- 04-Layer 3—IP Services Configuration Guide
- 01-ARP configuration
- 02-IP addressing configuration
- 03-DHCP configuration
- 04-DNS configuration
- 05-IP forwarding basics configuration
- 06-Fast forwarding configuration
- 07-IRDP configuration
- 08-IP performance optimization configuration
- 09-UDP Helper configuration
- 10-IPv6 basics configuration
- 11-DHCPv6 configuration
- 12-IPv6 fast forwarding configuration
- 13-HTTP redirect configuration
13-HTTP redirect configuration | 45.61 KB |
HTTP redirect configuration task list
Specifying the HTTPS redirect listening port number
Associating an SSL server policy with the HTTPS redirect service
Configuring HTTP redirect
About HTTP redirect
HTTP redirect is a method to redirect users' HTTP or HTTPS requests to a specific URL. It is used in the following features:
· Redirect URL assignment in 802.1X authentication, MAC authentication, and port security.
· EAD assistant URL redirection in 802.1X authentication.
· URL redirection services in portal authentication.
No configuration is required to redirect HTTP requests.
To redirect HTTPS requests, perform the following tasks:
Tasks at a glance |
(Required.) Specifying the HTTPS redirect listening port number |
(Optional.) Associating an SSL server policy with the HTTPS redirect service |
The device can redirect HTTPS requests only after you specify the TCP port number on which the HTTPS redirect service listens for HTTPS requests.
When you specify the HTTPS redirect listening port number, follow these restrictions and guidelines:
· To avoid service unavailability caused by port conflict, do not specify a TCP port number used by a well-known protocol or used by any other TCP-based service. To display TCP port numbers that have been used by services, use the display tcp command. For more information about this command, see IP performance optimization commands in Layer 3—IP Services Command Reference.
· If you perform this task multiple times, the most recent configuration takes effect.
To specify the HTTPS redirect listening port number:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Specify the HTTPS redirect listening port number. |
http-redirect https-port port-number |
By default, no HTTPS redirect listening port number is specified. |
To improve the security of HTTPS redirect, you can associate an SSL server policy with the HTTPS redirect service. For more information about the SSL server policy configuration, see SSL in Security Configuration Guide.
When you associate an SSL server policy with the HTTPS redirect service, follow these restrictions and guidelines:
· HTTPS redirect is unavailable if the associated SSL server policy does not exist. You can first associate a nonexistent SSL server policy with the HTTPS redirect service and then configure the SSL server policy.
· If you change the SSL server policy associated with the HTTPS redirect service, the new policy takes effect immediately.
To associate an SSL server policy with the HTTPS redirect service:
Step |
Command |
Remarks |
system-view |
N/A |
2. Associate an SSL server policy with the HTTPS redirect service. |
http-redirect ssl-server-policy policy-name |
By default, no SSL server policy is associated with the HTTPS redirect service. The HTTPS redirect service uses the self-assigned certificate and the default SSL parameters. |
