02-WLAN Configuration Guides
HomeSupportConfigure & DeployConfiguration GuidesH3C Unified Wired and Wireless Access Controller User Manual (R5417P03)-6W10302-WLAN Configuration Guides
15-Wireless location configuration
15-Wireless location configuration 132.93 KB
Configuring wireless location
About wireless location
Wireless location tracks 802.11 devices for medical monitoring, asset management, and logistics management.
Wireless location system
As shown in Figure 1, a wireless location system contains 802.11 devices, information receivers(802.11 APs), and a location server. 802.11 devices include Tags (small wireless devices that can only send 802.11 packets periodically) and MUs (all 802.11 devices except Tags).
Figure 1 Wireless location system
Wireless location mechanism
Wireless location operates as follows:
1.        The 802.11 devicesends a wireless packet.
2.        Upon receiving the wireless packet, the APs encapsulate the collected location information (including RSSI and timestamp) in location packets, and then send the packets to the location server.
3.        The location server calculates the location of the 802.11 or BLE device.
A location server needs location information from a minimum of three APs to locate an 802.11 or BLE device.
Wireless location methods
RF fingerprinting sets up a fingerprint database by collecting signal strength and location of clients. To locate a client, an AP encapsulates the location information of the client into a location packet and sends the packet to the location server. The location server uses a location algorithm to match the signal strength of the client against information in the database to locate the client.
RF fingerprinting is used to locate MUs and Tags.
Restrictions and guidelines: Wireless location configuration
You can configure APs by using the following methods:
·          Configure APs one by one in AP view.
·          Assign APs to an AP group and configure the AP group in AP group view.
·          Configure all APs in global configuration view.
For an AP, the settings made in these views for the same parameter take effect in descending order of AP view, AP group view, and global configuration view.
Wireless location tasks at a glance
To configure RF fingerprinting, perform the following tasks:
1.        Enabling RF fingerprinting
2.        Enabling radio-based location
3.        Specifying an IPv4 address and a port number for the location server
4.        Specifying a port to listen for messages from the location server
5.        Specifying a multicast MAC address for Tags
6.        Specifying the type of devices to locate
7.        (Optional.) Configuring raw frame reporting
8.        (Optional.) Configuring MU information reporting
9.        (Optional.) Specifying the location packet format
10.     (Optional.) Specifying the report mode for location packets
11.     (Optional.) Configuring wireless location common parameters
¡  Configuring packet dilution
¡  Enabling ignoring beacon frames
¡  Enabling ignoring AP frames
¡  Configuring RSSI-based packet filtering
¡  Configuring client packet rate limiting
¡  Configuring location packet rate limiting
¡  Configuring wireless location keepalive
Configuring RF fingerprinting
For an AP to send location packets to the location server, you must enable both RF fingerprinting and radio-based location.
1.        Enter system view.
2.        Enter AP view, AP group view, or global configuration view.
¡  Enter AP view.
wlan ap ap-name
¡  Enter AP group view.
wlan ap-group group-name
¡  Enter global configuration view.
wlan global-configuration
3.        Enable RF fingerprinting.
rfid-tracking fingerprint enable
By default:
¡  In AP view, an AP uses the configuration in AP group view. If no setting is configured in AP group view, the AP uses the configuration in global configuration view.
¡  In AP group view, an AP uses the configuration in global configuration view.
¡  In global configuration view, RF fingerprinting is disabled.
2.        Enter AP view or an AP group's AP model view.
¡  Enter AP view.
wlan ap ap-name
¡  Execute the following commands in sequence to enter an AP group's AP model view:
ap-model ap-model
3.        Enter radio view.
radio radio-id
4.        Enable radio-based location.
rfid-tracking radio enable
By default:
¡  In radio view, an AP uses the configuration in an AP group's radio view.
¡  In an AP group's radio view, radio-based location is disabled.
About specifying an IPv4 address and port number for the location server
This feature enables APs to send location packets to the specified IPv4 address and port number for communicating with the location server.
¡  Enter AP view.
wlan ap ap-name
3.        Specify an IPv4 address and a port number for the location server.
rfid-tracking fingerprint engine-address engine-address engine-port engine-port
By default:
¡  In global configuration view, no IPv4 address and port number are specified for the location server.
About specifying the port to listen
Perform this task to specify a port for an AP to listen for messages from the location server.
¡  Enter AP view.
wlan ap ap-name
3.        Specify a port to listen for messages from the location server.
rfid-tracking fingerprint vendor-port vendor-port-number
By default:
¡  In global configuration view, the port to listen is port 1144.
About the multicast MAC address for Tags
The destination MAC address of packets sent by Tags is the multicast MAC address defined by the manufacturer. Perform this task to specify the multicast MAC address for an AP to identify Tags.
If you do not specify a multicast MAC address for Tags, an AP determines that all received 802.11 packets are from MUs.
¡  Enter AP view.
wlan ap ap-name
3.        Specify a multicast MAC address for Tags.
rfid-tracking fingerprint tag-multicast-address mac-address
By default:
¡  In global configuration view, no multicast MAC address is specified for Tags.
About specifying the type of devices to locate
This feature enables an AP to send location information about only the specified type of devices to the location server.
¡  Enter AP view.
wlan ap ap-name
ap-model ap-model
radio radio-id
4.        Specify the type of devices to locate.
rfid-tracking mode { mu | tag } *
By default:
¡  In an AP group's radio view, the type of devices to locate is not specified.
About raw frame reporting
This feature enables an AP to encapsulate both the raw frames and the location information obtained from the frames in location packets.
¡  Enter AP view.
wlan ap ap-name
3.        Configure raw frame reporting.
rfid-tracking fingerprint raw-frame-report { disable | enable }
By default:
¡  In global configuration view, raw frame reporting is disabled.
About MU information reporting
This feature enables an AP to encapsulate MU information, including the IP address and the transmit rate of an MU in location packets.
¡  Enter AP view.
wlan ap ap-name
3.        Configure MU information reporting.
rfid-tracking fingerprint mu-report { disable | enable }
By default:
¡  In global configuration view, MU information reporting is disabled.
About location packet formats
RF fingerprinting supports the following location packet formats:
·          CUPID-hybrid—An AP encapsulates only clients' MAC addresses and RSSIs in location packets.
·          General—This format is applicable to most scenarios. Most third-party location servers support only the general format.
·          Lightweight—An AP encapsulates location information for several clients in one lightweight location packet to save bandwidth. This format is applicable to traffic-sensitive scenarios.
¡  Enter AP view.
wlan ap ap-name
3.        Specify the location packet format.
rfid-tracking fingerprint report-format { cupid-hybrid | general | light-weight }
By default:
¡  In global configuration view, an AP sends location packets in general format.
About location packet report modes
Both the AC (centralized report) and APs (local report) can report location packets to the location server. In centralized report mode, APs need to send location packets to the AC first.
¡  Enter AP view.
wlan ap ap-name
3.        Specify the report mode for location packets.
rfid-tracking fingerprint report-mode { central | local }
By default:
¡  In global configuration view, the local report mode is used.
About packet dilution
This feature enables an AP to send a location packet upon receiving the specific number of wireless packets or at the specified interval. This reduces the workloads of the location server and the AP.
For example, the dilution factor is 10 and the timeout timer is 5 seconds. If RF fingerprinting is enabled, the AP sends a location packet every time it receives 10 wireless packets from an MU client (excluding management and broadcast packets). If the AP fails to receive 10 packets from an MU client before the timeout timer expires, it sends the most recent wireless packet to the location server.
This feature takes effect only on MU clients for RF fingerprinting.
¡  Enter AP view.
wlan ap ap-name
3.        Enable packet dilution.
rfid-tracking dilution enable
By default:
¡  In global configuration view, packet dilution is disabled.
4.        Set the dilution factor and dilution timeout timer.
rfid-tracking dilution factor factor timeout timeout
By default:
¡  In global configuration view, the dilution factor and dilution timeout timer are not configured.
About ignoring beacon frames
Ignoring beacon frames prevents traffic flood.
This feature takes effect only when RF fingerprinting is configured.
¡  Enter AP view.
wlan ap ap-name
3.        Enable the AP to ignore beacon frames.
rfid-tracking ignore beacon enable
By default:
¡  In global configuration view, beacon frames are not ignored.
About ignoring AP frames
AP frames are frames that an AP received from other APs. Configure this feature if you do not need to locate or monitor APs.
¡  Enter AP view.
wlan ap ap-name
3.        Enable the AP to ignore AP frames.
rfid-tracking ignore ap-frame enable
By default:
¡  In global configuration view, AP frames are not ignored.
About RSSI-based packet filtering
When RSSI-based packet filtering is enabled, an AP does not report location information in packets with an RSSI lower than the RSSI threshold. This feature enables an AP to not locate clients far away from the AP.
¡  Enter AP view.
wlan ap ap-name
3.        Enable RSSI-based packet filtering.
rfid-tracking rssi enable
By default:
¡  In global configuration view, RSSI-based packet filtering is disabled.
4.        Set the RSSI threshold.
rfid-tracking rssi threshold rssi-threshold
By default:
¡  In global configuration view, the RSSI threshold is 5 (–123 dBm).
About client packet rate limiting
This feature enables an AP to not report location information from excessive client packets when both the CIR and CBS are exceeded. This practice ensures that the location information for each client can be sent to the location server and prevents client packets from flooding the AP.
If packet dilution is enabled, this feature limits the rate for diluted packets.
¡  Enter AP view.
wlan ap ap-name
3.        Enable client packet rate limiting.
rfid-tracking client rate-limit enable
By default:
¡  In global configuration view, client packet rate limiting is disabled.
4.        Set the CIR and CBS for client packets.
rfid-tracking client rate-limit cir cir [ cbs cbs ]
By default:
¡  In global configuration view, the CIR and CBS for client packets are not set.
About location packet rate limiting
This feature enables an AP to discard excessive location packets when both the CIR and CBS are exceeded. This practice prevents location packets from flooding the location server.
¡  Enter AP view.
wlan ap ap-name
3.        Enable location packet rate limiting.
rfid-tracking rate-limit enable
By default:
¡  In global configuration view, location packet rate limiting is disabled.
4.        Set the CIR and CBS for location packets.
rfid-tracking rate-limit cir cir [ cbs cbs ]
By default:
¡  In global configuration view, the CIR and CBS for location packets are not set.
About wireless location keepalive
This feature enables an AP to send Hello packets to the location server at an interval of 15 seconds. If the location server does not receive any packets from an AP within 30 seconds, the location server determines that the AP is offline.
Disable this feature to avoid bandwidth waste if the location server cannot process Hello packets.
¡  Enter AP view.
wlan ap ap-name
3.        Configure wireless location keepalive.
rfid-tracking keepalive { disable | enable }
By default:
¡  In global configuration view, wireless location keepalive is disabled.
Enabling SNMP notifications for wireless location
About SNMP notifications for wireless location
This feature enables the device to report critical wireless location events to an NMS. For wireless location event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
2.        Enable SNMP notifications for wireless location.
snmp-agent trap enable wlan location-aware
By default, SNMP notifications for wireless location are disabled.
Display and maintenance commands for wireless location
Display radio information for wireless location.
display wlan rfid-tracking radio [ ap apname ]
Wireless location configuration examples
Example: Configuring RF fingerprinting
As shown in Figure 2, configure RF fingerprinting for AP 1, AP 2, and AP 3 to locate the MUs.
Figure 2 Network diagram
1.        Configure AP 1:
# Create manual AP ap1, and specify the AP model and serial ID.
<AC> system-view
[AC] wlan ap ap1 model WA4320H
[AC-wlan-ap-ap1] serial-id 219801A0YG8165E00001
[AC-wlan-ap-ap1] quit
# Enable RF fingerprinting.
[AC-wlan-ap-ap1] rfid-tracking fingerprint enable
# Specify an IPv4 address and a port number for the location server.
[AC-wlan-ap-ap1] rfid-tracking fingerprint engine-address 192.168.10.10 engine-port 1145
# Specify a port to listen for messages from the location server.
[AC-wlan-ap-ap1] rfid-tracking fingerprint vendor-port 3000
# Enable radio-based location.
[AC-wlan-ap-ap1] radio 1
[AC-wlan-ap-ap1-radio-1] rfid-tracking radio enable
# Specify the type of devices to locate as MU.
[AC-wlan-ap-ap1-radio-1] rfid-tracking mode mu
# Enable radio 1 of AP 1.
[AC-wlan-ap-ap1-radio-1] quit
[AC] quit
2.        Configure AP 2 and AP 3 in the same way AP 1 is configured.
# Verify that RF fingerprinting is enabled and the type of devices to locate is MU for each AP.
<AC> display wlan rfid-tracking radio
                                 Wireless Locating
 AP                                 Radio   Type
 ap1                                1       MU
 ap2                                1       MU
 ap3                                1       MU
# Verify that you can view location information for the MUs by maps, forms, or reports provided by the graphics software. (Details not shown.)
