- H3C UniServer R4900 G3 Hardware Options Installation and Replacement Videos-6W101
- 01-Install standard, ball-bearing, or short-distance slide rails
- 02-Install the server to a rack
- 03-Remove the server from a rack
- 04-Install and remove a cable management arm (CMA)
- 05-Replace a DIMM
- 06-Replace a processor
- 07-Replace a SAS&SATA drive
- 08-Replace an NVMe drive
- 09-Replace the system board
- 10-Replace the NVMe VROC module
- 11-Replace an NVMe SSD expander module
- 12-Replace an SD card
- 13-Replace the dual SD card extended module
- 14-Replace a SATA M.2 SSD
- 15-Replace a standard storage controller and the power fail safeguard module
- 16-Replace the Mezzanine storage controller and the power fail safeguard module
- 17-Replace the mLOM Ethernet adapter
- 18-Replace the PCIe Ethernet adapter
- 19-Replace a GPU
- 20-Replace a riser card
- 21-Remove the front drive backplane
- 22-Remove the rear drive backplane
- 23-Replace the 12LFF drive expander module
- 24-Replace the 25SFF drive expander module
- 25-Replace a fan
- 26-Replace a power supply
- 27-Connect a power cord
- 28-Replace the multifunctional rack mount ears
- 29-Replace an optical drive
- 30-Replace the chassis-open alarm module
- 31-Replace the system battery
31-Replace the system battery | 17.99 MB |
Watch online
