H3C vAC1000 Virtual Access Controller Web-Based Configuration Guide(R5435P03)-6W100
HomeSupportWirelessvAC1000 Virtual Access ControllerConfigure & DeployUser ManualsH3C vAC1000 Virtual Access Controller Web-Based Configuration Guide(R5435P03)-6W100
02-Web interface
02-Web interface 263.13 KB
Using the Web interface
As shown in Figure 1, the Web interface contains the following areas:
Area
(1) Banner and auxiliary area
Contains the following items:
·     The H3C logo.
·     Device model.
·     Admin icon —Click this icon to select a language, change the login password, save the current settings, log out, display the roadmap, or use the scan to follow feature.
(2) Navigation tree
Organizes feature menus in a tree in system view or in network view.
(3) Content pane
Displays information and provides an area for you to configure features.
Depending on the content in this pane, the webpages include the following types:
·     Feature page—Contains functions or features that a feature module can provide (see "Using a feature page").
·     Table page—Displays entries in a table (see "Using a table page").
·     Configuration page—Contains parameters for you to configure a feature or function (see "Using a configuration page").
(4) Status area
Displays device status and statistics.
Figure 1 Web interface layout
2) Navigation tree (in system view or network view)
3) Content pane
4) Status area
Types of webpages
Webpages include feature, table, and configuration pages. This section provides basic information about these pages. For more information about using the icons and buttons on the pages, see "Icons and buttons."
As shown in Figure 2, a feature page contains information about a feature module, including its table entry statistics, features, and functions. From a feature page, you can configure features provided by a feature module.
Figure 2 Sample feature page
Using a table page
As shown in Figure 3, a table page displays entries in a table. To sort entries by a field in ascending or descending order, click the field. For example, click Interface to sort entries by interfaces.
Figure 3 Sample table page
As shown in Figure 4, one configuration page contains all parameters for a configuration task. If a parameter must be configured on another page, the configuration page typically provides a link. You do not need to navigate to the destination page.
For example, you must use an ACL when you configure a packet filter. If no ACLs are available when you perform the task, you can click the Add icon  to create an ACL. In this situation, you do not need to navigate to the ACL management page.
Figure 4 Sample configuration page
Icons and buttons
Table 1 describes icons and buttons you can use to configure and manage the device.
Table 1 Icons and buttons
Icon/button
Icon/button name
General icons
Refresh
Refresh statistics or information manually.
More
Display more contents.
Add
Add a new configuration entry.
Filter
Filter statistics or information by a specific field.
Help icons
Hint
Obtain help information for a function or parameter.
Note
Display notes for a function or service.
Counter icon
Counter
Identify the total number of table entries.
Navigation icon
Next
Access the lower-level page to display information or configure settings.
Status control icon
Status control
Control the enable status of the feature.
·     If ON is displayed, the feature is enabled. To disable the feature, click the button.
·     If OFF is displayed, the feature is disabled. To enable the feature, click the button.
Search icons
Search
Enter a search expression in the search box, and then click this icon to perform a basic search.
Advanced search
Click this icon, and then enter a combination of criteria to perform an advanced search.
Entry management icons
Refresh
Refresh table entries manually.
Add
·     Add a new entry.
·     Confirm the addition of an entry and continue to add an additional entry.
 or
Export
Export an entry.
Delete
Delete an entry.
This icon appears at the end of an entry when you hover your mouse cursor over the entry.
Modify
Modify an entry.
Bulk-delete
Delete all entries.
Details
Display detailed information for an entry.
Field selector
Select fields to be displayed.
Advanced settings icon
Advanced settings
Access the advanced setting page.
Quick configuration icon
Quick configuration
Guide you through the quick configuration of a service.
Performing basic tasks
This section describes the basic tasks that must be frequently performed when you configure or manage the device.
Saving the configuration
Typically, settings take effect immediately after you create them. However, the system does not automatically save the settings to the configuration file. They are lost when the device reboots.
To prevent settings from being lost, use one of the following methods to save the configuration:
·     Click the admin icon  in the upper right corner, and click Save.
·     Perform the following tasks to access the configuration management page:
a.     Click the system view tab at the bottom of the page.
b.     From the navigation tree, select System > Management.
c.     Click the Configuration tab.
d.     Click Save Running Configuration.
Displaying settings of a table entry
1.     Hover your mouse cursor over the entry.
2.     Click the Detail icon  at the end of the entry.
Rebooting the device
Reboot is required for some settings to take effect.
To reboot the device:
1.     Save the configuration.
2.     Click the system view tab at the bottom of the page.
3.     From the navigation tree, select System > Management.
4.     Click the Reboot tab.
5.     On the reboot page, click the reboot button.
