- 09-MPLS Configuration Guide
- 01-Basic MPLS configuration
- 02-Static LSP configuration
- 03-LDP configuration
- 04-MPLS TE configuration
- 05-Static CRLSP configuration
- 06-RSVP configuration
- 07-Tunnel policy configuration
- 08-MPLS L3VPN configuration
- 09-MPLS L2VPN configuration
- 10-VPLS configuration
- 11-L2VPN access to L3VPN or IP backbone configuration
- 12-MPLS OAM configuration
- 13-MCE configuration
13-MCE configuration | 333.12 KB |
MPLS L3VPN problems solved by MCE
MCE-related MPLS L3VPN concepts
Restrictions and guidelines: MCE configuration
Associating a VPN instance with a Layer 3 interface
Configuring route related attributes for a VPN instance
Configuring routing between an MCE and a VPN site
Configuring static routing between an MCE and a VPN site
Configuring RIP between an MCE and a VPN site
Configuring OSPF between an MCE and a VPN site
Configuring IS-IS between an MCE and a VPN site
Configuring EBGP between an MCE and a VPN site
Configuring IBGP between an MCE and a VPN site
Configuring routing between an MCE and a PE
About routing between an MCE and a PE
Configuring static routing between an MCE and a PE
Configuring RIP between an MCE and a PE
Configuring OSPF between an MCE and a PE
Configuring IS-IS between an MCE and a PE
Configuring EBGP between an MCE and a PE
Configuring IBGP between an MCE and a PE
Display and maintenance commands for MCE
Restrictions and guidelines: IPv6 MCE configuration
Configuring IPv6 static routing between an MCE and a VPN site
Configuring RIPng between an MCE and a VPN site
Configuring OSPFv3 between an MCE and a VPN site
Configuring IPv6 IS-IS between an MCE and a VPN site
Configuring IPv6 static routing between an MCE and a PE
Configuring RIPng between an MCE and a PE
Configuring OSPFv3 between an MCE and a PE
Configuring IPv6 IS-IS between an MCE and a PE
Display and maintenance commands for IPv6 MCE
IPv6 MCE configuration examples
Configuring MCE
About MCE
The Multi-VPN Instance Customer Edge (MCE) feature allows multiple VPNs to share a CE with ensured data security in an MPLS L3VPN network. MCE provides traffic separation between VPNs by distinguishing routes of the VPNs.
MPLS L3VPN is a L3VPN technology used to interconnect geographically dispersed VPN sites. MPLS L3VPN uses BGP to advertise VPN routes and uses MPLS to forward VPN packets over a service provider backbone. MPLS L3VPN provides flexible networking modes, excellent scalability, and convenient support for MPLS QoS and MPLS TE.
In conventional MPLS L3VPN, a VPN site must exclusively use a CE to connect a PE. With increasing business, a private network must be divided into multiple VPNs and the VPNs must be isolated from one another for data security. Using a CE exclusively for each VPN costs much in buying and maintaining the network devices. Using a common CE for multiple VPNs cannot ensure data security because the VPNs use the same routing table.
The MCE feature offers balance between cost and security. It creates multiple VPN instances on a CE to provide logically separated routing tables and address spaces for the VPNs, so the VPNs can share the CE. This CE is called the MCE device.
Basic MPLS L3VPN architecture
A basic MPLS L3VPN architecture has the following types of devices:
· Customer edge device—A CE device resides on a customer network and has one or more interfaces directly connected to a service provider network. It does not support MPLS.
· Provider edge device—A PE device resides at the edge of a service provider network and is connected to one or more CEs. All MPLS VPN services are processed on PEs.
· Provider device—A P device is a core device on a service provider network. It is not directly connected to any CEs. A P device has only basic MPLS forwarding capability and does not handle VPN routing information.
Figure 1 Basic MPLS L3VPN architecture
Site
A site has the following features:
· A site is a group of IP systems with IP connectivity that does not rely on any service provider networks.
· The classification of a site depends on the topology relationship of the devices, rather than the geographical positions. However, the devices at a site are, in most cases, adjacent to each other geographically.
· The devices at a site can belong to multiple VPNs, which means that a site can belong to multiple VPNs.
· A site is connected to a provider network through one or more CEs. A site can contain multiple CEs, but a CE can belong to only one site.
Sites connected to the same provider network can be classified into different sets by policies. Only the sites in the same set can access each other through the provider network. Such a set is called a VPN.
VPN instance
VPN instances implement route isolation, data independence, and data security for VPNs.
A VPN instance has the following components:
· A separate Label Forwarding Information Base (LFIB).
· An IP routing table.
· Interfaces bound to the VPN instance.
· VPN instance administration information, including route distinguishers (RDs), route targets (RTs), and route filtering policies.
To associate a site with a VPN instance, bind the VPN instance to the PE's interface connected to the site. A site can be associated with only one VPN instance, and different sites can be associated with the same VPN instance. A VPN instance contains the VPN membership and routing rules of associated sites.
VPN-IPv4 address
Each VPN independently manages its address space. The address spaces of VPNs might overlap. For example, if both VPN 1 and VPN 2 use the addresses on subnet 10.110.10.0/24, address space overlapping occurs.
Multiprotocol BGP (MP-BGP) can solve this problem by advertising VPN-IPv4 addresses (also called VPNv4 addresses).
As shown in Figure 2, a VPN-IPv4 address consists of 12 bytes. The first eight bytes represent the RD, followed by a four-byte IPv4 prefix. The RD and the IPv4 prefix form a unique VPN-IPv4 prefix.
Figure 2 VPN-IPv4 address structure
An RD can be in one of the following formats:
· When the Type field is 0, the Administrator subfield occupies two bytes, the Assigned number subfield occupies four bytes, and the RD format is 16-bit AS number:32-bit user-defined number. For example, 100:1.
· When the Type field is 1, the Administrator subfield occupies four bytes, the Assigned number subfield occupies two bytes, and the RD format is 32-bit IPv4 address:16-bit user-defined number. For example, 172.1.1.1:1.
· When the Type field is 2, the Administrator subfield occupies four bytes, the Assigned number subfield occupies two bytes, and the RD format is 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
To guarantee global uniqueness for a VPN-IPv4 address, do not set the Administrator subfield to any private AS number or private IP address.
Route target attribute
MPLS L3VPN uses route target community attributes to control the advertisement of VPN routing information. A VPN instance on a PE supports the following types of route target attributes:
· Export target attribute—A PE sets the export target attribute for VPN-IPv4 routes learned from directly connected sites before advertising them to other PEs.
· Import target attribute—A PE checks the export target attribute of VPN-IPv4 routes received from other PEs. If the export target attribute matches the import target attribute of a VPN instance, the PE adds the routes to the routing table of the VPN instance.
Route target attributes define which sites can receive VPN-IPv4 routes, and from which sites a PE can receive routes.
Like RDs, route target attributes can be one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 100:1.
· 32-bit IPv4 address:16-bit user-defined number. For example, 172.1.1.1:1.
· 32-bit AS number:16-bit user-defined number, where the minimum value of the AS number is 65536. For example, 65536:1.
MCE working mechanism
As shown in Figure 3, the MCE exchanges private routes with VPN sites and PE 1, and adds the private routes to the routing tables of corresponding VPN instances.
· Route exchange between MCE and VPN site—Create VPN instances VPN 1 and VPN 2 on the MCE. Bind Interface C to VPN 1, and Interface B to VPN 2. The MCE adds a received route to the routing table of the VPN instance that is bound to the receiving interface.
· Route exchange between MCE and PE—The MCE connects to PE 1 through Ethernet subinterfaces. On the MCE, bind Interface A.1 to VPN 1, and Interface A.2 to VPN 2. On PE 1, create VPN instances for VPN 1 and VPN 2. Bind Interface A.1 to VPN 1, and Interface A.2 to VPN 2. The MCE and PE add a received route to the routing table of the VPN instance that is bound to the receiving interface.
Figure 3 Network diagram for the MCE feature
You can configure static routes, RIP, OSPF, IS-IS, EBGP, or IBGP between an MCE and a VPN site and between an MCE and a PE.
NOTE: To implement dynamic IP assignment for DHCP clients in private networks, you can configure DHCP server or DHCP relay agent on the MCE. When the MCE functions as the DHCP server, the IP addresses assigned to different private networks cannot overlap. |
On the PE, disable routing loop detection to avoid route loss during route calculation, and disable route redistribution between routing protocols to save system resources.
MCE tasks at a glance
To configure MCE, perform the following tasks:
Perform the following VPN instance tasks on PEs and MCEs:
b. Associating a VPN instance with a Layer 3 interface
c. (Optional.) Configuring route related attributes for a VPN instance
2. Configuring routing between an MCE and a VPN site
3. Configuring routing between an MCE and a PE
Configuring VPN instances
Creating a VPN instance
About VPN instances
A VPN instance is a collection of the VPN membership and routing rules of its associated site. A VPN instance might correspond to more than one VPN.
1. Enter system view.
2. Create a VPN instance and enter VPN instance view.
3. Configure an RD for the VPN instance.
By default, no RD is configured for a VPN instance.
4. (Optional.) Configure a description for the VPN instance.
By default, no description is configured for a VPN instance.
5. (Optional.) Configure a VPN ID for the VPN instance.
vpn-id vpn-id
By default, no VPN ID is configured for a VPN instance.
2. Enter interface view.
This interface connects the device to the CE.
3. Associate a VPN instance with the interface.
By default, an interface is not associated with a VPN instance and it belongs to the public network.
Configuration of this command deletes the IP address of the current interface. You must reconfigure an IP address for the interface after configuring the command.
If you configure route related attributes in both VPN instance view and VPN instance IPv4 VPN view, IPv4 VPN uses the configuration in VPN instance IPv4 VPN view.
Before you perform this task, create the routing policies to be used by this task. For information about routing policies, see Layer 3—IP Routing Configuration Guide.
2. Enter VPN instance view or VPN instance IPv4 VPN view.
? Enter VPN instance view.
? Execute the following commands in sequence to enter VPN instance IPv4 VPN view:
address-family ipv4
3. Configure route targets.
By default, no route targets are configured.
4. Set the maximum number of active routes.
By default, the number of active routes in a VPN instance is not limited.
Setting the maximum number of active routes for a VPN instance can prevent the device from learning too many routes.
5. Apply an import routing policy.
By default, all routes matching the import target attribute are accepted.
6. Apply an export routing policy.
By default, routes to be advertised are not filtered.
About static routing between an MCE and a VPN site
An MCE can reach a VPN site through a static route. Static routing on a traditional CE is globally effective and does not support address overlapping among VPNs. An MCE supports binding a static route to a VPN instance, so that the static routes of different VPN instances can be isolated from each other.
Perform this configuration on the MCE. On the VPN site, configure a common static route.
2. Configure a static route for a VPN instance.
ip route-static vpn-instance s-vpn-instance-name dest-address { mask-length | mask } { interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] [ track track-entry-number ] | vpn-instance d-vpn-instance-name next-hop-address [ track track-entry-number ] } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
3. (Optional.) Configure the default preference for static routes.
ip route-static default-preference default-preference
The default preference is 60.
About RIP between an MCE and a VPN site
Binding RIP processes to VPN instances can isolate routes of different VPNs. For more information about RIP, see Layer 3—IP Routing Configuration Guide.
Perform this configuration on the MCE. On a VPN site, create a common RIP process.
2. Create a RIP process for a VPN instance and enter RIP view.
rip [ process-id ] vpn-instance vpn-instance-name
A RIP process can belong to only one VPN instance.
3. Enable RIP on the interface attached to the specified network.
By default, RIP is disabled on an interface.
4. Redistribute remote site routes advertised by the PE into RIP.
import-route protocol [ as-number ] [ process-id | all-processes | allow-ibgp ] [ allow-direct | cost cost-value | route-policy route-policy-name | tag tag ] *
By default, no route is redistributed into RIP.
About OSPF between an MCE and a VPN site
Binding OSPF processes to VPN instances can isolate routes of different VPNs. For more information about OSPF, see Layer 3—IP Routing Configuration Guide.
Perform this configuration on the MCE. On a VPN site, create a common OSPF process.
2. Create an OSPF process for a VPN instance and enter OSPF view.
ospf [ process-id ] router-id router-id vpn-instance vpn-instance-name
Keywords |
Usage guidelines |
router-id router-id |
An OSPF process that is bound to a VPN instance does not use the public network router ID configured in system view. Therefore, you must specify a router ID when creating a process or configure an IP address for a minimum of one interface in the VPN instance. |
vpn-instance vpn-instance-name |
An OSPF process can belong to only one VPN instance. If you delete a VPN instance, all OSPF processes of the VPN instance are also deleted. |
3. Redistribute remote site routes advertised by the PE into OSPF.
import-route protocol [ as-number ] [ process-id | all-processes | allow-ibgp ] [ allow-direct | cost cost-value | nssa-only | route-policy route-policy-name | tag tag | type type ] *
By default, no routes are redistributed into OSPF.
4. Create an OSPF area and enter OSPF area view.
area area-id
5. Enable OSPF on the interface attached to the specified network in the area.
By default, an interface neither belongs to any area nor runs OSPF.
About IS-IS between an MCE and a VPN site
Binding IS-IS processes to VPN instances can isolate routes of different VPNs. For more information about IS-IS, see Layer 3—IP Routing Configuration Guide.
Perform this configuration on the MCE. On a VPN site, configure a common IS-IS process.
2. Create an IS-IS process for a VPN instance and enter IS-IS view.
isis [ process-id ] vpn-instance vpn-instance-name
An IS-IS process can belong to only one VPN instance.
3. Configure a network entity title.
network-entity net
By default, no NET is configured.
4. Create the IS-IS IPv4 unicast address family and enter its view.
5. Redistribute remote site routes advertised by the PE into IS-IS.
import-route protocol [ as-number ] [ process-id | all-processes | allow-ibgp ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, IS-IS does not redistribute routes from any other routing protocol.
If you do not specify the route level in the command, the command redistributes routes to the level-2 routing table by default.
6. Return to system view.
7. Enter interface view.
8. Enable the IS-IS process on the interface.
isis enable [ process-id ]
By default, no IS-IS process is enabled on the interface.
About EBGP between an MCE and a VPN site
To run EBGP between an MCE and a VPN site, you must configure a BGP peer for each VPN instance on the MCE, and redistribute the IGP routes of each VPN instance on the VPN site.
You must configure a VPN site to advertise the VPN network addresses it can reach to the connected MCE.
Configuring the MCE
2. Enter BGP instance view.
By default, BGP is not enabled.
3. Enter BGP-VPN instance view.
Commands in BGP-VPN instance view are the same as those in BGP instance view. For more information, see Layer 3—IP Routing Configuration Guide.
4. Configure the VPN site as an EBGP peer.
5. Enter BGP-VPN IPv4 unicast address family view.
6. Enable BGP to exchange IPv4 unicast routes with the specified peer.
By default, BGP does not exchange IPv4 unicast routes with peers.
7. (Optional.) Allow the local AS number to appear in the AS_PATH attribute of routes received from the peer, and set the maximum number of repetitions.
By default, BGP discards incoming route updates that contain the local AS number.
8. Redistribute remote site routes advertised by the PE into BGP.
By default, no routes are redistributed into BGP.
Configuring the VPN site
3. Configure the MCE as an EBGP peer.
4. Enter BGP IPv4 unicast address family view.
5. Enable BGP to exchange IPv4 unicast routes with the specified peer or peer group.
By default, BGP does not exchange IPv4 unicast routes with peers or peer groups.
6. Redistribute the IGP routes of the VPN into BGP.
About IBGP between an MCE and a VPN site
To run IBGP between an MCE and a VPN site, you must configure a BGP peer for each VPN instance on the MCE, and redistribute the IGP routes of each VPN instance on the VPN site.
You must configure a VPN site to advertise VPN network addresses to the connected MCE.
Configuring the MCE
4. Configure the VPN site as an IBGP peer.
6. Enable BGP to exchange IPv4 unicast routes with the specified peer or peer group.
7. (Optional.) Configure the local device as the RR, and specify the peer as the client of the RR.
By default, no RR or RR client is configured.
After you configure a VPN site as an IBGP peer, the MCE does not advertise the BGP routes learned from the VPN site to other IBGP peers, including VPNv4 peers. The MCE advertises routes learned from a VPN site only when you configure the VPN site as a client of the RR (the MCE).
3. Configure the MCE as an IBGP peer.
5. Enable BGP to exchange IPv4 unicast routes with the specified peer.
MCE-PE routing configuration includes these tasks:
· Binding the MCE-PE interfaces to VPN instances.
· Performing route configurations.
· Redistributing VPN routes into the routing protocol running between the MCE and the PE.
Perform the following configurations on the MCE. Configure the PE in the same way that you configure a PE in a basic MPLS L3VPN. For more information about configuring the PE, see "Configuring MPLS L3VPN."
3. (Optional.) Set the default preference for static routes.
4. Redistribute the VPN routes.
By default, no routes are redistributed into RIP.
ospf [ process-id | router-id router-id | vpn-instance vpn-instance-name ] *
3. Disable routing loop detection.
vpn-instance-capability simple
By default, routing loop detection is enabled and the MCE does not receive OSPF routes from the PE.
5. Create an OSPF area and enter OSPF area view.
area area-id
6. Enable OSPF on the interface attached to the specified network in the area.
By default, an interface neither belongs to an area nor runs OSPF.
network-entity net
5. Redistribute VPN routes.
4. Configure the PE as an EBGP peer.
7. Redistribute the VPN routes of the VPN site.
4. Configure the PE as an IBGP peer.
Task |
Command |
Display VPN instance information. |
display ip vpn-instance [ instance-name vpn-instance-name ] |
For commands that display routing tables for VPN instances, see Layer 3—IP Routing Command Reference.
Example: Configuring MCE
As shown in Figure 4, VPN 2 runs RIP. The edge routers of VPN 1 and VPN 2 are VR 1 and VR 2, respectively. Configure the MCE device to separate routes from different VPNs and to advertise the VPN routes to PE 1 through OSPF.
1. Configure VPN instances on the MCE and PE 1:
# On the MCE, configure VPN instances vpn1 and vpn2, and specify an RD and route targets for each VPN instance.
<MCE> system-view
[MCE] ip vpn-instance vpn1
[MCE-vpn-instance-vpn1] route-distinguisher 10:1
[MCE-vpn-instance-vpn1] vpn-target 10:1
[MCE-vpn-instance-vpn1] quit
[MCE] ip vpn-instance vpn2
[MCE-vpn-instance-vpn2] route-distinguisher 20:1
[MCE-vpn-instance-vpn2] vpn-target 20:1
[MCE-vpn-instance-vpn2] quit
# Bind GigabitEthernet 3/1/1 to VPN instance vpn1, and configure an IP address for the interface.
[MCE] interface gigabitethernet 3/1/1
[MCE-GigabitEthernet3/1/1] ip binding vpn-instance vpn1
[MCE-GigabitEthernet3/1/1] ip address 10.214.10.3 24
[MCE-GigabitEthernet3/1/1] quit
# Bind GigabitEthernet 3/1/2 to VPN instance vpn2, and configure an IP address for the interface.
[MCE] interface gigabitethernet 3/1/2
[MCE-GigabitEthernet3/1/2] ip binding vpn-instance vpn2
[MCE-GigabitEthernet3/1/2] ip address 10.214.20.3 24
[MCE-GigabitEthernet3/1/2] quit
# On PE 1, configure VPN instances vpn1 and vpn2, and specify an RD and route targets for each VPN instance.
<PE1> system-view
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 10:1
[PE1-vpn-instance-vpn1] vpn-target 10:1
[PE1-vpn-instance-vpn1] quit
[PE1] ip vpn-instance vpn2
[PE1-vpn-instance-vpn2] route-distinguisher 20:1
[PE1-vpn-instance-vpn2] vpn-target 20:1
[PE1-vpn-instance-vpn2] quit
2. Configure routing between the MCE and VPN sites:
The MCE is connected to VPN 1 directly, and no routing protocol is enabled in VPN 1. Therefore, you can configure static routes.
# On VR 1, assign IP address 10.214.10.2/24 to the interface connected to MCE and 192.168.0.1/24 to the interface connected to VPN 1. (Details not shown.)
# On VR 1, configure a default route with the next hop as 10.214.10.3.
<VR1> system-view
[VR1] ip route-static 0.0.0.0 0.0.0.0 10.214.10.3
# On the MCE, configure a static route to 192.168.0.0/24, specify the next hop as 10.214.10.2, and bind the static route to VPN instance vpn1.
[MCE] ip route-static vpn-instance vpn1 192.168.0.0 24 10.214.10.2
# Run RIP in VPN 2. Configure RIP process 20 for VPN instance vpn2 on MCE, so that MCE can learn the routes of VPN 2 and add them to the routing table of VPN instance vpn2.
[MCE] rip 20 vpn-instance vpn2
# Advertise subnet 10.214.10.0.
[MCE-rip-20] network 10.214.20.0
[MCE-rip-20] quit
# On VR 2, assign IP address 10.214.20.2/24 to the interface connected to the MCE and 192.168.10.1/24 to the interface connected to VPN 2. (Details not shown.)
# Configure RIP, and advertise subnets 192.168.10.0 and 10.214.20.0.
<VR2> system-view
[VR2] rip 20
[VR2-rip-20] network 192.168.10.0
[VR2-rip-20] network 10.214.20.0
# On MCE, display the routing tables of VPN instances vpn1 and vpn2.
[MCE] display ip routing-table vpn-instance vpn1
Destinations : 11 Routes : 11
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
10.214.10.0/24 Direct 0 0 10.214.10.3 GE3/1/1
10.214.10.0/32 Direct 0 0 10.214.10.3 GE3/1/1
10.214.10.3/32 Direct 0 0 127.0.0.1 InLoop0
10.214.10.255/32 Direct 0 0 10.214.10.3 GE3/1/1
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
192.168.0.0/24 Static 60 0 10.214.10.2 GE3/1/1
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
[MCE] display ip routing-table vpn-instance vpn2
10.214.20.0/24 Direct 0 0 10.214.20.3 GE3/1/2
10.214.20.0/32 Direct 0 0 10.214.20.3 GE3/1/2
10.214.20.3/32 Direct 0 0 127.0.0.1 InLoop0
10.214.20.255/32 Direct 0 0 10.214.20.3 GE3/1/2
192.168.10.0/24 RIP 100 1 10.214.20.2 GE3/1/2
The output shows that the MCE has learned the private route of VPN 2 through RIP. MCE maintains the routes of VPN 1 and those of VPN 2 in two different routing tables. In this way, routes from different VPNs are separated.
3. Configure routing between the MCE and PE 1:
# The MCE is connected to PE 1 through subinterfaces. On MCE, bind GigabitEthernet 3/1/3.1 to VPN instance vpn1.
[MCE] interface gigabitethernet 3/1/3.1
[MCE-GigabitEthernet3/1/3.1] ip binding vpn-instance vpn1
# Configure the subinterface to terminate VLAN 10.
[MCE-GigabitEthernet3/1/3.1] vlan-type dot1q vid 10
# Configure an IP address for the subinterface.
[MCE-GigabitEthernet3/1/3.1] ip address 20.1.1.1 24
[MCE-GigabitEthernet3/1/3.1] quit
# On the MCE, bind GigabitEthernet 3/1/3.2 to VPN instance vpn2.
[MCE] interface gigabitethernet 3/1/3.2
[MCE-GigabitEthernet3/1/3.2] ip binding vpn-instance vpn2
# Configure the subinterface to terminate VLAN 20.
[MCE-GigabitEthernet3/1/3.2] vlan-type dot1q vid 20
[MCE-GigabitEthernet3/1/3.2] ip address 30.1.1.1 24
[MCE-GigabitEthernet3/1/3.2] quit
# On PE 1, bind GigabitEthernet 3/1/1.1 to VPN instance vpn1.
[PE1] interface gigabitethernet 3/1/1.1
[PE1-GigabitEthernet3/1/1.1] ip binding vpn-instance vpn1
[PE1-GigabitEthernet3/1/1.1] vlan-type dot1q vid 10
[PE1-GigabitEthernet3/1/1.1] ip address 20.1.1.2 24
[PE1-GigabitEthernet3/1/1.1] quit
# On PE 1, bind GigabitEthernet 3/1/1.2 to VPN instance vpn2.
[PE1] interface gigabitethernet 3/1/1.2
[PE1-GigabitEthernet3/1/1.2] ip binding vpn-instance vpn2
[PE1-GigabitEthernet3/1/1.2] vlan-type dot1q vid 20
[PE1-GigabitEthernet3/1/1.2] ip address 30.1.1.2 24
[PE1-GigabitEthernet3/1/1.2] quit
# Configure the IP address of the interface Loopback 0 as 101.101.10.1 for the MCE and as 100.100.10.1 for PE 1. Specify the loopback interface address as the router ID for the MCE and PE 1. (Details not shown.)
# Enable OSPF process 10 on the MCE, and bind the process to VPN instance vpn1.
[MCE] ospf 10 router-id 101.101.10.1 vpn-instance vpn1
# Disable OSPF routing loop detection for the VPN instance.
[MCE-ospf-10] vpn-instance-capability simple
# Set the domain ID to 10.
[MCE-ospf-10] domain-id 10
# Advertise subnet 20.1.1.0/24 in area 0, and redistribute the static route of VPN 1.
[MCE-ospf-10] area 0
[MCE-ospf-10-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[MCE-ospf-10-area-0.0.0.0] quit
[MCE-ospf-10] import-route static
# On PE 1, enable OSPF process 10, and bind the process to VPN instance vpn1.
[PE1] ospf 10 router-id 100.100.10.1 vpn-instance vpn1
[PE1-ospf-10] domain-id 10
# Advertise subnet 20.1.1.0/24 in area 0.
[PE1-ospf-10] area 0
[PE1-ospf-10-area-0.0.0.0] network 20.1.1.0 0.0.0.255
[PE1-ospf-10-area-0.0.0.0] quit
[PE1-ospf-10] quit
# Configure OSPF process 20 between MCE and PE 1, and redistribute routes from RIP process 20 into OSPF. (Details not shown.)
# Verify that PE 1 has learned the static route of VPN 1 through OSPF.
[PE1] display ip routing-table vpn-instance vpn1
20.1.1.0/24 Direct 0 0 20.1.1.2 GE3/1/1.1
20.1.1.0/32 Direct 0 0 20.1.1.2 GE3/1/1.1
20.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
20.1.1.255/32 Direct 0 0 20.1.1.2 GE3/1/1.1
192.168.0.0/24 O_ASE2 150 1 20.1.1.1 GE3/1/1.1
# Verify that PE 1 has learned the RIP route of VPN 2 through OSPF.
[PE1] display ip routing-table vpn-instance vpn2
Destinations : 13 Routes : 13
30.1.1.0/24 Direct 0 0 30.1.1.2 GE3/1/1.2
30.1.1.0/32 Direct 0 0 30.1.1.2 GE3/1/1.2
30.1.1.2/32 Direct 0 0 127.0.0.1 InLoop0
30.1.1.255/32 Direct 0 0 30.1.1.2 GE3/1/1.2
192.168.10.0/24 O_ASE2 150 1 30.1.1.1 GE3/1/1.2
The routing information for the two VPNs has been redistributed into the routing tables on PE 1.
Configuring IPv6 MCE
About IPv6 MCE
IPv6 MCE provides traffic separation between VPNs by distinguishing routes of the VPNs. It allows multiple VPNs to share the same CE with ensured data security in an IPv6 MPLS L3VPN network.
IPv6 MPLS L3VPN uses BGP to advertise IPv6 VPN routes and uses MPLS to forward IPv6 VPN packets on the service provider backbone.
IPv6 MCE uses the same working mechanism as MCE. It advertises IPv6 routes and exchanges IPv6 packets between the internal network and the PE.
IPv6 MCE tasks at a glance
To configure IPv6 MCE, perform the following tasks:
About VPN instances
The description should contain the VPN instance's related information, such as its relationship with a certain VPN.
5. (Optional.) Set an ID for the VPN instance.
vpn-id vpn-id
By default, no ID is configured for a VPN instance.
Configuration of this command deletes the IPv6 address of the current interface. You must reconfigure an IPv6 address for the interface after configuring the command.
If you configure route related attributes in both VPN instance view and VPN instance IPv6 VPN view, IPv6 VPN uses the configurations in VPN instance IPv6 VPN view.
2. Enter VPN instance view or VPN instance IPv6 VPN view.
? Enter VPN instance IPv6 VPN view.
address-family ipv6
Setting the maximum number of active routes for a VPN instance can prevent the device from storing too many routes.
About IPv6 static routing between an MCE and a VPN site
An MCE can reach a VPN site through an IPv6 static route. IPv6 static routing on a traditional CE is globally effective and does not support address overlapping among VPNs. An MCE supports binding an IPv6 static route with an IPv6 VPN instance, so that the IPv6 static routes of different IPv6 VPN instances can be isolated from each other.
Perform this configuration on the MCE. On a VPN site, configure normal IPv6 static routes.
2. Configure an IPv6 static route for an IPv6 VPN instance.
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | nexthop-address [ public ] | vpn-instance d-vpn-instance-name nexthop-address } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
3. (Optional.) Configure the default preference for IPv6 static routes.
ipv6 route-static default-preference default-preference
The default preference for IPv6 static routes is 60.
About RIPng between an MCE and a VPN site
By configuring RIPng process-to-IPv6 VPN instance bindings on a MCE, you allow routes of different VPNs to be exchanged between the MCE and the sites through different RIPng processes, ensuring the separation and security of IPv6 VPN routes.
For more information about RIPng, see Layer 3—IP Routing Configuration Guide.
Perform this configuration on the MCE. On a VPN site, configure normal RIPng.
2. Create a RIPng process for a VPN instance and enter RIPng view.
ripng [ process-id ] vpn-instance vpn-instance-name
A RIPng process can belong to only one IPv6 VPN instance.
3. Redistribute remote site routes advertised by the PE.
import-route protocol [ as-number | process-id ] [ allow-ibgp ] [ allow-direct | cost cost-value | route-policy route-policy-name ] *
By default, no routes are redistributed into RIPng.
4. Return to system view.
5. Enter interface view.
6. Enable RIPng on the interface.
ripng process-id enable
By default, RIPng is disabled.
About OSPFv3 between an MCE and a VPN site
By configuring OSPFv3 process-to-IPv6 VPN instance bindings on a MCE, you allow routes of different IPv6 VPNs to be exchanged between the MCE and the sites through different OSPFv3 processes, ensuring the separation and security of IPv6 VPN routes.
For more information about OSPFv3, see Layer 3—IP Routing Configuration Guide.
Perform this configuration on the MCE. On a VPN site, configure common OSPFv3.
2. Create an OSPFv3 process for a VPN instance and enter OSPFv3 view.
ospfv3 [ process-id | vpn-instance vpn-instance-name ] *
An OSPFv3 process can belong to only one IPv6 VPN instance.
Deleting a VPN instance also deletes all related OSPFv3 processes.
3. Set the router ID.
router-id router-id
4. Redistribute remote site routes advertised by the PE.
By default, no routes are redistributed into OSPFv3.
5. Return to system view.
6. Enter interface view.
7. Enable OSPFv3 on the interface.
ospfv3 process-id area area-id [ instance instance-id ]
By default, OSPFv3 is disabled on an interface.
About IPv6 IS-IS between an MCE and a VPN site
By configuring IPv6 IS-IS process-to-IPv6 VPN instance bindings on a MCE, you allow routes of different IPv6 VPNs to be exchanged between the MCE and the sites through different IPv6 IS-IS processes. This ensures the separation and security of IPv6 VPN routes. For more information about IPv6 IS-IS, see Layer 3—IP Routing Configuration Guide.
Perform this configuration on the MCE. On a VPN site, configure common IPv6 IS-IS.
2. Create an IPv6 IS-IS process for a VPN instance and enter IS-IS view.
An IPv6 IS-IS process can belong to only one IPv6 VPN instance.
3. Configure a network entity title for the IS-IS process.
network-entity net
4. Create the IS-IS IPv6 unicast address family and enter its view.
5. (Optional.) Redistribute remote site routes advertised by the PE.
import-route protocol [ as-number | process-id ] [ allow-ibgp ] [ allow-direct | cost cost-value | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, no routes are redistributed to IPv6 IS-IS.
If you do not specify the route level in the command, redistributed routes are added to the level-2 routing table.
8. Enable the IPv6 IS-IS process on the interface.
isis ipv6 enable [ process-id ]
By default, no IPv6 IS-IS process is enabled on the interface.
To use EBGP between an MCE and IPv6 VPN sites, you must configure a BGP peer for each IPv6 VPN instance on the MCE, and redistribute the IGP routes of each VPN instance on the IPv6 VPN sites.
For more information about IPv6 BGP, see Layer 3—IP Routing Configuration Guide.
A VPN site must advertise IPv6 VPN network addresses it can reach to the connected MCE.
Configuring the MCE
peer { group-name | ipv6-address [ prefix-length ] } as-number as-number
5. Enter BGP-VPN IPv6 unicast address family view.
6. Enable BGP to exchange IPv6 unicast routes with the specified peer.
peer { group-name | ipv6-address [ prefix-length ] } enable
By default, BGP does not exchange IPv6 unicast routes with any peer.
7. Redistribute remote site routes advertised by the PE.
By default, no route redistribution is configured.
4. Enter BGP IPv6 unicast address family view.
5. Enable BGP to exchange IPv6 unicast routes with the specified peer.
6. Redistribute the IGP routes of the VPN.
To use IBGP between an MCE and a VPN site, you must configure a BGP peer for each IPv6 VPN instance on the MCE, and redistribute the IGP routes of each VPN instance on the VPN site.
A VPN site must advertise VPN network addresses to the connected MCE.
Configuring the MCE
6. Enable BGP to exchange IPv6 unicast routes with the peer.
peer { group-name | ipv6-address [ prefix-length ] } reflect-client
After you configure a VPN site as an IBGP peer, the MCE does not advertise the BGP routes learned from the VPN site to other IBGP peers, including VPNv6 peers. The MCE advertises routes learned from a VPN site only when you configure the VPN site as a client of the RR (the MCE).
5. Enable BGP to exchange IPv6 unicast routes with the peer.
MCE-PE routing configuration includes the following tasks:
· Binding the MCE-PE interfaces to IPv6 VPN instances.
· Performing routing configurations.
· Redistributing IPv6 VPN routes into the routing protocol running between the MCE and the PE.
Perform the following configuration tasks on the MCE. Configure the PE in the same way that you configure a PE in a basic IPv6 MPLS L3VPN. For more information about configuring the PE, see "Configuring IPv6 MPLS L3VPN."
3. (Optional.) Set the default preference for IPv6 static routes.
The default value is 60.
2. Create a RIPng process for an IPv6 VPN instance and enter RIPng view.
3. Redistribute VPN routes.
6. Enable the RIPng process on the interface.
By default, RIPng is disabled on an interface.
2. Create an OSPFv3 process for an IPv6 VPN instance and enter OSPFv3 view.
router-id router-id
4. Disable routing loop detection.
By default, routing loop detection is enabled and the MCE does not receive OSPFv3 routes from the PE.
8. Enable the OSPFv3 process on the interface.
2. Create an IS-IS process for an IPv6 VPN instance and enter IS-IS view.
network-entity net
By default, IPv6 IS-IS does not redistribute routes from any other routing protocol.
If you do not specify the route level in the command, the command redistributes routes to the level-2 routing table.
By default, BGP does not exchange IPv6 unicast routes with peers.
7. Redistribute VPN routes.
Task |
Command |
Example: Configuring IPv6 MCE
As shown in Figure 5, VPN 2 runs RIPng. The edge routers of VPN 1 and VPN 2 are VR1 and VR2, respectively. Configure the MCE device to separate routes from different VPNs and advertise the VPN routes to PE 1 through OSPFv3.
# On MCE, configure VPN instances vpn1 and vpn2, and specify an RD and route targets for each VPN instance.
<MCE> system-view
# Bind interface GigabitEthernet 3/1/1 to VPN instance vpn1, and configure an IPv6 address for the interface.
[MCE-GigabitEthernet3/1/1] ipv6 address 2001:1::1 64
# Bind interface GigabitEthernet 3/1/2 to VPN instance vpn2, and configure an IPv6 address for the interface.
[MCE-GigabitEthernet3/1/2] ipv6 address 2002:1::1 64
<PE1> system-view
The MCE is connected to VPN 1 directly, and no routing protocol is enabled in VPN 1. Therefore, you can configure IPv6 static routes.
# On VR 1, assign IPv6 address 2001:1::2/64 to the interface connected to the MCE and 2012:1::2/64 to the interface connected to VPN 1. (Details not shown.)
# On VR 1, configure a default route with the next hop as 2001:1::1.
<VR1> system-view
[VR1] ipv6 route-static :: 0 2001:1::1
# On the MCE, configure an IPv6 static route to 2012:1::/64 with the next hop 2001:1::2. Bind the static route to VPN instance vpn1.
[MCE] ipv6 route-static vpn-instance vpn1 2012:1:: 64 2001:1::2
# Run RIPng in VPN 2. Configure RIPng process 20 for the VPN instance vpn2 on the MCE, so that the MCE can learn the routes of VPN 2 and add them to the routing table of the VPN instance vpn2.
[MCE] ripng 20 vpn-instance vpn2
# Advertise subnet 2002:1::/64.
[MCE-GigabitEthernet3/1/2] ripng 20 enable
# On VR 2, assign IPv6 address 2002:1::2/64 to the interface connected to the MCE. (Details not shown.)
# On VR 2, configure RIPng and advertise subnets 2012::/64 and 2002:1::/64.
<VR2> system-view
[VR2] ripng 20
[VR2-ripng-20] quit
[VR2] interface gigabitethernet 3/1/1
[VR2-GigabitEthernet3/1/1] ripng 20 enable
[VR2-GigabitEthernet3/1/1] quit
[VR2] interface gigabitethernet 3/1/2
[VR2-GigabitEthernet3/1/2] ripng 20 enable
[VR2-GigabitEthernet3/1/2] quit
# On the MCE, display the routing tables of the VPN instances vpn1 and vpn2.
[MCE] display ipv6 routing-table vpn-instance vpn1
Destinations : 5 Routes : 5
Destination: ::1/128 Protocol : Direct
NextHop : ::1 Preference: 0
Interface : InLoop0 Cost : 0
Destination: 2001:1::/64 Protocol : Direct
NextHop : :: Preference: 0
Interface : GE3/1/1 Cost : 0
Destination: 2001:1::1/128 Protocol : Direct
Destination: 2012:1::/64 Protocol : Static
NextHop : 2001:1::2 Preference: 60
Destination: FE80::/10 Protocol : Direct
Interface : NULL0 Cost : 0
[MCE] display ipv6 routing-table vpn-instance vpn2
Destination: 2002:1::/64 Protocol : Direct
Interface : GE3/1/2 Cost : 0
Destination: 2002:1::1/128 Protocol : Direct
Destination: 2012::/64 Protocol : RIPng
NextHop : FE80::20C:29FF:FE40:701 Preference: 100
Interface : GE3/1/2 Cost : 1
The output shows that the MCE has learned the private route of VPN 2 through RIPng. The MCE maintains the routes of VPN 1 and VPN 2 in two different routing tables. In this way, routes from different VPNs are separated.
# The MCE is connected to PE 1 through subinterfaces. On the MCE, bind subinterface GigabitEthernet 3/1/3.1 to the VPN instance vpn1.
# Configure an IPv6 address for the subinterface.
[MCE-GigabitEthernet3/1/3.1] ipv6 address 2001:2::3 64
# On the MCE, bind subinterface GigabitEthernet 3/1/3.2 to the VPN instance vpn2.
[MCE-GigabitEthernet3/1/3.2] ipv6 address 2002:2::3 64
# On PE 1, bind subinterface GigabitEthernet 3/1/1.1 to the VPN instance vpn1.
[PE1-GigabitEthernet3/1/1.1] ipv6 address 2001:2::4 64
# On PE 1, bind subinterface GigabitEthernet 3/1/1.2 to the VPN instance vpn2.
[PE1-GigabitEthernet3/1/1.2] ipv6 address 2002:2::4 64
# Enable OSPFv3 process 10 on the MCE, and bind the process to VPN instance vpn1.
[MCE] ospfv3 10 vpn-instance vpn1
# Redistribute the IPv6 static route of VPN 1.
[MCE-ospf-10] router-id 101.101.10.1
[MCE-ospf-10] quit
# Enable OSPFv3 on interface GigabitEthernet 3/1/3.1.
[MCE-GigabitEthernet3/1/3.1] ospfv3 10 area 0.0.0.0
# On PE 1, enable OSPFv3 process 10 and bind it to VPN instance vpn1.
[PE1] ospfv3 10 vpn-instance vpn1
[PE1-ospf-10] router-id 100.100.10.1
[PE1-ospf-10] quit
# Enable OSPFv3 on subinterface GigabitEthernet 3/1/1.1.
[PE1-GigabitEthernet3/1/1.1] ospfv3 10 area 0.0.0.0
# Verify that PE 1 has learned the private route of VPN 1 through OSPFv3.
[PE1] display ipv6 routing-table vpn-instance vpn1
Destination: 2001:2::/64 Protocol : Direct
Interface : GE3/1/1.1 Cost : 0
Destination: 2001:2::4/128 Protocol : Direct
Destination: 2012:1::/64 Protocol : O_ASE2
NextHop : FE80::200:5EFF:FE01:1C05 Preference: 15
Interface : GE3/1/1.1 Cost : 10
# Verify that PE 1 has learned the private route of VPN 2 through OSPFv3.
[PE1] display ipv6 routing-table vpn-instance vpn2
Destination: 2002:2::/64 Protocol : Direct
Interface : GE3/1/1.2 Cost : 0
Destination: 2002:2::4/128 Protocol : Direct
Destination: 2012::/64 Protocol : O_ASE2
NextHop : FE80::200:5EFF:FE01:1C06 Preference: 15
Interface : GE3/1/1.2 Cost : 10
The routing information for the two VPNs has been redistributed into the routing table on PE 1.
