18-Network Management and Monitoring Configuration Guide
HomeSupportWirelessWBC Series Multiservice Access ControllersConfigure & DeployConfiguration GuidesH3C WBC Series Multservice Access Controllers Configuration Guides(E5448)-6W10018-Network Management and Monitoring Configuration Guide
12-UCC configuration
12-UCC configuration 187.87 KB
Configuring UCC
About UCC
Unified Communication and Collaboration (UCC) can identify packets of specific protocols and increase the priority of the packets accordingly to accelerate packet forwarding and improve user experience.
SIP-based UCC enables the device to identify SIP protocol packets from wireless clients and preferentially forward audio and video traffic for the wireless clients.
Skype for Business (Skype4B)-based UCC enables the device to analyze Skype4B packets from wireless clients and preferentially forward the audio, video, and application sharing traffic for the wireless clients.
Restrictions and guidelines: UCC configuration
UCC does not support analysis of encrypted SIP protocol packets or fragments.
UCC configuration tasks at a glance
To configure UCC, perform either of the following tasks:
·     Configuring SIP-based UCC
·     Configuring Skype4B-based UCC
·     Configuring UCC for an audio or video application
¡     Enabling UCC for an audio or video application
¡     Configuring priority marking for traffic from an audio or video application
2.     Create a UCC profile and enter its view.
ucc profile profile-name
3.     Enable SIP-based UCC in the UCC profile.
sip enable
By default, SIP-based UCC is disabled for a UCC profile.
4.     Return to system view.
5.     Enter service template view.
wlan service-template service-template-name
6.     Bind a UCC profile to the service template.
ucc-profile profile-name
By default, no UCC profile is bound to a service template.
2.     Enable the device to communicate with the Skype4B server and specify the port number.
skype4b listener { http-port http-port-num | https-port https-port-num ssl-policy ssl-policy-name }
Make sure the port numbers are different if you configure both HTTP and HTTPS services.
3.     Create a UCC profile and enter its view.
4.     Enable Skype4B-based UCC.
skype4b enable
By default, Skype4B-based UCC is disabled.
5.     (Optional.) Configure priority marking for Skype4B application sharing packets.
skype4b app-share remark { dscp dscp-value | dot1p dot1p-value }
6.     (Optional.) Configure priority marking for Skype4B video packets.
skype4b video remark { dscp dscp-value | dot1p dot1p-value }
By default, the DSCP value is 34 and the 802.1p priority is 4 for Skype4B video packets.
7.     (Optional.) Configure priority marking for Skype4B voice packets.
skype4b voice remark { dscp dscp-value | dot1p dot1p-value }
By default, the DSCP value is 46 and the 802.1p priority is 6 for Skype4B voice packets.
With UCC enabled for an audio or video application, the wireless service bound to the UCC profile will preferentially forward traffic from that application for wireless users that use the application to obtain higher-quality services.
This feature is available only in local forwarding mode.
3.     Enable UCC for an audio or video application.
application app-name enable
By default, UCC is disabled for audio and video applications.
5.     Create a service template and enter its view.
6.     Bind the service template to a UCC profile.
Priority marking marks the priority of uplink traffic for an audio or video application and sends the priority to other service modules for them to process the traffic as configured. For example, after the priority of packets from an audio or video application is notified to the EoSRv6 tunnel, the tunnel adds the priority to the packets for the uplink device to identify and forward the packets preferentially.
3.     Configure priority marking for traffic from an audio or video application.
application app-name flow-mark
By default, priority marking is not configured for traffic from audio and video applications.
4.     Create a service template and enter its view.
5.     Bind the service template to a UCC profile.
Display and maintenance commands for UCC
Display UCC profile information.
display ucc profile [ profile-name ]
Display UCC entries.
display ucc table
Clear UCC entries.
reset ucc table [ sip | skype4b ]
UCC configuration examples
Example: Configuring SIP-based UCC
As shown in Figure 1, the SIP server installed with third-party VoIP server software acts as both the SIP agent server and SIP registration server to manage SIP user registration and respond to user calls. Client 1 and Client 2 use the AC as their gateway, and they can call each other through the client software installed on them. Centralized forwarding is configured.
Configure UCC to optimize multimedia traffic between the clients.
Figure 1 Network diagram
1.     Assign IP addresses to interfaces, as shown in Figure 1. (Details not shown.)
2.     Verify that the APs can associate with the AC and the clients can obtain an IP address.
3.     Configure the SIP server:
Install third-party VoIP server software, and configure a username (telephone number) and password for the clients.
4.     Configure Client 1 and Client 2:
Install third-party VoIP client software, specify the IP address of the SIP server, username (telephone number), password, and other parameters.
5.     Configure the AC:
# Create UCC profile 1, and enable SIP-based UCC in the UCC profile.
[Sysname] ucc profile 1
[Sysname-ucc-profile-1] sip enable
[Sysname-ucc-profile-1] quit
# Bind the UCC profile to service template service1.
[Sysname] wlan service-template service1
[Sysname-wlan-st-service1] ucc-profile 1
[Sysname-wlan-st-service1] quit
# Bind the UCC profile to service template service2.
[Sysname] wlan service-template service2
[Sysname-wlan-st-service2] ucc-profile 1
[Sysname-wlan-st-service2] quit
# Place a call from Client 1 to Client 2. (Details not shown.)
# Execute the following command to verify that multimedia traffic has been forwarded from Client 1 to Client 2.
[Sysname] display ucc table
UCC tuple5 entry info:
  Source IP/port             : 172.16.1.10/11111
  Destination IP/port       : 172.16.2.10/22222
  Transport layer protocol : UDP
  Flow type                   : SIP
  Media type                  : Audio
  Lifetime                    : 280
Total tuple5 entries found : 1
Total tuple3 entries found : 0
Total entries found: 1
Example: Configuring Skype4B-based UCC
As shown in Figure 2, all network users use Skype4B for communication.
The Skype4B server (including front-end and back-end) manage user registration and calls, and the Dialog Listener listens for Skype dialogs on the AC. The two servers are deployed on the same physical server.
The SDN Manager obtains dialog information from the Dialog Listener and establishes an HTTP or HTTPs connection with the AC to issue dialog information.
The AC is the client traffic forwarder, and the switch is the gateway for the clients. The clients use Skype4B client software to place calls to each other.
Configure Skype4B-based UCC on the AC to optimize Skype4B traffic between the clients to provide high-quality Skype4B services.
Figure 2 Network diagram
Assign IP addresses to interfaces, and make sure the devices can reach each other.
Make sure the APs can associate with the AC and the clients can obtain an IP address.
Deploy the Skype4B server, Skype4B client, SDN Manager, and Dialog Listener.
# Enable the device to communicate with the Skype4B server and specify the port number as 5000. Make sure this port number is the same as the port number configured on the SDN Manager.
[Sysname] skype4b listener http-port 5000
# Create UCC profile 1, and enable Skype4B-based UCC.
[Sysname-ucc-profile-1] skype4b enable
# Mark DSCP priority 50 for Skype4B application sharing packets.
[Sysname-ucc-profile-1] skype4b app-share remark dscp 50
# Mark DSCP priority 50 for Skype4B voice packets.
[Sysname-ucc-profile-1] skype4b voice remark dscp 50
# Mark DSCP priority 50 for Skype4B video packets.
[Sysname-ucc-profile-1] skype4b video remark dscp 50
# Bind the UCC profile to VLAN-interface 1 (gateway of Client 1).
[Sysname-Vlan-interface1] ucc-profile 1
[Sysname-Vlan-interface1] quit
# Bind the UCC profile to VLAN-interface 2 (gateway of Client 2).
[Sysname-Vlan-interface2] ucc-profile 1
[Sysname-Vlan-interface2] quit
UCC tuple3 entry info:
  Client IP/port             : 172.16.1.10/11111
  Flow type                   : SKYPE4B
  Media type                  : Audio
  Lifetime                    : 62
  Client IP/port             : 172.16.2.10/22222
  Flow type                   : SKYPE4B
  Media type                  : Audio
  Lifetime                    : 76
Total tuple5 entries found : 0
Total tuple3 entries found : 2
Total entries found: 2
Example: Configuring Tencent Meeting application based UCC
As shown in Figure 3, wireless network uses local forwardingClient 1 and Client 2 access the company's network through wireless services. By using UCC, Tencent Meeting application between terminals is optimized.
Figure 3 Network diagram
# Create UCC profile 1, and enable Tencent Meeting application based UCC.
<AC> system-view
[AC] ucc profile 1
[AC-ucc-profile-1] application tencentmeeting enable
[AC-ucc-profile-1] quit
[AC] wlan service-template service1
[AC-wlan-st-service1] ucc-profile 1
# Configure APs to forward client data traffic
[AC-wlan-st-service1] client forwarding-location ap
[AC-wlan-st-service1] quit
[AC] wlan service-template service2
[AC-wlan-st-service2] ucc-profile 1
[AC-wlan-st-service2] client forwarding-location ap
[AC-wlan-st-service2] quit
