H3C S12500R Switch Router Series Hardware Reference-6W104
HomeSupportSwitchesS12500R SeriesProduct LiteratureHardware Information & SpecificationsH3C S12500R Switch Router Series Hardware Reference-6W104
02-FRUs and Compatibility Matrixes
02-FRUs and Compatibility Matrixes 229.57 KB
2 FRUs and compatibility matrixes
FRUs compatibility
S12500R
Table 2-1 S12500R modules compatibility
Device model
MPU
Fabric module
Service module
S12516R
LSXM1SUPER1
LSXM1SUPEAR1
·     LSXM2SFH16CR1
·     LSXM1SFH16ER1
·     LSXM1SFK16ER1
·     LSXM1SFK16GR1
Type H service modules (LSXM1TGS48HFR1 for example) and Type K service modules (LSXM1CGQ48KBR1 for example). For more information, see Table 2-10.
S12508R
·     LSXM1SFH08CR1
·     LSXM1SFH08DR1
·     LSXM1SFK08ER1
·     LSXM1SFK08GR1
S12504R
LSXM1SUP04TR1
·     LSXM1SFH04DR1
·     LSXM1SFK04FR1
S12500R-2L
LSXM1SUP04TR1
LSXM1SUP02LR1
LSXM1SUP02TR1
Built-in fabric modules
S12500R-2XL
LSXM1SUP04TR1
LSXM1CGQ72KCR1
S12500CR
The S12516CR and S12508CR can be installed with Type K and Type S modules. To avoid module damage or operation anomalies, do not install both types of modules on the same device.
·     Type K MPUs (LSXM1SUPKR1 for example) can be used only with Type K service modules (LSXM1CGQ48KBR1 for example), LSXM1CMUR1 environment management module, and Type K fabric modules (LSXM1SFK08GR1 for example).
·     Type S MPUs (LSXM1SUPRS2 for example) can be used only with Type S service modules (LSXM3TGS48SF2 for example), Type S environment management module (LSXM1CMURS2 for example), and Type S fabric modules (LSXM3SFS08F2 for example).
Table 2-2 S12500CR Type K modules compatibility
Device model
MPU
Environment management module
Fabric module
Service module
S12516CR
LSXM1SUPKR1
LSXM1SUPKAR1
LSXM1CMUR1
·     LSXM1SFK16ER1
·     LSXM1SFK16GR1
S12508CR
·     LSXM1SFK08ER1
·     LSXM1SFK08FR1
·     LSXM1SFK08GR1
Table 2-3 S12500CR Type S modules compatibility
Device model
MPU
Fabric module
Service module
S12516CR
LSXM1SUPRS2
LSXM1CMURS2
·     LSXM3SFS16F2
·     LSXM3SFS16G2
Type S service modules (LSXM3TGS48SF2 for example). For more information, see Table 2-10.
S12508CR
·     LSXM3SFS08G2
·     LSXM3SFS08F2
MPUs
You can install one MPU, or two MPUs for redundancy on the device. Do not install MPUs of different models on the same device.
Table 2-4 MPUs available for the device
Device model
Available MPUs
·     S12516R
·     S12508R
LSXM1SUPER1
LSXM1SUPEAR1
·     S12504R
·     S12500R-2XL
LSXM1SUP04TR1
·     S12516CR
·     S12508CR
LSXM1SUPKR1
LSXM1SUPKAR1
LSXM1SUPRS2
S12500R-2L
LSXM1SUP02LR1
LSXM1SUP02TR1
Table 2-5 MPU specifications (1)
Item
LSXM1SUPER1
LSXM1SUPEAR1
LSXM1SUP04TR1
LSXM1SUPKR1
LSXM1SUPKAR1
LSXM1SUPRS2
Processor
Intel Processor (Quad Core) @ 2.2 GHz
SDRAM
32GB DDR4 SDRAM (two DIMM slots)
16GB DDR4 SDRAM (two DIMM slots)
Flash
4GB EMMC
8GB EMMC
4GB EMMC
NVRAM
512 KB
Port connector type
·     RJ-45
·     LC
·     USB (Type A)
·     Mini-USB (Type AB)
·     RJ-45
·     LC
·     USB (Type A)
·     RJ-45
·     LC
·     USB (Type A)
Ports
·     One console port (RJ-45 connector)
·     One console port (Mini-USB connector)
·     Two 10/100/1000BASE-T ports for management and upgrade
·     Two Gigabit SFP ports for management and upgrade
·     One USB port (USB3.0, host port)
·     Two 1PPS/TOD ports for time synchronization
·     Two SMB clock input ports
·     Two SMB clock output ports
·     One console port
·     One 10/100/1000BASE-T port for management and upgrade
·     One Gigabit SFP port for management and upgrade
·     One USB port (USB2.0, host port)
Port transmission rate
·     Console port: ≤ 115200 bps (default: 9600 bps)
·     SFP port: 1000 Mbps
·     10/100/1000BASE-T port: 10/100/1000 Mbps
The two console ports on the LSXM1SUPKR1, LSXM1SUPKAR1, or LSXM1SUPRS2 MPU cannot be used simultaneously.
Table 2-6 MPU specifications (2)
Item
LSXM1SUP02LR1
LSXM1SUP02TR1
Processor
SDRAM
Flash
8GB EMMC
8GB EMMC
NVRAM
512 KB
512 KB
Port connector type
·     RJ-45
·     LC
·     USB (Type A)
·     RJ-45
·     LC
·     USB (Type A)
·     Coaxial RF connector
Ports
·     One console port
·     One console port
·     One SMB clock input port
·     One SMB clock output port
·     One 1PPS/TOD port for time synchronization
The environment management module is the system monitoring module of the device. It can collect system running information and interact with the management system of the equipment room in real time to deliver highly reliable device monitoring and management.
Table 2-7 Module functionalities
Functionalities
Smart monitoring and management
·     The module exchanges data with the management system of the equipment room in real time, improving energy management resiliency in the data center.
¡     The module monitors the device temperature in real time, and adjusts the fan speed intelligently to avoid overtemperature.
¡     The module reports the power requirements of the device in real time to the management system of the equipment room which will then adjust power supply accordingly to avoid power distribution system overload or underload or energy waste.
·     The module monitors the power consumption and power usage of the device in real time and automatically powers on or off interface modules accordingly.
·     The module provides asset management and fault diagnosis.
High availability
The module is used in 1+1 redundancy with another one. When the active module fails, the standby module takes over the services immediately.
Maintainability
The module reserves a COM port and two 10/100/1000BASE-T management ports (ETH) for future service expansion.
Table 2-8 Environment management modules available for the device
Device model
Available environment management modules
S12516CR
S12508CR
LSXM1CMUR1
LSXM1CMURS2
Table 2-9 Environment management module specifications
Item
Specifications
Processor
Intel processor (Quad Core) @ 2.2 GHz
SDRAM
8 GB DDR4 SDRAM (two DIMM slots)
Flash
8 GB EMMC
Ports
·     1 × COM port (reserved)
·     2 × 10/100/1000BASE-T management ports (reserved)
Interface module adapter
To install an S12500R interface module with dimensions of 50.0 × 432.6 × 519.8 mm (1.97 × 17.03 × 20.46 in) on an S12508CR or S12516CR, you must first install an LSXM1IMAA interface module adapter in the interface module slot. To install an LSXM1CGQ72KCR1 interface module, you must first install two LSXM1IMAA interface module adapters in the interface module slot.
An LSXM1IMAA interface module adapter is required for each S12500R interface module.
Service modules
Table 2-10 describes the service modules available for the device. The service modules provide different types and numbers of ports.
IMPORTANT
IMPORTANT:
To use the LSXM1CGQ36HBR1 or LSXM1CGQ36HFR1 service modules on the device, choose high-performance fan trays for the device. See Table 2-3 for information about the available high-performance fan trays.
For the transceiver modules or cables available for modules, see H3C S12500R Switch Series Cards and Transceiver Modules Compatibility Matrixes and H3C S12500R Switch Router Series Port Splitting and Compatibility With Transceivers and Cables.
Table 2-10 Service modules available for the device
Service module type
Service module model
Port quantity
Compatible device models
Type K
LSXM1CDMS36KCR1
36-port 400G QSFP-DD MACsec Ethernet optical interface module
36
·     S12516CR
·     S12508CR
LSXM1CDQ24KBR1
24-port 400G QSFP-DD Ethernet optical interface module
24
·     S12516R
·     S12508R
·     S12504R
·     S12516CR
·     S12508CR
LSXM1CDQ36KBR1
36-port 400G QSFP-DD Ethernet optical interface module
36
·     S12516CR
·     S12508CR
LSXM1CCQ48KBR1
48-port 200G QSFP56 Ethernet optical interface module
48
·     S12516R
·     S12508R
·     S12504R
·     S12516CR
·     S12508CR
LSXM1CGQ72KCR1
36-port 200G QSFP56 Ethernet optical interface/72-port 100G QSFP28 Ethernet optical interface module
72
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2XL
·     S12500R-2L
·     S12516CR
·     S12508CR
LSXM1CGMS48KBR1
48-port 100GBASE MACsec Ethernet optical interface module
48
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
·     S12516CR
·     S12508CR
LSXM1CGQ48KBR1
48-port 100G QSFP28 Ethernet optical interface module
48
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
·     S12516CR
·     S12508CR
LSXM1CGQFX16KBR1
16-port 100GBASE FlexE Ethernet optical interface module
16
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
·     S12516CR
·     S12508CR
LSXM1MOD24KBR1
24KBR flexible line processing platform module, with two interface module slots
Depends on the interface modules installed. For more information about the available interface modules, see "Interface modules."
·     S12516R
·     S12508R
·     S12504R
·     S12500R-2L
·     S12516CR
·     S12508CR
Type H
LSXM1CGQ36HBR1
36-port 100GBASE QSFP28 Ethernet optical interface module
36
·     S12516R
·     S12508R
·     S12504R
LSXM1CGQ36HFR1
36
·     S12516R
·     S12508R
·     S12504R
LSXM1CGQ18QGHBR1
18-port 100G QSFP28 Ethernet optical interface/36-port 40G QSFP+ Ethernet optical interface module
36
·     S12516R
·     S12508R
·     S12504R
LSXM1CGQ18QGHFR1
36
·     S12516R
·     S12508R
·     S12504R
LSXM1CGQ6QGHFR1
6-port 100G QSFP28 Ethernet optical interface/12-port 40G QSFP+ Ethernet optical interface module
12
·     S12516R
·     S12508R
·     S12504R
LSXM1TGS48HBR1
48-port 10GBASE SFP+ Ethernet optical interface module
48
·     S12516R
·     S12508R
·     S12504R
LSXM1TGS48HFR1
48
·     S12516R
·     S12508R
·     S12504R
Type S
LSXM3CDQ16SF2
16-port 400G QSFP-DD Ethernet optical interface module
16
·     S12516CR
·     S12508CR
LSXM3CDQ8SF2
8-port 400G QSFP-DD Ethernet optical interface module
8
·     S12516CR
·     S12508CR
LSXM3CGQ36SF2
36-port 100G QSFP28 Ethernet optical interface module
36
·     S12516CR
·     S12508CR
LSXM3CGQ18SF2
18-port 100G QSFP28 Ethernet optical interface module
18
·     S12516CR
·     S12508CR
LSXM3QGS36SF2
36
·     S12516CR
·     S12508CR
LSXM3YGS48SF2
48-port 25G SFP28 Ethernet optical interface module
48
·     S12516CR
·     S12508CR
LSXM3TGS48SF2
48-port 10G SFP+ Ethernet optical interface module
48
·     S12516CR
·     S12508CR
Interface modules
The LSXM1MOD24KBR1 supports installation of interface modules. Table 2-11 describes the interface modules available for the LSXM1MOD24KBR1.
Table 2-11 Interface modules available for the LSXM1MOD24KBR1
Model
Port quantity and type
LSXM1CGQ18C1
18-port 100GBASE Ethernet optical interface module
18 QSFP28 ports
LSXM1CGQ8C1
8 QSFP28 ports
LSXM1TGS24C1
24-port 100GBASE Ethernet optical interface module
24 SFP+ ports
Fabric modules
Table 2-12 describes the fabric modules available for the device.
Do not install fabric module of different models on the same device.
Table 2-12 Fabric modules available for the device
Device model
Available fabric modules
Quantity per chassis
S12516R
·     LSXM2SFH16CR1
·     LSXM1SFH16ER1
·     LSXM1SFK16ER1
·     LSXM1SFK16GR1
2 to 6
S12508R
·     LSXM1SFH08CR1
·     LSXM1SFH08DR1
·     LSXM1SFK08ER1
·     LSXM1SFK08GR1
2 to 6
S12504R
·     LSXM1SFH04DR1
·     LSXM1SFK04FR1
2 to 6
S12516CR
·     LSXM1SFK16ER1
·     LSXM1SFK16GR1
·     LSXM3SFS16F2
·     LSXM3SFS16G2
2 to 9
S12508CR
·     LSXM1SFK08ER1
·     LSXM1SFK08FR1
·     LSXM1SFK08GR1
·     LSXM3SFS08F2
·     LSXM3SFS08G2
2 to 9
You can install a maximum of six Type S fabric modules (LSXM3SFS08F2 for example) on an S12516CR or S12508CR. For an S12508CR, install Type S fabric modules in slots 14 to 19. For an S12516CR, install Type S fabric modules in slots 22 to 27.
Fabric module slot filler panels
The device comes with empty fabric module slots. For good ventilation, purchase and install filler panels in the empty fabric module slots.
Table 2-13 Fabric module slot filler panels
Item
S12516R fabric module slot filler panel
0 to 4
S12508R fabric module slot filler panel
0 to 4
S12504R fabric module slot filler panel
0 to 4
S12516CR fabric module slot filler panel
0 to 6
S12508CR fabric module slot filler panel
0 to 6
Slide rails
No slide rails are provided with the device. Purchase slide rails for the device as needed.
Table 2-14 Slide rails available for the device
Device model
Chassis weight (fully configured)
Applicable slide rails
Slide rail model
Adjustment range
Occupied space
S12516R
400 kg (881.83 lb)
LSXM1BSR
630 mm to 900 mm (24.80 in to 35.43 in)
1 RU
S12508R
220 kg (485.01 lb)
LSXM1BSR
1 RU
LSTM2KSGD0
500 mm to 800 mm (19.69 in to 31.50 in)
2 RU
S12504R
S12500R-2XL
120 kg (264.55 lb)
LSVM1BSR10
630 mm to 850 mm (24.80 in to 33.46 in)
N/A
S12500R-2L
70 kg (154.32 lb)
S12516CR
620 kg (1366.84 lb)
LSXM1BSR
1 RU
S12508CR
400 kg (881.83 lb)
LSXM1BSR
1 RU
Power trays and power modules
CAUTION
CAUTION:
You must install power modules of the same model for the device.
The device supports N+N (dual power input lines) or N+1 (single power input line) power module redundancy. Determine the number of power modules based on the power supply mode and system power consumption. Make sure the maximum total output power of the device power modules is greater than the system power consumption. Reserve a 20% power surplus as a best practice.
Table 2-15 describes the power trays and power modules available for the device.
Table 2-15 Power trays and power modules available for the device
Device model
Available power trays
Available power modules
S12516R
S12508R
S12504R
S12500R-2XL
N/A
PSR2400-54A
PSR2400-54D
PSR3000-54A
PSR3000-54AHD
S12516CR
S12508CR
CR-PEM-DC2000
PSR2000B-54D
CR-PEM-AC3000
PSR3000B-54AHD
CR-PEM-HVDC3000
PSR3000B-54AHD
S12500R-2L
N/A
PSR1800-56A
PSR1800-56D
The PSR2000B-54D is a DC input and DC output removable power supply. The PSR3000B-54AHD is an AC/high-voltage DC input and DC output removable power supply.
Table 2-16 PSR2400-54A power module specifications
Item
Specifications
Rated input voltage
100 to 240 VAC @ 50 or 60 Hz
Rated output voltage
54 VDC
Maximum input current
16 A
Maximum output current
44.5 A
Maximum output power
·     1200 W @ 110 VAC
·     2400 W @ 220 VAC
Dimensions (H × W × D)
41 × 100 × 332 mm (1.61 × 3.94 × 13.07 in)
Ambient temperature
Operating temperature
–10°C to +50°C (–14°F to +122°F)
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Table 2-17 PSR3000-54A power module specifications
Item
Specifications
Rated input voltage
54 VDC
16 A
55.6 A
·     1200 W @ 100 to 175 VAC
·     3000 W @ 175 to 240 VAC
Ambient temperature
Storage temperature
Table 2-18 PSR2400-54D power module specifications
Item
Specifications
Rated input voltage
–48 to –60 VDC
54 VDC
80 A
44.5 A
2400 W
Ambient temperature
Storage temperature
Table 2-19 PSR3000-54AHD power module specifications
Item
Specifications
AC input
Rate input voltage
20 A
High-voltage DC input
Rate input voltage
240 to 380 VDC
20 A
54 V
27.8 A (100 to 175 VAC)
55.6 A (175 to 240 VAC or 240 to 380 VDC)
1500 W (100 to 175 VAC)
3000 W (175 to 240 VAC or 240 to 380 VDC)
Ambient temperature
Storage temperature
Table 2-20 PSR2000B-54D/PSR3000B-54AHD power supply specifications
Item
PSR2000B-54D
PSR3000B-54AHD
Rated input voltage
–48 to –60 VDC
·     100 to 130 VAC @ 50 or 60 Hz
·     200 to 240 VAC @ 50 or 60 Hz
·     240 VDC
·     336 VDC
Input voltage range
–39 to –72 VDC
·     90 to 150 VAC @ 47 to 63 Hz
·     176 to 290 VAC @ 47 to 63 Hz
·     180 to 290 VDC
·     260 to 400 VDC
Input current
60 A (max)
16 A (rated)
54 VDC
54 VDC
Max. output current
37 A
55.6 A
Max. output power
2000 W
·     100 to 130 VAC @ 60 Hz: 1500 W
·     200 to 240 VAC @ 50 Hz: 3000 W
·     240 VDC: 3000 W
·     336 VDC: 3000 W
Ambient temperature
·     Operating: –10°C to +50°C (14°F to 122°F)
·     Storage: –40°C to +70°C (–40°F to +158°F)
41 × 68 × 440 mm (1.61 × 2.68 × 17.32 in)
Weight
2.0 kg (4.41 lb)
2.0 kg (4.41 lb)
Compatible power trays
CR-PEM-DC2000
·     AC power input: CR-PEM-AC3000 and CR-PEM-HVDC3000
·     240 VDC power input: CR-PEM-AC3000 and CR-PEM-HVDC3000
·     336 VDC power input: CR-PEM-HVDC3000
Table 2-1 PSR1800-56A power supply specifications
Item
Specifications
Rated input voltage
56 VDC
·     13 A @ 110 VAC
·     9 A @ 220 VAC
32.2 A
·     1100 W @ 100 VAC to 200 VAC
·     1800 W @ 201 VAC to 240 VAC
·     1800 W @ 240 VDC
40.1 × 82.6 × 297.7 mm (1.58 × 3.25 × 11.72 in)
Ambient temperature
Storage temperature
–40°C to + 70°C (–40°F to +158°F)
Table 2-2 PSR1800-56D power supply specifications
Item
Specifications
Rated input voltage
–48 to –60 VDC
56 VDC
45 A
32.2 A
1800 W
Ambient temperature
Storage temperature
The power module shuts down automatically when its temperature exceeds the acceptable range. When the temperature returns to the acceptable range, the power module automatically restarts.
Fan trays
Table 2-3 Fan trays available for the device
Model
Available fan trays
Number of fans
Fan diameter
Maximum air flow rate
S12516R
LSXM116XFAN
6
120 mm (4.72 in)
1020 CFM (28.88 m3/min)
LSXM116XFANH (high-performance)
6
134 mm (5.28 in)
1860 CFM (52.67 m3/min)
S12508R
LSXM108XFAN
3
120 mm (4.72 in)
510 CFM (14.44 m3/min)
LSXM108XFANH (high-performance)
3
134 mm (5.28 in)
930 CFM (26.33 m3/min)
S12504R
LSXM104XFAN
2
120 mm (4.72 in)
340 CFM (9.63 m3/min)
LSXM104XFANH (high-performance)
2
120 mm (4.72 in)
560 CFM (15.86 m3/min)
S12516CR
FAN-80-9-A
9
80 mm (3.15 in)
900 CFM (25.49 m3/min)
S12508CR
FAN-80-5-A
5
80 mm (3.15 in)
500 CFM (14.16 m3/min)
S12500R-2L
FAN-120-1-A
2
120 mm (4.72 in)
1240 CFM (35.11 m3/min)
S12500R-2XL
2
120 mm (4.72 in)
You can install a maximum of three fan trays on an S12516CR or S12508CR installed with Type S modules. The fan trays can be installed only in slots FAN 2 to FAN 4. Do not remove the filler panels in slots FAN 1 and FAN 5.
DC power cords
A DC power cord is used for connecting a DC power module on the device to an external DC power supply system.
Table 2-4 DC power cords
Power module/power tray model
Power cord length
PSR2400-54D
3 m (9.84 ft)
Connects the DC power module to an external DC power supply system.
15 m (49.21 ft)
PSR3000-54AHD
3 m (9.84 ft)
Connects the 3000W AC & 240 to 380 HVDC power module to an external DC power supply system.
CR-PEM-DC2000
5 m (16.40 ft)
Connects the power tray to an external DC power supply system.
25 m (82.02 ft)
35 m (114.83 ft)
CR-PEM-HVDC3000
1 m (3.28 ft)
3 m (9.84 ft)
PSR1800-56D
3 m (9.84 ft)
Connects the DC power supply to an external DC power source.
15 m (49.21 ft)
AC power cords
An AC power cord is used for connecting an AC power module on the device to an external AC power supply system.
·     Select an AC power cord with a current-carrying capacity that meets the power module requirement.
·     The connector type varies by country or region. Select a compliant connector type as needed.
·     Select 16A AC power cords for the device. For the connector types of different countries or regions, see http://www.h3c.com/en/Support/Resource_Center/EN/Home/Switches/00-Public/Install/Installation_Guides/H3C_Power_Cords_Cables_UG-6W100/.
Chassis component ordering information
To purchase chassis components, contact the sales agent or H3C sales personnel.
Table 2-5 Chassis component ordering information
Product code
Product name
MPUs
0231AE3C
LSXM1SUPER1
H3C S12500R supervisor engine module
0231ADRF
LSXM1SUP04TR1
H3C S12504R supervisor engine module
0231ADUD
LSXM1SUPKR1
H3C S12500CR supervisor engine module
0231ABV3
LSXM1SUP02LR1
H3C S12500R-2L supervisor engine module
0231AG2Q
LSXM1SUP02TR1
0231AH9W
LSXM1SUPEAR1
H3C S12500R AI supervisor engine unit
0231AH9X
LSXM1SUPKAR1
H3C S12500CR AI supervisor engine unit
0231AJC1
LSXM1SUPRS2
H3C S12500CR supervisor engine unit
0231AE47
LSXM1CMUR1
H3C S12500CR switch environment management module
0231AJC0
LSXM1CMURS2
Fabric modules
0231AD26
LSXM2SFH16CR1
H3C S12516R fabric module, Type H (Class C)
0231AD2A
LSXM1SFH16ER1
H3C S12516R fabric module, Type H (Class E)
0231AD28
LSXM1SFH08CR1
H3C S12508R fabric module, Type H (Class C)
0231AD27
LSXM1SFH08DR1
H3C S12508R fabric module, Type H(Class D)
0231AD29
LSXM1SFH04DR1
H3C S12504R fabric module, Type H(Class D)
0231AFCT
LSXM1SFK16ER1
H3C S12516R fabric module, Type K(Class E)
0231AE48
LSXM1SFK16GR1
H3C S12516R fabric module, Type K(Class G)
0231AFCU
LSXM1SFK08ER1
H3C S12508R fabric module, Type K(Class E)
0231AE3A
LSXM1SFK08FR1
H3C S12508R fabric module, Type K(Class F)
0231AETV
LSXM1SFK08GR1
H3C S12508R fabric module, Type K(Class G)
0231AETW
LSXM1SFK04FR1
H3C S12504R fabric module, Type K(Class F)
0231AGJ7
LSXM3SFS16F2
H3C S12516 fabric module,Type S(Class F)
0231AGHK
LSXM3SFS16G2
H3C S12516 fabric module,Type S (Class G)
0231AGJ3
LSXM3SFS08F2
H3C S12508 fabric module,Type S(Class F)
0231AGHR
LSXM3SFS08G2
H3C S12508 fabric module,Type S (Class G)
Service modules
0231AD2D
LSXM1CGQ36HBR1
H3C S12500R 36-Port 100GBASE Ethernet optical interface module (QSFP28) (HB)
0231AD2E
LSXM1CGQ36HFR1
H3C S12500R 36-Port 100GBASE Ethernet optical interface module (QSFP28) (HF)
0231AEM6
LSXM1TGS48HFR1
H3C S12500R 48-port 10GBASE Ethernet optical interface module (SFP+,LC)(HF)
0231AEM8
LSXM1CGQ18QGHFR1
H3C S12500R 18-port 100GBASE Ethernet optical interface (QSFP28)/36-port 40GBASE Ethernet optical interface module (QSFP+)(HF)
0231AEM7
LSXM1CGQ6QGHFR1
H3C S12500R 6-port 100GBASE Ethernet optical interface (QSFP28)/12-port 40GBASE Ethernet optical interface module (QSFP+)(HF)
0231AE03
LSXM1TGS48HBR1
H3C S12500R 48-port 10GBASE Ethernet optical interface module (SFP+,LC)(HB)
0231AE04
LSXM1CGQ18QGHBR1
H3C S12500R 18-port 100GBASE Ethernet optical interface (QSFP28)/36-port 40GBASE Ethernet Optical interface module (QSFP+)(HB)
0231AE39
LSXM1CDQ24KBR1
H3C S12500R 24-port 400GBASE Ethernet optical interface module (QSFP-DD) (KB)
0231AE3B
LSXM1CGQ48KBR1
H3C S12500R 48-port 100GBASE Ethernet optical interface module (QSFP28) (KB)
0231AE4A
LSXM1CDQ36KBR1
H3C S12500CR 36-port 400GBASE Ethernet optical interface module (QSFP-DD) (KB)
0231AFPW
LSXM1CCQ48KBR1
H3C S12500R 48-port 200GBASE Ethernet optical interface module (QSFP56) (KB)
0231AG0A
LSXM1MOD24KBR1
H3C S12500R 24KBR flexible line processing platform module
0231AG2P
LSXM1CGQFX16KBR1
H3C S12500R 16-port 100GBASE FlexE Ethernet optical interface module(QSFP28)
0231AH8C
LSXM1CGMS48KBR1
H3C S12500R 48-port 100GBASE MACsec Ethernet optical interface module (QSFP28)
0231AJ2B
LSXM1CDMS36KCR1
H3C S12500CR 36-port 400GBASE MACsec Ethernet optical interface module (QSFP-DD)(KC)
0231AGX6
LSXM1CGQ72KCR1
H3C S12500R 36-port 200GBASE Ethernet optical interface (QSFP56)/72-port 100GBASE Ethernet optical interface module (QSFP28)(KC)
0231AGJ5
LSXM3CDQ16SF2
H3C S12500 16-port 400G Ethernet optical interface module (QSFP-DD)(SF)
0231AGJ6
LSXM3CDQ8SF2
H3C S12500 8-port 400G Ethernet optical interface module (QSFP-DD)(SF)
0231AGHL
LSXM3CGQ36SF2
H3C S12500 36-port 100G Ethernet optical interface module (QSFP28)(SF)
0231AGJ4
LSXM3CGQ18SF2
H3C S12500 18-port 100G Ethernet optical interface module (QSFP28)(SF)
0231AGJ2
LSXM3QGS36SF2
H3C S12500 36-port 40G Ethernet optical interface module (QSFP+)(SF)
0231AGHP
LSXM3YGS48SF2
H3C S12500 48-port 25G Ethernet optical interface module (SFP28,LC) (SF)
0231AGHN
LSXM3TGS48SF2
H3C S12500 48-port 10G Ethernet optical interface module (SFP+,LC)(SF)
Interface module
0231AFVG
LSXM1CGQ18C1
18-port 100GBASE Ethernet optical interface module (QSFP28)
0231AG38
LSXM1CGQ8C1
0231AG2N
LSXM1TGS24C1
24-port 100GBASE Ethernet optical interface module (SFP+,LC)
Fan trays
0231A2T1
LSXM116XFAN
Fan module for the H3C S12516R
0231A2UH
LSXM108XFAN
Fan module for the H3C S12508R
0231A2X9
LSXM104XFAN
Fan module for the H3C S12504R
0231A4WX
LSXM116XFANH
High speed fan module for the H3C S12516R
0231A4X0
LSXM108XFANH
High speed fan module for the H3C S12508R
0231A4X1
LSXM104XFANH
High speed fan module for the H3C S12504R
0231AE49
FAN-80-9-A
Fan tray module (9 fans, port to power airflow)
0231AE4B
FAN-80-5-A
Fan tray module (5 fans, port to power airflow)
0231ABVR
LSXM102LFAN
H3C S12500R-2L Ethernet switch router fan module
Power trays
0231A5UX
CR-PEM-DC2000
DC 2000W power tray
0231A5UW
CR-PEM-AC3000
AC 3000W power tray
0231A5UY
CR-PEM-HVDC3000
HVDC 3000W power tray
Power modules
0231A2KX
LSVM3PSRA
AC power supply, 1800W
0231A2KY
PSR1800-56D
DC power supply, 1800W
0231A2SN
PSR2400-54A
AC power module, 2400W
0231A2X7
PSR2400-54D
DC power module, 2400W
0231A5CH
PSR3000-54A
3000W AC power supply module
0231A6PS
PSR3000-54AHD
3000W AC & 240V-380V HVDC power supply
0231A5V1
PSR2000B-54D
DC 2000W power supply
0231A5V0
PSR3000B-54AHD
AC 3000W power supply (support HVDC)
Power cords
0404A0E1
CAB-DC Pwr-3m-2
External DC power cable, 3m, 13mm^2, PWR63A-B-2, 6UL10455BL+6UL10455B, 2*(T16-12G)+2*OT(16-6-0)!+2*OT(16-8-0)!
0404A0E2
CAB-DC Pwr-15m-2
External DC power cable, 15m, 13mm^2, PWR63A-B-2, 6UL10455BL+6UL10455B, 2*(T16-12G)+2*OT(16-6-0)!+2*OT(16-8-0)!
0404A0H4
CAB-AC-CHI-C19RA-3m
Chinese AC power cable (C19 right angle), 3.0m, 1.5mm^2, black, PI250V16AAM, 227 IEC 53(RVV)3*1.5mm^2B, C19-250V16ARAF
04043396
CAB-AC Pwr CHI-3m
Chinese AC power cable 220V16A, 3m, 3*1.5mm^2, black, I-Type angle plug, 227IEC53-1.5^2(3C), C19 straight connector
0404A0C2
CAB-AC Pwr 3C-3m-PDU
External power cable, Chinese AC power cable 220V16A, 3m, 3*1.5mm^2, black, C20 straight plug, 227IEC53-1.5^2(3C), C19 straight connector, PDU
0404A0GE
CAB-HVDC-16A-PDU-3m-Y
High voltage DC power cable (yellow), 3m, 1.5mm^2, pantone yellow 121C, C20-250V16A, 227IEC53(RVV)3*1.5mm^2 pantone yellow 121C, C19-250V16A
0404A0GK
CAB-HVDC-250V16A-3m-Y
High voltage DC power cable (yellow), 3m, 1.5mm^2, pantone yellow 121C, PI angle plug, 227IEC53(RVV)3*1.5mm^2PANTONE YELLOW 121C, C19-250V16A
0404A0HS
CAB-AC-PWR-3m-C20-C19RA
External AC power cable, 3m, 3*1.5mm^2, black, C20-250V16A, 227IEC53(RVV)3*1.5mm^2B, C19RA-250V16A
0404A0LH
CAB-HVDC-16A-PDU-5m-Y
High voltage DC power cable (yellow), 5m, 1.5mm^2, pantone yellow 121C, C20-250V16A, 227IEC53(RVV)3*1.5mm^2 pantone yellow 121C, C19-250V16A
0404A0NH
CAB-PDU PWR-3m-C19A-C20
Chinese PDU power cable (C19A-C20) yellow, 3.0m, 3*1.5mm^2, pantone yellow 121C, C20-250V16ASM, 227 IEC 53(RVV)3*1.5mm^2 pantone yellow 121C,C19-250V16AAF
0404A0RQ
CAB-AC-Pwr-3m-PW3C450V
External AC power cable, 3m, 3*1.5mm^2, black, PW3C-16A450V, 227IEC53(RVV)3*1.5mm^2B, PI-16A250V-SM
0404A0RP
CAB-PDU Pwr-3m-PW3C450V
External AC PDU power cable, 3m, 3*1.5mm^2, black, PW3C-16A450V, 227IEC 53(RVV)3*1.5mm^2B, C20-16A250V
0404A0RL
CAB-HVDC Pwr-3m-336V
336V high voltage DC power cable, 3m, 3*1.5mm^2, black, PW3C-16A450V, 227IEC53(RVV)3*1.5mm^2B, 3*T1.5mm^2-8R+3*OT(2.5-6-0)!
0231A3RK
LSXM1BFP16A
16 fabric blank filler panel
0231A3RL
LSXM1BFP08A
08 fabric blank filler panel
0231A3RM
LSXM1BFP04A
04 fabric blank filler panel
Slide rails
0231A4EK
LSXM1BSR
1U bottom-support rails, 630mm-900mm
0231A0PL
LSTM2KSGD0
Slide rail accessories, 500mm-800mm
0231A2VL
LSVM1BSR10
H3C S9810 bottom support rails, 630mm-900mm
0231AE4C
LSXM1IMAA
H3C S12500CR interface module adapter
