01-Installation Guide | 5.47 MB |
Examining the installation site
Installing the switch in a 19-inch rack
Rack-mounting the switch by using front mounting brackets
Rack-mounting the switch by using front and rear mounting brackets
Mounting the switch on a workbench
Grounding the switch with a grounding strip
Grounding the switch with a grounding conductor buried in the earth ground
Installing/removing a fan tray
Installing/removing a power module
Installing a PSR150-A1/PSR150-A2/PSR150-D1 power module
Removing a PSR150-A1/PSR150-A2/PSR150-D1 power module
Installing a PSR360-56A/PSR560-56D/PSR720-56A/PSR1110-56A power module
Removing a PSR360-56A/PSR560-56D/PSR720-56A/ PSR1110-56A power module
Connecting the power cord for the built-in AC power module (1)
Connecting the power cord for the built-in AC power module (2)
Connecting a power cord for the built-in DC power module
Connecting the PSR150-A1/PSR150-A2
Connecting the PSR150-D1/PSR560-56D
Connecting the PSR360-56A/PSR720-56A/PSR1110-56A
Installing/removing an expansion card
3 Accessing the switch for the first time
Connecting the switch to a configuration terminal
Connecting a DB9-to-RJ45 console cable
Connecting a USB-to-RJ45 console cable
Connecting a micro USB console cable
Planning IRF fabric size and the installation site
Identifying the master switch and planning IRF member IDs
Planning IRF topology and connections
Identifying physical IRF ports on the member switches
Configuring basic IRF settings
Connecting the physical IRF ports
Verifying the IRF fabric setup
5 Maintenance and troubleshooting
AC and DC concurrent input failure
Removable power module failure
Configuration terminal display problems
1 Preparing for installation
This document is applicable to the following Ethernet switches:
· S5560X-30C-EI
· S5560X-30C-PWR-EI
· S5560X-54C-EI
· S5560X-54C-PWR-EI
· S5560X-30F-EI
· S5560X-30F-EIF
· S5560X-54F-EI
· S5560X-34S-EI
· S5560X-54S-EI
Safety recommendations
To avoid any equipment damage or bodily injury caused by improper use, read the following safety recommendations before installation. Note that the recommendations do not cover every possible hazardous condition.
· Before cleaning the switch, remove all power cords from the switch. Do not clean the switch with wet cloth or liquid.
· Do not place the switch near water or in a damp environment. Prevent water or moisture from entering the switch chassis.
· Do not place the switch on an unstable case or desk. The switch might be severely damaged in case of a fall.
· Ensure good ventilation of the equipment room and keep the air inlet and outlet vents of the switch free of obstruction.
· Connect the yellow-green protection grounding cable before powering on the switch.
· Make sure the operating voltage is as required by the power modules.
· To avoid electrical shocks, do not open the chassis while the switch is operating or when the switch is just powered off.
· When replacing field replaceable units (FRUs), including expansion cards, power modules, and fan trays, wear an ESD wrist strap to avoid damaging the units.
The switch must be used indoors. You can mount your switch in a rack or on a workbench, but make sure:
· Adequate clearance is reserved at the air inlet and outlet vents for ventilation.
· The rack or workbench has a good ventilation system.
· Identify the hot aisle and cold aisle at the installation site, and make sure ambient air flows into the switch from the cold aisle and exhausts to the hot aisle.
· Identify the airflow designs of neighboring devices, and prevent hot air flowing out of the neighboring device from entering the device.
· The rack is sturdy enough to support the switch and its accessories.
· The rack or workbench is reliably grounded.
To ensure correct operation and long service life of your switch, install it in an environment that meets the requirements described in the following subsections.
Temperature/humidity
For correct operation and long service life of your switch, maintain the temperature and humidity in the equipment room at acceptable ranges.
· Lasting high relative humidity can cause poor insulation, electricity leakage, mechanical property change of materials, and metal corrosion.
· Lasting low relative humidity can cause washer contraction and ESD and cause problems including loose mounting screws and circuit failure.
· High temperature can accelerate the aging of insulation materials and significantly lower the reliability and lifespan of the switch.
For the temperature and humidity requirements of the switch, see technical specifications in Hardware Information and Specifications.
Cleanliness
Dust buildup on the chassis might cause electrostatic adsorption and dust corrosion, resulting in poor contact of metal connectors and contact points. This might shorten the device's lifetime and even cause device failure in the worst case. Table1-1 describes the dust concentration limits in the equipment room.
Table1-1 Dust concentration limits in the equipment room
Substance |
Particle diameter |
Concentration limit |
Dust particles |
≥ 0.5 µm |
≤ 3.5 × 106 particles/m3 |
Dust particles |
≥ 5 µm |
≤ 3 × 104 particles/m3 |
Dust (suspension) |
≤ 75 µm |
≤ 0.2 mg/m3 |
Dust (sedimentation) |
75 µm to 150 µm |
≤ 1.5 mg/(m2h) |
To maintain cleanliness in the equipment room, follow these guidelines:
· Keep the equipment room away from pollution sources. Do not smoke, eat, or drink in the equipment room.
· Use double-layer glass in windows and seal doors and windows with dust-proof rubber strips. Use screen doors and window screens for doors and windows open to the outside and make sure the external windows are air tight.
· Use dustproof materials for floors, walls, and ceilings and use wallpaper or matt paint that does not produce powders.
· Clean the equipment room regularly and clean the air filters of the rack each month.
· Wear ESD clothing and shoe covers before entering the equipment room, keep the ESD clothing and shoe covers clean, and change them frequently.
Corrosive gas limit
Corrosive gases can accelerate corrosion and aging of metal components. Make sure the corrosive gases in the equipment room do not exceed the concentration limits as shown in Table1-2.
Table1-2 Corrosive gas concentration limits in the equipment room
Gas |
Average concentration (mg/m3) |
Maximum concentration (mg/m3) |
SO2 |
0.3 |
1.0 |
H2S |
0.1 |
0.5 |
Cl2 |
0.1 |
0.3 |
HCI |
0.1 |
0.5 |
HF |
0.01 |
0.03 |
NH3 |
1.0 |
3.0 |
O3 |
0.05 |
0.1 |
NOX |
0.5 |
1.0 |
CAUTION: As a best practice, control the corrosive gas concentrations in the equipment room at their average values. Make sure the corrosive gas concentrations do not exceed 30 minutes per day at their maximum values. |
To control corrosive gases, use the following guidelines:
· As a best practice, do not build the equipment room in a place with a high concentration of corrosive gases.
· Make sure the equipment room is not connected to sewer, vertical shaft, or septic tank pipelines and keep it far away from these pipelines. The air inlet of the equipment room must be away from such pollution sources.
· Use environmentally friendly materials to decorate the equipment room. Avoid using organic materials that contains harmful gases, such as sulfur or chlorine-containing insulation cottons, rubber mats, sound-proof cottons, and avoid using plasterboards with high sulfur concentration.
· Place fuel (diesel or gasoline) engines separately. Do not place them in the same equipment room with the device. Make sure the exhausted air of the engines will not flow into the equipment room or towards the air inlet of the air conditioners.
· Place batteries separately. Do not place them in the same room with the device.
· Employ a professional company to monitor and control corrosive gases in the equipment room regularly.
EMI
All electromagnetic interference (EMI) sources, from outside or inside of the switch and application system, adversely affect the switch in the following ways:
· A conduction pattern of capacitance coupling.
· Inductance coupling.
· Electromagnetic wave radiation.
· Common impedance (including the grounding system) coupling.
To prevent EMI, use the following guidelines:
· If AC power is used, use a single-phase three-wire power receptacle with protection earth (PE) to filter interference from the power grid.
· Keep the switch far away from radio transmitting stations, radar stations, and high-frequency devices.
· Use electromagnetic shielding, for example, shielded interface cables, when necessary.
· To prevent signal ports from getting damaged by overvoltage or overcurrent caused by lightning strikes, route interface cables only indoors.
Laser safety
WARNING! The switch is Class 1 laser device. Do not stare into any fiber port when the switch has power. The laser light emitted from the optical fiber might hurt your eyes. |
Installation tools
· Flat-blade screwdriver
· Phillips screwdriver
· ESD wrist strap
All these installation tools are user supplied.
2 Installing the switch
CAUTION: Keep the tamper-proof seal on a mounting screw on the chassis cover intact, and if you want to open the chassis, contact H3C for permission. Otherwise, H3C shall not be liable for any consequence. |
Figure2-1 Hardware installation flow
Installation methods
Table2-2 Installation methods for the S5560X-EI switches
Chassis |
Installation methods |
Installation requirements |
Installation procedure |
S5560X-30C-EI S5560X-54C-EI S5560X-30F-EI S5560X-30F-EIF S5560X-54F-EI S5560X-34S-EI S5560X-54S-EI |
Using front mounting brackets |
Install the front mounting brackets at the port side or power module side. |
See "Rack-mounting the switch by using front mounting brackets." |
S5560X-30C-PWR-EI S5560X-54C-PWR-EI |
Using front and rear mounting brackets |
· Install the front mounting brackets at the port side or power module side. · Install the rear mounting brackets based on the rack depth. ¡ If the rack depth is in the range of 429 to 595 mm (16.89 to 23.43 in), orient the bracket with the wide flange inside the rack. ¡ If the rack depth is in the range of 274 to 440 mm (10.79 to 17.32 in) and the distance from the rear rack posts to the inner surface of the cabinet door is longer than 153 mm (6.02 in), orient the bracket with the wide flange outside the rack. |
See "Rack-mounting the switch by using front and rear mounting brackets." |
Figure2-2 Procedure for rack-mounting the switch by using the front mounting brackets
Figure2-3 Procedure for rack-mounting the switch by using the front and rear mounting brackets
NOTE: If a rack shelf is available, you can put the switch on the rack shelf, slide the switch to an appropriate location, and attach the switch to the rack by using the mounting brackets. |
Installation accessories
Table2-3 Installation accessories for the S5560X-EI switches
Switch model |
Front mounting brackets (Figure2-4) |
Rear mounting brackets and shoulder screws (Figure2-5) |
Provided |
N/A |
Provided |
Provided |
Figure2-4 Front mounting bracket
(1) Screw hole for attaching the bracket to the switch |
(2) Screw hole for attaching the bracket to the rack |
(3) M4 screw |
Figure2-5 Rear mounting bracket and shoulder screw
(1) Screw hole for attaching the bracket to the rack |
(2) Shoulder screw |
Attaching the front mounting brackets to the switch
The S5560X-30C-EI, S5560X-54C-EI, S5560X-30F-EI, S5560X-30F-EIF, S5560X-54F-EI, S5560X-34S-EI, and S5560X-54S-EI switches provide two installation positions on the side panels for the front mounting brackets. One is near the power module side and one is near the port side.
To attach the front mounting brackets to the switch:
1. Determine the mounting position for the front mounting brackets.
2. Align the round holes in the wide flange of one front mounting bracket with the screw holes in the chassis. See Figure2-6 and Figure2-7.
3. Use M4 screws (provided with the switch) to attach the mounting bracket to the chassis.
4. Repeat the proceeding two steps to attach the other mounting bracket to the chassis.
Figure2-6 Attaching the front mounting bracket to the port side
Figure2-7 Attaching the front mounting bracket to the power module side
Mounting the switch in the rack
1. Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
2. Make sure the front mounting brackets have been attached securely to the two sides of the switch.
3. Install cage nuts (user-supplied) in the mounting holes in the rack posts. Make sure the corresponding cage nuts on the left and right front rack posts are at the same height.
4. One person holds the switch chassis and aligns the installation holes on the mounting brackets with the cage nuts on the rack posts.
5. The other person attaches the mounting brackets with M6 screws (user-supplied) to the rack.
Figure2-8 Mounting the switch in the rack (front mounting brackets at the port side)
Figure2-9 Mounting the switch in the rack (front mounting brackets at the power module side)
Attaching the front mounting brackets and shoulder screws to the switch
To rack-mount the S5560X-30C-PWR-EI and S5560X-54C-PWR-EI switches by using the front and rear mounting brackets, you can install the front mounting brackets at the port-side or power module-side mounting position. The following uses port-side mounting as an example. The power-side mounting is similar.
To attach the front mounting brackets and shoulder screws to the switch:
1. Align the round holes in the wide flange of one front mounting bracket with the screw holes in the port-side mounting position on one side of the chassis. See Figure2-10.
2. Use M4 screws (supplied with the switch) to attach the mounting bracket to the chassis.
3. Repeat the proceeding two steps to attach the other mounting bracket to the chassis.
4. Unpack the shoulder screws. Attach the shoulder screw to one of the two installation positions as red-marked in Figure2-10.
Figure2-10 Attaching the front mounting brackets and shoulder screws to the chassis
Attaching the rear mounting brackets to the rack
1. Determine the switch installation position in the rack.
2. Install cage nuts in the rack posts. Make sure the corresponding cage nuts on the left and right rear rack posts are at the same height.
3. Orient the rear mounting brackets with the wide flange inside or outside the rack as required.
4. Use M6 screws to attach the rear mounting brackets to the rear posts, as shown in Figure2-11.
Do not fully tighten the M6 screws before mounting the switch in the rack.
Figure2-11 Attaching the rear mounting brackets to a rack with the wide flange inside the rack
Figure2-12 Attaching the rear mounting brackets to a rack with the wide flange outside the rack
2. Make sure the front mounting brackets and shoulder screws are securely attached to the two sides of the switch.
3. Attach cage nuts to the front rack posts. Make sure the corresponding cage nuts on the left and right front rack posts are at the same height.
4. One person supports the chassis bottom with one hand, holds the front part of the chassis with the other hand, and pushes the chassis into the rack gently.
Make sure the shoulder screws make close contact with the upper edges of the rear mounting brackets, as shown in Figure2-13.
5. The other person attaches the front mounting brackets with M6 screws (user-supplied) to the front rack posts.
Make sure the switch is installed securely in the rack.
Figure2-13 Mounting the switch in the rack (with the wide flange of the rear mounting brackets inside the rack)
IMPORTANT: · Reserve a minimum of 10 cm (3.9 in) of clearance around the chassis for heat dissipation. · Do not place heavy objects on the switch. |
To mount the switch on a workbench:
1. Verify that the workbench is sturdy and reliably grounded.
2. Place the switch with bottom up, and clean the round holes in the chassis bottom with dry cloth.
3. Attach the rubber feet to the four round holes in the chassis bottom.
4. Place the switch with upside up on the workbench.
WARNING! Correctly connecting the grounding cable is crucial to lightning protection and EMI protection. |
The power input end of the switch has a noise filter, whose central ground is directly connected to the chassis to form the chassis ground (commonly known as PGND). You must securely connect this chassis ground to the earth to minimize the potential for system damage, maximize the safety at the site, and minimize EMI susceptibility of the system.
You can ground the switch in one of the following ways, depending on the grounding conditions available at the installation site:
· Grounding the switch with a grounding strip
· Grounding the switch with a grounding conductor buried in the earth ground
NOTE: The power and grounding terminals in this section are for illustration only. |
WARNING! · Connect the grounding cable to the grounding strip in the equipment room. Do not connect it to a fire main or lightning rod. · To guarantee the grounding effect and avoid switch damage, use the grounding cable provided with the switch to connect the switch to a grounding strip in the equipment room. |
If a grounding strip is available at the installation site, connect the grounding cable to the grounding strip.
Connecting the grounding cable to the chassis
1. Remove the grounding screw from the rear panel of the switch chassis.
2. Use the grounding screw to attach the ring terminal of the grounding cable to the grounding screw hole. Fasten the screw.
IMPORTANT: Orient the grounding cable as shown in Figure2-15 so you can easily install or remove the expansion card. |
Figure2-15 Connecting the grounding cable to the chassis
(1) Grounding screw |
(2) Ring terminal |
(3) Grounding sign |
(4) Grounding hole |
(5) Grounding cable |
Connecting the grounding cable to a grounding strip (1)
This method is applicable to the S5560X-30C-PWR-EI and S5560X-54C-PWR-EI switches.
To connect the grounding cable to a grounding strip:
1. Remove the hex nut of a grounding post on the grounding strip.
2. Cut the grounding cable to a length required for connecting to the grounding strip.
3. Attach a ring terminal to the grounding cable:
a. Use a wire stripper to strip 5 mm (0.20 in) of insulation off the end of the grounding cable.
b. Slide the heat-shrink tubing onto the cable and insert the bare metal part into the end of the ring terminal.
c. Use a crimper to secure the metal part of the cable to the ring terminal.
d. Slide the heat-shrink tubing down the cable until the tube covers the joint.
e. Use a heat gun to shrink the tubing around the cable.
Figure2-16 Attaching a ring terminal to the grounding cable
4. Connect the ring terminal of the grounding cable to the grounding post of the grounding strip, and fasten it with the removed hex nut.
Figure2-17 Connecting the grounding cable to a grounding strip
(1) Grounding post |
(2) Grounding strip |
(3) Grounding cable |
(4) Hex nut |
Connecting the grounding cable to a grounding strip (2)
This method is applicable to the S5560X-30C-EI, S5560X-54C-EI, S5560X-30F-EI, S5560X-30F-EIF, S5560X-54F-EI, S5560X-34S-EI, and S5560X-54S-EI switches.
1. Cut the grounding cable to a length required for connecting to the grounding strip.
2. Use a wire stripper to strip 20 mm (0.79 in) of insulation off the end of the grounding cable. Then use needle-nose pliers to bend the bare metal part to the shape as shown in Figure2-18. Make sure the bended part can securely attached to the grounding post on the grounding strip.
3. Attach the bended part of the grounding cable to the grounding post and use the hex nut to fasten the bended part to the post.
Figure2-18 Connecting the grounding cable to the grounding strip
(4) Hex nut |
If the installation site does not have any grounding strips, but earth ground is available, hammer a 0.5 m (1.64 ft) or longer angle iron or steel tube into the earth ground to serve as a grounding conductor.
The dimensions of the angle iron must be a minimum of 50 × 50 × 5 mm (1.97 × 1.97 × 0.20 in). The steel tube must be zinc-coated and its wall thickness must be a minimum of 3.5 mm (0.14 in).
Weld the yellow-green grounding cable to the angel iron or steel tube and treat the joint for corrosion protection.
Figure2-19 Grounding the switch by burying the grounding conductor into the earth ground
(2) Chassis rear panel |
(4) Earth |
(5) Joint |
(6) Grounding conductor |
CAUTION: · Install two fan trays of the same model on the switch. Do not power on the switch when it does not have fan trays or has only one fan tray installed. · Do not leave any slots empty when the switch is operating. Install a module or filler panel in the slots. · If both fan trays fail while the switch is operating, replace them within 2 minutes while the switch is operating. · If one fan tray fails while the switch is operating, perform either of the following tasks: ¡ If the ambient temperature is not higher than 27°C (80.6°F), replace the fan tray within 24 hours and make sure the failed fan tray is in position before the replacement. ¡ If the ambient temperature is higher than 27°C (80.6°F), replace the fan tray immediately. · If you power cycle the switch after a fan tray fails, the switch will fail to start up. |
S5560X-EI switches except the S5560X-34S-EI and S5560X-54S-EI provides fan tray slots and support hot swapping of fan trays.
The switch comes with empty fan tray slots. Choose fan tray models for the switch based on the ventilation requirement of the site. The air flow direction varies by fan tray model.
· The LSPM1FANSA fan tray draws ambient air into the chassis from the power module side and exhausts the air through the port side and chassis sides. The fan tray handle is blue.
· The LSPM1FANSB fan tray draws ambient air into the chassis from the port side and chassis sides and exhausts the air through the power module side. The fan tray handle is red.
For more information about the fan trays, see Hardware Information and Specifications.
Installing a fan tray
CAUTION: To prevent damage to the fan tray or the connectors in the chassis, insert the fan tray gently. If you encounter a hard resistance while inserting the fan tray, pull out the fan tray and insert it again. |
To install a fan tray:
2. Unpack the fan tray and verify that the fan tray model is correct.
3. Grasp the two handles of the fan tray with the side marked TOP facing up, and slide the fan tray along the guide rails into the slot until the fan tray seats in the slot and has a firm contact with the backplane.
Figure2-20 Installing a fan tray
IMPORTANT: · At the first login to the switch, use the fan prefer-direction command to set the airflow direction of the switch to be the same as the airflow direction of the fan tray. If the fan tray has a different airflow direction than the switch, the system outputs traps and logs to notify you to replace the fan tray. · By default, the switch uses the same airflow direction (port-to-power) as the LSPM1FANSB fan tray. |
Removing a fan tray
WARNING! · To avoid bodily injury, disturbing the dynamic balance of the fan tray, and causing loud noises, do not touch the rotation axis, or any bare wires, fan blades, or terminals on the fan tray. · Do not place the fan tray in a moist place. Prevent liquid from entering the fan tray. · Fan trays with faulty internal wiring and conductors require maintenance from maintenance engineers. Do not disassemble the faulty fan trays. |
To remove a fan tray:
2. Grasp the two handles of the fan tray, as shown by callout 1 in Figure2-21, and pull out the fan tray slowly along the guide rails.
3. Put the removed fan tray in an antistatic bag.
Figure2-21 Removing a fan tray
WARNING! In power redundancy mode, you can replace a power module without powering off the switch but you must strictly follow the installation and removal procedures in Figure2-22 and Figure2-23 to avoid any bodily injury or damage to the switch. |
CAUTION: Provide a circuit breaker for each power module. |
Figure2-22 Installation procedure
S5560X-EI switches except the S5560X-34S-EI and S5560X-54S-EI provide power module slots and come with power module slot 1 empty and power module slot 2 installed with a filler panel. You can install one or two power modules for the switch as required.
For the power modules available for the switch and their specifications, see Hardware Information and Specifications.
CAUTION: To prevent damage to the power module or the connectors on the backplane, insert the power module gently. If you encounter a hard resistance when inserting the power module, pull out the power module and insert it again. |
The installation procedure is the same for PSR150-A1, PSR150-A2, and PSR150-D1 power modules. The following procedure uses the PSR150-A1 power module as an example.
To install a PSR150-A1 power module:
2. Remove the filler panel, if any, from the target power module slot as follows:
a. Remove the screws on the filler panel.
b. Use a flathead screwdriver to remove the filler panel.
Figure2-24 Removing the filler panel
3. Unpack the power module and verify that the power module model is correct.
4. Correctly orient the power module with the power module slot (use the letters on the power module faceplate for orientation), grasp the handle of the power module with one hand and support its bottom with the other, and slide the power module slowly along the guide rails into the slot (see callout 1 in Figure2-25).
5. Fasten the captive screws on the power module with a Phillips screwdriver to secure the power module in the chassis (see callout 2 in Figure2-25). If the captive screw cannot be tightly fastened, verify the installation of the power module.
6. Install the filler panel over the empty power module slot to prevent dust and ensure good ventilation if you install only one power module.
Figure2-25 Installing a PSR150-A1 power module
The removal procedure is the same for PSR150-A1, PSR150-A2, and PSR150-D1 power modules. The following procedure uses the PSR150-A1 power module as an example.
To remove a PSR150-A1 power module:
2. Disconnect the power cord.
3. Loosen the captive screws of the power module with a Phillips screwdriver until they are completely disengaged.
4. Grasp the handle of the power module with one hand and pull it out a little, support the bottom with the other hand, and pull the power module slowly along the guide rails out of the slot.
Put away the removed power module in an antistatic bag or the power module package bag for future use.
5. Install the filler panel to prevent dust and ensure good ventilation if no power module is installed in the slot.
The installation procedure is the same for the PSR360-56A, PSR560-56D, PSR720-56A and PSR1110-56A power modules. The following procedure uses the PSR720-56A power module as an example.
To install a PSR720-56A power module:
2. Put your forefinger into the hole in the filler panel, if any, in the target power module slot, and pull out it gently.
Figure2-26 Removing the filler panel
Put away the packaging box and packaging bag of the power module for future use.
4. Correctly orient the power module with the power module slot (use the letters on the power module faceplate for orientation), grasp the handle of the power module with one hand and support its bottom with the other, and slide the power module slowly along the guide rails into the slot until you hear that the latch of the power module clicks into the slot.
When you insert the power module into the slot, you can do that through slight inertia so that the terminals of the power module can have a good contact with the backplane.
5. Install the filler panel over the empty power module slot to prevent dust and ensure good ventilation if you install only one power module.
Figure2-27 Installing the power module
Figure2-28 PSR1110-56A power module installed in the chassis
NOTE: The PSR1110-56A power module adds 64 mm (2.52 in) to chassis depth, which includes the handle of the power module. |
The removal procedure is the same for the PSR360-56A, PSR560-56D, PSR720-56A, and PSR1110-56A power modules. The following procedure uses the PSR720-56A power module as an example.
To remove a PSR720-56A power module:
3. Press the latch towards the handle, and pull the power module along the guide rails until it is part-way out.
4. Grasp the handle of the power module with one hand, support the bottom with the other hand, and pull the power module slowly along the guide rails out of the slot.
Figure2-29 Removing the power module
Table2-4 Power source options and power cord connection procedures for the power modules
Power module model |
Power source option |
Power cord connection procedure |
Fixed power module |
AC power source |
· S5560X-34S-EI and S5560X-54S-EI switches: Connecting the power cord for the built-in AC power module (1) · S5560X-30F-EIF switch: Connecting the power cord for the built-in AC power module (2) |
–48 VDC power source in the equipment room or an RPS (RPS800-A or RPS1600-A) |
PSR150-A1/PSR150-A2 |
AC power source |
PSR150-D1 |
PSR560-56D |
–48 VDC power source in the equipment room or an RPS (RPS1600-A) |
PSR360-56A/PSR720-56A/PSR1110-56A |
AC power source |
CAUTION: · The AC power cord provided with the PSR150-A1/PSR150-A2 power module uses a C13 connector. The AC power cord provided with the PSR360-56A/PSR720-56A/PSR1110-56A power module uses a high-temperature C15 connector. Do not mix them. · Provide a circuit breaker for each power module and make sure the circuit breaker is off before installation. |
The following procedure applies to the S5560X-34S-EI and S5560X-54S-EI switches.
To connect the power cord for the built-in AC power module:
2. Attach two ends of the bail latch into the holes on the two sides of the AC power receptacle, and pull the bail latch upwards (see Figure2-30).
3. Connect the female connector of the AC power cord to the AC-input power receptacle on the power module (see callout 1 in Figure2-31).
4. Pull the bail latch down to secure the connector to the AC-input power receptacle (see callout 2 in Figure2-31).
5. Connect the other end of the power cord to an AC power source.
Figure2-30 Connecting the power cord for the built-in AC power module (1)
Figure2-31 Connecting the power cord for the built-in AC power module (2)
The following procedure applies to the S5560X-30F-EIF switch.
1. Connect the female connector of the AC power cord to the AC-input power receptacle on the power module, as shown in Figure2-32.
2. Use a cable tie to secure the power cord to the cable holder near the AC-input power receptacle on the power module, as shown in Figure2-33.
3. Connect the other end of the power cord to an AC power source.
Figure2-32 Connecting the power cord for the built-in AC power module
Figure2-33 Securing the power cord
WARNING! · The DC-input power receptacle on the switch requires a DC power cord with a JD5-A connector. · To use a –48 VDC power source for power supply, purchase an H3C recommended DC power cord yourself. · To use an RPS for power supply, purchase a power cord compatible with the RPS yourself. · To connect a DC power cord to the –48 VDC power source, identify the positive (+) and negative (-) marks on the two wires of the power cord to avoid connection mistakes. |
To connect a power cord for the built-in DC power module:
2. Use a screwdriver to remove the cover from the DC-input power receptacle.
3. Correctly orient the power cord connector and insert the connector into the DC-input power receptacle. See callout 1 in Figure2-34.
If you cannot insert the connector into the receptacle, re-orient the connector rather than use excessive force to push it in.
4. Tighten the screws on the connector with a flat-blade screwdriver to secure the connector in the DC-input power receptacle. See callout 2 in Figure2-34.
5. Connect the other end of the power cord to the –48 VDC power source or an RPS.
Figure2-34 Connecting a power cord for the built-in DC power module
The power cord connection procedure is the same for the PSR150-A1 and PSR150-A2 power modules. The following procedure uses the PSR150-A1 power module as an example.
To connect the PSR150-A1:
2. Attach two ends of the bail latch (supplied with the power module) into the two holes next to the AC-input power receptacle on the power module, and pull the bail latch leftwards (see Figure2-35).
3. Connect one end of the AC power cord supplied with the power module to the AC-input power receptacle (see callout 1 in Figure2-36).
4. Pull the bail latch rightwards to secure the connector to the power receptacle (see callout 2 in Figure2-36).
Figure2-35 Connecting the PSR150-A1 (1)
Figure2-36 Connecting the PSR150-A1 (2)
CAUTION: · To use a –48 VDC power source for power supply, purchase an H3C recommended DC power cord yourself. · To use an RPS for power supply, purchase a power cord compatible with the RPS yourself. · To connect the power cord to a –48 VDC power source, identify the positive (+) and negative (-) marks on the two wires of the power cord to avoid connection mistakes. |
To connect the PSR150-D1/PSR560-56D:
3. Unpack the DC power cord, correctly orient the connector at one end of the cable with the DC-input power receptacle on the power module, and insert the connector into the power receptacle (see callout 1 in Figure2-37).
The power receptacle is foolproof. If you cannot insert the connector into the receptacle, re-orient the connector rather than use excessive force to push it in.
4. Tighten the screws on the connector with a flat-blade screwdriver to secure the connector in the DC-input power receptacle (see callout 2 in Figure2-37).
5. Connect the two wires at the other end of the power cord to a –48 VDC power source or an RPS.
Figure2-37 Connecting the PSR150-D1
Figure2-38 Connecting the PSR560-56D
The power cord connection procedure is the same for the PSR360-56A, PSR720-56A, and PSR1110-56A power modules. The following procedure uses the PSR720-56A power module as an example.
To connect the PSR720-56A:
2. Plug the female connector end of the AC power cord into the AC-input power receptacle of the power module (see callout 1 in Figure2-39).
3. Use a cable tie to secure the power cord to the handle of the power module (see callout 2 and callout 3 in Figure2-39).
4. Connect the other end of the AC power cord to an AC power source.
Figure2-39 Connecting the PSR720-56A
CAUTION: · Do not touch the surface-mounted components directly with your hands. · Do not use excessive force when you install or remove an expansion card. · Do not install or remove an expansion card on a starting switch. |
S5560X-EI switches except the S5560X-34S-EI and S5560X-54S-EI each provide an expansion slot at the rear. For the expansion cards available for the switch, see Hardware Information and Specifications.
The installation and removal procedure is similar for expansion cards. The following procedure uses the LSWM2SP2PM card (with an ejector lever) and the LSPM6FWD card (without an ejector lever) as examples.
Installing an expansion card
2. Use a Phillips screwdriver to remove the mounting screw on the filler panel over the expansion slot. Then remove the filler panel.
Keep the filler panel for future use.
Figure2-40 Removing the filler panel over the expansion slot
3. Unpack the expansion card.
4. If the expansion card has an ejector lever, follow these steps to install it:
a. Rotate out the ejector lever, as shown by callout 1 in Figure2-41.
b. Gently push the expansion card into the slot along the guide rails until the expansion card has good contact with the chassis. See callout 2 in Figure2-41.
c. Rotate in the ejector lever, as shown by callout 3 in Figure2-41.
d. Use a Phillips screwdriver to tighten the captive screws on the expansion card to secure it in the slot. See callout 4 in Figure2-41.
5. If the expansion card does not have an ejector lever, follow these steps to install it:
a. Gently push the expansion card into the slot along the guide rails until the expansion card has good contact with the chassis. See callout 1 Figure2-42.
b. Use a Phillips screwdriver to tighten the captive screws on the expansion card to secure it in the slot. See callout 2 Figure2-42.
Figure2-41 Installing an expansion card with an ejector lever (LSWM2SP2PM)
Figure2-42 Installing an expansion card without an ejector lever (LSPM6FWD)
Figure2-43 LSPM6FWD firewall card installed in the switch
NOTE: An LSPM6FWD or LSPM6FWD8 firewall card (including its handle) adds 75 mm (2.95 in) to the chassis depth when installed on the device. |
Removing an expansion card
2. Use a Phillips screwdriver to remove the captive screw on the expansion card.
3. (Optional.) If the expansion card has an ejector lever, rotate out the ejector lever.
Skip this step if the expansion card does not have an ejector lever.
4. Gently pull the expansion card out of the chassis along the guide rails.
5. If you are not to install a new expansion card after removing the original one, install a filler panel in the slot to prevent dust and ensure good ventilation in the switch.
Verifying the installation
After you complete the installation, verify the following information:
· There is enough space for heat dissipation around the switch, and the rack or workbench is stable.
· The grounding cable is securely connected.
· The correct power source is used.
· The power cords are correctly connected.
· All the interface cables are cabled indoors. If any cable is routed outdoors, verify that the socket strip with lightning protection and lightning arresters for network ports have been correctly connected.
You can connect the switch to a configuration terminal by using the serial console port or the micro USB console port. Only the micro USB console port takes effect if you connect both the serial console port and micro USB console port.
In Figure3-1, the switch is connected to a configuration terminal (PC as an example) from the serial console port.
Figure3-1 Connecting the switch to a configuration terminal
As shown in Table3-1, three console cables can be used for connecting the switch to a configuration terminal. As a best practice, use a serial console cable for connection. The switch is not provided with a serial console cable or a micro USB console cable. Prepare an H3C console cable or prepare a micro USB console cable yourself.
Table3-1 Connection methods and console cables
Connection method |
Console cable type |
Configuration terminal-side connector |
Switch-side connector |
Using the serial console port for connection |
DB9-to-RJ45 console cable |
DB-9 female connector |
RJ-45 connector |
USB-to-RJ45 console cable |
USB connector |
RJ-45 connector |
Using the micro USB console port for connection |
Micro USB console cable |
USB connector |
Micro USB connector |
CAUTION: Follow these guidelines when you connect a DB9-to-RJ45 console cable: · Identify the mark on the serial console port and make sure you are connecting to the correct port. · The serial ports on PCs do not support hot swapping. To connect a PC to an operating switch, first connect the PC end. To disconnect a PC from an operating switch, first disconnect the switch end. |
A DB9-to-RJ45 serial console cable is an 8-core shielded cable, with a crimped RJ-45 connector at one end for connecting to the serial console port of the switch, and a DB-9 female connector at the other end for connecting to the serial port on the console terminal.
Figure3-2 DB9-to-RJ45 console cable
Table3-2 DB9-to-RJ45 console cable signal pinout
RJ-45 |
Signal |
DB-9 |
Signal |
1 |
RTS |
8 |
CTS |
2 |
DTR |
6 |
DSR |
3 |
TXD |
2 |
RXD |
4 |
SG |
5 |
SG |
5 |
SG |
5 |
SG |
6 |
RXD |
3 |
TXD |
7 |
DSR |
4 |
DTR |
8 |
CTS |
7 |
RTS |
To connect to a configuration terminal (for example, a PC) through a DB9-to-RJ45 console cable:
1. Plug the DB-9 female connector of the DB9-to-RJ45 console cable to the serial port on the PC.
2. Connect the RJ-45 connector to the serial console port on the switch.
IMPORTANT: · To use a USB-to-RJ45 console cable to connect the switch to a configuration terminal, first download and install the USB-to-RJ45 console driver on the configuration terminal and then connect the USB-to-RJ45 console cable to the configuration terminal. · If you have connected a USB-to-RJ45 console cable to the configuration terminal before driver installation, you must remove and reconnect the USB-to-RJ45 console cable to the configuration terminal. |
Figure3-3 USB-to-RJ45 console cable
The following installs the driver on the Windows system. To install the driver on other operating systems, see the installation guide in the driver compression package named by the corresponding operating system.
To connect the switch to the configuration terminal through a USB-to-RJ45 console cable:
1. Click the following link, or copy it to the address bar on your browser and download the USB-to-RJ45 console driver.
http://www.h3c.com/en/home/USB_to_RJ45_Console/
2. View the TXT file Read me in the Windows folder to check whether the Windows system of the configuration terminal supports the driver.
3. If the Windows system supports the driver, install PL23XX-M_LogoDriver_Setup_v200_20190815.exe.
4. Click Next on the welcome page of the driver installation wizard.
Figure3-4 Driver installation wizard
5. Click Finish after the drive installation is completed.
Figure3-5 Finishing the driver installation
6. Connect the standard USB connector of the cable to the USB port of the configuration terminal.
7. Connect the RJ-45 connector of the cable to the console port of the switch.
A micro USB console cable has a micro USB Type B connector at one end to connect to the micro USB console port of the switch, and a standard USB Type A connector at the other end to connect to the USB port on the configuration terminal.
Figure3-6 Micro USB console cable
To connect to the PC through the micro USB console cable:
1. Connect the standard USB Type A connector to the USB port of the PC.
2. Connect the micro USB Type B connector to the micro USB console port of the switch.
3. Click the following link, or copy it to the address bar on the browser to log in to download and install the USB console driver on the configuration terminal.
http://www.h3c.com/en/home/USB_Console/
4. Select a driver program according to the operating system you use:
¡ XR21V1410_XR21B1411_Windows_Ver1840_x86_Installer.EXE—32-bit operating system.
¡ XR21V1410_XR21B1411_Windows_Ver1840_x64_Installer.EXE—64-bit operating system.
5. Click Next on the installation wizard.
Figure3-7 Device Driver Installation Wizard
6. Click Continue Anyway if the following dialog box appears.
Figure3-8 Software Installation
7. Click Finish.
Figure3-9 Completing the device driver installation wizard
Setting terminal parameters
To configure and manage the switch through the console port, you must run a terminal emulator program, such as TeraTermPro, on your configuration terminal. You can use the emulator program to connect a network device, a Telnet site, or an SSH site. For more information about the terminal emulator programs, see the user guides for these programs.
Configure the terminal parameters as follows:
· Bits per second—9,600.
· Data bits—8.
· Parity—None.
· Stop bits—1.
· Flow control—None.
Powering on the switch
Before powering on the switch, verify that the following conditions are met:
· The power cord is correctly connected.
· The input power voltage meets the requirement of the switch.
· The console cable is correctly connected.
· The PC has started, and its serial port settings are consistent with the console port settings on the switch.
Power on the switch. During the startup process, you can access Boot ROM menus to perform tasks such as software upgrade and file management. The Boot ROM interface and menu options differ with software versions. For more information about Boot ROM menu options, see the software-matching release notes for the device.
After the startup completes, you can access the CLI to configure the switch.
For more information about the configuration commands and CLI, see H3C S5560X-EI Switch Series Configuration Guides and H3C S5560X-EI Switch Series Command References.
4 Setting up an IRF fabric
You can use H3C IRF technology to connect and virtualize S5560X-EI switches into a large virtual switch called an "IRF fabric" for flattened network topology, and high availability, scalability, and manageability.
IRF fabric setup flowchart
Figure4-1 IRF fabric setup flowchart
To set up an IRF fabric:
Step |
1. Plan IRF fabric setup |
Plan the installation site and IRF fabric setup parameters: · Planning IRF fabric size and the installation site · Identifying the master switch and planning IRF member IDs · Planning IRF topology and connections |
2. Install IRF member switches |
See "Installing the switch in a 19-inch rack" or "Mounting the switch on a workbench." |
3. Connect ground wires and power cords |
See "Grounding the switch" and "Connecting the power cord." |
4. Power on the switches |
N/A |
5. Configure basic IRF settings |
See H3C S5560X-EI Switch Series IRF Configuration Guide or H3C S5560X-EI Switch Series Virtual Technologies Configuration Guide, depending on the software version. |
6. Connect the physical IRF ports |
Connect physical IRF ports on switches. All switches except the master switch automatically reboot, and the IRF fabric is established. |
Planning IRF fabric setup
This section describes issues that an IRF fabric setup plan must cover.
Choose switch models and identify the number of required IRF member switches, depending on the user density and upstream bandwidth requirements. The switching capacity of an IRF fabric equals the total switching capacities of all member switches.
Plan the installation site depending on your network solution, as follows:
· Place all IRF member switches in one rack for centralized high-density access.
· Distribute the IRF member switches in different racks to implement the ToR access solution for a data center.
NOTE: For the maximum IRF member devices supported by the S5560X-EI, see the release notes that come with the switch. |
Determine which switch you want to use as the master for managing all member switches in the IRF fabric.
An IRF fabric has only one master switch. You configure and manage all member switches in the IRF fabric at the CLI of the master switch. IRF member switches automatically elect a master.
You can affect the election result by assigning a high member priority to the intended master switch. For more information about master election, see H3C S5560X-EI Switch Series IRF Configuration Guide or H3C S5560X-EI Switch Series Virtual Technologies Configuration Guide, depending on the software version.
Prepare an IRF member ID assignment scheme. An IRF fabric uses member IDs to uniquely identify and manage its members, and you must assign each IRF member switch a unique member ID.
You can create an IRF fabric in daisy chain topology or more reliable ring topology. In ring topology, the failure of one IRF link does not cause the IRF fabric to split as in daisy chain topology. Instead, the IRF fabric changes to a daisy chain topology without interrupting network services.
You connect the IRF member switches through IRF ports, the logical interfaces for the connections between IRF member switches. Each IRF member switch has two IRF ports: IRF-port 1 and IRF-port 2. To use an IRF port, you must bind a minimum of one physical port to it.
When connecting two neighboring IRF member switches, you must connect the physical ports of IRF-port 1 on one switch to the physical ports of IRF-port 2 on the other switch.
The S5560X-EI switches provide 5-GE/10-GE/25-GE/40-GE IRF connections through multiple types of ports (see Table4-1 for the port types). You can bind several IRF physical ports to an IRF port for increased bandwidth and availability.
Figure4-2 and Figure4-3 show the topologies of an IRF fabric made up of three S5560X-30C-EI switches. The IRF port connections in the two figures are for illustration only, and more connection methods are available.
Figure4-2 IRF fabric in daisy chain topology
Figure4-3 IRF fabric in ring topology
Identify the physical IRF ports on the member switches according to your topology and connection scheme.
Table4-1 shows the physical ports that can be used for IRF connection and the port use restrictions.
Table4-1 Physical IRF port requirements
Chassis |
Candidate physical IRF ports |
Requirements |
· Four SFP+ ports on the front panel · Two QSFP+ ports on the rear panel |
· All physical ports to be bound to an IRF port must have the same data rate. · Physical ports on interface cards and the front panel can be bound to the same IRF port. · If a QSFP+ port is split into four virtual SFP+ ports, the QSFP+ port cannot be used as a physical IRF port. |
S5560X-30C-EI S5560X-30C-PWR-EI S5560X-54C-EI S5560X-54C-PWR-EI S5560X-30F-EI S5560X-54F-EI |
· Four fixed SFP+ ports on the front panel · Ports on the interface cards on the rear panel: ¡ 1/10GBASE-T autosensing Ethernet ports ¡ 5G/2.5G/1000BASE-T autosensing Ethernet ports ¡ 10G/5G/2.5G/1000BASE-T autosensing Ethernet ports ¡ SFP+ ports ¡ SFP28 ports ¡ QSFP+ ports |
S5560X-30F-EIF |
All SFP+ ports and QSFP+ ports on the front panel |
Planning the cabling scheme
The cables available for connecting two peer IRF physical ports vary by port type:
· 1/10GBASE-T, 5G/2.5G/1000BASE-T, and 10G/5G/2.5G/1000BASE-T autosensing Ethernet ports—For the available cables, see ports in Hardware Information and Specifications.
· SFP+ ports—SFP+ transceiver modules and optical fibers or SFP+ cables. For the available transceiver modules and cables, see ports in Hardware Information and Specifications.
· SFP28 ports—SFP28 transceiver modules and optical fibers or SFP28 cables. For the available transceiver modules and cables, see ports in Hardware Information and Specifications.
· QSFP+ ports—QSFP+ transceiver modules and optical fibers or QSFP+ cables. For the available transceiver modules and cables, see ports in Hardware Information and Specifications.
For a short-distance IRF connection in an equipment room, use a twisted-pair cable, SFP+ cable, SFP28 cable, or QSFP+ cable.
For a long-distance IRF connection, use SFP+/SFP28/QSFP+ transceiver modules and optical fibers.
The following subsections describe several H3C recommended IRF connection schemes. All these schemes use a ring topology.
IMPORTANT: In these schemes, all physical IRF ports are located on the same side. If physical IRF ports are on different sides, you must measure the distance between them to select an appropriate cable. |
Connecting the IRF member switches in one rack
Use twisted pair/SFP+/SFP28/QSFP+ cables to connect the IRF member switches (9 switches in this example) in a rack as shown in Figure4-4. The switches in the ring topology (see Figure4-5) are in the same order as connected in the rack.
Figure4-4 Connecting the switches in one rack
Connecting the IRF member switches in a ToR solution
You can install IRF member switches in different racks side by side to deploy a top of rack (ToR) solution.
Figure4-6 shows an example for connecting 9 top of rack IRF member switches by using SFP+/ SFP28/QSFP+ transceiver modules and optical fibers. The topology is the same as Figure4-5.
After you install the IRF member switches, power on the switches, and log in to each IRF member switch (see H3C S5560X-EI Switch Series Fundamentals Configuration Guide) to configure their member IDs, member priorities, and IRF port bindings.
Follow these guidelines when you configure the switches:
· Assign the master switch higher member priority than any other switch.
· Bind physical ports to IRF port 1 on one switch and to IRF port 2 on the other switch. You perform IRF port binding before or after connecting IRF physical ports depending on the software release.
· To bind the ports on an interface card to an IRF port, you must install the interface card first. For how to install an interface card, see H3C S5560X-EI Switch Series Interface Cards User Guide.
· Execute the display irf configuration command to verify the basic IRF settings.
For more information about configuring basic IRF settings, see H3C S5560X-EI Switch Series IRF Configuration Guide or H3C S5560X-EI Switch Series Virtual Technologies Configuration Guide, depending on the software version.
Use twisted pair/SFP+/SFP28/QSFP+ cables, or SFP+/SFP28/QSFP+ transceiver modules and fibers to connect the IRF member switches as planned.
Wear an ESD wrist strap when you connect twisted pair/SFP+/SFP28/QSFP+ cables or SFP+/SFP28/QSFP+ transceiver modules and fibers. For the connection methods and precautions, see H3C Transceiver Modules and Network Cables Installation Guide.
To verify the basic functionality of the IRF fabric after you finish configuring basic IRF settings and connecting IRF ports:
1. Log in to the IRF fabric through the console port of any member switch.
2. Create a Layer 3 interface, assign it an IP address, and make sure the IRF fabric and the remote network management station can reach each other.
3. Use Telnet, web, or SNMP to access the IRF fabric from the network management station. (See H3C S5560X-EI Switch Series Fundamentals Configuration Guide.)
4. Verify that you can manage all member switches as if they were one node.
5. Display the running status of the IRF fabric by using the commands in Table4-2.
Table4-2 Displaying and maintaining IRF configuration and running status
Task |
Command |
Display information about the IRF fabric. |
display irf |
Display all members’ IRF configurations that take effect at a reboot. |
display irf configuration |
Display IRF fabric topology information. |
display irf topology |
NOTE: To avoid IP address collision and network problems, configure a minimum of one multi-active detection (MAD) mechanism to detect the presence of multiple identical IRF fabrics and handle collisions. For more information about MAD detection, see H3C S5560X-EI Switch Series IRF Configuration Guide or H3C S5560X-EI Switch Series Virtual Technologies Configuration Guide, depending on the software version. |
Fixed power module failure
The S5560X-30F-EIF, S5560X-34S-EI, and S5560X-54S-EI switches use fixed power modules and support AC power input, DC power input, and concurrent AC and DC power inputs.
· S5560X-34S-EI and S5560X-54S-EI switches—To identify a fixed power module failure, examine the system status LED and the RPS status LED on the switch.
· S5560X-30F-EIF switch—To identify a fixed power module failure, examine the system status LED, AC power input status LED, and DC power input status LED.
Table5-1 Description of LEDs for fixed power modules
LED |
Mark |
Status |
System status LED |
SYS |
Off |
The switch is powered off. |
RPS status LED |
RPS |
Steady green |
Both the DC input and the AC input are normal. |
Steady yellow |
Normal DC input, no or abnormal AC input. |
Off |
No or abnormal DC input. |
AC input power status LED |
AC PWR |
Steady green |
Normal AC input. |
Off |
No or abnormal AC input. |
DC input power status LED |
DC PWR |
Steady green |
Normal DC input. |
Off |
AC input failure
Symptom
The switch uses only AC power input. The system status LED is off.
Solution
To resolve the issue:
1. Verify that the AC power cord connects the switch to an AC power source correctly, and the AC power receptacle on the switch and the AC power outlet are in good condition.
2. Verify that the AC power source is operating correctly.
3. Verify that the ambient temperature of the switch is in the acceptable range and ensure good ventilation for the power module. Overtemperature can cause the power module to stop working and enter the protection state.
4. If the issue persists, contact H3C Support.
DC input failure
Symptom
The switch uses only DC power input. The system status LED is off.
Solution
1. Verify that the switch is connected correctly to the DC power source.
2. Verify that the DC power source is operating correctly.
Symptom 1
The switch uses concurrent AC and DC power inputs. The system status LED is off.
Solution
1. Verify that the AC power cord connects the switch to the power source correctly, and the AC-input power receptacle on the switch and the AC power outlet are in good condition.
3. Verify that the switch is connected correctly to the DC power source.
4. Verify that the DC power source is operating correctly.
5. Verify that the ambient temperature of the switch is in the acceptable range and ensure good ventilation for the power module. Overtemperature can cause the power module to stop working and enter the protection state.
6. If the issue persists, contact H3C Support.
Symptom 2
· On an S5560X-30F-EIF switch that uses concurrent AC and DC power inputs, the system status LED is on, the DC PWR LED is steady green, but the AC PWR LED is off.
· On an S5560X-34S-EI or S5560X-54S-EI switch that uses concurrent AC and DC power inputs, the system status LED is on but the RPS status LED is steady yellow.
Solution
1. Verify that the AC power cord is securely connected to the switch, and the AC-input power receptacle on the switch and the connected AC power outlet are in good condition.
3. Verify that the ambient temperature of the switch is in the acceptable range.
Symptom 3
· On an S5560X-30F-EIF switch that uses concurrent AC and DC power inputs, the system status LED is on, the AC PWR LED is steady green, but the DC PWR LED is off.
· On an S5560X-34S-EI or S5560X-54S-EI switch that uses concurrent AC and DC power inputs, the system status LED is on but the RPS status LED is off.
Solution
1. Verify that the switch is connected to the DC power source correctly.
Symptom
S5560X-EI switches except the S5560X-34S-EI and S5560X-54S-EI use removable power modules.
· To identify the operating status of a power module on the S5560X-30C-EI, S5560X-54C-EI, S5560X-30F-EI, and S5560X-54F-EI switches, observe the PWR LED on the front panel of the switch. For more information about the power module status LED on the front panel of the switch, see LEDs in Hardware Information and Specifications.
· To identify the operating status of a power module on the S5560X-30C-PWR-EI and S5560X-54C-PWR-EI switches, observe the LEDs on the power module and the PWR LED on the front panel of the switch. For more information about the LEDs on a power module, see H3C PSR360-56A Power Module User Manual, H3C PSR560-56D Power Module User Manual, H3C PSR720-56A Power Module User Manual, or H3C PSR1110-56A Power Module User Manual.
Solution
1. Verify that the power cord is correctly connected.
2. Verify that the power source meets the requirement.
3. Verify that the operating temperature of the switch is in an acceptable range and the power module has good ventilation.
To replace a removable power module, see "Installing/removing a power module."
Fixed fan tray failure
The S5560X-30F-EIF, S5560X-34S-EI, and S5560X-54S-EI switches each use a fixed fan tray. If the fan tray fails, contact H3C Support.
Removable fan tray failure
WARNING! · If both fan trays fail during switch operation, replace them within 2 minutes. · If one fan tray fails, perform either of the following tasks: ¡ If the ambient temperature is not higher than 27°C (80.6°F), replace the fan tray within 24 hours and make sure the failed fan tray remains in position before the replacement. ¡ If the ambient temperature is higher than 27°C (80.6°F), replace the fan tray immediately. |
The S5560X-EI switches except the S5560X-34S-EI and S5560X-54S-EI use removable fan trays. If a fan tray fails, see "Installing/removing a fan tray" to replace the fan tray.
If the configuration environment setup is correct, the configuration terminal displays booting information when the switch is powered on. If the setup is incorrect, the configuration terminal displays nothing or garbled text.
No display
Symptom
The PC displays nothing when the switch is powered on.
Solution
1. Verify that the power module is supplying power to the switch.
2. Verify that the console cable is correctly connected.
3. Verify that the console cable does not have any problems and the PC settings are correct.
Garbled display
Symptom
The display on the PC is garbled.
Solution
1. Verify that the following settings are configured for the terminal:
¡ Baud rate—9,600.
¡ Data bits—8.
¡ Stop bits—1.
¡ Parity—None.
¡ Flow control—None.
