- 03-Layer 2 Command Reference
- 01-Ethernet Interface Commands
- 02-Loopback and Null Interface Commands
- 03-MAC Address Table Commands
- 04-Spanning Tree Commands
- 05-Loopback Detection Commands
- 06-VLAN Commands
- 07-Layer 2 Forwarding Commands
- 08-PPP Commands
- 09-Ethernet Link Aggregation Commands
- 10-DCC Commands
06-VLAN Commands | 154.59 KB |
Basic VLAN configuration commands
display interface vlan-interface
reset counters interface vlan-interface
Port-based VLAN configuration commands
MAC-based VLAN configuration commands
default
Use default to restore the default settings for a VLAN-interface.
default
VLAN-interface view
Default command level
2: System level
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. You can identify these commands by using the display this command in interface view, and then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
When you execute this command on VLAN interface 1, the IP address of the interface is deleted and will not be restored to the default address (192.168.0.50).
# Restore the default settings for VLAN-interface 2.
[Sysname-Vlan-interface2] default
This command will restore the default settings. Continue? [Y/N]:y
description
Use description to change the description of the VLAN or VLAN-interface.
The description for a VLAN is VLAN vlan-id, which is the ID of the VLAN. For example, the default description of VLAN 100 is VLAN 0100. The default description for a VLAN-interface is the name of the interface. For example, the default description of VLAN-interface 1 is Vlan-interface1 Interface.
VLAN view, VLAN-interface view
2: System level
text: Specifies a description for a VLAN or VLAN-interface. The string can include case-sensitive letters, digits, special characters such as tilde (~), exclamation point (!), at sign (@), pound sign (#), dollar sign ($), percent sign (%), caret (^), ampersand sign (&), asterisk (*), left brace({), right brace (}), left parenthesis ((), right parenthesis ()), left bracket ([), right bracket (]), left angle bracket (<), right angle bracket (>), hyphen (-), underscore(_), plus sign (+), equal sign (=), vertical bar (|), back slash (\), colon (:), semi-colon (;) quotation marks ("), apostrophe ('), comma (,), dot (.), and slash (/), spaces, and other Unicode characters and symbols.
· For a VLAN, this is a string of 1 to 32 characters.
· For a VLAN-interface, this is a string of 1 to 80 characters.
When you specify a description, follow these guidelines:
· Each Unicode character takes the space of two regular characters.
· To use Unicode characters or symbols in an interface description, install the specific input method editor and log in to the device through remote login software that supports the character type.
· When the length of a description string reaches or exceeds the maximum line width on the terminal software, the software starts a new line, possibly breaking a Unicode character into two and creating garbled characters at the end of a line.
Configure a description to describe the function or connection of a VLAN or VLAN-interface for easy management.
# Change the description of VLAN 2 to sales-private.
[Sysname] vlan 2
[Sysname-vlan2] description sales-private
# Change the description of VLAN-interface 2 to linktoPC56.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Vlan-interface2] description linktoPC56
· display interface vlan-interface
· display vlan
Use display interface vlan-interface to display information about a specified or all VLAN-interfaces.
display interface [ vlan-interface ] [ brief [ down ] ] [ | { begin | exclude | include } regular-expression ]
display interface vlan-interface vlan-interface-id [ brief ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
vlan-interface-id: Specifies a VLAN-interface number.
down: Displays information about interfaces in the DOWN state and the causes. If you do not specify this keyword, this command displays information about interfaces in all states.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If you do not provide the vlan-interface keyword, this command displays information about all interfaces.
If you provide the vlan-interface keyword but do not specify the VLAN-interface number, this command displays information about all VLAN-interfaces.
# Display information about VLAN-interface 10.
<Sysname> display interface vlan-interface 10
Vlan-interface10 current state: UP
Description: Vlan-interface10 Interface
The Maximum Transmit Unit is 1500
Internet Address is 192.168.1.54/24 Primary
IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0023-89b6-d613
IPv6 Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 0023-89b6-d613
# Display brief information for VLAN-interface 2.
<Sysname> display interface vlan-interface 2 brief
The brief information of interface(s) under route mode:
Protocol: (s) - spoofing
Interface Link Protocol Main IP Description
Vlan2 DOWN DOWN --
# Display brief information for VLAN-interfaces in DOWN state.
<Sysname> display interface vlan-interface brief down
Interface Link Cause
Vlan2 DOWN Not connected
Vlan-interface2 current state |
Physical state of a VLAN-interface: · DOWN (Administratively)—The administrative state of the VLAN-interface is down, because it has been shut down with the shutdown command. · DOWN—The administrative sate of the VLAN-interface is up, but its physical sate is down. The VLAN corresponding to this interface does not contain any physical port in the UP state (possibly because the ports are not well connected or the lines have failed). · UP—Both the administrative state and the physical state of the VLAN-interface are up. |
Line protocol current state |
Link layer protocol state of a VLAN-interface: · DOWN—The protocol state of the VLAN-interface is down. · UP—The protocol state of the VLAN-interface is up. |
Description string of a VLAN-interface. |
The Maximum Transmit Unit |
MTU of a VLAN-interface. |
Internet protocol processing : disabled |
The interface is not capable of processing IP packets. This information is displayed when the interface is not configured with an IP address. |
Internet Address is 192.168.1.54/24 Primary |
The primary IP address of the interface is 192.168.1.54/24. This information is displayed only if the primary IP address is configured for the interface. |
IP Packet Frame Type |
IPv4 outgoing frame format. |
Hardware address |
MAC address corresponding to a VLAN-interface. |
IPv6 Packet Frame Type |
IPv6 outgoing frame format. |
Last clearing of counters |
Time when the reset counters interface vlan-interface command was last used to clear the interface statistics. Never indicates the reset counters interface vlan-interface command has never been used on the interface after the device's startup. |
The brief information of interface(s) under route mode |
Brief information about Layer 3 interfaces. |
Link: ADM - administratively down; Stby - standby |
Link layer state of an interface: · ADM—The interface has been administratively shut down. To recover its physical state, use the undo shutdown command. · Stby—The interface is operating as a standby interface. To see the main interface, use the display standby state command. |
Protocol: (s) - spoofing |
If the network layer protocol state of an interface is shown as UP, but its link is an on-demand link or not present at all, its protocol attribute includes the spoofing flag (an s in parentheses). |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The link is up. · ADM—The link has been administratively shut down. To recover its physical state, use the undo shutdown command. |
Protocol |
Protocol connection state of the interface, which can be UP, DOWN, or UP(s). |
Main IP |
Main IP address of the interface. |
Description of the interface. |
Cause |
Cause of a DOWN physical link. If the port has been shut down with the shutdown command, this field displays Administratively. To restore the physical state of the interface, use the undo shutdown command. |
display vlan
Use display vlan to display VLAN information.
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
vlan-id1: Displays information about a VLAN specified by VLAN ID, ranging from 1 to 4094.
vlan-id1 to vlan-id2: Displays information about VLANs specified by a VLAN ID range. vlan-id2 must be no smaller than vlan-id1.
all: Displays all VLAN information but the reserved VLANs.
dynamic: Displays the number of dynamic VLANs and the ID for each dynamic VLAN. The dynamic VLANs are assigned by a RADIUS server.
reserved: Displays information about the reserved VLANs. Protocol modules determine which VLANs are reserved VLANs, according to function implementation, and reserved VLANs serve protocol modules. You cannot configure reserved VLANs.
static: Displays the number of static VLANs and the ID for each static VLAN. The static VLANs are manually created.
# Display VLAN 2 information.
<Sysname> display vlan 2
VLAN ID: 2
VLAN Type: static
Route interface: not configured
Description: VLAN 0002
Tagged Ports: none
Untagged Ports:
GigabitEthernet1/0/1 GigabitEthernet1/0/2
# Display VLAN 3 information.
<Sysname> display vlan 3
VLAN ID: 3
VLAN Type: static
Route Interface: configured
IP Address: 1.1.1.1
Subnet Mask: 255.255.255.0
Description: VLAN 0003
Tagged Ports: none
Untagged Ports: none
VLAN Type |
VLAN type, static or dynamic. |
Route interface |
Indicates whether the VLAN-interface is configured or not. |
Description of the VLAN. |
Name |
Name configured for the VLAN. |
IP Address |
Primary IP address of the VLAN-interface. This is available only when an IP address is configured for the VLAN-interface. To display secondary IP addresses, use the display interface vlan-interface command in any view or the display this command in VLAN-interface view. |
Subnet Mask |
Subnet mask of the primary IP address. This is available only when an IP address is configured for the VLAN-interface. |
Tagged Ports |
Ports through which VLAN packets are sent tagged. |
Untagged Ports |
Ports through which VLAN packets are sent untagged. |
vlan
Use interface vlan-interface to create a VLAN-interface and enter its view or enter the view of an existing VLAN-interface.
Use undo interface vlan-interface to remove the specified VLAN-interface.
undo interface vlan-interface vlan-interface-id
2: System level
vlan-interface-id: Specifies a VLAN-interface number, ranging from 1 to 4094.
Create the VLAN before you create the VLAN-interface.
To configure an IP address for a VLAN-interface that will perform IP routing, use the ip address command in VLAN-interface view.
# Create VLAN-interface 2, and enter its view.
[Sysname] vlan 2
ip address
Use ip address to assign an IP address and subnet mask to a VLAN-interface.
Use undo ip address to remove the IP address and subnet mask for a VLAN-interface.
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
The IP address of VLAN-interface 1 is 192.168.0.50. No IP addresses are assigned to other VLAN-interfaces.
VLAN-interface view
2: System level
ip-address: Specifies an IP address in dotted decimal notation.
mask: Specifies a subnet mask in dotted decimal notation.
mask-length: Sets the number of consecutive 1s in the subnet mask, ranging from 0 to 32.
sub: Indicates the address is a secondary IP address.
To connect a VLAN to multiple subnets, assign one primary IP address and multiple secondary IP addresses to a VLAN-interface. You can assign a maximum of two IP addresses to a VLAN-interface.
When you configure IP addresses for a VLAN-interface, follow these rules:
· The primary IP address you assign to a VLAN-interface overwrites the previous one, if any.
· Remove all secondary IP addresses before you remove the primary IP address.
· To remove all IP addresses, use the undo ip address command without any parameter.
· To remove the primary IP address, use the undo ip address ip-address { mask | mask-length } command.
· To remove a secondary IP address, use the undo ip address ip-address { mask | mask-length } sub command.
# Specify the IP address as 1.1.0.1, the subnet mask as 255.255.255.0 for VLAN-interface 1.
[Sysname-Vlan-interface1] ip address 1.1.0.1 255.255.255.0
display ip interface (Layer 3 Command Reference)
mtu
Use mtu to set the MTU for a VLAN-interface.
mtu size
undo mtu
The MTU of a VLAN-interface is 1500 bytes.
VLAN-interface view
2: System level
size: Sets the MTU in bytes. The value range for this argument is 46 to 1500.
# Set the MTU to 1492 bytes for VLAN-interface 1.
[Sysname-Vlan-interface1] mtu 1492
name
Use name to configure a name for the VLAN.
Use undo name to restore the default name of the VLAN.
name text
undo name
The name of a VLAN is VLAN vlan-id, which is its VLAN ID. For example, the default name of VLAN 100 is VLAN 0100.
VLAN view
2: System level
text: Specifies a VLAN name, a string of 1 to 32 characters. The string can include case-sensitive letters, digits, special characters such as tilde (~), exclamation point (!), at sign (@), pound sign (#), dollar sign ($), percent sign (%), caret (^), ampersand sign (&), asterisk (*), left brace({), right brace (}), left parenthesis ((), right parenthesis ()), left bracket ([), right bracket (]), left angle bracket (<), right angle bracket (>), hyphen (-), underscore(_), plus sign (+), equal sign (=), vertical bar (|), back slash (\), colon (:), semi-colon (;) quotation marks ("), apostrophe ('), comma (,), dot (.), and slash (/), spaces, and other Unicode characters and symbols.
When 802.1X or MAC address authentication is configured on the device, you can use a RADIUS server to issue VLAN configuration to ports that have passed the authentication. Some servers can send IDs or names of the issued VLANs to the device.
Use VLAN names, rather than VLAN IDs, to distinguish a large number of VLANs.
# Configure the name of VLAN 2 as Test VLAN.
[Sysname] vlan 2
[Sysname-vlan2] name Test VLAN
display vlan
Use reset counters interface vlan-interface to clear the statistics on a VLAN-interface.
reset counters interface vlan-interface [ vlan-interface-id ]
2: System level
Before collecting the traffic statistics within a specific period of time on an interface, clear the existing statistics first.
If the vlan-interface-id argument is not specified, this command clears the statistics of all VLAN-interfaces.
If the vlan-interface-id argument is specified, this command clears the statistics of the specified VLAN-interface.
# Clear the statistics on VLAN-interface 2.
<Sysname> reset counters interface vlan-interface 2
shutdown
Use shutdown to manually shut down a VLAN-interface.
Use undo shutdown to cancel the action of shutting down a VLAN-interface.
shutdown
A VLAN-interface is not manually shut down. The VLAN-interface is up if one or more ports in the VLAN is up, and goes down if all ports in the VLAN go down.
VLAN-interface view
2: System level
A VLAN-interface shut down with the shutdown command is in DOWN (Administratively) state until you bring it up, regardless of how the state of the ports in the VLAN changes.
Before configuring parameters for a VLAN-interface, shut down the VLAN-interface with the shutdown command to prevent the configurations from affecting the network. Use the undo shutdown command to bring up a VLAN-interface after you have configured related parameters and protocols for the VLAN-interface.
You can shut down a failed interface with the shutdown command and then bring it up with the undo shutdown command to see if it recovers.
In a VLAN, the state of any Ethernet port is independent of the state of the VLAN-interface.
# Shut down VLAN-interface 2, and then cancel the action of shutting it down.
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
vlan
Use vlan vlan-id to create a VLAN and enter its view or enter the view of an existing VLAN.
Use vlan vlan-id1 to vlan-id2 to create VLANs ranging from vlan-id1 to vlan-id2, except reserved VLANs.
Use undo vlan to remove the specified VLANs.
vlan { vlan-id1 [ to vlan-id2 ] }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
Only the default VLAN (VLAN 1) exists in the system.
2: System level
vlan-id1, vlan-id2: Specifies a VLAN ID, ranging from 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN range. vlan-id2 must be no smaller than vlan-id1.
all: Specifies all VLANs except reserved VLANs. The keyword is not supported when the maximum number of VLANs that can be created on a device is less than 4094.
You cannot create or remove the default VLAN (VLAN 1).
You cannot create or remove VLANs reserved for specific functions.
To remove the following VLANs, remove the related configurations first, because you cannot use the undo vlan command to directly remove them:
· Protocol reserved VLANs
· Management VLANs
· Dynamic VLANs
· VLANs configured with QoS policies
# Create VLAN 2, and enter VLAN 2 view.
[Sysname] vlan 2
[Sysname-vlan2]
# Create VLAN 4 through VLAN 100.
[Sysname] vlan 4 to 100
Please wait............. Done.
display vlan
display port
Use display port to display information about the hybrid or trunk ports on the device, including the port names, PVIDs, and allowed VLAN IDs.
display port { hybrid | trunk } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
hybrid: Displays hybrid ports.
trunk: Displays trunk ports.
# Display information about the hybrid ports in the system.
<Sysname> display port hybrid
Interface PVID VLAN passing
GE1/0/1 100 Tagged: 1000, 1002, 1500, 1600-1611, 2000,
2555-2558, 3000, 4000
Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
150-160, 200, 255, 286, 300-302
# Display information about the trunk ports in the system.
<Sysname> display port trunk
GE1/0/1 2 1-4, 6-100, 145, 177, 189-200, 244, 289, 400,
555, 600-611, 1000, 2006-2008
Port name. |
PVID |
Port VLAN ID. |
VLAN passing |
VLANs for which the port allows packets to pass through. |
Tagged |
VLANs for which the port sends packets without removing VLAN tags. |
Untagged |
VLANs for which the port sends packets after removing VLAN tags. |
port
Use port to assign the specified access ports to the VLAN.
Use undo port to remove the specified access ports from the VLAN.
port interface-list
undo port interface-list
All ports are in VLAN 1. All ports are access ports. However, you can manually configure the port type. For more information, see "port link-type."
VLAN view
2: System level
interface-list: Specifies an interface list, in the format of interface-list = { interface-type interface-number1 [ to interface-type interface-number2 ] }&<1-10>, where interface-type interface-number specifies an interface by its type and number and &<1-10> indicates that you can specify up to 10 ports or port ranges.
This command is only applicable on access ports.
You cannot assign Layer 2 aggregate interfaces to a VLAN.
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port GigabitEthernet 1/0/1 to GigabitEthernet 1/0/2
display vlan
port access vlan
Use port access vlan to assign the access ports to the specified VLAN.
Use undo port access vlan to restore the default.
port access vlan vlan-id
All access ports belong to VLAN 1.
Ethernet interface view, Layer 2 aggregate interface view, WLAN-BSS interface view
2: System level
vlan-id: Specifies a VLAN ID, ranging from 1 to 4094. Make sure the VLAN specified by the VLAN ID already exists.
The configuration made in Ethernet interface view or WLAN-BSS interface view applies only to the port.
The configuration made in Layer 2 aggregate interface view applies to the aggregate interface and its aggregation member ports.
· If the system fails to apply the configuration to the aggregate interface, it stops applying the configuration to aggregation member ports.
· If the system fails to apply the configuration to an aggregation member port, it skips the port and moves to the next member port.
# Assign GigabitEthernet 1/0/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname-GigabitEthernet1/0/1] port access vlan 3
# Assign Layer 2 aggregate interface Bridge-Aggregation 1 and its member ports to VLAN 3.
[Sysname] vlan 3
[Sysname-Bridge-Aggregation1] port access vlan 3
port hybrid pvid
Use port hybrid pvid to configure the PVID of the hybrid port.
Use undo port hybrid pvid to restore the default.
port hybrid pvid vlan vlan-id
The PVID of a hybrid port is VLAN 1.
2: System level
You can use a nonexistent VLAN as the PVID for a hybrid port. If you use the undo vlan command to remove the PVID of a hybrid port, it does not affect the setting of the PVID on the port.
H3C recommends that you set the same PVID for the local and remote hybrid ports.
You must use the port hybrid vlan command to configure the hybrid port to permit the packets from the PVID to pass through.
The configuration made in Ethernet or WLAN-BSS interface view applies only to the port.
# Configure VLAN 100 as the PVID of the hybrid port GigabitEthernet 1/0/1.
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-GigabitEthernet1/0/1] port link-type hybrid
[Sysname-GigabitEthernet1/0/1] port hybrid pvid vlan 100
# Configure VLAN 100 as the PVID of the hybrid Layer 2 aggregate interface Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] port link-type hybrid
[Sysname-Bridge-Aggregation1] port hybrid pvid vlan 100
· port hybrid vlan
· port link-type
port hybrid vlan
Use port hybrid vlan to assign the hybrid ports to the specified VLANs.
Use undo port hybrid vlan to remove the hybrid ports from the specified VLANs.
port hybrid vlan vlan-list { tagged | untagged }
undo port hybrid vlan vlan-list
A hybrid port only allows packets from VLAN 1 to pass through untagged.
2: System level
vlan-list: Specifies a list of VLANs that the hybrid ports will be assigned to in the format of { vlan-id1 [ to vlan-id2 ] }&<1-10>, where vlan-id1 and vlan-id2 represent VLAN IDs and each range from 1 to 4094, vlan-id2 must be no smaller than vlan-id1, and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges. Make sure the specified VLANs already exist.
tagged: Configures the ports to send the tagged packets of the specified VLANs.
untagged: Configures the ports to send the untagged packets of the specified VLANs.
A hybrid port can carry multiple VLANs. If you execute the port hybrid vlan command multiple times, the VLANs the hybrid port carries are the set of VLANs specified by vlan-list in each execution.
# Assign the hybrid port GigabitEthernet 1/0/1 to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100, and configure GigabitEthernet 1/0/1 to send packets of these VLANs with tags kept.
[Sysname-GigabitEthernet1/0/1] port hybrid vlan 2 4 50 to 100 tagged
# Assign the hybrid Layer 2 aggregate interface Bridge-Aggregation 1 and its member ports to VLAN 2, and configure them to send packets of VLAN 2 with tags removed.
[Sysname-Bridge-Aggregation1] port hybrid vlan 2 untagged
Please wait... Done.
Configuring GigabitEthernet1/0/1... Done.
Configuring GigabitEthernet1/0/2... Done.
The output shows that GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 are the member ports of the aggregation group corresponding to Bridge-Aggregation 1.
port link-type
port link-type
Use port link-type to configure the link type of a port.
Use undo port link-type to restore the default link type of a port.
undo port link-type
Any port is an access port.
2: System level
access: Configures the link type of a port as access.
hybrid: Configures the link type of a port as hybrid.
trunk: Configures the link type of a port as trunk. This keyword is not available in WLAN-BSS interface view.
To change the link type of a port from trunk to hybrid or vice versa, you must first set the link type to access.
After you change the link type of an interface with the port link-type command, the loopback detection action configured on the interface with the loopback-detection action command automatically restores the default.
# Configure GigabitEthernet 1/0/1 as a trunk port.
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 and its member ports as hybrid ports.
port trunk permit vlan
Use port trunk permit vlan to assign the trunk ports to the specified VLANs.
Use undo port trunk permit vlan to remove the trunk ports from the specified VLANs.
port trunk permit vlan { vlan-list | all }
undo port trunk permit vlan { vlan-list | all }
A trunk port allows only packets from VLAN 1 to pass through.
2: System level
vlan-list: Specifies a list of VLANs that the trunk ports will be assigned to in the format of { vlan-id1 [ to vlan-id2 ] }&<1-10>, where vlan-id1 and vlan-id2 represent VLAN IDs and each range from 1 to 4094, vlan-id2 must be no smaller than vlan-id1, and &<1-10> indicates that you can specify up to 10 VLAN IDs or VLAN ID ranges. Make sure the specified VLANs already exist.
all: Permits all VLANs to pass through the trunk ports.
A trunk port can carry multiple VLANs. If you execute the port trunk permit vlan command multiple times, the trunk port carries the set of VLANs specified by vlan-list in each execution.
On a trunk port, only traffic of the PVID can pass through untagged.
To prevent unauthorized VLAN users from accessing restricted resources, use the port trunk permit vlan all command with caution.
The configuration made in Ethernet interface view applies only to the port.
# Assign the trunk port GigabitEthernet 1/0/1 to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100.
[Sysname-GigabitEthernet1/0/1] port trunk permit vlan 2 4 50 to 100
Please wait........... Done.
# Assign the trunk Layer 2 aggregate interface Bridge-Aggregation 1 to VLAN 2.
[Sysname-Bridge-Aggregation1] port link-type trunk
[Sysname-Bridge-Aggregation1] port trunk permit vlan 2
port link-type
port trunk pvid
Use port trunk pvid to configure the PVID for the trunk port.
Use undo port trunk pvid to restore the default.
port trunk pvid vlan vlan-id
The PVID of a trunk port is VLAN 1.
2: System level
You can use a nonexistent VLAN as the PVID for a trunk port. If you use the undo vlan command to remove the PVID of a trunk port, it does not affect the setting of the PVID on the port.
The local and remote trunk ports must use the same PVID for the traffic of the PVID to be transmitted properly.
You must use the port trunk permit vlan command to configure the trunk port to allow and forward packets from the PVID.
# Configure VLAN 100 as the PVID of the trunk port GigabitEthernet 1/0/1, and assign GigabitEthernet 1/0/1 to VLAN 100.
[Sysname-GigabitEthernet1/0/1] port trunk pvid vlan 100
[Sysname-GigabitEthernet1/0/1] port trunk permit vlan 100
# Configure VLAN 100 as the PVID of the trunk Layer 2 aggregate interface Bridge-Aggregation 1, and assign Bridge-Aggregation 1 to VLAN 100.
[Sysname-Bridge-Aggregation1] port trunk pvid vlan 100
[Sysname-Bridge-Aggregation1] port trunk permit vlan 100
· port link-type
· port trunk permit vlan
display mac-vlan
Use display mac-vlan to display the specified MAC address-to-VLAN entries.
display mac-vlan { all | dynamic | mac-address mac-address [ mask mac-mask ] | static | vlan vlan-id } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays all the MAC address-to-VLAN entries.
dynamic: Displays dynamically configured MAC address-to-VLAN entries.
mac-address mac-address: Displays the MAC address-to-VLAN entry containing the specified MAC address.
mask mac-mask: Displays the MAC address-to-VLAN entries with their MAC addresses in the specified range.
static: Displays the statically configured MAC address-to-VLAN entries.
vlan vlan-id: Displays the MAC address-to-VLAN entries associated with the specified VLAN.
If mac-address mac-address is specified, but mask is not specified, only the MAC address-to-VLAN entry containing the specified MAC address is displayed.
# Display all the MAC address-to-VLAN entries.
<Sysname> display mac-vlan all
The following MAC-VLAN address exist:
S: Static D: Dynamic
MAC ADDR MASK VLAN ID PRIO STATE
0008-0001-0000 FFFF-FF00-0000 5 3 S
0002-0001-0000 FFFF-FFFF-FFFF 5 3 S&D
Total MAC VLAN address count:2
S: Static |
S stands for the MAC address-to-VLAN entries that are configured statically. |
D: Dynamic |
D stands for the MAC address-to-VLAN entries that are configured dynamically. |
MAC ADDR |
MAC address of a MAC address-to-VLAN entry. |
MASK |
Mask of the MAC address of a MAC address-to-VLAN entry. |
VLAN ID |
VLAN ID of a MAC address-to-VLAN entry. |
PRIO |
802.1p priority corresponding to the MAC address of a MAC address-to-VLAN entry. |
STATE |
State of a MAC address-to-VLAN entry: · S—The MAC address-to-VLAN entry is configured statically. · D—The MAC address-to-VLAN entry is configured automatically through the authentication server. · S&D—The MAC address-to-VLAN entry is configured both statically and dynamically. |
display mac-vlan interface
Use display mac-vlan interface to display all the ports with MAC-based VLAN enabled.
display mac-vlan interface [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display all the interfaces with MAC-based VLAN enabled.
<Sysname> display mac-vlan interface
MAC VLAN is enabled on following ports:
mac-vlan enable
mac-vlan enable
Use mac-vlan enable to enable the MAC-based VLAN feature on a port.
Use undo mac-vlan enable to disable the MAC-based VLAN feature on a port.
mac-vlan enable
The MAC-based VLAN feature is disabled on a port.
Layer 2 Ethernet interface view, WLAN-BSS interface view
2: System level
This command is available on only hybrid ports.
# Enable the MAC-based VLAN feature on GigabitEthernet 1/0/1.
[Sysname–GigabitEthernet1/0/1] mac-vlan enable
mac-vlan mac-address
Use mac-vlan mac-address to associate the specified VLAN and priority value with the specified MAC addresses.
Use undo mac-vlan to remove the association.
mac-vlan mac-address mac-address [ mask mac-mask ] vlan vlan-id [ priority pri ]
undo mac-vlan { all | mac-address mac-address [ mask mac-mask ] | vlan vlan-id }
No MAC-to-VLAN association is configured.
2: System level
mac-address mac-address: Specifies a MAC address.
mask mac-mask: Specifies a mask for the MAC address in the format of H-H-H. For the mac-mask argument, the high-order bits must be consecutive 1s in binary notation or consecutive Fs in hexadecimal notation. The default value is all Fs in hexadecimal notation.
vlan vlan-id: Specifies a VLAN ID, ranging from of 1 to 4094.
priority pri: Specifies the 802.1p priority value corresponding to the specified MAC address. The pri argument ranges from 0 to 7.
all: Removes all the static MAC address-to-VLAN entries.
Two MAC address-to-VLAN entry tables exist in a device. One table contains the MAC address-to-VLAN entries configured with the mask keyword specified. A MAC address-to-VLAN entry of this type describes the relationship between a group of MAC addresses and a VLAN, and a priority value. Another table contains the MAC address-to-VLAN entries configured without the mask keyword specified. A MAC address-to-VLAN entry of this type describes the relationship between a single MAC address and a VLAN, and a priority value. The system adds or removes MAC address-to-VLAN entries to or from the two tables according to the configuration.
# Associate a single MAC address 0-1-1 with VLAN 100 and 802.1p priority 7.
[Sysname] mac-vlan mac-address 0-1-1 vlan 100 priority 7
# Associate the MAC addresses with the high-order six hexadecimal digits being 121122 with VLAN 100 and 802.1p priority 4.
[Sysname] mac-vlan mac-address 1211-2222-3333 mask ffff-ff00-0000 vlan 100 priority 4
