05-Network Connectivity
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5426P02)-6W10405-Network Connectivity
33-3G and 4G modem management commands
33-3G and 4G modem management commands 262.83 KB
3G/4G modem management commands
Common management commands
controller cellular
Use controller cellular to enter cellular interface view.
controller cellular cellular-number
cellular-number: Specifies a cellular interface by its number.
# Enter Cellular 2/4/0 interface view.
[Sysname] controller cellular 2/4/0
[Sysname-Cellular 2/4/0]
description
The description for a cellular interface is in the interface name Interface format, for example, Cellular 2/4/0 Interface.
Cellular interface view
text: Sets an interface description, a case-sensitive string of 1 to 255 characters.
# Set the description to Cellular-intf for Cellular 2/4/0.
[Sysname-Cellular2/4/0] description Cellular-intf
display cellular
Use display cellular to display call connection information for a 3G/4G modem.
display cellular [ interface-number ]
cellular [ interface-number ]: Specifies a cellular interface by its number. If you do not specify a cellular interface, this command displays call connection information for all cellular interfaces with 3G/4G modems installed.
The command output might vary by modem manufacturers.
# Display call connection information for the 3G modem. (WCDMA network).
<Sysname> display cellular 2/4/0
Cellular2/4/0:
  Hardware Information:
    Model: E176G
    Modem Firmware Version: 11.604.09.00.00
    Hardware Version: CD25TCPU
    International Mobile Subscriber Identity (IMSI): 460029010431055
    International Mobile Equipment Identity (IMEI): 353871020138548
    Factory Serial Number (FSN):  DK9RAA1871500602
    Modem Status: Online
  Profile Information:
    Profile 1: Active
      PDP Type: IPv4, Header Compression: Off
      Data Compression: Off
      Access Point Name (APN): 001
      Packet Session Status: Inactive
  Modem Setup Information:
    Diagnostics Monitor: Close
  Network Information:
    Current Service Status: Service available
    Current Service: Combined
    Packet Service: Attached
    Current Roaming Status: Roaming
    Network Selection Mode: Manual
    Network Connection Mode: WCDMA precedence
    Current Network Connection: HSDPA and HSUPA
    Mobile Country Code (MCC): 460
    Mobile Network Code (MNC): 00
    Location Area Code (LAC): 4318
    Cell ID: 25381
  Radio Information:
    Current Band: ANY
    Current RSSI: -51 dBm
  Modem Security Information:
    PIN Verification: Disabled
    PIN Status: Ready
    Number of Retries remaining: 3
    SIM Status: OK
Model
Modem name.
IMSI string of the SIM card.
IMEI serial number of the modem.
FSN of the modem.
Modem Status
Status of the modem:
·     Online—The modem is powered on.
·     Offline—The modem is powered off or in low power mode. The cellular interface is not available.
Profile Information
Profile settings for the modem.
Profile 1
PDP status of the modem:
·     Active—The profile is already configured.
·     Undefined—The profile is not configured.
PDP Type
PDP type, displayed only when Profile 1 is Active:
·     IPv4.
·     IPv6.
·     PPP (transparent transmission).
Header Compression
PDP header compression status:
·     On.
·     Off.
Data Compression
PDP data compression status:
·     On.
·     Off.
PDP status:
·     Active—The modem is transmitting data through PPP.
·     Inactive—The modem is physically down.
Diagnostics Monitor
Diagnostic and monitoring (DM) status:
·     Open—DM is enabled.
·     Close—DM is disabled.
Service status of the modem:
·     Service available—The modem is providing services correctly.
·     Emergency—The modem is providing limited services. The cellular interface is not available.
·     No service—The modem cannot provide services. The cellular interface is not available.
·     Low power—The modem is in low power mode. The cellular interface is not available.
Current Service
Current service type:
·     Circuit-switched—For the CS domain only.
·     Packet-switched—For the PS domain only.
·     Combined—For both the CS and PS domains.
·     Invalid—Invalid service.
Packet Service
PS domain attach/detach status of the modem:
·     Detached—The cellular interface is not available.
·     Attached—The cellular interface is available.
Roaming status:
·     Roaming.
·     Home.
Network selection mode:
·     Manual.
·     Automatic.
Network connection mode:
·     WCDMA only—Connected to the WCDMA network only.
·     WCDMA precedence—Connected to the WCDMA network with preference.
·     GSM only—Connected to the GSM network only.
·     GSM precedence—Connected to the GSM network with preference.
Current network:
·     No Service.
·     GSM.
·     GPRS.
·     EDGE.
·     WCDMA.
·     HSDPA.
·     HSUPA.
·     HSDPA and HSUPA.
·     HSPA+.
·     Unknown.
The MCC is displayed if the modem has found a mobile network.
The MNC is displayed if the modem is successfully registered with a mobile network.
The LAC is displayed if the modem is successfully registered with a mobile network.
Cell ID
The Cell ID is displayed if the modem is successfully registered with a mobile network.
Current Band
Current band selection mode:
·     GSM.
·     WCDMA.
·     ANY.
·     AUTO.
Current RSSI
Current RSSI:
·     An RSSI value in the range of –110 dBm to –51 dBm.
·     Unknown—No signal. The cellular interface is unavailable.
PIN Verification
PIN authentication status:
·     Disabled.
·     Enabled.
PIN Status
PIN status:
·     Ready—The SIM card is ready.
·     PIN Requirement—Requires you to execute the pin verify command to enter the PIN for PIN verification.
·     PUK Requirement—Requires you to execute the pin unlock command to unlock the SIM or UIM card.
Remaining retries available for entering the PIN or PUK.
SIM Status
SIM card status:
·     OK—The SIM card is normal.
·     Network Reject—The SIM card is denied access to the network. The cellular interface is not available.
·     Not Insert—The SIM card is absent. The cellular interface is not available.
# Display call connection information for the 3G modem (TD-SCDMA network).
Cellular2/4/0:
    Model: ET128
    Modem Firmware Version: 11.101.01.08.00
    Hardware Version:  CS31TCPU
    International Mobile Subscriber Identity (IMSI): 460079011105842
    International Mobile Equipment Identity (IMEI): 860039002369111
    Factory Serial Number (FSN):  GQ4CAB1942911350
    Profile 1: Active
      PDP Type: IPv4
      Access Point Name (APN): cmnet
      Packet Session Status: Active
    Network Selection Mode: Automatic
    Network Connection Mode: TD-SCDMA precedence
    Mobile Network Name: CHINA MOBILE
    Downstream Bandwidth: 2800000 bps
  Radio Information:
    Current RSSI: -75 dBm
    PIN Status: Ready
    SIM Status: OK
Model
Modem name.
FSN of the modem.
Modem Status
Profile Information
Profile 1
PDP Type
·     IPv4.
·     IPv6.
Header Compression
·     On.
·     Off.
Data Compression
·     On.
·     Off.
PDP status:
·     Manual.
·     Automatic.
Current network:
·     No Service.
·     GSM.
·     GPRS.
·     EDGE.
·     TD-SCDMA.
·     HSDPA.
·     Unknown.
Downstream bandwidth, in bps.
Radio Information
Radio communication information.
Current RSSI
Current RSSI:
·     An RSSI value in the range of –110 dBm and –51 dBm.
PIN Verification
·     Disabled.
·     Enabled.
PIN Status
PIN status:
SIM Status
SIM card status:
# Display call connection information for the 3G modem (CDMA network).
Cellular2/4/0:
    Model: EC169
    Manufacturer: HUAWEI TECHNOLOGIES CO.
    Modem Firmware Version: 11.002.03.01.45
    Hardware Version:  CE62TCPUVer A
    Electronic Serial Number (ESN): c1836f2d
    Preferred Roaming List (PRL) Version: 0
    International Mobile Subscriber Identity (IMSI): 460036101433925
    Current Roaming Status: Home
    Network Connection Mode: Manual
    Current Network Connection: 1xRTT/EVDO HYBRID
    Downstream Bandwidth: 3100000 bps
  Radio Information:
    Current RSSI(1xRTT): -93 dBm
    Current RSSI(EVDO): -75 dBm
    Current Voltage: 3336 mV
    PIN Status: Ready
    UIM Status: OK
Model
Modem name.
IMSI string of the UIM card.
Modem Status
Roaming status:
·     Roaming.
·     Home.
·     Manual.
·     Automatic.
Current network:
·     No Service.
·     1xRTT/EVDO HYBRID.
·     EVDO.
·     1xRTT.
·     Unknown.
Radio Information
Current RSSI (1xRTT)
Current RSSI of 1xRTT:
·     An RSSI value in the range of –125 dBm to –75 dBm.
Current RSSI (EVDO)
Current RSSI of EVDO:
·     An RSSI value in the ranges of –120 dBm to –60 dBm.
Current Voltage
Current voltage of the UIM card, in mV.
PIN Verification
·     Disabled.
·     Enabled.
PIN Status
PIN status:
·     Ready—The UIM card is ready.
UIM Status
UIM card status:
·     OK—The UIM card is normal.
·     Network Reject—The UIM card is denied access to the network. The cellular interface is not available.
·     Not Insert—The UIM card is absent. The cellular interface is not available.
# Display the call connection information for the 4G modem (LTE network).
<Sysname> display cellular 0/0
Cellular0/0:
    Model: MC7750
    Manufacturer: Sierra Wireless, Incorporated
    Modem Firmware Version: SWI9600M_03.05.10.06
    Hardware Version: 10
    International Mobile Equipment Identity (IMEI): 990000560327506
    Profile index: 1
      PDP Type: IPv4
      Access Point Name (APN): vzwinternet
    Current Data Bearer Technology: Unknown
    Cell ID: 25381
  Radio Information:
    Technology Preference: LTE only
    Technology Selected: LTE
  LTE related info:
    Current RSSI: -79 dBm
    Current RSRQ: -9 dB
    Current RSRP: -106 dBm
    Current SNR: 5 dB
    Tx Power: -3276 dBm
    PIN Status: Ready
    SIM Status: OK
      ICCID: 89860113811003195000
Model
Modem name.
Modem Status
·     Offline—The modem is powered off or in lower power mode. The cellular interface is unavailable.
Profile Information
Profile settings for the 4G modem.
Profile index
Index of the profile for modem.
PDP Type
·     IPv4.
·     IPv6.
Header Compression
·     On.
·     Off.
Data Compression
·     On.
·     Off.
·     Limited—The modem is not in the coverage of the selected network. The cellular interface is not available.
Roaming status:
·     Roaming.
·     Home.
Current data carrier technology:
·     CDMA2000 1X.
·     CDMA2000 HRPD (1xEV-DO).
·     GSM.
·     UMTS.
·     CDMA2000 HRPD (1xEV-DO RevA).
·     EDGE.
·     HSDPA and WCDMA.
·     WCDMA and HSUPA.
·     HSDPA and HSUPA.
·     LTE.
·     CDMA2000 EHRPD.
·     HSDPA+ and WCDMA.
·     HSDPA+ and HSUPA.
·     DC_HSDPA+ and WCDMA.
·     DC_HSDPA+ and HSUPA.
·     HSDPA+ and 64QAM.
·     HSDPA+, 64QAM and HSUPA.
·     TDSCDMA.
·     TDSCDMA and HSDPA.
·     Unknown.
·     Manual.
·     Automatic.
The MCC is displayed if the modem has found the network.
Cell ID
Radio Information
Network connecting preference:
·     AUTO—Connects to a network automatically.
·     GSM only—Connects to a GSM network only.
·     GSM precedence—Connects to a GSM network with preference.
·     WCDMA only—Connects to a WCDMA network only.
·     WCDMA precedence—Connects to a WCDMA network with preference.
·     TD-SCDMA only—Connects to a TD-SCDMA network only.
·     TD-SCDMA precedence—Connects to a TD-SCDMA network with preference.
·     EVDO—Connects to a CDMA-EVDO network only.
·     1x RTT—Connects to a CDMA-1x RTT network only.
·     1xRTT/EVDO HYBRID—Connects to the CDMA-EVDO and CDMA-1x RTT hybrid networks only.
·     LTE only—Connects to an LTE network only.
Technology Selected
Current network:
·     GSM—Has connected to a GSM network.
·     WCDMA—Has connected to a WCDMA network.
·     TD-SCDMA—Has connected to a TD-SCDMA network.
·     EVDO—Has connected to a CDMA-EVDO network.
·     1Xrtt—Has connected to a CDMA-1x RTT network.
·     1xRTT/EVDO HYBRID—Has connected to the CDMA-EVDO and CDMA-1x RTT networks.
·     LTE—Has connected to an LTE network.
LTE related info
Information about the LTE network.
Current RSSI
Current RSSI:
Current RSRQ
Reference Signal Received Quality.
Current RSRP
Reference Signal Receiving Power.
Current SNR
Signal to noise ratio.
Tx Power
Transmitting power.
Information about modem security.
PIN Verification
·     Disabled.
·     Enabled.
·     Unknown.
PIN Status
PIN status:
SIM Status
SIM card status:
·     Not Initialized—The SIM card status cannot be identified.
ICCID
ID of the SIM card, displayed only when the SIM card status is OK.
mode
pin modify
pin unlock
pin verification enable
pin verify
plmn select
profile create
display controller cellular
Use display controller cellular to display information about cellular interfaces.
display controller [ cellular [ interface-number ] ]
cellular [ interface-number ]: Specifies cellular interfaces or a cellular interface by its number. If you do not specify the cellular keyword, this command displays information about all interfaces. If you specify the cellular keyword but not the interface-number argument, this command displays information about all cellular interfaces.
Hot swapping a USB 3G/4G modem clears the cellular interface statistics.
# Display information about Cellular 2/4/0.
<Sysname> display controller cellular 2/4/0
Cellular2/4/0
Current state: UP
Description: Cellular2/4/0 Interface
Modem status: Present
DM port status: Disabled
Capability:
  1 Control channel, 1 PPP channel
Control channel 0 traffic statistics:
  TX: 0 packets, 0 errors
  RX: 0 packets, 0 errors
PPP channel 0 traffic statistics:
Table 5 Command output
Cellular2/4/0
Current state
Status of the interface:
·     DOWN(Administratively)—The interface has been administratively shut down by using the shutdown command.
·     DOWN—The interface is administratively up but its physical state is down, possibly because of a connection or link failure.
·     UP—The administrative and physical states of the interface are both up.
Description of the interface.
Modem status
Status of the USB 3G/4G modem:
·     Present—The modem is present.
·     Absent—The modem is absent.
DM port status
DM status:
·     Enabled.
·     Disabled.
Capability:
Type and number of channels the cellular interface supports:
·     1 Control channel—Supports one control channel.
·     1 PPP channel—Supports one asynchronous serial subchannel.
·     1 ETH channel—Supports one Ethernet subchannel.
Control channel statistics:
·     TX: 0 packets, 0 errors—Number of packets and number of error packets sent through the control channel.
·     RX: 0 packets, 0 errors—Number of packets and number of error packets received through the control channel.
PPP channel statistics:
·     TX: 0 packets, 0 errors—Number of packets and number of error packets sent through the PPP channel.
·     RX: 0 packets, 0 errors—Number of packets and number of error packets received through the PPP channel.
ETH channel 0 traffic statistics
Ethernet channel statistics:
·     TX: 0 packets, 0 errors—Number of packets and number of error packets sent through the Ethernet channel.
·     RX: 0 packets, 0 errors—Number of packets and number of error packets received through the Ethernet channel.
reset counters controller cellular
dm-port open
Use dm-port open to enable diagnostic and monitoring (DM) on a 3G/4G modem.
Use undo dm-port open to disable DM on a 3G/4G modem.
dm-port open
undo dm-port open
The default setting for this command depends on the modem model.
Enabling DM on a 3G/4G modem allows third-party debugging tools to diagnose and monitor the 3G/4G modem through cellular interface debugging output.
# Enable DM on a 3G/4G modem.
[Sysname-Cellular2/4/0] dm-port open
mode
Use mode to specify network services for a 3G/4G modem.
mode { 1xrtt | auto | evdo | gsm | gsm-precedence | hybrid | lte | td | td-precedence | wcdma | wcdma-precedence }
1xrtt: Connects to a CDMA-1x RTT network only.
auto: Connects to a network automatically.
evdo: Connects to a CDMA-EVDO network only.
gsm: Connects to a GSM network only.
gsm-preference: Connects to a GSM network with preference.
hybrid: Connects to the CDMA-EVDO and CDMA-1xRTT networks only.
lte: Connects to an LTE network only.
td: Connects to a TD-SCDMA network only.
td-preference: Connects to a TD-SCDMA network with preference.
wcdma: Connects to a WCDMA network only.
wcdma-preference: Connects to a WCDMA network with preference.
The available parameters depend on the modem model.
# Specify the LTE service for the 4G modem.
[Sysname-Cellular2/4/0] mode lte
modem reboot
Use modem reboot to reboot a 3G/4G modem.
modem reboot
A 3G/4G modem module can automatically detect running errors and reboot. If the 3G/4G modem fails to reboot by itself, you can use this command to reboot it.
# Manually reboot the 3G/4G modem.
[Sysname-Cellular2/4/0] modem reboot
modem response
Use modem response to set a 3G/4G modem response timer and a consecutive response failure threshold for auto recovery.
Use undo modem response to restore the default.
modem response timer time auto-recovery threshold
undo modem response
The response timer is 10 seconds and the consecutive response failure threshold is 3.
timer time: Sets the response timer, in the range of 1 to 300, in seconds.
auto-recovery threshold: Specifies the consecutive response failure threshold for auto recovery. The value range for the threshold argument is 0 to 10. To disable auto recovery, set the value to 0.
A 3G/4G modem might malfunction in an unstable 3G/4G network or when the application environment changes. During a malfunction, the modem cannot respond to the device's requests or configuration commands. If the device does not receive any responses from the 3G/4G modem within the timer, a response failure occurs. When the number of consecutive response failures reaches the threshold, the device restarts the 3G/4G modem automatically. This releases the user from manually rebooting the modem.
The device does not restart the 3G/4G modem when the 3G/4G modem has not made a successful dialup since the last restart. This restriction avoids repeated restarts of the 3G/4G modem when there are configuration errors.
# Set the response timer to 20 seconds and the consecutive response failure threshold for auto recovery to 4.
[Sysname-Cellular2/4/0] modem response timer 20 auto-recovery 4
pin modify
Use pin modify to modify the PIN of a SIM/UIM card.
pin modify current-pin new-pin
current-pin: Specifies the current PIN of the SIM/UIM card, a string of 4 to 8 digits.
new-pin: Specifies the new PIN, a string of 4 to 8 digits.
The new PIN is saved on the SIM/UIM card.
If PIN verification is enabled, execute the pin verify command to save the new PIN on the device after the PIN is modified.
Failure to modify the PIN in a maximum number of attempts locks the SIM/UIM card. The maximum number of attempts depend on the 3G/4G modem model. To unlock the card, execute the pin unlock command.
For some 3G/4G modems, you can modify their PINs only when the 3G/4G modems pass the PIN authentication.
# Modify the PIN of a SIM/UIM card.
[Sysname-Cellular2/4/0] pin modify 1234 4321
PIN will be changed to “4321”. Continue? [Y/N]:y
PIN has been changed successfully.
pin unlock
pin verify
pin unlock
Use pin unlock to specify the Personal Unlock Code (PUK) to unlock a SIM/UIM card.
pin unlock puk new-pin
puk: Specifies the PUK of the SIM/UIM card, a string of 4 to 8 digits. The PUK code of a SIM/UIM card is provided by the network service provider.
A SIM/UIM card will be locked in the following circumstances:
·     Consecutive PIN modification failures.
·     Consecutive failures for enabling or disabling PIN authentication.
·     Consecutive PIN authentication failures.
If the SIM/UIM card is locked, the 3G modem cannot be used. To unlock the card, you can use the pin unlock command. The new PIN is saved on the SIM/UIM card.
If PIN verification is enabled, use the pin verify command to save the new PIN on the device after the SIM/UIM card is unlocked.
If you consecutively fail to unlock a card by using the PUK, the card will be locked permanently. To unlock a permanently locked card, contact the service provider of the card.
# Use the PUK to unlock a SIM/UIM card.
[Sysname-Cellular2/4/0] pin unlock 87654321 1234
PIN will be unlocked and changed to “1234”. Continue? [Y/N]:y
PIN has been unlocked and changed successfully.
pin modify
Use pin verification enable to enable PIN verification for a 3G/4G modem.
Use undo pin verification enable to disable PIN verification for a 3G/4G modem.
pin verification enable [ pin ]
undo pin verification enable [ pin ]
pin: Specifies the PIN of the SIM/UIM card, a string of 4 to 8 digits.
If PIN verification is enabled, PIN verification is performed after you perform any of the following tasks:
·     Install a 3G/4G modem.
·     Reboot the device.
·     Execute the modem reboot command to reboot a 3G/4G modem.
·     Hot swap a USB 3G/4G modem.
·     Cold boot the device where a SIC-3G/4G modem is installed.
To perform PIN verification, you also need to execute the pin verify command to save the PIN of the SIM/UIM card on the device. After the PIN is saved on the device, the PIN is used for verification automatically when required.
You might be required to provide the current PIN when you enable or disable PIN verification. Consecutive failures for enabling or disabling PIN verification lock a SIM/UIM card. To unlock the card, execute the pin unlock command.
For some 3G/4G modems, you can disable PIN verification only when the 3G/4G modems pass PIN authentication.
# Enable PIN authentication.
[Sysname-Cellular2/4/0] pin verification enable 1234
pin unlock
pin verify
pin verify
Use pin verify to specify the PIN of a SIM/UIM card on a 3G/4G modem.
Use undo pin verify to restore the default.
pin verify { cipher | simple } string
undo pin verify
No PIN is specified for a SIM/UIM card.
cipher ciphered-pin: Specifies a PIN in encrypted form.
simple pin: Specifies a PIN in plaintext form. For security purposes, the PIN specified in plaintext form will be stored in encrypted form.
string: Specifies the PIN. Its plaintext form is 4 to 8 digits long. Its encrypted from is a string of 37 to 41 characters.
This command saves the PIN of the SIM/UIM card on the device. The PIN is used for verifying the 3G/4G modem when PIN verification is performed. You can execute this command before or after you enable PIN verification.
Consecutive PIN verification failures might lock a SIM/UIM card. To unlock the card, execute the pin unlock command.
# Specify the plaintext form PIN 1234 for the SIM/UIM card.
[Sysname-Cellular2/4/0] pin verify simple 1234
pin unlock
plmn search
Use plmn search to search for available mobile networks.
plmn search
Before you use a 3G/4G modem to access a mobile network, use the plmn search command to search a PLMN for available mobile networks. The search takes a few minutes. After the search is complete, the CLI displays the available mobile networks. Some 3G/4G modems automatically access an available network. You can also specify a mobile network for the 3G/4G modem from the available mobile networks.
# Search for mobile networks on Cellular 2/4/0.
[Sysname-Cellular2/4/0] plmn search
PLMN search done.
Available PLMNs:
PLMN No.     MCC    MNC    Status     Type
01           460    00     Current    GSM
02           460    00     Available  UTRAN
03           460    01     Forbidden  GSM
Table 6 Command output
PLMN No
PLMN number.
MCC
Mobile Country Code.
MNC
Mobile Network Code:
·     00, 02, and 07—China Mobile.
·     01China Unicom.
·     03—China Telecom.
Status
Status of the mobile network:
·     Current.
·     Available.
·     Forbidden.
Type of the mobile network.
display cellular
plmn select
plmn select
Use plmn select to configure the mobile network selection mode.
plmn select { auto | manual mcc mnc }
auto: Specifies the auto selection mode. The 3G modem automatically selects a mobile network.
manual: Specifies the manual selection mode.
mcc: Specifies the mobile country code (MCC) in the range of 0 to 65535.
mnc: Specifies the mobile network code (MNC) in the range of 0 to 65535.
For manual selection, you can first use the plmn search command to obtain the MCC and MNC of a mobile network.
# Manually specify a mobile network.
[Sysname-Cellular2/4/0] plmn select manual 65524 65524
display cellular
plmn search
Use reset counters controller cellular to clear statistics on cellular interfaces.
reset counters controller cellular [ interface-number ]
cellular [ interface-number ]: Specifies cellular interfaces or a cellular interface by its number. If you do not specify the interface-number argument, this command clears statistics on all cellular interfaces. If you specify the interface-number argument, this command clears statistics on the specified cellular interface.
To collect traffic statistics on an interface during a period of time, first use the reset counters controller cellular command to clear the existing statistics on the interface.
# Clear statistics on Cellular 2/4/0.
<Sysname> reset counters controller cellular 2/4/0
rssi
Use rssi to set the RSSI thresholds for a 3G/4G modem.
Use undo rssi to restore the default.
rssi { 1xrtt | evdo | gsm | lte } { low lowthreshold | medium mediumthreshold } *
undo rssi { 1xrtt | evdo | gsm | lte } [ low | medium ]
The lower and upper RSSI thresholds for a 3G/4G modem are –150 dBm and 0 dBm, respectively.
1xrtt: Specifies the 1xRTT mode.
evdo: Specifies the EVDO mode.
gsm: Specifies the GSM mode.
lte: Specifies the LTE mode.
low lowthreshold: Specifies the lower RSSI threshold value in the range of 0 to 150, which represents a lower RSSI threshold in the range of –150 dBm to 0 dBm. The value of lowthreshold cannot be smaller than the value of mediumthreshold because the system automatically adds a negative sign to the RSSI thresholds.
medium mediumthreshold: Specifies the upper RSSI threshold value in the range of 0 to 150, which represents an upper RSSI threshold in the range of –150 dBm to 0 dBm.
The device performs the following operations based on the actual RSSI of the 3G/4G modem:
·     Sends a trap that indicates high RSSI when the RSSI exceeds the upper threshold.
·     Sends a trap that indicates normal RSSI when the RSSI is between the lower threshold and upper threshold (included).
·     Sends a trap that indicates low RSSI when the RSSI drops to or below the lower threshold.
·     Sends a trap that indicates low RSSI every 10 minutes when the RSSI remains equal to or smaller than the lower threshold.
To view the RSSI change information for a 3G/4G modem, use the display cellular command.
# Set the lower threshold for a 3G/4G modem in GSM mode to –110 dBm.
[Sysname] controller cellular 0/0
[Sysname-Cellular0/0] rssi gsm low 110
sendat
Use sendat to issue a configuration directive to a 3G/4G modem.
sendat at-string
at-string: Specifies a configuration directive string, a string of 1 to 300 characters. This argument can be an AT directive (containing +++, A/, or be any string beginning with AT) or a CNS directive. For more information about AT directives, see the sendat command in Layer 2—WAN Access Command Reference. Table 7 describes the CNS directive samples. The format of this argument depends on the device model.
Table 7 CNS directive description
Directive
CNSn
Controls the CNS heartbeat debugging switch.
·     n = 00000500000000000000—Enables CNS heartbeat debugging.
·     n = 00000800000000000000—Disables CNS heartbeat debugging.
The sendat command does not verify the configuration directive. Each time it issues one configuration directive to the 3G/4G modem, lowercase characters are automatically converted to uppercase characters.
One sendat command issues one configuration directive. To issue multiple configuration directives to a modem, you must repeat the sendat command.
Configuration directives might cause malfunction of a 3G/4G modem. When you issue a configuration directive to the modem, make sure you understand the impact on the 3G/4G modem.
# Issue the ATD169 directive to the 3G/4G modem to call number 169.
[Sysname-Cellular2/4/0] sendat ATD169
# Issue the cns00000500000000000000 directive to the 3G/4G modem to enable CNS heartbeat debugging.
[Sysname-Cellular2/4/0] sendat cns00000500000000000000
shutdown
Use shutdown to shut down a cellular interface.
Use undo shutdown to bring up a cellular interface.
shutdown
The cellular interface is up.
# Shut down Cellular 2/4/0.
[Sysname] interface cellular 2/4/0
[Sysname-Cellular2/4/0] shutdown
sim backup enable track
Use sim backup enable track to associate 3G/4G link backup with a track entry.
Use undo sim backup enable to restore the default.
sim backup enable track entry-number
undo sim backup
3G/4G link backup is not associated with a track entry.
entry-number: Specifies a track entry by its ID in the range of 1 to 1024.
This command uses a track entry to monitor the status of the primary 3G/4G link. When the track entry state changes from Positive to Negative, the secondary 3G/4G link takes over. For information about track entries, see track configuration in High Availability Configuration Guide.
You can associate only one track entry with a 3G/4G link. If you execute this command multiple times, the most recent configuration takes effect.
The association takes effect only after the track entry is created.
# Associate Cellular 1/0 with track entry 1.
<sysname> system
[system] controller cellular 1/0
[system-Cellular1/0] sim backup enable track 1
sim switch-back enable
sim switch-to
Use sim switch-back enable to enable automatic switchback to the primary SIM card.
Use undo sim switch-back enable to disable automatic switchback to the primary SIM card.
sim switch-back enable [ wait-time time ]
Automatic switchback to the primary SIM card is disabled.
time: Specifies the length of time for using the secondary SIM card. The value is in the range of 1 to 65535, in minutes. The default value is 60. After the time expires, the device automatically switches back to the primary SIM card.
This command allows the device to automatically switch back to the primary SIM card after the specified length of time for using the secondary SIM card. To avoid frequent primary/secondary switchovers, make sure the link of the primary SIM card can recover after the specified length of time.
# Enable the device to automatically switch back to the primary SIM card after 100 minutes of using the secondary SIM card.
[Sysname] controller cellular 1/0
[Sysname-Cellular1/0] sim switch-back enable wait-time 100
sim switch-to
Use sim switch-to to specify the primary or secondary SIM card.
sim switch-to card-number
The primary SIM card is used.
card-number: Specifies a SIM card by its slot number. The value is 0 or 1. 0 represents the primary SIM card. 1 represents the secondary SIM card.
CAUTION
CAUTION:
This command might cause traffic interruption. Be aware of the impact of this command before executing it.
On a device that uses dual SIM card, you can execute this command to specify the use of the secondary SIM card when one of the following problems occurs:
·     The 3G/4G link signals of the primary SIM card are weak.
·     The service provider network that the primary SIM card connects to is unavailable.
·     The primary SIM card has failed.
If the problems of the primary SIM card are resolved, you can use this command to specify the use of the primary SIM card.
# Specify the secondary SIM card for the device.
[Sysname-Cellular1/0] sim switch-to 1
trust-imsi
Use trust-imsi to configure a trusted IMSI.
Use undo trust-imsi to remove a trusted IMSI.
trust-imsi string-imsi
undo trust-imsi [ string-imsi ]
No trusted IMSI is configured.
string-imsi: Specifies an IMSI. The string-imsi argument is a case-insensitive string of 1 to 31 characters.
For a successful dialup, configure the IMSI of the SIM card as a trusted IMSI.
You can configure a maximum of 16 trusted IMSIs.
# Configure trusted IMSI hccc123456789 for Cellular 0/0.
[Sysname-Cellular0/0] trust-imsi hccc123456789
3G modem-specific management commands
gsm band
Use gsm band to specify a GSM frequency band.
Use undo gsm band to restore the default.
gsm band { egsm900 | gsm450 | gsm480 | gsm750 | gsm850 | gsm1800 | gsm1900 | pgsm900 | rsgm900 }
undo gsm band
No GSM band is specified.
egsm900: Specifies the E-GSM 900 MHz band.
gsm450: Specifies the GSM 450 MHz band.
gsm480: Specifies the GSM 480 MHz band
gsm750: Specifies the GSM 750 MHz band.
gsm850: Specifies the GSM 850 MHz band.
gsm1800: Specifies the GSM 1800 MHz band.
gsm1900: Specifies the GSM 1900 MHz band.
pgsm900: Specifies the P-GSM 900 MHz band.
rgsm900: Specifies the GSM-R 900 MHz band.
This command is supported only by Sierra MC7354 (ATT version) and MC7304 4G modules.
Multiple frequency bands are available for accessing the GSM network. When the network environment changes, the 3G/4G modem might change the working band automatically to adapt to the change. To avoid link instability caused by frequency changes, you can specify a GSM band for the 3G/4G modem.
# Specify the GSM 1800 MHz band for the 3G/4G modem.
[Sysname-Cellular0/0] gsm band gsm1800
lte band
wcdma band
profile create
Use profile create to create a profile for the 3G modem.
profile create profile-number { dynamic | static apn } authentication-mode { none | { chap | pap } user username [ password password ] }
profile-number: Specifies a profile number. The value range varies by the modem model.
dynamic: Uses an access point automatically assigned by the service provider.
static apn: Specifies the access point provided by the service provider. It is a string of 1 to 100 characters. Whether the string is case-sensitive varies by service providers.
authentication-mode: Specifies the authentication mode, which can be none, pap, or chap.
none: Performs no authentication.
chap: Specifies CHAP authentication.
pap: Specifies PAP authentication.
user username: Specifies the username provided by the service provider. It is a case-sensitive string of 1 to 32 characters.
password password: Specifies the authentication password provided by the service provider. It is a case-sensitive string of 1 to 32 characters.
If you specify chap or pap, make sure the authentication settings are identical to those assigned by the service provider.
# Create a profile for Cellular 2/4/0. Specify the profile number as 1 and the access point name as cmnet, and specify the PAP authentication mode.
[Sysname-Cellular2/4/0] profile create 1 static cmnet authentication-mode pap user abc password abc
display cellular
profile delete
profile delete
Use profile delete to delete a profile for the 3G modem.
profile delete profile-number
profile-number: Specifies a profile by its number. The value range varies by the modem model.
# Delete profile 1 for Cellular 2/4/0.
[Sysname-Cellular2/4/0] profile delete 1
display cellular
profile create
profile main
Use profile main to specify the primary and backup profiles for 3G modem dialup.
Use undo profile main to restore the default.
profile main profile-M-number backup profile-B-number
undo profile main
Profile 1 is used for 3G modem dialup.
main profile-M-number: Specifies the primary profile by its number. The value range varies by the modem model.
backup profile-B-number: Specifies the backup profile by its number. The value range varies by the modem model.
The primary profile always has priority over the backup profile. For each dialup connection establishment, the 3G modem uses the backup profile only when it has failed to dial up using the primary profile.
You must configure the same user name and password for the primary and backup profiles.
This command takes effect only on dialup connections initiated after the command is configured. It does not take effect on a dialup connection that has been established.
# Specify the profiles numbered 1 and 2 as the primary and backup profiles, respectively.
<sysname>system-view
[sysname]interface Cellular 2/4/0
[sysname-Cellular2/4/0]profile main 1 backup 2
serial-set
Use serial-set to channelize a cellular interface into a synchronous/asynchronous serial interface.
Use undo serial-set to delete a synchronous/asynchronous serial interface channelized from a cellular interface.
serial-set set-number
undo serial-set set-number
set-number: Specifies the serial interface number. The value range and the default setting for this argument depend on the device model.
The command names the serial interface as serial cellular-number:set-number.
# Channelize Cellular 2/4/0 into a serial interface.
[Sysname-Cellular2/4/0] serial-set 0
wcdma band
Use wcdma band to specify a WCDMA band.
Use undo wcdma band to restore the default.
wcdma band { wcdma800 | wcdma850 | wcdma900 | wcdma1700ip | wcdma1700us | wcdma1800 | wcdma1900 | wcdma2100 | wcdma2600 }
undo wcdma band
No WCDMA band is specified.
wcdma800: Specifies the WCDMA 800 MHz band.
wcdma850: Specifies the WCDMA 850 MHz band.
wcdma900: Specifies the WCDMA 900 MHz band.
wcdma1700jp: Specifies the Japan WCDMA 1700 MHz band.
wcdma1700us: Specifies the US WCDMA 1700 MHz band.
wcdma1800: Specifies the WCDMA 1800 MHz band.
wcdma1900: Specifies the WCDMA 1900 MHz band.
wcdma2100: Specifies the WCDMA 2100 MHz band.
wcdma2600: Specifies the WCDMA 2600 MHz band.
Multiple frequency bands are available for accessing the WCDMA network. When the network environment changes, the 3G/4G modem might change the working band automatically to adapt to the change. To avoid link instability caused by frequency changes, you can specify a WCDMA band for the 3G/4G modem.
# Specify the WCDMA 1700 MHz band for the 3G/4G modem.
[Sysname-Cellular0/0] wcdma band wcdma1700
gsm band
lte band
4G modem-specific management commands
apn
Use apn to specify an access point name (APN) for a 4G modem.
Use undo apn to remove an APN.
apn { dynamic | static apn }
undo apn
No APN is specified for a 4G modem.
4G modem profile view
dynamic: Uses an APN automatically assigned by the service provider.
static apn: Specifies the APN provided by the service provider. The apn argument is a string of 1 to 100 characters. Whether the string is case-sensitive depends on the service provider.
# Specify APN apn1 for 4G modem profile test.
[Sysname] apn-profile test
[Sysname-apn-profile-test] apn static apn1
apn-profile
apn-profile
Use apn-profile to create a 4G modem profile.
Use undo apn-profile to remove a 4G modem profile.
apn-profile profile-name
undo apn-profile profile-name
No 4G modem profile exists.
profile-name: Specifies a 4G modem profile name.
A 4G modem profile takes effect only after you apply the profile to a 4G interface. To remove a 4G modem profile, you must first remove the association between the profile and the 4G interface.
# Create 4G modem profile test.
apn-profile apply
apn-profile apply
Use apn-profile apply to specify 4G modem profiles for an interface.
Use undo apn-profile apply to restore the default.
apn-profile apply profile-name [ backup profile-name ]
No 4G modem profiles are specified for an interface.
Eth-channel interface view
profile-name: Specifies a primary 4G modem profile name.
backup profile-name: Specifies a backup 4G modem profile name.
After you specify a 4G modem profile for a 4G modem, the 4G modem uses the settings in the profile to negotiate with the service provider's device.
A primary profile always has priority over a backup profile. For each dialup connection establishment, the 4G modem uses the backup profile only when it has failed to dial up using the primary profile.
# Specify primary 4G modem profile test and backup 4G modem profile bktest for Eth-channel interface 2/4/0:0.
[Sysname] interface eth-channel 2/4/0:0
[Sysname-Eth-channel2/4/0:0] apn-profile apply test backup bktest
apn-profile
attach-format imsi-sn split
Use attach-format imsi-sn split to specify a delimiter for the IMSI/SN binding authentication information.
Use undo attach-format imsi-sn split to restore the default.
attach-format imsi-sn split splitchart
No delimiter is specified for the IMSI/SN binding authentication information.
split splitchart: Specifies a delimiter. It can be a letter, a digit, or a sign such as a percent sign (%) or a pound sign (#).
If IMSI/SN binding authentication is enabled, the IMSI/SN information is included in the authentication information in addition to the username. You need to configure a delimiter to separate different types of information. For example, if you specify the delimiter as #, the authentication information will be sent in the imsiinfo#sninfo#username format.
# Configure the pound sign (#) as the delimiter for the IMSI/SN binding authentication information.
[Sysname-apn-profile-test] attach-format imsi-sn split #
apn-profile
authentication-mode
Use authentication-mode to specify an authentication mode for accessing a 4G network.
Use undo authentication-mode to restore the default.
authentication-mode { pap | chap| pap-chap } user user-name password { cipher | simple } string
No authentication mode is specified for accessing a 4G network.
pap-chap: Specifies CHAP or PAP authentication.
user username: Specifies the username for authentication, a case-sensitive string of 1 to 32 characters.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters
# Specify the CHAP authentication mode for 4G modem profile test. Specify the username as user1 and the password as 123456.
[Sysname-apn-profile-test] authentication-mode chap user user1 password simple 123456
apn-profile
bandwidth
Use bandwidth to configure the expected bandwidth for an Eth-channel interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth for an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth for Eth-channel 2/4/0:0 to 1000 kbps.
[Sysname-Eth-channel2/4/0:0] bandwidth 1000
default
Use default to restore the default settings for an interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command before using it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands. Then, use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Eth-channel 2/4/0:0.
[Sysname-Eth-channel2/4/0:0] default
description
The description for an interface is in the interface name Interface format, for example, Echannel 2/4/0:0 Interface.
Configure the description of an interface for easy identification and management purposes.
You can use the display interface command to view the description for an interface.
# Configure the description for Eth-channel 2/4/0:0 as Echannel-interface.
[Sysname-Eth-channel2/4/0:0] description Echannel-interface
display interface eth-channel
Use display interface eth-channel to display information about the specified or all Eth-channel interfaces.
display interface [ eth-channel [ channel-id ] ] [ brief [ description | down ] ]
eth-channel [ channel-id ]: Specifies Eth-channel interfaces or an Eth-channel interface by its number. If you do not specify the eth-channel keyword, the command displays information about all interfaces. If you specify the eth-channel keyword but not the channel-id argument, this command displays information about all Eth-channel interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Eth-channel 2/4/0:0, including its operating status.
<Sysname> display interface eth-channel 2/4/0:0
Echannel2/4/0:0
Current state: DOWN
Line protocol state: DOWN
Description: Echannel2/4/0:0 Interface
Bandwidth: 100000kbps
Maximum Transmit Unit: 1500
Internet protocol processing: disabled
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 000c-2963-b75d
IPv6 Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 000c-2963-b75d
Last link flapping: Never
Last 300 seconds input rate 0.00 bytes/sec, 0.00 packets/sec
Last 300 seconds output rate 0.00 bytes/sec, 0.00 packets/sec
Input: 0 packets, 0 bytes, 0 buffers
Output:0 packets, 0 bytes
# Display brief information about Eth-channel 2/4/0:0.
<Sysname> display interface eth-channel 2/4/0:0 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface            Link Protocol Main IP         Description
Echannel2/4/0:0      UP   UP(s)    192.168.80.239
# Display information about all Eth-channel interfaces in down state and the causes.
<Sysname> display interface eth-channel brief down
Echannel2/4/0:0      ADM  Administratively
Table 8 Command output
Current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces.
Description for the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
The interface is not assigned an IP address and cannot process IP packets.
Internet Address is 192.168.1.200/24 Primary
IP address of the interface. The primary attribute indicates that the address is the primary IP address..
IPv4 packet framing format.
Hardware Address
MAC address of the interface.
IPv6 packet framing format.
Packet statistics for urgent queuing in the output queue of the interface:
·     Size—Current number of packets in the queue.
·     Length—Maximum number of packets that can stay in the queue.
·     Discards—Number of dropped packets.
Packet statistics for protocol queuing in the output queue of the interface:
Packet statistics for FIFO queuing in the output queue of the interface:
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
Time when statistics on the logical interface were last cleared by using the reset counters interface command.
If the statistics of the interface have never been cleared by using the reset counters interface command since the device started, this field displays Never.
Average input rate during the last 300 seconds:
·     bytes/sec—Average number of received bytes per second.
·     bits/sec—Average number of received bits per second.
·     packets/sec—Average number of received packets per second.
Average output rate over the last 300 seconds:
·     bytes/sec—Average number of sent bytes per second.
·     bits/sec—Average number of sent bits per second.
·     packets/sec—Average number of sent packets per second.
Incoming packet statistics:
·     0 packets—Packet number.
·     0 bytes—Packet size in bytes.
·     0 buffers—Number of buffered units.
Output: 0 packets, 0 bytes
Outgoing packet statistics:
Link
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol of the interface is up.
·     DOWN—The data link layer protocol of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces.
Main IP
Main IP address of the interface.
Cause
Cause for the physical link state of the interface to be DOWN. The value of the field varies by device model.
Administratively represents that the interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
eth-channel
Use eth-channel to channelize a cellular interface into an Eth-channel interface.
Use undo eth-channel to remove the Eth-channel interface channelized from a cellular interface.
eth-channel channel-number
undo eth-channel channel-number
channel-number: Specifies an Eth-channel interface by its number. The value range for this argument varies by device model.
This command names the Eth-channel interface channelized from a cellular interface as eth-channel cellular-number:channel-number.
# Channelize Cellular 2/4/0 into an Eth-channel interface.
[Sysname-Cellular2/4/0] eth-channel 0
imsi bind
Use imsi bind to bind the IMSI on the SIM card to an interface.
Use undo imsi bind to restore the default.
imsi bind interface-type interface-number
undo imsi bind
The IMSI on the SIM card is not bound to any interface.
interface-type interface-number: Specifies an interface by its type and number. In the current software version, the IMSI on the SIM card can only be bound to an L2TP virtual PPP interface.
This feature is not available for distributed devices or devices operating in IRF mode.
The device must support PPP LCP negotiation of the IMSI/SI when it acts as a LAC to access the LNS in LAC-auto-initiated mode. After you bind the IMSI on the SIM card to a virtual PPP interface, the packets sent by the device carry the IMSI.
# Bind the IMSI on the SIM card to Virtual-PPP 1.
[Sysname] controller Cellular 0/0
[Sysname-Cellular0/0] imsi bind virtual-ppp 1
Use interface eth-channel to enter Eth-channel interface view.
interface eth-channel interface-number
interface-number: Specifies an Eth-channel interface by its number.
# Enter Eth-channel 2/4/0:0 interface view.
ip address cellular-alloc
Use ip address cellular-alloc to enable an Eth-channel interface to obtain an IP address by using the modem-manufacturer's proprietary protocol.
Use undo ip address cellular-alloc to restore the default.
An Eth-channel interface does not obtain an IP address by using the modem-manufacturer's proprietary protocol.
To enable an interface to obtain an IP address from the modem by using the modem-manufacturer's proprietary protocol, use the ip address cellular-alloc command.
To enable an interface to obtain an IP address from the modem by using DHCP, use the ip address dhcp-alloc command.
The IP address of the modem is automatically allocated by the service provider.
# Channelize Cellular 2/4/0 into an Eth-channel interface. Enable the Eth-channel interface to obtain an IP address by using the modem-manufacturer's proprietary protocol.
[Sysname-Cellular2/4/0] quit
[Sysname-Eth-channel2/4/0:0] ip address cellular-alloc
ipv6 address cellular-alloc
Use ipv6 address cellular-alloc to enable an interface to obtain an IPv6 address by using the modem-manufacturer's proprietary protocol.
Use undo ipv6 address cellular-alloc to restore the default.
An interface does not obtain an IPv6 address by using the modem-manufacturer's proprietary protocol.
To enable an interface to obtain an IPv6 address by using the modem-manufacturer's proprietary protocol, use the ipv6 address cellular-alloc command.
To enable an interface to obtain an IP address by using DHCP, use the ipv6 address dhcp-alloc command.
The IPv6 address of the modem is automatically allocated by the service provider.
# Channelize Cellular 2/4/0 into an Eth-channel interface. Enable the Eth-channel interface to obtain an IPv6 address by using the modem-manufacturer's proprietary protocol.
[Sysname-Eth-channel2/4/0:0] ipv6 address cellular-alloc
lte band
Use lte band to specify a band for a 4G modem.
Use undo lte band to restore the default.
lte band band-number
undo lte band
The default setting for this command varies by 4G modem model.
band-number: Specifies a band for a 4G modem. The available bands vary by modem model.
This command is supported by the following 4G modems:
·     Sierra MC7354 and MC7304.
·     Long Sung U8300C, U8300W, and U8300.
·     WNC DM11-2.
# Specify band 3 for Cellular 2/4/0.
[Sysname-Controller-Cellular2/4/0] lte band 3
mtu
Use mtu to set the maximum transmission unit (MTU) for an interface.
mtu size
undo mtu
The MTU of an interface is 1500 bytes.
size: Sets the MTU in bytes. The value range for this argument varies by device model.
# Set the MTU for Eth-channel 2/4/0:0 to 1430 bytes.
[Sysname-Eth-channel2/4/0:0] mtu 1430
pdp-type
Use pdp-type to specify the PDP data carrying protocol.
Use undo pdp-type to restore the default.
pdp-type { ipv4 | ipv6 | ipv4v6 }
undo pdp-type
The PDP data carrying protocol is IPv4 and IPv6.
Apn-profile view
ipv4: Specifies the IPv4 protocol.
ipv6: Specifies the IPv6 protocol.
ipv4v6: Specifies the IPv4 and IPv6 protocols.
# Specify the PDP data carrying protocol as IPv4.
[Sysname] apn-profile 1
[Sysname-apn-profile-1] pdp-type ipv4
Use reset counters interface to clear the statistics on the specified or all Eth-channel interfaces.
reset counters interface [ eth-channel [ channel-id ] ]
eth-channel [ channel-id ]: Specifies Eth-channel interfaces or an Eth-channel interface by its number. If you do not the eth-channel keyword, the command clears statistics on all interfaces. If you specify the eth-channel keyword but not the channel-id argument, this command clears statistics on all Eth-channel interfaces. If you specify both the eth-channel keyword and the channel-id argument, this command clears statistics on the specified Eth-channel interface.
Use this command to clear history statistics if you want to collect traffic statistics for a specific period.
# Clear the statistics on Eth-channel 2/4/0:0.
<Sysname> reset counters interface eth-channel 2/4/0:0
shutdown
Use shutdown to shut down an Eth-channel interface.
Use undo shutdown to bring up an Eth-channel interface.
shutdown
The default setting for this command depends on the device model.
# Shut down Eth-channel 2/4/0:0.
[Sysname-Eth-channel2/4/0:0] shutdown
