- 01-Fundamentals
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-Device management configuration
- 09-Tcl configuration
- 10-Python configuration
- 11-License management
- 12-Automatic configuration
00-Preface | 62.93 KB |
Preface
The H3C access controllers documentation set describes the software features for the H3C access controllers and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The Fundamentals Configuration Guide describes using the CLI, RBAC, login management, FTP and TFTP, file system management, configuration file management, software upgrade, device management, Tcl, Python, and license management configurations.
· Hardware and software compatibility matrix
· Audience
Table 1 Hardware and software compatibility matrix
Model |
Product version |
WX1800H series |
· WX1804H · WX1810H · WX1820H |
· WX1804H-CMW710-E5208P03 · WX1810H-CMW710-E5215P01 · WX1820H-CMW710-E5208P03 |
WX2500H series |
· WX2510H · WX2540H · WX2560H |
· WX2510H-CMW710-R5215P01 · WX2540H-CMW710-R5215P01 · WX2560H-CMW710-R5215P01 |
WX3000H series |
· WX3010H · WX3010H-L · WX3010H-X · WX3024H · WX3024H-L |
· WX3010H-CMW710-R5215P01 · WX3010HL-CMW710-R5215P01 · WX3010HX-CMW710-R5215P01 · WX3024H-CMW710-R5215P01 · WX3024HL-CMW710-R5215P01 |
WX3500H series |
· WX3508H · WX3510H · WX3520H · WX3540H |
· WX3510H-CMW710-R5215P01 · WX3520H-CMW710-R5215P01 · WX3540H-CMW710-R5215P01 |
WX5500E series |
· WX5510E · WX5540E |
· WX5510E-CMW710-R5215P01 · WX5540E-CMW710-R5215P01 |
WX5500H series |
· WX5540H · WX5560H · WX5580H |
· WX5540H-CMW710-R5215P01 · WX5560H-CMW710-R5215P01 · WX5580H-CMW710-R5215P01 |
Access controller modules |
· EWPXM1MAC0F · EWPXM1WCME0 · EWPXM2WCMD0F · LSQM1WCMX20 · LSQM1WCMX40 · LSUM1WCME0 · LSUM1WCMX20RT · LSUM1WCMX40RT |
· WCMX40-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 · WCMX20-CMW710-R5215P01 · WCMX20-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 · WCMX20-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 |
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
WARNING! |
CAUTION: |
IMPORTANT: |
NOTE: |
TIP: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
