12-Security Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command References-Release795x-6W10012-Security Command Reference
14-ARP attack protection commands
14-ARP attack protection commands 140.67 KB
ARP attack protection commands· 1
Unresolvable IP attack protection commands· 1
arp resolving-route enable· 1
arp resolving-route probe-count 1
arp resolving-route probe-interval 2
arp source-suppression enable· 2
arp source-suppression limit 3
display arp source-suppression· 4
Source MAC-based ARP attack detection commands· 4
arp source-mac· 4
arp source-mac aging-time· 5
arp source-mac check-interval 6
arp source-mac exclude-mac· 6
arp source-mac threshold· 7
display arp source-mac· 8
display arp source-mac configuration· 10
display arp source-mac statistics· 11
reset arp source-mac· 12
reset arp source-mac statistics· 13
ARP packet source MAC consistency check commands· 14
arp valid-check enable· 14
display arp valid-check statistics· 14
reset arp valid-check statistics· 15
ARP active acknowledgement commands· 16
arp active-ack enable· 16
Interface-based ARP attack suppression commands· 16
arp attack-suppression check-interval 16
arp attack-suppression enable per-interface· 17
arp attack-suppression suppression-time· 18
arp attack-suppression threshold· 19
display arp attack-suppression configuration· 20
display arp attack-suppression per-interface· 20
display arp attack-suppression per-interface inteface· 22
reset arp attack-suppression per-interface· 23
reset arp attack-suppression per-interface statistics· 24
Authorized ARP commands· 25
arp authorized enable· 25
ARP scanning and fixed ARP commands· 25
arp fixup· 25
arp scan· 26
ARP gateway protection commands· 27
arp filter source· 27
ARP filtering commands· 28
arp filter binding· 28
ARP sender IP address checking commands· 29
arp sender-ip-range· 29
Use arp resolving-route enable to enable ARP blackhole routing.
Use undo arp resolving-route enable to disable ARP blackhole routing.
ARP blackhole routing is enabled.
Configure this command on the gateways.
# Enable ARP blackhole routing.
[Sysname] arp resolving-route enable
Use arp resolving-route probe-count to set the number of ARP blackhole route probes for each unresolved IP address.
Use undo arp resolving-route probe-count to restore the default.
arp resolving-route probe-count count
The device performs three ARP blackhole route probes for each unresolved IP address.
count: Sets the number of probes, in the range of 1 to 25.
# Configure the device to perform five ARP blackhole route probes for each unresolved IP address.
[Sysname] arp resolving-route probe-count 5
Use arp resolving-route probe-interval to set the interval at which the device probes ARP blackhole routes.
Use undo arp resolving-route probe-interval to restore the default.
arp resolving-route probe-interval interval
The device probes ARP blackhole routes every 1 second.
interval: Specifies the probe interval in the range of 1 to 5 seconds.
# Configure the device to probe ARP blackhole routes every 3 seconds.
[Sysname] arp resolving-route probe-interval 3
Use arp source-suppression enable to enable the ARP source suppression feature.
Use undo arp source-suppression enable to disable the ARP source suppression feature.
The ARP source suppression feature is disabled.
Configure this feature on the gateways.
# Enable the ARP source suppression feature.
[Sysname] arp source-suppression enable
Use arp source-suppression limit to set the maximum number of unresolvable packets that can be processed per source IP address within 5 seconds.
Use undo arp source-suppression limit to restore the default.
The device can process a maximum of 10 unresolvable packets per source IP address within 5 seconds.
limit-value: Specifies the limit in the range of 2 to 1024.
If unresolvable packets received from an IP address within 5 seconds exceed the limit, the device stops processing the packets from that IP address until the 5 seconds elapse.
# Configure the device to process a maximum of 100 unresolvable packets per source IP address within 5 seconds.
[Sysname] arp source-suppression limit 100
Use display arp source-suppression to display information about the current ARP source suppression configuration.
# Display information about the current ARP source suppression configuration.
<Sysname> display arp source-suppression
 ARP source suppression is enabled
 Current suppression limit: 100
Maximum number of unresolvable packets that can be processed per source IP address within 5 seconds.
arp source-mac
Use arp source-mac to enable the source MAC-based ARP attack detection feature and specify a handling method.
Use undo arp source-mac to disable the source MAC-based ARP attack detection feature.
arp source-mac { filter | monitor }
undo arp source-mac [ filter | monitor ]
The source MAC-based ARP attack detection feature is disabled.
filter: Specifies the filter handling method.
monitor: Specifies the monitor handling method.
This feature checks the number of ARP packets delivered to the CPU. If the number of packets from the same MAC address within the check interval exceeds a threshold, the device generates an ARP attack entry for the MAC address. Before the entry ages out, the device handles the attack by using either of the following methods:
·          Monitor—Only generates log messages.
·          Filter—Generates log messages and filters out subsequent ARP packets from the MAC address.
Make sure you have enabled the ARP logging feature before enabling the source MAC-based ARP attack detection feature. For information about the ARP logging feature, see Layer 3—IP Services Configuration Guide.
If you do not specify any handling method in the undo arp source-mac command, the command disables this feature.
# Enable the source MAC-based ARP attack detection feature and specify the filter handling method.
[Sysname] arp source-mac filter
Use arp source-mac aging-time to set the aging time for ARP attack entries.
Use undo arp source-mac aging-time to restore the default.
arp source-mac aging-time time
The aging time for ARP attack entries is 300 seconds.
time: Sets the aging time for ARP attack entries, in the range of 60 to 6000 seconds.
# Set the aging time for ARP attack entries to 60 seconds.
[Sysname] arp source-mac aging-time 60
Use arp source-mac check-interval to set the check interval for source MAC-based ARP attack detection.
Use undo arp source-mac check-interval to restore the default.
arp source-mac check-interval interval
The check interval for source MAC-based ARP attack detection is 5 seconds.
interval: Specifies the check interval in seconds. The value range is 5 to 60.
The source MAC-based ARP attack detection feature checks the number of ARP packets delivered to the CPU. If the number of packets from the same MAC address within the check interval exceeds the threshold, the device generates an ARP attack entry for the MAC address.
If attacks occur frequently in your network, set a short check interval so that source MAC-based ARP attacks can be detected in a timely manner. If attacks seldom occur, you can set a long check interval.
# Set the check interval for source MAC-based ARP attack detection to 30 seconds.
[Sysname] arp source-mac check-interval 30
arp source-mac
Use arp source-mac exclude-mac to exclude specific MAC addresses from source MAC-based ARP attack detection.
Use undo arp source-mac exclude-mac to remove the excluded MAC addresses from source MAC-based ARP attack detection.
arp source-mac exclude-mac mac-address&<1-64>
undo arp source-mac exclude-mac [ mac-address&<1-64> ]
No MAC addresses are excluded from source MAC-based ARP attack detection.
mac-address&<1-64>: Specifies a MAC address list. The mac-address argument indicates an excluded MAC address in the format of H-H-H. &<1-64> indicates that you can configure a maximum of 64 excluded MAC addresses.
If you do not specify a MAC address, the undo arp source-mac exclude-mac command removes all excluded MAC addresses.
# Exclude a MAC address from source MAC-based ARP attack detection.
[Sysname] arp source-mac exclude-mac 001e-1200-0213
Use arp source-mac threshold to set the threshold for source MAC-based ARP attack detection. If the number of ARP packets sent from a MAC address within the check interval exceeds this threshold, the device recognizes this as an attack.
Use undo arp source-mac threshold to restore the default.
arp source-mac threshold threshold-value
The threshold for source MAC-based ARP attack detection is 30.
threshold-value: Specifies the threshold for source MAC-based ARP attack detection. The value range for this argument is 1 to 5000.
# Set the threshold for source MAC-based ARP attack detection to 30.
[Sysname] arp source-mac threshold 30
Use display arp source-mac to display ARP attack entries detected by source MAC-based ARP attack detection.
In standalone mode:
display arp source-mac interface interface-type interface-number [ slot slot-number ] [ verbose ]
display arp source-mac { mac mac-address | vlan vlan-id } slot slot-number [ verbose ]
display arp source-mac slot slot-number [ count | verbose ]
In IRF mode:
[ chassis chassis-number slot slot-number ] [ verbose ]
display arp source-mac { mac mac-address | vlan vlan-id } chassis chassis-number slot slot-number [ verbose ]
display arp source-mac chassis chassis-number slot slot-number [ count | verbose ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays ARP attack entries for all interfaces.
slot slot-number: Displays the ARP attack entries detected by the physical interfaces that reside on the specified card and belong to the specified virtual interface. If you do not specify a card, this command displays entries detected by the physical interfaces that reside on the active MPUs and belong to the specified virtual interface. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the ARP attack entries detected by the physical interfaces that reside on the specified slot and belong to the virtual interface. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays entries detected by the physical interfaces that reside on the global active MPU and belong to the virtual interface. (In IRF mode.)
mac mac-address: Displays the ARP attack entry for the specified MAC address. The MAC address format is H-H-H.
vlan vlan-id: Displays the source MAC-based ARP attack entry for the specified VLAN. The VLAN ID is in the range of 1 to 4094.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ARP attack entries for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ARP attack entries for the global active MPU. (In IRF mode.)
verbose: Displays the detailed information about source MAC-based ARP attack entries. If you do not specify this keyword, this command displays the brief information about the source MAC-based ARP attack entries.
count: Displays the number of ARP attack entries detected by source MAC-based ARP attack detection. If you do not specify this keyword, the command displays ARP attack entries detected by source MAC-based ARP attack detection.
(In standalone mode.) The slot slot-number option is supported only when the interface interface-type interface-number option specifies a virtual interface.
(In IRF mode.) The chassis chassis-number slot slot-number options are supported only when the interface interface-type interface-number option specifies a virtual interface.
Virtual interfaces can be Layer 2 aggregate interfaces, Layer 3 aggregate interfaces, Layer 3 aggregate subinterfaces, and VXLAN VSI interface.
If you do not specify any parameters, the command displays all ARP attack entries.
# Display the ARP attack entries detected by source MAC-based ARP attack detection on GigabitEthernet 3/1/1.
<Sysname> display arp source-mac interface gigabitethernet 3/1/1
Source MAC     VLAN ID Interface                Aging time (sec) Packets dropped
23f3-1122-3344 4094    GE3/1/1                  10
# Display the number of ARP attack entries detected by source MAC-based ARP attack detection on slot 3.
<Sysname> display arp source-mac slot 3 count
Total source MAC-based ARP attack detection entries: 1
# Display the detailed information about ARP attack entries detected by source MAC-based ARP attack detection on GigabitEthernet 3/1/1.
<Sysname> display arp source-mac interface gigabitethernet 3/1/1 verbose
Source MAC: 0001-0001-0001
VLAN ID: 4094
Hardware status: Succeeded
Aging time: 10 seconds
Interface: GigabitEthernet3/1/1
Attack time: 2018/06/04 15:53:34
Packets dropped: 18446744073709551615
Source MAC
Source MA address in the source MAC-based ARP attack entry.
VLAN ID
ID of the VLAN where the source MAC-based ARP attack is detected.
Interface where the source MAC-based ARP attack is detected.
Aging time
Remaining lifetime of the source MAC-based ARP attack entry, in seconds.
Packets dropped
Total number of packets dropped by source MAC-based ARP attack detection.
If the packets dropped by source MAC-based ARP attack occurs on a Layer 2 Ethernet interface, packet drop statistics is not calculated and this field displays 1.
Total number of source MAC-based ARP attack entries.
Hardware status
Status of the source MAC-based ARP attack entry setting to hardware:
·         Succeeded
·         Failed
·         Not supported
·         Not enough resources
Attack time
Time when the source MAC-based ARP attack is detected. The formation of the time is YYYY/MM/DD HH:MM:SS.
Use display arp source-mac configuration to display the configuration of source MAC-based ARP attack detection.
# Display the configuration of source MAC-based ARP attack detection.
<Sysname> display arp source-mac configuration
ARP source-mac is enabled.
Mode: Filter        Check interval: 5 seconds
Threshold: 20       Aging time: 300 seconds
ARP source-mac is disabled.
The source MAC-based ARP attack detection is enabled.
The source MAC-based ARP attack detection is disabled.
Mode
Source MAC-based ARP attack detection mode:
·         Filter.
·         Monitor.
Check interval
Check interval of the source MAC-based ARP attack detection, in seconds.
Threshold
Threshold for source MAC-based ARP attack detection.
Aging time
Aging time of the source MAC-based ARP attack entry, in seconds.
arp source-mac
Use display arp source-mac statistics to display statistics for packets dropped by source MAC-based ARP attack detection.
In standalone mode:
display arp source-mac statistics slot slot-number
In IRF mode:
display arp source-mac statistics chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
This command is supported only on CSPEX (excluding CSPEX-1204 and CSPEX-1104-E cards) and CEPC cards.
# Display statistics for packets dropped by source MAC-based ARP attack detection on slot 3.
<Sysname> display arp source-mac statistics slot 3
Dropped ARP packets:123321
Dropped ARP packets
Number of packets dropped by source MAC-based ARP attack detection.
arp source-mac
Use reset arp source-mac to delete source MAC-based ARP attack entries.
In standalone mode:
reset arp source-mac [ interface interface-type interface-number | mac mac-address | vlan vlan-id ] [ slot slot-number ]
In IRF mode:
reset arp source-mac [ interface interface-type interface-number | mac mac-address | vlan vlan-id ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Deletes the source MAC-based ARP attack entries detected on the specified interface. The interface-type interface-number arguments specify an interface by its type and number.
mac mac-address: Deletes the source MAC-based ARP attack entry for the specified MAC address. The MAC address format is H-H-H.
vlan vlan-id: Deletes the source MAC-based ARP attack entry for the specified VLAN. The value range for the vlan-id argument is 1 to 4094.
If you do not specify any parameter, the command deletes all source MAC-based ARP attack entries on the device.
# Delete all source MAC-based ARP attack entries on the device.
<Sysname> reset arp source-mac
Use reset arp source-mac statistics to clear statistics of packets dropped by source MAC-based ARP attack detection.
In standalone mode:
reset arp source-mac statistics [ interface interface-type interface-number | mac mac-address | vlan vlan-id ] [ slot slot-number ]
In IRF mode:
reset arp source-mac statistics [ interface interface-type interface-number | mac mac-address | vlan vlan-id ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Clears statistics of packets dropped by source MAC-based ARP attack detection on the specified interface. The interface-type interface-number arguments specify an interface by its type and number.
mac mac-address: Clears statistics of packets dropped by source MAC-based ARP attack detection for the specified MAC address. The MAC address format is H-H-H.
vlan vlan-id: Clears statistics of packets dropped by source MAC-based ARP attack detection for the specified VLAN. The value range for the VLAN ID is 1 to 4094.
If you do not specify any parameter, the command clears all statistics of packets dropped by source MAC-based ARP attack detection.
# Clear all statistics of packets dropped by source MAC-based ARP attack detection.
<Sysname> reset arp source-mac statistics
Use arp valid-check enable to enable ARP packet source MAC address consistency check.
Use undo arp valid-check enable to disable ARP packet source MAC address consistency check.
ARP packet source MAC address consistency check is disabled.
Configure this feature on gateways. The gateways can filter out ARP packets whose source MAC address in the Ethernet header is different from the sender MAC address in the message body.
# Enable ARP packet source MAC address consistency check.
[Sysname] arp valid-check enable
Use display arp valid-check statistics to display statistics for packets dropped by ARP packet source MAC address consistency check.
In standalone mode:
display arp valid-check statistics slot slot-number
In IRF mode:
display arp valid-check statistics chassis chassis-number slot slot-number
# Display statistics for packets dropped by ARP packet source MAC address consistency check on slot 3.
<Sysname> display arp valid-check statistics slot 3
Table 5 Command output
Dropped ARP packets
Number of packets dropped by ARP packet source MAC address consistency check.
Use reset arp valid-check statistics to clear statistics for packets dropped by ARP packet source MAC address consistency check.
In standalone mode:
reset arp valid-check statistics [ slot slot-number ]
In IRF mode:
reset arp valid-check statistics [ chassis chassis-number slot slot-number ]
# Display statistics for packets dropped by ARP packet source MAC address consistency check on slot 1.
<Sysname> reset arp valid-check statistics
Use arp active-ack enable to enable the ARP active acknowledgement feature.
Use undo arp active-ack enable to disable the ARP active acknowledgement feature.
arp active-ack [ strict ] enable
undo arp active-ack [ strict ] enable
The ARP active acknowledgement feature is disabled.
strict: Enables strict mode for ARP active acknowledgement.
Configure this feature on gateways to prevent user spoofing.
In strict mode, a gateway learns an entry only when ARP active acknowledgement is successful based on the correct ARP resolution.
# Enable the ARP active acknowledgement feature.
[Sysname] arp active-ack enable
Interface-based ARP attack suppression is supported only on Layer 3 Ethernet interfaces and Layer 3 Ethernet subinterfaces of CSPEX cards (excluding CSPEX-1204 and CSPEX-1104-E cards) and CEPC cards.
Use arp attack-suppression check-interval to set the check interval for interface-based ARP attack suppression.
Use undo arp attack-suppression check-interval to restore the default.
arp attack-suppression check-interval interval
The check interval for interface-based ARP attack suppression is 5 seconds.
interval: Specifies the check interval in seconds. The value range is in the range of 5 to 60.
The interface-based ARP attack suppression feature monitors the number of ARP requests that each Layer 3 interface received within the check interval. If the number on an interface exceeds the ARP attack suppression threshold, the device creates an ARP attack suppression entry for the interface.
# Set the check interval for interface-based ARP attack suppression to 30 seconds.
[Sysname] arp attack-suppression check-interval 30
Use arp attack-suppression enable per-interface to enable interface-based ARP attack suppression.
Use undo arp attack-suppression enable per-interface to disable interface-based ARP attack suppression.
Interface-based ARP attack suppression is disabled.
Use this feature to rate limit ARP requests on each Layer 3 interface to prevent ARP spoofing attacks.
This feature monitors the number of ARP requests that each Layer 3 interface received within the check interval. If the number on an interface exceeds the ARP attack suppression threshold, the device creates an ARP attack suppression entry for the interface. Before the suppression time for the entry times out, the maximum receiving rate for ARP packets is limited on the interface.
During the suppression period, the device monitors the number of received ARP requests on the interface:
·          If the number of the received ARP requests is higher than or equal to a calculated value, the device determines that the ARP attack still exists on the interface. When the suppression time expires, the device resets the suppression time for the entry and continues the ARP suppression on the interface.
The calculated value = (suppression time/check interval) × suppression threshold
·          If the number of the received ARP requests is lower than the calculated value, the ARP suppression entry is deleted when the suppression time expires.
As a best practice, enable this feature on the gateway.
# Enable interface-based ARP attack suppression.
[Sysname] arp attack-suppression enable per-interface
Use arp attack-suppression suppression-time to set the interface-based ARP attack suppression time.
Use undo arp attack-suppression suppression-time to restore the default.
arp attack-suppression suppression-time time
The interface-based ARP attack suppression time is 300 seconds.
time: Specifies the suppression time in seconds. The value range is 60 to 6000.
When an interface-based ARP attack is detected on an interface, the device creates an ARP attack suppression entry for the interface, and starts the suppression time. Before the suppression time for the entry expires, the maximum receiving rate for ARP packets is limited on the interface. When the suppression time expires,
# Set the interface-based ARP attack suppression time to 60 seconds.
[Sysname] arp attack-suppression suppression-time 60
Use arp attack-suppression threshold to set the threshold for triggering interface-based ARP attack suppression.
Use undo arp attack-suppression threshold to restore the default.
arp attack-suppression threshold threshold-value
The interface-based ARP attack suppression threshold is 3000.
threshold-value: Specifies the interface-based ARP attack suppression threshold in the range of 1 to 5000. This threshold defines the maximum number of ARP requests that can be received on an interface within the check interval.
When the number of ARP requests received on an interface within the check interval exceeds the threshold, the system determines that the interface is being attacked.
# Set the interface-based ARP attack suppression threshold to 1000.
[Sysname] arp attack-suppression threshold 1000
Use display arp attack-suppression configuration to display the configuration of the interface-based ARP attack suppression.
# Display the configuration of the interface-based ARP attack suppression.
<Sysname> display arp attack-suppression configuration
ARP attack-suppression per-interface is enabled.
Check interval: 5 seconds      Suppression time : 300 seconds
Threshold: 3000
ARP attack-suppression per-interface is disabled.
Table 6 Command output
The interface-based ARP attack suppression is enabled.
The interface-based ARP attack suppression is disabled.
Check interval
Check interval of the interface-based ARP attack suppression, in seconds.
Suppression time
Interface-based ARP attack suppression time in seconds.
Threshold
Threshold for triggering interface-based ARP attack suppression.
Use display arp attack-suppression per-interface to display interface-based ARP attack suppression entries.
In standalone mode:
display arp attack-suppression per-interface slot slot-number [ count | verbose ]
In IRF mode:
display arp attack-suppression per-interface chassis chassis-number slot slot-number [ count | verbose ]
verbose: Displays the detailed information about interface-based ARP attack suppression entries. If you do not specify this keyword, this command displays brief information about interface-based ARP attack suppression entries.
count: Displays the number of interface-based ARP attack suppression entries. If you do not specify this keyword, the command displays interface-based ARP attack suppression entries.
If you do not specify any parameter, this command displays brief information about all interface-based ARP attack suppression entries.
# Display interface-based ARP attack suppression entries for slot 1.
<Sysname> display arp attack-suppression per-interface interface slot 1
Interface                Suppression time (second) Packets dropped
GE3/1/1                  200                       18446744073709551615
GE3/1/2                  140                       13829384728123487362
# Display the number of interface-based ARP attack suppression entries for slot 1.
<Sysname> display arp attack-suppression per-interface slot 1 count
Total ARP attack suppression entries: 2
# Display the detailed information about interface-based ARP attack suppression entries for slot 1.
<Sysname> display arp attack-suppression per-interface interface slot 1 verbose
Suppression time: 200 seconds
Interface: GigabitEthernet3/1/2
Suppression time: 140 seconds
Attack time: 2018/06/04 14:53:34
Packets dropped: 13829384728123487362
Table 7 Command output
Interface in ARP attack suppression.
Remaining suppression time, in seconds.
Packets dropped
Total number of dropped packets.
Total number of interface-based ARP attack suppression entries.
Hardware status
Status of the interface-based ARP attack entry setting to hardware:
·         Succeeded.
·         Failed.
·         Not supported.
·         Not enough resources.
Suppression time
Remaining suppression time in seconds.
Attack time
Time when the interface-based ARP attack is detected. The time format is YYYY/MM/DD HH:MM:SS.
Use display arp attack-suppression per-interface interface to display interface-based ARP attack suppression entries on an interface.
display arp attack-suppression per-interface interface interface-type interface-number [ verbose ]
interface interface-type interface-number: Displays interface-based ARP attack suppression entries for the specified interface. The interface-type interface-number arguments specify an interface by its type and number.
verbose: Displays detailed information about interface-based ARP attack suppression entries. If you do not specify this keyword, the command displays brief information about ARP attack suppression entries.
# Display interface-based ARP attack suppression entries on GigabitEthernet 3/1/1.
<Sysname> display arp attack-suppression per-interface interface gigabitethernet 3/1/1
# Display detailed information about the interface-based ARP attack suppression entries on GigabitEthernet 3/1/1.
<Sysname> display arp attack-suppression per-interface interface gigabitethernet 3/1/1 verbose
Table 8 Command output
Packets dropped
Hardware status
·         Succeeded.
·         Failed.
·         Not supported.
Suppression time
Attack time
Use reset arp attack-suppression per-interface to delete interface-based ARP attack suppression entries.
In standalone mode:
reset arp attack-suppression per-interface [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
reset arp attack-suppression per-interface [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Deletes interface-based ARP attack suppression entries for the specified interface. The interface-type interface-number arguments specify an interface by its type and number.
If you do not specify any parameter, this command deletes all interface-based ARP attack suppression entries on the device.
# Delete all interface-based ARP attack suppression entries on the device.
<Sysname> reset arp attack-interface per-interface
Use reset arp attack-suppression per-interface statistics to clear statistics of packets dropped by interface-based ARP attack suppression.
In standalone mode:
reset arp attack-suppression per-interface statistics [ interface interface-type interface-number ] [ slot slot-number ]
In IRF mode:
reset arp attack-suppression per-interface statistics [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
interface interface-type interface-number: Clears statistics of packets dropped by interface-based ARP attack suppression on the specified interface. The interface-type interface-number arguments specify an interface by its type and number.
After you execute this command, the value for the Packets dropped field from the output of the display arp attack-suppression per-interface command will be cleared.
If you do not specify any parameter, this command clears all statistics of packets dropped by interface-based ARP attack suppression.
# Clear all statistics of packets dropped by interface-based ARP attack suppression.
<Sysname> reset arp attack-interface per-interface statistics
Use arp authorized enable to enable authorized ARP on an interface.
Use undo arp authorized enable to disable authorized ARP on an interface.
Authorized ARP is disabled on the interface.
Layer 3 Ethernet interface/subinterface view
Layer 3 aggregate interface/subinterface view
VSI interface view
VLAN interface view
# Enable authorized ARP on GigabitEthernet 3/1/1.
[Sysname] interface gigabitethernet 3/1/1
[Sysname-GigabitEthernet3/1/1] arp authorized enable
arp fixup
Use arp fixup to convert existing dynamic ARP entries to static ARP entries.
Use undo arp fixup to convert valid static ARP entries to dynamic ARP entries and delete invalid static ARP entries.
arp fixup
undo arp fixup
The ARP conversion is a one-time operation. You can use this command again to convert the dynamic ARP entries learned later to static.
The static ARP entries converted from dynamic ARP entries have the same attributes as the manually configured static ARP entries. Due to the device's limit on the total number of static ARP entries, some dynamic ARP entries might fail the conversion.
The static ARP entries after conversion can include the following entries:
·          Existing dynamic and static ARP entries before conversion.
·          New dynamic ARP entries learned during the conversion.
Dynamic ARP entries that are aged out during the conversion are not converted to static ARP entries.
To delete a static ARP entry changed from a dynamic one, use the undo arp ip-address [ vpn-instance-name ] command. To delete all such static ARP entries, use the reset arp all or reset arp static command.
# Convert existing dynamic ARP entries to static ARP entries.
[Sysname] arp fixup
arp scan
Use arp scan to trigger an ARP scanning in an address range.
arp scan [ start-ip-address to end-ip-address ]
VSI interface view
VLAN interface view
start-ip-address: Specifies the start IP address of the scanning range.
end-ip-address: Specifies the end IP address of the scanning range. The end IP address must be higher than or equal to the start IP address.
ARP scanning automatically creates ARP entries for devices in the specified address range. IP addresses already in existing ARP entries are not scanned.
If the interface's primary and secondary IP addresses are in the address range, the sender IP address in the ARP request is the address on the smallest network segment.
If no address range is specified, the device learns ARP entries for devices on the subnet where the primary IP address of the interface resides. The sender IP address in the ARP requests is the primary IP address of the interface.
The start and end IP addresses must be on the same subnet as the primary IP address or secondary IP addresses of the interface.
ARP scanning will take some time. To stop an ongoing scan, press Ctrl + C. Dynamic ARP entries are created based on ARP replies received before the scan is terminated.
# Configure the device to scan neighbors on the network where the primary IP address of GigabitEthernet 3/1/1 resides.
[Sysname-GigabitEthernet3/1/1] arp scan
# Configure the device to scan neighbors in an address range.
[Sysname-GigabitEthernet3/1/1] arp scan 1.1.1.1 to 1.1.1.20
arp filter source
Use arp filter source to enable ARP gateway protection for a gateway.
Use undo arp filter source to disable ARP gateway protection for a gateway.
arp filter source ip-address
undo arp filter source ip-address
ARP gateway protection is disabled.
ip-address: Specifies the IP address of a protected gateway.
You can enable ARP gateway protection for a maximum of eight gateways on an interface.
You cannot configure both the arp filter source and arp filter binding commands on the same interface.
# Enable ARP gateway protection for the gateway with IP address 1.1.1.1.
[Sysname-GigabitEthernet3/1/1] arp filter source 1.1.1.1
arp filter binding
Use arp filter binding to enable ARP filtering and configure an ARP permitted entry.
Use undo arp filter binding to remove an ARP permitted entry.
undo arp filter binding ip-address
ARP filtering is disabled.
ip-address: Specifies a permitted sender IP address.
mac-address: Specifies a permitted sender MAC address.
If the sender IP and MAC addresses of an ARP packet match an ARP permitted entry, the ARP packet is permitted. If the sender IP and MAC addresses of an ARP packet do not match an ARP permitted entry, the ARP packet is discarded.
You can configure a maximum of eight ARP permitted entries on an interface.
# Enable ARP filtering and configure an ARP permitted entry.
[Sysname-GigabitEthernet3/1/1] arp filter binding 1.1.1.1 0e10-0213-1023
arp sender-ip-range
Use arp sender-ip-range to enable the ARP sender IP address checking feature and specify the IP address range.
Use undo arp sender-ip-range to disable the ARP sender IP address checking feature.
arp sender-ip-range start-ip-address end-ip-address
The ARP sender IP address checking feature is disabled.
VLAN view
start-ip-address: Specifies the start IP address.
end-ip-address: Specifies the end IP address. The end IP address must be higher than or equal to the start IP address.
This feature enables a device to discard an ARP packet if its sender IP address is not within the specified IP address range.
# Enable the ARP sender IP address checking feature in VLAN 2 and specify the IP address range 1.1.1.1 to 1.1.1.20.
[Sysname] vlan 2
[Sysname–vlan2] arp sender-ip-range 1.1.1.1 1.1.1.20
