10-WLAN Roaming Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(R5426P02)-6W10410-WLAN Roaming Configuration Guide
03-802.11r configuration
03-802.11r configuration 194.06 KB
Configuring 802.11r
About 802.11r
802.11r fast BSS transition (FT) minimizes the delay when a client roams from a BSS to another BSS within the same ESS. During 802.11r FT, a client needs to exchange messages with the target AP.
802.11r operating mechanism
FT provides the following message exchanging methods:
·     Over-the-air—The client communicates directly with the target AP for pre-roaming authentication.
·     Over-the-DS—The client communicates with the target AP through the current AP for pre-roaming authentication.
Intra-AC roaming through over-the-air FT
As shown in Figure 1, the client is associated with AP 1. Intra-AC roaming through over-the-air FT uses the following process:
1.     The client sends an FT authentication request to AP 2.
2.     AP 2 sends an FT authentication response to the client.
3.     The client sends a reassociation request to AP 2.
4.     AP 2 sends a reassociation response to the client.
5.     The client roams to AP 2.
Figure 1 Intra-AC roaming through over-the-air FT
Inter-AC roaming through over-the-air FT
As shown in Figure 2, the client is associated with AP 1. Inter-AC roaming through over-the-air FT uses the following process:
1.     After the client comes online, AC 1 sends roaming information for the client to AC 2. Roaming information includes the PMK and the client VLAN.
2.     The client sends an FT authentication request to AP 2.
3.     AP 2 sends an FT authentication response to the client.
4.     The client sends a reassociation request to AP 2.
5.     AP 2 sends a reassociation response to the client.
6.     The client roams to AP 2.
Figure 2 Inter-AC roaming through over-the-air FT
Intra-AC roaming through over-the-DS FT
As shown in Figure 3, the client is associated with AP 1. Intra-AC roaming through over-the-DS FT uses the following process:
1.     After the client comes online, the AC creates a roaming entry and saves it for the client.
2.     The client sends an FT authentication request to AP 1.
3.     AP 1 sends an FT authentication response to the client.
Figure 3 Intra-AC roaming through over-the-DS FT
Inter-AC roaming through over-the-DS FT
As shown in Figure 4, the client is associated with AP 1. Inter-AC roaming through over-the-DS FT uses the following process:
Figure 4 Inter-AC roaming through over-the-DS FT
Protocols and standards
802.11r IEEE Standard for Information technology—Telecommunications and information exchange between systems—Local and metropolitan area networks—Specific requirements
Restrictions and guidelines: 802.11r configuration
When you configure 802.11r, follow these restrictions and guidelines:
·     To enable a client that does not support FT to access the WLAN, create two service templates using the same SSID: one enabled with FT and the other not.
·     To prevent a client from coming online every time the periodic re-authentication timer expires, do not enable FT and 802.1X periodic re-authentication for the same service template. For more information about 802.1X periodic re-authentication, see User Access and Authentication Configuration Guide.
·     PTK updates are not supported for clients that have been associated with a WLAN through FT. For more information about PTK updates, see WLAN Security Configuration Guide.
Configuring 802.11r
2.     Enter service template view.
wlan service-template service-template-name
3.     Enable FT.
ft enable
By default, FT is disabled.
4.     (Optional.) Set the FT method.
ft method { over-the-air | over-the-ds }
By default, the FT method is over-the-air.
5.     (Optional.) Set the reassociation timeout timer.
ft reassociation-timeout timeout
By default, the association timeout timer is 20 seconds.
The roaming process is terminated if a client does not send any reassociation requests before the timeout timer expires.
802.11r configuration examples (intra-AC)
The AP models and serial numbers in this document are used only as examples. Support for AP models and serial numbers depends on the AC model.
Example: Configuring over-the-DS FT and PSK authentication
As shown in Figure 5, configure intra-AC roaming through over-the-DS FT to enable the client to roam between AP 1 and AP 2. Configure PSK as the authentication and key management mode.
Figure 5 Network diagram
# Create service template acstname.
<AC> system-view
[AC] wlan service-template acstname
# Set the SSID to service.
[AC-wlan-st-acstname] ssid service
# Set the authentication and key management mode to PSK, and configure simple string 12345678 as the PSK.
[AC-wlan-st-acstname] akm mode psk
[AC-wlan-st-acstname] preshared-key pass-phrase simple 12345678
# Set the CCMP cipher suite and enable the RSN IE in the beacon and probe responses.
[AC-wlan-st-acstname] cipher-suite ccmp
[AC-wlan-st-acstname] security-ie rsn
# Enable FT.
[AC-wlan-st-acstname] ft enable
# Set the reassociation timeout timer to 50 seconds.
[AC-wlan-st-acstname] ft reassociation-timeout 50
# Set the FT method to over-the-DS.
[AC-wlan-st-acstname] ft method over-the-ds
# Enable the service template.
[AC-wlan-st-acstname] service-template enable
[AC-wlan-st-acstname] quit
# Create AP 1, and bind service template acstname to radio 1 of the AP.
[AC] wlan ap 1 model WA4320i-ACN
[AC-wlan-ap-1] serial-id 210235A1BSC123000050
[AC-wlan-ap-1] radio 1
[AC-wlan-ap-1-radio-1] service-template acstname
[AC-wlan-ap-1-radio-1] radio enable
[AC-wlan-ap-1-radio-1] quit
[AC-wlan-ap-1] quit
# Create AP 2, and bind service template acstname to radio 1 of the AP.
[AC] wlan ap 2 model WA4320i-ACN
[AC-wlan-ap-2] serial-id 210235A1BSC123000055
[AC-wlan-ap-2] radio 1
[AC-wlan-ap-2-radio-1] service-template acstname
[AC-wlan-ap-2-radio-1] radio enable
[AC-wlan-ap-2-radio-1] quit
[AC-wlan-ap-2] quit
# Verify that the service template is correctly configured.
[AC] display wlan service-template acstname verbose
Service template name        : acstname
Description                  : Not configured
SSID                         : service
SSID-hide                    : Disabled
User-isolation               : Disabled
Service template status      : Enabled
Maximum clients per BSS      : Not configured
Frame format                 : Dot3
Seamless-roam status         : Disabled
Seamless-roam RSSI threshold : 50
Seamless-roam RSSI gap       : 20
VLAN ID                      : 1
AKM mode                     : PSK
Security IE                  : RSN
Cipher suite                 : CCMP
TKIP countermeasure time     : 0 sec
PTK lifetime                 : 43200 sec
GTK rekey                    : Enabled
GTK rekey method             : Time-based
GTK rekey time               : 86400 sec
GTK rekey client-offline     : Disabled
User authentication mode     : Bypass
Intrusion protection         : Disabled
Intrusion protection mode    : Temporary-block
Temporary block time         : 180 sec
Temporary service stop time  : 20 sec
Fail VLAN ID                 : Not configured
802.1X handshake             : Disabled
802.1X handshake secure      : Disabled
802.1X domain                : Not configured
MAC-auth domain              : Not configured
Max 802.1X users             : 4096
Max MAC-auth users           : 4096
802.1X re-authenticate       : Disabled
Authorization fail mode      : Online
Accounting fail mode         : Online
Authorization                : Permitted
Key derivation               : SHA1
PMF status                   : Disabled
Hotspot policy number        : Not configured
Forwarding policy status     : Disabled
Forwarding policy name       : Not configured
Forwarder                    : AC
FT Status                    : Enable
FT Method                    : over-the-ds
FT Reassociation Deadline    : 50 sec
QoS trust                    : Port
QoS priority                 : 0
# Verify that the roaming status is N/A and the FT status is Active.
[AC] display wlan client verbose
Total number of clients: 1
MAC address                        : fc25-3f03-8361
IPv4 address                       : 10.1.1.114
IPv6 address                       : N/A
Username                           : N/A
AID                                : 1
AP ID                              : 1
AP name                            : 1
Radio ID                           : 1
SSID                               : service
BSSID                              : 000f-e266-7788
VLAN ID                            : 1
Sleep count                        : 242
Wireless mode                      : 802.11ac
Channel bandwidth                  : 80MHz
SM power save                      : Enabled
SM power save mode                 : Dynamic
Short GI for 20MHz                 : Supported
Short GI for 40MHz                 : Supported
Short GI for 80MHz                 : Supported
Short GI for 160/80+80MHz          : Not supported
STBC RX capability                 : Not supported
STBC TX capability                 : Not supported
LDPC RX capability                 : Not supported
SU beamformee capability           : Not supported
MU beamformee capability           : Not supported
Beamformee STS capability          : N/A
Block Ack                          : TID 0 In
Supported VHT-MCS set              : NSS1 0, 1, 2, 3, 4, 5, 6, 7, 8
                                     NSS2 0, 1, 2, 3, 4, 5, 6, 7, 8
Supported HT MCS set               : 0, 1, 2, 3, 4, 5, 6, 7,
                                     8, 9, 10, 11, 12, 13, 14,
                                     15, 16, 17, 18, 19, 20,
                                     21, 22, 23
Supported rates                    : 6, 9, 12, 18, 24, 36,
                                     48, 54 Mbps
QoS mode                           : WMM
Listen interval                    : 10
RSSI                               : 62
Rx/Tx rate                         : 130/11
Authentication method              : Open system
Security mode                      : RSN
AKM mode                           : PSK
Encryption cipher                  : CCMP
Authorization ACL ID               : 3001(Not effective)
Authorization user profile         : N/A
Roam status                        : N/A
PMF status                         : Enabled
Forward policy name                : Not configured
Online time                        : 0days 0hours 1minutes 13seconds
FT status                          : Active
# Move the client to the coverage of AP 2. (Details not shown.)
# Verify that the authentication method is FT and the roaming status is Intra-AC roam.
IPv6 address                       : N/A
Username                           : N/A
AID                                : 1
AP ID                              : 2
AP name                            : 2
Radio ID                           : 1
SSID                               : service
BSSID                              : 000f-e211-2233
VLAN ID                            : 1
Sleep count                        : 242
                                     21, 22, 23
                                     48, 54 Mbps
QoS mode                           : WMM
RSSI                               : 62
Rx/Tx rate                         : 130/11
Authentication method              : FT
Security mode                      : RSN
AKM mode                           : PSK
Roam status                        : Intra-AC roam
Online time                        : 0days 0hours 5minutes 13seconds
FT status                          : Active
Example: Configuring over-the-air FT and PSK authentication
As shown in Figure 5, configure intra-AC roaming through over-the-air FT to enable the client to roam between AP 1 and AP 2. Configure PSK as the authentication and key management mode.
<AC> system-view
# Enable the RSN IE in the beacon and probe responses.
# Enable FT.
[AC-wlan-ap-1] quit
[AC-wlan-ap-2] quit
# Verify the following information:
·     RSN IE is enabled.
·     The AKM mode is PSK.
·     The cipher suite is CCMP.
·     The FT status is Active.
IPv6 address                       : N/A
Username                           : N/A
AID                                : 1
AP ID                              : 1
AP name                            : 1
Radio ID                           : 1
SSID                               : service
VLAN ID                            : 1
Sleep count                        : 242
                                     21, 22, 23
                                     48, 54 Mbps
QoS mode                           : WMM
RSSI                               : 62
Rx/Tx rate                         : 130/11
Security mode                      : RSN
AKM mode                           : PSK
Roam status                        : N/A
FT status                          : Active
IPv6 address                       : N/A
Username                           : N/A
AID                                : 1
AP ID                              : 2
AP name                            : 2
Radio ID                           : 1
SSID                               : service
VLAN ID                            : 1
Sleep count                        : 242
                                     21, 22, 23
                                     48, 54 Mbps
QoS mode                           : WMM
RSSI                               : 62
Rx/Tx rate                         : 130/11
Security mode                      : RSN
AKM mode                           : PSK
FT status                          : Active
Example: Configuring over-the-DS FT and 802.1X authentication
As shown in Figure 5, configure intra-AC roaming through over-the-DS FT to enable the client to roam between AP 1 and AP 2. Configure 802.1X as the authentication and key management mode.
<AC> system-view
# Set the AKM mode to 802.1X.
[AC-wlan-st-acstname] akm mode dot1x
# Set the authentication mode to 802.1X for clients.
[AC-wlan-st-acstname] client-security authentication-mode dot1x
[AC-wlan-st-acstname] dot1x domain imc
# Enable FT.
# Set the 802.1X authentication mode to EAP.
[AC] dot1x authentication-method eap
# Create RADIUS scheme imcc.
[AC] radius scheme imcc
# Set the IP address of the primary authentication and accounting servers to 10.1.1.3.
[AC-radius-imcc] primary authentication 10.1.1.3
[AC-radius-imcc] primary accounting 10.1.1.3
# Set the shared key for the AC to exchange packets with the authentication and accounting servers to 12345678.
[AC-radius-imcc] key authentication simple 12345678
[AC-radius-imcc] key accounting simple 12345678
# Configure the AC to remove the ISP domain name from usernames sent to the RADIUS server.
[AC-radius-imcc] user-name-format without-domain
[AC-radius-imcc] quit
# Create ISP domain imc, and configure the domain to use the RADIUS scheme imcc for authentication, authorization, and accounting.
[AC] domain imc
[AC-isp-imc] authentication lan-access radius-scheme imcc
[AC-isp-imc] authorization lan-access radius-scheme imcc
[AC-isp-imc] accounting lan-access radius-scheme imcc
[AC-isp-imc] quit
[AC-wlan-ap-1] quit
[AC-wlan-ap-2] quit
SSID                         : service
Frame format                 : Dot3
VLAN ID                      : 1
AKM mode                     : 802.1X
Security IE                  : RSN
Cipher suite                 : CCMP
GTK rekey                    : Enabled
User authentication mode     : 802.1X
802.1X domain                : imc
Forwarder                    : AC
FT Status                    : Enable
FT Reassociation Deadline    : 20 sec
QoS trust                    : Port
QoS priority                 : 0
IPv6 address                       : N/A
Username                           : N/A
AID                                : 1
AP ID                              : 1
AP name                            : 1
Radio ID                           : 1
SSID                               : service
VLAN ID                            : 1
Sleep count                        : 242
                                     21, 22, 23
                                     48, 54 Mbps
QoS mode                           : WMM
RSSI                               : 62
Rx/Tx rate                         : 130/11
Security mode                      : RSN
AKM mode                           : 802.1X
Roam status                        : N/A
FT status                          : Active
IPv6 address                       : N/A
Username                           : N/A
AID                                : 1
AP ID                              : 2
AP name                            : 2
Radio ID                           : 1
SSID                               : service
VLAN ID                            : 1
Sleep count                        : 242
                                     21, 22, 23
                                     48, 54 Mbps
QoS mode                           : WMM
RSSI                               : 62
Rx/Tx rate                         : 130/11
Security mode                      : RSN
AKM mode                           : 802.1X
FT status                          : Active
Example: Configuring over-the-air FT and 802.1X authentication
As shown in Figure 5, configure intra-AC roaming through over-the-air FT to enable the client to roam between AP 1 and AP 2. Configure 802.1X as the authentication and key management mode.
<AC> system-view
# Enable FT.
# Create ISP domain imc, and configure the domain to use RADIUS scheme imcc for authentication, authorization, and accounting.
[AC] domain imc
[AC-isp-imc] quit
[AC-wlan-ap-1] quit
[AC-wlan-ap-2] quit
·     The AKM mode is 802.1X.
IPv6 address                       : N/A
Username                           : N/A
AID                                : 1
AP ID                              : 1
AP name                            : 1
Radio ID                           : 1
SSID                               : service
VLAN ID                            : 1
Sleep count                        : 242
                                     21, 22, 23
                                     48, 54 Mbps
QoS mode                           : WMM
RSSI                               : 62
Rx/Tx rate                         : 130/11
Security mode                      : RSN
AKM mode                           : 802.1X
Roam status                        : N/A
FT status                          : Active
IPv6 address                       : N/A
Username                           : N/A
AID                                : 1
AP ID                              : 2
AP name                            : 2
Radio ID                           : 1
SSID                               : service
VLAN ID                            : 1
Sleep count                        : 242
                                     21, 22, 23
                                     48, 54 Mbps
QoS mode                           : WMM
RSSI                               : 62
Rx/Tx rate                         : 130/11
Security mode                      : RSN
AKM mode                           : 802.1X
FT status                          : Active
