05-Network
HomeSupportConfigure & DeployH3C Firewall Products Comware 7 Web Configuration Guide-6W40205-Network
39-Wireless
39-Wireless 35.97 KB
Wireless
This help contains the following topics:
·     Introduction
¡     Wireless settings
¡     Wireless information
·     Configure wireless
¡     Create a wireless service
¡     Configure an AP
¡     Configure the client blacklist or whitelist
Introduction
The Wireless menu displays wireless device information and wireless client statistics and allows you to configure wireless settings.
You can view the following information on the Wireless Info page:
·     Wireless client statisticsDisplays the total client quantity and the number of clients for each radio mode. Radio modes include 802.11a, 802.11b, 802.11g, 802.11n (2.4 GHz), 802.11n (5GHz), and 802.11ac.
·     Wireless servicesDisplays summary information about wireless services, including SSID, VLAN interface, and the number of associated clients. You can click the Details button to view detailed information.
·     SNR distributionDisplays distribution of clients by SNR. A larger SNR value indicates a higher WLAN quality.
·     Rate distributionDisplays distribution of clients by transmission rate. A higher transmission rate indicates a higher WLAN quality.
·     Online clientsDisplays information about online clients, including MAC address, IP address, and SSID. To log off a client, click Log Off. To add a client to the blacklist, click Add to Blacklist.
Wireless settings
You can configure the following settings on the Wireless Settings page:
·     Wireless servicesCreate, edit, or delete wireless services and configure WLAN features such as SSID hidden, Layer 2 isolation, and local authentication.
·     APs—Configure the working frequencies and power modes for the AP.
·     Client blacklist and whitelistConfigure the client blacklist or whitelist to forbid specific clients to access the WLANs or allow only the specified clients to access the WLANs.
Configure wireless settings
1.     Select Networks > Wireless > Wireless Settings.
2.     In the Configure Wireless Service area, click Create.
3.     Configure wireless settings.
Table 1 Wireless service configuration items
Item
SSID
Enter the SSID.
VLAN interface
Select the VLAN interface.
Password
Specify the password for clients to access the WLAN.
SSID hidden
Select whether to enable the SSID hidden feature. With this feature enabled, a user must manually specify the SSID for a client to access the WLAN.
Layer 2 isolation
Select whether to enable Layer 2 isolation. With this feature enabled, clients cannot communicate with each other directly at Layer 2.
Local auth
Select whether to enable the AP to authenticate clients.
Portal server
Specify the IP address of the portal Web server for client authentication.
This field is available only when local authentication is enabled.
ISP domain
Specify the ISP domain to which clients accessing the WLAN belong.
4.     Click OK.
Configure an AP
1.     Select Network > Wireless > Wireless Settings.
2.     Configure AP settings.
Table 2 AP configuration items
Item
AP Name
Edit the AP name.
5 GHz state
Enable or disable the 5 GHz band.
5 GHz power mode
Select the 5 GHz power mode. Options include:
·     Power saveLow transmit power. This mode is applicable to scenarios that require a small coverage and low radiation.
·     NormalNormal transmit power.
·     StrongHigh transmit power. This mode is applicable to scenarios that require a large coverage but do not have high requirements on radiation.
2.4 GHz
Enable or disable the 2.4 GHz band.
2.4 GHz power mode
Select the 2.4 GHz power mode. Options include:
2.     In the Client Blacklist or Client Whitelist area, click Add.
3.     Enter a client MAC address.
4.     Click OK.
