ 4.5 kg (9.92 lb)
≤ 4.5 kg (9.92 lb)
6 kg (13.23 lb)
6 kg (13.23 lb)
6 kg (13.23 lb)
Console port
·     1 × serial console port
·     1 × micro USB console port
If you connect both ports to a configuration terminal, only the micro USB port takes effect.
SFP+ port
N/A
4
N/A
4
N/A
SFP port
4
N/A
4
N/A
4
24
24
48
48
24
Input voltage
30 W
Total PoE power
240 W
370W
15 W
15 W
36 W
36 W
12 W
294 W
294 W
467 W
467 W
400 W
10 A/250 V
15 A/250 V
10 A/420 V
Operating humidity
Table 7 Technical specifications for the S5120V3-LI PoE switch models (2)
Item
S5120V3-10P-PWR-LI
S5120V3-28P-HPWR-LI
S5120V3-28S-HPWR-LI
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.22 in)
Weight
≤ 3 kg (6.61 lb)
≤ 3 kg (6.61 lb)
≤ 4.5 kg (9.92 lb)
≤ 4.5 kg (9.92 lb)
Console port
SFP port
2
4 (The leftmost two SFP ports and their corresponding 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces.)
4 (Each and its corresponding 10/100/1000BASE-T autosensing Ethernet port form a combo interface.)
SFP+ port
N/A
N/A
N/A
4
8
10 (The rightmost two and their corresponding SFP ports form combo interfaces.)
28 (The rightmost four and their corresponding SFP ports form combo interfaces.)
24 (The rightmost four and their corresponding SFP ports form combo interfaces.)
Input voltage
·     Rated voltage range 100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Max voltage range 90 VAC to 264 VAC @ 47 Hz to 63 Hz
30 W
The copper combo ports on the S5120V3-12TP-HPWR-LI, S5120V3-28P-HPWR-LI, and S5120V3-28S-HPWR-LI switches are not PoE capable.
Total PoE power
125 W
125 W
370 W
370 W
10 W
10 W
15 W
16 W
Maximum power consumption (including PoE output)
155 W
155 W
443 W
445 W
UL 62368-1/EN 62368-1/IEC 62368-1/UL 60950-1/EN 60950-1/IEC 60950-1/GB4943.1
6.3 A/250 V
6.3 A/250 V
15 A/250 V
15 A/250 V
Operating humidity
Table 8 Technical specifications for S5120V3-SI switch series non-PoE switch models
Item
S5120V3-28P-SI
S5120V3-28S-SI
S5120V3-52P-SI
S5120V3-52S-SI
S5120V3-36F-SI
S5120V3-10P-SI
Weight
2.5 kg (5.51 lb)
2.5 kg (5.51 lb)
3.5 kg (7.72 lb)
3.5 kg (7.72 lb)
3.5 kg (7.72 lb)
1.5 kg (3.31 lb)
Console port
SFP port
4
N/A
4
N/A
24
2
SFP+ port
N/A
4
N/A
4
4
N/A
24
24
48
48
8
8
Input voltage
9 W
10 W
18 W
19 W
27 W
8 W
23 W
24 W
41 W
44 W
54 W
14 W
2 A/250 V
2 A/250 V
3.15 A/250 V
3.15 A/250 V
3.15 A/250 V
2 A/250 V
Operating humidity
Table 9 Technical specifications for S5120V3-SI switch series PoE switch models
Item
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
Weight
5 kg (11.02 lb)
5.5 kg (12.13 lb)
6 kg (13.23 lb)
Console port
SFP port
4
6
N/A
SFP+ port
N/A
N/A
4
24
48
24
Input voltage
·     Rated voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Max voltage range: 90 VAC to 264 VAC @ 47 Hz to 63 Hz
PoE power capacity
·     Total PoE power: 370 W
·     Max PoE power on a single port: 30 W
24 W
30 W
12 W
460 W
470 W
400 W
Power supply efficiency
80 PLUS Gold
80 PLUS Gold
N/A
10 A/250 V
10 A/420 V
Operating humidity
Chassis views
S5120V3-28S-EI
Figure 1 S5120V3-28S-EI front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) SFP+ port
(3) Serial console port
(4) 10/100/1000BASE-T autosensing Ethernet port LED
(5) System status LED
(6) SFP+ port LED
Figure 2 S5120V3-28S-EI rear panel
1-1-S5170-28S-EI后面板-01
(1) Grounding screw
(2) AC-input power receptacle
S5120V3-54S-EI
Figure 3 S5120V3-54S-EI front panel
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) SFP+ port
(4) SFP+ port LED
(5) Serial console port
(6) System status LED
Figure 4 S5120V3-54S-EI rear panel
2-1-S5170-54S-EI后面板-01
(1) AC-input power receptacle
(2) Grounding screw
S5120V3-28P-EI
Figure 5 S5120V3-28P-EI front panel
(2) SFP port
(6) SFP port LED
Figure 6 S5120V3-28P-EI rear panel
(1) Grounding screw
S5120V3-54P-EI
Figure 7 S5120V3-54P-EI front panel
(3) SFP port
(4) SFP port LED
Figure 8 S5120V3-54P-EI rear panel
(2) Grounding screw
S5120V3-36F-EI
Figure 9 S5120V3-36F-EI front panel
(1) SFP port
(3) SFP+ port
(4) Serial console port
(5) SFP port LED
(6) 10/100/1000BASE-T autosensing Ethernet port LED
(7) System status LED
(8) SFP+ port LED
Figure 10 S5120V3-36F-EI rear panel
(2) Grounding screw
S5120V3-28S-HPWR-EI
Figure 11 S5120V3-28S-HPWR-EI front panel
(2) SFP+ port
(6) Mode LED (MODE)
(7) SFP+ port LED
(8) Port LED mode switching button
Figure 12 S5120V3-28S-HPWR-EI rear panel
(1) Grounding screw
S5120V3-54S-PWR-EI
Figure 13 S5120V3-54S-PWR-EI front panel
(1) 10/100/1000BASE-T PoE+ autosensing Ethernet port
(2) 10/100/1000BASE-T PoE+ autosensing Ethernet port LED
(3) SFP+ port
(4) SFP+ port LED
(6) Port LED mode switching button
(8) Mode LED (MODE)
Figure 14 S5120V3-54S-PWR-EI rear panel
6-1-S5170-54S-PWR-EI后面板-01
(1) Grounding screw
Figure 15 S5120V3-30MS-UPWR-DP-EI front panel
(1) 1000/100BASE-T autosensing Ethernet port
(2) 2.5G/1000/100BASE-T autosensing Ethernet port
(3) 1000/100BASE-T autosensing Ethernet port LED
(4) 2.5G/1000/100BASE-T autosensing Ethernet port LED
(5) SFP+ port LED
(7) Mode LED (MODE)
(8) Power supply 1 status LED
(9) Power supply 2 status LED
(10) Port LED mode switching button
(11) Serial console port
(12) SFP+ port
Figure 16 S5120V3-30MS-UPWR-DP-EI rear panel
(1) Grounding screw
(2) Power supply 1
(3) Power supply 2
The S5120V3-30MS-UPWR-DP-EI switch has two power supply slots on the rear panel. It came with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch. In Figure 16, two PSR720-56A AC power supplies are installed on the switch.
S5120V3-10P-LI
Figure 17 S5120V3-10P-LI front panel
(3) SFP port LED
(4) System status LED (SYS)
(5) Console port
(6) SFP port
Figure 18 S5120V3-10P-LI rear panel
03-S5130S-10P-EI-后面板_复制-01
(1) Grounding screw
S5120V3-20P-LI
Figure 19 S5120V3-20P-LI front panel
(3) SFP port LED
(5) Console port
(6) SFP port
Figure 20 S5120V3-20P-LI rear panel
(2) Grounding screw
S5120V3-28P-LI
Figure 21 S5120V3-28P-LI front panel
(3) SFP port LED
(5) Console port
(6) SFP port
Figure 22 S5120V3-28P-LI rear panel
(1) Grounding screw
S5120V3-28S-LI
Figure 23 S5120V3-28S-LI front panel
(3) SFP+ port LED
(5) Console port
(6) SFP+ port
Figure 24 S5120V3-28S-LI rear panel
(1) Grounding screw
S5120V3-52P-LI
Figure 25 S5120V3-52P-LI front panel
(3) Console port
(4) SFP port LED
(5) System status LED (SYS)
(6) SFP port
Figure 26 S5120V3-52P-LI rear panel
(1) Grounding screw
S5120V3-52S-LI
Figure 27 S5120V3-52S-LI front panel
(3) Console port
(4) SFP+ port LED
(6) SFP+ port
Figure 28 S5120V3-52S-LI rear panel
(1) Grounding screw
S5120V3-28P-PWR-LI
Figure 29 S5120V3-28P-PWR-LI front panel
(2) Port LED mode switching button
(3) 10/100/1000BASE-T autosensing Ethernet port LED
(4) SFP port LED
(6) Mode LED (MODE)
(7) Console port
(8) SFP port
Figure 30 S5120V3-28P-PWR-LI rear panel
(1) Grounding screw
S5120V3-28S-PWR-LI
Figure 31 S5120V3-28S-PWR-LI front panel
(4) SFP+ port LED
(6) Mode LED (MODE)
(7) Console port
(8) SFP+ port
Figure 32 S5120V3-28S-PWR-LI rear panel
(1) Grounding screw
S5120V3-52P-PWR-LI
Figure 33 S5120V3-52P-PWR-LI front panel
(3) Console port
(4) Port LED mode switching button
(6) Mode LED (MODE)
(7) SFP port LED
(8) SFP port
Figure 34 S5120V3-52P-PWR-LI rear panel
(1) Grounding screw
S5120V3-52S-PWR-LI
Figure 35 S5120V3-52S-PWR-LI front panel
(3) Console port
(6) Mode LED (MODE)
(7) SFP+ port LED
(8) SFP+ port
Figure 36 S5120V3-52S-PWR-LI rear panel
(1) Grounding screw
S5120V3-10P-PWR-LI
Figure 37 S5120V3-10P-PWR-LI front panel
01-S5130S-10P-HPWR-EI-前面板-白牌化_复制-01
(3) SFP port LED
(5) Mode LED (MODE)
(7) Console port
(8) SFP port
Figure 38 S5120V3-10P-PWR-LI rear panel
S3100V3-10TP-PWR-EI--S5130S-10P-HPWR-EI-后面板 - 副本-01
(2) Grounding screw
Figure 39 S5120V3-12TP-HPWR-LI front panel
02-S5130S-12TP-HPWR-EI-前面板_复制-01
(3) SFP port LED
(5) Mode LED (MODE)
(7) Console port
(8) SFP port
Figure 40 S5120V3-12TP-HPWR-LI rear panel
(2) Grounding screw
S5120V3-28P-HPWR-LI
Figure 41 S5120V3-28P-HPWR-LI front panel
05-s5130s-28p-hpwr-ei-前面板 - 副本-01
(2) Console port
(3) Port LED mode switching button
(6) Mode LED (MODE)
(7) SFP port LED
(8) SFP port
Figure 42 S5120V3-28P-HPWR-LI rear panel
(1) Grounding screw
S5120V3-28S-HPWR-LI
Figure 43 S5120V3-28S-HPWR-LI front panel
04-s5130s-28s-hpwr-ei-前面板 - 副本-01
(2) SFP port
(3) Console port
(5) 10/100/1000BASE-T autosensing Ethernet port LED
(6) System status LED (SYS)
(7) Mode LED (MODE)
(8) SFP+ port LED
(9) SFP port LED
(10) Micro USB console port
(11) SFP+ port
Figure 44 S5120V3-28S-HPWR-LI rear panel
(1) Grounding screw
Figure 45 S5120V3-28P-HPWR-LI-Q front panel
(4) SFP port LED
(6) Mode LED (MODE)
(7) Micro USB console port
(8) Serial console port
(9) SFP port
Figure 46 S5120V3-28P-HPWR-LI-Q rear panel
(1) Grounding screw
S5120V3-10P-SI
Figure 47 S5120V3-10P-SI front panel
(3) SFP port LED
(5) Console port
(6) SFP port
Figure 48 S5120V3-10P-SI rear panel
(1) Grounding screw
S5120V3-28P-SI
Figure 49 S5120V3-28P-SI front panel
(3) SFP port LED
(5) Console port
(6) SFP port
Figure 50 S5120V3-28P-SI rear panel
(1) Grounding screw
S5120V3-28S-SI
Figure 51 S5120V3-28S-SI front panel
(3) SFP+ port LED
(5) Console port
(6) SFP+ port
Figure 52 S5120V3-28S-SI rear panel
(1) Grounding screw
S5120V3-52P-SI
Figure 53 S5120V3-52P-SI front panel
(3) Console port
(4) SFP port LED
(6) SFP port
Figure 54 S5120V3-52P-SI rear panel
(1) Grounding screw
S5120V3-52S-SI
Figure 55 S5120V3-52S-SI front panel
(3) Console port
(4) SFP+ port LED
(6) SFP+ port
Figure 56 S5120V3-52S-SI rear panel
(1) Grounding screw
S5120V3-36F-SI
Figure 57 S5120V3-36F-SI front panel
(1) SFP port
(3) SFP+ port
(5) SFP port LED
(8) SFP+ port LED
Figure 58 S5120V3-36F-SI rear panel
(2) Grounding screw
S5120V3-28P-HPWR-SI
Figure 59 S5120V3-28P-HPWR-SI front panel
5-3-S5120V3-28P-HPWR-SI前面板
(1) 10/100/1000BASE-T-PoE+ autosensing Ethernet port
(2) SFP port
(4) 10/100/1000BASE-T PoE+ autosensing Ethernet port LED
(6) Mode LED (MODE)
(7) SFP port LED
Figure 60 S5120V3-28P-HPWR-SI rear panel
(1) Grounding screw
Figure 61 S5120V3-28S-HPWR-SI-Q front panel
(4) SFP+ port LED
(6) Mode LED (MODE)
(7) Micro USB Console port
(9) SFP+ port
Figure 62 S5120V3-28S-HPWR-SI-Q rear panel
(1) Grounding screw
S5120V3-54P-PWR-SI
Figure 63 S5120V3-54P-PWR-SI front panel
6-3-S5120V3-54P-PWR-SI前面板-01
(2) 10/100/1000BASE-T-PoE+ autosensing Ethernet port LED
(3) SFP port
(4) SFP port LED
(8) Mode LED (MODE)
Figure 64 S5120V3-54P-PWR-SI rear panel
(1) Grounding screw
The S5120V3-30MS-UPWR-DP-EI switch uses the modular design and supports the following removable components.
Table 10 Removable components
Removable component model
PSR360-56A
Supported
PSR720-56A
Supported
PSR1100-56A
Supported
PSR560-56D
Supported
You can install one power supply, or two power supplies for redundancy on the S5120V3-30MS-UPWR-DP-EI switch. Ensure uninterrupted power supply when only one power supply is present. The PoE power capacity of the switch varies by power supply configuration. For more information, see Table 4. The PoE capacity of the switch degrades when a power supply is faulty.
The removable components available for the S5120V3-30MS-UPWR-DP-EI switch are subject to change over time. For the most recent list of removable components for the switch, see the release notes.
To view electronic label information of the S5120V3-30MS-UPWR-DP-EI switch, execute the display device manuinfo power command.
Table 11 Removable power supplies
Power supply
Specifications
Reference
PSR360-56A
·     Rated input voltage range: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Max input voltage range: 90 VAC to 264 VAC @ 47 Hz to 63 Hz
·     Max output power: 360 W
H3C PSR360-56A Power Module User Manual
PSR560-56D
·     Rated input voltage range: –48 VDC to –60 VDC
·     Max input voltage range: –36 VDC to –72 VDC
·     Max output power: 560 W
H3C PSR560-56D Power Module User Manual
PSR720-56A
·     Max output power: 720 W
H3C PSR720-56A Power Module User Manual
PSR1110-56A
·     Rated input voltage range: 115 VAC to 240 VAC @ 50 Hz or 60 Hz
·     Max input voltage range: 102.5 VAC to 264 VAC @ 47 Hz to 63 Hz
·     Max output power: 1110 W
H3C PSR1110-56A Power Module User Manual
A PSR1110-56A power supply including its handle adds 64 mm (2.52 in) to the total depth of the switch.
Ports and LEDs
Ports
Console port
Table 12 Console port specifications
Item
Serial console port
Connector type
RJ-45
Micro USB Type B
Compliant standard
EIA/TIA-232
USB 2.0
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local PC running terminal emulation program.
·     Provides connection to the USB port of a local PC running terminal emulation program.
Switch models that provide a console port
All switch models
S5120V3-28S-HPWR-LI
If you connect both the serial console port and micro USB console port, only the micro USB console port takes effect.
Table 13 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
Port rate and duplex mode
·     10/100 Mbps, half/full duplex
·     1000 Mbps, full duplex
Auto-MDI/MDI-X
Supported
Max transmission distance
100 m (328.08 ft)
Transmission medium
Category-5 (or above) twisted pair cable
Compatible standards
IEEE 802.3i, 802.3u, 802.3ab
Switch models that provide a 10/100/1000BASE-T autosensing Ethernet port
All switch models (except the S5120V3-30MS-UPWR-DP-EI)
Table 14 2.5G/1000/100BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
Speed, duplex mode, and MDIX mode
·     1/2.5 Gbps, full duplex, auto-MDI/MDIX
·     100 Mbps, full or half duplex, auto-MDI/MDIX
·     2.5 Gbps: 100 m (328.08 ft)
·     1 Gbps: 140 m (459.32 ft)
·     100 Mbps: 200 m (656.17 ft)
The maximum transmission distance between a PSE and PD depends on the peer device capacity and the twisted pair cable quality.
Available cable
Category-5e or above twisted pair cable
Standards
802.3u, IEEE 802.3ab, 802.3bz
Switch model
Table 15 1000/100BASE-T Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     100 Mbps, half/full duplex
·     Auto-MDI/MDI-X
Transmission medium
Standards
Switch model
SFP port
Table 16 SFP port specifications
Item
Specification
Available transceiver modules and cables
·     FE SFP transceiver modules and cables described in Table 17 (available only for the S5120V3-28P-EI, S5120V3-54P-EI, S5120V3-36F-EI, S5120V3-28P-HPWR-SI, S5120V3-54P-PWR-SI, and S5120V3-36F-SI switch models).
·     GE SFP transceiver modules and cables described in Table 18.
Switch models
·     S5120V3-28P-EI, S5120V3-54P-EI, and S5120V3-36F-EI
·     S5120V3-10P-LI, S5120V3-20P-LI, S5120V3-28P-LI, S5120V3-52P-LI, S5120V3-28P-PWR-LI, S5120V3-52P-PWR-LI, S5120V3-10P-PWR-LI, S5120V3-12TP-HPWR-LI, S5120V3-28P-HPWR-LI, S5120V3-28S-HPWR-LI, and S5120V3-28P-HPWR-LI-Q
·     S5120V3-10P-SI, S5120V3-28P-SI, S5120V3-52P-SI, S5120V3-28P-HPWR-SI, S5120V3-54P-PWR-SI, and S5120V3-36F-SI
Restrictions
To use transceiver modules with a maximum transmission distance 80 km (49.71 miles) on an S5120V3-10P-LI, S5120V3-10P-PWR-LI, S5120V3-10P-SI, or S5120V3-12TP-HPWR-LI switch, make sure the ambient temperature is 40°C (104°F).
Table 17 FE SFP transceiver modules
FE SFP transceiver module model
Central wavelength
Interface connector
Interface cable
SFP-GE/FE-LX10-SM1310
1310 nm
LC
9/125 µm, SMF
10 km (6.21 miles)
SFP-FE-SX-MM1310-A
1310 nm
LC
50/125 µm, MMF
2 km (1.24 miles)
62.5/125 µm, MMF
SFP-FE-LX-SM1310-A
1310 nm
LC
9/125 µm, SMF
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310 nm
LC
9/125 µm, SMF
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310 nm
LC
9/125 µm, SMF
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550 nm
LC
9/125 µm, SMF
80 km (49.71 miles)
SFP-FE-LX-SM1310-BIDI
TX: 1310 nm
RX: 1550 nm
LC
9/125 µm, SMF
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
TX: 1550 nm
RX: 1310 nm
IMPORTANT
IMPORTANT:
The SFP-FE-LX-SM1310-BIDI and SFP-FE-LX-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-FE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-FE-LX-SM1550-BIDI transceiver module.
Table 18 GE SFP transceiver modules and cables
GE SFP transceiver module model and cable
Central wavelength
Interface connector
Interface cable
Modal bandwidth (MHz*km)
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-SX-MM850-A
850 nm
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
200 m (656.17 ft)
SFP-GE-SX-MM850-D
850 nm
LC
50/125 µm, MMF
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm, MMF
200
275 m (902.23 ft)
160
200 m (656.17 ft)
SFP-GE-LX-SM1310-A
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
50/125 µm, MMF
500/400
550 m (1804.46 ft)
62.5/125 µm, MMF
500
550 m (1804.46 ft)
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-D
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310 nm
RX: 1490 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 149 nm
RX: 1310  nm
N/A
SFP-GE-LH40-SM1310-BIDI
TX: 1310 nm
RX: 550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles
SFP-GE-LH40-SM1550-BIDI
TX: 1550 nm
RX: 1310 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles
SFP-GE-LH70-SM1490-BIDI
TX: 1490 nm
RX: 1550 nm
LC
9/125 µm, SMF
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550 nm
RX: 490 nm
LC
9/125 µm, SMF
N/A
70 km (43.50 miles)
SFP cables
SFP-STACK-Kit
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use the SFP-GE-LX-SM1490-BIDI transceiver module.
SFP+ port
Table 19 SFP+ port specifications
Item
Specification
10-GE SFP transceiver modules and cables described in Table 20
Switch models
·     All S5120V3-EI switch models (except S5120V3-28P-EI and S5120V3-54P-EI)
·     S5120V3-28S-LI, S5120V3-52S-LI, S5120V3-28S-PWR-LI, S5120V3-52S-PWR-LI, and S5120V3-28S-HPWR-LI
·     S5120V3-28S-SI, S5120V3-52S-SI, S5120V3-28S-HPWR-SI-Q, and S5120V3-36F-SI
Restrictions
You can use only a maximum of two 10-GE transceiver modules with a maximum transmission distance of 80 km (49.71 miles) for the S5120V3-EI switch models (except the S5120V3-28P-EI and S5120V3-54P-EI) and the S5120V3-36F-SI switch.
Table 20 10-GE SFP+ transceiver modules and cables
SFP+ transceiver module/cable model
Central wavelength
Interface connector
Interface cable
SFP-XG-SX-MM850-A
850 nm
LC
50/125 µm, MMF
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125 µm, MMF
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-D
850 nm
LC
50/125 µm, MMF
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
62.5/125 µm, MMF
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-D
1310 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270 nm
RX: 330 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330 nm
RX: 1270 nm
LC
9/125 µm, SMF
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
TX: 1270 nm
RX: 1330 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330 nm
RX: 1270 nm
LC
9/125 µm, SMF
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1490-BIDI
TX: 1490 nm
RX: 1550 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-BIDI
TX: 1550 nm
RX: 1490 nm
LC
9/125 µm, SMF
N/A
80 km (49.71 miles)
SFP+ AOC cables
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
SFP+ copper cables
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules, SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules, and SFP-XG-LH80-SM1490-BIDI and SFP-XG-LH80-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses the SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use the SFP-XG-LX-SM1330-BIDI transceiver module.
Figure 65 SFP+ cable
(1) Connector
(2) Pull latch
·     As a best practice, use H3C transceiver modules and cables for the switch.
·     The H3C transceiver modules and cables are subject to change over time. For the most recent list of H3C transceiver modules and cables, contact your H3C Support or marketing staff.
·     For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide.
Combo interface
The S5120V3-28P-HPWR-LI and S5120V3-28S-HPWR-LI switches each provide four combo interfaces on the front panel. The S5120V3-12TP-HPWR-LI switch provides two combo interfaces on the front panel. A combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports can operate at a time.
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table 21 System status LED description
LED mark
Status
SYS
Steady yellow
Boot ROM booting stage.
Steady green
Linux kernel booting stage, or the switch has started up correctly.
Flashing green (1 Hz)
Software image loading and decompressing stage, or software booting stage.
Steady red
The switch has failed POST or the switch is faulty.
Off
The switch is powered off or has not started up correctly.
Each removable power supply provides a status LED on the front panel to indicate its operating status.
Table 22 Power supply status LED description
LED mark
Status
PWR1/PWR1
Steady green
A power supply is installed in the power supply slot, and the power supply is outputting power correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply is faulty or no power is being supplied to the power supply.
Off
No power supply is installed in the power supply slot.
Mode LED (MODE)
To show more information about the switch through the port status LEDs, some switch models provide a MODE LED to indicate the type of information that the port status LEDs are showing.
You can use the mode button to change the indication of the MODE LED.
·     For the following switch models, the MODE LED changes in color and indication after you press the mode button and keep that state until you press the mode button again.
¡     S5120V3-10P-PWR-LI
¡     S5120V3-12TP-HPWR-LI
¡     S5120V3-28P-HPWR-LI
¡     S5120V3-28S-HPWR-LI
¡     S5120V3-28P-PWR-LI
¡     S5120V3-28S-PWR-LI
¡     S5120V3-52P-PWR-LI
¡     S5120V3-52S-PWR-LI
¡     S5120V3-28P-HPWR-LI-Q
¡     S5120V3-28S-HPWR-SI-Q
·     For the following switch models, after you press the mode button for the mode LED to flash green, the mode LED keeps that state for only 60 seconds and then turns steady green automatically.
¡     S5120V3-28S-HPWR-EI
¡     S5120V3-54S-PWR-EI
¡     S5120V3-30MS-UPWR-DP-EI
¡     S5120V3-28P-HPWR-SI
¡     S5120V3-54P-PWR-SI
Table 23 Description for the MODE LED
LED mark
Status
MODE
Steady green
The port LEDs indicate port link status.
Flashing green (available only for PoE models)
The port status LEDs indicate the PoE power supply status of the ports.
Flashing yellow
·     S5120V3-28P-HPWR-SI, S5120V3-54P-PWR-SI, S5120V3-28S-HPWR-EI, S5120V3-54S-PWR-EI, and S5120V3-30MS-UPWR-DP-EI—The port LEDs indicates the IRF member ID of the switch. For example, if the LEDs for ports 1 to 5 are steady green and the other LEDs are off, the IRF member ID of the switch is 5.
·     S5120V3-28P-PWR-LI, S5120V3-28S-PWR-LI, S5120V3-52P-PWR-LI, S5120V3-28S-HPWR-SI-Q, S5120V3-28P-HPWR-LI-Q, S5120V3-10P-PWR-LI, S5120V3-12TP-HPWR-LI, S5120V3-28P-HPWR-LI, S5120V3-28S-HPWR-LI, and S5120V3-52S-PWR-LI—The port LEDs indicates the IRF member ID of the switch. For example, if the LED for port 5 is steady green and the other LEDs are off, the IRF member ID of the switch is 5.
For switch models that do not provide a port LED mode switching button, see Table 24 for the description for the 10/100/1000BASE-T autosensing Ethernet port LEDs.
Table 24 10/100/1000BASE-T autosensing Ethernet port LED description (1)
LED status
Steady green
A link is present on the port.
Flashing green
The port is sending or receiving data.
Off
No link is present on the port
For switch models that provide a port LED mode switching button, the 10/100/1000BASE-T autosensing Ethernet port LEDs and the mode LED work in conjunction to indicate the operating status of the 10/100/1000BASE-T autosensing Ethernet ports.
Table 25 10/100/1000BASE-T autosensing Ethernet port LED description (2)
Mode LED status
10/100/1000BASE-T autosensing Ethernet port LED status
Steady green (link/active mode)
Steady green
Flashing green
Off
No link is present on the port.
Flashing green (PoE mode, available only for PoE models)
Steady green
Normal PoE power supply.
·     The PD attached to the port requires power higher than the maximum PoE output power of the port.
·     PoE overvoltage, overcurrent, or short circuit has occurred.
·     The remaining power of the switch is not sufficient for the PoE output requirement of the port.
Off
No link is present on the port, or PoE is not enabled on the port.
Flashing yellow (IRF mode)
Steady green
·     S5120V3-28P-HPWR-SI, S5120V3-54P-PWR-SI, S5120V3-28S-HPWR-EI, and S5120V3-54S-PWR-EI—The port LEDs indicates the IRF member ID of the switch. For example, if the LEDs for ports 1 to 5 are steady green and the other LEDs are off, the IRF member ID of the switch is 5.
·     S5120V3-10P-PWR-LI, S5120V3-12TP-HPWR-LI, S5120V3-28P-HPWR-LI, S5120V3-28S-HPWR-LI, S5120V3-28P-PWR-LI, S5120V3-28S-PWR-LI, S5120V3-52P-PWR-LI, S5120V3-52S-PWR-LI, S5120V3-28P-HPWR-LI-Q, and S5120V3-28S-HPWR-SI-Q—The port LEDs indicates the IRF member ID of the switch. For example, if the LED for port 5 is steady green and the other LEDs are off, the IRF member ID of the switch is 5.
Table 26 2.5G/1000/100BASE-T autosensing Ethernet port LED description
Mode LED status
2.5G/1000/100BASE-T autosensing Ethernet port LED status
Steady green
Flashing green
Off
Steady green
·     The device attached to the port requires power higher than the maximum PoE output power of the port.
Off
Off
Table 27 1000/100BASE-T autosensing Ethernet port LED description
Mode LED status
Steady green
Flashing green
Off
Flashing green (PoE mode)
Steady green
·     The device attached to the port requires power higher than the maximum PoE output power on the port.
Off
SFP/SFP+ port LED
Table 28 SFP/SFP+ port LED description
Status
Steady green
Flashing green
Off
·     No link is present on the port.
·     The mode LED is operating in IRF mode (available only for switch models with a mode button)
·     The mode LED is operating in PoE mode (available only for PoE switch models)
The PSR360-56A, PSR560-56D, PSR720-56A, and PSR1110-56A power supplies each provide a power input status LED and power output statue LED to indicate the power input and output status. For more information about the LEDs, see the user guide for the power supply.
Cooling system
The switch uses a high-performance cooling system for fast heat dissipation and system stability. Consider the site ventilation design when you plan the installation site for the switch.
Table 29 Cooling system
Device model
Fan tray type
Airflow direction
S5120V3-36F-SI
S5120V3-28P-HPWR-SI
S5120V3-54P-PWR-SI
S5120V3-52P-PWR-LI
S5120V3-52S-PWR-LI
Fixed fan trays
From the left side to the right side
The S5120V3-28S-HPWR-EI switch is used as an example:
S5120V3-28P-PWR-LI
S5120V3-28S-PWR-LI
S5120V3-28P-HPWR-LI
S5120V3-28S-HPWR-LI
From the left and port sides to the right side
S5120V3-52P-LI
S5120V3-52S-LI
S5120V3-52P-SI
S5120V3-52S-SI
From the left and right sides to the power supply side
The S5120V3-52P-LI switch is used as an example:
S5120V3-10P-LI
S5120V3-10P-SI
S5120V3-20P-LI
S5120V3-28P-LI
S5120V3-28S-LI
S5120V3-28P-SI
S5120V3-28S-SI
S5120V3-10P-PWR-LI
Without fan trays
Passive cooling
  • Become a Partner
  • Partner Resources
