04 Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesH3C S10500 Switch SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release757X-6W10004 Layer 2 - LAN Switching Command Reference
04-Port isolation commands
04-Port isolation commands 34.50 KB
display port-isolate group
Use display port-isolate group to display port isolation group information.
display port-isolate group [ group-id ]
group-id: Specifies an isolation group by its ID. The value range is 1 to 8.
# Display all isolation groups.
<Sysname> display port-isolate group
 Port isolation group information:
 Group ID: 1
 Group members:
    Ten-GigabitEthernet1/0/1
 Group ID: 5
 Group members:
    Ten-GigabitEthernet1/0/2            Ten-GigabitEthernet1/0/4
 Community VLAN ID: None
# Display information about isolation group 1.
<Sysname> display port-isolate group 1
 Group ID: 1
 Group members:
Group ID
ID of the isolation group.
Group members
Isolated ports in the isolation group. No ports indicates that the isolation group does not contain isolated ports.
Community VLAN ID
IDs of the community VLANs in the isolation group.
port-isolate enable
port-isolate enable
Use port-isolate enable to assign a port to an isolation group.
Use undo port-isolate enable to remove a port from an isolation group.
Devices that support only one isolation group:
port-isolate enable
Devices that support multiple isolation groups:
port-isolate enable group group-id
The port is not assigned to an isolation group.
group group-id: Specifies an isolation group by its ID. The value range is 1 to 8.
The configuration in Layer 2 Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
You cannot assign the member ports of a service loopback group to an isolation group, and vice versa.
To assign ports to an isolation group, make sure the isolation group already exists.
One port can be assigned to only one isolation group.
# Assign Ten-GigabitEthernet 1/0/1 and Ten-GigabitEthernet 1/0/2 to isolation group 1.
[Sysname-Ten-GigabitEthernet1/0/1] port-isolate enable group 1
[Sysname-Ten-GigabitEthernet1/0/2] port-isolate enable group 1
port-isolate group
Use port-isolate group to create an isolation group.
Use undo port-isolate group to delete isolation groups.
port-isolate group group-id
undo port-isolate group { group-id | all }
No isolation groups exist.
all: Deletes all isolation groups.
# Create isolation group 1.
[Sysname] port-isolate group 1
