11-ACL and QoS Command Reference
HomeSupportRoutersH3C SR8800-F Router SeriesReference GuidesCommand ReferencesH3C SR8800-F Routers Command References-Release7951PXX-6W10011-ACL and QoS Command Reference
02-QoS commands
02-QoS commands 441.16 KB
QoS policy commands· 1
Traffic class commands· 1
display traffic classifier 1
if-match· 2
traffic classifier 8
Traffic behavior commands· 8
accounting· 8
bind nat-instance· 9
car 10
display traffic behavior 11
filter 13
free account 14
primap color-map-dp· 14
primap pre-defined color 15
redirect 16
remark account-level 18
remark dot1p· 19
remark drop-precedence· 20
remark dscp· 21
remark ip-precedence· 22
remark local-precedence· 23
remark qos-local-id· 24
remark service-class· 25
remark service-id· 25
remark tunnel-dscp· 26
traffic behavior 27
QoS policy commands· 28
classifier behavior 28
control-plane· 29
display qos policy· 30
display qos policy control-plane· 31
display qos policy control-plane pre-defined· 32
display qos policy global 34
display qos policy interface· 35
display qos vlan-policy· 38
qos apply policy· 40
qos apply policy global 42
qos policy· 43
qos vlan-policy· 43
reset qos policy control-plane· 44
reset qos policy global 45
reset qos vlan-policy· 45
Exclusive bandwidth commands· 46
display qos exclusive-bandwidth interface outbound· 46
qos exclusive-bandwidth· 47
Priority mapping commands· 49
Priority map commands· 49
display qos map-table· 49
display qos map-table color 50
display qos map-table interface· 51
display qos map-table name· 52
import (flexible priority map view) 53
import (priority map view) 54
qos apply map-table name· 55
qos map-table· 56
qos map-table color 57
qos map-table name· 58
Priority trust mode commands· 59
display qos trust interface· 59
qos trust 60
Port priority commands· 61
qos priority· 61
Traffic policing, GTS, and rate limit commands· 63
Traffic policing commands· 63
display qos car control-plane whitelist 63
qos car (control plane view) 65
qos car any (user profile view) 66
qos car whitelist enable· 67
reset qos car control-plane whitelist 68
GTS commands· 69
display qos gts interface· 69
display qos queue-statistics user-id· 70
qos gts (interface view) 74
qos gts (session group profile view) 75
qos gts (user group profile view) 76
Rate limit commands· 77
display qos lr 77
qos lr 78
Hardware congestion management commands· 80
Common commands· 80
display qos queue interface· 80
display qos-queue resource· 80
SP commands· 82
display qos queue sp interface· 82
qos sp· 82
WRR commands· 83
display qos queue wrr interface· 83
qos wrr 84
qos wrr weight 84
qos wrr group sp· 86
WFQ commands· 86
display qos queue wfq interface· 86
qos bandwidth queue· 87
qos wfq· 88
qos wfq weight 89
Queue scheduling profile commands· 90
bandwidth queue· 90
display qos qmprofile configuration· 90
display qos qmprofile interface· 92
qos apply qmprofile (interface view) 93
qos apply qmprofile (session group profile view, user profile view) 93
qos qmprofile· 94
queue· 95
CBQ commands· 96
queue af 96
queue ef 97
queue wfq· 98
weight 99
Congestion avoidance commands· 101
WRED table commands· 101
display qos wred interface· 101
display qos wred table· 102
qos wred apply· 103
qos wred queue table· 104
queue· 104
queue ecn· 106
queue weighting-constant 106
Global CAR commands· 108
car name· 108
display qos car name· 108
qos car 109
reset qos car name· 110
Queue-based accounting commands· 111
display qos queue-statistics interface outbound· 111
qos queue-statistics· 114
QPPB commands· 116
bgp-policy· 116
QoS policy commands
Use display traffic classifier to display traffic classes.
In standalone mode:
In IRF mode:
display traffic classifier user-defined [ classifier-name ] [ chassis chassis-number slot slot-number ]
user-defined: Specifies user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the traffic classes for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the traffic classes for the global active MPU. (In IRF mode.)
# Display all user-defined traffic classes.
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match not protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
Classifier
Traffic class name and its match criteria.
Operator
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria.
Rule(s)
Match criteria.
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option
acl [ ipv6 | mac ] { acl-number | name acl-name }
Matches an ACL.
The value range for the acl-number argument is 2000 to 5999 for IPv4 and IPv6 ACLs and 4000 to 4999 for Layer 2 ACLs.
The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, make sure the argument is not all.
any
Matches all packets.
Only SPC, CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E), and CMPE-1104 cards support this keyword.
authenticated-user
Matches the packets of users that have passed IPoE, portal, or PPPoE authentication.
control-plane protocol protocol-name&<1-8>
Matches control plane protocols.
The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3.
This option matches only the protocol packets that use well-known port numbers.
control-plane protocol-group protocol-group-name
Matches a control plane protocol group.
The protocol-group-name argument can be critical, important, management, monitor, normal, or redirect.
customer-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in inner VLAN tags of double-tagged packets.
The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
SPC, CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E), and CMPE-1104 cards do not support this option.
customer-vlan-id vlan-id-list
Matches VLAN IDs in inner VLAN tags of double-tagged packets.
The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
dscp dscp-value&<1-8>
Matches DSCP values.
The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 6.
inbound-interface interface-type interface-number
Matches an input interface specified by its type and number.
ip-precedence ip-precedence-value&<1-8>
Matches IP precedence values.
The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7.
mpls-exp exp-value&<1-8>
Matches MPLS EXP values.
The exp-value&<1-8> argument specifies a space-separated list of up to eight EXP values. The value range for the exp-value argument is 0 to 7.
This option is available only on CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards.
Matches a protocol.
The protocol-name argument can be arp, ipv6, or ip.
qos-local-id local-id-value
Matches a local QoS ID in the range of 1 to 4095.
service-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in outer VLAN tags.
The dot1p-value&<1-8> argument is a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
service-vlan-id vlan-id-list
Matches VLAN IDs in outer VLAN tags.
You can use this option to match single-tagged packets.
source-mac mac-address
Matches a source MAC address.
This option takes effect only on Ethernet interfaces.
This option is supported only in standard mode. For more information about system operating modes see device management in Fundamentals Configuration Guide.
Table 3 Available system-defined control plane protocols
Protocol
default
Protocol packets other than the following packet types
arp
ARP packets
arp-snooping
ARP snooping packets
bfd
BFD packets
bgp
BGP packets
bgp4+
IPv6 BGP packets
bpdu-tunnel
BPDU tunnel packets
cdp
CDP packets
cfd
CFD packets
dhcp
DHCP packets
dhcp-snooping
DHCP snooping packets
dhcpv6
IPv6 DHCP packets
dldp
DLDP packets
dot1x
802.1X packets
ftp
FTP packets
gmrp
GMRP packets
hoplimit-expires
Hop-limit expire packets
http
HTTP packets
https
HTTPS packets
icmp
ICMP packets
icmpv6
ICMPv6 packets
igmp
IGMP packets
igmp-snooping
IGMP snooping packets
ip-option
IPv4 packets with the Options field
ipv6-option
IPv6 packets with the Options field
irdp
IRDP packets
isis
IS-IS packets
lacp
LACP packets
ldp
LDP packets
ldp6
IPv6 LDP packets
lldp
LLDP packets
mld
MLD packets
msdp
MSDP packets
mvrp
MVRP packets (including GVRP packets)
ntp
NTP packets
oam
OAM packets
ospf-multicast
OSPF multicast packets
ospf-unicast
OSPF unicast packets
ospf3-multicast
OSPFv3 multicast packets
ospf3-unicast
OSPFv3 unicast packets
pim-multicast
PIM multicast packets
pim-unicast
PIM unicast packets
pim6-multicast
IPv6 PIM multicast packets
pim6-unicast
IPv6 PIM unicast packets
portal
Portal packets
pppoe-negotiation
PPPoE negotiation packets
pvst
PVST packets
radius
RADIUS packets
rip
RIP packets
ripng
RIPng packets
rrpp
RRPP packets
rsvp
RSVP packets
smart-link
SmartLink packets
snmp
SNMP packets
ssh
SSH packets
stp
STP packets
tacacs
TACACS packets
telnet
Telnet packets
tftp
TFTP packets
ttl-expires
TTL expire packets
udld
UDLD packets
udp-helper
UDP helper packets
vrrp
VRRP packets
vrrp6
IPv6 VRRP packets
vtp
VTP packets
In a traffic class with the logical OR operator, you can configure multiple if match commands for any of the available match criteria.
When you configure a match criterion that can have multiple values in one if-match command, follow these restrictions and guidelines:
·          You can specify up to eight values for any of the following match criteria in one if-match command:
¡  802.1p priority.
¡  DSCP.
¡  IP precedence.
¡  MPLS EXP.
¡  VLAN ID.
·          If a packet matches one of the specified values, it matches the if-match command.
·          To delete a criterion that has multiple values, the specified values in the undo if-match command must be the same as those specified in the if-match command. The order of the values can be different.
When you configure ACL-based match criteria, follow these restrictions and guidelines:
·          The ACL used as a match criterion must already exist.
·          The ACL is used for classification only and the permit/deny actions in ACL rules are ignored.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of 0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match the advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match the advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname] traffic classifier class1 operator or
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match the packets with a local QoS ID of 3.
[Sysname-classifier-class1] if-match qos-local-id 3
traffic classifier
Use traffic classifier to create a traffic class and enter its view, or enter the view of an existing traffic class.
Use undo traffic classifier to delete a traffic class.
No traffic classes exist.
classifier-name: Specifies a name for the traffic class, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class named class1.
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to restore the default.
accounting { byte | packet }
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
bind nat-instance
Use bind nat-instance to configure a NAT instance binding action in a traffic behavior.
Use undo bind nat-instance to restore the default.
bind nat-instance instance-name
undo bind nat-instance instance-name
No NAT instance binding action is configured.
instance-name: Specifies a NAT instance by its name, a case-sensitive string of 1 to 31 characters.
NAT supports interface-based NAT and global NAT. By redirecting traffic that requires NAT to the specified NAT instance, this command implements global NAT. For more information about NAT, see Layer 3—IP Services Configuration Guide.
This command and the redirect failover-group command are mutually exclusive.
# Configure a NAT instance binding action in traffic behavior database.
[Sysname-behavior-database] bind nat-instance test
nat instance (Layer 3—IP Services Command Reference)
car
Use car to configure a CAR action in absolute value in a traffic behavior.
Use undo car to restore the default.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in the range of 1 to 160000000 kbps.
cbs committed-burst-size: Specifies the committed burst size (CBS) in the range of 512 to 256000000 bytes. The default is the product of 62.5 and the CIR value.
ebs excess-burst-size: Specifies the excess burst size (EBS) in the range of 0 to 256000000 bytes. If the PIR is not specified, the value range for excess-burst-size is 0 to 256000000, and the default is 0. If the PIR is specified, the value range for excess-burst-size is 512 to 256000000.
pir peak-information-rate: Specifies the peak information rate (PIR) in the range of 1 to 160000000 kbps.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on packets that conform to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
·          discard: Drops the packet.
·          pass: Permits the packet to pass through.
·          remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
·          remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63.
·          remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
Only the pass action is supported for green packets and yellow packets on CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards.
Only the discard and pass actions are supported for red packets on CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards.
If you set the cir committed-information-rate option to a value in the range of 1 to 8 kbps on CSPEX cards (except CSPEX-1204 and CSPEX-1104-E), the actual setting takes effect. If you set the cir committed-information-rate option to a value in the range of 1 to 8 on any other card, 8 kbps always takes effect.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
A QoS policy that uses a traffic behavior configured with CAR can be applied in either the inbound direction or outbound direction of an interface.
In a traffic policing action applied to a control plane, the supported value range for the cir committed-information-rate option is 8 to 10000 kbps.
If you execute the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database:
·          Set the CIR to 200 kbps, CBS to 51200 bytes, and EBS to 0.
·          Transmit the conforming packets, and mark the excess packets with DSCP value 0 and transmit them.
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
Use display traffic behavior to display traffic behaviors.
In standalone mode:
In IRF mode:
display traffic behavior user-defined [ behavior-name ] [ chassis chassis-number slot slot-number ]
user-defined: Specifies user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays traffic behaviors for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the traffic behaviors for the global active MPU. (In IRF mode.)
# Display all user-defined traffic behaviors.
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
      Primap pre-defined table: dscp-dp
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Marking:
        Remark mpls-exp 4
    Behavior: 3 (ID 102)
      -none-
    Behavior: 4 (ID 103)
      Mirroring:
        Mirror to the interface: Ten-GigabitEthernet3/1/1 pop-label
Behavior
Name and contents of a traffic behavior.
Marking
Information about priority marking.
Remark dscp
Action of setting the DSCP value for packets.
Information about the CAR action.
Green action
Action to take on green packets.
Yellow action
Action to take on yellow packets.
Red action
Action to take on red packets.
Primap pre-defined color table
Information about pre-defined colored priority maps. For more information, see "Priority map commands."
Accounting enable
Traffic accounting action.
Filter enable
Traffic filtering action.
Remark mpls-exp
Action of setting the MPLS EXP value for packets.
none
No other traffic behavior is configured.
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to restore the default.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets.
# Configure a traffic filtering action as deny in traffic behavior database.
free account
Use free account to configure the traffic permission action in a traffic behavior.
Use undo free account to restore the default.
free account
undo free account
The traffic permission action is not configured.
# Configure the traffic permission action in traffic behavior database.
[Sysname-behavior-database] free account
primap color-map-dp
Use primap color-map-dp to configure the action of mapping packet colors to drop priority values in a traffic behavior.
Use undo primap color-map-dp to restore the default.
primap color-map-dp
No priority mapping action is configured in a traffic behavior.
This command must be used in conjunction with the car command.
The packet color-to-drop priority mappings are fixed.
·          The red color is mapped to drop priority 2.
·          The yellow color is mapped to drop priority 1.
·          The green color is mapped to drop priority 0.
# Configure the action of mapping packet colors to drop priority values in traffic behavior behavior1.
[Sysname-behavior-behavior1] car cir 1600
[Sysname-behavior-behavior1] primap color-map-dp
Use primap pre-defined color to configure the action of mapping source precedence to target precedence through the specified colored priority mapping table for a traffic behavior.
Use undo primap pre-defined color to delete the action.
primap pre-defined color { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
undo primap pre-defined color { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
pre-defined: Specifies predefined priority mapping tables.
color: Uses colored priority mapping tables for priority mapping.
The device provides the following types of priority map.
Table 5 Priority maps
Priority mapping
dot1p-dot1p
802.1p-802.1p priority map.
dot1p-dp
802.1p-drop priority map.
dot1p-dscp
802.1p-DSCP priority map.
dot1p-exp
802.1p-EXP priority map.
dot1p-lp
802.1p-local priority map.
dscp-dot1p
DSCP-802.1p priority map.
dscp-dp
DSCP-drop priority map.
dscp-dscp
DSCP-DSCP priority map.
dscp-exp
DSCP-EXP priority map.
dscp-lp
DSCP-local priority map.
exp-dot1p
EXP-802.1p priority map.
exp-dp
EXP-drop priority map.
exp-dscp
EXP-DSCP priority map.
exp-exp
EXP-EXP priority map.
exp-lp
EXP-local priority map.
# Configure the action of mapping DSCP values to drop priority through the colored DSCP-to-drop mapping table in traffic behavior behavior1.
[Sysname-behavior-behavior1] primap pre-defined color dscp-dp
primap color-map-dp
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to restore the default.
In standalone mode:
redirect { access-vpn vpn-instance vpn-instance-name | cpu | failover-group group-name | http-to-cpu | https-to-cpu | interface interface-type interface-number | next-hop [ vpn-instance vpn-instance-name ] { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] } | slot slot-number }
undo redirect { access-vpn | cpu | failover-group group-name | http-to-cpu | https-to-cpu | interface interface-type interface-number | next-hop | slot slot-number }
In IRF mode:
redirect { access-vpn vpn-instance vpn-instance-name | cpu | failover-group group-name | http-to-cpu | https-to-cpu | interface interface-type interface-number | next-hop [ vpn-instance vpn-instance-name ] { ipv4-add1 [ track track-entry-number ] [ ipv4-add2 [ track track-entry-number ] ] | ipv6-add1 [ track track-entry-number ] [ ipv6-add2 [ track track-entry-number ] ] } | chassis chassis-number slot slot-number }
undo redirect { access-vpn | cpu | failover-group group-name | http-to-cpu | https-to-cpu | interface interface-type interface-number | next-hop | chassis chassis-number slot slot-number }
No traffic redirecting action is configured.
access-vpn vpn-instance vpn-instance-name: Redirects traffic to an MPLS L3VPN instance specified by its name, a case-sensitive string of 1 to 31 characters.
cpu: Redirects traffic to the CPU.
failover group group-name: Redirects traffic to a failover group specified by its name, a case-sensitive string of 1 to 63 characters.
http-to-cpu: Redirects HTTP requests to the CPU.
https-to-cpu: Redirects HTTPS requests to the CPU.
interface interface-type interface-number: Redirects traffic to an interface specified by its type and number. To redirect traffic to a tunnel interface, set the interface type to tunnel. To redirect traffic to a Layer 2 aggregate interface, set the interface type to bridge-aggregation. To redirect traffic to a Layer 3 aggregate interface, set the interface type to route-aggregation.
next-hop: Redirects traffic to a next hop. For successful traffic redirection, make sure the next hop IP address is reachable. If both primary and secondary next hop IP addresses are specified, make sure a minimum of one IP address is reachable. The redirection feature periodically looks up the routing table to verify the reachability of next hop IP addresses. If track entries are specified, the redirection feature verifies the reachability of the next hop IP addresses based on the Track detection result. If both primary and secondary next hop IP addresses are unreachable, traffic redirection to a next hop does not take effect.
vpn-instance vpn-instance-name: Specifies the MPLS L3VPN instance to which the next hop belongs. The vpn-instance-name argument represents the VPN instance name, a case-sensitive string of 1 to 31 characters. If the next hop belongs to the public network, do not specify this option.
ipv4-add1: Specifies the primary next hop IPv4 address. If traffic fails to be redirected to this IPv4 address, the traffic is redirected to the secondary IPv4 address.
ipv4-add2: Specifies the secondary next hop IPv4 address.
ipv6-add1: Specifies the primary next hop IPv6 address. If traffic fails to be redirected to this IPv6 address, the traffic is redirected to the secondary IPv6 address.
ipv6-add2: Specifies the secondary next hop IPv6 address.
track track-entry-number: Specifies a track entry by its ID in the range of 1 to 1024. Different track entries can be specified for primary and secondary IP addresses. By specifying track entries, you can associate traffic redirection with detection modules, such as NQA and BFD (see High Availability Configuration Guide).
slot slot-number: Redirects traffic to a card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Redirects traffic to a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
If you execute the redirect command multiple times in the same traffic behavior, all configured actions take effect at the same time. Exceptions are that the redirect cpu, redirect http-to-cpu, and redirect https-to-cpu commands are mutually exclusive.
For IPoE Web authentication, you must configure the redirect http-to-cpu or redirect https-to-cpu command. If a user performs IPoE Web authentication through the Web browser but the HTTP request is not destined for the portal Web server, the access device redirects the request to the CPU. The CPU pushes the Web authentication page to the user.
To prevent the CPU from receiving a large number of HTTP requests during IPoE Web authentication, use the ip subscriber http-fast-reply enable command to enable the HTTP request fast reply function. This function reduces the CPU load by identifying HTTP requests in hardware and automatically replying with HTTP responses. For more information about the ip subscriber http-fast-reply enable command, see IPoE commands in Layer 2—WAN Access Command Reference.
Only CSPEX cards (except CSPEX-1204 and CSPEX-1104-E) support redirecting traffic to Layer 3 Ethernet interfaces and loopback interfaces, and they do not support redirecting traffic to Layer 3 aggregate interfaces.
If the next hop for redirection is in an MPLS network, IP TTL is always copied to the inner label TTL for packets redirected to the next hop. For more information about TTL propagation, see basic MPLS in MPLS Configuration Guide.
# Configure redirecting traffic to GigabitEthernet 3/1/1 in traffic behavior database.
[Sysname-behavior-database] redirect interface gigabitethernet 3/1/1
# Configure redirecting traffic to a next hop in traffic behavior database.
[Sysname-behavior-database] redirect next-hop 10.55.66.1 track 1 10.55.88.1 track 2
# Configure redirecting traffic to VPN instance vpn1 in traffic behavior database.
[Sysname-behavior-database] redirect access-vpn vpn-instance vpn1
classifier behavior
qos policy
traffic behavior
Use remark account-level to configure an accounting level marking action in a traffic behavior.
Use undo remark account-level to restore the default.
remark account-level account-level
No accounting level marking action is configured.
account-level: Specifies an accounting level in the range of 1 to 8. Do not specify accounting level 1. The traffic for this accounting level also includes non-ITA service traffic, and accounting for ITA service traffic will be inaccurate.
If QoS policies that contain accounting level marking actions are applied globally, to an interface, and to a user profile, configure an ITA policy for each accounting level. For information about ITA policies, see AAA in Security Configuration Guide and Security Command Reference.
The remark account-level command takes effect only on packets from users that are configured with the same accounting level in an ITA policy.
This command is available only on CSPEX cards (except CSPEX-1204).
# Configure traffic behavior database to mark matching packets with accounting level 3.
[Sysname-behavior-database] remark account-level 3
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action or an inner-to-outer tag priority copying action in a traffic behavior.
Use undo remark dot1p to restore the default.
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
No marking action or inner-to-outer tag priority copying action is configured.
green: Specifies green packets. CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards do not support this keyword.
red: Specifies red packets. CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards do not support this keyword.
yellow: Specifies yellow packets. CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards do not support this keyword.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
customer-dot1p-trust: Copies the 802.1p priority value in the inner VLAN tag to the outer VLAN tag.
The remark dot1p dot1p-value and remark dot1p customer-dot1p-trust commands override each other in the same traffic behavior.
The remark dot1p customer-dot1p-trust command does not take effect on single-tagged packets.
If you execute the remark dot1p dot1p-value command multiple times for the same color, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
# Configure an inner-to-outer tag priority copying action in traffic behavior database.
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to restore the default.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets, in the range of 0 to 2.
On SPC, CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E), and CMPE-1104 cards, a drop priority marking action takes effect only when the QoS policy is applied to the inbound direction.
If you execute this command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to restore the default.
undo remark [ green | red | yellow ] dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 6.
Table 6 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
The remark tunnel-dscp command is mutually exclusive with the remark dscp command in a traffic behavior.
Colored packets are not marked on CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, or CSPEX cards.
If you execute the remark dscp command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior database to mark matching traffic with DSCP 6.
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to restore the default.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
The remark tunnel-dscp command is mutually exclusive with the remark ip-precedence command in a traffic behavior.
If you execute the remark ip-precedence command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to restore the default.
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
If you execute the remark local-precedence command multiple times in the same traffic behavior, the most recent configuration takes effect.
By marking the local precedence, you assign matching packets to the queue corresponding to the local precedence value. You can use the display qos queue-statistics interface outbound command to display outgoing traffic statistics collected for interfaces on a per-queue basis. The outgoing traffic statistics are displayed only if you have enabled queue-based traffic accounting in the outbound direction.
On SPC, CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E), and CMPE-1104 cards, a local precedence marking action takes effect only when the QoS policy is applied to the inbound direction.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to restore the default.
remark qos-local-id local-id-value
No local QoS ID marking action is configured.
local-id-value: Specifies the local QoS ID to be marked for packets, in the range of 1 to 4095.
You can use one QoS policy to mark the local QoS ID for packets in the inbound direction. Then, you can use another QoS policy to apply other QoS features in the outbound direction based on the marked local QoS ID.
On CSPEX cards (except CSPEX-1204 and CSPEX-1104-E), a local QoS ID marking action takes effect only when the QoS policy is applied to the outbound direction.
# Configure the action of marking packet with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
Use remark service-class to configure an action of marking the MPLS TE service class in a traffic behavior.
Use undo remark service-class to restore the default.
remark service-class service-class-value
No MPLS TE service class marking action is configured.
service-class-value: Specifies the MPLS TE service class in the range of 1 to 15.
If the remark service-class command is configured in a QoS policy:
·          The QoS policy can only be applied to the inbound direction of an interface.
·          Only one MPLS TE service class marking action can be configured for packets with the same MPLS EXP value on an interface. To modify the MPLS TE service class to be marked, you must remove the existing service class setting and configure a new service class value.
If you execute the remark service-class command multiple times in the same traffic behavior, the most recent configuration takes effect.
You can use the mpls te service-class command to set the MPLS TE service class. For more information, see MPLS TE commands in MPLS Command Reference.
This command is available only on CSPEX cards (except CSPEX-1204 and CSPEX-1104-E).
# Configure an action of marking the MPLS TE service class as 2.
[Sysname-behavior-data] remark service-class 2
remark service-id
Use remark service-id to configure an action of marking the EDSG service ID in a traffic behavior.
Use undo remark service-id to restore the default.
remark service-id service-id
No EDSG service ID marking action is configured.
service-id: Specifies the EDSG service ID in the range of 1 to 8. Only the values 1 through 4 are supported in the current software version.
If you execute the remark service-id command multiple times in the same traffic behavior, the most recent configuration takes effect.
The remark service-id command takes effect only when the QoS policy is applied to an interface or globally.
The remark service-id command takes effect only on packets from users that use the EDSG service ID specified in the remark service-id command.
# Configure an action of marking the EDSG service ID as 2.
[Sysname-behavior-database] remark service-id 2
service policy (BRAS Services Command Reference)
service-id (BRAS Services Command Reference)
remark tunnel-dscp
Use remark tunnel-dscp to configure an outer DSCP marking action in a traffic behavior.
Use undo remark tunnel-dscp to restore the default.
remark tunnel-dscp dscp-value
No outer DSCP marking action is configured.
dscp-value: Specifies the DSCP value to be set for the outer IP header of tunneled packets. The DSCP value can be a number from 0 to 63 or a keyword in Table 6.
This command takes effect on GRE packets and VXLAN packets.
The outer DSCP value marking action takes effect only when the QoS policy is applied to an interface or globally.
The remark tunnel-dscp command is mutually exclusive with the remark dscp or remark ip-precedence command in one traffic behavior.
If the tunnel tos command is configured on a VXLAN tunnel interface, the ToS value in the outer IP header for broadcast and multicast packets received from local sites cannot be modified by using the remark tunnel-dscp command. For more information about the tunnel tos command, see tunneling commands in Layer 3—IP Services Command Reference.
If you execute the remark tunnel-dscp command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure traffic behavior data to mark matching packets with DSCP value 2 in the outer IP header of tunneled packets.
[Sysname-behavior-data] remark tunnel-dscp 2
traffic behavior
Use traffic behavior to create a traffic behavior and enter its view, or enter the view of an existing traffic behavior.
Use undo traffic behavior to delete a traffic behavior.
No traffic behaviors exist.
behavior-name: Specifies a name for the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [ mode  qppb-manipulation | insert-before before-classifier-name ] *
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
mode qppb-manipulation: Specifies that the class-behavior association applies only to QPPB. The if-match qos-local-id command in the class sets the same local QoS ID as the apply qos-local-id command in the BGP routing policy. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
insert-before before-classifier-name: Inserts the new traffic class before an existing traffic class in the QoS policy. The before-classifier-name argument specifies an existing traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new traffic class is placed at the end of the QoS policy.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
# Associate traffic class database with traffic behavior test in QoS policy user1, and specify that the class-behavior association applies only to QPPB.
[Sysname-qospolicy-user1] classifier database behavior test mode qppb-manipulation
# Associate traffic class database with traffic behavior test in QoS policy user1, and insert traffic class database before an existing traffic class named class-a.
[Sysname-qospolicy-user1] classifier database behavior test insert-before class-a
qos policy
control-plane
Use control-plane to enter control plane view.
In standalone mode:
In IRF mode:
control-plane chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
A QoS policy applied in control plane view takes effect on all packets to the control plane except the packets sent from the management interface.
# (In standalone mode.) Enter the control plane view of slot 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
display qos policy
Use display qos policy to display QoS policies.
In standalone mode:
In IRF mode:
display qos policy user-defined [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
user-defined: Specifies user-defined QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the QoS policies for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the QoS policies for the global active MPU. (In IRF mode.)
# Display all user-defined QoS policies.
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
     Behavior: 2
      Marking:
        Remark mpls-exp 4
     Behavior: 3
      -none-
For the output description, see Table 1 and Table 4.
Use display qos policy control-plane to display QoS policies applied to a control plane.
In standalone mode:
In IRF mode:
display qos policy control-plane chassis chassis-number slot slot-number
# (In standalone mode.) Display the QoS policy applied to the control plane of slot 2.
<Sysname> display qos policy control-plane slot 2
Control plane slot 2
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
        Green packets : 0 (Bytes)
                        0 (bps)
        Yellow packets: 0 (Bytes)
                        0 (bps)
                        0 (bps)
        Red packets   : 0 (Bytes)
   Classifier: 2
     Operator: AND
     Rule(s) :
      If-match protocol ipv6
     Behavior: 2
      Accounting enable:
        3268134 (Packets)
        1000 (pps)
      Marking:
        Remark mpls-exp 4
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 7 Command output
Direction
Inbound direction on the control plane.
Green packets
Total number of bytes for green packets and average rate of green packets in the most recent statistics collection interval. The interval is set by using the flow-interval command (see Ethernet interface commands in Interface Command Reference).
Yellow packets
Total number of bytes for yellow packets and average rate of yellow packets in the most recent statistics collection interval. The interval is set by using the flow-interval command (see Ethernet interface commands in Interface Command Reference).
Red packets
Total number of bytes for red packets and average rate of red packets in the most recent statistics collection interval. The interval is set by using the flow-interval command (see Ethernet interface commands in Interface Command Reference).
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane pre-defined to display predefined control plane QoS policies of cards.
In standalone mode:
In IRF mode:
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the predefined control plane QoS policies for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays predefined control plane QoS policies for all cards. (In IRF mode.)
# (In standalone mode.) Display the predefined control plane QoS policy of slot 3.
<Sysname> display qos policy control-plane pre-defined slot 3
Pre-defined policy information slot 3
  Protocol          Priority   Bandwidth          Group
  Default           N/A        7168 (kbps)        N/A
  IS-IS             29         8192 (kbps)        critical
  VRRP              36         512 (kbps)         important
  OSPF Multicast    30         5120 (kbps)        critical
  IGMP              18         512 (kbps)         important
  OSPFv3 Unicast    30         5120 (kbps)        critical
  OSPFv3 Multicast  30         5120 (kbps)        critical
  VRRPv6            36         512 (kbps)         important
  ARP               12         1024 (kbps)        normal
  DHCP Snooping     18         3072 (kbps)        redirect
  802.1x            12         128 (kbps)         important
  STP               36         256 (kbps)         critical
  LACP              36         64 (kbps)          critical
  MVRP              18         256 (kbps)         critical
  TTL Expires       18         64 (kbps)          monitor
  IPOPTION          18         64 (kbps)          normal
  BGPv6             24         1024 (kbps)        critical
  Hop Limit Expires 18         64 (kbps)          monitor
  IPOPTIONv6        18         64 (kbps)          normal
  LLDP              24         64 (kbps)          important
  DLDP              24         64 (kbps)          critical
  ARP Snooping      18         1024 (kbps)        redirect
  DHCPv6            18         3072 (kbps)        normal
Table 8 Command output
Pre-defined control plane policy
Contents of the predefined control plane QoS policy.
Use display qos policy global to display QoS policies applied globally.
In standalone mode:
In IRF mode:
display qos policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
inbound: Specifies the QoS policy applied in the inbound direction globally.
outbound: Specifies the QoS policy applied in the outbound direction globally.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays global QoS policies for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays global QoS policies for the global active MPU. (In IRF mode.)
If you do not specify a direction, this command displays both QoS policies applied globally.
# Display QoS policies applied globally.
<Sysname> display qos policy global
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
                        0 (bps)
                        0 (bps)
                        0 (bps)
Table 9 Command output
Direction
Direction (inbound or outbound ) in which the QoS policy is applied.
Green packets
Yellow packets
Red packets
Use display qos policy interface to display the QoS policies applied to interfaces.
In standalone mode:
display qos policy interface [ interface-type interface-number ] [ slot slot-number | all ] [ inbound | outbound ]
In IRF mode:
display qos policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number | all ] [ inbound | outbound ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays QoS policies applied to all interfaces.
slot slot-number: Specifies a card by its slot number. Only virtual interfaces such as aggregate interfaces support this option. If you do not specify a card, this command displays QoS policies on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays QoS policies on the global active MPU. Only virtual interfaces such as aggregate interfaces support this option. (In IRF mode.)
all: Displays information about QoS policies applied to a logical interface on all cards. If you do not specify this keyword, the command displays information about QoS policies applied to a logical interface on the global active MPU.
inbound: Specifies the QoS policies applied to the inbound direction.
outbound: Specifies the QoS policies applied to the outbound direction.
If you do not specify a direction, this command displays both the QoS policies applied to the inbound direction and the QoS policies applied to the outbound direction.
# Display the QoS policy applied to the incoming traffic of GigabitEthernet 3/1/1.
<Sysname> display qos policy interface gigabitethernet 3/1/1 inbound
Interface: GigabitEthernet3/1/1
  Direction: Inbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
                        0 (bps)
                        0 (bps)
                        0 (bps)
# Display the QoS policy applied to the incoming traffic of interface Route-Aggregation1 on all cards.
<Sysname> display qos accounting policy interface Route-Aggregation 1 all inbound
slot 1:
  Interface: Route-Aggregation1
    Direction: Inbound
    Policy: p
     Classifier: c
       Operator: AND
       Rule(s) :
        If-match any
       Behavior: b
        Marking:
          Remark dscp af11
slot 2:
    Direction: Inbound
    Policy: p
     Classifier: c
       Operator: AND
       Rule(s) :
        If-match any
       Behavior: b
        Marking:
          Remark dscp af11
# Display the QoS policies applied to all interfaces.
  Direction: Inbound
  Mode     : Share
  Policy: a
   Classifier: a
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: a
        CIR 112 (kbps), CBS 5120 (Bytes), EBS 0 (Bytes)
        Green action  : pass
                        0 (bps)
                        0 (bps)
                        0 (bps)
Table 10 Command output
Direction
Direction in which the QoS policy is applied to the interface.
Mode
Sharing mode for QoS and ACL resources.
This field appears only if a QoS policy is applied with the share-mode keyword specified.
Matched
Number of matching packets.
Forwarded
Average rate of successfully forwarded matching packets in a statistics collection period.
Dropped
Average rate of dropped matching packets in a statistics collection period.
Green packets
Yellow packets
Red packets
Redirect to next-hop
Redirect traffic to a next hop. If the next hop does not exist, this field is displayed as Redirect to next-hop N/A.
Use display qos vlan-policy to display QoS policies applied to VLANs.
In standalone mode:
In IRF mode:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays QoS policies applied to VLANs for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays QoS policies applied to VLANs for the global active MPU. (In IRF mode.)
If you do not specify a direction, this command displays the QoS policies applied to the inbound direction and the QoS policies applied to the outbound direction.
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Outbound
  Policy: 1
   Classifier: 1
     Operator: AND
     Rule(s) :
      If-match acl 2000
     Behavior: 1
      Marking:
        Remark dscp 3
        Green action  : pass
                        0 (bps)
        Yellow packets: 0(Bytes)
                        0 (bps)
        Red packets   : 0(Bytes)
                        0 (bps)
   Classifier: 2
     Operator: AND
     Rule(s) :
     Behavior: 2
        3268134 (Packets)
        1000 (pps)
      Marking:
   Classifier: 3
     Operator: AND
     Rule(s) :
      -none-
     Behavior: 3
      -none-
Table 11 Command output
Direction
Direction in which the QoS policy is applied for the VLAN.
Green packets
Yellow packets
Red packets
qos apply policy
Use qos apply policy to apply a QoS policy to an interface or control plane.
Use undo qos apply policy to remove an applied QoS policy.
qos apply policy policy-name { inbound | outbound } [ preorder preorder-value ] [ share-mode ]
undo qos apply policy policy-name { inbound | outbound }
No QoS policy is applied.
Control plane view
Interface view
inbound: Applies the QoS policy to the inbound direction.
outbound: Applies the QoS policy to the outbound direction. This keyword is not supported in control plane view.
preorder preorder-value: Specifies the priority that the traffic behavior in a QoS policy is executed. The greater the priority value, the higher the priority. The preorder-value argument can only be 1 in the current software version. This option is not supported in control plane view.
share-mode: Applies the QoS policy in sharing mode. If you do not specify this keyword, this command applies the QoS policy in non-sharing mode. This keyword is not supported in control plane view.
A QoS policy applied to the inbound direction of an interface cannot contain any of these queuing actions: queue ef, queue af, or queue wfq.
On the following cards, if you apply QoS policies separately to an aggregate interface and a member port of the aggregate interface, the QoS policy applied to the aggregate interface effect:
·          CSPEX.
·          CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E.
The QoS policy applied to the member port takes effect after it leaves the aggregation group.
A QoS policy configured with CBQ is not supported in control plane view.
You can use the following commands to match protocol packets sent to the CPU for a QoS policy applied to a control plane:
·          if-match control-plane protocol
·          if-match control-plane protocol-group
·          if-match acl
When you use the if-match acl command to match protocol packets sent to the CPU, follow these restrictions and guidelines:
¡  The used ACL must be an advanced ACL.
¡  You must specify TCP or UDP for the protocol argument in the rule.
¡  You must specify a source port or destination port by using the eq operator in the rule.
For example, an IPv4 advanced ACL that contains a rule permit tcp source-port eq 80 statement can match TCP packets sent to the CPU.
If you specify the share-mode keyword when applying a QoS policy to an interface, follow these restrictions and guidelines:
·          All interfaces on an interface module with the QoS policy applied in one direction share one QoS and ACL resource.
If the share-mode keyword is not specified, each interface uses one QoS and ACL resource in one direction.
·          The total bandwidth of all interfaces that share one QoS and ACL resource cannot exceed the set CIR if a traffic policing action is configured in the QoS policy.
If the share-mode keyword is not specified, the bandwidth of each interface can be limited to the CIR.
·          You cannot specify the share-mode keyword when applying an ACL to the same direction of the interface. For more information about applying an ACL to an interface, see the packet-filter (interface view) command in ACL commands.
If you specify the preorder preorder-value option when applying a QoS policy, follow these restrictions and guidelines:
·          This option is supported only in the inbound direction of interfaces on CSPEX cards.
·          Packets preferentially match the traffic classes in the QoS policy.
The display qos policy interface command output for an interface also contains packet statistics for all interfaces that share the QoS and ACL resource with the interface.
You cannot change the sharing mode dynamically after a QoS policy is applied to an interface. To change the sharing mode for an applied QoS policy, perform the following tasks:
1.        Remove the QoS policy from the interface.
2.        Reapply the QoS policy with or without the share-mode keyword specified.
# Apply QoS policy USER1 to the outgoing traffic of GigabitEthernet 3/1/1.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] qos apply policy USER1 outbound
# Apply QoS policy aaa to the incoming traffic of the control plane of slot 3.
[Sysname-cp-slot3] qos apply policy aaa inbound
# Apply QoS policy aaa in sharing mode to the outgoing traffic of GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1]qos apply policy aaa outbound share-mode
qos apply policy global
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
qos apply policy policy-name global { inbound | outbound } [ preorder preorder-value ]
undo qos apply policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
preorder preorder-value: Specifies the order in which QoS policies applied in the same direction are executed. The greater the value, the higher the priority. The preorder-value argument can only be 1 in the current software version. A QoS policy configured with this option is executed before a QoS policy that is not configured with this option. This option takes effect only in the inbound direction on CSPEX cards.
A QoS policy applied globally takes effect on traffic of all interfaces.
# Globally apply QoS policy user1 to the incoming traffic.
[Sysname] qos apply policy user1 global inbound
qos policy
Use qos policy to create a QoS policy and enter its view, or enter the view of an existing QoS policy.
Use undo qos policy to delete a QoS policy.
qos policy policy-name
undo qos policy policy-name
No QoS policies exist.
policy-name: Specifies a name for the QoS policy, a case-sensitive string of 1 to 31 characters.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a QoS policy named user1.
classifier behavior
qos apply policy
qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to eight VLAN IDs or a VLAN ID range in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
# Apply QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
reset qos policy control-plane
Use reset qos policy control-plane to clear the statistics of the QoS policy applied to a control plane.
In standalone mode:
In IRF mode:
reset qos policy control-plane chassis chassis-number slot slot-number
# (In standalone mode.) Clear the statistics of the QoS policy applied to the control plane of slot 3.
<Sysname> reset qos policy control-plane slot 3
reset qos policy global
Use reset qos policy global to clear the statistics for QoS policies applied globally.
inbound: Specifies the QoS policy applied to the inbound direction globally.
outbound: Specifies the QoS policy applied to the outbound direction globally.
If you do not specify a direction, this command clears the statistics for both QoS policies applied globally.
# Clear the statistics of the QoS policy applied to the incoming traffic globally.
<Sysname> reset qos policy global inbound
reset qos vlan-policy
Use reset qos vlan-policy to clear the statistics for QoS policies applied to VLANs.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
If you do not specify a direction, this command clears the statistics for both the QoS policies applied to the inbound direction and the QoS policies applied to the outbound direction .
# Clear the statistics of QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
Exclusive bandwidth commands
display qos exclusive-bandwidth interface outbound
Use display qos exclusive-bandwidth interface outbound to display exclusive bandwidth settings in the outbound direction of interfaces.
In standalone mode:
display qos exclusive-bandwidth interface [ interface-type interface-number ] outbound [ slot slot-number ]
In IRF mode:
display qos exclusive-bandwidth interface [ interface-type interface-number ] outbound [ chassis chassis-number slot slot-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays exclusive bandwidth settings for all interfaces.
slot slot-number: Specifies a card by its slot number. Only virtual interfaces such as aggregate interfaces support this option. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. Only virtual interfaces such as aggregate interfaces support this option. (In IRF mode.)
# Display the exclusive bandwidth setting for Ten-GigabitEthernet 3/1/1.
<Sysname> display qos exclusive-bandwidth interface ten-gigabitethernet 3/1/1 outbound
Ten-GigabitEthernet3/1/1 exclusive-bandwidth: 500 kbps
Outbound traffic statistics:
 Total passed: 1 packets, 2 bytes
 Total discarded: 3 packets, 4 bytes
 Last 30 seconds pass rate: 0 pps, 0 bps
 Last 30 seconds discard rate: 0 pps, 0 bps
Table 12 Command output
Total passed
Total number of packets and total number of bytes allowed to pass.
Total discarded
Total number of packets and total number of bytes dropped.
Number of packets and number of bytes allowed to pass per second in the last 30 seconds.
Number of packets and number of bytes dropped per second in the last 30 seconds.
Use qos exclusive-bandwidth to set the exclusive bandwidth on an interface.
Use undo qos exclusive-bandwidth to cancel the exclusive bandwidth setting on an interface.
qos exclusive-bandwidth bandwidth-value
No exclusive bandwidth is set on an interface.
bandwidth-value: Specifies the exclusive bandwidth value in kbps. The value range for this argument is:
·          300 to 950000 for GE interfaces.
·          300 to 9500000 for 10-GE interfaces.
·          300 to 38000000 for 40-GE interfaces.
·          300 to 95000000 for 100-GE interfaces.
·          300 to 95000000 for Layer 3 aggregate interfaces.
The exclusive bandwidth on an interface is reserved for specific features and cannot be shared with other features. The amount of exclusive bandwidth is deducted from the interface bandwidth. For example, if you set the exclusive bandwidth for CRLSP, the exclusive bandwidth can only be used by CRLSP. For more information about the CRLSP exclusive bandwidth, see static CRLSP configuration in MPLS Configuration Guide.
The exclusive bandwidth feature is mutually exclusive with the HQoS feature. If one feature has been configured on an interface, the other feature cannot be configured successfully.
# Set the exclusive bandwidth to 500 kbps on Ten-GigabitEthernet 3/1/1.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] qos exclusive-bandwidth 500
Priority mapping commands
display qos map-table
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ inbound [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp ] ]
inbound: Specifies priority maps for the inbound direction.
Table 13 Priority maps
Priority mapping
dot1p-dot1p
dot1p-dp
dot1p-dscp
dot1p-exp
dot1p-lp
dscp-dot1p
dscp-dp
dscp-dscp
dscp-exp
dscp-lp
exp-dot1p
exp-dp
exp-dscp
exp-exp
exp-lp
If you do not specify a priority map, the command  displays the configuration of all uncolored priority maps.
If you do not specify any parameters, the command (namely, the display qos map-table command) displays the configuration of all priority maps in both directions, including colored and uncolored priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define   DIRECTION: inbound
IMPORT  :  EXPORT
   0    :    0
   1    :    1
   2    :    2
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 14 Command output
MAP-TABLE NAME
Name of the priority map.
TYPE
Type of the priority map.
DIRECTION
Direction of the priority map.
IMPORT
Input values of the priority map.
EXPORT
Output values of the priority map.
display qos map-table color
Use display qos map-table color to display the configuration of a colored priority map.
display qos map-table color [ green | yellow | red ] { inbound [ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp ] | outbound [ dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp ] }
outbound: Specifies priority maps for the outbound direction.
For the description of other keywords, see Table 13.
Packets processed by traffic policing are colored green, yellow, or red. To perform priority mapping for packets in different colors, the device provides colored priority maps, each of which is a priority map specific to a color. For how traffic policing processes and colors packets, see ACL and QoS Configuration Guide.
If you do not specify a color, this command displays the configuration of priority maps for all three colors.
If you do not specify a priority map, this command displays the configuration of all colored priority maps.
# Display the configuration of the EXP-local priority map for incoming green packets.
<Sysname> display qos map-table color green inbound exp-lp
MAP-TABLE NAME: exp-lp   TYPE: pre-define   COLOR: green   DIRECTION: inbound
IMPORT  :  EXPORT
   0    :    0
   1    :    1
   2    :    2
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 15 Command output
MAP-TABLE NAME
Priority map name.
TYPE
Priority map type.
COLOR
Priority map color.
DIRECTION
IMPORT
EXPORT
display qos map-table interface
Use display qos map-table interface to display flexible priority maps applied to interfaces.
In standalone mode:
display qos map-table interface [ interface-type interface-number ] [ slot slot-number ] [ inbound | outbound ]
In IRF mode:
display qos map-table interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays flexible priority maps applied to all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the flexible priority maps applied on all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the flexible priority maps applied on all cards. (In IRF mode.)
inbound: Specifies flexible priority maps applied to the inbound direction.
outbound: Specifies flexible priority maps applied to the outbound direction.
If you do not specify a direction, this command displays both the flexible priority maps applied to the inbound direction and the flexible priority maps applied to the outbound direction.
# Display the flexible priority map applied to GigabitEthernet 3/1/1.
<Sysname> display qos map-table interface gigabitethernet 3/1/1
  Direction: Inbound
  Map table name: user1
display qos map-table name
qos map-table name
Use display qos map-table name to display the configuration of flexible priority maps.
display qos map-table name [ map-table-name ]
map-table-name: Specifies a flexible priority map by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a flexible priority map, this command displays the configuration of all flexible priority maps.
# Display the configuration of flexible priority map user1.
<Sysname> display qos map-table name user1
Map table name: user1   Item: 4
Type             Import   Export
dot1p-lp            0        2
dot1p-lp            1        0
dscp-dp             2        1
dscp-dp             3        3
qos map-table name
import (flexible priority map view)
Use import to configure mappings for a flexible priority map.
Use undo import to delete mappings of a flexible priority map.
{ dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp | lp-dot1p | lp-dp | lp-dscp | lp-exp | lp-phb } import import-value-list export export-value
undo { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp | lp-dot1p | lp-dp | lp-dscp | lp-exp | lp-phb } import import-value-list
No mappings exist in a flexible priority map.
Flexible priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
For the description of other parameters, see Table 16.
Table 16 Priority maps
Priority mapping
dot1p-dot1p
dot1p-dp
dot1p-dscp
dot1p-exp
dot1p-lp
dscp-dot1p
dscp-dp
dscp-dscp
dscp-exp
dscp-lp
exp-dot1p
exp-dp
exp-dscp
exp-exp
exp-lp
lp-dot1p
Local-802.1p priority map.
lp-dp
Local-drop priority map.
lp-dscp
Local-DSCP priority map.
lp-exp
Local-EXP priority map.
lp-phb
Local-PHB priority map.
If you execute this command multiple times and enter the same input values for one priority map, the most recent configuration takes effect.
# Configure a mapping from DSCP 2 to local precedence 4 for flexible priority map user1.
[Sysname] qos map-table name user1
[Sysname-flexmaptbl-user1] dscp-lp import 2 export 4
qos map-table name
import (priority map view)
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-drop priority map to map 802.1p priority values 4 and 5 to drop priority 1.
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
qos apply map-table name
Use qos apply map-table name to apply a flexible priority map to an interface.
Use undo qos apply map-table name to remove a flexible priority map from an interface.
qos apply map-table name map-table-name [ inbound | outbound ]
undo qos apply map-table name map-table-name [ inbound | outbound ]
No flexible priority map is applied to an interface.
Interface view
map-table-name: Specifies a flexible priority map by its name, a case-sensitive string of 1 to 31 characters. The specified flexible priority map must already exist.
inbound: Applies the flexible priority map to the inbound direction.
outbound: Applies the flexible priority map to the outbound direction.
If you do not specify a direction, this command applies the flexible priority map to the inbound direction. Only one flexible priority map can be applied to one direction of an interface.
If you both configure a priority map in priority map view and apply a flexible priority map to an interface, the flexible priority map takes effect on the interface.
·          Only the following priority maps can be applied to the inbound direction of an interface:
·          dot1p-dot1p
·          dot1p-dp
·          dot1p-dscp
·          dot1p-exp
·          dot1p-lp
·          dscp-dot1p
·          dscp-dp
·          dscp-dscp
·          dscp-exp
·          dscp-lp
·          exp-dot1p
·          exp-dp
·          exp-dscp
·          exp-exp
·          exp-lp
Only the following priority maps can be applied to the outbound direction of an interface:
·          lp-dot1p
·          lp-dp
·          lp-dscp
·          lp-exp
·          lp-php
# Apply flexible priority map user1 to GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] qos apply map-table name user1 outbound
qos map-table name
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p| dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp }
inbound: Specifies the priority map for the inbound direction.
outbound: Specifies the priority map for the outbound direction.
SPC, CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E), and CMPE-1104 cards do not support the dot1p-dot1p, dot1p-dscp, dot1p-exp, dscp-exp, dscp-lp, exp-dscp, exp-dp, exp-exp, or exp-lp priority map.
# Enter the inbound 802.1p-drop priority map view.
[Sysname] qos map-table inbound dot1p-dp
[Sysname-maptbl-in-dot1p-dp]
import
qos map-table color
Use qos map-table color to enter the specified colored priority map view.
qos map-table color { green | yellow | red } { inbound { dot1p-dot1p | dot1p-dp | dot1p-dscp | dot1p-exp | dot1p-lp | dscp-dot1p | dscp-dp | dscp-dscp | dscp-exp | dscp-lp | exp-dot1p | exp-dp | exp-dscp | exp-exp | exp-lp } | outbound { dot1p-dot1p | dot1p-dscp | dot1p-exp | dscp-dot1p | dscp-dscp | dscp-exp | exp-dot1p | exp-dscp | exp-exp } }
For a type of colored priority mapping, two priority maps exist: one for the inbound direction and one for the outbound direction.
SPC, CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E), and CMPE-1104 cards do not support this command.
# Enter the view of the EXP-local priority map for incoming green packets..
[Sysname] qos map-table color green inbound exp-lp
[Sysname-maptbl-green-in-exp-lp]
# Enter the view of the DSCP-local priority map for incoming red packets.
[Sysname] qos map-table color red inbound dscp-lp
[Sysname-maptbl-red-in-dscp-lp]
import
qos map-table name
Use qos map-table name to create a flexible priority map and enter its view, or enter the view of an existing flexible priority map.
Use undo qos map-table name to delete a flexible priority map.
qos map-table name map-table-name
undo qos map-table name map-table-name
No flexible priority maps exist.
map-table-name: Specifies a flexible priority map name, a case-sensitive string of 1 to 31 characters.
A flexible priority map applied to an interface cannot be deleted directly. To delete an applied flexible priority map, first remove the flexible priority map from the interface by using the undo qos apply map-table name command.
# Create a flexible priority map named user1 and enter its view.
[Sysname-map-tbl-user1]
Priority trust mode commands
display qos trust interface
Use display qos trust interface to display the priority trust mode and port priorities of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of GigabitEthernet 3/1/1.
<Sysname> display qos trust interface gigabitethernet 3/1/1
 Port priority information
  Port priority: 0
  Port dot1p priority: -
  Port dscp priority: -
  Port exp priority: -
  Port priority trust type: none
Table 17 Command output
Interface type and interface number.
Port dot1p priority
802.1p priority of the port.
Port dscp priority
DSCP value of the port.
Port exp priority
EXP value of the port.
Priority trust mode: auto or none. If the trust mode is none, the port priority is used for priority mapping.
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { auto | dot1p | dscp | inner-dot1p } [ override ]
undo qos trust
An interface trusts the port priority for priority mapping.
Interface view
auto: Uses the priority in incoming packets for priority mapping.
On SPC, CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E), and CMPE-1104 cards:
·          For non-IP packets, the 802.1p priority is used.
·          For IP packets, the IP precedence is used.
·          For MPLS packets, the EXP value is used.
On CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards:
·          For Layer 2 packets, the 802.1p priority is used.
·          For Layer 3 packets, the IP precedence is used.
dot1p: Uses the 802.1p priority of received packets for mapping.
dscp: Uses the DSCP precedence of received IP packets for mapping.
inner-dot1p: Uses the inner 802.1p priority of received QinQ packets for mapping.
override: Uses the priority derived through priority mapping to overwrite the original priority carried in the packet. By default, this feature is disabled.
On SPC and MPE-1104 cardsSPC, CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E), and CMPE-1104 cardsCSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E) and CMPE-1104 cards, you must specify the override keyword when configuring the qos trust auto command.
You must specify the override keyword when configuring the qos trust auto command on the following cards:
·          SPC cards.
·          CSPC cards.
·          CMPE-1104 cards.
·          CSPEX-1104-E and CSPEX-1104-E cards.
The dot1p, dscp, and inner-dot1p keywords are available only on CSPEX cards (except CSPEX-1204 and CSPEX-1104-E).
When an IP packet enters an MPLS network, the device populates the EXP field with the EXP value derived from a priority map even if the override keyword is not specified.
For a Layer 3 packet, the device overwrites the 802.1p priority value in the packet with the 802.1p priority value derived from a priority map even if the override keyword is not specified.
For an MPLS packet that comes from the public network, he device uses the EXP value in the packet for priority mapping instead of trusting the configured 802.1p or DSCP priority.
# Set the priority trust mode to auto on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] qos trust auto
Port priority commands
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority [ dot1p | dscp | exp ] priority-value
undo qos priority [ dot1p | dscp | exp ]
The port priority is 0.
Interface view
priority-value: Specifies the port priority value.
·          If no port priority type is specified, the port priority is in the range of 0 to 7.
·          If a card supports multiple port priority types, see Table 18 for the value range for each type of port priority.
Table 18 Value ranges for different types of port priority
Port priority type
Value range
Remarks
802.1p
0 to 7
The dot1p keyword is available only on CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards.
DSCP
0 to 63
The dscp keyword is available only on CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards.
EXP
0 to 7
The exp keyword is available only on CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards.
# Set the port priority of GigabitEthernet 3/1/1 to 2.
[Sysname-GigabitEthernet3/1/1] qos priority 2
# Set the DSCP priority of GigabitEthernet 3/1/1 to 2.
[Sysname-GigabitEthernet3/1/1] qos priority dscp 20
Traffic policing, GTS, and rate limit commands
Traffic policing commands
display qos car control-plane whitelist
Use display qos car control-plane whitelist to display whitelist-based control plane CAR configuration and statistics.
In standalone mode:
display qos car control-plane whitelist [ ipv6 ] slot slot-number
In IRF mode:
display qos car control-plane whitelist [ ipv6 ] chassis chassis-number slot slot-number
ipv6: Specifies the IPv6 dynamic whitelist. If you do not specify this keyword, the command displays IPv4 whitelist-based control plane CAR configuration and statistics.
After you enable whitelist-based traffic policing for the control plane, you can use this command to display whitelist-based control plane CAR configuration and statistics by queue.
# (In standalone mode.) Display whitelist-based control plane CAR configuration and statistics for slot 2.
<Sysname> display qos car control-plane whitelist slot 2
Slot 2
   Whitelist-based traffic policing: Enabled
   Queue name: default
   CIR 30720 (kbps), CBS 8192 (Bytes)
   Green packets : 0 (Packets), 0 (Bytes)
   Yellow packets: 0 (Packets), 0 (Bytes)
   Red packets   : 0 (Packets), 0 (Bytes)
   Queue name: ftp
   CIR 1024 (kbps), CBS 8192 (Bytes)
   Queue name: telnet
   Queue name: ssh
   Queue name: http
   Queue name: https
   Queue name: ldp
   CIR 15360 (kbps), CBS 8192 (Bytes)
   Queue name: bgp
   Queue name: snmp
   Queue name: bfd
Table 19 Command output
Failed rule ID
IDs of rules that failed to take effect.
display acl whitelist
qos car whitelist enable
qos car (control plane view)
Use qos car to configure a CAR policy for a control plane.
Use undo qos car to delete a CAR policy from a control plane.
qos car { any | user } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { any | user } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car { any | user }
No CAR policy is configured.
Control plane view
any: Performs CAR for all control plane traffic.
user: Performs CAR for the control plane traffic from all online users.
cir committed-information-rate: Specifies the CIR in kbps. The committed-information-rate argument has the following value ranges:
·          8 to 160000000 for traffic policing for all control plane traffic. Only the range 8 to 1000000 is supported in the current software version.
·          8 to 160000000 for online user-based traffic policing.
·          8 to 160000000 for whitelist-based traffic policing. Only the range 8 to 100000 is supported in the current software version.
cbs committed-burst-size: Specifies the CBS in the range of 512 to 256000000 bytes. The default is the product of 62.5 and the CIR value.
ebs excess-burst-size: Specifies the EBS in bytes. If the PIR is not specified, the value range for excess-burst-size is 0 to 256000000, and the default is 0. If the PIR is specified, the value range for excess-burst-size is 512 to 256000000.
pir peak-information-rate: Specifies the PIR in kbps. The peak-information-rate argument has the following value ranges:
To use two rates for traffic policing, configure the qos car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the qos car command without the pir peak-information-rate option.
For online user-based traffic policing, the CIR is the rate of control plane traffic from each online user.
# Perform CAR for all control plane traffic for slot 3. The CAR parameters are as follows:
·          The CIR is 2000 kbps.
·          The CBS is 150000 bytes.
·          The EBS is 0 bytes.
[Sysname-cp-slot3] qos car any cir 2000 cbs 150000 ebs 0
# Perform CAR for the control plane traffic from all online users for slot 3. The CAR parameters are as follows:
·          The CIR is 200 kbps.
·          The CBS is 15000 bytes.
[Sysname-cp-slot3] qos car user cir 200 cbs 15000 ebs 0
qos car any (user profile view)
Use qos car any to configure a CAR policy for all packets of a user profile.
Use undo qos car to delete a CAR policy from a user profile.
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car { inbound | outbound } any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car { inbound | outbound }
No CAR policy is configured for a user profile.
User profile view
inbound: Performs CAR in the inbound direction.
outbound: Performs CAR in the outbound direction.
cir committed-information-rate: Specifies the CIR in the range of 8 to 160000000 kbps.
ebs excess-burst-size: Specifies the EBS in the range of 0 to 256000000 bytes. The default is 0.
pir peak-information-rate: Specifies the PIR in the range of 8 to 160000000 kbps.
The conforming traffic is permitted to pass through, and the excess traffic is dropped.
If you execute the qos car command multiple times for the same user profile or session group profile, the most recent configuration takes effect.
This command is available only on CSPEX cards (except CSPEX-1204).
# Perform CAR for packets received by user profile user. The CAR parameters are as follows:
·          The CBS is 51200 bytes.
[Sysname] user-profile user
[Sysname-user-profile-user] qos car outbound any cir 200 cbs 51200
Use qos car whitelist enable to enable whitelist-based traffic policing for the control plane.
Use undo qos car whitelist enable to disable whitelist-based traffic policing for the control plane.
qos car whitelist [ ipv6 ] enable
undo qos car whitelist [ ipv6 ] enable
Whitelist-based traffic policing is enabled, and the device uses the default rate limit values to police matching traffic.
Control plane view
ipv6: Enables whitelist-based traffic policing for the IPv6 dynamic whitelist. If you do not specify this keyword, the command enables whitelist-based traffic policing for the IPv4 dynamic whitelist.
After you execute this command, the system dynamically generates a whitelist according to existing TCP connections or other protocol sessions. The whitelist contains ACL rules used to match traffic. You can use the display acl whitelist command to display the ACL rules in the whitelist.
# Enable whitelist-based traffic policing for the control plane of slot 3.
[Sysname-cp-slot3] qos car whitelist enable
reset qos car control-plane whitelist
Use reset qos car control-plane whitelist to clear whitelist-based control plane CAR statistics.
In standalone mode:
reset qos car control-plane whitelist [ ipv6 ] slot slot-number
In IRF mode:
reset qos car control-plane whitelist [ ipv6 ] chassis chassis-number slot slot-number
ipv6: Specifies the IPv6 dynamic whitelist. If you do not specify this keyword, the command clears IPv4 whitelist-based control plane CAR statistics.
# (In standalone mode.) Clear whitelist-based control plane CAR statistics for slot 2.
<Sysname> reset qos car control-plane whitelist slot 2
GTS commands
display qos gts interface
Use display qos gts interface to display the GTS configuration for interfaces.
In standalone mode:
display qos gts interface [ interface-type interface-number [ slot slot-number ] ]
In IRF mode:
display qos gts interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration for all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the GTS configuration for the active MPU. This option is available only for aggregate interfaces. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the GTS configuration for the global active MPU. This option is available only for aggregate interfaces. (In IRF mode.)
# Display the GTS configuration for all interfaces.
 Rule: If-match queue 1
  CIR 10000 (kbps), CBS 625000 (Bytes)
Table 20 Command output
Interface name, including the interface type and interface number.
Rule
Match criteria.
display qos queue-statistics user-id
Use display queue-statistics user-id to display queue-based statistics for a home user.
In standalone mode:
display qos queue-statistics user-id user-id [ slot slot-number ] outbound
In IRF mode:
display qos queue-statistics user-id user-id [ chassis chassis-number slot slot-number ] outbound
user-id user-id: Specifies a home user by a system-assigned, hexadecimal ID in the range of 0 to fffffffe.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays information for all cards. (In IRF mode.)
outbound: Specifies queue-based statistics for the outbound direction.
A user that comes online on a physical interface is called a local user. A user that comes online on a logical interface is called a global user. If you do not specify a slot for a global user, the command displays queue-based statistics for all slots associated with the logical interface.
# Display queue-based statistics for the home user with a user ID of 48000009.
<Sysname> display qos queue-statistics user-id 48000009 outbound
slot 2
 User ID: 0x48000009 (global)
  Direction: Outbound
  Forwarded: 6756832 packets, 891901824 bytes
  Dropped: 49648521 packets, 6553604772 bytes
  Queue 0
   Forwarded: 1333037 packets, 175960884 bytes
   Dropped: 5721125 packets, 755188500 bytes
   Green forwarded: 1333037 packets, 175960884 bytes
   Green dropped: 0 packets, 0 bytes
   Yellow forwarded: 0 packets, 0 bytes
   Yellow dropped: 0 packets, 0 bytes
   Red forwarded: 0 packets, 0 bytes
   Red dropped: 5721125 packets, 755188500 bytes
   Current queue length: 999 packets
  Queue 1
   Forwarded: 162933 packets, 21507156 bytes
   Dropped: 6888203 packets, 909242796 bytes
   Green forwarded: 162933 packets, 21507156 bytes
   Red dropped: 6888203 packets, 909242796 bytes
   Current queue length: 4092 packets
  Queue 2
   Forwarded: 162945 packets, 21508740 bytes
   Dropped: 6888260 packets, 909250320 bytes
   Green forwarded: 162945 packets, 21508740 bytes
   Red dropped: 6888260 packets, 909250320 bytes
  Queue 3
   Forwarded: 162956 packets, 21510192 bytes
   Dropped: 6888315 packets, 909257580 bytes
   Green forwarded: 162956 packets, 21510192 bytes
   Red dropped: 6888315 packets, 909257580 bytes
  Queue 4
   Forwarded: 163895 packets, 21634140 bytes
   Dropped: 6887445 packets, 909142740 bytes
   Green forwarded: 163895 packets, 21634140 bytes
   Red dropped: 6887445 packets, 909142740 bytes
  Queue 5
   Forwarded: 475882 packets, 62816424 bytes
   Dropped: 6575525 packets, 867969300 bytes
   Green forwarded: 475882 packets, 62816424 bytes
   Red dropped: 6575525 packets, 867969300 bytes
  Queue 6
   Forwarded: 1986335 packets, 262196220 bytes
   Dropped: 5065139 packets, 668598348 bytes
   Green forwarded: 1986335 packets, 262196220 bytes
   Red dropped: 5065139 packets, 668598348 bytes
  Queue 7
   Forwarded: 2308849 packets, 304768068 bytes
   Dropped: 4734509 packets, 624955188 bytes
   Green forwarded: 2308849 packets, 304768068 bytes
   Red dropped: 4734509 packets, 624955188 bytes
   Current queue length: 12276 packets
slot 4
  Direction: Outbound
  Queue 0
  Queue 1
  Queue 2
  Queue 3
  Queue 4
  Queue 5
  Queue 6
  Queue 7
Table 21 Command output
Forwarded
Total number of packets forwarded and total number of bytes forwarded.
Dropped
Total number of packets dropped and total number of bytes dropped.
Green forwarded
Number of green packets forwarded and number of bytes forwarded for green packets.
Green dropped
Number of green packets dropped and number of bytes dropped for green packets.
Yellow forwarded
Number of yellow packets forwarded and number of bytes forwarded for yellow packets.
Yellow dropped
Number of yellow packets dropped and number of bytes dropped for yellow packets.
Red forwarded
Number of red packets forwarded and number of bytes forwarded for red packets.
Red dropped
Number of red packets dropped and number of bytes dropped for red packets.
Number of packets in the queue.
qos gts (interface view)
Use qos gts to set GTS parameters on an interface.
Use undo qos gts to delete the GTS configuration on an interface.
undo qos gts queue queue-id
No GTS parameters are configured.
Interface view
queue queue-id: Shapes the packets in a queue specified by its ID. The value range for queue-id is 0 to 7.
·          300 to 1000000 for GE interfaces.
·          300 to 10000000 for 10-GE interfaces.
·          2500 to 100000000 for 100-GE interfaces. Only the range 2500 to 10000000 is supported in the current software version.
cbs committed-burst-size: Specifies the CBS in the range of 4096 to 133169152 bytes. The default is the product of 62.5 and the CIR value.
On CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, CSPEX-1104-E, and CSPEX-1204 cards, you cannot configure both queue-based GTS and a queue scheduling profile with WRR queuing for the same interface.
# Shape the packets in queue 1 on GigabitEthernet 3/1/1. The GTS parameters are as follows:
·          The CIR is 6400 kbps.
[Sysname-GigabitEthernet3/1/1] qos gts queue 1 cir 6400 cbs 51200
qos gts (session group profile view)
Use qos gts to set GTS parameters for a session group profile.
Use undo qos gts to delete GTS settings for a session group profile.
qos gts { any | queue queue-id } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts { any | queue queue-id } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
undo qos gts { any | queue queue-id }
No GTS parameters are set.
Session group profile view
cir committed-information-rate: Specifies the CIR in the range of 300 to 100000000 kbps.
pir peak-information-rate: Specifies the PIR in the range of 300 to 100000000 kbps. The PIR cannot be smaller than the CIR.
queue-length queue-length: Specifies the maximum number of packets that can be queued, in the range of 1 to 12582912. The default is 4096. The queue length cannot be greater than the integer that is closest to and greater than the CIR multiplied by 0.078125.
This command takes effect only on outgoing traffic.
This command is available only on CSPEX cards (except CSPEX-1204 and CSPEX-1104-E).
# Shape the packets received by session group profile aaa in queue 1. The GTS parameters are as follows:
·          The CIR is 400 kbps.
[Sysname] user-profile aaa type session-group
[Sysname-session-group-profile-aaa] qos gts queue 1 cir 400 cbs 51200
qos gts (user group profile view)
Use qos gts to set GTS parameters for a user group profile.
Use undo qos gts to delete GTS settings for a user group profile.
qos gts any cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ queue-length queue-length ]
qos gts any cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ queue-length queue-length ]
undo qos gts any
User group profile view
any: Shapes all packets.
# Shape the packets received by user group profile aaa. The GTS parameters are as follows:
[Sysname] user-group-profile aaa
[Sysname-user-group-profile-aaa] qos gts any cir 400 cbs 51200
Rate limit commands
display qos lr
Use display qos lr to display the rate limit information for interfaces.
In standalone mode:
display qos lr interface [ interface-type interface-number ] [ slot slot-number ]
In IRF mode:
display qos lr interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit information for all interfaces.
# Display the rate limit information for all interfaces.
 Direction: Outbound
Table 22 Command output
Direction
Direction to which the rate limit configuration is applied: inbound or outbound.
qos lr
Use qos lr to configure outbound rate limiting on an interface.
Use undo qos lr to delete the outbound rate limit configuration on an interface.
qos lr outbound cir committed-information-rate [ cbs committed-burst-size ]
undo qos lr outbound
No rate limit is configured.
Interface view
·          160 to 100000000 for Layer 3 aggregate interfaces.
cbs committed-burst-size: Specifies the CBS in bytes. The committed-burst-size argument has the following value ranges:
·          1024 to 133169152 for Layer 3 aggregate interfaces.
·          4096 to 133169152 for other interfaces.
# Limit the rate of outgoing packets on GigabitEthernet 3/1/1, with CIR 400 kbps and CBS 51200 bytes.
[Sysname-GigabitEthernet3/1/1] qos lr outbound cir 400 cbs 51200
Hardware congestion management commands
Common commands
display qos queue interface
Use display qos queue interface to display the queuing information for interfaces.
display qos queue interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queuing information for all interfaces.
# Display the queuing information for all interfaces.
<Sysname> display qos queue interface
 Output queue: Strict Priority queuing
Interface: GigabitEthernet3/1/2
Interface: GigabitEthernet3/1/3
Interface: GigabitEthernet3/1/4
Interface: GigabitEthernet3/1/5
Interface: GigabitEthernet3/1/6
Table 23 Command output
display qos-queue resource
Use display qos-queue resource to display the QoS queue resource usage for a card.
In standalone mode:
display qos-queue resource slot slot-number { inbound | outbound }
In IRF mode:
display qos-queue resource chassis chassis-number slot slot-number { inbound | outbound }
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
If a card does not support collecting QoS queue resource usage statistics, this command displays no queue resource usage statistics for the card.
# Display the QoS queue resource usage for the card in slot 3 in the outbound direction.
[Sysname] display qos-queue resource slot 3 outbound
Chip 0
 Res-Pool    Type        Total      Used      Free
 TM0         UserGroup   22126      0         22126   (share with each other)
             Hqos        22126      0         22126   (share with each other)
             PortQos     22126      0         22126   (share with each other)
             AdvancedUser22126      0         22126   (share with each other)
             BasicUser   33174      0         33174   (share with each other)
Table 24 Command output
Res-Pool
TM chip for the resources.
Resource type.
Total
Total number of resources.
Used
Number of resources that have been used.
Free
Number of resources that you can use.
SP commands
display qos queue sp interface
Use display qos queue sp interface to display the SP queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration for all interfaces.
# Display the SP queuing configuration of GigabitEthernet 3/1/1.
<Sysname> display qos queue sp interface gigabitethernet 3/1/1
Table 25 Command output
Output queue
Type of the current output queue.
qos sp
Use qos sp to enable SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
An interface uses SP queuing.
Interface view
This command is available only on the following cards:
·          SPC cards.
·          CSPC cards (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E).
·          CMPE cards.
# Enable SP queuing on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] qos sp
WRR commands
CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards do not support WRR.
display qos queue wrr interface
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration for all interfaces.
# Display the WRR queuing configuration of GigabitEthernet 3/1/1.
<Sysname> display qos queue wrr interface gigabitethernet 3/1/1
 Output queue: Weighted Round Robin queuing
 Queue ID     Queue name     Group     Weight
 0            be             1         1
 1            af1            1         2
 2            af2            1         3
 3            af3            1         4
 4            af4            1         5
 5            ef             1         6
 6            cs6            1         7
 7            cs7            1         8
Table 26 Command output
Output queue
Group
Number of the group a queue is assigned to.
Weight
Packet-based queue scheduling weight of a queue. N/A is displayed for a queue that uses the SP scheduling algorithm.
qos wrr
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to restore the default.
qos wrr weight
undo qos wrr weight
Interface view
weight: Allocates bandwidth to queues based on packet count.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable weight-based WRR queuing on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] qos wrr weight
qos wrr weight
Use qos wrr weight to configure the WRR queuing parameters for a queue on an interface.
Use undo qos wrr to restore the default for a queue.
qos wrr queue-id group 1 weight schedule-value
undo qos wrr queue-id
All queues on a WRR-enabled interface are in WRR group 1 and have a weight of 1.
Interface view
queue-id: Specifies a queue by its ID in the range of 0 to 7 or by a keyword listed in Table 27.
Table 27 The number-keyword map for the queue-id argument
Number
Keyword
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
schedule-value: Specifies the number of packets that can be sent each time, in the range of 1 to 310. Only the range 1 to 63 is supported in the current software version.
This command is available only on SPC, CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E), and CMPE-1104 cards
# Enable packet-count WRR queuing on GigabitEthernet 3/1/1, and assign queue 0, with the scheduling weight 10, to WRR group 1.
[Sysname-GigabitEthernet3/1/1] qos wrr 0 group 1 weight 10
qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to remove a queue from the SP group.
qos wrr queue-id group sp
All queues on a WRR-enabled interface are in the WRR group.
Interface view
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
# Enable WRR queuing on GigabitEthernet 3/1/1, and assign queue 0 to the SP group.
[Sysname-GigabitEthernet3/1/1] qos wrr 0 group sp
qos wrr
WFQ commands
CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards do not support WFQ.
Layer 3 Ethernet subinterfaces on SPC, CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E), and CMPE-1104 cards do not support WFQ.
display qos queue wfq interface
Use display qos queue wfq interface to display the WFQ configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ configuration for all interfaces.
# Display the WFQ configuration of GigabitEthernet 3/1/1.
<Sysname> display qos wfq interface gigabitethernet 3/1/1
 Output queue: Hardware Weighted Fair Queuing
 Queue ID     Queue name     Weight         Min bandwidth
 0            be             1              0
 1            af1            1              0
 2            af2            1              0
 3            af3            1              0
 4            af4            1              0
 5            ef             1              0
 6            cs6            1              0
 7            cs7            1              0
Table 28 Command output
Output queue
Group
Number of the group that holds the queue.
Weight
Packet-count scheduling weight of the queue.
Min bandwidth
Minimum guaranteed bandwidth for the queue.
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
No minimum guaranteed bandwidth is provided.
Interface view
min bandwidth-value: Sets the minimum guaranteed bandwidth in kbps. The value range for the bandwidth-value argument is 300 to 1000000 for GE interfaces, 300 to 10000000 for 10-GE interfaces, 300 to 40000000 for 10-GE interfaces, and 300 to 100000000 for 100-GE interfaces.
The minimum guaranteed bandwidth is the amount of bandwidth guaranteed for a queue when the interface is congested.
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] qos wfq weight
[Sysname-GigabitEthernet3/1/1] qos bandwidth queue 0 min 100
qos wfq
qos wfq
Use qos wfq to enable WFQ on an interface.
Use undo qos wfq to restore the default.
qos wfq weight
undo qos wfq weight
Interface view
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable weight-based WFQ on GigabitEthernet 3/1/1.
qos wfq weight
Use qos wfq weight to configure the scheduling weight of a queue.
Use undo qos wfq to restore the default for a queue.
qos wfq queue-id weight schedule-value
undo qos wfq queue-id
All queues on a WFQ-enabled interface have a weight of 1.
Interface view
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable packet-count WFQ on GigabitEthernet 3/1/1, and set the scheduling weight to 10 for queue 0.
[Sysname-GigabitEthernet3/1/1] qos wfq 0 weight 10
qos bandwidth queue
qos wfq
Queue scheduling profile commands
bandwidth queue
Use bandwidth queue to set the minimum guaranteed bandwidth for a queue.
Use undo bandwidth queue to restore the default.
undo bandwidth queue queue-id
No minimum guaranteed bandwidth is set for a queue.
Queue scheduling profile view
queue-id: Specifies a queue by its ID in the range of 0 to 7.
min bandwidth-value: Specifies the minimum guaranteed bandwidth in the range of 300 to 100000000 kbps.
# Set the minimum guaranteed bandwidth to 128 kbps for queue 1.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] bandwidth queue 1 min 128
display qos qmprofile configuration
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
In standalone mode:
In IRF mode:
display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number ]
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the queue scheduling profile configuration for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the queue scheduling profile configuration for the global active MPU. (In IRF mode.)
# Display the configuration of queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
 Queue ID  Type  Group   Schedule   Schedule  Min         Max
                         unit       value     bandwidth   bandwidth
 be        SP    N/A     N/A        N/A       0           N/A
 af1       SP    N/A     N/A        N/A       0           N/A
 af2       SP    N/A     N/A        N/A       1000        N/A
 af3       SP    N/A     N/A        N/A       0           N/A
 af4       SP    N/A     N/A        N/A       0           N/A
 ef        SP    N/A     N/A        N/A       0           N/A
 cs6       SP    N/A     N/A        N/A       0           N/A
 cs7       SP    N/A     N/A        N/A       0           N/A
Table 29 Command output
Queue scheduling profile name.
Basic
This word indicates a basic queue scheduling profile. If this word is absent, the queue scheduling profile is advanced.
Queue scheduling type:
·         SP.
·         WRR.
Group
Priority group to which the queue belongs.
N/A indicates this field is ignored.
Schedule unit
Scheduling unit.
N/A indicates that this field is ignored.
Schedule value
This field indicates the number of packets that can be scheduled each time.
Min bandwidth
Max bandwidth
Maximum allowed bandwidth for the queue.
display qos qmprofile interface
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
In standalone mode:
display qos qmprofile interface [ interface-type interface-number [ slot slot-number ] ] [ inbound ]
In IRF mode:
display qos qmprofile interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ] [ inbound ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the queue scheduling profile information for the active MPU. This option is available only for aggregate interfaces. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the queue scheduling profile information for the global active MPU. This option is available only for aggregate interfaces. (In IRF mode.)
inbound: Specifies the queue scheduling profile applied to the inbound direction. If you do not specify this keyword, the command displays the queue scheduling profile applied to the outbound direction. This keyword is not supported in the current software version.
This command is available only on CSPEX cards.
# Display the queue scheduling profile applied to GigabitEthernet 3/1/1.
<Sysname> display qos qmprofile interface gigabitethernet 3/1/1
Interface: GigabitEthernet3/1/1
Direction: Outbound
Table 30 Command output
Direction
Direction in which the queue scheduling profile is applied.
Name of the queue scheduling profile applied to the interface.
qos apply qmprofile (interface view)
Use qos apply qmprofile to apply a queue scheduling profile to an interface.
Use undo qos apply qmprofile to restore the default.
qos apply qmprofile profile-name [ inbound ]
undo qos apply qmprofile [ inbound ]
Interface view
inbound: Applies the queue scheduling profile to the inbound direction. If you do not specify this keyword, the command applies the queue scheduling profile to the outbound direction. This keyword is not supported in the current software version.
You can apply only one queue scheduling profile to one direction of an interface.
On a CSPEX-1204 card, you cannot configure both queue-based GTS and a queue scheduling profile with WRR queuing for the same interface.
# Apply queue scheduling profile myprofile to the outbound direction of GigabitEthernet 3/1/1.
[Sysname-GigabitEthernet3/1/1] qos apply qmprofile myprofile
qos apply qmprofile (session group profile view, user profile view)
Use qos apply qmprofile to apply a queue scheduling profile to a session group profile or user profile.
No queue scheduling profile is applied to a session group profile or user profile.
User profile view
inbound: Applies the queue scheduling profile to the packets sent by the session group profile or user profile. If you do not specify this keyword, the command applies the queue scheduling profile to the packets received by the session group profile or user profile. This keyword is not supported in the current software version.
You can apply only one queue scheduling profile to one direction of a session group profile or user profile.
To delete a queue scheduling profile applied to a session group profile or user profile, first remove the queue scheduling profile from the session group profile or user profile.
The queue scheduling profile to be applied to a session group profile or user profile must already exist.
# Apply queue scheduling profile myprofile to the packets received by session group profile a123.
[Sysname] user-profile a123 type session-group
[Sysname-session-group-profile-a123] qos apply qmprofile myprofile
# Apply queue scheduling profile myprofile to the packets received by user profile a123.
[Sysname-user-profile-a123] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name [ basic ]
undo qos qmprofile profile-name
No user-created queue scheduling profiles exist.
profile-name: Specifies a name for the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
basic: Specifies the queue scheduling profile as basic. If you do not specify this keyword, the command creates an advanced queue scheduling profile. This keyword is not supported in the current software version.
To delete a queue scheduling profile already applied to an object, first remove it from the object.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to delete queue scheduling parameter settings.
queue queue-id { sp | wrr group group-id weight schedule-value } [ max-bandwidth bandwidth-value ]
undo queue queue-id
All queues in a queue scheduling profile are SP queues.
sp: Enables SP for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WRR group by its ID in the range of 1 to 4.
schedule-value: Specifies the number of packets that can be sent each time, in the range of 1 to 310. The CSPEX-1204 card supports only the range 1 to 63.
max-bandwidth bandwidth-value: Specifies the maximum allowed bandwidth in the range of 300 to 100000000 kbps. This option is supported only on CSPEX cards (except CSPEX-1204 and CSPEX-1104-E).
This command is available only on CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile. Configure queue 1 to meet the following requirements:
·          The WRR queuing is used.
·          The WRR group is group 1.
·          The scheduling weight is 100.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 100
qos qmprofile
CBQ commands
queue af
Use queue af to enable assured-forwarding (AF) and set the minimum guaranteed bandwidth for AF.
Use undo queue af to restore the default.
queue af bandwidth { bandwidth [ pir peak-information-rate ] | pct percentage }
undo queue af
AF is not configured.
Traffic behavior view
bandwidth: Specifies the minimum guaranteed bandwidth in the range of 64 to 100000000 kbps.
pir peak-information-rate: Specifies the PIR in the range of 64 to 100000000 kbps. CMPE-1104 cards do not support this option.
pct percentage: Specifies the percentage of the available bandwidth, in the range of 1 to 100.
To associate the traffic behavior configured with the queue af command with a class in a policy, you must follow these requirements:
·          The total bandwidth assigned to AF and EF queues in a policy cannot exceed the maximum available bandwidth of the interface where the policy is applied.
·          The total percentage of bandwidth assigned to AF and EF in a policy cannot exceed 100.
·          The bandwidth assigned to AF and EF in a policy must use the same form, either as an absolute bandwidth value or as a percentage.
If you execute this command multiple times in the same traffic behavior, the most recent configuration takes effect.
You cannot configure the queue af command together with the queue ef or queue wfq command in the same traffic behavior.
SPC and CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E) cards do not support the queue af command.
# Enable AF in traffic behavior database and set the minimum guaranteed bandwidth to 200 kbps for AF.
[Sysname-behavior-database] queue af bandwidth 200
queue ef
Use queue ef to enable expedited forwarding (EF) and set the guaranteed bandwidth for EF.
Use undo queue ef to restore the default.
queue ef bandwidth { bandwidth [ cbs burst ] [ pir peak-information-rate ] | pct percentage [ cbs-ratio ratio ] }
undo queue ef
EF is not configured.
bandwidth: Specifies the guaranteed bandwidth in the range of 64 to 100000000 kbps.
cbs burst: Specifies the CBS in the range of 1600 to 1000000000 bytes. The default is the bandwidth value multiplied by 25. To accommodate bursts, you must set the CBS to be greater than the amount of traffic transmitted at the bandwidth over 50 milliseconds.
cbs-ratio ratio: Specifies the allowed burst ratio in the range of 25 to 500. This default is 25.
This command and the queue af command are mutually exclusive in one traffic behavior.
The total bandwidth assigned to AF and EF in a policy cannot exceed the maximum available bandwidth of the interface where the policy is applied.
The total percentage of the maximum available bandwidth assigned to AF and EF in a policy cannot exceed 100.
The bandwidths assigned to AF and EF in a policy must have the same type, in kbps or in percentage.
If the queue ef bandwidth pct percentage [ cbs-ratio ratio ] command is used, the CBS equals (Interface available bandwidth × percentage × ratio)/100.
If the queue ef bandwidth bandwidth [ cbs burst ] command is used, the CBS equals burst. If the cbs burst option is not specified, the CBS equals bandwidth × 25.
SPC and CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E) cards do not support the queue ef command.
# Configure EF in traffic behavior database, with the guaranteed bandwidth as 200 kbps and CBS as 5000 bytes.
[Sysname-behavior-database] queue ef bandwidth 200 cbs 5000
queue wfq
Use queue wfq to configure WFQ for the default class.
Use undo queue wfq to restore the default.
queue wfq
undo queue wfq
WFQ is not configured for the default class.
SPC and CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E) cards do not support this command.
You cannot configure the queue wfq command together with the queue af or queue ef command in the same traffic behavior.
# Configure the default class to use WFQ.
[Sysname] traffic behavior test
[Sysname-behavior-test] queue wfq
weight
Use weight to set the WFQ weight.
Use undo weight to restore the default.
weight weight-value
undo weight
On CMPE-1104 cards, the WFQ weight is 1 for AF and BE queues, and the WFQ weight is 0 for the EF queue.
On CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, and CSPEX cards (except CSPEX-1204), the WFQ weight is 1 for AF and EF queues, and the WFQ weight is 0 for the BE queue.
For POS interfaces and Ethernet interfaces on the CSPEX-1204 card, the WFQ weight is 1 for AF and EF queues, and the WFQ weight is 0 for the BE queue. For other interface types and subinterfaces on the CSPEX-1204 card, SP queuing is used.
weight-value: Specifies the weight value in the range of 1 to 63.
The following traffic is scheduled by using WFQ:
·          Traffic between the minimum guaranteed bandwidth and PIR.
·          Traffic between the maximum bandwidth and PIR.
This command must be used together with the queue af, queue ef, or queue wfq command.
This command is available only on SPEX, CSPEX, and CEPC cardsCSPEX cardsCSPEX and CEPC cards if it is used together with the queue ef command.
On CMPE-1104 cards, the AF traffic exceeding its minimum guaranteed bandwidth and BE traffic are scheduled according to the WFQ weights. If remaining bandwidth is available, the EF traffic exceeding its minimum bandwidth can be sent.
On CSPEX cards (except CSPEX-1204), the AF traffic exceeding its minimum guaranteed bandwidth, EF traffic exceeding its guaranteed bandwidth, and BE traffic are scheduled according to the WFQ weights.
For POS interfaces and Ethernet interfaces on the CSPEX-1204 card, the AF traffic exceeding its minimum guaranteed bandwidth, EF traffic exceeding its guaranteed bandwidth, and BE traffic are scheduled according to the WFQ weights. For other interface types and subinterfaces on the CSPEX-1204 card, the following traffic types are in descending order of priority:
·          EF traffic within the guaranteed bandwidth.
·          AF traffic within the minimum guaranteed bandwidth.
·          AF traffic exceeding the minimum guaranteed bandwidth.
·          BE traffic.
·          EF traffic exceeding the guaranteed bandwidth.
# Configure traffic behavior database as follows:
·          Enable AF, and set the minimum guaranteed bandwidth to 200 kbps.
·          Set the WFQ weight to 10 for traffic exceeding 200 kbps.
[Sysname-behavior-database] weight 10
Congestion avoidance commands
WRED table commands
display qos wred interface
Use display qos wred interface to display the WRED information for interfaces.
In standalone mode:
display qos wred interface [ interface-type interface-number [ slot slot-number ] ]
In IRF mode:
display qos wred interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED information for all interfaces.
slot slot-number: Specifies a card by its slot number. This option is available only for aggregate interfaces. If you do not specify a member device, this command displays the WRED information for the master device. This option is available only for aggregate interfaces. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. This option is available only for aggregate interfaces. If you do not specify this option, the command displays the WRED information for the global active MPU. This option is available only for aggregate interfaces. (In IRF mode.)
# Display the WRED information for all interfaces.
<Sysname> display qos wred interface
 Current WRED configuration:
 Applied WRED table name: queue-table1
Table 31 Command output
display qos wred table
Use display qos wred table to display the WRED table configuration.
In standalone mode:
In IRF mode:
display qos wred table [ name table-name ] [ chassis chassis-number slot slot-number ]
name table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the WRED table configuration for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the WRED table configuration for the global active MPU. (In IRF mode.)
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID gmin     gmax     gpro ymin     ymax     ypro rmin     rmax     rpro exp ECN
0   100      1000     10   100      1000     10   100      1000     10   9   N
1   100      1000     10   100      1000     10   100      1000     10   9   N
2   100      1000     10   100      1000     10   100      1000     10   9   N
3   100      1000     10   100      1000     10   100      1000     10   9   N
4   100      1000     10   100      1000     10   100      1000     10   9   N
5   100      1000     10   100      1000     10   100      1000     10   9   N
6   100      1000     10   100      1000     10   100      1000     10   9   N
7   100      1000     10   100      1000     10   100      1000     10   9   N
Table 32 Command output
Table name
Name of a WRED table.
Table type
Type of a WRED table.
QID
Queue ID.
gmin
Lower limit for green packets.
gmax
Upper limit for green packets.
gpro
Drop probability for green packets.
ymin
Lower limit for yellow packets.
ymax
Upper limit for yellow packets.
ypro
Drop probability for yellow packets.
rmin
Lower limit for red packets.
rmax
Upper limit for red packets.
rpro
Drop probability for red packets.
exp
Exponent for average queue length calculation.
ECN
Indicates whether ECN is enabled for the queue:
·         Y—Enabled.
·         N—Disabled.
qos wred apply
Use qos wred apply to apply a WRED table to an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and the tail drop mode is used on an interface.
Interface view
table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters. If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply WRED table table1 to GigabitEthernet 3/1/1.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] qos wred apply table1
qos wred table
qos wred queue table
Use qos wred queue table to create a WRED table and enter its view, or enter the view of an existing WRED table.
Use undo qos wred queue table to delete a WRED table.
undo qos wred queue table table-name
No WRED tables exist.
queue: Creates a queue-based WRED table, which drops packets based on the queue when congestion occurs.
table table-name: Specifies a name for the WRED table, a case-sensitive string of 1 to 32 characters.
You cannot delete a WRED table in use. To delete it, first remove it from the specified interface.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
queue
Use queue to configure the drop-related parameters for a queue in the queue-based WRED table.
Use undo queue to restore the default.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id | all }
The low-limit argument is 100, the high-limit argument is 1000, and the discard-prob argument is 10.
WRED table view
all: Specifies all queues.
drop-level drop-level: Specifies a drop level. This argument is a consideration for dropping packets. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
low limit low-limit: Specifies the lower limit for the average queue length, in the range of 0 to 12582912 packets.
high-limit high-limit: Specifies the upper limit for the average queue length, in the range of 0 to 12582912 packets. The value for the high-limit argument must be greater than the value for the low-limit argument.
discard-probability discard-prob: Specifies the drop probability in percentage, in the range of 0 to 100. When the average queue size is between the lower limit and the upper limit, packets are dropped according to this drop probability. This option is not configurable on CSPEX cards.
When the average queue size is smaller than the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped at random. The longer the queue is, the higher the drop probability is. When the average queue size exceeds the upper threshold, subsequent packets are dropped.
# In queue-based WRED table queue-table1, configure the following drop-related parameters for packets in queue 1:
·          The drop level is 1.
·          The lower limit for the average queue length is 10.
·          The upper limit for the average queue length is 20.
·          The drop probability is 30%.
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
qos wred table
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
ECN is disabled for a queue.
WRED table view
When both the receiver and sender support ECN, the device can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
CSPEX cards do not support this command.
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
qos wred table
queue weighting-constant
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation, in the range of 0 to 15.
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula:
Average queue size = previous average queue size × (1-2-n) + current queue size × 2-n,
where n can be configured with the qos wred weighting-constant command.
This command does not take effect on CSPEX cards.
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
qos wred table
Global CAR commands
car name
Use car name to use a global CAR action in a traffic behavior.
Use undo car to restore the default.
car name car-name
undo car
No global CAR action is configured in a traffic behavior.
car-name: Specifies the name of an aggregate CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
# Use aggregate CAR action aggcar-1 in traffic behavior be1.
display qos car name
display traffic behavior user-defined
Use display qos car name to display information about global CAR actions.
car-name: Specifies a global CAR action by its name, which can be an aggregate CAR action or a hierarchical CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify a global CAR action, this command displays information about all global CAR actions.
# Display information about all aggregate CAR actions.
<Sysname> display qos car name
  Mode: aggregative
   CIR 32 (kbps) CBS: 2048 (Bytes) PIR: 888 (kbps) EBS: 0 (Bytes)
Table 33 Command output
Name
Name of the global CAR action.
Mode
Type of the CAR action.
CIR  CBS  PIR  EBS
Parameters for the CAR action.
qos car
Use qos car aggregative to configure an aggregate CAR action.
Use undo qos car to delete an aggregate CAR action.
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ]
qos car car-name aggregative cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ]
undo qos car car-name
No aggregate CAR action is configured.
car-name: Specifies the name of the global CAR action. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters.
cir committed-information-rate: Specifies the CIR in the range of 1 to 160000000 kbps.
ebs excess-burst-size: Specifies the EBS in the range of 0 to 256000000 bytes. The default is 512.
pir peak-information-rate: Specifies the PIR in the range of 1 to 160000000 kbps.
To use two rates for global CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for global CAR, configure the qos car command without the pir peak-information-rate option.
If you set the cir committed-information-rate option to a value in the range of 1 to 8 kbps on CSPEX cards (except CSPEX-1204 and CSPEX-1104-E), the actual setting takes effect. If you set this option to a value in the range of 1 to 8 kbps on any other card, 8 kbps always takes effect.
An aggregate CAR action takes effect only after it is used in a QoS policy.
# Configure aggregate CAR action aggcar-1, where CIR is 200 and CBS is 2048.
[Sysname] qos car aggcar-1 aggregative cir 200 cbs 2048
reset qos car name
Use reset qos car name to clear the statistics about global CAR actions.
car-name: Specifies a global CAR action by its name. This argument must start with a letter, and is a case-sensitive string of 1 to 31 characters. If you do not specify a global CAR action, this command clears statistics for all global CAR actions.
# Clear the statistics about global CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display outgoing traffic statistics collected for interfaces on a per-queue basis.
In standalone mode:
display qos queue-statistics interface [ interface-type interface-number [ slot slot-number ] ] outbound
In IRF mode:
display qos queue-statistics interface [ interface-type interface-number [ chassis chassis-number slot slot-number ] ] outbound
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
slot slot-number: Specifies a card by its slot number. This option is available only for aggregate interfaces. If you do not specify a member device, this command displays the outgoing traffic statistics for the master device. This option is available only for aggregate interfaces. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. This option is available only for aggregate interfaces. If you do not specify this option, the command displays the outgoing traffic statistics for the global active MPU. This option is available only for aggregate interfaces. (In IRF mode.)
Only the following traffic statistics can be displayed in the current software version:
·          The number of forwarded green packets, the number of bytes forwarded for green packets, and the average rate of green packets in the most recent statistics collection interval.
·          The number of dropped red packets, the number of bytes dropped for red packets, and the average rate of red packets in the most recent statistics collection interval.
On CSPEX-1204 cards, only the number of forwarded green packets and the number of bytes forwarded for green packets can be displayed.
# Display queue-based outgoing traffic statistics of GigabitEthernet 3/1/1.
<Sysname> display qos queue-statistics interface gigabitethernet 3/1/1 outbound
 Direction: Outbound
 Forwarded: 10077 packets, 864466 bytes, 0 pps, 0 bps
 Dropped: 0 packets, 0 bytes, 0 pps, 0 bps
 Queue 0
  Forwarded: 61 packets, 4758 bytes, 0 pps, 0 bps
  Green forwarded: 61 packets, 4758 bytes, 0 pps, 0 bps
  Green dropped: 0 packets, 0 bytes, 0 pps, 0 bps
  Yellow forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Yellow dropped: 0 packets, 0 bytes, 0 pps, 0 bps
  Red forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Red dropped: 0 packets, 0 bytes, 0 pps, 0 bps
  Total queue length: 0 packets
  Current queue length: 0 packets
 Queue 1
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Green forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
 Queue 2
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
Table 34 Command output
Interface for which queue-based traffic statistics are displayed.
Direction
Direction of traffic for which statistics are collected.
Forwarded
Total number of forwarded packets, total number of bytes for forwarded packets, and average rate of forwarded packets in the most recent statistics collection interval. The interval is set by using the flow-interval command.
Dropped
Total number of dropped packets, total number of bytes for dropped packets, and average rate of dropped packets in the most recent statistics collection interval. The interval is set by using the flow-interval command.
Green forwarded
Total number of forwarded green packets, total number of bytes for forwarded green packets, and average rate of forwarded green packets in the most recent statistics collection interval. The interval is set by using the flow-interval command.
Green dropped
Total number of dropped green packets, total number of bytes for dropped green packets, and average rate of dropped green packets in the most recent statistics collection interval. The interval is set by using the flow-interval command.
Yellow forwarded
Total number of forwarded yellow packets, total number of bytes for forwarded yellow packets, and average rate of forwarded yellow packets in the most recent statistics collection interval. The interval is set by using the flow-interval command.
Yellow dropped
Total number of dropped yellow packets, total number of bytes for dropped yellow packets, and average rate of dropped yellow packets in the most recent statistics collection interval. The interval is set by using the flow-interval command.
Red forwarded
Total number of forwarded red packets, total number of bytes for forwarded red packets, and average rate of forwarded red packets in the most recent statistics collection interval. The interval is set by using the flow-interval command.
Red dropped
Total number of dropped red packets, total number of bytes for dropped red packets, and average rate of dropped red packets in the most recent statistics collection interval. The interval is set by using the flow-interval command.
reset counters interface (Interface Command Reference)
Use qos queue-statistics to enable queue-based traffic accounting.
Use undo qos queue-statistics to disable queue-based traffic accounting.
qos queue-statistics { inbound | outbound }
undo qos queue-statistics { inbound | outbound }
Queue-based traffic accounting is enabled.
inbound: Specifies the inbound direction. You can configure this keyword, but it does not take effect.
# Enable queue-based outgoing traffic accounting.
[Sysname] qos queue-statistics outbound
QPPB commands
bgp-policy
Use bgp-policy to enable QPPB, which transmits the apply ip-precedence and apply qos-local-id configuration through BGP routing policies.
Use undo bgp-policy to restore the default.
bgp-policy { destination | source } ip-prec-map ip-qos-map
undo bgp-policy { destination | source } [ ip-prec-map ip-qos-map ]
QPPB is disabled.
Interface view
destination: Searches the routing table by destination IP address.
source: Searches the routing table by source IP address. If the source keyword is specified, the source IP address is used as the destination address for inverse lookup.
ip-prec-map: Sets an IP precedence value for matching packets.
ip-qos-map: Sets a local QoS ID for matching packets.
The bgp-policy command applies only to the incoming traffic of an interface.
In an MPLS L3VPN, the bgp-policy command is executed after the QoS features are performed in the inbound direction of the PE's public network interface. In any other case, the bgp-policy command is executed before the QoS features.
If you configure two bgp-policy commands by using the source and destination keywords, the newly entered command overwrites the previously entered command.
# Configure Ten-GigabitEthernet 3/1/1 to get the IP precedence and local QoS ID by looking up routes based on source IP address.
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] bgp-policy source ip-prec-map ip-qos-map
apply ip-precedence (Layer 3—IP Routing Command Reference)
apply qos-local-id (Layer 3—IP Routing Command Reference)
route-policy (Layer 3—IP Routing Command Reference)
