- 12-WLAN Advanced Features Command Reference
- 01-WLAN optimization commands
- 02-Hotspot 2.0 commands
- 03-WLAN probe commands
- 04-WSA commands
- 05-Wireless location commands
- 06-WLAN process maintenance commands
- 07-Bonjour gateway commands
- 08-WLAN mesh commands
- 09-AC hierarchy commands
- 10-WLAN forwarding commands
01-WLAN optimization commands | 198.10 KB |
option broadcast-multicast-buffer
option channel-reuse-optimization
option client hide-node-protection
option directional-antenna-selection
option non-local-packet rate-limit cir
option optimize-link-performance
option rx-opportunity-optimize
rrop arp ap-proxy-gateway enable
rrop traffic-policy priority tcp
rrop traffic-policy priority udp
rrop ul-arp attack-suppression enable
sacp roam-optimize traffic-hold enable
IMPORTANT: Use WLAN optimization commands under the guidance of H3C Support. |
option 4-way-handshake resend
Use option 4-way-handshake resend to set the maximum number of retransmissions for an EAPOL-Key packet and the retransmission interval.
Use undo option 4-way-handshake resend to restore the default.
option 4-way-handshake resend max-count [ interval interval ]
The maximum number of retransmissions for an EAPOL-Key packet is three, and the retransmission interval is 300 milliseconds.
Service template view
resend max-count: Specifies the maximum number of retransmissions for an EAPOL-Key packet, in the range of 0 to 3.
interval interval: Specifies the retransmission interval in the range of 200 to 500 milliseconds.
In Robust Security Network Association (RSNA) authentication, an AP and a client use EAPOL-Key packets in the four-way handshake to negotiate the keys. After that, the AP and the client periodically exchange EAPOL-Key packets to update the keys.
During key negotiation or update, the AP keeps retransmitting an EAPOL-Key packet until a response is received or the maximum number of retries for an EAPOL-Key packet is reached.
The system starts to count the retries when the maximum number of retransmissions is reached.
To ensure successful RSN key negotiation or update, you can increase the maximum number of retransmissions and the maximum number of retries for an EAPOL-Key packet.
For more information about RSN key negotiation or update, see "Configuring WLAN security."
# In service template view, set the maximum number of retransmissions for an EAPOL-Key packet to one and the retransmission interval to 400 milliseconds.
[Sysname] wlan service-template service1
[Sysname-wlan-st-svervice1] option 4-way-handshake resend 1 interval 400
option 4-way-handshake retry
Use option 4-way-handshake retry to set the maximum number of retries for an EAPOL-Key packet and the retry interval.
Use undo option 4-way-handshake retry to restore the default.
option 4-way-handshake retry max-count [ interval interval ]
The maximum number of retries for an EAPOL-Key packet is three, and the retry interval is 5 seconds.
retry max-count: Specifies the maximum number of retries for an EAPOL-Key packet, in the range of 0 to 3.
interval interval: Specifies the retry interval in the range of 2 to 5 seconds.
During RSN key negotiation or update, an AP keeps retransmitting an EAPOL-Key packet until a response is received or the maximum number of retries for an EAPOL-Key packet is reached.
If you execute this command for multiple times, the most recent configuration takes effect.
# In service template view, set the maximum number of retries for an EAPOL-Key packet to two and the retry interval to 3 seconds.
[Sysname-wlan-st-service1] option 4-way-handshake retry 2 interval 3
Use option broadcast-multicast-buffer enable to enable multicast and broadcast buffering.
Use option broadcast-multicast-buffer disable to disable multicast and broadcast buffering.
Use undo option broadcast-multicast-buffer to restore the default.
option broadcast-multicast-buffer { disable | enable [ limit limit ] }
In radio view, a radio uses the configuration in an AP group's radio view.
In an AP group's radio view, multicast and broadcast buffering is enabled.
Radio view
limit limit: Specifies the maximum number of multicast or broadcast packets that can be buffered. The value range for the limit argument is 1 to 600 and the default value is 100.
With this feature enabled, the AC stops sending broadcast and multicast packets and buffers them if an associated client is in sleep state. This mechanism affects the performance of real-time multicast applications.
With this feature disabled, the AC directly sends all broadcast and multicast packets regardless of whether an associated client is in sleep state.
# Disable multicast and broadcast buffering for AP ap1.
[Sysname] wlan ap ap1 model WA6320
[Sysname-wlan-ap-ap1] radio 1
[Sysname-wlan-ap-ap1-radio-1] option broadcast-multicast-buffer disable
# Disable multicast and broadcast buffering for APs with model WA6320 in AP group 1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] ap-model WA6320
[Sysname-wlan-ap-group-1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option broadcast-multicast-buffer disable
option capacity-adjust
Use option capacity-adjust enable to enable transmit power adjustment.
Use option capacity-adjust disable to disable transmit power adjustment.
Use undo capacity-adjust to restore the default.
option capacity-adjust { disable | enable [ all ] { increase | decrease } value }
undo option capacity-adjust
In an AP group's radio view, transmit power adjustment is disabled.
Radio view
all: Configures transmit power adjustment for all rates. If you do not specify this keyword, the command configures transmit power adjustment for mandatory rates.
increase: Increases the transmit power.
decrease: Decreases the transmit power.
value: Specifies the transmit power adjustment value in the range of 1 to 27 dBm.
This feature enables an AP to use the adjusted transmit power to transmit packets.
# Enable transmit power adjustment for AP ap1, and increase the transmit power by 1 dBm for all rates.
[Sysname-wlan-ap-ap1-radio-1] option capacity-adjust all increase 1
# Enable transmit power adjustment for APs with model WA6320 in AP group apgroup1, and increase the transmit power by 1 dBm for all rates.
[Sysname] wlan ap-group apgroup1
[Sysname-wlan-ap-group-apgroup1] ap-model WA6320
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option capacity-adjust all increase 1
Use option channel-reuse-optimization enable to enable channel reuse.
Use option channel-reuse-optimization disable to disable channel reuse.
Use undo option channel-reuse-optimization to restore the default.
option channel-reuse-optimization { disable | enable level level }
In an AP group's radio view, channel reuse is disabled.
Radio view
level level: Specifies the channel reuse level in the range of 1 to 10. The recommended channel reuse level is 6.
This feature enables an AP to ignore packets with a signal strength lower than the specified channel reuse level. This mechanism enables the AP to obtain more radio resources and improves the performance of APs working on the same channel.
# Enable channel reuse for AP ap1 and set the channel reuse level to 5.
[Sysname-wlan-ap-ap1-radio-1] option channel-reuse-optimization enable level 5
# Enable channel reuse for APs with model WA6320 in AP group 1 and set the channel reuse level to 5.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option channel-reuse-optimization enable level 5
option channel-share
Use option channel-share enable to enable channel sharing.
Use option channel-share disable to disable channel sharing.
Use undo channel-share to restore the default.
option channel-share { disable | enable power-level power-level }
undo channel-share
In an AP group's radio view, channel sharing is disabled.
Radio view
power-level power-level: Specifies the power level for channel sharing, in the range of 1 to 40. The recommended value is 30.
When this feature is enabled, an AP sends or does not send packets according to whether the detected signals are stronger or weaker than the specified power level. This mechanism avoids channel collision and interference.
# Enable channel sharing for AP ap1 and set the power level to 30.
[Sysname-wlan-ap-ap1-radio-1] option channel-share enable power-level 30
# Enable channel sharing for APs with model WA6320 in AP group apgroup1 and set the power level to 30.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option channel-share enable power-level 30
option client fast-forwarding
Use option client fast-forwarding enable to enable fast forwarding of AP-to-client data frames.
Use option client fast-forwarding disable to disable fast forwarding of AP-to-client data frames.
Use undo option client fast-forwarding to restore the default.
option client fast-forwarding { disable | enable level level-value }
In an AP group's radio view, fast forwarding of AP-to-client data frames is disabled.
Radio view
level level-value: Specifies the fast forwarding level in the range of 1 to 4.
This feature enables an AP to forward data frames to clients without extra processing (such as verification and counting) to improve processing efficiency.
# Enable fast forwarding of AP-to-client data frames for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option client fast-forwarding enable level 1
# Enable fast forwarding of AP-to-client data frames for APs with model WA6320 in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option client fast-forwarding enable level 1
Use option client hide-node-protection enable to enable hidden node protection.
Use option client hide-node-protection disable to disable hidden node protection.
Use undo option client hide-node-protection to restore the default.
option client hide-node-protection { disable | enable }
In an AP group's radio view, hidden node protection is disabled.
Radio view
This command takes effect only on 802.11g, 802.11n, and 802.11ac clients.
This feature enables clients to send RTS or CTS frames before transmitting frames to avoid interference from hidden nodes.
# Enable hidden node protection for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option client hide-node-protection enable
# Enable hidden node protection for APs with model WA6320 in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option client hide-node-protection enable
option client reconnect
Use option client reconnect enable to enable AP-triggered client reassociation.
Use option client reconnect disable to disable AP-triggered client reassociation.
Use undo option client reconnect to restore the default.
option client reconnect { disable | enable [ rssi rssi-value ] [ interval interval ] }
In an AP group's radio view, AP-triggered client reassociation is disabled.
Radio view
rssi rssi-value: Specifies the RSSI threshold in the range of 5 to 100. The default and recommended RSSI thresholds are 10 and 20, respectively.
interval interval: Specifies the interval at which an AP detects the signal strength of the clients. The value range for the interval argument is 3 to 10 seconds and the default interval is 3 seconds.
This feature enables an AP to send deauthentication frames to a client when the AP detects that the signal strength of the client is lower than the specified RSSI threshold. Then, the client can reassociate with the AP or roam to another AP.
# Enable AP-triggered client reassociation for AP ap1. Set the RSSI threshold and detection interval to 30 and 5 seconds, respectively.
[Sysname-wlan-ap-ap1-radio-1] option client reconnect enable rssi 30 interval 5
# Enable AP-triggered client reassociation for APs with model WA6320 in AP group 1. Set the RSSI threshold and detection interval to 30 and 5 seconds, respectively.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option client reconnect enable rssi 30 interval 5
option client reject
Use option client reject enable to enable an AP to reject weak-signal clients.
Use option client reject disable to disable an AP from rejecting weak-signal clients.
Use undo option client reject to restore the default.
option client reject { disable | enable [ rssi rssi-value ] }
In an AP group's radio view, a radio does not reject weak-signal clients.
Radio view
rssi rssi-value: Specifies the RSSI threshold in the range of 5 to 100. Both the default and recommended RSSI thresholds are 10.
This feature enables an AP to reject clients with an RSSI lower than the specified threshold to release channel resources and enhance WLAN performance.
After you enable this feature, wireless clients with an RSSI lower than the threshold might fail to access the WLAN.
After a client accesses the WLAN, an AP will not log off the client with an RSSI lower than the threshold but will reject the client after it disconnects from the network.
# Enable AP ap1 to reject clients with an RSSI lower than 30 dBm.
[Sysname-wlan-ap-ap1-radio-1] option client reject enable rssi 30
# Enable APs with model WA6320 in AP group 1 to reject clients with an RSSI lower than 30 dBm.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option client reject enable rssi 30
Use option directional-antenna-selection enable to enable dynamic directional antenna selection.
Use option directional-antenna-selection disable to disable dynamic directional antenna selection.
Use undo option directional-antenna-selection to restore the default.
option directional-antenna-selection { disable | enable }
In an AP group's radio view, dynamic directional antenna selection is disabled.
Radio view
This feature enables an AP to dynamically adjust its signal transmitting mode based on the signal transmitting mode and signal strength of the CPEs to improve user experience.
# Enable dynamic directional antenna selection for AP ap1.
[Sysname] wlan ap ap1 model WA2620X
[Sysname-wlan-ap-ap1-radio-1] option directional-antenna-selection enable
# Enable dynamic directional antenna selection for APs with model WA2620X in AP group 1.
[Sysname-wlan-ap-group-1] ap-model WA2620X
[Sysname-wlan-ap-group-1-ap-model-WA2620X] radio 1
[Sysname-wlan-ap-group-1-ap-model-WA2620X-radio-1] option directional-antenna-selection enable
option dot11n-restraint
Use option dot11n-restraint enable to enable 802.11n packet suppression.
Use option dot11n-restraint disable to disable 802.11n packet suppression.
Use undo dot11n-restraint to restore the default.
option dot11n-restraint { disable | enable packet-number packet-number packet-length packet-length } [ inbound | outbound ] [ tid tid-number ]
undo option dot11n-restraint
In an AP group's radio view, 802.11n packet suppression is disabled.
Radio view
packet-number packet-number: Specifies the maximum number of MPDUs that can be aggregated into an A-MPDU, in the range of 1 to 64. The recommended value is 8.
packet-length packet-length: Specifies the maximum A-MPDU length, in the range of 2000 to 380000 bytes. The recommended value is 6000.
inbound: Specifies 802.11n packet suppression in the inbound direction.
outbound: Specifies 802.11n packet suppression in the outbound direction.
tid tid-number: Specifies a traffic identifier, in the range of 0 to 7. The queue type varies by TID value.
· 0 and 3—AC-BE queue.
· 1 and 2—AC-BK queue.
· 4 and 5—AC-VI queue.
· 6 and 7—AC-VO queue.
If you do not specify this option, 802.11n packet suppression applies to all types of packets.
Perform this task to suppress 802.11n packets by defining the maximum number of aggregated MPDUs and the maximum A-MPDU length. The two thresholds take effect at the same time. If either threshold is reached, the AP stops aggregation and sends the A-MPDU.
# Enable 802.11n packet suppression for AP ap1. Set the maximum number of MPDUs that can be aggregated into an A-MPDU and the maximum A-MPDU length to 30 and 10000 bytes, respectively.
[Sysname-wlan-ap-ap1-radio-1] option dot11n-restraint enable packet-number 30 packer-length 10000
# Enable 802.11n packet suppression for APs with model WA6320 in AP group apgroup1. Set the maximum number of MPDUs that can be aggregated into an A-MPDU and the maximum A-MPDU length to 30 and 10000 bytes, respectively.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option dot11n-restraint enable packet-number 30 packer-length 10000
option immediate-transmit
Use option immediate-transmit enable to enable immediate packet sending.
Use option immediate-transmit disable to disable immediate packet sending.
Use undo immediate-transmit to restore the default.
option immediate-transmit { disable | enable }
In an AP group's radio view, immediate packet sending is disabled.
Radio view
When you enable this feature, APs do not detect channel collision before sending packets to save system resources and improve network throughput. Enabling this feature might cause hidden node problems. When you disable this feature, wireless devices send RTS/CTS packets to avoid channel collision.
# Disable immediate packet sending for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option immediate-transmit disable
# Disable immediate packet sending for APs with model WA6320 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option immediate-transmit disable
option keep-active
Use option keep-active enable to enable decreasing the sleep interval of wireless clients.
Use option keep-active disable to disable decreasing the sleep interval of wireless clients.
Use undo option keep-active to restore the default.
option keep-active { disable | enable }
In an AP group's radio view, decreasing the sleep interval of wireless clients is disabled.
Radio view
A wireless client in sleep state listens for traffic indication map (TIM) information in beacon frames to determine whether the associated AP has buffered packets for it. This feature enables an AP to modify the TIM information in beacon frames to decrease the sleep interval of wireless clients to improve transmission efficiency.
# Enable decreasing the sleep interval of wireless clients for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option keep-active enable
# Enable decreasing the sleep interval of wireless clients for APs with model WA6320 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option keep-active enable
option max-interfer-threshold
Use option max-interfer-threshold enable to set the maximum interference threshold.
Use option max-interfer-threshold disable to remove the configuration.
Use undo max-interfer-threshold to restore the default.
option max-interfer-threshold { disable | enable value }
In an AP group's radio view, the maximum interference threshold is not set.
Radio view
value: Specifies the maximum interference threshold in the range of 20 to 120 dBm. The recommended value is 50.
# Set the maximum interference threshold to 30 dBm for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option max-interfer-threshold enable 30
# Set the maximum interference threshold to 30 dBm for APs with model WA6320 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option max-interfer-threshold enable 30
Use option non-local-packet rate-limit cir to set a rate limit for packets destined to radios on other APs.
Use undo option non-local-packet rate-limit cir to restore the default.
option non-local-receive rate-limit cir cir
undo option non-local-receive rate-limit cir
No rate limit is set for packets destined to radios on other APs.
Radio view
cir cir: Specifies the CIR for packets destined to radios on other APs, in the range of 1 to 1300000 Kbps.
After you enable the scanning service (such as wireless probing, WLAN location, and WIPS) for an AP, a radio on the AP might receive packets destined to radios on a different AP than the radio. Such packets will increase the CPU usage and decrease the processing efficiency for packets destined to radios on the AP.
To address this issue, configure this command to set a rate limit for packets destined to radios on other APs.
# Set the CIR to 8 Kbps for packets destined to radios on other APs.
[Sysname-wlan-ap-ap1-radio-1] option non-local-packet rate-limit cir 8000
Use option optimize-link-performance { inbound | outbound } enable to enable link performance optimization.
Use option optimize-link-performance { inbound | outbound } disable to disable link performance optimization.
Use undo optimize-link-performance to restore the default.
option optimize-link-performance { inbound | outbound } { disable | enable } [ value ]
undo optimize-link-performance { inbound | outbound }
In an AP group's radio view, link performance optimization is disabled.
Radio view
inbound: Optimizes downlink performance.
outbound: Optimizes uplink performance.
value: Specifies the packet fragmentation threshold in the range of 0 to 2048 bytes.
# Enable uplink performance optimization for AP ap1 and set the packet fragmentation threshold to 100 bytes.
[Sysname-wlan-ap-ap1-radio-1] option optimize-link-performance outbound enable 100
# Enable uplink performance optimization for APs with model WA6320 in AP group apgroup1 and set the packet fragmentation threshold to 100 bytes.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option optimize-link-performance outbound enable 100
option power-supply
Use option power-supply enable to specify a power supply mode for an AP to adjust the transmit power.
Use option power-supply disable to disable this feature.
Use undo power-supply to restore the default.
option power-supply { disable | enable { local | poe | poeplus } }
undo power-supply
In an AP group's radio view, APs do not adjust the transmit power according to the power supply mode.
Radio view
local: Specifies the local power supply mode.
poe: Specifies the PoE power supply mode.
poeplus: Specifies the PoE+ power supply mode.
# Configure AP ap1 to use the transmit power corresponding to the PoE+ power supply mode.
[Sysname-wlan-ap-ap1-radio-1] option power-supply enable poeplus
# Configure APs with model WA6320 in AP group apgroup1 to use the transmit power corresponding to the PoE+ power supply mode.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option power-supply enable poeplus
option probe-response-try
Use option probe-response-try enable to set the maximum number of probe response attempts.
Use option probe-response-try disable to remove the configuration.
Use undo probe-response-try to restore the default.
option probe-response-try { disable | enable number }
In an AP group's radio view, the maximum number of probe response attempts is not limited.
Radio view
number: Specifies the maximum number of probe response attempts, in the range of 1 to 16.
Perform this task to reduce the number of probe responses sent by a radio to save resources and improve network performance.
# Set the maximum number of probe response attempts to 10 for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option probe-response-try enable 10
# Set the maximum number of probe response attempts to 10 for APs with model WA6320 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option probe-response-try enable 10
option rate-algorithm emr
IMPORTANT: This command might decrease the network throughput. |
Use option rate-algorithm emr enable to enable the EMR algorithm.
Use option rate-algorithm emr disable to disable the EMR algorithm.
Use undo option rate-algorithm emr to restore the default.
option rate-algorithm emr { disable | enable }
In an AP group's radio view, the EMR algorithm is disabled. A radio uses a rate that ensures the maximum throughput.
Radio view
This feature enables an AP to use the ensure minimum rate (EMR) algorithm to ensure the connection reliability.
# Enable the EMR algorithm for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option rate-algorithm emr enable
# Enable the EMR algorithm for APs with model WA6320 in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option rate-algorithm emr enable
option roam-navigation
Use option roam-navigation enable to enable roaming navigation.
Use option roam-navigation disable to disable roaming navigation.
Use undo option roam-navigation to restore the default.
option roam-navigation { disable | enable rssi rssi-value { beacon-power power-value | probe-response-power power-value } }
In an AP group's radio view, roaming navigation is disabled.
Radio view
rssi rssi-value: Specifies the RSSI threshold in the range of 1 to 50. The recommended RSSI threshold is 20.
beacon-power power-value: Specifies the transmit power for beacon frames, in the range of 1 to 30 dBm. The recommended transmit power is 10 dBm.
probe-response-power power-value: Specifies the transmit power for probe response frames, in the range of 1 to 30 dBm. The recommended transmit power is 10 dBm.
If you set the transmit power for beacons or probe responses, the system uses the default transmit power to transmit other packets.
# Enable roaming navigation for AP ap1. Set the RSSI threshold to 10 and the transmit power for beacon frames to 10 dBm.
[Sysname-wlan-ap-ap1-radio-1] option roam-navigation enable rssi 10 beacon-power 10
# Enable roaming navigation for APs with model WA6320 in AP group apgroup1. Set the RSSI threshold to 10 and the transmit power for probe response frames to 10 dBm.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option roam-navigation enable rssi 10 probe-response-power 10
option rx-broadcast-all
Use option rx-broadcast-all enable to enable an AP to receive all broadcast packets.
Use option rx-broadcast-all disable to disable an AP to receive all broadcast packets.
Use undo rx-broadcast-all to restore the default.
option rx-broadcast-all { disable | enable }
In an AP group's radio view, receiving all broadcast packets is disabled.
Radio view
The system detects spoofing attacks by listening for broadcast deauthentication and disassociation packets. Perform this task to enable an AP to receive all broadcasts so that the AP can detect spoofing attacks.
This feature is not applicable to 5 GHz radios of 802.11ac APs.
# Enable AP ap1 to receive all broadcast packets.
[Sysname-wlan-ap-ap1-radio-1] option rx-broadcast-all enable
# Enable APs with model WA6320 in AP group apgroup1 to receive all broadcast packets.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option rx-broadcast-all enable
Use option rx-opportunity-optimize enable to enable packet receiving timing adjustment.
Use option rx-opportunity-optimize disable to disable packet receiving timing adjustment.
Use undo option rx-opportunity-optimize to restore the default.
option rx-opportunity-optimize { disable | enable }
In an AP group's radio view, packet receiving timing adjustment is disabled.
Radio view
This feature enables an AP to adjust the timing for receiving packet to achieve the optimal receiving effect.
# Enable packet receiving timing adjustment for AP ap1.
[Sysname-wlan-ap-ap1-radio-1] option rx-opportunity-optimize enable
# Enable packet receiving timing adjustment for APs with model WA6320 in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option rx-opportunity-optimize enable
option signal-ignore
Use option signal-ignore enable to enable an AP to ignore weak signals.
Use option signal-ignore disable to disable an AP from ignoring weak signals.
Use undo option signal-ignore to restore the default.
option signal-ignore { disable | enable rssi rssi-value }
In an AP group's radio view, a radio does not ignore weak signals.
Radio view
rssi rssi-value: Specifies the RSSI threshold in the range of 1 to 30. The recommended RSSI threshold is 10.
This feature enables an AP to ignore packets with a signal strength lower than the specified RSSI threshold. Enabling this feature might cause collisions and interference among devices on the same channel.
# Enable AP ap1 to ignore weak signals and set the RSSI threshold to 10.
[Sysname-wlan-ap-ap1-radio-1] option signal-ignore enable rssi 10
# Enable APs with model WA6320 in AP group 1 to ignore weak signals and set the RSSI threshold to 10.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option signal-ignore enable rssi 10
option smart-chip-protection
Use option smart-chip-protection enable to enable smart chip protection.
Use option smart-chip-protection disable to disable smart chip protection.
Use undo option smart-chip-protection to restore the default.
option smart-chip-protection { disable | enable interval interval }
In an AP group's radio view, smart chip protection is disabled.
Radio view
interval interval: Specifies the interval at which smart chip protection is enabled, in the range of 1 to 24 hours.
# Enable smart chip protection for AP ap1 and set the enabling interval to 10 hours.
[Sysname-wlan-ap-ap1-radio-1] option smart-chip-protection enable interval 10
# Enable smart chip protection for APs with model WA6320 and set the enabling interval to 10 hours.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] option smart-chip-protection enable interval 10
option subway-band-width
Use option subway-band-width enable to enable the narrow bandwidth feature.
Use option subway-band-width disable to disable the narrow bandwidth feature.
Use undo subway-band-width to restore the default.
option subway-band-width { disable | enable { 5 | 10 } }
In an AP group's radio view, the narrow bandwidth feature is disabled.
Radio view
5: Configures the radio to operate in 5 MHz bandwidth mode.
10: Configures the radio to operate in 10 MHz bandwidth mode.
When the bandwidth decreases, the signal strength is improved, and the risks of signal interference are reduced.
# Enable the narrow bandwidth feature for AP ap1, and set the bandwidth to 5 MHz.
[Sysname-wlan-ap-ap1-radio-1] option subway-band-width enable 5
# Enable the narrow bandwidth feature for APs with model WA6320 in AP group apgroup1, and set the bandwidth to 5 MHz.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-1] option subway-band-width enable 5
option tpc
Use option tpc enable to enable per-packet transmit power control.
Use option tpc disable to disable per-packet transmit power control.
Use undo option tpc to restore the default.
option tpc { disable | enable [ minpower minpower | powerstep powerstep | rssistep rssistep | rssithreshold rssithreshold ] }
undo option tpc
In an AP group's radio view, per-packet transmit power control is disabled.
Radio view
minpower minpower: Specifies the minimum transmit power in the range of 1 to 27. The default value is 10.
powerstep powerstep: Specifies the step value for transmit power decrease, in the range of 1 to 15. The default value is 5.
rssistep rssistep: Specifies the step value for RSSI adjustment, in the range of 1 to 20. The default value is 10.
rssithreshold rssithreshold: Specifies the RSSI threshold for per-packet transmit power control, in the range of 20 to 95. The default value is 65.
This feature enables an AP to dynamically perform transmit power control on a per packet basis. For example, the AP reduces the transmit power when it sends packets to a client with high RSSI. This feature can reduce power consumption, radiation, and interference to improve user experience.
# Enable per-packet transmit power control for AP ap1, and set the minimum transmit power to 20.
[Sysname-wlan-ap-ap1] radio 2
[Sysname-wlan-ap-ap1-radio-2] option tpc enable minpower 20
# Enable per-packet transmit power control for APs with model WA6320 in AP group apgroup1, and set the minimum transmit power to 20.
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320] radio 2
[Sysname-wlan-ap-group-apgroup1-ap-model-WA6320-radio-2] option tpc enable minpower 20
option x-share quiet
Use option x-share quiet enable to enable the quiet mode.
Use option x-share quiet disable to disable the quiet mode.
Use undo option x-share quiet to restore the default.
option x-share quiet { disable | enable }
In an AP group's radio view, the quiet mode is disabled.
Radio view
This feature is applicable only to X-share APs. When you enable the quiet mode for an X-share AP, the AP sends every packet by using only one antenna to save resources and reduce radiation.
# Enable the quiet mode for AP ap1.
[Sysname] wlan ap ap1 model WA4320i-X
[Sysname-wlan-ap-ap1-radio-1] option x-share quiet enable
# Enable the quiet mode for APs with model WA4320i-X in AP group apgroup1.
[Sysname-wlan-ap-group-apgroup1] ap-model WA4320i-X
[Sysname-wlan-ap-group-apgroup1-ap-model-WA4320i-X] radio 1
[Sysname-wlan-ap-group-apgroup1-ap-model- WA4320i-X-radio-1] option x-share quiet enable
rrop anti-bmc default-action
Use rrop anti-bmc default-action permit to configure an AP to forward broadcast and multicast packets through radio interfaces.
Use rrop anti-bmc default-action deny to configure an AP to discard broadcast and multicast packets.
Use undo rrop anti-bmc default-action to restore the default.
rrop anti-bmc default-action { deny | permit }
In AP view, an AP uses the configuration in AP group view.
In AP group view, an AP forwards broadcast and multicast packets through radio interfaces.
AP view
AP group view
After you configure the rrop anti-bmc default-action permit command, an AP processes broadcast and multicast packets as follows:
· If basic broadcast and multicast packet control is enabled for the AP, it answers ARP requests, discard DHCP requests, and forwards other broadcast and multicast packets through radio interfaces.
· If basic broadcast and multicast packet control is disabled for the AP, it forwards all broadcast and multicast packets through radio interfaces.
This command is applicable only when software forwarding is used.
# Configure AP ap1 to discard broadcast and multicast packets.
[Sysname-wlan-ap-ap1] rrop anti-bmc default-action deny
# Configure APs in AP group 10 to discard broadcast and multicast packets.
[Sysname] wlan ap-group 10
[Sysname-ap-group10] rrop anti-bmc default-action deny
rrop anti-bmc network
Use rrop anti-bmc network enable to enable basic broadcast and multicast packet control in a network.
Use rrop anti-bmc network disable to disable basic broadcast and multicast packet control in a network.
Use undo rrop anti-bmc network to restore the default.
rrop anti-bmc network { disable | { ipv4-simple | ipv6-simple | ipv4-and-ipv6-simple } enable }
In AP group view, basic broadcast and multicast packet control is enabled for an IPv4 network.
AP view
AP group view
ipv4-simple: Enables basic broadcast and multicast packet control for the IPv4 network.
ipv6-simple: Enables basic broadcast and multicast packet control for the IPv6 network.
ipv4-and-ipv6-simple: Enables basic broadcast and multicast packet control for both the IPv4 and IPv6 networks.
To save radio resources and improve the forwarding performance, perform the following tasks:
· Configure APs not to forward broadcast or multicast packets through radio interfaces.
· Enable basic broadcast and multicast packet control in an IPv4 network. Then, APs reply to ARP broadcast packets, discard DHCP broadcast packets, and process other packets normally.
· Enable basic broadcast and multicast packet control in an IPv6 network. Then, APs discard RS and DHCPv6 broadcast packets, perform unicast forwarding on RA packets, reply to NS packets, and process other packets normally.
# Enable basic broadcast and multicast packet control for AP ap1 in an IPv4 network.
[Sysname-wlan-ap-ap1] rrop anti-bmc network ipv4-simple enable
# Enable basic broadcast and multicast packet control for APs in AP group group1 in an IPv4 network.
[Sysname] wlan ap-group group1
[Sysname-ap-group-group1] rrop anti-bmc network ipv4-simple enable
rrop anti-bmc protocol ipv6
Use rrop anti-bmc protocol ipv6 continue to configure an AP to take the default action specified by the rrop anti-bmc default-action command on IPv6 multicast packets.
Use rrop anti-bmc protocol ipv6 deny to configure an AP to discard IPv6 multicast packets.
Use undo rrop anti-bmc protocol ipv6 to restore the default.
rrop anti-bmc protocol ipv6 { continue | deny }
In AP group view, an AP takes the default action specified by the rrop anti-bmc default-action command on IPv6 multicast packets.
AP view
AP group view
# Configure AP ap1 to discard IPv6 multicast packets.
[Sysname-wlan-ap-ap1] rrop anti-bmc protocol ipv6 deny
# Configure APs in AP group group1 to discard IPv6 multicast packets.
[Sysname-ap-group-group1] rrop anti-bmc protocol ipv6 deny
rrop anti-bmc rate-limit
Use rrop anti-bmc rate-limit enable to enable broadcast or multicast packet rate limiting.
Use rrop anti-bmc rate-limit disable to disable broadcast or multicast packet rate limiting.
Use undo rrop anti-bmc rate-limit to restore the default.
rrop anti-bmc { broadcast | multicast } rate-limit { disable | enable }
undo rrop anti-bmc { broadcast | multicast } rate-limit
In AP group view, broadcast or multicast packet rate limiting is disabled.
AP view
AP group view
broadcast: Specifies broadcast packets.
multicast: Specifies multicast packets.
# Enable broadcast packet rate limiting for AP ap1.
[Sysname-wlan-ap-ap1] rrop anti-bmc broadcast rate-limit enable
# Enable broadcast packet rate limiting for APs in AP group group1.
[Sysname-ap-group-group1] rrop anti-bmc broadcast rate-limit enable
rrop anti-bmc rate-limit pps
Use rrop anti-bmc rate-limit pps to set the maximum number of broadcast or multicast packets that an AP can send per second.
Use undo rrop anti-bmc rate-limit pps to restore the default.
rrop anti-bmc { broadcast | multicast } rate-limit pps max-pps
undo rrop anti-bmc { broadcast | multicast } rate-limit pps
In AP group view, the maximum number of broadcast or multicast packets that an AP can send per second is not specified.
AP view
AP group view
pps max-pps: Specifies the maximum number of broadcast or multicast packets that an AP can send per second, in the range of 1 to 1410000. The AP discards the broadcast or multicast packets exceeding the specified limit.
This command takes effect only after you enable packet rate limiting.
# Configure AP ap1 to send a maximum number of 1024 broadcast packets per second.
[Sysname-wlan-ap-ap1] rrop anti-bmc broadcast rate-limit pps 1024
# Configure an AP in AP group group1 to send a maximum number of 1024 broadcast packets per second.
[Sysname-ap-group-group1] rrop anti-bmc broadcast rate-limit pps 1024
Use rrop arp ap-proxy-gateway enable to enable the AP to reply to ARP requests of clients on behalf of the gateway.
Use undo rrop arp ap-proxy-gateway enable to disable the AP from replying to ARP requests of clients on behalf of the gateway.
rrop arp ap-proxy-gateway enable [ count count ]
The AP does not reply to ARP requests of clients on behalf of the gateway.
count count: Specifies the maximum number of ARP requests that the AP can reply to on behalf of the gateway in a reply period. The value range for the count argument is 1 to 4096, and the default value is 10.
Perform this task to enable the AP to reply to ARP requests of clients on behalf of the gateway. If the MAC address of the gateway changes during a reply period, ARP failures might occur. To resolve this issue, you can specify a limit for the number of ARP requests that the AP can reply to on behalf of the gateway in a reply period. When the number of ARP requests that the AP has replied to reaches the limit, the AP will forward an ARP request to the gateway and perform either of the following tasks:
· If the gateway replies to the ARP request, the AP starts a new reply period with the new MAC address of the gateway.
· If the gateway does not reply to the ARP request, the AP starts a new reply period with the original MAC address of the gateway.
As a best practice to reduce the gateway's service load, enable this feature when the gateway's service load is heavy or the network condition is poor.
# Enable the AP to reply to ARP requests of clients on behalf of the gateway.
[Sysname] rrop arp ap-proxy-gataway enable
rrop client fast-keep-alive
Use rrop client fast-keep-alive enable to enable client fast keepalive.
Use rrop client fast-keep-alive disable to disable client fast keepalive.
Use undo rrop client fast-keep-alive to restore the default.
rrop client fast-keep-alive { disable | enable [ count count-value ] }
In radio view, a radio uses the configuration in the AP group's radio view.
In an AP group's radio view, the client fast keepalive feature is enabled.
Radio view
count count-value: Specifies the maximum number of keepalive packets that an AP can send to a client, in the range of 128 to 2048. The default value is 450.
To quickly determine whether clients are online and save radio resources, execute this command to set the maximum number of keepalive packets that an AP can send to a client. The AP logs off a client if it does not receive any replies from the client after sending the specified number of keepalive packets to the client.
This command is mainly used in scenarios with high client mobility. If the network quality is poor, reduce the maximum number of keepalive packets that an AP can send to a client. As a best practice, use the default setting in scenarios with stable clients.
The configuration in radio view takes precedence over the configuration in an AP group's radio view.
# Enable client fast keepalive for AP ap1 and set the maximum number of keepalive packets to 300.
[Sysname-wlan-ap-ap1-radio-1] rrop client fast-keep-alive enable count 300
# Enable client fast keepalive for APs with model WA6320 in AP group group1 and set the maximum number of keepalive packets to 300.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] rrop client fast-keep-alive enable count 300
client keep-alive
rrop software-retry
Use rrop software-retry enable to enable software retransmission and set the maximum number of software retransmissions.
Use rrop software-retry disable to disable software retransmission.
Use undo rrop software-retry to restore the default.
rrop software-retry { unicast [ eap ] | broadcast-multicast } enable count count
rrop software-retry { unicast [ eap ] | broadcast-multicast } disable
undo rrop software-retry { unicast [ eap ] | broadcast-multicast }
In an AP group's radio view, the maximum number of software retransmissions varies by device model.
Radio view
unicast: Configures software retransmission for unicast packets.
eap: Configures software retransmission for EAP packets.
broadcast-multicast: Configures software retransmission for broadcast and multicast packets.
count count: Specifies the maximum number of software retransmissions, in the range of 0 to 16.
# Set the maximum number of software retransmissions for EAP packets to the default for radio 1 of AP ap1.
[Sysname-wlan-ap-ap1-radio-1] undo rrop software-retry unicast eap
# Set the maximum number of software retransmissions for broadcast and multicast packets to the default for radio 1 of APs with model WA6320 in AP group 1.
[Sysname-wlan-ap-group-1-ap-model-WA6320-radio-1] undo rrop software-retry broadcast-multicast
Use rrop traffic-policy priority tcp to specify a DSCP value for TCP packets with the specified port numbers.
Use undo rrop traffic-policy priority tcp to delete the DSCP value for TCP packets with the specified port numbers.
rrop traffic-policy priority tcp port-num-list dscp value
undo rrop traffic-policy priority tcp { port-num-list | all }
In AP group view, no DSCP value is specified for TCP packets.
AP view
AP group view
port-num-list: Specifies a list of up to 10 TCP ports. The port number range is 1 to 65535.
dscp value: Specifies a DSCP value in the range of 0 to 63.
all: Deletes all the DSCP values specified for TCP packets.
A greater DSCP value represents a higher packet priority.
This command takes effect only on downstream packets.
If you execute this command with the same DSCP value multiple times, you can specify the DSCP value for up to 10 TCP ports.
If you execute this command with different DSCP values multiple times, the most recent configuration takes effect.
# Configure AP ap1 to use 50 as the DSCP value for TCP packets with port numbers 8001 and 8002.
[Sysname-wlan-ap-ap1] rrop traffic-policy priority tcp 8001 8002 dscp 50
# Configure APs in AP group 1 to use 50 as the DSCP value for TCP packets with port numbers 8001 and 8002.
[Sysname-wlan-ap-group-group1] rrop traffic-policy priority tcp 8001 8002 dscp 50
Use rrop traffic-policy priority udp to specify a DSCP value for UDP packets with the specified port numbers.
Use undo rrop traffic-policy priority udp tcp to delete the DSCP value for UDP packets with the specified port numbers.
rrop traffic-policy priority udp port-num-list dscp value
undo rrop traffic-policy priority udp { port-num-list | all }
In AP group view, no DSCP value is specified for UDP packets.
AP view
AP group view
port-num-list: Specifies a list of up to 10 UDP ports. The port number range is 1 to 65535.
all: Deletes all the DSCP values specified for UDP packets.
If you execute this command with the same DSCP value multiple times, you can specify the DSCP value for up to 10 UDP ports.
# Configure AP ap1 to use 50 as the DSCP value for UDP packets with port numbers 8001 and 8002.
[Sysname-wlan-ap-ap1] rrop traffic-policy priority udp 8001 8002 dscp 50
# Configure APs in AP group 1 to use 50 as the DSCP value for UDP packets with port numbers 8001 and 8002.
[Sysname-wlan-ap-group-group1] rrop traffic-policy priority udp 8001 8002 dscp 50
Use rrop ul-arp attack-suppression enable to enable upstream ARP packet suppression.
Use undo rrop ul-arp attack-suppression enable to disable upstream ARP packet suppression.
rrop ul-arp attack-suppression enable [ threshold threshold-value ] [ block-time time ]
Upstream ARP packet suppression is disabled.
threshold threshold-value: Specifies the threshold for triggering upstream ARP packet suppression. If the number of ARP packets that an AP receives from a client in one second reaches the threshold, the AP discards all ARP packets from the client within the specified suppression period. The value range for the threshold-value argument is 2 to 4096, and the default value is 10.
block-time time: Specify the upstream ARP packet suppression period in the range of 10 to 6000 seconds. The default suppression period is 60 seconds.
Execute this command to protect APs against ARP flooding attacks. If the number of ARP packets that a client sends to an AP in one second reaches the specified threshold, the AP discards all ARP packets from the client within the specified time period.
This command does not take effect on ARP requests for the gateway.
# Enable upstream ARP packet suppression.
[Sysname] rrop ul-arp attack-suppression enable
Use sacp roam-optimize traffic-hold enable to enable data transmission holding during roaming.
Use undo sacp roam-optimize traffic-hold enable to disable data transmission holding during roaming.
Data transmission holding during roaming is disabled.
With data transmission holding during roaming enabled, the device caches the packets during client roaming and sends the packets to the client after the client roams successfully to reduce the packet loss during client roaming. With data transmission holding during roaming disabled, the device ages out the cached packets after a period of time and will not send the packets to the client. As a best practice, enable this feature in a scenario that is sensitive to packet loss.
To make this feature take effect, enable client association at the AC and enable the AC to forward client data traffic.
This feature is not supported in an AC hierarchy network or inter-AC roaming network.
# Enable data transmission holding during roaming.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] sacp roam-optimize traffic-hold enable
wlan client inspect
Use wlan client inspect enable to enable client inspection.
Use wlan client inspect disable to disable client inspection.
Use undo wlan client inspect to restore the default.
wlan client inspect { disable | enable }
In AP group view, client inspection is disabled.
AP view
AP group view
The client inspection feature enables you to view information about packets exchanged and time consumed in each stage of the client association process.
In the current software version, the client inspection feature supports only client association, client association failure, and IP address lease extension events.
# Enable client inspection for AP ap1.
[Sysname-wlan-ap-ap1] wlan client inspect enable
# Enable client inspection for APs in AP group group1.
[Sysname-ap-group-group1] wlan client inspect enable
