13-IRF
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E5208P03 E5215P01 R5215P01)-6W10213-IRF
Table of Contents
Related Documents
00-Preface
00-Preface 62.86 KB
Preface
The H3C access controllers documentation set describes the software features for the H3C access controllers and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The IRF Configuration Guide describes the fundamentals and configuration procedures that help you set up and maintain an IRF fabric in star topology.
·     Hardware and software compatibility matrix
·     Audience
·     Conventions
·     Documentation feedback
Table 1 Hardware and software compatibility matrix
Hardware series
Model
Product version
WX1800H series
·     WX1804H
·     WX1810H
·     WX1820H
·     WX1804H-CMW710-E5208P03
·     WX1810H-CMW710-E5215P01
·     WX1820H-CMW710-E5208P03
WX2500H series
·     WX2510H
·     WX2540H
·     WX2560H
·     WX2510H-CMW710-R5215P01
·     WX2540H-CMW710-R5215P01
·     WX2560H-CMW710-R5215P01
WX3000H series
·     WX3010H
·     WX3010H-L
·     WX3010H-X
·     WX3024H
·     WX3024H-L
·     WX3010H-CMW710-R5215P01
·     WX3010HL-CMW710-R5215P01
·     WX3010HX-CMW710-R5215P01
·     WX3024H-CMW710-R5215P01
·     WX3024HF-CMW710-R5215P01
·     WX3024HL-CMW710-R5215P01
WX3500H series
·     WX3508H
·     WX3510H
·     WX3520H
·     WX3540H
·     WX3510H-CMW710-R5215P01
·     WX3520H-CMW710-R5215P01
·     WX3540H-CMW710-R5215P01
WX5500E series
·     WX5510E
·     WX5540E
·     WX5510E-CMW710-R5215P01
·     WX5540E-CMW710-R5215P01
WX5500H series
·     WX5540H
·     WX5560H
·     WX5580H
·     WX5540H-CMW710-R5215P01
·     WX5560H-CMW710-R5215P01
·     WX5580H-CMW710-R5215P01
Access controller modules
·     EWPXM1MAC0F
·     EWPXM1WCME0
·     EWPXM2WCMD0F
·     LSQM1WCMX20
·     LSQM1WCMX40
·     LSUM1WCME0
·     LSUM1WCMX20RT
·     LSUM1WCMX40RT
·     WCMX40-CMW710-R5215P01
·     WCMX20-CMW710-R5215P01
Audience
·     Network planners.
·     Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
Wireless terminator unit.
Wireless terminator.
We appreciate your comments.
