03-Interface Command Reference
HomeSupportRoutersCR16000-F SeriesReference GuidesCommand ReferencesH3C CR16000-F Routers Command References-Release795x-6W10003-Interface Command Reference
04-POS interface commands
04-POS interface commands 108.83 KB
alarm-detect
Use alarm-detect to configure the action to take when an RDI, SD, or SF alarm occurs on an interface.
Use undo alarm-detect to restore the default.
alarm-detect { rdi | sd | sf } action link-down
undo alarm-detect { rdi | sd | sf }
The device does not take any actions on the interface when an RDI, SD, or SF alarm occurs.
Standard POS interface view
rdi: Specifies remote defect indication (RDI) alarms.
sd: Specifies signal degrade (SD) alarms.
sf: Specifies signal fail (SF) alarms.
action: Specifies the action to take when the specified alarm is detected on the interface.
link-down: Places the interface in down state.
An RDI alarm occurs if the device receives multiplexer section remote defect indication (MS-RDI) signals from the remote end.
An SD or SF alarm occurs if the bit error rate of incoming packets crosses the SD or SF alarm threshold.
# Configure POS 2/2/1 to go down when an RDI alarm occurs.
[Sysname] interface pos 2/2/1
[Sysname-Pos2/2/1] alarm-detect rdi action link-down
bandwidth
Use bandwidth to configure the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
# Set the expected bandwidth to 50 kbps for POS 2/2/1.
[Sysname-Pos2/2/1] bandwidth 50
clock
Use clock to set the clock mode of a standard POS interface.
Use undo clock to restore the default.
clock { master | slave }
undo clock
The clock mode of a POS interface is slave.
master: Sets the clock mode to master.
slave: Sets the clock mode to slave.
Standard POS interfaces support the following clock modes:
·          Master—Uses internal clock signal.
·          Slave—Uses line clock signal.
If the standard POS interface is connected to another router, set its clock mode to be different from the mode used by the remote end. If the standard POS interface is connected to a SONET/SDH device, which provides higher clock precision, always set its clock mode to slave.
# Set the clock mode to master for POS 2/2/1.
[Sysname-Pos2/2/1] clock master
crc
Use crc to set the CRC length on an interface.
Use undo crc to restore the default.
crc { 16 | 32 }
undo crc
The CRC length on an interface is 32 bits.
16: Sets the CRC length to 16 bits.
32: Sets the CRC length to 32 bits.
The CRC length must be the same at both ends.
# Set the CRC length to 16 bits on POS 2/2/1.
[Sysname-Pos2/2/1] crc 16
dampening
Use dampening to enable the device to dampen an interface when it is flapping.
Use undo dampening to disable interface dampening.
undo dampening
Interface dampening is disabled on POS interfaces.
half-life: Specifies the amount of time (in seconds) for a penalty to decrease by half of its value. The value range is 1 to 120 seconds, and the default is 54 seconds.
reuse: Specifies the reuse threshold. The value range is 200 to 20000, and the default is 750. The reuse threshold must be lower than the suppression threshold.
suppress: Specifies the suppression threshold. The value range is 200 to 20000, and the default is 2000.
max-suppress-time: Specifies the maximum amount of time an interface can be dampened. The value range is 1 to 255 seconds, and the default is 162 seconds (three times the default half-life timer).
This command and the link-delay command cannot be both configured on an interface.
This command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the higher layer protocols.
For more information about the interface dampening feature, see Interface Configuration Guide.
# Configure interface dampening on POS2/2/1.
[Sysname-Pos2/2/1] dampening 2 800 3000 5
display interface pos
link-delay
default
Use default to restore the default settings for an interface.
default
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. You can use the display this command in interface view to check for these commands, and use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
# Restore the default settings of POS 2/2/1.
[Sysname-Pos2/2/1] default
description
The interface description uses the interface-name Interface format, for example, Pos2/2/1 Interface.
text: Specifies the description, a case-sensitive string of 1 to 255 characters.
# Configure the description of POS 2/2/1 as pos-interface.
[Sysname-Pos2/2/1] description pos-interface
Use display interface pos to display information about POS interfaces.
display interface [ pos [ interface-number ] ] [ brief [ description | down ] ]
pos [ interface-number ]: Specifies a standard POS interface by its number. If you do not specify the pos keyword, this command displays information about all interfaces. If you specify the pos keyword without specifying an interface, this command displays information about all POS interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays physically down interfaces and their down causes. If you do not specify this keyword, the command displays information about interfaces in any state.
# Display detailed information about POS 2/2/1.
<Sysname> display interface pos 2/2/1
Pos2/2/1
Current state: DOWN
Line protocol state: DOWN
Description: pos-interface
Bandwidth: 155520 kbps
Hold timer: 10 seconds, retry times: 5
Dampening enabled:
 Penalty: 0 (not suppressed)
 Ceiling: 6000
 Reuse: 750
 Suppress: 2000
 Half-life: 54 seconds
 Max-suppress-time: 162 seconds
 Flap count: 0
Link layer protocol: PPP
LCP: initial
Port priority: 0
Last link flapping: Never
Current system time:2017-12-15 17:18:19
Last time when physical state changed to up:-
Last time when physical state changed to down:2017-12-11 09:57:36
Port connector type is No connector
Physical layer is packet over SDH
Port speed type: STM-1
Loopback is not set
FCS: 32-bit CRC
Clock source: Slave
Clock grade: Quality unknown(existing synchronization network)
SPE scrambling: Enable
BER thresholds:
    SD: 10e-6    SF: 10e-4
Regenerator section layer:
    J0(TX): "CR16000"
            43 52 31 36 30 30 30 00 00 00 00 00 00 00 00 00
    J0(RX): ""
            00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    Alarm: LOS
    Error: 0 BIP(B1)
Multiplex section layer:
    Alarm: None
    Error: 0 BIP(B2), 0 REI(M1)
Higher order path layer:
    C2(TX): 0x16    C2(RX): 0xef
    J1(TX): "CR16000"
    J1(RX): ""
    Alarm: None
    Error: 0 BIP(B3), 0 REI(G1)
           0 PJE, 0 NJE
Port statistic:start time: 2017-12-11 09:57:46
UP time: 0 H 0 M 0 S
Section: ES        0   SES        0   SEFS        0
Line   : ES        0   SES        0   UAS         0   FE-ES        0
Input speed in last 300 seconds: 0 packets/s, 0 bytes/s
Output speed in last 300 seconds: 0 packets/s, 0 bytes/s
Input: 0 packets,  0 bytes(good), 0 bytes(all)
        0 FCS errors,  0 Aborts,  0 FIFO overflow
        0 Runts,  0 Giants
Output: 0 packets,  0 bytes(good), 0 bytes(all)
        0 FIFO underflow,  0 Aborts,  0 Runts
Peak value of input: 0 bytes/sec, at 2017-12-15 00:01:34
Peak value of output: 0 bytes/sec, at 2017-12-15 00:01:34
# Display brief information about POS 2/2/1.
<Sysname> display interface pos 2/2/1 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP      Description
Pos2/2/1             DOWN DOWN     --
# Display brief information about all standard POS interfaces in a down state and the causes.
<Sysname> display interface pos brief down
Pos2/2/1             ADM  Administratively
Current state
Physical link state of the interface:
·         Administratively DOWN—The interface has been shut down by using the shutdown command.
·         DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·         UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer.
·         UP—The data link layer protocol is up.
·         DOWN—The data link layer protocol is down.
Description of the interface.
Bandwidth
Expected bandwidth of the interface.
MTU of the interface.
Holder timer
Interval at which the data link layer protocol sends keepalives.
Dampening enabled:
 Ceiling: 6000
 Reuse: 750
 Suppress: 2000
 Flap count: 0
Interface dampening information:
·         Dampening enabled—The dampening feature is enabled.
·         Penalty—Penalty value. The interface suppression state is displayed in parentheses.
¡  Not suppressed—The interface is not dampened. Interface state changes are reported to higher layer protocols.
¡  Suppressed—The interface is dampened. Interface state changes are not reported to higher layer protocols.
·         Ceiling—Maximum penalty value.
·         Reuse—Reuse threshold.
·         Suppress—Suppression threshold.
·         Half-life—Half-life timer.
·         Max-suppress-time—Maximum suppression time.
·         Flap count—Number of times that the interface has flapped.
These fields are not displayed if dampening is disabled on the interface.
retry times
Keepalive retry limit.
The interface determines that the remote end is down if it does not receive a keepalive response after the keepalive retry limit has been made.
The interface is not assigned an IP address and cannot process IP packets.
Internet Address
IP address of the interface. The primary attribute indicates that the address is the primary IP address.
Link layer protocol
Data link layer protocol of the interface.
LCP
LCP negotiation.
IPCP
IPCP negotiation.
Last link flapping
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup.
The most recent time that the reset counters interface pos command was executed. This field displays Never if the command has not been executed on the interface since device startup.
Current system time
Current system time in the YYYY-MM-DD HH:MM:SS format. If the time zone is configured, this field is in the YYYY-MM-DD HH:MM:SS UTC±HH:MM:SS format.
Last time when physical state of the interface changed to up.
A hyphen (-) indicates that the physical state of the interface has not changed to up.
Last time when physical state of the interface changed to down.
A hyphen (-) indicates that the physical state of the interface has not changed to down.
Port connector type
Type of the transceiver module on the interface.
Physical layer
Physical interface.
Loopback
Loopback state.
SONET alarm
SONET alarms.
FCS
FCS type.
Clock source
Clock mode.
SPE scrambling
Scrambling state of the interface.
BER thresholds
SD threshold and SF threshold of the CPOS interface.
section layer
Alarm and error statistics for the multiplex section.
J0(TX)
Transmitted J0 trace message value.
J0(RX)
Received J0 trace message value.
Alarm
Alarm statistics.
Error
Error statistics.
Alarm and error statistics for the higher order path.
C2(TX)
Transmitted C2 bytes.
C2(RX)
Received C2 bytes.
J1(TX)
Transmitted J1 trace message value.
J1(RX)
Received J1 trace message value.
Starting time for interface statistics.
UP time
Time when the interface was brought up.
Section
Alarm seconds for the regenerator section:
·         Error Seconds (ES)—Minor error alarm seconds.
·         Serious Error Seconds (SES)—Sever error alarm seconds.
·         Serious Error Frame Seconds (SEFS)—Sever frame error alarm seconds.
Line
Alarm seconds for the multiplex section:
·         Unavailable Seconds (UAS)—Unavailable alarm seconds. This field value starts to count after 10 seconds of continuous SES.
·         FE-ES—Alarm seconds for remote errors. This field value starts to count when the peer end sends an REI RDI alarm.
Path1
Alarm seconds for the higher order path (displayed only when the alarm statistics are not 0).
Input packet rates and input byte rates for the last 300 seconds.
Output packet rates and output byte rates for the last 300 seconds.
        0 Runts,  0 aborts, 0 Giants
Inbound traffic statistics for the POS interface:
·         packets—Number of inbound packets.
·         bytes(good)—Number of inbound good bytes.
·         bytes(all)—Total number of inbound bytes.
·         FCS errors—Number of FCS errors.
·         aborts—Number of invalid inbound frames.
·         FIFO overflow—Number of packets that overflow.
·         Runts—Number of inbound packets shorter than the minimum frame length.
·         Giants—Number of inbound packets larger than the maximum frame length.
Outbound traffic statistics for the POS interface:
·         packets—Number of outbound packets.
·         bytes(good)—Number of outbound good bytes.
·         bytes(all)—Total number of outbound bytes.
·         Runts—Number of outbound packets shorter than the minimum frame length.
·         Giants—Number of outbound packets larger than the maximum frame length.
Peak value of input
Peak value of input packets and time when the peak rate occurred.
Peak value of output packets and time when the peak rate occurred.
Brief information about Layer 3 interfaces.
Abbreviated interface name.
Link
·         UP—The interface is physically up.
·         DOWN—The interface is physically down.
·         ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·         Stby—The interface is a backup interface in standby state.
Protocol
Data link layer protocol state of the interface:
·         UP—The data link layer protocol of the interface is up.
·         DOWN—The data link layer protocol of the interface is down.
·         UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s)attribute represents the spoofing flag.
Primary IP
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address.
Cause
Cause for the physical link state of an interface to be DOWN:
·         Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·         Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty).
flag c2
Use flag c2 to set the C2 path signal label byte.
Use undo flag c2 to restore the default.
flag c2 flag-value
undo flag c2
The C2 value is 16 in hexadecimal notation.
flag-value: Specifies a C2 byte value, a hexadecimal number in the range of 0 to ff.
The C2 byte is a higher-order path overhead byte. It indicates the multiplex structure of virtual container (VC) frames and the property of payload.
When the C2 byte of one end is set to 1, the C2 byte of the other end can be set to any character in hexadecimal notation. If the C2 byte of either ends of a link is not set to 1, the C2 byte must be the same at both ends.
# Set the C2 byte to 01 in hexadecimal notation on POS 2/2/1.
[Sysname-Pos2/2/1] flag c2 01
flag j0
Use flag j0 to set the J0 regenerator section trace byte for SONET or SDH frames.
Use undo flag j0 to restore the default.
flag j0 { sdh | sonet } flag-value
undo flag j0 {sdh | sonet }
The device uses the SDH framing format. In SDH frames, the J0 byte value is CR16000.
flag-value: Specifies the J0 byte. It must be a string of 1 to 15 characters for SDH, and a hexadecimal number in the range of 0 to ff for SONET.
sdh: Specifies the SDH framing format.
sonet: Specifies the SONET framing format.
J0 byte is a section overhead byte. SDH and SONET use this byte to test continuity of the connection between two interfaces at the section level.
The J0 byte can be different on devices of the same service provider. On the interfaces between two service providers, the J0 byte must be the same.
# Set the J0 byte to ff in hexadecimal notation for SDH on POS2/2/1.
[Sysname-Pos2/2/1] flag j0 sdh ff
frame-format
flag j1
Use flag j1 to set the J1 path trace byte for SONET or SDH frames.
Use undo flag j1 to restore the default.
flag j1 { sdh | sonet } flag-value
undo flag j1 {sdh | sonet }
The device uses the SDH framing format. In SDH frames, the J1 byte value is CR16000.
flag-value: Specifies a J1 byte value. It must be a string of 1 to 15 characters for SDH and a string of 1 to 62 characters for SONET.
J1 byte is a higher-order path overhead byte. SDH and SONET use this byte to test continuity of the connection between two interfaces at the path level.
The J1 byte must be the same at both ends of a link.
# Set the J1 byte to aabbcc for SDH on POS2/2/1.
[Sysname-Pos2/2/1] flag j1 sdh aabbcc
frame-format
flow-interval
Use flow-interval to set the statistics polling interval for an interface.
Use undo flow-interval to restore the default.
flow-interval interval
undo flow-interval
The statistics polling interval is 300 seconds.
interval: Specifies the statistics polling interval in the range of 5 to 300 and in steps of 5, in seconds.
You can use this command in system view or interface view.
·          In system view, the command takes effect on all interfaces.
·          In interface view, the command takes effect only on the specified interface.
When the statistics polling interval uses the default setting in interface view, the setting in system view takes effect. When the command is configured in both system view and interface view, the setting in interface view takes priority.
# Set the statistics polling interval to 180 seconds.
[Sysname] flow-interval 180
frame-format
Use frame-format to set the framing format on a standard POS interface.
Use undo frame-format to restore the default.
frame-format { sdh | sonet }
undo frame-format
The framing format is SDH on a standard POS interface.
# Set the framing format to SONET on POS 2/2/1.
[Sysname-Pos2/2/1] frame-format sonet
flag j0
flag j1
interface pos
Use interface pos to enter the view of an existing standard POS interface.
interface pos interface-number
interface-number: Specifies a standard POS interface by its number.
# Enter the view of POS 2/2/1.
[Sysname-Pos2/2/1]
link-protocol
link-delay
Use link-delay to set the physical state change suppression interval on an interface.
Use undo link-delay to restore the default.
link-delay msec milliseconds
undo link-delay
The physical state change suppression interval is 1 second.
msec milliseconds: Sets the physical state change suppression interval on an interface, in the range of 0 to 10000 milliseconds.
When the physical state changes, a POS interface reports the event to the upper-layer modules, and generates log and SNMP notification messages. To reduce system overhead caused by frequent physical state changes, use this command to suppress physical state changes within an interval. The interface will ignore any changes that occur during each suppression interval. When the suppression interval expires, the interface will not report the change event or generate messages if the change is removed.
For example, the suppression interval starts when the interface changes from up to down. The interface reports the change event and generates messages if it is still down when the interval expires. The interface does not report the change event or generate messages if it is up when the interval expires.
This command and the dampening command cannot both be configured on an interface.
# Set the physical state change suppression interval to 100 milliseconds for POS 2/2/1.
[Sysname-Pos2/2/1] link-delay msec 100
dampening
link-protocol
Use link-protocol to set the data link layer protocol of an interface.
link-protocol { hdlc | ppp }
PPP is used.
hdlc: Specifies HDLC as the data link layer protocol of the interface.
ppp: Specifies PPP as the data link layer protocol of the interface.
# Specify HDLC as the data link protocol of POS 2/2/1.
[Sysname-Pos2/2/1] link-protocol hdlc
loopback
Use loopback to enable loopback for standard POS interface.
Use undo loopback to disable loopback for a standard POS interface.
loopback { local | remote }
undo loopback
Loopback is disabled on a standard POS interface.
local: Enables internal loopback.
remote: Enables external loopback.
Loopback is intended for testing only. Disable the feature when the interface is operating correctly.
Before you use this command on a standard POS interface, make sure its clock mode is master.
When you enable internal loopback on a standard POS interface before you connect it to the peer end, the state of the data link layer protocol is reported as up.
# Enable internal loopback on POS 2/2/1.
[Sysname-Pos2/2/1] loopback local
clock
mtu
Use mtu to set the MTU size for an interface.
mtu size
undo mtu
The MTU of a POS interface is 1500 bytes.
size: Sets the maximum transmission unit (MTU) in bytes. The value range for this argument varies by card model.
·          For MIC subcard interfaces on the CSPEX-1204 or CSPEX-1104-E card, the value range for this argument is 46 to 4980.
·          For PIC-PSP4L subcard interfaces on the CSPEX-1204 card, the value range for this argument is 46 to 7600.
·          For PIC-PS2G4L and PIC-TCP8L subcard interfaces on the CSPEX-1204 card, the value range for this argument is 46 to 2000.
The MTU setting affects the assembly and fragmentation of IP packets.
After configuring the MTU for an interface, you must use the shutdown command and then the undo shutdown command on the interface for the modification to take effect.
Follow these guidelines when you set the MTU for an interface:
·          IP packets received by an incoming interface cannot be fragmented based on the MTU set for the outgoing interface when the incoming interface is on one of the following cards:
¡  CSPC (except CSPC-GE16XP4L-E, CSPC-GE24L-E, and CSPC-GP24GE8XP2L-E).
¡  CMPE-1104.
·          IP packets are fragmented to each fragment of 1280 bytes when the following conditions are met:
¡  An interface on a CSPC-GE16XP4L-E, CSPC-GE24L-E, CSPC-GP24GE8XP2L-E, CSPEX, or CEPC card acts as the incoming interface.
¡  The configured MTU value for the outgoing interface is less than 1280.
If the device is installed with the above cards, as a best practice, set the outgoing interface MTU to a value greater than 1280.
# Set the MTU to 1430 bytes for POS 2/2/1.
[Sysname-Pos2/2/1] mtu 1430
port-type switch
Use port-type switch to change the type of an interface.
In standard POS interface view:
port-type switch gigabitethernet
In Layer 3 GigabitEthernet interface view:
port-type switch pos
2: System level
gigabitethernet: Change a standard POS interface to a Layer 3 GigabitEthernet interface.
pos: Change a Layer 3 GigabitEthernet interface to a standard POS interface.
This command is supported only on the PIC-TCP8L subcard.
When you execute this command, the device performs the following operations:
1.        Removes the original interface.
2.        Creates a new-type interface with the same number as the original interface.
3.        Enters the interface view of the new-type interface.
# Change POS 2/2/1 to GigabitEthernet 2/2/1.
[Sysname-Pos2/2/1] port-type switch gigabitethernet
Changing port type can result in loss of port configuration. Are you sure to continue? [Y/N]:y
[Sysname-GigabitEthernet2/2/1]
Use reset counters interface pos to clear interface statistics.
reset counters interface [ pos [ interface-number ] ]
pos [ interface-number| interface-number.subnumber]: Clears statistics for a standard POS interface specified by its number. If you do not specify the pos keyword, this command clears statistics for all interfaces. If you specify the pos keyword without specifying an interface, this command clears statistics for all standard POS interfaces.
Use this command to clear history statistics before you collect statistics for a time period.
# Clear statistics for POS 2/2/1.
<Sysname> reset counters interface pos 2/2/1
scramble
Use scramble to enable payload scrambling on an interface.
Use undo scramble to disable payload scrambling on an interface.
scramble
undo scramble
Payload scrambling is enabled on standard POS interfaces.
Payload scrambling enables an interface to scramble outgoing data and descramble incoming data. By preventing the presence of long strings of all 1s or all 0s, payload scrambling enables the receiving end to extract the line clock signal correctly.
If payload scrambling is disabled, the interface does not scramble outgoing data or descramble incoming data.
The payload scrambling setting must be the same at both ends of a link to ensure correct communication.
For H3C devices, changing the payload scrambling setting does not affect cell headers. After you change the payload scrambling settings on both ends of a link, verify that the C2 byte value on them match each other. If the two values do not match, use the flag c2 command to modify the C2 byte value on the H3C device.
# Enable payload scrambling on POS 2/2/1.
[Sysname-Pos2/2/1] scramble
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to bring up an interface.
shutdown
An interface is up.
# Shut down POS 2/2/1.
[Sysname-Pos2/2/1] shutdown
speed
Use speed to set the rate of a standard POS interface.
Use undo speed to restore the default.
speed speed-value
undo speed
The rate of a standard POS interface is 155 Mbps.
speed-value: Specifies the rate in Mbps.
This command is supported only on the PIC-TCP8L subcard interfaces.
# Set the rate to 155 Mbps for POS 2/2/1.
<Sysname>system-view
[Sysname-Pos2/2/1] speed 155
timer-hold
Use timer-hold to set the keepalive interval.
Use undo timer-hold to restore the default.
timer-hold seconds
undo timer-hold
The keepalive interval is 10 seconds.
seconds: Specifies the interval at which the interface sends keepalive packets. The value range for this argument is 0 to 32767 seconds.
On an interface encapsulated with PPP or HDLC, the data link layer sends keepalive packets at keepalive intervals to detect the availability of the remote end. The data link layer determines that the peer end is down if it does not receive a response after the keepalive retry limit has been made. The data link layer then reports the link down event to the upper-layer protocols.
To set the keepalive retry limit, use the timer-hold retry command.
On a slow link, increase the keepalive interval to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive interval to 15 seconds for POS 2/2/1.
[Sysname-Pos2/2/1] timer-hold 15
timer-hold retry
timer-hold retry
Use timer-hold retry to set the keepalive retry limit.
Use undo timer-hold retry to restore the default.
timer-hold retry retries
The keepalive retry limit is 5.
retries: Specifies the keepalive retry limit, in the range of 1 to 255.
This command applies to interfaces encapsulated with PPP or HDLC. To set the keepalive interval, use the timer-hold command.
On a slow link, increase the keepalive retry limit to prevent false shutdown of the interface. This situation might occur when keepalive packets are delayed because a large packet is being transmitted on the link.
# Set the keepalive retry limit to 10 for POS2/2/1.
[Sysname-Pos2/2/1] timer-hold retry 10
timer-hold
