08-Radio Resources Management
HomeSupportReference GuidesCommand ReferencesH3C Access Points Cloud Mode Command References(E2442 R2442)-6W10008-Radio Resources Management
01-Radio management commands
01-Radio management commands 195.61 KB
The following compatibility matrix shows the support of hardware platforms for radio management:
Hardware series
Model
Radios
Supported protocols
WA6600 series
WA6638
·     Radio 1: 5 GHz
·     Radio 2: 5 GHz
·     Radio 3: 2.4 GHz
802.11a/b/g/n/ac/ax/gax
WA6638i
·     Radio 1: 5 GHz
·     Radio 2: 5 GHz
·     Radio 3: 2.4 GHz
WA6636
·     Radio 1: 5 GHz
·     Radio 2: 5 GHz
·     Radio 3: 2.4 GHz
WA6630X
·     Radio 1: 5 GHz
·     Radio 2: 5 GHz
·     Radio 3: 2.4 GHz
WA6628
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6628X
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6628E-T
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6622
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6620
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz/5 GHz
WA6620X
·     Radio 1: 5 GHz
WA6300 series
WA6338
·     Radio 1: 5 GHz
·     Radio 2: 5 GHz
·     Radio 3: 2.4 GHz/5 GHz
WA6338-HI
·     Radio 1: 5 GHz
·     Radio 2: 5 GHz
WA6338-LI
·     Radio 1: 5 GHz
·     Radio 2: 5 GHz
WA6330
·     Radio 1: 5 GHz
802.11a/b/g/n/ac/gac/ax/gax
WA6330-LI
·     Radio 1: 5 GHz
WA6322
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6322H
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6322H-HI
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6322H-LI
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6320
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6320-C
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6320-D
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6320-SI
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6320H
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6320H-LI
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WA6320H-XEPON
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WAP922 series
WAP922E
·     Radio 1: 5 GHz
·     Radio 2: 2.4 GHz
WAP923 series
WAP923
·     Radio 1: 5 GHz
a-mpdu
Use a-mpdu enable to enable the A-MPDU aggregation method.
Use a-mpdu disable to disable the A-MPDU aggregation method.
Use undo a-mpdu to restore the default.
a-mpdu { disable | enable }
undo a-mpdu
The A-MPDU aggregation method is enabled.
Radio interface view
This command is applicable only to 802.11n, 802.11ac, 802.11gac, 802.11ax, and 802.11gax radios. Changing the radio mode to 802.11a, 802.11b, or 802.11g invalidates the command.
# Disable the A-MPDU aggregation method.
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio1/0/1] type dot11an
[Sysname-WLAN-Radio1/0/1] a-mpdu disable
a-msdu
Use a-msdu enable to enable the A-MSDU aggregation method.
Use a-msdu disable to disable the A-MSDU aggregation method.
Use undo a-msdu to restore the default.
a-msdu { disable | enable }
undo a-msdu
The A-MSDU aggregation method is enabled.
The device can receive but cannot send A-MSDUs.
# Disable the A-MSDU aggregation method.
[Sysname-WLAN-Radio1/0/1] a-msdu disable
antenna type
Use antenna type to set the antenna type for an AP.
Use undo antenna type to restore the default.
antenna type antenna-type
undo antenna type
The antenna type is internal.
antenna-type: Specifies an antenna type, a string of 1 to 10 characters.
Perform this task to set the antenna type for an AP. The command supports H3C antennas and third-party antennas.
The antenna type setting for an AP must be consistent with the type of the antenna used on the AP.
To ensure that the Effective Isotropic Radiated Power (EIRP) is within the correct range, the antenna gain automatically changes after you set the antenna type.
# Set the antenna type to internal.
[Sysname-WLAN-Radio1/0/1] antenna type internal
beacon-interval
Use beacon-interval to set the beacon interval.
Use undo beacon-interval to restore the default.
beacon-interval interval
The beacon interval is 100 TUs.
interval: Specifies the beacon interval in the range of 32 to 8191 TUs.
# Set the beacon interval to 1000 TUs.
[Sysname-WLAN-Radio1/0/1] beacon-interval 1000
channel
Use channel to specify a working channel for a radio interface.
Use undo channel to restore the default.
channel { channel-number | auto }
undo channel
The AP automatically selects a working channel for a radio interface.
channel-number: Specifies a channel by its number. The value range for this argument varies by country code and radio mode.
auto: Configures the AP to automatically select a channel.
When radar signals are detected on the working channel of a radio, the AP changes its channel, and switches back to the specified channel after 30 minutes. Then the AP starts the quiet timer. If no radar signals are detected within the quiet time, the AP starts to use the channel. If radar signals are detected within the quiet time, the AP changes its channel.
If you manually specify a channel in the range of 36 to 64, whether the 5.1 GHz band can be used outdoors depends on the device region.
·     For outdoor devices that use the 5150 to 5250 Hz band:
¡     China—Not supported.
¡     EU—Not supported.
¡     US—Supported if the maximum effective isotropic radiated power (EIRP) at any elevation angle above 30 degrees does not exceed 125mW and you are to deploy 1000 or fewer devices at a time. To install over 1000 devices at one deployment, contact Federal Communications Commission (FCC) and reduce the total transmit power.
¡     Canada—Not supported.
·     For outdoor devices that use the 5250 to 5350 Hz band:
¡     EU—Not supported.
¡     US—Supported if Depth First Search (DFS) is used.
¡     Canada—Supported if Depth First Search (DFS) is used.
# Specify channel 6 as the working channel.
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] channel 6
channel auto-select
Use channel auto-select to configure the channel selection blacklist or whitelist.
Use undo channel auto-select to remove the specified channels from the channel selection blacklist or whitelist.
channel auto-select { blacklist | whitelist } channel-number
undo channel auto-select { blacklist | whitelist } { all | channel-number }
No channel selection blacklist or whitelist exists.
blacklist: Adds channels to the channel selection blacklist. An AP will not select channels in the blacklist.
whitelist: Adds channels to the channel selection whitelist. An AP will only select channels in the whitelist.
channel-number: Specifies channels by their channel numbers. The value range for this argument varies by country code and radio mode.
all: Specifies all channels in the channel selection blacklist or whitelist.
You cannot configure both the channel selection blacklist and whitelist for the same AP.
This command takes effect only on APs operating in auto channel selection mode.
# Add channels 48, 52, and 56 to the channel selection whitelist.
[Sysname-WLAN-Radio1/0/1] channel auto-select whitelist 48 52 56
channel
channel band-width
Use channel band-width to set the bandwidth mode.
Use undo channel band-width to restore the default.
channel band-width { 20 | 40 [ auto-switch ] | 80 | 160 }
The bandwidth mode is 80 MHz for 802.11ax radios, 20 MHz for 802.11gax radios, 80 MHz for 802.11ac radios, 20 MHz for 802.11gac radios, 40 MHz for 802.11an radios, and 20 MHz for 802.11gn radios.
20: Sets the bandwidth mode to 20 MHz.
40: Sets the bandwidth mode to 40 MHz.
80: Sets the bandwidth mode to 80 MHz.
auto-switch: Allows a radio to switch its bandwidth mode between 20 MHz and 40 MHz. This keyword is applicable only to 802.11gn and 802.11gac radios.
160: Sets the bandwidth mode to 160 MHz. Support for this keyword depends on the AP model.
This command is applicable only to 802.11n, 802.11ac, 802.11gac, 802.11ax, and 802.11gax radios. When you change the mode of a radio, the default setting of this command for the new radio mode is restored.
The radio uses the specified 40/80/160 MHz bandwidth if adjacent channels can be bound to form a 40/80/160 channel. If adjacent channels cannot form a 40/80/160 channel, the radio uses the next available bandwidth less than the specified one.
For example, the bandwidth mode is set to 80 MHz. The radio uses the 80 MHz bandwidth if adjacent channels that can be bound together exist. If adjacent channels that can be bound to an 80 MHz channel do not exist, but two adjacent channels that can be bound to a 40 MHz channel exist, the 40 MHz bandwidth is used. If no adjacent channels that can be bound together exist, the radio uses the 20 MHz bandwidth.
# Set the bandwidth mode to 40 MHz.
[Sysname-WLAN-Radio1/0/1] channel band-width 40
channel
channel-usage measure
Use channel-usage measure to perform on-demand channel usage measurement.
This feature enables an AP to scan supported channels and display the channel usage after measurement. The measurement of each channel takes about one second.
# Perform on-demand channel usage measurement on radio interface 2.
[Sysname] interface WLAN-Radio 1/0/2
[Sysname-WLAN-Radio1/0/2] channel-usage measure
Please wait..............Done.
Channel  Usage
1        23%
2        34%
3        26%
4        36%
5        42%
6        39%
7        27%
8        45%
9        29%
10       38%
11       46%
12       30%
13       33%
client dot11ac-only
Use client dot11ac-only enable to enable the client dot11ac-only feature.
Use client dot11ac-only disable to disable the client dot11ac-only feature.
Use undo client dot11ac-only to restore the default.
client dot11ac-only { disable | enable }
The client dot11ac-only feature is disabled.
This command is applicable only to 802.11ac, 802.11gac, 802.11ax, and 802.11gax radios. Changing the radio mode invalidates the command.
After you configure this command for a radio, the radio accepts only 802.11ac and 802.11ax clients, and all non-802.11ac and non-802.11ax clients that are associated with the radio are logged off.
# Enable the client dot11ac-only feature.
[Sysname-wlan-radio-1/0/1] client dot11ac-only enable
dot11ac mandatory maximum-nss
client dot11ax-only
Use client dot11ax-only enable to enable the client dot11ax-only feature.
Use client dot11ax-only disable to disable the client dot11ax-only feature.
Use undo client dot11ax-only to restore the default.
client dot11ax-only { disable | enable }
The client dot11ax-only feature is disabled.
This command is applicable only to 802.11ax and 802.11gax radios. Changing the radio mode invalidates the command.
After you configure this command for a radio, the radio accepts only 802.11ax clients, and all non-802.11ax clients that are associated with the radio are logged off.
# Enable the client dot11ax-only feature.
[Sysname-wlan-radio-1/0/1] client dot11ax-only enable
client dot11b-forbidden
Use client dot11b-forbidden enable to disable access services for 802.11b clients.
Use client dot11b-forbidden disable to enable access services for 802.11b clients.
Use undo client dot11b-forbidden to restore the default.
client dot11b-forbidden { disable | enable }
Access services for 802.11b clients are enabled.
Enabling an 802.11b, 802.11g, 802.11gac, 802.11gax, or 802.11gn radio to reject 802.11b clients reduces the impact of low-speed 802.11b clients and speeds up wireless data transmission.
# Configure WLAN-radio 1/0/2 to reject 802.11b clients.
[Sysname-wlan-radio-1/0/2] client dot11b-forbidden enable
client dot11n-only
Use client dot11n-only enable to enable the client dot11n-only feature.
Use client dot11n-only disable to disable the client dot11n-only feature.
Use undo client dot11n-only to restore the default.
client dot11n-only { disable | enable }
The client dot11n-only feature is disabled.
After you configure this command on a radio, the radio accepts only the 802.11n, 802.11ac, and 802.11ax clients, and all 802.11a/b/g clients that are associated with the radio are logged off.
# Enable the client dot11n-only feature.
[Sysname-WLAN-Radio1/0/1] client dot11n-only enable
client max-count
Use client max-count to set the maximum number of clients that can associate with an AP.
Use undo client max-count to restore the default.
client max-count max-number
No limit is set for the number of clients that can associate with an AP.
max-number: Specifies the maximum number of clients that can associate with an AP
When the maximum number of clients is reached on an AP, the AP stops accepting new clients and hides its SSIDs.
# Set the maximum number of clients that can associate with an AP to 38.
[Sysname-WLAN-Radio1/0/1] client max-count 38
client association-location
continuous-mode
Use continuous-mode to enable the continuous mode for a radio.
Use undo continuous-mode to restore the default.
continuous-mode { mcs mcs-index | nss nss-index vht-mcs vhtmcs-index | rate rate-value }
The continuous mode is disabled.
mcs mcs-index: Specifies the MCS index in the range of 0 to 76.
nss nss-index vht-mcs vhtmcs-index: Specifies the VHT-MCS index. The value ranges for the nss-index and vhtmcs-index arguments are 1 to 8 and 0 to 9, respectively.
rate rate-value: Specifies the transmit rate in Mbps.
This feature is used for network testing only. Do not use it under any other circumstances.
It enables continuous data packet sending at the specified rate. When the feature is enabled, do not perform any other operations except changing the transmit rate.
For an 802.11a, 802.11b, or 802.11g radio, set the transmit rate. For an 802.11n radio, set the transmit rate or MCS index. For an 802.11ac or 802.11gac radio, set the transmit rate, MCS index, or VHT-MCS index.
# Enable the continuous mode and set the transmit rate to 6 Mbps.
[Sysname-WLAN-Radio1/0/2] continuous-mode rate 6
display wlan ap continuous-mode
custom-antenna gain
Use custom-antenna gain to set the antenna gain.
Use undo custom-antenna gain to restore the default.
custom-antenna gain antenna-gain
The antenna gain is 0 dBi.
antenna-gain: Specifies the antenna gain in the range of 0 to 20 dBi.
This command is applicable only when an AP uses a third-party antenna.
Effective Isotropic Radiated Power (EIRP) is the actual transmit power of an antenna, and it is the sum of the antenna gain and the maximum transmit power of the radio. If the configured antenna gain causes the EIRP to exceed the threshold, the antenna gain configuration fails.
Make sure the antenna gain setting is the same as the gain of the antenna used on the AP.
Changing the radio mode automatically changes the antenna gain.
# Set the antenna gain to 2 dBi.
[Sysname-WLAN-Radio1/0/1] type dot11gn
[Sysname-WLAN-Radio1/0/1] custom-antenna gain 2
display wlan radio
Use display wlan radio to display radio information.
display wlan radio radio-id
radio-id: Specifies a radio by its ID.
# Display information about radio 1.
<Sysname> display wlan radio 1
Radio 1:
    BSSID                     : 74ea-cbdf-0640
    State                     : Up
    Type                      : 802.11ac
    Antenna type              : external
    Client dot11ac-only       : Disabled
    Client dot11n-only        : Disabled
    Channel band-width        : 20/40/80MHz
    Operating band-width      : 20/40/80MHz
    Secondary channel mode    : SCA
    Short GI for 20MHz        : Supported
    Short GI for 40MHz        : Supported
    Short GI for 80MHz        : Supported
    Short GI for 160MHz       : Not supported
    MIMO                      : Not Config
    Green-Energy-Management   : Disabled
    A-MSDU                    : Enabled
    A-MPDU                    : Enabled
    LDPC                      : Not Supported
    STBC                      : Supported
    Operational VHT-MCS set:
        Mandatory             : Not configured
        Supported             : NSS1 0,1,2,3,4,5,6,7,8,9
                                NSS2 0,1,2,3,4,5,6,7,8,9
                                NSS3 0,1,2,3,4,5,7,8,9
                                NSS4 0,1,2,3,4,5,6,7,8,9
        Multicast             : Not configured
    Operational HT MCS set:
        Supported             : 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,
                                10, 11, 12, 13, 14, 15, 16, 17,
                                18, 19, 20, 21, 22, 23, 24, 25,
                                26, 27, 28, 29, 30, 31
    Channel                   : 36
    Channel usage(%)          : 0
    Max power                 : 24 dBm
    Preamble type             : Short
    Operational rate:
        Mandatory             : 6, 12, 24 Mbps
        Multicast             : Auto
        Supported             : 9, 18, 36, 48, 54 Mbps
        Disabled              : Not configured
    Distance                  : 1 km
    ANI                       : Enabled
    Fragmentation threshold   : 2346 bytes
    Beacon interval           : 100 TU
    Protection threshold      : 2346 bytes
    Long retry threshold      : 4
    Short retry threshold     : 7
    Frame aging time in cache : 2000 ms
    Noise floor               : -113 dBm
    Protection mode           : cts-to-self
    MU-TxBF                   : Enabled
    SU-TxBF                   : Enabled
    Continuous mode           : N/A
    HT protection mode        : No protection
Radio state:
·     Up.
·     Down.
Radio type:
·     2.4GHz—802.11b, 802.11g, or 802.11n(2.4GHz).
·     5GHz—802.11a, 802.11n(5GHz), or 802.11ac.
Antenna type
Antenna type of the radio.
Client dot11ac-only
·     Disabled—Allows both 802.11ac and 802.11a/b/g/n clients to associate with the radio.
·     Enabled—Allows only 802.11ac clients to associate with the radio.
Client dot11n-only
·     Disabled—Allows 802.11ac, 802.11n, and 802.11a/b/g clients to associate with the radio.
·     Enabled—Allows only 802.11n and 802.11ac clients to associate with the radio.
Channel band-width
Channel bandwidth:
·     20MHz.
·     20/40MHz.
·     20/40/80MHz.
·     20/40/80/160MHz.
Operating bandwidth of the radio.
Secondary channel mode for 802.11n and 802.11ac radios:
·     SCA—Second Channel Above (SCA). The radio operates in 40 MHz bandwidth mode, and the secondary channel is above the primary channel.
·     SCB—Second Channel Below (SCB). The radio operates in 40 MHz bandwidth mode, and the secondary channel is below the primary channel.
·     SCN—The radio does not operate in 40 MHz bandwidth mode.
This field is available only when the operating bandwidth is 20/40/80MHz.
Short GI for 20MHz
·     Not supported.
·     Supported.
Short GI for 40MHz
·     Not supported.
·     Supported.
Short GI for 80MHz
·     Not supported.
·     Supported.
Short GI for 160MHz
·     Not supported.
·     Supported.
MIMO
MIMO mode:
·     1x1—The radio sends and receives signals through one spatial stream.
·     2x2—The radio sends and receives signals through two spatial streams.
·     3x3—The radio sends and receives signals through three spatial streams.
·     4x4—The radio sends and receives signals through four spatial streams.
·     Not configured—The radio sends and receives signals through the maximum number of spatial streams supported by the radio.
If this field also displays (PowerLow) after any value option to indicate low power level, the radio can send and receive signals only through one spatial stream.
·     Disabled.
·     Enabled.
A-MSDU
·     Disabled.
·     Enabled.
A-MPDU
·     Disabled.
·     Enabled.
LDPC
·     Supported.
·     Not Supported.
STBC
·     Supported.
·     Not Supported.
·     Supported—Supported VHT MCS set.
·     Mandatory—Mandatory VHT MCS set.
·     Multicast—Multicast VHT MCS set.
·     Supported—Supported MCS set.
·     Mandatory—Mandatory MCS set.
·     Multicast—Multicast MCS set.
Channel
·     Number<auto>—This field displays Number<auto> if the current channel is the optimal channel automatically selected by the AP.
·     Number—This field displays Number if the current channel is manually configured.
·     Number<avoid radar>—This field displays Number<avoid radar> if the current channel is automatically selected by the AP to avoid radar signals.
Max power
Maximum transmission power of the radio.
Preamble type
Preamble type:
·     Short.
·     Long.
Operational rate
·     Mandatory.
·     Supported.
·     Multicast.
·     Disabled.
·     Not configured.
Distance
Maximum distance that the radio signal can reach.
ANI
·     Enabled.
·     Disabled.
Frame length threshold required for triggering the protection mechanism.
Maximum number of retransmission attempts for frames whose length exceeds the RTS threshold.
Maximum number of retransmission attempts for frames whose length is below the RTS threshold.
Protection mode
Conflict avoidance mode:
·     cts-to-self.
·     rts-cts.
MU-TxBF
·     Enabled.
·     Disabled.
SU-TxBF
·     Enabled.
·     Disabled.
Continuous mode
Continuous mode configuration:
·     Rate.
·     MCS index.
·     NSS index.
·     VHT-MCS index.
·     This field displays N/A if the continuous mode is not configured.
HT protection mode
802.11n protection mode:
·     No protection.
¡     AP-associated clients and nearby wireless devices are operating in 802.11n mode and AP-associated clients are 802.11n clients with a bandwidth of 40 MHz.
¡     AP-associated clients are 802.11n clients with a bandwidth of 20 MHz.
·     Non-member protection.
In this mode, all AP-associated clients are 802.11n clients but some nearby wireless devices are non-802.11n clients.
·     20 MHz protection.
In this mode, the AP's radio has a bandwidth of 40 MHz. AP-associated clients and nearby wireless devices are operating in 802.11n mode and a minimum of one 802.11n client with a bandwidth of 20 MHz is associated with the AP's radio.
·     Non-HT mixed.
This mode applies when none of the above mentioned modes apply.
distance
Use distance to set the maximum transmission distance.
Use undo distance to restore the default.
distance distance
undo distance
The maximum transmission distance is 1 km (0.62 miles).
distance: Specifies the maximum transmission distance in the range of 1 to 40 km (0.62 to 24.86 miles).
# Set the maximum transmission distance to 5 km (3.11 miles).
[Sysname-WLAN-Radio1/0/2] type dot11g
[Sysname-WLAN-Radio1/0/2] distance 5
dl-ofdma
Use dl-ofdma enable to enable OFDMA.
Use dl-ofdma disable to disable OFDMA.
Use undo dl-ofdma to restore the default.
dl-ofdma { disable | enable }
undo dl-ofdma
Downlink OFDMA is disabled.
This command takes effect only on 802.11ax and 802.11gax radios. Changing the radio mode to 802.11a/b/g/n/ac/gac removes the configuration.
OFDMA can provide the following benefits if enabled in a high density environment where small data packets are transmitted:
·     Concurrent transmission to multiple users.
·     Improved radio usage.
·     Shortened transmission latency.
·     Reduced conflict backoff.
# Enable downlink OFDMA.
[Sysname-WLAN-Radio1/0/2] dl-ofdma enable
type dot11ax
Use dot11ac mandatory maximum-nss to set the maximum mandatory NSS.
Use undo dot11ac mandatory maximum-nss to restore the default.
dot11ac mandatory maximum-nss nss-number
No maximum mandatory NSS is set.
nss-number: Specifies the maximum mandatory NSS in the range of 1 to 8.
This command is applicable only to 802.11ac and 802.11gac radios. Changing the radio mode to non-802.11ac modes invalidates the command.
The maximum mandatory NSS cannot be greater than the maximum supported NSS.
After you modify the maximum mandatory NSS, clients that are associated with the radio and that do not support the modified NSS will go offline.
# Set the maximum mandatory NSS to 7.
[Sysname-wlan-radio-1/0/1] dot11ac mandatory maximum-nss 7
dot11ac support maximum-nss
dot11ac multicast-nss
Use dot11ac multicast-nss to set the multicast NSS and specify a VHT-MCS index.
Use undo dot11ac multicast-nss to restore the default.
dot11ac multicast-nss nss-number vht-mcs index
No multicast NSS is set.
nss-number: Specifies the multicast NSS in the range of 1 to 8.
index: Specifies a VHT-MCS index in the range of 0 to 9.
Before configuring this command, you must configure the dot11ac mandatory maximum-nss command.
The multicast NSS cannot be greater than the maximum mandatory NSS.
# Set the maximum mandatory NSS, multicast NSS, and VHT-MCS index to 2, 2, and 2, respectively.
[Sysname-wlan-radio-1/0/1] dot11ac mandatory maximum-nss 2
[Sysname-wlan-radio-1/0/1] dot11ac multicast-nss 2 vht-mcs 2
Use dot11ac support maximum-nss to set the maximum supported NSS.
Use undo dot11ac support maximum-nss to restore the default.
dot11ac support maximum-nss nss-number
The maximum supported NSS is 8.
nss-number: Specifies the maximum supported NSS in the range of 1 to 8.
The maximum supported NSS cannot be smaller than the maximum mandatory NSS.
# Set the maximum supported NSS to 7.
[Sysname-wlan-radio-1/0/1] dot11ac support maximum-nss 7
dot11g protection
Use dot11g protection enable to enable 802.11g protection.
Use dot11g protection disable to disable 802.11g protection.
Use undo dot11g protection to restore the default.
dot11g protection { disable | enable }
802.11g protection is disabled.
This command is applicable only to 802.11g, 802.11n (2.4 GHz), 802.11gac, and 802.11gax radios. If you change the mode of a radio to a mode other than the three modes, 802.11g protection configuration is removed.
802.11g, 802.11n, 802.11gac devices send RTS/CTS or CTS-to-self packets before sending data only when 802.11b signals are detected on the channel.
802.11g protection automatically takes effect when 802.11b clients associate with an 802.11g, 802.11n (2.4 GHz), 802.11gac, or 802.11gax radio.
# Enable 802.11g protection.
[Sysname-WLAN-Radio1/0/2] dot11g protection enable
protection-mode
dot11n mandatory maximum-mcs
Use dot11n mandatory maximum-mcs to set the maximum mandatory MCS index.
Use undo dot11n mandatory maximum-mcs to restore the default.
dot11n mandatory maximum-mcs index
No maximum mandatory MCS index is set.
index: Specifies the maximum mandatory MCS index in the range of 0 to 76.
Before configuring the dot11n multicast-mcs command, you must set the maximum mandatory MCS index.
After you modify the maximum mandatory MCS index, clients that are associated with the radio and that do not support the modified MCS index will go offline.
# Set the maximum mandatory MCS index to 14.
[Sysname-WLAN-Radio1/0/1] dot11n mandatory maximum-mcs 14
Use dot11n multicast-mcs to set the multicast MCS index.
Use undo dot11n multicast-mcs to restore the default.
dot11n multicast-mcs index
No multicast MCS index is set.
index: Specifies the multicast MCS index in the range of 0 to 76.
The multicast MCS index takes effect only when the radio associates only with 802.11n, 802.11ac, and 802.11ax clients.
If 802.11a/b/g clients exist, the AP and clients use the 802.11a/b/g multicast rate to send multicast packets.
The multicast MCS index maps to a rate in 20 MHz bandwidth mode regardless of whether the bandwidth mode is 20 MHz or 40 MHz.
# Set the multicast MCS index to 14.
[Sysname-WLAN-Radio1/0/1] dot11n mandatory maximum-mcs 15
[Sysname-WLAN-Radio1/0/1] dot11n multicast-mcs 14
dot11n protection
Use dot11n protection enable to enable 802.11n protection.
Use dot11n protection disable to disable 802.11n protection.
Use undo dot11n protection to restore the default.
dot11n protection { disable | enable }
802.11n protection is disabled.
This command is applicable only to 802.11n, 802.11ac, 802.11gac, 802.11ax, and 802.11gax radios. If you change the mode of a radio to a mode other than the three modes, the 802.11n protection configuration is removed.
With this feature enabled, 802.11n, 802.11ac, and 802.11gac devices send RTS/CTS or CTS-to-self packets before sending data when 802.11a/b/g signals are detected on the channel.
802.11n protection automatically takes effect when 802.11a/b/g clients associate with an 802.11n, 802.11ac, 802.11gac, 802.11ax, or 802.11gax radio.
# Enable 802.11n protection.
[Sysname-WLAN-Radio1/0/1] dot11n protection enable
dot11n support maximum-mcs
Use dot11n support maximum-mcs to set the maximum supported MCS index.
Use undo dot11n support maximum-mcs to restore the default.
dot11n support maximum-mcs index
The maximum supported MCS index is 76.
index: Specifies the maximum supported MCS index in the range of 0 to 76.
The maximum supported MCS index cannot be smaller than the maximum mandatory MCS index.
# Set the maximum supported MCS index to 14.
[Sysname-WLAN-Radio1/0/1] dot11n support maximum-mcs 14
dtim
Use dtim to set the Delivery Traffic Indication Map (DTIM) interval.
Use undo dtim to restore the default.
dtim counter
undo dtim
The DTIM interval is 1. The AP sends buffered broadcast and multicast frames after every beacon frame.
counter: Specifies the DTIM interval in the range of 1 to 31.
An AP periodically broadcasts a beacon compliant with the DTIM. After the AP broadcasts the beacon, it sends buffered broadcast and multicast frames based on the value of the DTIM interval. For example, if you set the DTIM interval to 5, the AP sends buffered broadcast and multicast frames every five beacon frames.
# Set the DTIM interval to 5.
[Sysname-wlan-radio1/0/1] dtim 5
green-energy-management
Use green-energy-management enable to enable the energy-saving feature.
Use green-energy-management disable to disable the energy-saving feature.
Use undo green-energy-management to restore the default.
The following compatibility matrix shows the support of hardware platforms for this command:
Hardware series
Model
Command compatibility
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
No
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
Yes
WAP922 series
WAP922E
Yes
WAP923 series
WAP923
Yes
green-energy-management { disable | enable }
The energy saving feature is disabled.
After you enable the energy-saving feature, the multiple-input and multiple-output (MIMO) mode of a radio automatically changes to 1x1 if no clients associate with the radio and the radio is not configured with WIPS. This reduces power consumption.
# Enable the energy-saving feature.
[Sysname-WLAN-Radio1/0/1] green-energy-management enable
ldpc
Use ldpc enable to enable LDPC.
Use ldpc disable to disable LDPC.
Use undo ldpc to restore the default.
ldpc { disable | enable }
undo ldpc
LDPC is enabled.
The device can receive but cannot send LDPC packets.
For 802.11ax radios, LDPC is enabled by default and cannot be disabled. If you execute the undo ldpc command for an 802.11ax radio, the command does not take effect.
# Disable LDPC.
[Sysname-wlan-radio-1/0/1] type dot11an
[Sysname-wlan-radio-1/0/1] ldpc disable
long-retry threshold
Use long-retry threshold to set the hardware retransmission limit for large frames.
Use undo long-retry threshold to restore the default.
long-retry threshold count
Hardware series
Model
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
No
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
Yes
WAP922 series
WAP922E
Yes
WAP923 series
WAP923
Yes
The hardware retransmission limit is 4 for large frames.
count: Specifies the hardware retransmission limit for large frames, in the range of 1 to 15.
Perform this task to set the hardware retransmission limit for frames larger than the RTS threshold.
# Set the hardware retransmission limit to 5 for large frames.
[Sysname-wlan-radio-1/0/1] long-retry threshold 5
protection-threshold
short-retry threshold
max-power
Use max-power to set the maximum transmit power.
Use undo max-power to restore the default.
max-power radio-power
undo max-power
The AP uses the maximum supported transmit power.
radio-power: Specifies the maximum transmit power.
The transmit power range supported by a radio varies by country code, channel, AP model, radio mode, antenna type, and bandwidth mode. If you change these attributes for a radio after you set the maximum transmit power, the configured maximum transmit power might be out of the supported transmit power range. If this happens, the system automatically adjusts the maximum transmit power to a valid value.
If you enable power lock, the locked power becomes the maximum transmit power.
# Set the maximum transmit power to 15 dBm.
[Sysname-WLAN-Radio1/0/2] max-power 15
mimo
Use mimo to specify a MIMO mode for a radio.
Use undo mimo to restore the default.
mimo { 1x1 | 2x2 | 3x3 | 4x4 | 5x5 | 6x6 | 7x7 | 8x8 }
undo mimo
The default setting for this command varies by radio.
1x1: Sends and receives signals through one spatial stream.
2x2: Sends and receives signals through two spatial streams.
3x3: Sends and receives signals through three spatial streams.
4x4: Sends and receives signals through four spatial streams.
5x5: Sends and receives signals through five spatial streams.
6x6: Sends and receives signals through six spatial streams.
7x7: Sends and receives signals through seven spatial streams.
8x8: Sends and receives signals through eight spatial streams.
MIMO enables a radio to send and receive wireless signals through multiple spatial streams. This improves system capacity and spectrum usage without requiring higher bandwidth.
# Set the MIMO mode to 2x2.
[Sysname-WLAN-Radio1/0/1] mimo 2x2
[Sysname-WLAN-Radio1/0/1] undo mimo
mu-txbf
Use mu-txbf enable to enable multi-user transmit beamforming (TxBF).
Use mu-txbf disable to disable multi-user TxBF.
Use undo mu-txbf to restore the default.
mu-txbf { disable | enable }
undo mu-txbf
Multi-user TxBF is disabled.
This command is applicable only to 802.11ac, 802.11gac, 802.11ax, and 802.11gax radios. Changing the radio mode to 802.11a, 802.11b, 802.11g, or 802.11n invalidates the command.
TxBF enables an AP to adjust transmitting parameters based on the channel information to focus RF signals on intended clients. This feature improves the RF signal quality.
Multi-user TxBF is part of 802.11ac Wave2. Multi-user TxBF enables an AP to focus different RF signals on their intended clients to reduce interference and transmission delay. This improves traffic throughput and bandwidth usage. Multi-user TxBF is applicable to WLANs that have a large number of clients and require high bandwidth usage and low transmission delay.
Multi-user TxBF takes effect only when single-user TxBF is enabled.
As a best practice, do not modify the default MIMO settings for an AP enabled with multi-user TxBF.
# Enable multi-user TxBF.
[Sysname-WLAN-Radio1/0/1] su-txbf enable
[Sysname-WLAN-Radio1/0/1] mu-txbf enable
su-txbf
preamble
Use preamble to set the preamble type.
Use undo preamble to restore the default.
preamble { long | short }
undo preamble
Hardware series
Model
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
No
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
Yes
WAP922 series
WAP922E
Yes
WAP923 series
WAP923
Yes
The short preamble is used.
long: Specifies a long preamble. A long preamble ensures compatibility with all wireless devices that use an earlier standard than 802.11n.
short: Specifies a short preamble. A short preamble can improve network performance.
This command is applicable only to 802.11b, 802.11g, and 802.11gn radios.
A preamble is a set of bits in a packet header to synchronize transmission signals between sender and receiver.
# Set the preamble type to long.
[Sysname-WLAN-Radio1/0/2] preamble long
protection-mode
Use protection-mode to specify a collision avoidance mode.
Use undo protection-mode to restore the default.
protection-mode { cts-to-self | rts-cts }
Hardware series
Model
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
Both the RTS/CTS and CTS-to-self modes are supported.
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
Only the RTS/CTS mode is supported.
WAP922 series
WAP922E
WAP923 series
WAP923
For a fat AP, the mode varies by device model. For more information, see the table below.
Hardware series
Model
Default collision avoidance mode
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
CTS-to-self
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
RTS/CTS
WAP922 series
WAP922E
RTS/CTS
WAP923 series
WAP923
RTS/CTS
cts-to-self: Specifies the CTS-to-self mode.
rts-cts: Specifies the RTS/CTS mode.
You can specify either of the following collision avoidance modes for an AP:
·     RTS/CTS—An AP sends an RTS packet to a client before sending data to the client. After receiving the RTS packet, the client sends a CTS packet to the AP. The AP begins to send data after receiving the CTS packet, and other devices that detect the RTS or CTS packet do not send data within a specific time period.
·     CTS-to-self—An AP sends a CTS packet with its own MAC address as the destination MAC address before sending data to a client. After receiving the CTS-to-self packet, the AP begins to send data, and other devices that detect the CTS-to-self packet do not send data within a specific time period.
# Specify the RTS/CTS mode.
[Sysname-WLAN-Radio1/0/2] protection-mode rts-cts
dot11g protection
rate
Use rate to set the transmission rates for a radio.
Use undo rate to restore the default.
rate { multicast { auto | rate-value } | { disabled | mandatory | supported } rate-value }
undo rate
In radio interface view:
·     802.11a/802.11an/802.11ac/802.11ax:
¡     Prohibited rates—None.
¡     Mandatory rates—6, 12, and 24.
¡     Multicast rate—Selected from the mandatory rates.
¡     Supported rates—9, 18, 36, 48, and 54.
·     802.11b:
¡     Mandatory rates—1 and 2.
¡     Supported rates—5.5 and 11.
·     802.11g/802.11gn/802.11gac/802.11gax:
¡     Mandatory rates—1, 2, 5.5, and 11.
¡     Supported rates—6, 9, 12, 18, 24, 36, 48, and 54.
disabled: Specifies rates that cannot be used by an AP.
mandatory: Specifies rates that the clients must support to associate with an AP.
multicast: Specifies the rate at which an AP multicasts packets. The multicast rate must be selected from the mandatory rates.
supported: Specifies rates that an AP supports. After a client associates with an AP, the client can select a higher or lower rate from the supported rates to communicate with the AP.
auto: Automatically selects a mandatory rate as the multicast rate.
rate-value: Specifies the rate value in Mbps. You can set multiple rates and separate them by spaces. The available values for this argument are as follows:
·     802.11a/802.11an/802.11ac/802.11ax—6, 9, 12, 18, 24, 36, 48, and 54.
·     802.11b—1, 2, 5.5, and 11.
·     802.11g/802.11gn/802.11gac/802.11gax—1, 2, 5.5, 6, 9, 11, 12, 18, 24, 36, 48, and 54.
The mandatory rates and multicast rate cannot be null. When there is only one mandatory rate, you cannot specify the mandatory rate as a supported rate or prohibited rate.
# Set the mandatory rates to 6 Mbps, 12 Mbps, and 24 Mbps.
[Sysname-WLAN-Radio1/0/2] rate mandatory 6 12 24
short-gi
Use short-gi enable to enable short Guard Interval (GI).
Use short-gi disable to disable short GI.
Use undo short-gi to restore the default.
short-gi { disable | enable }
undo short-gi
Hardware series
Model
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
No
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
Yes
WAP922 series
WAP922E
Yes
WAP923 series
WAP923
Yes
Short GI is enabled.
# Disable short GI.
[Sysname-WLAN-Radio1/0/1] short-gi disable
Use short-retry threshold to set the hardware retransmission limit for small frames.
Use undo short-retry threshold to restore the default.
short-retry threshold count
Hardware series
Model
WA6600 series
WA6638
WA6638i
WA6636
WA6630X
WA6628
WA6628X
WA6628E-T
WA6622
WA6620
WA6620X
No
WA6300 series
WA6338
WA6338-HI
WA6338-LI
WA6330
WA6330-LI
WA6322
WA6322H
WA6322H-HI
WA6322H-LI
WA6320
WA6320-C
WA6320-D
WA6320-SI
WA6320H
WA6320H-LI
WA6320H-XEPON
Yes
WAP922 series
WAP922E
Yes
WAP923 series
WAP923
Yes
The hardware retransmission limit is 7 for small frames.
count: Specifies the hardware retransmission limit for small frames, in the range of 1 to 15.
Perform this task to set the hardware retransmission limit for frames smaller than or equal to the RTS threshold.
# Set the hardware retransmission limit to 10 for small frames.
[Sysname-WLAN-Radio1/0/1] short-retry threshold 10
stbc
Use stbc enable to enable Space-Time Block Coding (STBC).
Use stbc disable to disable STBC.
Use undo stbc to restore the default.
stbc { disable | enable }
undo stbc
STBC is enabled.
# Enable STBC.
[Sysname-wlan-radio-1/0/1] stbc enable
su-txbf
Use su-txbf enable to enable single-user TxBF.
Use su-txbf disable to disable single-user TxBF.
Use undo su-txbf to restore the default.
su-txbf { disable | enable }
undo su-txbf
Single-user TxBF is disabled.
Single-user TxBF enables an AP to improve the signal to one intended client. Single-user TxBF is applicable to WLANs that have widely spread clients, poor network quality, and serious signal attenuation.
# Enable single-user TxBF.
mu-txbf
type
Use type to specify a radio mode.
Use undo type to restore the default.
type { dot11a | dot11ac | dot11an | dot11ax | dot11b | dot11g | dot11gac | dot11gax | dot11gn }
undo type
The default setting varies by radio ID.
dot11a: Specifies the 802.11a radio mode.
dot11ac: Specifies the 802.11ac radio mode.
dot11an: Specifies the 802.11n (5 GHz) radio mode.
dot11ax: Specifies the 802.11ax radio mode.
dot11b: Specifies the 802.11b radio mode.
dot11g: Specifies the 802.11g radio mode.
dot11gac: Specifies the 802.11gac radio mode.
dot11gax: Specifies the 802.11gax radio mode.
dot11gn: Specifies the 802.11n (2.4 GHz) radio mode.
CAUTION
CAUTION:
Modifying the mode of an enabled radio logs off all associated clients.
# Set the radio mode to 802.11n (5 GHz).
[Sysname-WLAN-Radio1/0/2] type dot11an
