H3C UniServer R4700 G3 Server User Guide-6W101
HomeSupportServerH3C UniServer R4700 G3Install & UpgradeInstallation GuidesH3C UniServer R4700 G3 Server User Guide-6W101
02-Appendix
02-Appendix 1.65 MB
Appendix A  Server specifications· 1
Server models and chassis view·· 1
Technical specifications· 1
Components· 3
Front panel 4
Front panel view·· 4
LEDs and buttons· 5
Ports· 7
Rear panel 7
Rear panel view·· 7
LEDs· 8
Ports· 9
System board· 10
System board components· 10
System maintenance switches· 11
DIMM slots· 11
Appendix B  Component specifications· 13
About component model names· 13
Processors· 13
Intel processors· 13
Jintide-C series processors· 15
DIMMs· 15
DRAM specifications· 15
DCPMM specifications· 16
DRAM DIMM rank classification label 16
HDDs and SSDs· 17
Drive specifications· 17
Drive configurations and numbering· 26
Drive LEDs· 28
PCIe modules· 29
Storage controllers· 30
NVMe SSD expander modules· 39
GPU modules· 39
PCIe Ethernet adapters· 41
FC HBAs· 43
mLOM Ethernet adapters· 44
Riser cards· 44
PCIe slots· 44
Riser card specifications· 44
Fans· 45
Fan layout 45
Fan specifications· 45
Power supplies· 45
Expander modules and transfer modules· 49
Diagnostic panels· 50
Diagnostic panel specifications· 50
Diagnostic panel view·· 50
LEDs· 51
Fiber transceiver modules· 53
Storage options other than HDD and SSD drives· 53
NVMe VROC modules· 53
TPM/TCM modules· 53
Security bezels, slide rail kits, and cable management brackets· 54
Appendix C  Managed hot removal of NVMe drives· 55
Performing a managed hot removal in Windows· 55
Prerequisites· 55
Procedure· 55
Performing a managed hot removal in Linux· 56
Prerequisites· 56
Performing a managed hot removal from the CLI 56
Appendix D  Environment requirements· 60
Guidelines· 60
General environment requirements· 60
Operating temperature requirements· 60
Guidelines· 60
4LFF server with any drive configuration· 60
8SFF server with an 8SFF drive configuration· 62
8SFF server with a 10SFF drive configuration· 63
10SFF server with any drive configuration· 64
Appendix E  Product recycling· 66
Appendix F  Glossary· 67
Appendix G  Acronyms· 69
The information in this document might differ from your product if it contains custom configuration options or features.
H3C UniServer R4700 G3 server is a 1U rack server with two Intel Purley or Jintide-C series processors. It is suitable for cloud computing, IDC, and enterprise networks built based on new-generation infrastructure.
Figure 1 Chassis view
The server comes in the models described in Table 1. These models offer different drive configurations. For information about the compatible drive and storage controller configurations, see "Drive configurations and numbering."
Table 1 R4700 G3 server models
Model
Maximum drive configuration
4LFF
4 front LFF SAS/SATA drives and 2 rear SFF SAS/SATA drives
8SFF
·         8 front SFF NVMe drives and 2 front SFF SAS/SATA drives
·         8 front SFF SAS/SATA drives and 2 front SFF SAS/SATA drives
·         8 front SFF SAS/SATA drives and 2 front SFF NVMe drives
·         4 front SFF SAS/SATA drives and 4 front SFF NVMe drives
10SFF
10 front SFF SAS/SATA drives and 2 rear SFF SAS/SATA drives
Item
4LFF
8SFF
10SFF
Dimensions (H × W × D)
·         Without a security bezel: 42.9 × 434.6 × 780 mm (1.69 × 17.11 ×30.71 in)
·         With a security bezel: 42.9 × 434.6 × 803 mm (1.69 × 17.11 × 31.61 in)
Max. weight
19.35 kg (42.66 lb)
19.70 kg (43.43 lb)
21.20 kg (46.74 lb)
Processors
2 × Intel Purley or Jintide-C series processors
(Up to 3.6 GHz base frequency, maximum 205 W power consumption, and 38.5 MB cache per processor)
Memory
24 × DDR4 DIMMs
Chipset
Intel C622 Lewisburg chipset
Network connection
·         1 × onboard 1 Gbps HDM dedicated network port
·         1 × mLOM Ethernet adapter connector
I/O connectors
·         9 SATA connectors in total:
¡  1 × onboard mini-SAS connector (x8 SATA connectors)
¡  1 × onboard x1 SATA connector
·         6 × USB connectors:
¡  4 × USB 3.0 connectors (two at the server rear and two on the system board)
¡  2 × USB 2.0 connectors (available only if a front media module is installed)
·         2 × VGA connectors (one at the server rear and one available only if a front media module is installed)
·         1 × BIOS serial port at the server rear
Expansion slots
4 × PCIe3.0 connectors, including two standard connectors, one mezzanine storage controller connector, and one Ethernet adapter connector
Optical drives
·         External USB optical drives
·         Built-in SATA optical drive
Power supplies
1+1 hot-swappable power supply redundancy
Options:
·         550 W Platinum
·         550 W high-efficiency Platinum
·         800 W Platinum
·         800 W –48 VDC
·         800 W 336V high-voltage DC
·         850 W high-efficiency Platinum
·         850 W Titanium
·         1200 W Platinum
For more information, see "Power supplies."
Standards
CCC
CECP
SEPA
Components
Figure 2 R4700 G3 server components
Table 2 R4700 G3 server components
Item
(1) Access panel
N/A
(2) Chassis-open alarm module
Generates a chassis open alarm every time the access panel is removed. The alarms can be displayed from the HDM Web interface.
(3) NVMe VROC module
Works with VMD to provide RAID capability for the server to virtualize NVMe drives.
(4) Chassis air baffle
Provides ventilation aisles for the chassis. The server also provides power supply air baffles for ventilation of the power supplies.
(5) Storage controller
Provides RAID capability for the server to virtualize storage resources of SAS/SATA drives. It supports RAID configuration, RAID capability expansion, online upgrade, and remote configuration.
(6) Dual SD card expansion module
Provides SD card slots.
(7) Riser card
Installed on the system board to provide an additional slot for PCIe modules.
(8) System battery
Supplies power to the system clock.
(9) Drive cage
Encloses SAS and SATA drives.
(10) Power supply
Supplies power to the server. It supports hot swapping and 1+1 redundancy.
(11) Riser card blank
Installed on an empty riser card connector to ensure good ventilation.
(12) mLOM Ethernet adapter
Installed on the mLOM Ethernet adapter connector of the system board for network expansion.
(13) Chassis ears
Attach the server to the rack.
(14) Front media module
Provides one VGA connector and two USB 2.0 connectors at the front of the server.
(15) Diagnostic panel
Displays information about faulty components for quick diagnosis.
(16) M.2 transfer module
Expands the server with a maximum of two SATA M.2 SSDs.
(17) SATA M.2 SSD card
Provides storage media for the server.
(18) Drive
Drive for data storage, which is hot swappable.
(19) Drive expander module
Provides connection between drives and a storage controller to expand the number of drives controlled by the storage controller. If no drive expander module is installed, a storage controller can manage a maximum of eight drives.
(20) Drive backplane
Provides power and data channels for drives.
(21) Fan blank
Installed in an empty fan bay to ensure good ventilation.
(22) Fan
Supports hot swapping and N+1 redundancy.
(23) Supercapacitor holder
Secures a supercapacitor in the chassis.
(24) Supercapacitor
Supplies power to the flash card of the power fail safeguard module, which enables the storage controller to write data to the flash card for protection when power outage occurs.
(25) Memory
Stores computing data and data exchanged with external storage.
(26) System board
The main printed circuit board that accommodates and interconnects various server components, including the processors, memory, BIOS chip, HDM chip, PCIe connectors, and fans.
(27) Processor
Integrates a control unit and a PCIe controller to provide data processing capabilities for the server.
(28) Processor retaining bracket
Attaches a processor to the heatsink.
(29) Processor heatsink
Cools the processor.
Front panel
Front panel view
Figure 3, Figure 4, and Figure 5 show the front panel views of 4LFF, 8SFF, and 10SFF servers, respectively.
Figure 3 4LFF front panel
(1) Serial label pull tab module
(2) Optical drives or SATA M.2 SSDs
(3) Optional front media module (one VGA connector + two USB 2.0 connectors)
(4) Optional drive or diagnostic panel
(5) LFF drives
Figure 4 8SFF front panel
(2) Optical drive, SATA M.2 SSDs, or 2SFF drives
(5) SFF drives
Figure 5 10SFF front panel
(2) Optional front media module (one VGA connector + two USB 2.0 connectors)
(3) Optional drive or diagnostic panel
(4) SFF drives
LEDs and buttons
Figure 6, Figure 7, and Figure 8 show front panel LEDs and buttons. Table 3 describes the status of the front panel LEDs.
Figure 6 Front panel LEDs and buttons (4LFF)
(1) UID button LED
(2) Health LED
(3) mLOM Ethernet adapter Ethernet port LED
(4) Power on/standby button and system power LED
Figure 7 Front panel LEDs and buttons (8SFF)
(1) UID button LED
(2) Health LED
Figure 8 Front panel LEDs and buttons (10SFF)
(1) UID button LED
(2) Health LED
Table 3 LEDs and buttons on the front panel
Button/LED
Status
UID button LED
·         Steady blue—UID LED is activated. The UID LED can be activated by using the following methods:
¡  Press the UID button LED.
¡  Activate the UID LED from HDM.
·         Flashing blue:
¡  1 Hz—The firmware is being upgraded or the system is being managed from HDM.
¡  4 Hz—HDM is restarting. To restart HDM, press the UID button LED for eight seconds.
·         Off—UID LED is not activated.
Health LED
·         Steady green—The system is operating correctly.
·         Flashing green (4 Hz)—HDM is initializing.
·         Flashing amber (0.5 Hz)—A predictive alarm has occurred.
·         Flashing amber (1 Hz)—A general alarm has occurred.
·         Flashing red (1 Hz)—A severe alarm has occurred.
If a system alarm is present, log in to HDM to obtain more information about the system running status.
·         Steady green—A link is present on the port.
·         Flashing green (1 Hz)—The port is receiving or sending data.
·         Off—No link is present on the port.
System power LED
·         Steady green—The system has started.
·         Flashing green (1 Hz)—The system is starting.
·         Steady amber—The system is in Standby state.
·         Off—No power is present. Possible reasons:
¡  No power source is connected.
¡  No power supplies are present.
¡  The installed power supplies are faulty.
¡  The system power cords are not connected correctly.
Ports
The server does not provide fixed ports on its front panel. However, you can install a front media module if VGA or USB connections are needed, as shown in Table 4. For detailed port locations, see "Front panel view."
Table 4 Optional ports on the front panel
Port
VGA connector
DB-15
Connects a display terminal, such as a monitor or KVM device.
USB connector
USB 2.0
Connects the following devices:
·         USB flash drive.
·         USB keyboard or mouse.
Rear panel
Rear panel view
Figure 9 shows the rear panel view.
Figure 9 Rear panel components
(1) PCIe slot 1 (processor 1)
(2) PCIe slot 2 (processor 2)
(3) Power supply 2
(4) Power supply 1
(5) BIOS serial port
(6) VGA connector
(7) USB 3.0 connectors
(8) HDM dedicated network port
(1 Gbps, RJ-45, default IP address 192.168.1.2/24)
(9) mLOM Ethernet adapter (optional)
LEDs
Figure 10 shows the rear panel LEDs. Table 5 describes the status of the rear panel LEDs.
Figure 10 Rear panel LEDs
(1) Link LED of the Ethernet port
(2) Activity LED of the Ethernet port
(3) UID LED
(4) Power supply 1 LED
(5) Power supply 2 LED
Table 5 LEDs on the rear panel
LED
Status
·         Off—The port is not receiving or sending data.
UID LED
¡  Enable UID LED from HDM.
·         Flashing blue:
¡  1 Hz—The firmware is being updated or the system is being managed by HDM.
Power supply LED
·         Steady green—The power supply is operating correctly.
·         Flashing green (1 Hz)—Power is being input correctly but the system is not powered on.
·         Flashing green (0.33 Hz)—The power supply is in standby state and does not output power.
·         Flashing green (2 Hz)—The power supply is updating its firmware.
·         Steady amber—Either of the following conditions exists:
¡  The power supply is faulty.
¡  The power supply does not have power input, but the other power supply has correct power input.
·         Flashing amber (1 Hz)—An alarm has occurred on the power supply.
·         Off—No power supplies have power input, which can be caused by an incorrect power cord connection or power source shutdown.
Ports
For detailed port locations, see "Rear panel view."
Table 6 Ports on the rear panel
Port
BIOS serial port
DB-9
The BIOS serial port is used for the following purposes:
·         Log in to the server when the remote network connection to the server has failed.
·         Establish a GSM modem or encryption lock connection.
VGA connector
DB-15
USB connector
USB 3.0
·         USB flash drive.
·         USB optical drive for operating system installation.
RJ-45
Establishes a network connection to manage HDM from its Web interface.
Power receptacle
Standard single-phase
Connects the power supply to the power source.
System board
Figure 11 System board components
(1) TPM/TCM connector
(2) Mezzanine storage controller connector
(3) System battery
(4) System maintenance switch 1
(5) System maintenance switch 2
(6) System maintenance switch 3
(7) PCIe riser connector 1 (processor 1)
(8) mLOM Ethernet adapter connector
(9) Ethernet adapter NCSI function connector
(10) Mini-SAS port (x8 SATA ports)
(11) Front I/O connector
(12) Optical/SATA port
(13) Air inlet temperature sensor connector
(14) Fan bay 7
(15) Fan bay 6
(16) Fan bay 5
(17) Fan bay 4
(18) Fan bay 3
(19) Fan bay 2
(20) Fan bay 1
(21) Dual internal USB 3.0 connectors
(22) Drive backplane AUX connector 2
(23) Chassis-open alarm module, front VGA, and USB 2.0 connector
(24) Drive backplane power connector 1 and SATA M.2 SSD power connector
(25) Drive backplane AUX connector 1
(26) Drive backplane power connector 2
(27) NVMe VROC module connector
(28) Dual SD card extended module connector
(29) PCIe riser connector 2 (processor 2)
Use the system maintenance switches if you forget HDM username, HDM password, or BIOS password, or need to restore the default BIOS settings, as described in Table 7. To identify the location of the switches on the system board, see Figure 11.
Table 7 System maintenance switches
Item
Remarks
·         Pins 1-2 jumped (default)—HDM login requires the username and password of a valid HDM user account.
·         Pins 2-3 jumped—HDM login requires the default username and password.
For security purposes, jump pins 1 and 2 after you complete tasks with the default username and password as a best practice.
·         Pins 1-2 jumped (default)—Normal server startup.
·         Pins 2-3 jumped—Clears all passwords from the BIOS at server startup.
To clear all passwords from the BIOS, jump pins 2 and 3 and then start the server. All the passwords will be cleared from the BIOS. Before the next server startup, jump pins 1 and 2 to perform a normal server startup.
·         Pins 2-3 jumped—Restores the default BIOS settings.
To restore the default BIOS settings, jump pins 2 and 3 for over 30 seconds, and then jump pins 1 and 2 for normal startup.
DIMM slots
The server provides 6 DIMM channels per processor, 12 channels in total. Each channel contains one white-coded slot and one black-coded slot, as shown in Table 8.
Table 8 DIMM slot numbering and color-coding scheme
Processor
DlMM slots
Processor 1
A1 through A6 (white coded)
A7 through A12 (black coded)
Processor 2
B1 through B6 (white coded)
B7 through B12 (black coded)
Figure 12 shows the physical layout of the DIMM slots on the system board. For more information about the DIMM slot population rules, see the guidelines in "Installing DIMMs."
Figure 12 DIMM physical layout
The model name of a hardware option in this document might differ slightly from its model name label.
A model name label might add a prefix or suffix to the hardware-coded model name for purposes such as identifying the matching server brand or applicable region. For example, the DDR4-2666-8G-1Rx8-R memory model represents memory module labels including UN-DDR4-2666-8G-1Rx8-R, UN-DDR4-2666-8G-1Rx8-R-F, and UN-DDR4-2666-8G-1Rx8-R-S, which have different suffixes.
Processors
Intel processors
Table 9 Skylake processors
Model
Base frequency
Power
Number of cores
Cache (L3)
UPI links
UPI speed
Supported max. data rate of DIMMs
8180
2.5 GHz
205 W
28
38.5 MB
3
10.4 GT/s
2666 MHz
8176
2.1 GHz
165 W
28
38.5 MB
3
10.4 GT/s
2666 MHz
8170
2.1 GHz
165 W
26
35.75 MB
3
10.4 GT/s
2666 MHz
8168
2.7 GHz
205 W
24
33 MB
3
10.4 GT/s
2666 MHz
8164
2.0 GHz
150 W
26
35.75 MB
3
10.4 GT/s
2666 MHz
8160
2.1 GHz
150 W
24
33 MB
3
10.4 GT/s
2666 MHz
8158
3.0 GHz
150 W
12
24.75 MB
3
10.4 GT/s
2666 MHz
8156
3.6 GHz
105 W
4
16.5 MB
3
10.4 GT/s
2666 MHz
8153
2.0 GHz
125 W
16
22 MB
3
10.4 GT/s
2666 MHz
6154
3.0 GHz
200 W
18
24.75 MB
3
10.4 GT/s
2666 MHz
6152
2.1 GHz
140 W
22
30.25 MB
3
10.4 GT/s
2666 MHz
6150
2.7 GHz
165 W
18
24.75 MB
3
10.4 GT/s
2666 MHz
6148
2.4 GHz
150 W
20
27.5 MB
3
10.4 GT/s
2666 MHz
6146
3.2 GHz
165 W
12
24.75 MB
3
10.4 GT/s
2666 MHz
6144
3.5 GHz
150 W
8
24.75
3
10.4 GT/s
2666 MHz
6142
2.6 GHz
150 W
16
22 MB
3
10.4 GT/s
2666 MHz
6140
2.3 GHz
140 W
18
24.75 MB
3
10.4 GT/s
2666 MHz
6138
2.0 GHz
125 W
20
28 MB
3
10.4 GT/s
2666 MHz
6136
3.0 GHz
150 W
12
24.75 MB
3
10.4 GT/s
2666 MHz
6134
3.2 GHz
130 W
8
24.75 MB
3
10.4 GT/s
2666 MHz
6133
2.5 GHz
150 W
20
27.5 MB
2
10.4 GT/s
2666 MHz
6132
2.6 GHz
140 W
14
19.25 MB
3
10.4 GT/s
2666 MHz
6130
2.1 GHz
125 W
16
22 MB
3
10.4 GT/s
2666 MHz
6128
3.4 GHz
115 W
6
19.25 MB
3
10.4 GT/s
2666 MHz
6126
2.6 GHz
125 W
12
19.25 MB
3
10.4 GT/s
2666 MHz
5122
3.6 GHz
105 W
4
16.5 MB
2
10.4 GT/s
2666 MHz
5120
2.2 GHz
105 W
14
19.25 MB
2
10.4 GT/s
2400 MHz
5118
2.3 GHz
105 W
12
16.5 MB
2
10.4 GT/s
2400 MHz
5117
2.0 GHz
105 W
14
19.25 MB
2
10.4 GT/s
2400 MHz
5115
2.4 GHz
85 W
10
13.75 MB
2
10.4 GT/s
2400 MHz
4116
2.1 GHz
85 W
12
16.5 MB
2
9.6 GT/s
2400 MHz
4114
2.2 GHz
85 W
10
13.75 MB
2
9.6 GT/s
2400 MHz
4112
2.6 GHz
85 W
4
8.25 MB
2
9.6 GT/s
2400 MHz
4110
2.1 GHz
85 W
8
11 MB
2
9.6 GT/s
2400 MHz
4108
1.8 GHz
85 W
8
11 MB
2
9.6 GT/s
2400 MHz
3106
1.7 GHz
85 W
8
11 MB
2
9.6 GT/s
2133 MHz
3104
1.7 GHz
85 W
6
8.25 MB
2
9.6 GT/s
2133 MHz
8160T
2.1 GHz
150 W
24
33 MB
3
10.4 GT/s
2666 MHz
6138T
2.0 GHz
125 W
20
27.5 MB
3
10.4 GT/s
2666 MHz
6130T
2.1 GHz
125 W
16
22 MB
3
10.4 GT/s
2666 MHz
6126T
2.6 GHz
125 W
12
19.25 MB
3
10.4 GT/s
2666 MHz
5120T
2.2 GHz
105 W
14
19.25 MB
2
10.4 GT/s
2400 MHz
5119T
1.9 GHz
85 W
14
19.25 MB
2
10.4 GT/s
2400 MHz
4116T
2.1 GHz
85 W
12
16.5 MB
2
9.6 GT/s
2400 MHz
4114T
2.1 GHz
85 W
10
13.75 MB
2
9.6 GT/s
2400 MHz
4109T
2.0 GHz
70 W
8
11 MB
2
9.6 GT/s
2400 MHz
8180M
2.5 GHz
205 W
28
38.5 MB
3
10.4 GT/s
2666 MHz
8176M
2.1 GHz
165 W
28
38.5 MB
3
10.4 GT/s
2666 MHz
8170M
2.1 GHz
165 W
26
35.75 MB
3
10.4 GT/s
2666 MHz
8160M
2.1 GHz
150 W
24
33 MB
3
10.4 GT/s
2666 MHz
6142M
2.6 GHz
150 W
16
22 MB
3
10.4 GT/s
2666 MHz
6140M
2.3 GHz
140 W
18
24.75 MB
3
10.4 GT/s
2666 MHz
6134M
3.2 GHz
130 W
8
24.75 MB
3
10.4 GT/s
2666 MHz
Table 10 Cascade Lake processors
Model
Base frequency
Power
Number of cores
Cache (L3)
UPI links
UPI speed
8276
2.2 GHz
165 W
28
38.5 MB
3
10.4 GT/s
2933 MHz
8260
2.4 GHz
165 W
24
35.75 MB
3
10.4 GT/s
2933 MHz
6248
2.5 GHz
150 W
20
27.5 MB
3
10.4 GT/s
2933 MHz
6244
3.6 GHz
150 W
8
24.75 MB
3
10.4 GT/s
2933 MHz
6242
2.8 GHz
150 W
16
22 MB
3
10.4 GT/s
2933 MHz
6240
2.6 GHz
150 W
18
24.75 MB
3
10.4 GT/s
2933 MHz
6230
2.1 GHz
125 W
20
27.5 MB
3
10.4 GT/s
2933 MHz
5220
2.2 GHz
125 W
18
24.75 MB
2
10.4 GT/s
2666 MHz
5218
2.3 GHz
125 W
16
22 MB
2
10.4 GT/s
2666 MHz
6240Y
2.6 GHz
150 W
18
24.75 MB
3
10.4 GT/s
2933 MHz
Model
Base frequency
Power
Number of cores
Cache (L3)
UPI links
UPI speed
C2460
2.1 GHz
150 W
24
33 MB
3
10.4 GT/s
2666 MHz
C1640
2.1 GHz
125 W
16
22 MB
3
10.4 GT/s
2666 MHz
C1450
2.2 GHz
105 W
14
19.25 MB
2
10.4 GT/s
2400 MHz
C1230
2.3 GHz
105 W
12
16.5 MB
2
10.4 GT/s
2400 MHz
C1020
2.2 GHz
85 W
10
13.75 MB
2
9.6 GT/s
2400 MHz
C0810
2.1 GHz
85 W
8
11 MB
2
9.6 GT/s
2400 MHz
DIMMs
The server provides 6 DIMM channels per processor, 12 channels in total. Each DIMM channel has two DIMM slots and supports a maximum of eight ranks. For the physical layout of DIMM slots, see "DIMM slots."
DRAM specifications
Product code
Model
Capacity
Data rate
Rank
0231AADX
DDR4-16G-1Rx4-R-1
RDIMM
16 G
2400 MHz
Single-rank
0231AADY
DDR4-32G-2Rx4-R-1
RDIMM
32 G
2400 MHz
Dual-rank
0231A6SR
DDR4-2666-8G-1Rx8-R
RDIMM
8 GB
2666 MHz
Single-rank
0231A6SP
DDR4-2666-16G-1Rx4-R
RDIMM
16 GB
2666 MHz
Single-rank
0231A6SQ
DDR4-2666-16G-2Rx8-R
RDIMM
16 GB
2666 MHz
Dual-rank
0231AADP
DDR4-2666-16G-1Rx4-R-1
RDIMM
16 GB
2666 MHz
Single-rank
0231AAEF
DDR4-2666-16G-1Rx4-R-2
RDIMM
16 GB
2666 MHz
Single-rank
0231AAEG
DDR4-2666-16G-1Rx4-R-3
RDIMM
16 GB
2666 MHz
Single-rank
0231AAEH
DDR4-2666-16G-2Rx8-R-1
RDIMM
16 GB
2666 MHz
Dual-rank
0231AAE8
DDR4-2666-16G-2Rx8-R-2
RDIMM
16 GB
2666 MHz
Dual-rank
0231AAE0
DDR4-2666-16G-2Rx8-R-3
RDIMM
16 GB
2666 MHz
Dual-rank
0231A6SS
DDR4-2666-32G-2Rx4-R
RDIMM
32 GB
2666 MHz
Dual-rank
0231AAE9
DDR4-2666-32G-2Rx4-R-1
RDIMM
32 GB
2666 MHz
Dual-rank
0231AAEJ
DDR4-2666-32G-2Rx4-R-2
RDIMM
32 GB
2666 MHz
Dual-rank
0231AAEK
DDR4-2666-32G-2Rx4-R-3
RDIMM
32 GB
2666 MHz
Dual-rank
0231A8QJ
DDR4-2666-64G-4Rx4-L
LRDIMM
64 GB
2666 MHz
Quad-rank
0231AADQ
DDR4-2666-64G-4Rx4-L-1
LRDIMM
64 GB
2666 MHz
Quad-rank
0231AADT
DDR4-2666-64G-4Rx4-L-2
LRDIMM
64 GB
2666 MHz
Quad-rank
0231AADR
DDR4-2666-64G-4Rx4-L-3
LRDIMM
64 GB
2666 MHz
Quad-rank
0231AC4S
DDR4-2933P-16G-1Rx4-R
RDIMM
16 GB
2933 MHz
Single-rank
0231AC4V
DDR4-2933P-16G-2Rx8-R
RDIMM
16 GB
2933 MHz
Dual-rank
0231AC4T
DDR4-2933P-32G-2Rx4-R
RDIMM
32 GB
2933 MHz
Dual-rank
0231AC4N
DDR4-2933P-64G-2Rx4-R
RDIMM
64 GB
2933 MHz
Dual-rank
Product code
Model
Capacity
Data rate
0231AC5R
AP-128G-NMA1XBD128GQSE
Apache Pass
128 GB
2666 MHz
0231AC7P
AP-256G-NMA1XBD256GQSE
Apache Pass
256 GB
2666 MHz
0231AC65
AP-512G-NMA1XBD512GQSE
Apache Pass
512 GB
2666 MHz
A DIMM rank is a set of memory chips that the system accesses while writing or reading from the memory. On a multi-rank DIMM, only one rank is accessible at a time.
To determine the rank classification of a DRAM DIMM, use the label attached to the DIMM, as shown in Figure 13.
Figure 13 DRAM DIMM rank classification label
Table 11 DIMM rank classification label description
Callout
Remarks
1
Capacity
N/A
2
Number of ranks
N/A
3
Data width
·         ×4—4 bits.
·         ×8—8 bits.
4
DIMM generation
Only DDR4 is supported.
5
Data rate
·         2133P—2133 MHz.
·         2400T—2400 MHz.
·         2666V—2666 MHz.
·         2933Y—2933 MHz.
6
DIMM type
·         L—LRDIMM.
·         R—RDIMM.
HDDs and SSDs
SAS HDDs
Model
Form factor
Capacity
Rate
Rotating speed
HDD-300G-SAS-12G-10K-SFF-EP
SFF
300 GB
12 Gbps
10000 RPM
HDD-300G-SAS-12G-15K-SFF
SFF
300 GB
12 Gbps
15000 RPM
HDD-600G-SAS-12G-10K-SFF
SFF
600 GB
12 Gbps
10000 RPM
HDD-600G-SAS-12G-10K-SFF-1
SFF
600 GB
12 Gbps
10000 RPM
HDD-600G-SAS-12G-15K-SFF-1
SFF
600 GB
12 Gbps
15000 RPM
HDD-900G-SAS-12G-10K-SFF
SFF
900 GB
12 Gbps
10000 RPM
HDD-900G-SAS-12G-15K-SFF
SFF
900 GB
12 Gbps
15000 RPM
HDD-1.2T-SAS-12G-10K-SFF
SFF
1.2 TB
12 Gbps
10000 RPM
HDD-1.8T-SAS-12G-10K-SFF
SFF
1.8 TB
12 Gbps
10000 RPM
HDD-2.4T-SAS-12G-10K-SFF
SFF
2.4 TB
12 Gbps
10000 RPM
HDD-300G-SAS-12G-10K-LFF-EP
LFF
300 GB
12 Gbps
10000 RPM
HDD-300G-SAS-12G-15K-LFF-EP
LFF
300 GB
12 Gbps
15000 RPM
HDD-600G-SAS-12G-10K-LFF-1
LFF
600 GB
12 Gbps
10000 RPM
LFF
600 GB
12 Gbps
10000 RPM
HDD-600G-SAS-12G-15K-LFF-1
LFF
600 GB
12 Gbps
15000 RPM
HDD-900G-SAS-12G-15K-LFF
LFF
900 GB
12 Gbps
15000 RPM
HDD-2T-SAS-12G-7.2K-LFF
LFF
2.0 TB
12 Gbps
7200 RPM
HDD-2.4T-SAS-12G-10K-LFF
LFF
2.4 TB
12 Gbps
10000 RPM
HDD-4T-SAS-12G-7.2K-LFF
LFF
4.0 TB
12 Gbps
7200 RPM
HDD-6T-SAS-12G-7.2K-LFF
LFF
6.0 TB
12 Gbps
7200 RPM
HDD-8T-SAS-12G-7.2K-LFF
LFF
8.0 TB
12 Gbps
7200 RPM
HDD-10T-SAS-12G-7.2K-LFF
LFF
10.0 TB
12 Gbps
7200 RPM
HDD-12T-SAS-12G-7.2K-LFF
LFF
12.0 TB
12 Gbps
7200 RPM
SATA HDDs
Model
Form factor
Capacity
Rate
Rotating speed
HDD-1T-SATA-6G-7.2K-SFF-1
SFF
1.0 TB
6 Gbps
7200 RPM
HDD-2T-SATA-6G-7.2K-SFF
SFF
2.0 TB
6 Gbps
7200 RPM
HDD-1T-SATA-6G-7.2K-LFF
LFF
1.0 TB
6 Gbps
7200 RPM
HDD-1T-SATA-6G-7.2K-LFF-1
LFF
1.0 TB
6 Gbps
7200 RPM
HDD-2T-SATA-6G-7.2K-LFF
LFF
2.0 TB
6 Gbps
7200 RPM
HDD-2T-SATA-6G-7.2K-LFF-1
LFF
2.0 TB
6 Gbps
7200 RPM
HDD-2T-SATA-6G-7.2K-LFF-4
LFF
2.0 TB
6 Gbps
7200 RPM
HDD-4T-SATA-6G-7.2K-LFF
LFF
4.0 TB
6 Gbps
7200 RPM
HDD-4T-SATA-6G-7.2K-LFF-BS
LFF
4.0 TB
6 Gbps
7200 RPM
HDD-4T-SATA-6G-7.2K-LFF-BH
LFF
4.0 TB
6 Gbps
7200 RPM
HDD-4T-SATA-6G-7.2K-LFF-1
LFF
4.0 TB
6 Gbps
7200 RPM
HDD-4T-SATA-6G-7.2K-LFF-2
LFF
4.0 TB
6 Gbps
7200 RPM
HDD-4T-SATA-6G-7.2K-LFF-3
LFF
4.0 TB
6 Gbps
7200 RPM
HDD-6T-SATA-6G-7.2K-LFF
LFF
6.0 TB
6 Gbps
7200 RPM
HDD-6T-SATA-6G-7.2K-LFF-BS
LFF
6.0 TB
6 Gbps
7200 RPM
HDD-6T-SATA-6G-7.2K-LFF-BH
LFF
6.0 TB
6 Gbps
7200 RPM
HDD-8T-SATA-6G-7.2K-LFF
LFF
8.0 TB
6 Gbps
7200 RPM
HDD-8T-SATA-6G-7.2K-LFF-C
LFF
8.0 TB
6 Gbps
7200 RPM
HDD-8T-SATA-6G-7.2K-LFF-2
LFF
8.0 TB
6 Gbps
7200 RPM
HDD-8T-SATA-6G-7.2K-LFF-3
LFF
8.0 TB
6 Gbps
7200 RPM
HDD-8T-SATA-6G-7.2K-LFF-4
LFF
8.0 TB
6 Gbps
7200 RPM
HDD-10T-SATA-6G-7.2K-LFF
LFF
10.0 TB
6 Gbps
7200 RPM
HDD-10T-SATA-6G-7.2K-LFF-1
LFF
10.0 TB
6 Gbps
7200 RPM
HDD-12T-SATA-6G-7.2K-LFF
LFF
12.0 TB
6 Gbps
7200 RPM
HDD-12T-SATA-6G-7.2K-LFF-1
LFF
12.0 TB
6 Gbps
7200 RPM
HDD-12T-SATA-6G-7.2K-LFF-2
LFF
12.0 TB
6 Gbps
7200 RPM
HDD-14T-SATA-6G-7.2K-LFF
LFF
14.0 TB
6 Gbps
7200 RPM
SATA SSDs
Model
Vendor
Form factor
Capacity
Rate
SSD-150G-SATA-6G-SFF-EV
Intel
SFF
150 GB
6 Gbps
SSD-240G-SATA-6G-SFF-EM-i
Intel
SFF
240 GB
6 Gbps
SSD-240G-SATA-6G-SFF-1-EV-i
Intel
SFF
240 GB
6 Gbps
SSD-240G-SATA-6G-SFF-i
Intel
SFF
240 GB
6 Gbps
Samsung
SFF
240 GB
6 Gbps
SSD-240G-SATA-6G-SFF-3
Micron
SFF
240 GB
6 Gbps
SSD-240G-SATA-6G-SFF-S3
Micron
SFF
240 GB
6 Gbps
SSD-240G-SATA-6G-EM-SFF-i-2
Intel
SFF
240 GB
6 Gbps
SSD-240G-SATA-6G-EV-SFF-i-1
Intel
SFF
240 GB
6 Gbps
SSD-480G-SATA-6G-SFF-2
Micron
SFF
480 GB
6 Gbps
SSD-480G-SATA-6G-SFF-EM-i
Intel
SFF
480 GB
6 Gbps
SSD-480G-SATA-6G-EV-SFF-i-2
Intel
SFF
480 GB
6 Gbps
SSD-480G-SATA-6G-EM-SFF-i-3
Intel
SFF
480 GB
6 Gbps
SSD-480G-SATA-6G-SFF-EV
Intel
SFF
480 GB
6 Gbps
SSD-480G-SATA-6G-SFF-i
Intel
SFF
480 GB
6 Gbps
SSD-480G-SATA-6G-SFF-1
Micron
SFF
480 GB
6 Gbps
Micron
SFF
480 GB
6 Gbps
SSD-480G-SATA-6G-SFF-3
Samsung
SFF
480 GB
6 Gbps
SSD-480G-SATA-6G-SFF-4
Samsung
SFF
480 GB
6 Gbps
SSD-480G-SATA-6G-SFF-5
Micron
SFF
480 GB
6 Gbps
SSD-480G-SATA-6G-EV-SFF-sa
Samsung
SFF
480 GB
6 Gbps
SSD-480G-SATA-Ny1351-SFF-6
Seagate
SFF
480 GB
6 Gbps
SSD-480G-SATA-Ny1351-SCL
Seagate
SFF
480 GB
6 Gbps
SSD-800G-SATA-6G-SFF-i-2
Intel
SFF
800 GB
6 Gbps
SSD-800G-SATA-6G-SFF-1
TOSHIBA
SFF
800 GB
6 Gbps
SSD-960G-SATA-6G-SFF-EM-i
Intel
SFF
960 GB
6 Gbps
SSD-960G-SATA-6G-SFF-2
Micron
SFF
960 GB
6 Gbps
SSD-960G-SATA-6G-SFF-3
Samsung
SFF
960 GB
6 Gbps
SSD-960G-SATA-6G-EM-SFF-m
Micron
SFF
960 GB
6 Gbps
SSD-960G-SATA-6G-EV-SFF-i
Intel
SFF
960 GB
6 Gbps
SSD-960G-SATA-6G-EM-SFF-i-2
Intel
SFF
960 GB
6 Gbps
Micron
SFF
960 GB
6 Gbps
SSD-960G-SATA-6G-SFF-4
Micron
SFF
960 GB
6 Gbps
SSD-960G-SATA-6G-SFF-6
Samsung
SFF
960 GB
6 Gbps
SSD-960G-SATA-6G-SFF-i
Intel
SFF
960 GB
6 Gbps
SSD-960G-SATA-6G-SFF-1
Samsung/Micron
SFF
960 GB
6 Gbps
SSD-960G-SATA-Ny1351-SFF-7
Seagate
SFF
960 GB
6 Gbps
SSD-960G-SATA-Ny1351-SCL
Seagate
SFF
960 GB
6 Gbps
SSD-960G-SATA-6G-PM883-SFF
Samsung
SFF
960 GB
6 Gbps
SSD-960G-SATA-PM883-SFF
Samsung
SFF
960 GB
6 Gbps
SSD-1.2T-SATA-6G-SFF-i-1
Intel
SFF
1.2 TB
6 Gbps
SSD-1.6T-SATA-6G-SFF-i-1
Intel
SFF
1.6 TB
6 Gbps
SSD-1.92T-SATA-6G-SFF
Micron
SFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-EM-SFF-i-1
Intel
SFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-SFF-1
Samsung
SFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-SFF-2
Samsung
SFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-SFF-3
Micron
SFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-EM-SFF-m
Micron
SFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-EV-SFF-i
Intel
SFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-SFF-i
Intel
SFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-SFF-EM-i
Intel
SFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-PM883-SFF
Samsung
SFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-PM883-SFF
Samsung
SFF
1.92 TB
6 Gbps
SSD-3.84T-SATA-6G-EM-SFF-i
Intel
SFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-EV-SFF-i
Intel
SFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-SFF
Micron
SFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-SFF-1
Samsung
SFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-SFF-2
Micron
SFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-SFF-3
Samsung
SFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-SFF-i
Intel
SFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-PM883-SFF
Samsung
SFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-PM883-SFF
Samsung
SFF
3.84 TB
6 Gbps
SSD-150G-SATA-6G-LFF-i
Intel
LFF
150 GB
6 Gbps
SSD-240G-SATA-6G-LFF-1-EV-i
Intel
LFF
240 GB
6 Gbps
SSD-240G-SATA-6G-LFF-i-EM
Intel
LFF
240 GB
6 Gbps
SSD-240G-SATA-6G-LFF-EV
Intel
LFF
240 GB
6 Gbps
Samsung
LFF
240 GB
6 Gbps
SSD-240G-SATA-6G-LFF-3
Micron
LFF
240 GB
6 Gbps
SSD-240G-SATA-6G-EV-SCL-i
Intel
LFF
240 GB
6 Gbps
SSD-240G-SATA-6G-EM-SCL-i-1
Intel
LFF
240 GB
6 Gbps
SSD-480G-SATA-6G-LFF
Micron
LFF
480 GB
6 Gbps
SSD-480G-SATA-6G-LFF-2
Samsung
LFF
480 GB
6 Gbps
SSD-480G-SATA-6G-LFF-4
Micron
LFF
480 GB
6 Gbps
SSD-480G-SATA-6G-LFF-5
Samsung
LFF
480 GB
6 Gbps
SSD-480G-SATA-6G-EV-SCL-i-1
Intel
LFF
480 GB
6 Gbps
SSD-480G-SATA-6G-EM-SCL-i-2
Intel
LFF
480 GB
6 Gbps
SSD-480G-SATA-6G-LFF-i-EM
Intel
LFF
480 GB
6 Gbps
SSD-480G-SATA-6G-LFF-EV
Intel
LFF
480 GB
6 Gbps
SSD-480G-SATA-6G-EV-SCL-sa
Samsung
LFF
480 GB
6 Gbps
Intel
LFF
480 GB
6 Gbps
SSD-800G-SATA-6G-LFF-i
Intel
LFF
800 GB
6 Gbps
SSD-800G-SATA-6G-LFF-B-i
Intel
LFF
800 GB
6 Gbps
SSD-800G-SATA-6G-LFF-1
TOSHIBA
LFF
800 GB
6 Gbps
SSD-960G-SATA-6G-LFF-i-EM
Intel
LFF
960 GB
6 Gbps
SSD-960G-SATA-6G-LFF-EV
Intel
LFF
960 GB
6 Gbps
SSD-960G-SATA-6G-EM-SCL-m
Micron
LFF
960 GB
6 Gbps
SSD-960G-SATA-6G-EV-SCL-i
Intel
LFF
960 GB
6 Gbps
SSD-960G-SATA-6G-EM-SCL-i
Intel
LFF
960 GB
6 Gbps
Samsung
LFF
960 GB
6 Gbps
SSD-960G-SATA-6G-LFF-1
Micron
LFF
960 GB
6 Gbps
SSD-960G-SATA-6G-LFF-2
Samsung
LFF
960 GB
6 Gbps
SSD-960G-SATA-6G-LFF-4
Micron
LFF
960 GB
6 Gbps
SSD-960G-SATA-6G-LFF-5
Samsung
LFF
960 GB
6 Gbps
SSD-960G-SATA-6G-PM883-SCL
Samsung
LFF
960 GB
6 Gbps
SSD-960G-SATA-PM883-SCL
Samsung
LFF
960 GB
6 Gbps
SSD-1.92T-SATA-6G-LFF
Micron
LFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-EM-SCL-i
Intel
LFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-EM-SCL-m
Micron
LFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-EV-SCL-i
Intel
LFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-LFF-i-EM
Intel
LFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-LFF-1
Samsung
LFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-LFF-2
Samsung
LFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-LFF-3
Micron
LFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-LFF-EV-2
Intel
LFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-6G-PM883-SCL
Samsung
LFF
1.92 TB
6 Gbps
SSD-1.92T-SATA-PM883-SCL
Samsung
LFF
1.92 TB
6 Gbps
SSD-3.84T-SATA-6G-LFF
Micron
LFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-LFF-1
Samsung
LFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-LFF-EV
Intel
LFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-LFF-3
Micron
LFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-EM-SCL-i
Intel
LFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-EV-SCL-i
Intel
LFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-LFF-2
Samsung
LFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-6G-PM883-SCL
Samsung
LFF
3.84 TB
6 Gbps
SSD-3.84T-SATA-PM883-SCL
Samsung
LFF
3.84 TB
6 Gbps
NVMe SSDs
Model
Vendor
Form factor
Capacity
Rate
SSD-375G-NVMe-SFF-i
Intel
SFF
375 GB
PCIe
8 Gbps
SSD-375G-NVMe-SFF-i-1
Intel
SFF
375 GB
PCIe
8 Gbps
SSD-450G-NVMe-SFF-i
Intel
SFF
450 GB
PCIe
8 Gbps
SSD-750G-NVMe-SFF-i
Intel
SFF
750 GB
PCIe
8 Gbps
SSD-750G-NVMe-SFF-i-1
Intel
SFF
750 GB
PCIe
8 Gbps
SSD-960G-NVMe-SFF
Samsung
SFF
960 GB
PCIe
8 Gbps
SSD-960G-NVMe-EV-SFF-sa
Samsung
SFF
960 GB
PCIe
8 Gbps
SSD-960G-NVMe-SFF-1
HGST
SFF
960 GB
PCIe
8 Gbps
SSD-1T-NVMe-SFF-i-2
Intel
SFF
1.0 TB
PCIe
8 Gbps
SSD-1T-NVMe-SFF-i
Intel
SFF
1.0 TB
PCIe
8 Gbps
SSD-1T-NVMe-SFF-i-1
Intel
SFF
1.0 TB
PCIe
8 Gbps
SSD-1.2T-NVMe-SFF-i
Intel
SFF
1.2 TB
PCIe
8 Gbps
SSD-1.6T-NVMe-EM-SFF-i
Intel
SFF
1.6 TB
PCIe
8 Gbps
SSD-1.6T-NVMe-SFF-1
HGST
SFF
1.6 TB
PCIe
8 Gbps
SSD-1.6T-NVMe-SFF-i-1
Intel
SFF
1.6 TB
PCIe
8 Gbps
SSD-1.92T-NVMe-SFF-1
HGST
SFF
1.92 TB
PCIe
8 Gbps
SSD-1.92T-NVMe-EV-SFF-sa
Samsung
SFF
1.92 TB
PCIe
8 Gbps
SSD-2T-NVMe-SFF-2
Memblaze
SFF
2.0 TB
PCIe
8 Gbps
SSD-2T-NVMe-SFF-i
Intel
SFF
2.0 TB
PCIe
8 Gbps
SSD-2T-NVMe-SFF-i-6
Intel
SFF
2.0 TB
PCIe
8 Gbps
SSD-2T-NVMe-SFF-i-2
Intel
SFF
2.0 TB
PCIe
8 Gbps
SSD-2T-NVMe-SFF-i-3
Intel
SFF
2.0 TB
PCIe
8 Gbps
SSD-2T-NVMe-SFF-i-1
Intel
SFF
2.0 TB
PCIe
8 Gbps
SSD-3.2T-NVMe-EM-SFF-mbl
Memblaze
SFF
3.2 TB
PCIe
8 Gbps
SSD-3.2T-NVMe-EM-SFF-i
Intel
SFF
3.2 TB
PCIe
8 Gbps
SSD-3.2T-NVMe-SFF-1
Intel
SFF
3.2 TB
PCIe
8 Gbps
SSD-4T-NVMe-SFF-i-2
Intel
SFF
4.0 TB
PCIe
8 Gbps
SSD-3.2T-NVMe-SFF-2
HGST
SFF
3.2 TB
PCIe
8 Gbps
SSD-3.84T-NVMe-SFF-1
HGST
SFF
3.84 TB
PCIe
8 Gbps
SSD-3.84T-NVMe-EV-SFF-sa
Samsung
SFF
3.84 TB
PCIe
8 Gbps
SSD-4T-NVMe-SFF-i-1
Intel
SFF
4.0 TB
PCIe
8 Gbps
SSD-4T-NVMe-SFF-1
Memblaze
SFF
4.0 TB
PCIe
8 Gbps
SSD-4T-NVMe-SFF-i-5
Intel
SFF
4.0 TB
PCIe
8 Gbps
SSD-6.4T-NVMe-SFF-1
HGST
SFF
6.4 TB
PCIe
8 Gbps
SSD-6.4T-NVMe-EM-SFF-mbl
Memblaze
SFF
6.4 TB
PCIe
8 Gbps
SSD-6.4T-NVMe-EM-SFF-i
Intel
SFF
6.4 TB
PCIe
8 Gbps
SSD-7.68T-NVMe-CE-SFF-i
Intel
SFF
7.68 TB
PCIe
8 Gbps
SSD-7.68T-NVMe-EM-SFF-i
Intel
SFF
7.68 TB
PCIe
8 Gbps
SSD-8T-NVMe-SFF-i
Intel
SFF
8.0 TB
PCIe
8 Gbps
SSD-375G-NVMe-LFF-i
Intel
LFF
375 GB
PCIe
8 Gbps
SSD-375G-NVMe-SCL-i
Intel
LFF
375 GB
PCIe
8 Gbps
SSD-450G-NVMe-LFF
Intel
LFF
450 GB
PCIe
8 Gbps
SSD-750G-NVMe-SCL-i
Intel
LFF
750 GB
PCIe
8 Gbps
SSD-750G-NVMe-LFF-i
Intel
LFF
750 GB
PCIe
8 Gbps
SSD-960G-NVMe-EV-SCL-sa
Samsung
LFF
960 GB
PCIe
8 Gbps
SSD-960G-NVMe-LFF
Samsung
LFF
960 GB
PCIe
8 Gbps
SSD-960G-NVMe-LFF-1
HGST
LFF
960 GB
PCIe
8 Gbps
SSD-1T-NVMe-LFF-i-2
Intel
LFF
1.0 TB
PCIe
8 Gbps
SSD-1T-NVMe-LFF-i
Intel
LFF
1.0 TB
PCIe
8 Gbps
SSD-1T-NVMe-LFF-i-1
Intel
LFF
1.0 TB
PCIe
8 Gbps
SSD-1.2T-NVMe-LFF
Intel
LFF
1.2 TB
PCIe
8 Gbps
SSD-1.6T-NVMe-EM-SCL-i
Intel
LFF
1.6 TB
PCIe
8 Gbps
SSD-1.6T-NVMe-LFF-1
HGST
LFF
1.6 TB
PCIe
8 Gbps
SSD-1.6T-NVMe-LFF-i
Intel
LFF
1.6 TB
PCIe
8 Gbps
SSD-1.92T-NVMe-LFF-1
HGST
LFF
1.92 TB
PCIe
8 Gbps
SSD-1.92T-NVMe-EV-SCL-sa
Samsung
LFF
1.92 TB
PCIe
8 Gbps
SSD-2T-NVMe-LFF
Intel
LFF
2.0 TB
PCIe
8 Gbps
SSD-2T-NVMe-LFF-1
Memblaze
LFF
2.0 TB
PCIe
8 Gbps
SSD-2T-NVMe-LFF-i-3
Intel
LFF
2.0 TB
PCIe
8 Gbps
SSD-2T-NVMe-LFF-i-2
Intel
LFF
2.0 TB
PCIe
8 Gbps
SSD-2T-NVMe-LFF-i-1
Intel
LFF
2.0 TB
PCIe
8 Gbps
SSD-2T-NVMe-LFF-i
Intel
LFF
2.0 TB
PCIe
8 Gbps
SSD-3.2T-NVMe-EM-SCL-mbl
Memblaze
LFF
3.2 TB
PCIe
8 Gbps
SSD-3.2T-NVMe-EM-SCL-i
Intel
LFF
3.2 TB
PCIe
8 Gbps
SSD-3.2T-NVMe-LFF-2
HGST
LFF
3.2 TB
PCIe
8 Gbps
SSD-3.2T-NVMe-LFF
HGST
LFF
3.2 TB
PCIe
8 Gbps
SSD-3.84T-NVMe-LFF-1
HGST
LFF
3.84TB
PCIe
8 Gbps
SSD-3.84T-NVMe-EV-SCL-sa
Samsung
LFF
3.84TB
PCIe
8 Gbps
SSD-4T-NVMe-LFF-i
Intel
LFF
4.0 TB
PCIe
8 Gbps
SSD-4T-NVMe-LFF-i-1
Intel
LFF
4.0 TB
PCIe
8 Gbps
SSD-4T-NVMe-LFF
Memblaze
LFF
4.0 TB
PCIe
8 Gbps
SSD-4T-NVMe-LFF-i-2
Intel
LFF
4.0 TB
PCIe
8 Gbps
SSD-6.4T-NVMe-LFF-1
HGST
LFF
6.4 TB
PCIe
8 Gbps
SSD-6.4T-NVMe-EM-SCL-mbl
Memblaze
LFF
6.4 TB
PCIe
8 Gbps
SSD-6.4T-NVMe-EM-SCL-i
Intel
LFF
6.4 TB
PCIe
8 Gbps
SSD-7.68T-NVMe-CE-SCL-i
Intel
LFF
7.68 TB
PCIe
8 Gbps
SSD-7.68T-NVMe-EM-SCL-i
Intel
LFF
7.68 TB
PCIe
8 Gbps
SSD-8T-NVMe-LFF-i
Intel
LFF
8.0 TB
PCIe
8 Gbps
SATA M.2 SSDs
Model
Form factor
Capacity
Rate
SSD-240G-SATA-S4510-M.2
M.2 2280
80 × 22 mm (3.15 × 0.87 in)
240 GB
SATA
6 Gbps
SSD-240G-SATA-M2
M.2 2280
240 GB
SATA
6 Gbps
SSD-256G-SATA-M2
M.2 2280
256 GB
SATA
6 Gbps
SSD-480G-SATA-5100ECO-M.2
M.2 2280
480 GB
SATA
6 Gbps
SSD-480G-SATA-S4510-M.2
M.2 2280
480 GB
SATA
6 Gbps
NVMe SSD PCIe accelerator module
Model
Vendor
Form factor
Capacity
Rate
Link width
SSD-NVME-375G-P4800X
Intel
HHHL
375 GB
PCIe
8 Gbps
×4
SSD-NVME-750G-P4800X
Intel
HHHL
750 GB
PCIe
8 Gbps
×4
SSD-NVME-1.6T-EM-2
SHANNON
LP
1.6 TB
PCIe
8 Gbps
×8
SSD-1.6T-NVME-PM1725b
Samsung
HHHL
1.6 TB
PCIe
8 Gbps
×8
SSD-1.6T-NVME-PM1725b-M
Samsung
HHHL
1.6 TB
PCIe
8 Gbps
×8
SSD-1.6T-NVME-PB516
Memblaze
HHHL
1.6 TB
PCIe
8 Gbps
×8
SSD-NVME-3.2T-EM-2
SHANNON
LP
3.2 TB
PCIe
8 Gbps
×8
SSD-NVME-2T-EV
Memblaze
LP
2.0 TB
PCIe
8 Gbps
×8
SSD-NVME-2T-P4600
Intel
HHHL
2.0 TB
PCIe
8 Gbps
×8
SSD-NVME-3.2T-PBlaze5
Memblaze
HHHL
3.2 TB
PCIe
8 Gbps
×8
SSD-NVME-4T-PBlaze5
Memblaze
HHHL
4.0 TB
PCIe
8 Gbps
×8
SSD-NVME-4T-P4500
Intel
HHHL
4.0 TB
PCIe
8 Gbps
×4
SSD-NVME-4T-P4600
Intel
HHHL
4.0 TB
PCIe
8 Gbps
×8
SSD-NVME-6.4T-PBlaze5
Memblaze
HHHL
6.4 TB
PCIe
8 Gbps
×8
4LFF server
Table 12 presents the drive configurations available for the 4LFF server and their compatible storage controller types.
Table 12 Drive and storage controller configurations (4LFF server)
Drive configuration
Storage controller
4LFF
(4 front LFF SAS/SATA drives)
·         Embedded RSTe
·         Mezzanine
·         Standard
4LFF+2SFF
(4 front LFF SAS/SATA drives and 2 rear SFF SAS/SATA drives)
·         Embedded RSTe
·         Mezzanine
These drive configurations use different drive numbering schemes, as shown in Table 13.
Table 13 Drive numbering schemes (4LFF server)
Drive configuration
Drive numbering
4LFF (4 front LFF drives)
See Figure 14.
4LFF+2SFF (4 front LFF drives and 2 rear SFF drives)
See Figure 15.
Figure 14 Drive numbering for 4LFF drive configurations (4LFF server)
Figure 15 Drive numbering for 4LFF+2SFF drive configurations (4LFF server)
8SFF server
Table 14 presents the drive configurations available for the 8SFF server and their compatible storage controller types and NVMe SSD expander modules.
Table 14 Drive, storage controller, and NVMe SSD expander configurations (8SFF server)
Drive configuration
Storage controller
NVMe SSD expander
Drive backplane and installation requirements
8SFF
(8 front SFF SAS/SATA drives)
·         Embedded RSTe
·         Mezzanine
·         Standard
N/A
Use the drive backplane that supports only 8SFF SAS/SATA drives.
10SFF
(8 front SFF SAS/SATA drives and 2 front SFF SAS/SATA drives)
·         Embedded RSTe + mezzanine
·         Embedded RSTe + standard
N/A
8SFF
(4 front SFF SAS/SATA drives and 4 front SFF NVMe drives)
·         Embedded RSTe
·         Mezzanine
·         Standard
1 × 4-port NVMe SSD expander module
Use the drive backplane that supports both 4SFF SAS/SATA drives and 4SFF NVMe drives.
Install the SAS/SATA drives in drive slots 4 through 7 and install the NVMe drives in drives slots 0 through 3.
8SFF
(8 front SFF NVMe drives)
N/A
·         1 × 8-port NVMe SSD expander module
·         2 × 4-port NVMe SSD expander modules
Use the drive backplane that supports only 8SFF NVMe drives.
10SFF
(8 front SFF NVMe drives and 2 front SFF SAS/SATA drives)
Embedded RSTe
10SFF
(8 front SFF SAS/SATA drives and 2 front SFF NVMe drives)
·         Embedded RSTe
·         Mezzanine
·         Standard
These drive configurations use different drive numbering schemes, as shown in Table 15.
Table 15 Drive numbering schemes (8SFF server)
Drive configuration
Drive numbering
8SFF
See Figure 16.
10SFF
See Figure 17.
Figure 16 Drive numbering for the 8SFF drive configurations (8SFF server)
Figure 17 Drive numbering for the 10SFF drive configurations (8SFF server)
10SFF server
Table 16 presents the drive configurations available for the 10SFF server and their compatible types of storage controllers.
Table 16 Drive and storage controller configurations (10SFF server)
Drive configuration
Storage controller
10SFF
(10 front SFF SAS/SATA drives)
·         Mezzanine
·         Standard
12SFF
(10 front SFF SAS/SATA drives and 2 rear SFF SAS/SATA drives)
Mezzanine
These drive configurations use different drive numbering schemes, as shown in Table 17.
Table 17 Drive numbering schemes (10SFF server)
Drive configuration
Drive numbering
10SFF
See Figure 18.
12SFF
See Figure 19.
Figure 18 Drive numbering for the 10SFF drive configuration (10SFF server)
Figure 19 Drive numbering for the 12SFF (10 front + 2 rear) drive configuration (10SFF server)
Drive LEDs
The server supports SAS, SATA, and NVMe drives, of which SAS and SATA drives are hot swappable by default. You can use the LEDs on a drive to identify its status after it is connected to a storage controller.
Figure 20 shows the location of the LEDs on a drive.
Figure 20 Drive LEDs
(1) Fault/UID LED
(2) Present/Active LED
To identify the status of a SAS or SATA drive, use Table 18. To identify the status of an NVMe drive, use Table 19.
Table 18 SAS/SATA drive LED description
Fault/UID LED status
Present/Active LED status
Steady green/Flashing green (4.0 Hz)
A drive failure is predicted. As a best practice, replace the drive before it fails.
Steady amber
The drive is faulty. Replace the drive immediately.
Steady blue
The drive is operating correctly and is selected by the RAID controller.
Off
The drive is performing a RAID migration or rebuilding, or the system is reading or writing data to the drive.
Off
Steady green
The drive is present but no data is being read or written to the drive.
Off
Off
The drive is not securely installed.
Table 19 NVMe drive LED description
Off
The managed hot removal process is completed. You can remove the drive safely.
Flashing amber (4.0 Hz)
Off
The drive is in hot insertion process.
Steady amber
Steady blue
The drive is operating correctly and selected by the RAID controller.
Off
Off
Steady green
Off
Off
PCIe modules
Typically, the PCIe modules are available in the following standard form factors:
·          LP—Low profile.
·          FHHL—Full height and half length.
·          FHFL—Full height and full length.
·          HHHLHalf height and half length.
·          HHFLHalf height and full length.
Some PCIe modules, such as mezzanine storage controllers, are in non-standard form factors.
Storage controllers
The server supports the following types of storage controllers depending on their form factors:
·          Embedded RAID controllerEmbedded in the server and does not require installation.
·          Mezzanine storage controllerInstalled on the mezzanine storage controller connector of the system board and does not require a riser card for installation.
·          Standard storage controllerComes in a standard PCIe form factor and requires a riser card for installation.
For some storage controllers, you can order a power fail safeguard module to prevent data loss from power outages. This module provides a flash card and a supercapacitor. When a system power failure occurs, the supercapacitor provides power for a minimum of 20 seconds. During this interval, the storage controller can transfer data from DDR memory to the flash card, where the data remains indefinitely or until the controller retrieves the data. If the storage controller contains a built-in flash card, you can order only a supercapacitor.
Embedded RSTe RAID controller
Item
Specifications
Embedded in PCH of the system board
Connectors
·         One onboard ×8 mini-SAS connector
·         One onboard ×1 SATA connector
Number of internal ports
9 internal SATA ports
Port rate
6 Gbps SATA 3.0
PCIe slot
PCIe2.0 ×4
RAID levels
0, 1, 5, 10
Built-in cache memory
N/A
Supported drives
·         SATA HDD
·         SATA SSD
Power fail safeguard module
Not supported
Firmware upgrade
Upgraded with BIOS
HBA-1000-M2-1
Item
Specifications
Form factor
137 × 103 mm (5.39 × 4.06 in)
Connectors
One internal ×8 mini-SAS-HD connector
8 internal SAS ports (compatible with SATA)
Drive interface
12 Gbps SAS 3.0 (compatible with 6 Gbps SATA 3.0)
PCIe interface
PCIe3.0 ×8
RAID levels
0, 1, 10
N/A
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
Not supported
Firmware upgrade
Online upgrade
HBA-H460-B1
Item
Specifications
Form factor
LP
Connectors
One internal ×8 mini-SAS connector
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
0, 1, 10
N/A
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
Not supported
Firmware upgrade
Online upgrade
HBA-H460-M1
Item
Specifications
Form factor
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
0, 1, 10
N/A
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
Not supported
Firmware upgrade
Online upgrade
HBA-LSI-9300-8i-A1-X
Item
Specifications
Form factor
LP
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
Not supported
N/A
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
The controller supports a maximum of 12 drives.
Not supported
Firmware upgrade
Online upgrade
HBA-LSI-9311-8i
Item
Specifications
Form factor
LP
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
0, 1, 1E, 10
N/A
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
Not supported
Firmware upgrade
Online upgrade
HBA-LSI-9440-8i
Item
Specifications
Form factor
LP
Connectors
Drive interface
PCIe interface
PCIe3.1 ×8
RAID levels
0, 1, 5, 10, 50
N/A
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
Not supported
Firmware upgrade
Online upgrade
RAID-L460-M4
Item
Specifications
Form factor
Connectors
Drive interface
PCIe interface
PCIe3.1 ×8
RAID levels
0, 1, 5, 6, 10, 50, 60
4 GB internal cache module (DDR4-2133 MHz)
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
BAT-LSI-G3
The supercapacitor is optional.
Built-in flash card
Available
Supercapacitor connector
Available
Firmware upgrade
Online upgrade
RAID-LSI-9361-8i(1G)-A1-X
Item
Specifications
Form factor
LP
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
1 GB internal cache module (DDR3-1866 MHz)
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
Flash-LSI-G2
The power fail safeguard module is optional.
Built-in flash card
N/A
N/A
The supercapacitor connector is on the flash card of the power fail safeguard module.
Firmware upgrade
Online upgrade
RAID-LSI-9361-8i(2G)-1-X
Item
Specifications
Form factor
LP
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
Cache memory
2 GB internal cache module (DDR3-1866 MHz)
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
Flash-LSI-G2
Built-in flash card
N/A
N/A
Firmware upgrade
Online upgrade
RAID-LSI-9460-8i(2G)
Item
Specifications
Form factor
LP
Connectors
Drive interface
PCIe interface
PCIe3.1 ×8
RAID levels
Cache memory
2 GB internal cache module (DDR4-2133 MHz)
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
BAT-LSI-G3
Built-in flash card
Available
Available
Firmware upgrade
Online upgrade
RAID-LSI-9460-8i(4G)
Item
Specifications
Form factor
LP
Connectors
Drive interface
PCIe interface
PCIe3.1 ×8
RAID levels
Cache memory
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
BAT-LSI-G3
Built-in flash card
Available
Available
Firmware upgrade
Online upgrade
RAID-P430-M1
Item
Specifications
Form factor
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
0, 1, 1E, 5, 6, 10, 50, 60, simple volume
1 GB internal cache module (DDR3-1600 MHz, 72-bit bus at 12.8 Gbps)
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
Flash-PMC-G2
The power fail safe guard module is optional.
Built-in flash card
N/A
N/A
Firmware upgrade
Online upgrade
RAID-P430-M2
Item
Specifications
Form factor
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
2 GB internal cache module (DDR3-1600 MHz, 72-bit bus at 12.8 Gbps)
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
Flash-PMC-G2
Built-in flash card
N/A
N/A
Firmware upgrade
Online upgrade
RAID-P460-B2
Item
Specifications
Form factor
LP
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
Cache memory
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
BAT-PMC-G3
Built-in flash card
Available
Available
Firmware upgrade
Online upgrade
RAID-P460-B4
Item
Specifications
Form factor
LP
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
Cache memory
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
BAT-PMC-G3
Built-in flash card
Available
Available
Firmware upgrade
Online upgrade
RAID-P460-M2
Item
Specifications
Form factor
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
BAT-PMC-G3
Built-in flash card
Available
Available
Firmware upgrade
Online upgrade
RAID-P460-M4
Item
Specifications
Form factor
Connectors
Drive interface
PCIe interface
PCIe3.0 ×8
RAID levels
4 GB internal cache module (DDR3-2133 MHz, 72-bit bus at 12.8 Gbps)
Supported drives
·         SAS HDD
·         SAS SSD
·         SATA HDD
·         SATA SSD
BAT-PMC-G3
Built-in flash card
Available
Available
Firmware upgrade
Online upgrade
Model
Specifications
EX-4NVMe-A
4-port NVMe SSD expander module, which supports a maximum of 4 NVMe SSD drives
EX-8NVMe-A
8-port NVMe SSD expander module, which supports a maximum of 8 NVMe SSD drives
GPU modules
GPU-M4-1
Item
Specifications
PCIe interface
PCIe3.0 ×16
Form factor
LP, single-slot wide
Maximum power consumption
75 W
Output ports
N/A
Memory size
4 GB GDDR5
Memory bus width
128 bits
Memory bandwidth
88 Gbps
Power interface
N/A
GPU-M4000-1-X
Item
Specifications
PCIe interface
PCIe3.0 ×16
Form factor
FH3/4FL, single-slot wide
120 W
Output ports
·         1 × DVI-I port
·         2 × DP ports
Memory size
8 GB GDDR5
Memory bus width
256 bits
Memory bandwidth
192 Gbps
Power interface
Available
GPU-M2000
Item
Specifications
PCIe interface
PCIe3.0 ×16
Form factor
FHHL, single-slot wide
75 W
Output ports
4 × DP ports
Memory size
4 GB GDDR5
Memory bus width
128 bits
Memory bandwidth
105.7 Gbps
Power interface
N/A
GPU-P4-X
Item
Specifications
PCIe interface
PCIe3.0 ×16
Form factor
75 W
Output ports
N/A
Memory size
8 GB GDDR5
Memory bus width
256 bits
Memory bandwidth
192 Gbps
Power interface
N/A
GPU-T4
Item
Specifications
PCIe interface
PCIe3.0 ×16
Form factor
70 W
Output ports
N/A
Memory size
16 GB GDDR6
Memory bus width
256 bits
Memory bandwidth
320 Gbps
Power interface
N/A
GPU-MLU100-D3
Item
Specifications
PCIe interface
PCIe3.0 ×16
Form factor
HHHL, single-slot wide
75 W
Memory size
8 GB
Memory bus width
256 bits
Memory bandwidth
102.4 Gbps
Power interface
N/A
In addition to the PCIe Ethernet adapters, the server also supports mLOM Ethernet adapters (see "mLOM Ethernet adapters").
Figure 21 PCIe Ethernet adapter specifications
Model
Ports
Connector
Data rate
Bus type
Form factor
NCSI
CNA-10GE-2P-510F-B2-1-X
2
SFP+
10 Gbps
PCIe 3.0 ×8
LP
Not supported
CNA-10GE-2P-560F-B2-1-X
2
SFP+
10 Gbps
PCIe 2.0 ×8
LP
Not supported
CNA-560T-B2-10Gb-2P-1-X
2
RJ-45
10 Gbps
PCIe 3.0 ×8
LP
Not supported
CNA-QL41262HLCU-11-2*25G
2
SFP28
25 Gbps
PCIe 3.0 ×8
LP
Not supported
IB-MCX555A-ECAT-100Gb-1P
1
QSFP28
100 Gbps
PCIe 3.0 ×16
LP
Not supported
IB-MCX555A-ECAT-100Gb-1P-1
1
QSFP28
100 Gbps
PCIe 3.0 ×16
LP
Not supported
IB-MCX453A-FCAT-56/40Gb-1P
1
QSFP28
56 Gbps
PCIe 3.0 ×8
LP
Not supported
IB-MCX453A-FCAT-56/40Gb-1P-1
1
QSFP28
56 Gbps
PCIe 3.0 ×8
LP
Not supported
IB-MCX354A-FCBT-56/40Gb-2P-X
2
QSFP+
40/56 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-10GE-2P-520F-B2-1-X
2
SFP+
10 Gbps
PCIe 3.0 ×8
LP
Not supported
NIC-10GE-2P-530F-B2-1-X
2
SFP+
10 Gbps
PCIe 2.0 ×8
LP
Not supported
NIC-620F-B2-25Gb-2P-1-X
2
SFP28
25 Gbps
PCIe 3.0 ×8
LP
Supported
NIC-GE-4P-360T-B2-1-X
4
RJ-45
10/100/1000 Mbps
PCIe 2.0 ×4
LP
Not supported
NIC-BCM957416-T-B-10Gb-2P
2
RJ-45
10 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-BCM957302-F-B-10Gb-2P
2
SFP+
10 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-BCM957412-F-B-10Gb-2P
2
SFP+
10 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-BCM957414-F-B-25Gb-2P
2
SFP28
25 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-957454A4540C-B-100G-1P
1
QSFP28
100 Gbps
PCIe 3.0 ×16
LP
Not supported
NIC-CAVIUM-F-B-25Gb-2P
2
SFP28
25 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-MCX415A-F-B-100Gb-1P
1
QSFP28
100 Gbps
PCIe3.0 ×16
LP
Not supported
NIC-MCX416A-F-B-40/56-2P
2
QSFP28
56 Gbps
PCIe 3.0 ×16
LP
Not supported
NIC-MCX416A-F-B-100Gb-2P
2
SFP28
25 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-MCX4121A-F-B-10Gb-2P
2
SFP28
10 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-X520DA2-F-B-10Gb-2P
2
SFP+
10 Gbps
PCIe 2.0 ×8
LP
Not supported
NIC-X540-T2-T-10Gb-2P
2
RJ45
10 Gbps
PCIe2.0 ×8
LP
Not supported
NIC-XL710-QDA1-F-40Gb-1P
1
QSFP+
40 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-XL710-QDA2-F-40Gb-2P
2
QSFP+
40 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-X710DA2-F-B-10Gb-2P-2
2
SFP+
10 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-X710DA4-F-B-10Gb-4P
4
SFP+
10 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-MCX4121A-F-B-25Gb-2P
2
SFP28
25 Gbps
PCIe 3.0 ×8
LP
Not supported
NIC-MCX512A-ACAT-F-2*25Gb
2
SFP28
25 Gbps
PCIe3.0 ×8
LP
Not supported
NIC-XXV710-F-B-25Gb-2P
2
SFP28
25 Gbps
PCIe 3.0 ×8
LP
Not supported
NIC-OPA-100Gb-1P
1
QSFP28
100 Gbps
PCIe3.0 ×16
LP
Not supported
NIC-10/25Gb-2P-640FLR-SFP28
2
SFP28
25 Gbps
PCIe 3.0 ×8
FLOM
Supported
NIC-iETH-PS225-H16
2
SFP28
25 Gbps
PCIe 3.0 ×8
LP
Supported
FC HBAs
Table 20 FC HBA specifications
Model
Ports
Connector
Data rate
Form factor
FC-HBA-QLE2560-8Gb-1P-1-X
1
SFP+
8 Gbps
LP
FC-HBA-QLE2562-8Gb-2P-1-X
2
SFP+
8 Gbps
LP
FC-HBA-QLE2690-16Gb-1P-1-X
1
SFP+
16 Gbps
LP
FC-HBA-QLE2692-16Gb-2P-1-X
2
SFP+
16 Gbps
LP
HBA-8Gb-LPe12000-1P-1-X
1
SFP+
8 Gbps
LP
HBA-8Gb-LPe12002-2P-1-X
2
SFP+
8 Gbps
LP
HBA-16Gb-LPe31000-1P-1-X
1
SFP+
16 Gbps
LP
HBA-16Gb-LPe31002-2P-1-X
2
SFP+
16 Gbps
LP
FC-HBA-LPe32000-32Gb-1P-X
1
SFP+
32 Gbps
LP
FC-HBA-LPe32002-32Gb-2P-X
2
SFP+
32 Gbps
LP
FC-HBA-QLE2740-32Gb-1P
1
SFP+
32 Gbps
LP
FC-HBA-QLE2742-32Gb-2P
2
SFP+
32 Gbps
LP
In addition to mLOM Ethernet adapters, the server also supports PCIe Ethernet adapters (see "PCIe Ethernet adapters").
NIC-GE-4P-360T-L3
Item
Specifications
Dimensions
128 × 68 mm (5.04 × 2.68 in)
Ports
4
Connector
RJ-45
Data rate
1000 Mbps
Bus type
1000BASE-X ×4
NCSI
Supported
Riser cards
PCIe slots
The server supports the RC-FHHL-1U-G3 riser card, as shown in Figure 22.
Figure 22 Riser card
The slot number of a PCIe slot varies by the PCIe riser connector that holds the riser card, as shown in Figure 23.
·          If the riser card is installed on PCIe riser connector 1, the slot number of the PCIe slot is 1.
·          If the riser card is installed on PCIe riser connector 2, the slot number of the PCIe slot is 2.
Figure 23 PCIe slots on the RC-FHHL-1U-G3 riser card
(1) PCIe slot 1
(2) PCIe slot 2
A PCIe slot can supply power to the installed PCIe module if the maximum power consumption of the module does not exceed 75 W. If the maximum power consumption exceeds 75 W, a power cord is required.
RC-FHHL-1U-G3
Item
Specifications
Installation location
·         PCIe riser connector 1
·         PCIe riser connector 2
PCIe slots
One PCIe3.0 ×16
Form factors of PCIe modules
FHFL
Maximum power supplied per PCIe slot
75 W
Fans
Fan layout
The server supports a maximum of seven hot swappable fans. Figure 24 shows the layout of the fans in the chassis.
Figure 24 Fan layout
Fan specifications
Item
Specifications
Model
FAN-1U-G3
Form factor
1U standard fan
Power supplies
The power supplies have an overtemperature protection mechanism. A power supply automatically stops working when an overtemperature occurs and automatically recovers when the overtemperature condition is removed.
550 W Platinum power supply
Item
Specifications
Model
·         PSR550-12A
·         PSR550-12A-1
·         PSR550-12A-2
Rated input voltage range
·         100 VAC to 240 VAC @ 50/60 Hz (10 A receptacle)
·         192 VDC to 288 VDC (240 HVDC power source)
Maximum rated input current
·         8.0 A @ 100 VAC to 240 VAC
·         2.75 A @ 240 VDC
Maximum rated output power
550 W
Efficiency at 50 % load
94%, 80 Plus Platinum level
Temperature requirements
·         Operating temperature: 0°C to 50°C (32°F to 122°F)
·         Storage temperature: –40°C to +70°C (–40°F to +158°F)
Operating humidity
5% to 90%
Maximum altitude
5000 m (16404.20 ft)
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
550 W high-efficiency Platinum power supply
Item
Specifications
Model
DPS-550W-12A
·         7.1 A @ 100 VAC to 240 VAC
·         2.8 A @ 240 VDC
550 W
·         Operating temperature: 0°C to 55°C (32°F to 131°F)
Operating humidity
5% to 85%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
800 W Platinum power supply
Item
Specifications
Model
PSR800-12A
·         10.0 A @ 100 VAC to 240 VAC
·         4.0 A @ 240 VDC
800 W
Operating humidity
5% to 90%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
800 W –48 VDC power supply
Item
Specifications
Model
DPS-800W-12A-48V
–48 VDC to –60 VDC
20.0 A @ –48 VDC to –60 VDC
800 W
92%
Operating humidity
5% to 90%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
800 W 336V high-voltage DC power supply
Item
Specifications
Model
PSR800-12AHD
·         180 VDC to 400 VDC (240 to 336 HVDC power source)
·         3.8 A @ 240 VDC
800 W
94%
Operating humidity
5% to 90%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
850 W high-efficiency Platinum power supply
Item
Specifications
Model
DPS-850W-12A
·         4.4 A @ 240 VDC
850 W
Operating humidity
5% to 85%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
850 W Titanium power supply
Item
Specifications
Model
PSR850-12A
·         11.0 A @ 100 VAC to 240 VAC
·         4.0 A @ 240 VDC
850 W
96%, 80 Plus Titanium level
Operating humidity
5% to 85%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
1200 W Platinum power supply
Item
Specifications
Model
PSR1200-12A
·         100 VAC to 127 VAC @ 50/60 Hz (1000 W)
·         200 VAC to 240 VAC @ 50/60 Hz (1200 W)
·         192 VDC to 288 VDC (1200 W)
·         12.0 A @ 100 VAC to 240 VAC
·         6.0 A @ 240 VDC
1200 W
Operating humidity
5% to 90%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
Model
Specifications
ODD-Cage-1U
Common expander module for optical drive or M.2 SATA SSD expansion on the 8SFF server
RC-M2-C
M.2 transfer module (used for expansion of two rear SATA M.2 SSDs)
RC-M2-1U
M.2 transfer module (used to expand the server with two front SATA M.2 SSDs)
DSD-EX
Dual SD card extended module (supports RAID level 1)
UV-1U-LFF
Front media module 1 (available for 4LFF servers)
UV-1U-SFF
Front media module 2 (available for 8SFF and 10SFF servers)
HDD-Cage-2SFF-Rear-1U
Rear 2SFF SAS/SATA drive cage
HDD-Cage-2SFF-Front
Front 2SFF SAS/SATA drive cage
HDD-Cage-2SFF-1U-G3-NVMe
Front 2SFF NVMe drive cage
Diagnostic panels
Diagnostic panels provide diagnostics and troubleshooting capabilities. You can locate and troubleshoot component failures by using the diagnostic panels in conjunction with the event log generated in HDM.
A diagnostic panel displays only one component failure at a time. When multiple component failures exist, the diagnostic panel displays all these failures one by one at intervals of 4 seconds.
Model
Specifications
SD-SFF-A
SFF diagnostic panel for 8SFF and 10SFF servers
SD-LFF-G3-A
LFF diagnostic panel for the 4LFF server
Figure 25 shows the error code and LEDs on a diagnostic panel.
Figure 25 Diagnostic panel view
(1) Error code
(2) LEDs
For more information about the LEDs and error codes, see "LEDs."
LEDs
POST LED
LED status
Error code
Steady green
POST code for the current phase (in the range of 00 to 99)
The server is performing POST and the POST process is normal.
Flashing red
The POST process encountered an error and stopped in the displayed phase.
Off
00
The server is operating correctly when the error code is 00 and all LEDs are off.
TEMP LED
LED status
Error code
Flashing red
Temperature sensor ID
A severe temperature warning is present on the component monitored by the sensor.
This warning might occur because the temperature of the component has exceeded the upper threshold or dropped below the lower threshold.
CAP LED
LED status
Error code
Flashing amber
01
The system power consumption has exceeded the power cap value.
Component LEDs
An alarm is present if a component LED has one of the following behaviors:
Use Table 21 to identify the faulty item if a component LED has one of those behaviors. To obtain records of component status changes, use the event log in HDM. For information about using the event log, see HDM online help.
Table 21 LED, error code and faulty item matrix
LED
Error code
Faulty item
BRD
11
System board
21, 22, or 23
Front drive backplane
32
Rear 2SFF drive backplane
71
Mezzanine storage controller power
81
Reserved
91
If the error code field displays 11 and any other code alternatively, replace the faulty item other than the system board. If the issue persists, replace the system board.
Processor
01
Processor 1
02
Processor 2
DIMM
A1 through A9, AA, AC, or AE
DIMMs in slots A1 through A12
B1 through B9, BA, BC, or BE
DIMMs in slots B1 through B12
HDD
00 through 03
Front drives (4LFF server)
00 through 07
Front drives (8LFF server)
00 through 09
Front drives (10SFF server)
00 and 01
Rear drives
PCIE
01 and 02
PCIe modules in PCIe slots 1 and 2 of the riser card
PSU
01
Power supply 1
02
Power supply 2
RAID
10
Mezzanine storage controller status
FAN
01 through 07
Fan 1 through Fan 7
VRD
01
System board P5V voltage
02
System board P1V05_PCH voltage
03
System board PVCC_HPMOS voltage
04
System board P3V3 voltage
05
System board P1V8_PCH voltage
06
System board PVCCIO_CPU1 voltage
07
System board PVCCIN_CPU1 voltage
08
System board PVCCIO_CPU2 voltage
09
System board PVCCIN_CPU2 voltage
10
System board VPP_CPU1_ABC voltage
11
System board VPP_CPU1_DEF voltage
12
System board VDDQ_CPU1_ABC voltage
13
System board VDDQ_CPU1_DEF voltage
14
System board VTT_CPU1_ABC voltage
15
System board VTT_CPU1_DEF voltage
16
17
18
System board VDDQ_CPU2_ABC voltage
19
System board VDDQ_CPU2_DEF voltage
20
System board VTT_CPU2_ABC voltage
21
System board VTT_CPU2_DEF voltage
The term "CPU" in this table refers to processors.
Model
Central wavelength
Connector
Max transmission distance
SFP-XG-SX-MM850-A1-X
850 nm
LC
300 m (984.25 ft)
SFP-XG-SX-MM850-E1-X
850 nm
LC
300 m (984.25 ft)
SFP-25G-SR-MM850-1-X
850 nm
LC
100 m (328.08 ft)
Model
Specifications
SD-32G-Micro-A
32 G microsSD mainstream flash media kit module
SD-32G-Micro-1
USB-32G-A
32 G USB 3.0 storage disk module
DVD-RW-Mobile-USB-A
Removable USB DVDRW optical drive
The optical drive can be connected only to a USB 3.0 port.
DVD-RW-SATA-9.5MM-A
9.5mm SATA DVD-RW optical drive
DVD-ROM-SATA-9.5MM-A
9.5mm SATA DVD-ROM optical drive
NVMe VROC modules
Model
RAID levels
Compatible NVMe SSDs
NVMe-VROC-Key-S
0, 1, 10
All NVMe SSDs
NVMe-VROC-Key-P
0, 1, 5, 10
All NVMe SSDs
NVMe-VROC-Key-i
0, 1, 5, 10
Intel NVMe SSDs
TPM/TCM modules
Trusted platform module (TPM) is a microchip installed on the system board. It stores encryption information (such as encryption keys) for authenticating server hardware and software. The TPM operates with drive encryption programs such as Microsoft Windows BitLocker to provide operating system security and data protection. For information about Microsoft Windows BitLocker, visit the Microsoft website at http://www.microsoft.com
Trusted cryptography module (TCM) is a trusted computing platform-based hardware module with protected storage space, which enables the platform to perform password calculation.
Table 22 describes the TPM and TCM modules supported by the server.
Table 22 TPM/TCM specifications
Model
Specifications
TPM-2-X
H3C series TPM module 2.0
TCM-1-X
H3C series TCM module 1.0
Security bezels, slide rail kits, and cable management brackets
Model
SEC-Panel-1U-X
1U security bezel
SL-1U -BB
1U ball bearing rail
SL-1U -FR
1U standard rail
CMA-1U-A
1U cable management bracket
Appendix C  Managed hot removal of NVMe drives
Managed hot removal of NVMe drives enables you to remove NVMe drives safely while the server is operating.
Use Table 23 to determine the managed hot removal method depending on the VMD status and the operating system. For more information about VMD, see the BIOS user guide for the server.
Table 23 Managed hot removal methods
VMD status
Operating system
Auto
Windows
Performing a managed hot removal in Windows.
Linux
Performing a managed hot removal in Linux.
Disabled
N/A
Contact the support.
Install Intel® Rapid Storage Technology enterprise (Intel® RSTe).
To obtain Intel® RSTe, use one of the following methods:
·          Go to https://platformsw.intel.com/KitSearch.aspx to download the software.
·          Contact Intel Support.
1.        Stop reading data from or writing data to the NVMe drive to be removed.
2.        Identify the location of the NVMe drive. For more information, see "Drive configurations and numbering."
3.        Run Intel® RSTe.
4.        Unmount the NVMe drive from the operating system, as shown in Figure 26:
¡  Select the NVMe drive to be removed.
¡  Click Activate LED to turn on the Fault/UID LED on the drive.
¡  Click Remove Disk.
Figure 26 Removing an NVMe drive
5.        Observe the Fault/UID LED on the drive. If the Fault/UID LED turns steady blue and the drive is removed from the Devices list, remove the drive from the server.
For more information about the removal procedure, see "Replacing an NVMe drive."
In Linux, you can perform a managed hot removal of NVMe drives from the CLI or by using Intel® Accelerated Storage Manager.
·          Verify that your operating system is a non-SLES Linux operating system. SLES operating systems do not support managed hot removal of NVMe drives.
·          To perform a managed hot removal by using Intel®  ASM, install Intel®  ASM.
To obtain Intel® ASM, use one of the following methods:
¡  Go to https://platformsw.intel.com/KitSearch.aspx to download the software.
¡  Contact Intel Support.
Performing a managed hot removal from the CLI
3.        Access the CLI of the server.
4.        Execute the lsblk | grep nvme command to identify the drive letter of the NVMe drive, as shown in Figure 27.
Figure 27 Identifying the drive letter of the NVMe drive to be removed
5.        Execute the ledctl locate=/dev/drive_letter command to turn on the Fault/UID LED on the drive. The drive_letter argument represents the drive letter, nvme0n1 for example.
6.        Execute the echo 1 > /sys/block/drive_letter/device/device/remove command to unmount the drive from the operating system. The drive_letter argument represents the drive letter, nvme0n1 for example.
7.        Observe the Fault/UID LED on the drive. If the Fault/UID LED turns steady blue, remove the drive from the server.
Performing a managed hot removal from the Intel® ASM Web interface
3.        Run Intel® ASM.
4.        Click RSTe Management.
Figure 28 Accessing RSTe Management
5.        Expand the Intel(R) VROC(in pass-thru mode) menu to view operating NVMe drives, as shown in Figure 29.
Figure 29 Viewing operating NVMe drives
6.        Click the light bulb icon to turn on the Fault/UID LED on the drive, as shown in Figure 30.
Figure 30 Turning on the drive Fault/UID LED
7.        Click the removal icon, as shown in Figure 31.
Figure 31 Removing an NVMe drive
8.        In the confirmation dialog box that opens, click Yes.
Figure 32 Confirming the removal
9.        Remove the drive from the server. For more information about the removal procedure, see "Replacing an NVMe drive."
Appendix D  Environment requirements
Guidelines
The operating temperature requirements for the server vary depending on the server model and hardware configuration. When the general and component-based requirements conflict, use the component-based requirement.
Be aware that the actual maximum operating temperature of the server might be lower than that stated. This is because the server cooling performance might decrease because of adverse external factors, including poor cabinet cooling performance, high power density inside the cabinet, or insufficient spacing between devices.
General environment requirements
Item
Specifications
Minimum: 5°C (41°F)
Maximum: Varies depending on the power consumed by the processors and presence of expansion modules. For more information, see "Operating temperature requirements."
Storage temperature
Operating humidity
8% to 90%, noncondensing
Storage humidity
5% to 90%, noncondensing
Operating altitude
–60 m to +3000 m (–196.85 ft to +9842.52 ft)
The allowed maximum temperature decreases by 0.33 °C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 900 m (2952.76 ft)
Storage altitude
–60 m to +5000 m (–196.85 ft to +16404.20 ft)
Guidelines
If a fan fails or is absent, performance of the following components might degrade:
·          DCPMMs.
·          GPU modules.
·          Processors on the 4LFF server, 8SFF server with a 10SFF drive configuration, or 10SFF server if the server is installed with rear drives.
4LFF server with any drive configuration
Use Table 24 to determine the maximum operating temperature of the 4LFF server that uses any drive configuration. A maximum server operating temperature applies if the server contains any options in its matching hardware option list.
If a single fan fails, the maximum server operating temperature drops by 5 °C (41°F) and cannot exceed 35°C (95°F).
All maximum server operating temperature values are provided on the basis that the fans are installed as needed and operating correctly. For more information about fan configurations, see the guidelines in "Installing fans."
Table 24 Operating temperature requirements for the 4LFF server with any configuration
Maximum server operating temperature
Processor configuration
Hardware option configuration
25°C (77°F)
165 W or higher
·         Rear drives.
·         GPU modules:
¡  GPU-P4-X.
¡  GPU-M4-1.
¡  GPU-T4.
¡  GPU-MLU100-D3.
30°C (86°F)
125 W to 165 W (exclusive)
·         Rear drives.
·         GPU modules:
¡  GPU-P4-X.
¡  GPU-M4-1.
¡  GPU-T4.
¡  GPU-MLU100-D3.
High than 165 W
Rear SATA M.2 SSDs
35°C (95°F)
Any
·         NVMe SSD PCIe accelerator modules.
·         DCPMMs.
Processor 8180, 8180M, 8168, 6154, 6146, 6144, 6244, or 6240Y
Any
Lower than 125 W
·         Rear drives.
·         GPU modules:
¡  GPU-P4-X.
¡  GPU-M4-1.
¡  GPU-T4.
¡  GPU-MLU100-D3.
165 W or lower
Rear SATA M.2 SSDs.
Higher than 165 W
Rear Ethernet adapter with a fiber transceiver module.
40°C (104°F)
165 W or lower, except for processor 6146
Any except for processors 8180, 8180M, 8168, 6154, 6146, 6144, 6244, and 6240Y
·         GPU modules:
¡  GPU-M4000-1-X.
¡  GPU-M2000.
·         Ethernet adapters:
¡  IB-MCX453A-FCAT-56/40Gb-1P.
¡  IB-MCX453A-FCAT-56/40Gb-1P-1.
Higher than 125 W, except for processors 8180, 8180M, 8168, 6154, 6146, 6144, 6244, and 6240Y
None of the above hardware options or operating conditions exists and seven operating fans are present
45°C (113°F)
125 W or lower
8SFF server with an 8SFF drive configuration
Use Table 25 to determine the maximum operating temperature of the 8SFF server with an 8SFF drive configuration. A maximum server operating temperature applies if the server contains any options in its matching hardware option list.
If a single fan fails, the maximum server operating temperature drops by 5°C (41°F) and cannot exceed 35°C (95°F).
Table 25 Operating temperature requirements for the 8SFF server with an 8SFF drive configuration
25°C (77°F)
165 W or higher
GPU modules:
·         GPU-P4-X.
·         GPU-M4-1.
·         GPU-T4.
·         GPU-MLU100-D3.
30°C (86°F)
GPU modules:
·         GPU-P4-X.
·         GPU-M4-1.
·         GPU-T4.
·         GPU-MLU100-D3.
High than 165 W
Rear SATA M.2 SSDs.
35°C (95°F)
Any
·         NVMe SSD PCIe accelerator module.
·         Samsung NVMe drives.
·         DCPMMs.
Any
Lower than 125 W
GPU modules:
·         GPU-P4-X.
·         GPU-M4-1.
·         GPU-T4.
·         GPU-MLU100-D3.
165 W or lower
Rear SATA M.2 SSDs.
Higher than 165 W
40°C (104°F)
Any except processors 8180, 8180M, 8168, 6154, 6146, 6144, 6244, and 6240Y
·         Rear Ethernet adapter with a fiber transceiver module.
·         NVMe drives, excluding Samsung NVMe drives.
·         GPU modules:
¡  GPU-M4000-1-X.
¡  GPU-M2000.
None of the above hardware options or operating conditions exists and seven operating fans are present.
45°C (113°F)
125 W or lower
Use Table 26 to determine the maximum operating temperature of the 8SFF server with a 10SFF drive configuration. A maximum server operating temperature applies if the server contains any options in its matching hardware option list.
Table 26 Operating temperature requirements for the 8SFF server with a 10SFF drive configuration
25°C (77°F)
165 W or higher
·         Rear drives.
·         GPU modules:
¡  GPU-P4-X.
¡  GPU-M4-1.
¡  GPU-T4.
¡  GPU-MLU100-D3.
30°C (86°F)
·         Rear drives.
·         GPU modules:
¡  GPU-P4-X.
¡  GPU-M4-1.
¡  GPU-T4.
¡  GPU-MLU100-D3.
Higher than 165 W
Rear SATA M.2 SSDs.
Any
NVMe SSD PCIe accelerator modules SSD-NVME-375G-P4800X and SSD-NVME-750G-P4800X, and Memblaze NVMe SSD PCIe accelerator modules
35°C (95°F)
Lower than 125 W
·         Rear drives
·         GPU modules:
¡  GPU-P4-X.
¡  GPU-M4-1.
¡  GPU-T4.
¡  GPU-MLU100-D3.
Higher than 165 W
Processor 8180, 8180M, 8168, 6154, 6146, 6144, 6244, and 6240Y
Any
Any
·         NVMe SSD PCIe accelerator modules excluding SSD-NVME-375G-P4800X, SSD-NVME-750G-P4800X, or Memblaze NVMe SSD PCIe accelerator modules.
·         DCPMMs.
165 W or lower
Rear SATA M.2 SSDs.
40°C (104°F)
Any except for processors 8180, 8180M, 8168, 6154, 6146, 6144, 6244, or 6240Y
10SFF server with any drive configuration
Use Table 26 to determine the maximum operating temperature of the 10SFF server with any drive configuration. A maximum server operating temperature applies if the server contains any options in its matching hardware option list.
Table 27 Operating temperature requirements for the 10SFF server with any drive configuration
25°C (77°F)
165 W or higher
·         Rear drives.
·         GPU modules:
¡  GPU-P4-X.
¡  GPU-M4-1.
¡  GPU-T4.
¡  GPU-MLU100-D3.
30°C (86°F)
·         Rear drives.
·         GPU modules:
¡  GPU-P4-X.
¡  GPU-M4-1.
¡  GPU-T4.
¡  GPU-MLU100-D3.
Higher than 165 W
Rear SATA M.2 SSDs.
Any
NVMe SSD PCIe accelerator modules SSD-NVME-375G-P4800X and SSD-NVME-750G-P4800X, and Memblaze NVMe SSD PCIe accelerator modules.
35°C (95°F)
Lower than 125 W
·         Rear drives.
·         GPU modules:
¡  GPU-P4-X.
¡  GPU-M4-1.
¡  GPU-T4.
¡  GPU-MLU100-D3.
Higher than 165 W
Any
Any
·         DCPMMs.
165 W or lower
Rear SATA M.2 SSDs.
40°C (104°F)
Appendix E  Product recycling
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
·          Tel: 400-810-0504
·          E-mail: [email protected]
·          Website: http://www.h3c.com
Appendix F  Glossary
Item
B
BIOS
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's system board. BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality.
C
CPLD
Complex programmable logic device is an integrated circuit used to build reconfigurable digital circuits.
E
Ethernet adapter
An Ethernet adapter, also called a network interface card (NIC), connects the server to the network.
F
FIST
Fast Intelligent Scalable Toolkit provided by H3C for easy and extensible server management. It can guide users to configure a server quickly with ease and provide an API interface to allow users to develop their own management tools on its basis.
G
GPU module
Graphics processing unit module converts digital signals to analog signals for output to a display device and assists processors with image processing to improve overall system performance.
H
HDM
H3C Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server.
Hot swapping
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation.
K
KVM
KVM is an abbreviation for keyboard, video, and mouse. KVM is a management method that allows remote users to use their local video display, keyboard, and mouse to monitor and control remote servers.
N
An expander module facilitates communication between the system board and the front NVMe hard drives. The module is required if a front NVMe drive is installed.
NVMe VROC module
A module that works with VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives.
R
RAID
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance.
Redundancy
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails.
S
Security bezel
A locking bezel mounted to the front of a server to prevent unauthorized access to the modules, such as hard drives.
T
Temperature sensor
A temperature sensor detects changes in temperature at the location where it is installed and reports the temperature data to the server system.
U
U
A unit of measure defined as 44.45 mm (1.75 in) in IEC 60297-1. It is used as a measurement of the overall height of racks, as well as equipment mounted in the racks.
V
VMD
VMD provides hot removal, management, and fault-tolerance functions for NVMe drives to increase availability, reliability, and serviceability.
Appendix G  Acronyms
Acronym
Full name
B
BIOS
Basic Input/Output System
C
CMA
Cable Management Arm
CPLD
Complex Programmable Logic Device
D
DCPMM
Data Center Persistent Memory Module
DDR
Double Data Rate
DIMM
Dual In-Line Memory Module
DRAM
Dynamic Random Access Memory
F
FIST
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDD
Hard Disk Drive
HDM
I
IDC
Internet Data Center
K
KVM
Keyboard, Video, Mouse
L
LFF
Large Form Factor
LRDIMM
Load Reduced Dual Inline Memory Module
M
mLOM
Modular LAN-on-Motherboard
N
NCSI
Network Controller Sideband Interface
NVMe
Non-Volatile Memory Express
P
PCIe
Peripheral Component Interconnect Express
PDU
Power Distribution Unit
POST
Power-On Self-Test
R
RAID
Redundant Array of Independent Disks
RDIMM
Registered Dual Inline Memory Module
S
SAS
Serial Attached Small Computer System Interface
SATA
Serial ATA
SD
Secure Digital
SDS
Secure Diagnosis System
SFF
Small Form Factor
SSD
Solid State Drive
T
TCM
Trusted Cryptography Module
TDP
Thermal Design Power
TPM
Trusted Platform Module
U
UID
Unit Identification
UPI
Ultra Path Interconnect
UPS
Uninterruptible Power Supply
USB
Universal Serial Bus
V
VROC
Virtual RAID on CPU
VMD
Volume Management Device
